GD25LX256EBIRY
GD25LX256EBIRY
    GIGADEVICE(兆易创新)
    TBGA24
    GD25LX256EBIRY
GD25LX256EBIRY 数据手册
Uniform Sector Standard and Quad Serial Flash GD25LT256E DATASHEET 1 GD25LT256E Uniform Sector Standard and Quad Serial Flash GD25LT256E Contents 1 FEATURES .........................................................................................................................................................5 2 GENERAL DESCRIPTIONS..............................................................................................................................6 3 MEMORY ORGANIZATION ............................................................................................................................. 10 4 DEVICE OPERATIONS.................................................................................................................................... 11 4.1 SPI MODE ............................................................................................................................................................ 11 4.2 QPI MODE............................................................................................................................................................ 11 4.3 QUAD DTR MODE ................................................................................................................................................. 11 4.4 RESET FUNCTION .................................................................................................................................................. 11 4.5 ECC FUNCTION ...................................................................................................................................................... 12 4.6 DATA STROBE FUNCTION ......................................................................................................................................... 12 5 DATA PROTECTION ........................................................................................................................................ 13 6 DATA INTEGRITY CHECK .............................................................................................................................. 15 7 8 9 6.1 ECC (ERROR CHECKING AND CORRECTING) ................................................................................................................. 15 6.2 ECS# (ERROR CORRECTED SIGNAL) PIN ...................................................................................................................... 16 6.3 PARITY CHECK (CRC) .............................................................................................................................................. 16 REGISTERS...................................................................................................................................................... 17 7.1 STATUS REGISTER ................................................................................................................................................... 17 7.2 FLAG STATUS REGISTER ........................................................................................................................................... 18 7.3 EXTENDED ADDRESS REGISTER .................................................................................................................................. 19 INTERNAL CONFIGURATION REGISTER ................................................................................................... 21 8.1 NONVOLATILE CONFIGURATION REGISTER ................................................................................................................... 21 8.2 VOLATILE CONFIGURATION REGISTER ......................................................................................................................... 23 8.3 SUPPORTED CLOCK FREQUENCIES .............................................................................................................................. 26 8.4 DATA SEQUENCE WRAPS BY DENSITY ......................................................................................................................... 27 COMMAND DESCRIPTIONS .......................................................................................................................... 28 9.1 ENABLE 4-BYTE MODE (B7H) .................................................................................................................................. 33 9.2 DISABLE 4-BYTE MODE (E9H) .................................................................................................................................. 33 9.3 WRITE ENABLE (WREN) (06H) ................................................................................................................................ 34 9.4 WRITE DISABLE (WRDI) (04H) ................................................................................................................................ 34 9.5 WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) ................................................................................................. 35 9.6 WRITE STATUS REGISTER (WRSR) (01H) ................................................................................................................... 35 9.7 WRITE EXTENDED ADDRESS REGISTER (C5H)............................................................................................................... 36 9.8 WRITE NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B1H/81H) ......................................................................... 37 9.9 READ STATUS REGISTER (05H) ................................................................................................................................. 38 2 Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.10 READ FLAG STATUS REGISTER (70H) .......................................................................................................................... 39 9.11 READ NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B5H/85H) ........................................................................... 40 9.12 READ EXTENDED ADDRESS REGISTER (C8H) ................................................................................................................ 41 9.13 READ DATA BYTES (03H/13H) ................................................................................................................................ 42 9.14 READ DATA BYTES AT HIGHER SPEED (0BH/0CH) ........................................................................................................ 43 9.15 QUAD OUTPUT FAST READ (6BH/6CH) ..................................................................................................................... 44 9.16 QUAD I/O FAST READ (EBH/ECH) ........................................................................................................................... 45 9.17 QUAD I/O DTR READ (EDH/EEH) ........................................................................................................................... 47 9.18 PAGE PROGRAM (PP) (02H/12H) ............................................................................................................................ 49 9.19 QUAD PAGE PROGRAM (32H/34H) .......................................................................................................................... 50 9.20 EXTEND QUAD PAGE PROGRAM (C2H/3EH) .............................................................................................................. 52 9.21 SECTOR ERASE (SE) (20H/21H) ............................................................................................................................... 53 9.22 32KB BLOCK ERASE (BE32) (52H/5CH) ................................................................................................................... 54 9.23 64KB BLOCK ERASE (BE64) (D8H/DCH) .................................................................................................................. 55 9.24 CHIP ERASE (CE) (60/C7H) ..................................................................................................................................... 56 9.25 ENABLE QPI (38H) ................................................................................................................................................ 57 9.26 DISABLE QPI (FFH) ................................................................................................................................................ 57 9.27 DEEP POWER-DOWN (DP) (B9H) ............................................................................................................................. 57 9.28 RELEASE FROM DEEP POWER-DOWN (ABH) ............................................................................................................... 58 9.29 READ UNIQUE ID (4BH) .......................................................................................................................................... 59 9.30 READ IDENTIFICATION (RDID) (9FH/9EH) ................................................................................................................. 60 9.31 PROGRAM/ERASE SUSPEND (PES) (75H) ................................................................................................................... 61 9.32 PROGRAM/ERASE RESUME (PER) (7AH) ................................................................................................................... 62 9.33 ERASE SECURITY REGISTERS (44H) ............................................................................................................................ 63 9.34 PROGRAM SECURITY REGISTERS (42H) ....................................................................................................................... 64 9.35 READ SECURITY REGISTERS (48H) ............................................................................................................................. 65 9.36 INDIVIDUAL BLOCK/SECTOR LOCK (36H)/UNLOCK (39H)/READ (3DH) ........................................................................... 66 9.37 GLOBAL BLOCK/SECTOR LOCK (7EH) OR UNLOCK (98H) ............................................................................................... 69 9.38 ENABLE RESET (66H) AND RESET (99H) ..................................................................................................................... 69 9.39 READ SERIAL FLASH DISCOVERABLE PARAMETER (5AH)................................................................................................. 70 10 ELECTRICAL CHARACTERISTICS .......................................................................................................... 72 10.1 POWER-ON TIMING ................................................................................................................................................ 72 10.2 INITIAL DELIVERY STATE ........................................................................................................................................... 72 10.3 ABSOLUTE MAXIMUM RATINGS ................................................................................................................................ 72 10.4 CAPACITANCE MEASUREMENT CONDITIONS................................................................................................................. 73 10.5 DC CHARACTERISTICS .............................................................................................................................................. 74 10.6 AC CHARACTERISTICS .............................................................................................................................................. 77 11 ORDERING INFORMATION........................................................................................................................ 86 11.1 12 12.1 VALID PART NUMBERS ............................................................................................................................................ 87 PACKAGE INFORMATION ......................................................................................................................... 88 PACKAGE SOP16 300MIL ...................................................................................................................................... 88 3 Uniform Sector Standard and Quad Serial Flash GD25LT256E 12.2 PACKAGE WSON8 (8X6MM) ................................................................................................................................... 89 12.3 PACKAGE TFBGA-24BALL (5X5 BALL ARRAY) ............................................................................................................. 90 13 REVISION HISTORY .................................................................................................................................... 91 4 Uniform Sector Standard and Quad Serial Flash GD25LT256E 1 FEATURES ◆ 256M-bit Serial Flash ◆ Fast Program/Erase Speed - 32M-Byte - Page Program time: 0.3ms typical - 256 Bytes per programmable page - Sector Erase time: 30ms typical - Block Erase time: 0.1/0.2s typical ◆ Standard, Quad SPI, DTR,QPI - Chip Erase time: 50s typical - Standard SPI: SCLK, CS#, SI, SO, WP#, RESET# - Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# ◆ Flexible Architecture - QPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# - Sector of 4K-Byte - SPI DTR (Double Transfer Rate) Read - Block of 32/64K-Byte - 3 or 4-Byte Address Mode - Erase/Program Suspend/Resume ◆ High Speed Clock Frequency ◆ Low Power Consumption - 200MHz for fast read - 20μA typical stand-by current - Quad I/O Data transfer up to 664Mbits/s - 5μA typical power-down current - QPI Mode Data transfer up to 664Mbits/s - DTR Quad I/O Data transfer up to 200MBytes/s with DQS ◆ Advanced Security Features - 128-bit Unique ID ◆ Allows XIP (eXecute in Place) Operation - 4K-Byte Security Registers With OTP Lock - High speed Read reduce overall XiP instruction fetch time - Continuous Read with Wrap further reduce data latency to fill up SoC cache ◆ Single Power Supply Voltage - Full voltage range: 1.65~2.0V ◆ Software/Hardware Write Protection ◆ Endurance and Data Retention - Write protect all/portion of memory via software - Minimum 100,000 Program/Erase Cycles - Enable/Disable protection with WP# Pin - 20-year data retention typical - Individual Block Protection ◆ Package Information ◆ Data Integrity Check - On-chip ECC (1-bit correction every - SOP16 300mil 8-Byte) (1) - WSON8 (8x6mm) - CRC detects accidental changes to raw data - TFBGA-24ball (5x5 Ball Array) Note: 1. When ECC is enabled, it is required to program minimum one or multiple aligned 8-Byte granularities. Every aligned 8Byte granularity should only be programmed once before Erase to ensure correct ECC operations. 5 Uniform Sector Standard and Quad Serial Flash 2 GD25LT256E GENERAL DESCRIPTIONS The GD25LT256E (256M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Quad SPI and DTR mode: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), I/O3,DQS, ECS# and RESET#. The Quad I/O & Quad output data is transferred with speed of 83MBytes/s, and the DTR Quad I/O data is transferred with speed of 200MBytes/s. CONNECTION DIAGRAM AND PIN DESCRIPTION Figure 1 Connection Diagram for SOP16 package IO3 1 16 SCLK VCC 2 15 SI (IO0) RESET# 3 14 NC NC 4 13 DQS Top View NC 5 12 NC DNU 6 11 DNU CS# 7 10 VSS SO (IO1) 8 9 WP# (IO2) 16-LEAD SOP Table 1 Pin Description for SOP16 package Pin No. Pin Name I/O Description 1 IO3 I/O Data Input Output 3 2 VCC 3 RESET# 6/11 DNU 7 CS# I 8 SO (IO1) I/O Data Output (Data Input Output 1) 9 WP# (IO2) I/O Data Input Output 2 10 VSS 13 DQS O Data Strobe Signal Output 15 SI (IO0) I/O Data Input (Data Input Output 0) 16 SCLK I Power Supply I Reset Input Do Not Use (It may connect to internal signal inside) Chip Select Input Ground Serial Clock Input Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. The DNU pin must be floating. It may connect to internal signal inside. 3. The NC pin is not connected to any internal signal. It is OK to connect it to the system ground (GND) or leave it floating. 6 Uniform Sector Standard and Quad Serial Flash GD25LT256E 4. RESET# will remain internal pull up function while this pin is not physically connected in system configuration. However, the internal pull up function will be disabled if the system has physical connection to RESET#. Figure 2 Connection Diagram for WSON8 package CS# 1 SO (IO1) 2 WP# (IO2) 3 6 SCLK VSS 4 5 8 VCC 7 IO3 Top View SI (IO0) 8–LEAD WSON Table 2 Pin Description for WSON8 package Pin No. Pin Name I/O Description 1 CS# I 2 SO (IO1) I/O Data Output (Data Input Output 1) 3 WP# (IO2) I/O Write Protect Input (Data Input Output 2) 4 VSS 5 SI (IO0) I/O 6 SCLK I 7 IO3 I/O 8 VCC Chip Select Input Ground Data Input (Data Input Output 0) Serial Clock Input Data Input Output 3 Power Supply Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 7 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 3 Connection Diagram for TFBGA24 5x5 ball array package Top View A2 A3 A4 A5 RESET# ECS# NC NC B1 B2 B3 B4 B5 NC SCLK VSS VCC NC C1 C2 C3 C4 C5 CS# DQS WP# (IO2) DNU D2 D3 VSS D1 VCC SO(IO1) SI(IO0) D4 D5 IO3 NC E1 E2 E3 E4 E5 NC NC NC VCC VSS 24-BALL TFBGA (5x5 ball array) Table 3 Ball Description for TFBGA24 5x5 ball array package Pin No. Pin Name I/O Description A4 RESET# I Reset Input A5 ECS# O ECC Correction Signal (Open Drain) B2 SCLK I Serial Clock Input B3/C1/E5 VSS Ground B4/D1/E4 VCC Power Supply C2 CS# I Chip Select Input C3 DQS O Data Strobe Signal Output C4 WP# (IO2) I/O Data Input Output 2 C5 DNU D2 SO (IO1) I/O Data Output (Data Input Output 1) D3 SI (IO0) I/O Data Input (Data Input Output 0) D4 IO3 I/O Data Input Output 3 Do Not Use (It may connect to internal signal inside) Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. The DNU ball must be floating. It may connect to internal signal inside. 3. The NC ball is not connected to any internal signal. It is OK to connect it to the system ground (GND) or leave it floating. 4. RESET# will remain internal pull up function while this pin is not physically connected in system configuration. However, the internal pull up function will be disabled if the system has physical connection to RESET#. 8 Uniform Sector Standard and Quad Serial Flash GD25LT256E BLOCK DIAGRAM Write Control Logic Status Register RESET# IO2 IO3 SCLK CS# SI(IO0) SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Flash Memory Column Decode And 256-Byte Page Buffer SO(IO1) DQS ECS# Write Protect Logic and Row Decode WP# Byte Address Latch/Counter 9 Uniform Sector Standard and Quad Serial Flash 3 GD25LT256E MEMORY ORGANIZATION GD25LT256E Each device has Each block has Each sector has Each page has 32M 64/32K 4K 256 Bytes 128K 256/128 16 - pages 8K 16/8 - - sectors 512/1K - - - blocks UNIFORM BLOCK SECTOR ARCHITECTURE GD25LT256E 64K Bytes Block Sector Architecture Block 511 510 …… …… 2 1 0 Sector Address range 8191 1FFF000H 1FFFFFFH …… …… …… 8176 1FF0000H 1FF0FFFH 8175 1FEF000H 1FEFFFFH …… …… …… 8160 1FE0000H 1FE0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH 10 Uniform Sector Standard and Quad Serial Flash GD25LT256E 4 DEVICE OPERATIONS 4.1 SPI Mode Standard SPI The GD25LT256E features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Quad SPI The GD25LT256E supports Quad SPI operation when using the “Quad Output Fast Read”, “Quad I/O Fast Read”, “Quad Page Program” (6BH/6CH, EBH/ECH, 32H/34H, C2H/3EH) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. DTR Quad SPI The GD25LT256E supports DTR Quad SPI operation when using the “DTR Quad I/O Fast Read” (EDH/EEH) command. These commands allow data to be transferred to or from the device at eight times the rate of the standard SPI, and data output will be latched on both rising and falling edges of the serial clock. When using the DTR Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. 4.2 QPI Mode The GD25LT256E supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Quad SPI mode to QPI mode using the “Enable the QPI (38H)” command. The QPI mode utilizes all four IO pins to input the command code. Standard/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given times. “Enable the QPI (38H)” and “Disable the QPI (FFH)” commands are used to switch between these two modes. Upon power-up and after software reset using “Enable Reset (66H) and Reset (99H)” command, the default state of the device is Standard/Quad SPI mode. 4.3 Quad DTR Mode The GD25LT256E supports Quad DTR operations only when the device is in Quad DTR mode, which could be entered by setting Byte in Configuration Register as E7H/C7H with the “Write Volatile Configuration Register command (81H)”. The Quad DTR Mode utilizes all four IO pins to input the command code latched on the rising edge of SCLK. All four IO pins are used to input the address output the data on both rising and falling edges of SCLK. 4.4 RESET Function The RESET# pin allows the device to be reset by the control. The RESET# pin goes low for a minimum period of tRLRH will reset the flash. After reset cycle, the flash is at the following states: - Standby mode - All the volatile bits will return to the default status as power on. 11 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 4 RESET Condition CS# RESET# RESET 4.5 ECC Function The ECC Correction Signal (ECS#) pin is provided to the system hardware designers to determine the ECC status during any Read operation. The ECS# pin will be pulled low during any 8-Byte Read data output period in which an ECC event has occurred. ECS# pin can be used to represent SEC (Single Error Correction) event. ECC Correction Signal Output pin is an Open-Drain connection. 4.6 Data Strobe Function The Data Strobe function is enabled as default for this device, and the DQS pin is an active output pin for the Data Strobe (DQS) signal during Read operations. The DQS signal is typically used in high speed applications to indicate when the output data is ready to be fetched by the controllers. When the data strobe function is enabled, DQS signal is driven to ground once CS# goes LOW, and will start to toggle when the output data is ready on the I/O pins. The toggling frequency is the same as the CLK frequency. For STR Read operations, the data should only be latched on the rising edge of DQS signal. For DTR Read operations, the data should be latched on both rising edge and falling edge of the DQS signal. The Data Strobe function can also be disabled by setting the non-volatile or volatile Configuration Register Byte. Please refer to the Configuration Register description for details. When disabled, the DQS signal is not driven and will stay at Hi-Z state. 12 Uniform Sector Standard and Quad Serial Flash 5 GD25LT256E DATA PROTECTION The GD25LT256E provide the following data protection methods: ◆ Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation: - Power-Up/ Software reset (66H+99H) - Write Disable (WRDI) - Write Status Register (WRSR) - Write Extended Address Register (WEAR) - Write Nonvolatile Configuration Register (WNVCR) - Write Volatile Configuration Register (WVCR) - Page Program (PP) - Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE) - Erase Security Registers / Program Security Registers ◆ Software Protection Mode: -The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits define the section of the memory array that can be read but cannot be changed. - Individual Block Protection bit provides the protection selection of each individual block. ◆ Hardware Protection Mode: WP# goes low to protect the BP0~BP4 bits and SRP0 bit. ◆ Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command and reset command (66H+99H). Table 4. GD25LT256E Protected area size Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X 0 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 511 01FF0000h-01FFFFFFh 64KB Upper 1/512 0 0 0 1 0 510 to 511 01FE0000h-01FFFFFFh 128KB Upper 1/256 0 0 0 1 1 508 to 511 01FC0000h-01FFFFFFh 256KB Upper 1/128 0 0 1 0 0 504 to 511 01F80000h-01FFFFFFh 512KB Upper 1/64 0 0 1 0 1 496 to 511 01F00000h-01FFFFFFh 1MB Upper 1/32 0 0 1 1 0 480 to 511 01E00000h-01FFFFFFh 2MB Upper 1/16 0 0 1 1 1 448 to 511 01C00000h-01FFFFFFh 4MB Upper 1/8 0 1 0 0 0 384 to 511 01800000h-01FFFFFFh 8MB Upper 1/4 0 1 0 0 1 256 to 511 01000000h-01FFFFFFh 16MB Upper 1/2 1 0 0 0 1 0 00000000h-0000FFFFh 64KB Lower 1/512 1 0 0 1 0 0 to 1 00000000h-0001FFFFh 128KB Lower 1/256 1 0 0 1 1 0 to 3 00000000h-0003FFFFh 256KB Lower 1/128 1 0 1 0 0 0 to 7 00000000h-0007FFFFh 512KB Lower 1/64 1 0 1 0 1 0 to 15 00000000h-000FFFFFh 1MB Lower 1/32 1 0 1 1 0 0 to 31 00000000h-001FFFFFh 2MB Lower 1/16 1 0 1 1 1 0 to 63 00000000h-003FFFFFh 4MB Lower 1/8 13 Uniform Sector Standard and Quad Serial Flash GD25LT256E 1 1 0 0 0 0 to 127 00000000h-007FFFFFh 8MB Lower 1/4 1 1 0 0 1 0 to 255 00000000h-00FFFFFFh 16MB Lower 1/2 X 1 1 0 X ALL 00000000h-01FFFFFFh 32MB ALL X 1 X 1 X ALL 00000000h-01FFFFFFh 32MB ALL Table 5. GD25LT256E Individual Block Protection (WPS=0) Block Sector Address range Individual Block Lock Operation 8191 01FF F000h 01FF FFFFh 512 Blocks …… …… …… Block Lock: 36H+Address 8176 01FF 0000h 01FF 0FFFh Block Unlock: 39H+Address 510 8160~8175 01FE 0000h 01FE FFFFh Read Block Lock: 3DH+Address …… …… …… …… Global Block Lock: 7EH …… …… …… …… Global Block Unlock: 98H …… …… …… …… 1 16~31 0001 0000h 0001 FFFFh 15 0000 F000h 0000 FFFFh …… …… …… 0 0000 0000h 0000 0FFFh 511 0 Notes: 1. Protection configuration: This bit is used to select which Write Protect scheme should be used. 2. Individual Block Protection bits are volatile lock bits. Each volatile bit corresponds to and provides volatile protection for an individual memory sector, which is locked temporarily (protection is cleared when the device is reset or powered down). 3. The first and last sectors will have volatile protections at the 4KB sector level. Each 4KB sector in these sectors can be individually locked by volatile lock bits setting. 14 Uniform Sector Standard and Quad Serial Flash 6 GD25LT256E DATA INTEGRITY CHECK The data storage and transmission errors will cause unexpected Flash device variation that makes a harmful impact on overall system functions. To prevent these errors, GD25LT256E product provides advanced Data Integrity Check function. For the data storage and data transmission in the flash device, Data Integrity Check can check errors and correct them, allowing self-checking and preventing errors in advance. The Data Integrity Check function includes two methods: - ECC (Error Checking and Correcting): to prevent the data storage errors - CRC (Cyclic Redundancy Check): to prevent the data transmission errors The register data and software signals can also be used to associate the Data Integrity Check function to fully record the results of checking, and can also immediately feedback. 6.1 ECC (Error Checking and Correcting) Error Correction Codes (ECC) is a commonly used technique in non-volatile memory to reduce the device Bit Error Rate (BER) during the device operation life and improve device reliability. To achieve error detection and correction, redundancy data must be added to store the ECC calculation results for a given length of data. In GD25LT256E, every aligned 8-Byte data (A[2:0] = 0, 0, 0) stored in the memory array will be checked by the internal ECC engine using SEC (Single Error Correction) Hsiao Codes algorithm. With 8-Byte ECC data granularity, ECC calculation latency time can be minimized and highest level of data integrity can be preserved. The default value of all memory data is FFH (Erased) when the device is shipped from the factory. A “Page Program (02H/12H)” or “Quad Page Program (32H/34H)” or “Extended Quad Page Program (C2H/3EH)” command can be used to program the user data into the memory array. When ECC is enabled (ECC=1 in Configuration Register), ECC calculation will be performed during the internal programming operation and the results are stored in the redundancy or spare area of the memory array. It is necessary to program every page in aligned 8-Byte granularity so that ECC engine can store the correct ECC information. It is also required that every aligned 8-Byte data granularity can only be programmed once to avoid additional ECC calculation in the same granularity resulting incorrect ECC results. A technique previously known as “Incremental Byte/Bit Programming to the same Byte location” cannot be used for GD25LT256E when ECC is enabled. During data read operations, the internal ECC engine will check the ECC results stored in the spare area and apply necessary error correction or error detection to the main array data being read out. It is necessary to check the ECC Status Bits (SEC) in the Status Register after every Read operation to see if the data read out contains one error or not. A Read operation can start from any Byte address and continue through the entire memory array, so it is not necessary to align the 8-Byte granularity boundary address to start a Read command. Additional hardware monitoring of the ECC status can also be used to observe the ECC status in real time during any data output. When configured, the ECS# (ECC Correction Signal) pin will be pulled low during any aligned 8-Byte data output if it contains SEC event. The SEC bit can be reset through anyone of the following situations: - Sending a new Read Command - Issuing Software Reset Command - Hardware Reset - Power-up cycle 15 Uniform Sector Standard and Quad Serial Flash 6.2 GD25LT256E ECS# (Error corrected Signal) Pin The ECS# pin is a real time hardware signal to feedback the ECC correction status. The ECS# pin is designed as an open drain structure and a pull-up resistor (Rp) is required. In normal situation, the ECS# is kept on High-Z state. Once error correction begins, the ECS# pin will pull low during the whole ECC chunk unit after a duration of tECSV delay timing. The ECS# (ECC Correction Signal) pin will be pulled low during any aligned 8-Byte data output if it contains SEC (Single Error Correction) event. Figure 5. ECS# Timing CS# SCLK IO[3:0] Command & Address & Dummys ECC chunk (8 Bytes) ECC chunk (8 Bytes) High-Z High-Z ECS# tECSV 6.3 ECC chunk with ECC error detected Parity Check (CRC) The parity check function can only be operated in DTR read mode, and it is not supported in STR mode. The bit7~6 in Byte of the Configuration Register can set the parity check function. For read operation after the Parity check function is enabled, the data CRC bit should be output by each CRC chunk unit. Otherwise, read CRC code might be error. The CRC Chunk size can be configured as 16-Byte, 32-Byte, or 64-Byte by the Configuration Register setting. However, when the device enters the “Read with Wrap” mode, while the CRC function is also enabled, and the CRC Chunk size will be set to be identical with the Wrap Length (16-Byte, 32-Byte, or 64-Byte) by internal circuitry. Only when the device is not in the “Read with Wrap” mode, the original CRC Chunk size setting will be restored. The data CRC Bytes are calculated by exclusive-OR on each I/O bus in the CRC chunk. Figure 6. CRC Timing CS# SCLK IO[3:0] Command & Address & Dummys CRC Multiple of CRC chunks 16 CRC Multiple of CRC chunks Uniform Sector Standard and Quad Serial Flash 7 GD25LT256E REGISTERS 7.1 Status Register Table 6. Status Register No. Bit Name Description Note S7 SRP0 Status Register Protection Non-volatile writable S6 BP4 Block Protect Bits Non-volatile writable S5 BP3 Block Protect Bits Non-volatile writable S4 BP2 Block Protect Bits Non-volatile writable S3 BP1 Block Protect Bits Non-volatile writable S2 BP0 Block Protect Bits Non-volatile writable S1 WEL Write Enable Latch Volatile, read only S0 WIP Erase/Write In Progress Volatile, read only The status and control bits of the Status Register are as follows: WIP bit The Write in Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register or configuration register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register or configuration register progress, when WIP bit sets 0, means the device is not in program/erase/write status register or configuration register progress. WEL bit The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are set to 1, the relevant memory area becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed only if none sector or block is protected. SRP0 bit The Status Register Protect SRP0 bit are non-volatile Read/Write bits in the status register. The SRP0 bit in conjunction with SRP1 bit (Reference Configuration Register) control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. SRP1 SRP0 WP# Status Register X 0 X Software Protected Description The Status Register can be written to after a Write Enable command, WEL=1. (Default) 17 Uniform Sector Standard and Quad Serial Flash 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 1 X One Time Program(1) GD25LT256E WP#=0, the Status Register locked and cannot be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Status Register is permanently protected and cannot be written to. NOTE: 1. This feature is available on special order. Please contact GigaDevice for details. 7.2 Flag Status Register Table 7. Flag Status Register No. Bit Name Description Note FS7 RY/BY# Ready/Busy# Volatile, read only FS6 SUS1 Erase Suspend Volatile, read only FS5 EE Erase Error bit Volatile, read only FS4 PE Program Error bit Volatile, read only FS3 Reserved Reserved Volatile, read only FS2 SUS2 Program Suspend Volatile, read only FS1 PTE Protection Error bit Volatile, read only FS0 ADS Current Address Mode Volatile, read only The status and control bits of the Flag Status Register are as follows: ADS bit The Address Status (ADS) bit is a read only bit that indicates the current address mode the device is operating in. The device is in 3-Byte address mode when ADS=0 (default), and in 4-Byte address mode when ADS=1. PTE bit The PTE bit is a read only bit that indicates a program or erase failure. Indicates whether an ERASE or PROGRAM operation has attempted to modify the protected array sector, or whether a PROGRAM operation has attempted to access the locked OTP space. PTE is cleared to "0" after program or erase operation resumes. SUS1, SUS2 bits The SUS1 and SUS2 bits are read only bit in the Flag Status Register (FS6 and FS2) that are set to 1 after executing an Erase/Program Suspend (75H) command (The Erase Suspend will set the SUS1 to 1,and the Program Suspend will set the SUS2 to 1). The SUS1 and SUS2 bits are cleared to 0 by Erase/Program Resume (7AH) command, software reset (66H+99H) command as well as a power-down, power-up cycle. PE bit The Program Error (PE) bit is a read only bit that indicates a program failure. It will also be set when the user attempts to program a protected array sector or access the locked OTP space. PE is cleared to "0" after program operation resumes 18 Uniform Sector Standard and Quad Serial Flash GD25LT256E EE bit The Erase Error (EE) bit is a read only bit that indicates an erase failure. It will also be set when the user attempts to erase a protected array sector or access the locked OTP space. EE is cleared to "0" after erase operation resumes RY/BY# bit The RY/BY# bit is a read only bit that indicates Program or Erase Status bit. Indicates whether one of the following command cycles is in progress: WRITE STATUS REGISTER, WRITE NONVOLATILE CONFIGURATION REGISTER, PROGRAM, or ERASE. 7.3 Extended Address Register Table 8 Extended Address Register No. Name Description Note EA7 SEC Single Error Correction Bit Volatile, read only EA6 Reserved Reserved Reserved EA5 Reserved Reserved Reserved EA4 Reserved Reserved Reserved EA3 Reserved Reserved Reserved EA2 Reserved Reserved Reserved EA1 Reserved Reserved Reserved EA0 A24 Address bit Volatile writable The extended address register is only used when the address mode is 3-Byte mode, as to set the higher address. The default value of the address bit is “0”. For the read operation, the whole array can be continually read out with one command. Data output starts from the selected 128Mb, and it can cross the boundary. When the last Byte of the segment is reached, the next Byte (in a continuous reading) is the first Byte of the next segment. However, the EAR (Extended Address Register) value does not change. The random access reading can only be operated in the selected segment. The Chip erase command will erase the whole chip and is not limited by EAR selected segment. However, the sector erase, block erase, program operation are limited in selected segment and will not cross the boundary. A24 bit The Extended Address Bits A24 is used only when the device is operating in the 3-Byte Address Mode (ADS=0), which is volatile writable by C5H command. The lowest 128Mb memory array (00000000h – 00FFFFFFh) is selected when A24 =0, and all instructions with 3-Byte addresses will be executed within that region. If Configuration Register Byte set to FEH, or an “Enter 4-Byte Address Mode (B7H)” instruction is issued, the device will require 4-Byte address input for all address related instructions, and the Extended Address Bit setting will be ignored. A24 Address Range 0 0000 0000h-00FF FFFFh 1 0100 0000h-01FF FFFFh 19 Uniform Sector Standard and Quad Serial Flash GD25LT256E SEC bit SEC (Single Error Correction) Status Bit are used to show the ECC results for the last Read operation. SEC bit will be cleared to 0 once the device accepts a new Read command. SEC 0 1 Definitions No ECC events in all aligned 8-Byte granularities SEC events in single or multiple 8-Byte granularities, and the data is OK to use. (Unless it contains more than one odd bit errors in 8-Byte granularity) 20 Uniform Sector Standard and Quad Serial Flash GD25LT256E 8 INTERNAL CONFIGURATION REGISTER The memory configuration is set by an internal configuration register that is not directly accessible to users. The user can change the default configuration at power up by using the WRITE NONVOLATILE CONFIGURATION REGISTER. Information from the nonvolatile configuration register overwrites the internal configuration register during power on or after a reset. The user can change the configuration during device operation using the WRITE VOLATILE CONFIGURATION REGISTER command. Information from the volatile configuration registers overwrite the internal configuration register immediately after the WRITE command completes. Nonvolatile to volatile register download after power-on or RESET Nonvolatile configuration register Nonvolatile to internal register download after power-on or RESET Volatile configuration register Volatile to internal register download after Write Volatile Configuration Register Command Internal configuration register Device behavior 8.1 Nonvolatile Configuration Register Nonvolatile Configuration Register bits set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ NONVOLATILE CONFIGURATION REGISTER and the WRITE NONVOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme, but only the LSB is used to access different register settings, thereby providing up to 256 Bytes of registers (See the table below for the details). A WRITE command to a reserved address will set the device to the default status of the corresponding Byte. Table 9 Nonvolatile Configuration Register Addr Settings I/O mode bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 1 1 1 1 1 1 1 1 STR with DQS (Default) 1 1 0 1 1 1 1 1 STR W/O DQS 1 1 1 0 0 1 1 1 Quad DTR with DQS 1 1 0 0 0 1 1 1 Quad DTR W/O DQS Others Reserved Dummy cycle 0 0 0 0 0 0 1 1 3 Dummy configuration(6-7) 0 0 0 0 0 1 0 0 4 Dummy 21 Uniform Sector Standard and Quad Serial Flash … … … … … … GD25LT256E … … Others OTP configuration configuration x x x x x x 0 x x x x x x x 1 Security Registers Locked x x x 0 x x x x SRP1 Unlocked (Default) x x x 1 x x x x SRP1 Locked(10) Reserved 1 1 1 1 1 1 1 1 50 Ohm (Default) 1 1 1 1 1 1 1 0 35 Ohm 1 1 1 1 1 1 0 1 25 Ohm 1 1 1 1 1 1 0 0 18 Ohm Reserved 1 x x x x x x CRC Disabled (Default) 1 0 x x x x x x 16-Byte CRC 0 1 x x x x x x 32-Byte CRC 0 0 x x x x x x 64-Byte CRC x x 1 1 x x x x ODT Disabled (Default) x x 1 0 x x x x 150-Ohm ODT x x 0 1 x x x x 100-Ohm ODT x x 0 0 x x x x 50-Ohm ODT x x x x 1 x x x DLP Disabled x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) x x x x x x x 1 ECC Enabled (Default) x x x x x x x 0 ECC Disabled On die termination DLP configuration ECC configuration Others Beyond 128Mb addr. configuration XIP configuration(9) Reserved 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address Others Reserved 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled Others (Default) 1 CRC configuration Security Registers unlocked x Others (Default=10h) Reserved Others Driver Strength 05~1E: 5~30 Dummy Wrap configuration Reserved 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 1 1 1 1 1 1 0 0 16-Byte Wrap Others Reserved Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command 22 Uniform Sector Standard and Quad Serial Flash GD25LT256E (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI&DTR N/A 3. 05H/70H/9EH/9FH: SPI&QPI 0 dummy; DTR 8 dummy. 4. 3DH: SPI 0dummy; QPI&DTR 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI&DTR 8 dummy. 6. 0BH/0CH/6BH/6CH/48H: SPI 8dummy; QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. 10. This feature is available on special order. Please contact GigaDevice for details. 8.2 Volatile Configuration Register Volatile Configuration Register bits temporarily set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ VOLATILE CONFIGURATION REGISTER and the WRITE VOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme; however, only the LSB is used to access different register settings to provide up to 256 Bytes of registers (See the table below for the details). A WRITE command to a reserved address will set the device to the default status of the corresponding Byte. Table 10 Volatile Configuration Register Addr Settings I/O mode bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 1 1 1 1 1 1 1 1 STR with DQS (Default) 1 1 0 1 1 1 1 1 STR W/O DQS 1 1 1 0 0 1 1 1 Quad DTR with DQS 1 1 0 0 0 1 1 1 Quad DTR W/O DQS Others Dummy cycle configuration(6-7) Reserved 0 0 0 0 0 0 1 1 3 Dummy 0 0 0 0 0 1 0 0 4 Dummy … … … … … … … … Others Driver Strength configuration CRC configuration (Default=10h) Reserved 1 1 1 1 1 1 1 1 50 Ohm (Default) 1 1 1 1 1 1 1 0 35 Ohm 1 1 1 1 1 1 0 1 25 Ohm 1 1 1 1 1 1 0 0 18 Ohm Others 05~1E: 5~30 Dummy Reserved 1 1 x x x x x x CRC Disabled (Default) 1 0 x x x x x x 16-Byte CRC 0 1 x x x x x x 32-Byte CRC 23 Uniform Sector Standard and Quad Serial Flash GD25LT256E 0 0 x x x x x x 64-Byte CRC x x 1 1 x x x x ODT Disabled (Default) x x 1 0 x x x x 150-Ohm ODT x x 0 1 x x x x 100-Ohm ODT x x 0 0 x x x x 50-Ohm ODT x x x x 1 x x x DLP Disabled x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) x x x x x x x 1 ECC Enabled (Default) x x x x x x x 0 ECC Disabled On die termination DLP configuration ECC configuration Others Beyond 128Mb addr. configuration XIP configuration(9) Reserved 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address Others Reserved 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled Others Wrap configuration Reserved 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 1 1 1 1 1 1 0 0 16-Byte Wrap Others Reserved Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI&DTR N/A 3. 05H/70H/9EH/9FH: SPI&QPI 0 dummy; DTR 8 dummy. 4. 3DH: SPI 0dummy; QPI&DTR 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI&DTR 8 dummy. 6. 0BH/0CH/6BH/6CH/48H: SPI 8dummy; QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. DLP bit The DLP bit is Data Learning Pattern Enable bit, which is writable by B1/81H command. For Quad output, Quad I/O and Quad I/O DTR Fast Read commands, a pre-defined “Data Learning Pattern” can be used by the flash memory controller to determine the flash data output timing on 4 I/O pins. When DLP=1, from the third dummy clock, the flash will output “00110100” Data Learning Pattern sequence on each of the I/O or 4 I/O pins until data output. If the dummy clock is not enough for the output of the whole Data Learning Pattern, the last several bit of the Data Learning Pattern would be cut-off. 24 Uniform Sector Standard and Quad Serial Flash GD25LT256E During this period, controller can fine tune the data latching timing for each I/O pins to achieve optimum system performance. DLP=0 will disable the Data Learning Pattern output. Figure 7. Data Learning Pattern Sequence Diagram (STR, Dummy Clock ≥ 10) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 0 0 0 0 D D 7 6 5 4 3 2 1 0 7 6 Data D D Note: 12 dummy cycle example Figure 8. Data Learning Pattern Sequence Diagram (STR, Dummy Clock < 10) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 D D 7 6 5 4 3 2 Data D D Note: 8 dummy cycle example Figure 9. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock ≥ 6) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 0 0 0 0 D 7 6 5 4 3 2 1 0 7 6 Note: 7 dummy cycle example 25 Data D Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 10. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock < 6) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 D D 7 6 5 4 3 2 Data D D Note: 5 dummy cycle example 8.3 Supported Clock Frequencies Table 11 Clock Frequencies of TFBGA-24 (5x5 Ball Array) Quad I/O FAST READ Number of Dummy Clock QPI DTR Cycle STR DTR 4 40 40 40 6 84 84 84 8 104 104 104 10 133 133 133 12 152 152 152 14 166 166 166 16 and above 166 200 200 Table 12 Clock Frequencies of WSON8 (8x6mm) Quad I/O FAST READ Number of Dummy Clock QPI DTR Cycle STR DTR 4 40 40 40 6 84 84 84 8 104 90 90 10 133 90 90 12 152 90 90 14 and above 166 90 90 Table 13 Clock Frequencies of SOP16 (300mil) Quad I/O FAST READ Number of Dummy Clock QPI DTR Cycle STR DTR 4 40 40 40 6 84 84 84 8 104 104 104 10 133 133 133 12 152 152 152 26 Uniform Sector Standard and Quad Serial Flash 14 and above 166 GD25LT256E 166 166 Note: 1. Values are guaranteed by characterization and not 100% tested in production 8.4 Data Sequence Wraps by Density Table 14 Sequence of Bytes during Wrap Starting Address 16-Byte Wrap 32-Byte Wrap 64-Byte Wrap 0 0-1-2- . . . -15-0-1- . . 0-1-2- . . . -31-0-1- . . 0-1-2- . . . -63-0-1- . . 1 1-2- . . . -15-0-1-2- . . 1-2- . . . -31-0-1-2- . . 1-2- . . . -63-0-1-2- . . …. …. 15-16-17- . . . -63-0-1- . . …. …. 15 15-0-1-2-3- . . . -15-0-1- . . 15-16-17- . . . -31-0-1- . . …. …. …. 31 - 31-0-1-2-3- . . . -31-0-1- . . 31-32-33- . . . -63-0-1- . . … …. …. …. 63 - - 63-0-1- . . . -63-0-1- . . 27 Uniform Sector Standard and Quad Serial Flash 9 GD25LT256E COMMAND DESCRIPTIONS All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-Byte command code must be shifted in to the device, with most significant bit first on SI, and each bit is latched on the rising edges of SCLK. Every command sequence starts with a one-Byte command code. Depending on the command, this might be followed by address Bytes, or by data Bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been completed. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. All read instruction can be completed after any bit of the data-out sequence is being shifted out, and then CS# must be driven high to return to deselected status. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a Byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input Byte is not a full Byte, nothing will happen and WEL will not be reset. Table 15 Commands (Standard SPI & DTR Quad SPI) Quad SPI DTR Standard SPI Command name Code Command- Dummy Address- Clock Data Cycles CommandAddressData (s-d-d) Dummy Address Data Clock Bytes Bytes Cycles Software Reset Operations Enable Reset 66H 1-0-0 0 4-0-0 0 0 0 Reset 99H 1-0-0 0 4-0-0 0 0 0 9E/9FH 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ 5AH 1-1-(1) 8 4-4-(4) 8 3 1 to ∞ 4BH 1-1-(1) 8 4-4-(4) 8 3(4) 1 to ∞ 03H 1-1-(1) 0 - - 3(4) 1 to ∞ 0BH 1-1-(1) 8 4-4-(4) 16 3(4) 1 to ∞ Quad Output Fast Read 6BH 1-1-(4) 8 4-4-(4) 16 3(4) 1 to ∞ Quad I/O Fast Read EBH 1-4-(4) 16 4-4-(4) 16 3(4) 1 to ∞ Quad I/O DTR Fast Read EDH 1-4d-(4d) 16 4-4-(4) 16 3(4) 1 to ∞ Read ID Operations Read Identification Read Serial Flash Discoverable Parameter Read Unique ID Read Memory Operations Read Data Bytes Read Data Bytes at Higher Speed Read Memory Operations with 4-Byte Address 4-Byte Read Data Bytes 4-Byte Read Data Bytes at Higher Speed 13H 1-1-(1) 0 - - 4 1 to ∞ 0CH 1-1-(1) 8 4-4-(4) 16 4 1 to ∞ 28 Uniform Sector Standard and Quad Serial Flash 4-Byte Quad Output Fast GD25LT256E 6CH 1-1-(4) 8 4-4-(4) 16 4 1 to ∞ ECH 1-4-(4) 16 4-4-(4) 16 4 1 to ∞ EEH 1-4d-(4d) 16 4-4-(4) 16 4 1 to ∞ Write Enable 06H 1-0-0 0 4-0-0 0 0 0 Write Disable 04H 1-0-0 0 4-0-0 0 0 0 50H 1-0-0 0 4-0-0 0 0 0 Read Status Register 05H 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ Read Flag Status Register 70H 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ B5H 1-1-(1) 8 4-4-(4) 8 3(4) 1 85H 1-1-(1) 8 4-4-(4) 8 3(4) 1 C8H 1-0-(1) 8 4-0-(4) 8 0 1 01H 1-0-1 0 4-0-4 0 0 1 B1H 1-1-1 0 4-4-4 0 3(4) 1 81H 1-1-1 0 4-4-4 0 3(4) 1 C5H 1-0-1 0 4-0-4 0 0 1 Page Program 02H 1-1-1 0 4-4-4 0 3(4) Quad Page Program 32H 1-1-4 0 4-4-4 0 3(4) C2H 1-4-4 0 4-4-4 0 3(4) 12H 1-1-1 0 4-4-4 0 4 34H 1-1-4 0 4-4-4 0 4 3EH 1-4-4 0 4-4-4 0 4 20H 1-1-0 0 4-4-0 0 3(4) Read 4-Byte Quad I/O Fast Read 4-Byte Quad I/O DTR Fast Read Write Operations Write Enable for Volatile Status Register Read Register Operations Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register Write Register Operations Write Status Register Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Program Operations Extended Quad Page Program 1 to 256 1 to 256 1 to 256 Program Operations with 4-Byte Address 4-Byte Page Program 4-Byte Quad Page Program 4-Byte Extended Quad Page Program 1 to 256 1 to 256 1 to 256 Erase Operations Sector Erase 29 0 Uniform Sector Standard and Quad Serial Flash GD25LT256E 32KB Block Erase 52H 1-1-0 0 4-4-0 0 3(4) 0 64KB Block Erase D8H 1-1-0 0 4-4-0 0 3(4) 0 C7/60H 1-0-0 0 4-0-0 0 0 0 Chip Erase Erase Operations with 4-Byte Address 4-Byte Sector Erase 21H 1-1-0 0 4-4-0 0 4 0 4-Byte 32KB Block Erase 5CH 1-1-0 0 4-4-0 0 4 0 4-Byte 64KB Block Erase DCH 1-1-0 0 4-4-0 0 4 0 Program/Erase Suspend 75H 1-0-0 0 4-0-0 0 0 0 Program/Erase Resume 7AH 1-0-0 0 4-0-0 0 0 0 1 to ∞ Suspend/Resume Operations One-Time Programmable (OTP) Operations Read Security Registers 48H 1-1-(1) 8 4-4-(4) 16 3(4) 42H 1-1-1 0 4-4-4 0 3(4) 44H 1-1-0 0 4-4-0 0 3(4) 38H 1-0-0 0 4-0-0 0 0 0 B7H 1-0-0 0 4-0-0 0 0 0 E9H 1-0-0 0 4-0-0 0 0 0 B9H 1-0-0 0 4-0-0 0 0 0 ABH 1-0-0 0 4-0-0 0 0 0 36H 1-1-0 0 4-4-0 0 3(4) 0 39H 1-1-0 0 4-4-0 0 3(4) 0 3DH 1-1-(1) 0 4-4-(4) 8 3(4) 1 Global Block/Sector Lock 7EH 1-0-0 0 4-0-0 0 0 0 Global Block/Sector Unlock 98H 1-0-0 0 4-0-0 0 0 0 Program Security Registers Erase Security Registers 1 to 256 0 QPI Mode Operation Enable QPI 4-Byte Address Mode Operations Enable 4-Byte Address Mode Disable 4-Byte Address Mode Deep Power-Down Operations Deep Power-Down Release From Deep Power-Down Advanced Sector Protection Operations Individual Block/Sector Lock Individual Block/Sector Unlock Read Individual Block/Sector Lock Table 16 Commands (QPI) Command name Code Command- Dummy Clock Address Data Address-Data Cycles Bytes Bytes Software Reset Operations Enable Reset 66H 4-0-0 0 0 0 Reset 99H 4-0-0 0 0 0 30 Uniform Sector Standard and Quad Serial Flash GD25LT256E Read ID Operations 9E/9FH 4-0-(4) 0 0 1 to ∞ 5AH 4-4-(4) 8 3 1 to ∞ 4BH 4-4-(4) 8 3(4) 1 to ∞ Read Data Bytes at Higher Speed 0BH 4-4-(4) 8 3(4) 1 to ∞ Quad Output Fast Read 6BH 4-4-(4) 8 3(4) 1 to ∞ Quad I/O Fast Read EBH 4-4-(4) 16 3(4) 1 to ∞ Quad I/O DTR Fast Read EDH 4-4d-(4d) 16 3(4) 1 to ∞ 0CH 4-4-(4) 8 4 1 to ∞ 4-Byte Quad Output Fast Read 6CH 4-4-(4) 8 4 1 to ∞ 4-Byte Quad I/O Fast Read ECH 4-4-(4) 16 4 1 to ∞ 4-Byte Quad I/O DTR Fast Read EEH 4-4d-(4d) 16 4 1 to ∞ Write Enable 06H 4-0-0 0 0 0 Write Disable 04H 4-0-0 0 0 0 Write Enable for Volatile Status 50H Read Identification Read Serial Flash Discoverable Parameter Read Unique ID Read Memory Operations Read Memory Operations with 4-Byte Address 4-Byte Read Data Bytes at Higher Speed Write Operations Register Read Register Operations Read Status Register 05H 4-0-(4) 0 0 1 to ∞ Read Flag Status Register 70H 4-0-(4) 0 0 1 to ∞ B5H 4-4-(4) 8 3(4) 1 85H 4-4-(4) 8 3(4) 1 C8H 4-0-(4) 0 0 1 FFH 4-0-0 0 0 0 01H 4-0-4 0 0 1 B1H 4-4-4 0 3(4) 1 81H 4-4-4 0 3(4) 1 C5H 4-0-4 0 0 1 Page Program 02H 4-4-4 0 3(4) 1 to 256 Quad Page Program 32H 4-4-4 0 3(4) 1 to 256 Extended Quad Page Program C2H 4-4-4 0 3(4) 1 to 256 Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register QPI Mode Operation Disable QPI Write Register Operations Write Status Register Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Program Operations 31 Uniform Sector Standard and Quad Serial Flash GD25LT256E Program Operations with 4-Byte Address 4-Byte Page Program 12H 4-4-4 0 4 1 to 256 4-Byte Quad Page Program 34H 4-4-4 0 4 1 to 256 3EH 4-4-4 0 4 1 to 256 Sector Erase 20H 4-4-0 0 3(4) 0 32KB Block Erase 52H 4-4-0 0 3(4) 0 64KB Block Erase D8H 4-4-0 0 3(4) 0 C7/60H 4-0-0 0 0 0 4-Byte Extended Quad Page Program Erase Operations Chip Erase Erase Operations with 4-Byte Address 4-Byte Sector Erase 21H 4-4-0 0 4 0 4-Byte 32KB Block Erase 5CH 4-4-0 0 4 0 4-Byte 64KB Block Erase DCH 4-4-0 0 4 0 Program/Erase Suspend 75H 4-0-0 0 0 0 Program/Erase Resume 7AH 4-0-0 0 0 0 Suspend/Resume Operations One-Time Programmable (OTP) Operations Read Security Registers 48H 4-4-(4) 8 3(4) 1 to ∞ Program Security Registers 42H 4-4-(4) 0 3(4) 1 to 256 Erase Security Registers 44H 4-4-0 0 3(4) Enable 4-Byte Address Mode B7H 4-0-0 0 0 0 Disable 4-Byte Address Mode E9H 4-0-0 0 0 0 Deep Power-Down B9H 4-0-0 0 0 0 Release From Deep Power-Down ABH 4-0-0 0 0 0 0 4-ByteAddress Mode Operations Deep Power-Down Operations Advanced Sector Protection Operations Individual Block/Sector Lock 36H 4-4-0 0 3(4) 0 Individual Block/Sector Unlock 39H 4-4-0 0 3(4) 0 Read Individual Block/Sector Lock 3DH 4-4-(4) 8 3(4) 1 Global Block/Sector Lock 7EH 4-0-0 0 0 0 Global Block/Sector Unlock 98H 4-0-0 0 0 0 Table of ID Definitions GD25LT256E Operation Code M7-M0 ID23-ID16 ID15-ID8 ID7-ID0 9E/9FH C8 66 19 FF 32 Uniform Sector Standard and Quad Serial Flash 9.1 GD25LT256E Enable 4-Byte Mode (B7H) The Enable 4-Byte Mode command enables accessing the address length of 32-bit for the memory area of the higher density (larger than 128Mb). After sending the Enable 4-Byte Mode command, the ADS bit (FS0) will be set to 1 to indicate the 4-Byte address mode has been enabled. Once the 4-Byte address mode is enabled, the address length becomes 32bit. Figure 11 Enable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI B7H Figure 12 Enable 4-Byte Mode Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 9.2 B7H Disable 4-Byte Mode (E9H) The Disable 4-Byte Mode command is executed to exit the 4-Byte address mode and enter the 3-Byte address mode. After sending the Disable 4-Byte Mode command, the ADS bit (FS0) will be clear to be 0 to indicate the 4-Byte address mode has been disabled, and then the address length will return to 24-bit. Figure 13 Disable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI E9H Figure 14 Disable 4-Byte Mode Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] E9H 33 Uniform Sector Standard and Quad Serial Flash 9.3 GD25LT256E Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE), Write Status Register (WRSR), Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register and Erase/Program Security Registers command. The Write Enable (WREN) command sequence: CS# goes low  sending the Write Enable command  CS# goes high. Figure 15 Write Enable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 06H Figure 16 Write Enable Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 9.4 06H Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes low Sending the Write Disable command CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register, Page Program, Sector Erase, Block Erase, Chip Erase, Erase/Program Security Registers and Reset commands. Figure 17 Write Disable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H Figure 18 Write Disable Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 04H 34 Uniform Sector Standard and Quad Serial Flash 9.5 GD25LT256E Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command, and any other commands cannot be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure 19 Write Enable for Volatile Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 50H High-Z SO Figure 20 Write Enable for Volatile Status Register Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 9.6 50H Write Status Register (WRSR) (01H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). CS# must be driven high after the eighth of the data Byte has been latched in. Otherwise, the Write Status Register (WRSR) command is not executed. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits, to define the size of the area that is to be treated as read-only. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP0) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. 35 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 21 Write Status Register Sequence Diagram (SPI) CS# SCLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 7 6 Command SI 01H Status Register in 5 MSB SO 4 3 2 1 0 High-Z Figure 22 Write Status Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK IO[3:0] Command SR in 01H SR7-4 SR3-0 Figure 23 Write Status Register Sequence Diagram (Quad DTR) CS# 0 1 2 SCLK SR in IO[3:0] 9.7 01H SR7-4 SR3-0 Write Extended Address Register (C5H) The Extended Address Register is a volatile register that stores the 4th Byte address (A31-A24) when the device is operating in the 3-Byte Address Mode (ADS=0). To write the Extended Address Register bits, a Write Enable (06H) instruction must previously have been executed for the device to accept the Write Extended Address Register instruction (Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “C5H”, and then writing the Extended Address Register data Byte. Upon power up or the execution of a Software/Hardware Reset, the Extended Address Register bit values will be cleared to 0. The Extended Address Bit is only effective when the device is in the 3-Byte Address Mode. When the device operates in the 4-Byte Address Mode (ADS=1), any command with address input of A31-A24 will replace the Extended Address Register values. It is recommended to check and update the Extended Address Register if necessary when the device is switched from 4-Byte to 3-Byte Address Mode. 36 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 24 Write Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 C5H 7 Extended Addr. Register In 6 5 4 3 2 1 High-Z MSB SCLK Command SI SO 0 Figure 25 Write Extended Address Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK Command IO[3:0] EAR in EAR 7-4 C5H EAR 3-0 Figure 26 Write Extended Register Sequence Diagram (DTR, QPI) CS# 0 1 2 SCLK IO[3:0] 9.8 EAR in EAR EAR 7-4 3-0 C5H Write Nonvolatile/Volatile Configuration Register (B1H/81H) The Write Nonvolatile/Volatile Configuration Register (WRCR) command allows new values to be written to the Nonvolatile/Volatile Configuration Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). CS# must be driven high after the data Byte has been latched in. If not, the Write Configuration Register (WRCR) command is not executed. As soon as CS# is driven high, the self-timed Write Configuration Register cycle (whose duration is tW for B1H) is initiated. The Write In Progress (WIP) bit is 1 during the self-timed Write Configuration Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. Figure 27 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI B1H/81H 24-bit address 23 22 21 3 2 1 MSB 0 7 Configuration register in 6 5 4 3 2 1 0 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 37 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 28 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 SCLK Command IO[3:0] B1H/81H Address CR in Addr. Addr. Addr. Addr. Addr. Addr. CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 29 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK CR in IO[3:0] B1H or 81H Addr. Addr. Addr. Addr. Addr. Addr. CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.9 Read Status Register (05H) The Read Status Register command is for reading the Status Register. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write in Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. In QPI mode, 8 dummy clocks is required between the command and data when the clock frequency is higher than 104MHz. Figure 30 Read Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI SO 05H High-Z 7 6 5 SR out 4 3 2 1 MSB 0 7 6 5 SR out 4 3 2 MSB Figure 31 Read Status Register Sequence Diagram (QPI, fSCLK≤104MHz) CS# 0 1 2 3 4 5 SCLK Command IO[3:0] 05H SR out SR out SR7-4 SR3-0 SR7-4 SR3-0 38 SR out 1 0 7 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 32 Read Status Register Sequence Diagram (QPI, fSCLK﹥104MHz) CS# 0 1 2 9 10 11 12 13 SCLK Command IO[3:0] Don t care 05H SR out SR out SR7~0 SR7~0 SR out SR7~0 Figure 33 Read Status Register Sequence Diagram (Quad DTR) CS# 0 1 9 10 11 SCLK Dummy IO[3:0] SR out 05H SR out SR out SR 7-4SR 3-0SR 7-4SR 3-0 9.10 Read Flag Status Register (70H) The Read Flag Status Register command is for reading the Flag Status Register. The Flag Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is also possible to read the Flag Status Register continuously. In QPI mode, 8 dummy clocks is required between the command and data when the clock frequency is higher than 104MHz. Figure 34 Read Flag Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI SO 70H High-Z 7 6 5 FSR out 4 3 2 1 MSB 0 7 6 5 FSR out 4 3 2 1 0 MSB Figure 35 Read Flag Status Register Sequence Diagram (QPI, fSCLK≤104MHz) CS# 0 1 2 3 4 FSR 3-0 FSR 7-4 5 SCLK Command IO[3:0] 70H FSR out FSR 7-4 39 FSR out FSR 3-0 FSR out 7 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 36 Read Flag Status Register Sequence Diagram (QPI, fSCLK﹥104MHz) CS# 0 1 2 9 10 11 12 13 SCLK Command IO[3:0] Don t care 70H FSR out FSR out FSR7~0 FSR7~0 FSR7~0 Figure 37 Read Flag Status Register Sequence Diagram (Quad DTR) CS# 0 1 9 10 11 SCLK FSR out FSR FSR 7-4 3-0 Dummy IO[3:0] 70H FSR out FSR FSR 7-4 3-0 FSR out 9.11 Read Nonvolatile/Volatile Configuration Register (B5H/85H) The Read Nonvolatile/Volatile Configuration Register command is for reading the Nonvolatile/Volatile Configuration Registers. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the Configuration Register, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fC, on the falling edge of SCLK. Read Nonvolatile/Volatile Configuration Register command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 38 Read Configuration Registers Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command 24-bit address B5H/85H SI 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO 7 6 5 4 3 2 1 0 7 6 MSB 5 CR out 4 3 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 40 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 39 Read Configuration Registers Sequence (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address B5H/85H Addr. Addr. Addr. Addr. Addr. Addr. CR out CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 40 Read Configuration Registers Sequence (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] B5H or 85H Addr. Addr. Addr. Addr. Addr. Addr. dummy CS# 12 13 SCLK CR out IO[3:0] CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.12 Read Extended Address Register (C8H) The Read Extended Address Register instruction is entered by driving CS# low and shifting the instruction code “C8H” into the SI pin on the rising edge of SCLK. The Extended Address Register bits are then shifted out on the SO pin at the falling edge of SCLK with most significant bit (MSB) first. In QPI mode, 8 dummy clocks is required between the command and data when the clock frequency is higher than 104MHz. When the device is in the 4-Byte Address Mode, the value of the address bits is ignored. Figure 41 Read Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 7 6 SCLK Command SI SO C8H High-Z MSB 41 5 EAR out 4 3 2 1 0 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 42 Read Extended Address Register Sequence Diagram (QPI , f SCLK≤104MHz) CS# 0 1 2 3 SCLK Command IO[3:0] EAR out EAR 7-4 C8H EAR 3-0 Figure 43 Read Extended Address Register Sequence Diagram (QPI, fSCLK﹥104MHz) CS# 0 1 2 9 10 11 SCLK Command IO[3:0] EAR out Don t care C8H EAR7~0 Figure 44 Read Extended Address Register Sequence Diagram (Quad DTR) CS# 0 1 9 10 SCLK EAR out EAR EAR 7-4 3-0 Dummy IO[3:0] C8H 9.13 Read Data Bytes (03H/13H) The Read Data Bytes (READ) command is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0), and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fR, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 45 Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI SO 03H High-Z 24-bit address 23 22 21 3 2 1 0 MSB MSB 7 6 5 Data Out1 4 3 2 1 Data Out2 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 42 Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.14 Read Data Bytes at Higher Speed (0BH/0CH) The Read Data Bytes at Higher Speed (Fast Read) command is for quickly reading data out. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency f C, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 46 Read Data Bytes at Higher Speed Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 0BH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 SO 7 MSB Data Out1 6 5 4 3 2 1 Data Out2 0 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 47 Read Data Bytes at Higher Speed Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command IO[3:0] 0BH dummy Address Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 43 Byte 2 Data Data out out Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 48 Read Data Bytes at Higher Speed Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 0BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.15 Quad Output Fast Read (6BH/6CH) The Quad Output Fast Read command is followed by 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 49 Quad Output Fast Read Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command IO0 24-bit address 6BH 23 22 21 IO1 High-Z IO2 High-Z IO3 High-Z CS# 3 2 1 0 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Clocks IO0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 44 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 50 Quad Output Fast Read Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] Dummy Command Address 6BH Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Data out Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 51 Quad Output Fast Read Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 6BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.16 Quad I/O Fast Read (EBH/ECH) The Quad I/O Fast Read command is similar to the Quad Output Fast Read command but with the capability to input the 3Byte address (A23-0) or a 4-Byte address (A31-A0) and a “Continuous Read Mode” Byte and dummy clocks. 4-bit is transferred per clock by IO0, IO1, IO2, IO3, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 52 Quad I/O Fast Read Sequence Diagram (SPI, M5-4≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 29 30 31 32 33 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 SCLK Dummy Command IO0 EBH A23-16 A15-8 A7-0 M7-0 Byte1 Byte2 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 45 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 53 Quad I/O Fast Read Sequence Diagram (QPI, M5-4≠ (1, 0)) CS# 0 1 2 7 8 9 10 23 24 25 SCLK IO[3:0] Command Address EBH Addr. Dummy Byte 1 Data out M7-4 M3-0 Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 54 Quad I/O Fast Read Sequence Diagram (Quad DTR, M5-4≠ (1, 0)) CS# 0 1 2 3 4 5 6 SCLK Dummy IO[3:0] EBH Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-Byte address (A23-A0) or 4-Byte address (A31-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH/ECH command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the command code, thus returning to normal operation. A Reset command can be used to reset (M5-4) before issuing normal command. The only way to quit the Quad I/O Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 55 Quad I/O Fast Read Sequence Diagram (STR, M5-4= (1, 0)) CS# 0 5 6 7 8 21 22 23 SCLK Dummy Address IO[3:0] Addr. M7-4 M3-0 Byte 1 Data out Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 46 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 56 Quad I/O Fast Read Sequence Diagram (DTR, M5-4= (1, 0)) CS# 0 1 2 3 18 19 SCLK Dummy IO[3:0] Byte 1 Byte 2 Data Data Data out out out Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O Fast Read command can be used to access a specific portion within a page by issuing Wrap configuration register Byte prior to EBH/ECH. The data being accessed can be limited to either a 16/32/64-Byte section of a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 9.17 Quad I/O DTR Read (EDH/EEH) The Quad I/O DTR Read instruction enables Double Transfer Rate throughput on quad I/O of Serial Flash in read mode. The address (interleave on 4 I/O pins) is latched on both rising and falling edge of SCLK, and data (interleave on 4 I/O pins) shift out on both rising and falling edge of SCLK. The 8-bit address can be latched-in at one clock, and 8-bit data can be read out at one clock, which means four bits at rising edge of clock, the other four bits at falling edge of clock. The first address Byte can be at any location. The address is automatically increased to the next higher address after each Byte data is shifted out, so the whole memory can be read out at a single Quad I/O DTR Read command. The address counter rolls over to 0 when the highest address has been reached. While Program/Erase/Write Status Register cycle is in progress, Quad I/O DTR Read command is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 57. DTR Quad I/O Fast Read Sequence Diagram (SPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 26 27 SCLK Command EDH IO0 Dummy 4 0 4 0 4 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 A23-0 DQS M7-0 7 3 7 3 Byt e1 Byt e2 High-Z Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 47 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 58. DTR Quad I/O Fast Read Sequence Diagram (QPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 20 21 22 SCLK Command IO[3:0] Dummy Address Byte 1 Byte 2 A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 EDH Data out Data out Byte n Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 59. DTR Quad I/O Fast Read Sequence Diagram (Quad DTR, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 SCLK Dummy IO[3:0] EDH Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Read with “Continuous Read Mode” The Quad I/O DTR Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input address. If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O DTR Read command (after CS# is raised and then lowered) does not require the EDH/EEH command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the first EDH/EEH command code, thus returning to normal operation. The only way to quit the Quad I/O DTR Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 60. DTR Quad I/O Fast Read Sequence Diagram (M5-4 = (1, 0)) CS# 0 1 2 3 4 5 18 19 20 SCLK Dummy Address IO[3:0] A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 Byte 1 Byte 2 Data out Data out Byte n Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O DTR Fast Read command can be used to access a specific portion within a page by issuing Wrap 48 Uniform Sector Standard and Quad Serial Flash GD25LT256E configuration register Byte prior to EDH/EEH. The data being accessed can be limited to either a 16/32/64-Byte section of a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 9.18 Page Program (PP) (02H/12H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three or four address Bytes and at least one data Byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low  sending Page Program command  3-Byte address or 4-Byte address on SI  at least 1 Byte data on SI  CS# goes high. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is t PP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. Figure 61 Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 3 2 1 0 7 MSB 6 5 4 3 2 1 2078 2079 2076 2077 2075 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2074 CS# 2072 MSB 2073 02H SI Data Byte 1 1 0 SCLK Data Byte 2 SI 7 MSB 6 5 4 3 2 Data Byte 3 1 0 7 6 5 4 3 MSB 2 Data Byte 256 1 0 7 6 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 49 0 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 62 Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 02H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 63 Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Addr. Addr. Addr. Addr. Addr. Addr. Data in in 02H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.19 Quad Page Program (32H/34H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The quad Page Program command is entered by driving CS# Low, followed by the command code (32H/34H), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Quad Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. 50 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 64 Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 32H 23 22 21 3 Byte1 Byte2 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 538 539 540 541 542 543 1 537 2 0 4 IO0 CS# 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 536 MSB SCLK Byte11Byte12 Byte253 Byte256 IO0 4 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 65 Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 32H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 51 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 66 Quad Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in 32H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.20 Extend Quad Page Program (C2H/3EH) The Extend Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The extend quad Page Program command is entered by driving CS# Low, followed by the command code (C2H/3EH), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Extend Quad Page Program (EPP) command is not executed. As soon as CS# is driven high, the self-timed Extend Quad Page Program cycle (whose duration is tPP) is initiated. While the Extend Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Extend Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. An Extend Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) is not executed. Figure 67 Extend Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 7 IO0 C2H Address A23-16 A15-8 A7-0 Byte1 Byte2 Byte3 Byte4 Byte5 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 52 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 68 Extend Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK Command Address C2H Addr. IO[3:0] Byte 1 Data in Byte 2 Data in Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 69 Extend Quad Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Addr. Addr. Addr. Addr. Addr. Addr. Data in in C2H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.21 Sector Erase (SE) (20H/21H) The Sector Erase (SE) command is erased the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3- Byte address or 4-Byte address on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low  sending Sector Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) command applied to a sector which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 70 Sector Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 20H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 53 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 71 Sector Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 20H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 72 Sector Erase Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 20H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.22 32KB Block Erase (BE32) (52H/5CH) The 32KB Block Erase command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 32KB Block Erase command. CS# must be driven low for the entire duration of the sequence. The 32KB Block Erase command sequence: CS# goes low  sending 32KB Block Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 32KB Block Erase command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE1) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 73 32KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 52H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 54 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 74 32KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 52H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 75 32KB Block Erase Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 52H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.23 64KB Block Erase (BE64) (D8H/DCH) The 64KB Block Erase command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 64KB Block Erase command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low  sending 64KB Block Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 64KB Block Erase command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE2) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits is not executed. Figure 76 64KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI D8H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 55 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 77 64KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address D8H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 78 64KB Block Erase Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] D8H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.24 Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is erased the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The Chip Erase command sequence: CS# goes low  sending Chip Erase command  CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the self-timed Chip Erase cycle (whose duration is t CE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, and BP0) bits are 0 The Chip Erase (CE) command is ignored if one or more sectors are protected. Figure 79 Chip Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 60H or C7H SI Figure 80 Chip Erase Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 60H or C7H 56 Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.25 Enable QPI (38H) The device support both Standard/Quad SPI and QPI mode. The “Enable QPI (38H)” command can switch the device from SPI mode to QPI mode. In order to switch the device to QPI mode, “Enable QPI (38H)” command must be issued. When the device is switched from SPI mode to QPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 81 Enable QPI mode command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 38H SI Figure 82 Enable QPI mode command Sequence Diagram (Quad DTR) CS# 0 1 SCLK Command IO[3:0] 38H 9.26 Disable QPI (FFH) To exit the QPI mode and return to Standard/Quad SPI mode, the “Disable QPI (FFH)” command must be issued. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 83 Disable QPI mode command Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] FFH 9.27 Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down (ABH) or Enable Reset (66H) and Reset (99H) commands. These commands can release the device from this mode. The Release from Deep Power-Down command releases the device from deep power down mode. 57 Uniform Sector Standard and Quad Serial Flash GD25LT256E The Deep Power-Down Mode automatically stops at Power-Down, and the device is in the Standby Mode after Power-Up. The Deep Power-Down command sequence: CS# goes low  sending Deep Power-Down command  CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of t DP before the supply current is reduced to ICC2 and the Deep Power-Down Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 84 Deep Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 tDP 7 SCLK Command SI Deep Power-down mode B9H Figure 85 Deep Power-Down Sequence Diagram (QPI and Quad DTR) CS# 0 1 tDP SCLK Deep Power-down mode Command IO[3:0] B9H 9.28 Release from Deep Power-Down (ABH) To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must remain high during the tRES1 time duration. When used to release the device from the Power-Down state, the command is the same as previously described, After this time duration the device will resume normal operation and other command will be accepted. If the Release from PowerDown command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not have any effects on the current cycle. Figure 86 Release Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 t RES1 SCLK Command SI ABH Deep Power-down mode 58 Stand-by mode Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 87 Release Power-Down Sequence Diagram (QPI & Quad DTR) CS# 0 1 tRES1 SCLK Deep Power-down mode Command IO[3:0] Stand-by mode ABH 9.29 Read Unique ID (4BH) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low  sending Read Unique ID command  3-Byte address (000000H) or 4-Byte address (00000000H) on SI 1 Byte Dummy 128bit Unique ID Out CS# goes high. Figure 88 Read Unique ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 4BH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 Data Out1 Data Out2 7 6 5 4 3 2 1 0 7 6 5 MSB MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. SO Figure 89 Read Unique ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command IO[3:0] 4BH Address (000000H) Addr. Addr. Addr. Addr. Addr. Addr. Dummy Byte 1 UID out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 59 UID out Byte 2 UID out Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 90 Read Unique ID Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 4BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 12 13 SCLK Byte 1 UID UID out out IO[3:0] Byte 2 UID out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.30 Read Identification (RDID) (9FH/9EH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by three Bytes of device identification. The device identification indicates the memory type in the first Byte, and the memory capacity of the device in the second Byte. The Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# low. Then, the 8-bit command code for the command is shifted in. This is followed by the 32-bit device identification, stored in the memory. Each bit is shifted out on the falling edge of Serial Clock. The Read Identification (RDID) command is terminated by driving CS# high at any time during data output. When CS# is driven high, the device is in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. In QPI mode, 8 dummy clocks is required between the command and data when the clock frequency is higher than 104MHz. Figure 91 Read Identification ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK SI 9FH/9EH SO CS# 7 6 MSB Manufacturer ID 5 4 3 2 1 0 7 Memory Type ID23-16 6 5 4 3 2 1 0 MSB 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI SO 7 MSB Capacity ID15-8 6 5 4 3 2 1 Device ID7-0 0 7 6 5 4 MSB 3 2 Manufacturer ID 1 0 7 MSB 60 6 5 4 3 2 1 0 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 92 Read Identification ID Sequence Diagram (QPI, fSCLK≤104MHz) CS# 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command IO[3:0] (MID & DID) LOOP 9FH/9EH MID7~0 DID23~16 (MID & DID) LOOP DID15~8 DID7~0 MID7~0 DID Figure 93 Read Identification ID Sequence Diagram (QPI, fSCLK﹥104MHz) CS# 0 1 2 9 10 11 12 13 14 15 16 17 SCLK Command IO[3:0] Don t care (MID & DID) Loop 9FH/9EH MID7~0 DID23~16 DID15~8 DID7~0 (MID & DID) Loop MID7~0 Figure 94 Read Identification ID Sequence Diagram (Quad DTR) CS# 0 9 1 10 11 12 SCLK Dummy IO[3:0] MID 7-4 9FH or 9EH (MID & DID) LOOP MID DID DID DID DID 3-0 23-20 19-16 15-12 11-8 DQS CS# 13 14 15 16 17 18 SCLK IO[3:0] DID 7-4 DID 3-0 MID 7-4 (MID & DID) LOOP MID DID DID DID DID 3-0 23-20 19-16 15-12 11-8 DID 7-4 DID 3-0 (MID & DID) LOOP MID MID DID 7-4 3-0 DQS 9.31 Program/Erase Suspend (PES) (75H) The Program/Erase Suspend command “75H”, allows the system to interrupt a page program or sector/block erase operation and then read data from any other sector or block. The Write Register command (01H, B1H) and Erase/Program Security Registers command (44H, 42H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) and Page Program command (02H/12H, 32H/34H, C2H/3EH) are not allowed during Program suspend. The Write Register command (01H, B1H) and Erase Security Registers command (44H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) are not allowed during Erase suspend. Program/Erase Suspend is valid only during the page program or sector/block erase operation. A maximum of time of “tsus” (See AC Characteristics) is required to suspend the program/erase operation. The Program/Erase Suspend command will be accepted by the device only if the SUS1/SUS2 bit in the Flag Status Register equal to 0 and WIP bit equal to 1 while a Page Program or a Sector or Block Erase operation is on-going. If the SUS1/SUS2 61 Uniform Sector Standard and Quad Serial Flash GD25LT256E bit equal to 1 or WIP bit equal to 0, the Suspend command will be ignored by the device. The WIP bit will be cleared from 1 to 0 within “tsus” and the SUS1/SUS2 bit will be set from 0 to 1 immediately after Program/Erase Suspend. A power-off during the suspend period will reset the device and release the suspend state. Figure 95 Program/Erase Suspend Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 tSUS SCLK Command SI 75H High-Z SO Accept read command Figure 96 Program/Erase Suspend Sequence Diagram (QPI and Quad DTR) CS# 0 1 tSUS SCLK Accept read command Command IO[3:0] 75H 9.32 Program/Erase Resume (PER) (7AH) The Program/Erase Resume command must be written to resume the program or sector/block erase operation after a Program/Erase Suspend command. The Program/Erase Resume command will be accepted by the device only if the SUS1/SUS2 bit equal to 1 and the WIP bit equal to 0. After issued the SUS1/SUS2 bit in the status register will be cleared from 1 to 0 immediately, the WIP bit will be set from 0 to 1 within 200ns and the Sector or Block will complete the erase operation or the page will complete the program operation. The Program/Erase Resume command will be ignored unless a Program/Erase Suspend is active. Figure 97 Program/Erase Resume Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7AH Resume Erase/Program Figure 98 Program/Erase Resume Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 7AH 62 Resume Program/Erase Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.33 Erase Security Registers (44H) The GD25LT256E provides 4K-Byte Security Registers which can be erased and programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low  sending Erase Security Registers command  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit in the Configuration Register can be used to OTP protect the security registers. Once the bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-0 Don’t care Figure 99 Erase Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 23 22 MSB 44H 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 100 Erase Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK IO[3:0] Command Address 44H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 101 Erase Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 44H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 63 Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.34 Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. The security register contains 16 pages content. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address Bytes and at least one data Byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-8 Page Address A7-0 Byte Address Figure 102 Program Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 3 2 1 0 7 MSB 6 5 4 3 2 1 0 2078 2079 2076 2077 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2075 2072 CS# 2074 MSB 2073 42H SI Data Byte 1 1 0 SCLK Data Byte 2 SI 7 6 5 4 3 2 Data Byte 3 1 MSB 0 7 6 5 4 3 2 Data Byte 256 1 0 7 MSB 6 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 103 Program Security Registers command Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 42H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 64 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 104 Program Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in 42H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.35 Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3-Byte or 4-Byte address (A23-A0 or A31-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency f C, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Once the A11-A0 address reaches the last Byte of the register (Byte FFFH), it will reset to 000H, the command is completed by driving CS# high. Address Security Register A23-16 00H A15-12 0000 A11-8 Page Address A7-0 Byte Address Figure 105 Read Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 48H 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI SO 7 6 5 4 3 2 1 0 7 6 MSB Data Out1 5 4 3 2 1 0 Data Out2 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 65 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 106 Read Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 23 24 25 SCLK IO[3:0] Dummy Command Address 48H Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Data out Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 107 Read Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 48H Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 20 21 SCLK IO[3:0] Byte 1 Data Data out out Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.36 Individual Block/Sector Lock (36H)/Unlock (39H)/Read (3DH) The individual block/sector lock provides an alternative way to protect the memory array from adverse Erase/Program. In order to use the Individual Block/Sector Locks, the WPS bit in Configuration Register bit 2 at address 04h must be set to 0. If WPS=1, the write protection will be determined by the combination of BP (4:0) bits in the Status Register. The individual Block/Sector Lock command (36H) sequence: CS# goes low SI: Sending individual Block/Sector Lock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  CS# goes high. The individual Block/Sector Unlock command (39H) sequence: CS# goes low SI: Sending individual Block/Sector Unlock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  CS# goes high. The Read individual Block/Sector lock command (3DH) sequence: CS# goes low  SI: Sending Read individual Block/Sector Lock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  SO: The Block/Sector Lock Bit will out CS# goes high. If the least significant bit (LSB) is1, the corresponding block/sector is locked, if the LSB is 0, the corresponding block/sector is unlocked, Erase/Program operation can be performed. 66 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 108 Individual Block/Sector Lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 36H 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 109 Individual Block/Sector Lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 36H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 110 Individual Block/Sector Lock command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 36H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 111 Individual Block/Sector Unlock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 39H 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 112 Individual Block/Sector Unlock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK IO[3:0] Command Address 39H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 67 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 113 Individual Block/Sector Unlock command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 39H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 114 Read Individual Block/Sector lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 3DH 23 22 2 1 Lock value out X X X X X X X 0 High-Z SO 0 MSB MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 115 Read Individual Block/Sector lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command IO[3:0] dummy Address 3DH Lock Value Data out Addr. Addr. Addr. Addr. Addr. Addr. Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 116 Read Individual Block/Sector lock command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK IO[3:0] 3DH Addr. Addr. Addr. Addr. Addr. Addr. CS# 12 13 SCLK IO[3:0] Lock Value Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 68 dummy Uniform Sector Standard and Quad Serial Flash GD25LT256E 9.37 Global Block/Sector Lock (7EH) or Unlock (98H) All Block/Sector Lock bits can be set to 1 by the Global Block/Sector Lock command, or can set to 0 by the Global Block/Sector Unlock command. The Global Block/Sector Lock command (7EH) sequence: CS# goes low SI: Sending Global Block/Sector Lock command CS# goes high. The Global Block/Sector Unlock command (98H) sequence: CS# goes low SI: Sending Global Block/Sector Unlock command CS# goes high. Figure 117 Global Block/Sector Lock Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7EH High-Z SO Figure 118 Global Block/Sector Lock Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 7EH Figure 119 Global Block/Sector Unlock Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 98H High-Z SO Figure 120 Global Block/Sector Unlock Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command IO[3:0] 98H 9.38 Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation (except in Continuous Read Mode) will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status 69 Uniform Sector Standard and Quad Serial Flash GD25LT256E Register bits, Write Enable Latch status (WEL), Program/Erase Suspend status, Read Parameter setting (P7-P0), Deep Power Down Mode, Continuous Read Mode bit setting (M7-M0). When Flash is in QPI Mode, DTR Mode or Continuous Read Mode (XIP), 66H&99H cannot reset Flash to power-on state. Therefore, it is recommended to send the following sequence to reset Flash in these modes: 1. 8CLK with IO= all “H” or all “L”: ensure Flash quit XIP mode 2. QPI format 66H/99H: ensure Flash in QPI mode and DTR mode can be reset 3. SPI format 66H/99H: ensure Flash in SPI mode can be reset The “Enable Reset (66H)” and the “Reset (99H)” commands can be issued in either SPI or QPI mode. The “Reset (99H)” command sequence as follow: CS# goes low  Sending Enable Reset command  CS# goes high  CS# goes low  Sending Reset command  CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST / tRST_E to reset. During this period, no command will be accepted. Data corruption may happen if there is an on-going or suspended internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the WIP bit and the SUS1/SUS2 bits in Flag Status Register before issuing the Reset command sequence. Figure 121 Enable Reset and Reset command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command Command 66H 99H SI High-Z SO Figure 122 Enable Reset and Reset command Sequence Diagram (QPI and Quad DTR) CS# 0 1 0 1 SCLK IO[3:0] Command Command 66H 99H 9.39 Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216C. 70 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 123 Read Serial Flash Discoverable Parameter command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 5AH 23 22 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 Data Out1 5 4 3 2 7 6 MSB SO 1 0 Data Out2 7 6 5 MSB Figure 124 Read Serial Flash Discoverable Parameter command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command IO[3:0] 5AH Dummy Address Byte 1 Byte 2 SFDP SFDP SFDP out out out Addr. Addr. Addr. Addr. Addr. Addr. Figure 125 Read Serial Flash Discoverable Parameter command Sequence Diagram (DTR, QPI) CS# 0 1 2 3 4 5 SCLK IO[3:0] 5AH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 11 12 SCLK Dummy IO[3:0] Byte 1 Byte 2 SFDP SFDP SFDP out out out DQS Table 17 Signature and Parameter Identification Data Values (Please contact GigaDevice for details) 71 Uniform Sector Standard and Quad Serial Flash GD25LT256E 10 ELECTRICAL CHARACTERISTICS 10.1 Power-On Timing Figure 126 Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) Device is fully accessible tVSL VWI Time Table 18 Power-Up Timing and Write Inhibit Threshold Symbol Parameter tVSL VCC (min.) to device operation VWI Write Inhibit Voltage Min. Max. 1.5 Unit ms 1 1.4 V 10.2 Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1 (each Byte contains FFH). The Status Register contains 00H (all Status Register bits are 0). 10.3 Absolute Maximum Ratings Parameter Value Ambient Operating Temperature (TA) -40 to 85 Unit ℃ -40 to 105 -40 to 125 ℃ Storage Temperature -65 to 150 Transient Input/Output Voltage (note: overshoot) -2.0 to VCC+2.0 V Applied Input/Output Voltage -0.6 to VCC+0.4 V -0.6 to 2.5 V VCC 72 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 127. Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns Maximum Positive Overshoot Waveform 20ns 20ns Vss Vcc + 2.0V Vss-2.0V Vcc 20ns 20ns 20ns 10.4 Capacitance Measurement Conditions Symbol Parameter Min. Typ. Max. Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 30 pF Input Rise And Fall time 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to 0.7VCC V 0.5VCC V Output Timing Reference Voltage Figure 128. Absolute Maximum Ratings Diagram Input timing reference level 0.8VCC 0.7VCC 0.1VCC 0.2VCC Output timing reference level AC Measurement Level Note: Input pulse rise and fall time are100MHz) tCHCL Serial Clock Rise/Fall Time (Slew Rate) (fSCLK>133MHz) Serial Clock Rise/Fall Time (Slew Rate) (fSCLK>166MHz) tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX Output Disable Time 8 1.8 ns Data In Setup Time (STR) (fSCLK≤133MHz) 2 ns Data In Setup Time (STR) (fSCLK>133MHz) 1 ns Data In Setup Time (DTR) (fSCLK≤100MHz) 1 ns tDVCH Data In Setup Time (DTR) (fSCLK>100MHz) 0.8 ns tDVCL Data In Setup Time (DTR) (fSCLK>133MHz) 0.6 ns Data In Setup Time (DTR) (fSCLK>166MHz) 0.5 ns Data In Hold Time (STR) (fSCLK≤133MHz) 2 ns Data In Hold Time (STR) (fSCLK>133MHz) 1 ns Data In Hold Time (DTR) (fSCLK≤100MHz) 1 ns tCHDX Data In Hold Time (DTR) (fSCLK>100MHz) 0.8 ns tCLDX Data In Hold Time (DTR) (fSCLK>133MHz) 0.6 ns Data In Hold Time (DTR) (fSCLK>166MHz) 0.5 ns tCHQX tDVCH tCHDX tQSV Output Hold Time ns Clock transient to DQS valid time Align to 30pF tCLQV 77 ns Uniform Sector Standard and Quad Serial Flash GD25LT256E SIO Valid Skew Related to DQS (TFBGA, 12pF) 0.4 ns SIO Valid Skew Related to DQS (SOP, 12pF) 0.6 ns SIO Hold Skew Factor (TFBGA, 12pF) 0.4 ns SIO Hold Skew Factor (SOP, 12pF) 0.6 ns tECSV ECS# Setup Time 10 ns tCLQV Clock Transient To Output Valid (30pF) 8 ns tCHQV Clock Transient To Output Valid (12pF) 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode tDQSQ tQHS tRES1 CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST tRST_E tW 3 μs 30 μs 20 μs 100 μs CS# High To Next Command After Reset (Except 40 μs 25 ms 2 20 ms From Erase) CS# High To Next Command After Reset (From Erase) Write Status Register Cycle Time Write Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 70 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 12 μs tPP Page Programming Time 0.3 1.2 ms tSE Sector Erase Time 30 300 ms tBE1 Block Erase Time (32K Bytes) 0.1 1 s tBE2 Block Erase Time (64K Bytes) 0.2 2 s tCE Chip Erase Time (GD25LT256E) 50 200 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST 4. For SOP16 package, fC1 = 166MHz, fC2 = 166MHz. For WSON8 package, fC1 = 166MHz, fC2 = 90MHz. 78 Uniform Sector Standard and Quad Serial Flash GD25LT256E (TA = -40℃~105℃, VCC=1.65~2.0V) Symbol fC1 Parameter Min. Typ. Serial Clock Frequency for all instructions except Read (03H, 13H) in STR mode Max. Unit. 166(4) MHz 200(4) MHz 60 MHz Serial Clock Frequency for Fast Read in DTR Mode fC2 (0BH, 0CH, 6BH, 6CH, EBH, ECH, EDH, EEH in DTR mode) fR Serial Clock Frequency For: Read (03H, 13H) tCLH Serial Clock High Time 45% (1/fc) ns tCLL Serial Clock Low Time 45% (1/fc) ns 0.6 V/ns 0.8 V/ns 1 V/ns 1.2 V/ns Serial Clock Rise/Fall Time (Slew Rate) (fSCLK≤100MHz) Serial Clock Rise/Fall Time (Slew Rate) tCLCH (fSCLK>100MHz) tCHCL Serial Clock Rise/Fall Time (Slew Rate) (fSCLK>133MHz) Serial Clock Rise/Fall Time (Slew Rate) (fSCLK>166MHz) tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX Output Disable Time 8 1.8 ns Data In Setup Time (STR) (fSCLK≤133MHz) 2 ns Data In Setup Time (STR) (fSCLK>133MHz) 1 ns Data In Setup Time (DTR) (fSCLK≤100MHz) 1 ns tDVCH Data In Setup Time (DTR) (fSCLK>100MHz) 0.8 ns tDVCL Data In Setup Time (DTR) (fSCLK>133MHz) 0.6 ns Data In Setup Time (DTR) (fSCLK>166MHz) 0.5 ns Data In Hold Time (STR) (fSCLK≤133MHz) 2 ns Data In Hold Time (STR) (fSCLK>133MHz) 1 ns Data In Hold Time (DTR) (fSCLK≤100MHz) 1 ns tCHDX Data In Hold Time (DTR) (fSCLK>100MHz) 0.8 ns tCLDX Data In Hold Time (DTR) (fSCLK>133MHz) 0.6 ns Data In Hold Time (DTR) (fSCLK>166MHz) 0.5 ns tCHQX tDVCH tCHDX tQSV Output Hold Time ns Clock transient to DQS valid time Align to 30pF tCLQV 79 ns Uniform Sector Standard and Quad Serial Flash GD25LT256E SIO Valid Skew Related to DQS (TFBGA, 12pF) 0.4 ns SIO Valid Skew Related to DQS (SOP, 12pF) 0.6 ns SIO Hold Skew Factor (TFBGA, 12pF) 0.4 ns SIO Hold Skew Factor (SOP, 12pF) 0.6 ns tECSV ECS# Setup Time 10 ns tCLQV Clock Transient To Output Valid (30pF) 8 ns tCHQV Clock Transient To Output Valid (12pF) 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode tDQSQ tQHS tRES1 CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST tRST_E tW 3 μs 30 μs 20 μs 100 μs CS# High To Next Command After Reset (Except 40 μs 25 ms 2 30 ms From Erase) CS# High To Next Command After Reset (From Erase) Write Status Register Cycle Time Write Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 140 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 25 μs tPP Page Programming Time 0.3 2 ms tSE Sector Erase Time 30 500 ms tBE1 Block Erase Time (32K Bytes) 0.1 1.6 s tBE2 Block Erase Time (64K Bytes) 0.2 3 s tCE Chip Erase Time (GD25LT256E) 50 300 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST 4. For SOP16 package, fC1 = 166MHz, fC2 = 166MHz. For WSON8 package, fC1 = 166MHz, fC2 = 90MHz. 80 Uniform Sector Standard and Quad Serial Flash GD25LT256E (TA = -40℃~125℃, VCC=1.65~2.0V) Symbol fC1 Parameter Min. Typ. Serial Clock Frequency for all instructions except Read (03H, 13H) in STR mode Max. Unit. 166(4) MHz 166(4) MHz 60 MHz Serial Clock Frequency for Fast Read in DTR Mode fC2 (0BH, 0CH, 6BH, 6CH, EBH, ECH, EDH, EEH in DTR mode) fR Serial Clock Frequency For: Read (03H, 13H) tCLH Serial Clock High Time 45% (1/fc) ns tCLL Serial Clock Low Time 45% (1/fc) ns 0.6 V/ns 0.8 V/ns 1 V/ns Serial Clock Rise/Fall Time (Slew Rate) (fSCLK≤100MHz) tCLCH Serial Clock Rise/Fall Time (Slew Rate) tCHCL (fSCLK>100MHz) Serial Clock Rise/Fall Time (Slew Rate) (fSCLK>133MHz) tSLCH CS# Active Setup Time 4 ns tCHSH CS# Active Hold Time 4 ns tCLSH CS# Active Hold Time (DTR) 4 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns CS# High Time (Read) 20 ns CS# High Time (Write) 40 ns tSHSL tSHQZ tCLQX tCHQX tDVCH tDVCH tDVCL tCHDX tCHDX tCLDX tQSV tDQSQ tQHS tECSV Output Disable Time 8 Output Hold Time ns 1.8 ns Data In Setup Time (STR) (fSCLK≤133MHz) 2 ns Data In Setup Time (STR) (fSCLK>133MHz) 1 ns Data In Setup Time (DTR) (fSCLK≤100MHz) 1 ns Data In Setup Time (DTR) (fSCLK>100MHz) 0.8 ns Data In Setup Time (DTR) (fSCLK>133MHz) 0.6 ns Data In Hold Time (STR) (fSCLK≤133MHz) 2 ns Data In Hold Time (STR) (fSCLK>133MHz) 1 ns Data In Hold Time (DTR) (fSCLK≤100MHz) 1 ns Data In Hold Time (DTR) (fSCLK>100MHz) 0.8 ns Data In Hold Time (DTR) (fSCLK>133MHz) 0.6 ns Clock transient to DQS valid time Align to 30pF tCLQV ns SIO Valid Skew Related to DQS (TFBGA, 12pF) 0.4 ns SIO Valid Skew Related to DQS (SOP, 12pF) 0.6 ns SIO Hold Skew Factor (TFBGA, 12pF) 0.4 ns SIO Hold Skew Factor (SOP, 12pF) 0.6 ns ECS# Setup Time 10 ns 81 Uniform Sector Standard and Quad Serial Flash GD25LT256E tCLQV Clock Transient To Output Valid (30pF) 8 ns tCHQV Clock Transient To Output Valid (12pF) 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode tRES1 CS# High To Standby Mode Without Electronic Signature Read tSUS CS# High To Next Command After Suspend tRS Latency Between Resume And Next Suspend tRST tRST_E tW 3 μs 30 μs 20 μs 100 μs CS# High To Next Command After Reset (Except 40 μs 25 ms 2 30 ms From Erase) CS# High To Next Command After Reset (From Erase) Write Status Register Cycle Time Write Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 140 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 25 μs tPP Page Programming Time 0.3 3 ms tSE Sector Erase Time 30 700 ms tBE1 Block Erase Time (32K Bytes) 0.1 1.6 s tBE2 Block Erase Time (64K Bytes) 0.2 3 s tCE Chip Erase Time (GD25LT256E) 50 300 s Note: 1. Typical value at TA = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST 4. For SOP16 package, fC1 = 133MHz, fC2 = 133MHz. For WSON8 package, fC1 = 133MHz, fC2 = 84MHz. Figure 129. Serial Input Timing tSHSL CS# tCHSL tSLCH tCHSH tSHCH SCLK tDVCH SI MSB SO High-Z tCHCL tCLCH tCHDX LSB 82 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 130. Output Timing CS# tCLH SCLK tCLQV tCLQV tCLQX tSHQZ tCLL tCLQX SO LSB SI Least significant address bit (LIB) in Figure 131. Serial Input Timing (DTR) tSHSL CS# tSLCH tCLSH tCHSL tSHCH SCLK tDVCL tDVCH tCLDX IO tCLCH MSB tCHCL LSB tCHDX Figure 132. Serial Output Timing (DTR) CS# tCLQV tCLH SCLK IO tCLL tCHQV tCLQX tSHQZ MSB LSB tCHQX 83 Uniform Sector Standard and Quad Serial Flash GD25LT256E Figure 133. DQS Output Timing (STR) CS# SCLK tQSV DQS tDQSQ tQHS tSHQZ IO Figure 134. DQS Output Timing (DTR) CS# SCLK tQSV DQS tDQSQ tDQSQ tQHS tSHQZ IO tQHS Figure 135. Resume to Suspend Timing Diagram Resume Command CS# tRS Suspend Command Figure 136. RESET Timing CS# tRB RESET# tRLRH 84 tRHSL Uniform Sector Standard and Quad Serial Flash GD25LT256E Table 17. Reset Timing Symbol Parameter Min. Typ. Max. Unit. tRLRH Reset Pulse Width 1 μs tRHSL Reset Hold time before next Operation 50 ns tRB Reset Recovery Time (From Read or Program) 40 μs Reset Recovery Time (From Erase) 25 ms Note: 1. Time of Reset Recovery Time from 01H/B1H command would be tW + tRB 2. The device need tRB (max) at most to get ready for all commands after RESET# low. 85 Uniform Sector Standard and Quad Serial Flash GD25LT256E 11 ORDERING INFORMATION GD XX XX XX X X X X X Packing T or no mark: Tube Y: Tray R: Tape and Reel Green Code G: Pb Free + Halogen Free Green Package R: Pb Free + Halogen Free Green Package + RESET# Pin Temperature Range I: Industrial (-40℃ to +85℃) J: Industrial (-40℃ to +105℃) E: Industrial (-40℃ to +125℃) F: Industrial+ (-40℃ to +85℃)** 3: Automotive (-40℃ to +85℃)* 2: Automotive (-40℃ to +105℃)* A: Automotive (-40℃ to +125℃)* Package Type F: SOP16 300mil Y: WSON8 (8x6mm) B: TFBGA-24ball (5x5 Ball Array) Generation E: E Version Density 256: 256M bit Series LT: 1.8V, 4KB Uniform Sector, high speed Product Family 25: SPI NOR Flash *Please contact GigaDevice sales for automotive products. **F grade has implemented additional test flows to ensure higher product quality than I grade. 86 Uniform Sector Standard and Quad Serial Flash GD25LT256E 11.1 Valid Part Numbers Please contact GigaDevice regional sales for the latest product selection and available form factors. Temperature Range I: Industrial (-40℃ to +85℃) Product Number Clock (DTR) Density Package Type Packing Options GD25LT256EFIR GD25LT256EYIG GD25LT256EBIR 166MHz 90MHz 200MHz 256Mbit 256Mbit 256Mbit SOP16 300mil WSON8 (8x6mm) TFBGA-24ball (5x5 Ball Array) T/Y/R Y/R Y Temperature Range J: Industrial (-40℃ to +105℃) Product Number Clock (DTR) Density Package Type Packing Options GD25LT256EFJR GD25LT256EYJG GD25LT256EBJR 166MHz 90MHz 200MHz 256Mbit 256Mbit 256Mbit SOP16 300mil WSON8 (8x6mm) TFBGA-24ball (5x5 Ball Array) T/Y/R Y/R Y Temperature Range E: Industrial (-40℃ to +125℃) Product Number Clock (DTR) Density Package Type Packing Options GD25LT256EFER GD25LT256EYEG GD25LT256EBER 133MHz 84MHz 166MHz 256Mbit 256Mbit 256Mbit SOP16 300mil WSON8 (8x6mm) TFBGA-24ball (5x5 Ball Array) T/Y/R Y/R Y Temperature Range F: Industrial+ (-40℃ to +85℃) Product Number Clock (DTR) Density Package Type Packing Options GD25LT256EFFR GD25LT256EYFG GD25LT256EBFR 166MHz 90MHz 200MHz 256Mbit 256Mbit 256Mbit SOP16 300mil WSON8 (8x6mm) TFBGA-24ball (5x5 Ball Array) T/Y/R Y/R Y 87 Uniform Sector Standard and Quad Serial Flash GD25LT256E 12 PACKAGE INFORMATION 12.1 Package SOP16 300MIL D 16 9 E1 E h L1 L 1 h 8 “A” θ b Base Metal c A A2 b Detail “A” A1 e Dimensions Symbol A A1 A2 b c D E E1 Min - 0.10 2.05 0.31 0.10 10.20 10.10 7.40 Nom - 0.20 - 0.41 0.25 10.30 10.30 7.50 Max 2.65 0.30 2.55 0.51 0.33 10.40 10.50 7.60 Unit mm Note: 1. Both the package length and width do not include the mold flash. 2. Seating plane: Max. 0.1mm. 88 e L L1 0.40 1.27 1.27 1.40 h θ 0.25 0 - - 0.75 8 Uniform Sector Standard and Quad Serial Flash GD25LT256E 12.2 Package WSON8 (8x6mm) c D PIN 1# E A1 A Top View Side View D2 4 5 E2 e b 1 8 L Bottom View Dimensions Symbol A A1 c b D D2 E E2 Min 0.70 0.00 0.180 0.35 7.90 3.30 5.90 4.20 Nom 0.75 0.02 0.203 0.40 8.00 3.40 6.00 4.30 Max 0.80 0.05 0.250 0.45 8.10 3.50 6.10 4.40 Unit mm e L 0.45 1.27 0.50 0.55 Note: 1. Both the package length and width do not include the mold flash. 2. The exposed metal pad area on the bottom of the package is floating. 3. Coplanarity ≤0.08mm. Package edge tolerance≤0.10mm. 4. The lead shape may be of little difference according to different package lead frames. These lead shapes are compatible with each other. 89 Uniform Sector Standard and Quad Serial Flash GD25LT256E 12.3 Package TFBGA-24BALL (5x5 ball array) 1 2 3 4 5 5 4 3 2 1 A A B B b C D C D1 D D e E E e E E1 A2 A A1 Dimensions Symbol A A1 A2 b E Min - 0.25 0.75 0.35 5.90 Nom - 0.30 0.80 0.40 6.00 Max 1.20 0.35 0.85 0.45 6.10 Unit mm E1 D1 e 4.00 1.00 7.90 4.00 Note: Both the package length and width do not include the mold flash. 90 D 8.00 8.10 Uniform Sector Standard and Quad Serial Flash GD25LT256E 13 REVISION HISTORY Version No 1.0 Description Page Date Initial release All 2019-8-5 Remove 30H command --- Modify the sequence diagram of 05H/70H/C8H/9EH/9FH in QPI mode 1.1 1.2 P36-38,40,59 Modify tVSL min. value from 2.5ms to 1.5ms P70 Modify ICC1 from 25~150uA to 20~140uA P72 Modify ICC2 max value from 50uA to 30uA P72 Modify ICC3 @200MHz(DTR) from 50~70mA to 30~50mA P72 Modify ICC3 @166MHzfrom 30~50mA to 20~30mA P72 Modify ICC4~8 from 20~40mA to 12~20mA P72 Modify tW from 4~40ms to 2~20ms P73 Modify tPP typ. value from 0.4ms to 0.3ms P74 Modify tSE max. value from 400ms to 300ms P74 Modify tBE1 max. value from 0.8s to 1s P74 Modify max. value of tRST, tRST_E, tBP1, tBP2 @-40 to 85℃ P76 P74, 77, 78 Add DC/AC parameters @-40 to 105℃ Modify default value of Byte and Byte in non-volatile/volatile 2020-1-8 2020-7-20 P21-24 configuration register 1.3 Modify tCHSH/tCLSH from 3ns to 4ns P77, 79 Modify tSHCH from 3ns to 5ns P77, 79 Modify tCLQX/tCHQX from 1ns to 1.8ns P77, 79 P76, 81-82 Add -40~125℃ DC/AC parameters Add package of WSON8 8x6mm P89 91 2020-11-20 Uniform Sector Standard and Quad Serial Flash GD25LT256E Important Notice This document is the property of GigaDevice Semiconductor (Beijing) Inc. and its subsidiaries (the "Company"). This document, including any product of the Company described in this document (the “Product”), is owned by the Company according to the laws of the People’s Republic of China and other applicable laws. The Company reserves all rights under such laws and no Intellectual Property Rights are transferred (either wholly or partially) or licensed (either expressly or impliedly). The names and brands of third party referred thereto (if any) are the property of their respective owner and referred to for identification purposes only. The Company does not assume any warranty or condition, express or implied, with regard to this document or any Product, including, but not limited to, the implied warranties of merchantability, fitness for any particular purpose, noninfringement, or any warranty arising out of the application or use of any Product described in this document. Any information provided in this document is provided only for reference purposes. It is the responsibility of the user of this document to properly design, program, and test the functionality and safety of any application and any product produced. Except for customized products which has been expressly identified in the applicable agreement, the Products are designed, developed, and/or manufactured for ordinary business, industrial, personal, and/or household applications only. The Products are not designed or intended for use in, and no warranty is made respect to, any applications designed or intended for the operation of weaponry, nuclear equipment, atomic energy control instruments, combustion control instruments, airplane or spaceship instruments, traffic signal instruments, life-support devices or systems, other medical devices or systems (including resuscitation equipment and surgical implants etc.), pollution control or hazardous substances management, or other uses where failure to perform can reasonably be expected to result in personal injury, death, property or environmental damage ("Unintended Uses"). Customers shall take any and all actions to ensure using and selling the Products in accordance with the applicable laws and regulations. The Company is not liable, in whole or in part, and customers shall and hereby do release the Company as well as it’s suppliers and/or distributors from any claim, damage, or other liability arising from or related to all Unintended Uses of the Products. Customers shall indemnify and hold the Company as well as it’s suppliers and/or distributors harmless from and against all claims, costs, damages, and other liabilities, including claims for personal injury or death, arising from or related to any Unintended Uses of the Products. Customers shall discard the device according to the local environmental law. Information in this document is provided solely in connection with the Products. The Company reserves the right to make changes, corrections, modifications or improvements to this document and the Products and services described herein at any time, without notice. And the company shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to them. 92 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GigaDevice: GD25LX256EBIRY GD25LT256EBIRY GD25LT256EYIGR
GD25LX256EBIRY 价格&库存
很抱歉,暂时无法提供与“GD25LX256EBIRY”相匹配的价格&库存,您可以联系我们找货
