SLC NAND & BENAND
NAND FLASH MEMORY
Reliability and Performance
Toshiba’s SLC NAND advanced flash memory
products provide cutting-edge endurance and data
retention for sensitive or frequently used system data.
For long-lasting products or systems working with
extremely high data throughput between the host and
the memory, Toshiba's SLC is a suitable solution.
Toshiba’s new BENAND™ removes the burden of
error correction code (ECC) from the host processor
by embedding ECC directly in the hardware while
maintaining the same specifications, reliability and
performance as raw SLC NAND.
APPLICATIONS
FLASH
INVENTOR OF
Industrial
Consumer Electronics
Multimedia
Smart Metering & Intelligent Lighting
M
FEATURES
ADVANTAGES
SLC NAND 24nm
• 1Gb – 128Gb
• Extended temperature range
• TSOP and BGA package
BENAND 24nm
Built-in ECC SLC NAND
1Gb – 8Gb
On-chip H/W ECC
Same reliability and performance
as raw SLC
Same hardware interface and
package as raw SLC
E
M O R
Y
BENEFITS
Broad lineup to meet customer
demand for different densities
24nm technology for cost optimization
Long data retention, extreme write/
erase performance
Small package available to reduce
board space
No ECC operation is required on the
host side (BENAND)
Produced in Toshiba's cutting-edge
technology flash factory
A suitable solution for long-lasting
storage of significant or frequently
changed data
Reduced BOM cost due to latest
24nm production technology
Supports smaller board size (e.g.
for mobile devices)
Using Toshiba BENAND, it is
possible to utilize the latest 24nm
SLC NAND flash technology even
if the existing platform cannot
support higher bit ECC. No
hardware change necessary.
SPECIFICATIONS
Product / Features
SLC NAND
BENAND™ (SLC+ECC)
1Gb – 128Gb
Density
Technology
1Gb – 8Gb
24nm
Required on Host Side
ECC (Error Correction Code)
Embedded on Memory Chip
-40°C to 85°C
0°C to 70°C
Temperature
Package
TSOP and BGA
BENAND – SLC WITH EMBEDDED ECC FOR BOM REDUCTION AND SYSTEM FLEXIBILITY
BENAND
Raw SLC NAND 24nm
8bit
ECC
Data read from the SLC is
already error corrected
HOST SYSTEM
Main CPU
Memory Controller
Raw SLC NAND 43nm
not error corrected
1bit ECC
www.toshiba.semicon-storage.com
SLC NAND – PRODUCT LIST
Density
1Gb
2Gb
4Gb
8Gb
16Gb
32Gb
64Gb
128Gb
Part Number
TC58NVG0S3HTA00
TC58NYG0S3HBAI4
TC58NVG0S3HTAI0
TC58NVG0S3HBAI4
TC58NYG0S3HBAI6
TC58NVG0S3HBAI6
TC58NVG1S3HTA00
TC58NYG1S3HBAI4
TC58NVG1S3HTAI0
TC58NVG1S3HBAI4
TC58NYG1S3HBAI6
TC58NVG1S3HBAI6
TH58NVG2S3HTA00
TC58NVG2S0HTA00
TC58NVG2S0HTAI0
TH58NVG2S3HTAI0
TH58NVG2S3HBAI4
TH58NYG2S3HBAI4
TC58NVG2S0HBAI4
TC58NYG2S0HBAI4
TC58NVG2S0HBAI6
TC58NYG2S0HBAI6
TH58NVG3S0HTA00
TH58NVG3S0HBAI4
TH58NYG3S0HBAI4
TH58NVG3S0HTAI0
TH58NVG3S0HBAI6
TH58NYG3S0HBAI6
TH58NVG4S0FTA20
TH58NVG4S0FTAK0
TH58NVG4S0FBAID
TH58NVG4S0HTA20
TH58NVG4S0HTAK0
TC58NVG5H2HTA00
TC58NVG5H2HTAI0
TH58NVG6H2HTAK0
TH58NVG7H2HTA20
Techn.
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
32nm
32nm
32nm
24nm
24nm
24nm
24nm
24nm
24nm
Page Size
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(4096+256)x8 bit
(8192+1024)x8 bit
(8192+1024)x8 bit
(8192+1024)x8 bit
(8192+1024)x8 bit
Vcc
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
1.8V
3.3V
1.8V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
ECC
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
4bit/512B
4bit/512B
4bit/512B
8bit/512B
8bit/512B
24bit/1024B
24bit/1024B
24bit/1024B
24bit/1024B
Temperature
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
Package
48TSOP 12x20
63BGA 9x11
48TSOP 12x20
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
63BGA 9x11
48TSOP 12x20
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
63BGA 9x11
63BGA 9x11
63BGA 9x11
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
63BGA 9x11
63BGA 9x11
48TSOP 12x20
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
48TSOP 12x20
63BGA 10x11
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
Page Size
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(2048+64)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
(4096+128)x8 bit
Vcc
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
3.3V
3.3V
3.3V
3.3V
1.8V
3.3V
1.8V
3.3V
1.8V
1.8V
3.3V
1.8V
3.3V
3.3V
3.3V
1.8V
ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
Temperature
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
Package
48TSOP 12x20
63BGA 9x11
48TSOP 12x20
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
63BGA 9x11
48TSOP 12x20
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
63BGA 9x11
63BGA 9x11
63BGA 9x11
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
67BGA 6.5x8
48TSOP 12x20
63BGA 9x11
48TSOP 12x20
63BGA 9x11
67BGA 6.5x8
67BGA 6.5x8
BENAND™ – PRODUCT LIST
Density
1Gb
2Gb
4Gb
8Gb
Part Number
TC58BVG0S3HTA00
TC58BYG0S3HBAI4
TC58BVG0S3HTAI0
TC58BVG0S3HBAI4
TC58BYG0S3HBAI6
TC58BVG0S3HBAI6
TC58BVG1S3HTA00
TC58BYG1S3HBAI4
TC58BVG1S3HTAI0
TC58BVG1S3HBAI4
TC58BYG1S3HBAI6
TC58BVG1S3HBAI6
TH58BVG2S3HTA00
TC58BVG2S0HTA00
TC58BVG2S0HTAI0
TH58BVG2S3HTAI0
TH58BVG2S3HBAI4
TH58BYG2S3HBAI4
TC58BVG2S0HBAI4
TC58BYG2S0HBAI4
TC58BVG2S0HBAI6
TC58BYG2S0HBAI6
TH58BYG2S3HBAI6
TH58BVG3S0HTA00
TH58BYG3S0HBAI4
TH58BVG3S0HTAI0
TH58BVG3S0HBAI4
TH58BVG3S0HBAI6
TH58BYG3S0HBAI6
Techn.
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
BENAND™ is the trademark of Toshiba Corporation.
Product density is identified based on the maximum density of memory chip(s) within the Product, not the amount of memory capacity available for data storage by the end user
Consumer-usable capacity will be less due to overhead data areas, formatting, bad blocks, and other constraints, and may also vary based on the host device and application.
Maximum read and write speed may vary depending on the host device, read and write conditions, and file size.
Copyright August 2016 Toshiba America Electronic Components, Inc. (TAEC) - All Rights Reserved
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Kioxia:
TC58NVG1S3HTAI0 TC58NVG0S3HBAI4 TC58NVG2S0HTA00 TC58NVG1S3HBAI4 TC58NVG0S3HTAI0
TH58NVG2S3HTAI0 TH58BVG2S3HTAI0 TH58NVG3S0HTA00 TH58BYG2S3HBAI6 TH58NVG3S0HTAI0
TH58BVG2S3HTA00 TH58NVG2S3HTA00 TC58NVG2S0HBAI6 TC58NVG2S0HTAI0 TC58NYG2S0HBAI6
TC58NYG1S3HBAI4 TH58BYG2S3HBAI4 TH58NVG3S0HBAI4 TC58NYG2S0HBAI4 TH58BVG2S3HBAI4
TH58NYG2S3HBAI4 TC58NYG0S3HBAI6 TC58NYG1S3HBAI6 TC58NVG0S3HBAI6 TC58NVG1S3HBAI6
TC58NVG1S3HTA00 TH58NYG3S0HBAI6 TC58NVG0S3HTA00 TH58NYG3S0HBAI4 TH58NVG3S0HBAI6
TH58NVG2S3HBAI4 TC58NVG2S0HBAI4 TC58NYG0S3HBAI4
很抱歉,暂时无法提供与“TH58NYG2S3HBAI4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+64.653121+8.40333
- 10+49.7635110+6.46805
- 国内价格
- 1+26.28720
- 210+10.49760
- 420+10.14120
- 1050+9.96840
