SK86C V7G
SK86C V7G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    电压:60V
SK86C V7G 数据手册
SK82C – SK810C Taiwan Semiconductor 8A, 20V - 100V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 8 A VRRM 20 - 100 V IFSM 150 A TJ MAX 125, 150 °C Package DO-214AB (SMC) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.210g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SK 82C SK 82C 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SK 83C SK 83C 30 SK 84C SK 84C 40 SK 85C SK 85C 50 SK 86C SK 86C 60 SK 810C SK 810C 100 21 28 35 42 70 UNIT V V IF 8 A IFSM 150 A dV/dt 10,000 V/µs TJ - 55 to +125 TSTG - 55 to +150 - 55 to +150 1 °C °C Version: L2102 SK82C – SK810C Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance SYMBOL TYP UNIT RӨJA 20 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SK82C SK83C SK84C SK85C SK86C SK810C (1) Reverse current @ rated VR Reverse current @ rated VR (2) (2) IF = 8A, TJ = 25°C TJ = 25°C SK82C SK83C SK84C SK85C SK86C SK810C SYMBOL VF IR TJ = 100°C TYP MAX UNIT - 0.55 V - 0.75 V - 0.90 V - 0.5 mA - 15 mA - 10 mA IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SK8xC DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SK82C) to 100V(SK810C) 2 Version: L2102 SK82C – SK810C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SK85C - SK810C 8 CAPACITANCE (pF) 6 SK82C - SK84C 4 1000 SK82C - SK84C 100 SK85C - SK86C 2 0 10 25 50 75 100 125 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=75°C 0.1 TJ=25°C 0.01 0.001 0.0001 10 20 30 40 50 60 70 80 90 100 100 10 10 1 SK82C - SK84C UF1DLW TJ=125°C TJ=25°C 0.1 SK85C - SK86C 1 SK810C 0.01 0.1 0.001 0.1 Pulse width 300μs 1% duty cyclePulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.3 0.4 0.5 0.5 0.7 0.9 0.6 0.7 0.8 1.1 0.9 1.3 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) SK82C - SK84C SK85C - SK810C 10 1 100 Fig.4 Typical Forward Characteristics 1000 TJ=125°C 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 SK810C f=1.0MHz Vsig=50mVp-p (A) AVERAGE FORWARD CURRENT (A) 10 8.3ms single half sine wave 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: L2102 1.2 SK82C – SK810C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: L2102 SK82C – SK810C Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: L2102 SK82C – SK810C Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2102
SK86C V7G 价格&库存
很抱歉,暂时无法提供与“SK86C V7G”相匹配的价格&库存,您可以联系我们找货
