NJU7077R-TE2
NJU7077R-TE2
    JRC(⽇本无线)
    LSSOP8
    IC CMOS 2 CIRCUIT 8VSP
NJU7077R-TE2 数据手册
NJU7076/NJU7077/NJU7078 PRECISION, LOW NOISE, RAIL-TO-RAIL OUTPUT, EXCELLENT EMI IMMUNITY, CMOS OPERATIONAL AMPLIFIERS FEATURES DESCRIPTION ●High Precision Low Input Offset Voltage NJU7076 / NJU7077 150μV max. NJU7078 200μV max. Low Offset Voltage Drift 0.5μV/°C typ. ●Low Noise 10nV/√Hz typ. ●Low Input Bias Current 1pA typ. ●Rail-to-Rail Output RL=10kΩ 0.02V to 4.98V typ. (V+=5V) RL=600Ω 0.08V to 4.92V typ. (V+=5V) ●Ground Sensing ●Integrated EMI Filter EMIRR=59dB typ. @f=900 MHz ●Operating Voltage 2.2V to 5.5V ●Unity-Gain Stable ●Package NJU7076 SOT-23-5 NJU7077 MSOP8 (VSP8)* The NJU7076/NJU7077/NJU7078 are single/dual/Quad channel, precision, low-noise, rail-to-rail output CMOS operational amplifiers. These devices featuring a low input offset voltage (50µV max.), low temperature drift (0.5µV/°C typ.), and low bias current (1pA typ.). The combination of these specifications makes the devices well-suited for sensor applications such as temperature sensors, weight sensors, high-precision current sensing amplifiers, and current-voltage converters. The output swing can reach 20 mV from the rails while driving a 10kΩ load (at 5V operation). Input voltage includes ground, enabling direct sensing near ground. The NJU7076/NJU7077/NJU7078 have high EMI immunity to reduce malfunctions, making them ideal for EMI-sensitive applications. *meet JEDEC MO-187-DA NJU7078 SSOP14 APPLICATIONS ●Thermocouple / Thermopile Amplifiers ●Strain Gauge / Pressure Sensor Amplifiers ●Load Cell and Bridge Transducer Amplifiers ●High-Resolution Data Acquisition ●Precision Current Sensing ●Battery Monitoring ●Photodiode Amplifiers ■ TYPICAL CHARACTERISTICS Voltage Noise Density vs. Frequency Input Offset Voltage vs. Temperature V+=5V, V-=0V, VCOM =V+/2 Equivalent Input Noise Voltage [nV/√Hz] 500 Input Offset Voltage [μV] 400 300 200 100 0 -100 -200 -300 -400 -500 -50 Ver.6.2 -25 V+=5V, V-=0V, Ta=25ºC 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature [ºC] www.njr.com 1 10 100 Frequency [Hz] 1k 10k -1- NJU7076/NJU7077/NJU7078 ■ PIN CONFIGURATIONS PRODUCT NAME NJU7076F NJU7077R Package SOT-23-5 MSOP8 (VSP8) (Top View) (Top View) OUTPUT 1 V- 2 +INPUT 3 Pin Functions 5 4 A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A +INPUT 3 6 B -INPUT V- 4 5 B +INPUT V+ -INPUT PRODUCT NAME NJU7078V Package SSOP14 (Top View) Pin Functions A OUTPUT 1 14 D OUTPUT A -INPUT 2 13 D -INPUT A +INPUT 3 12 D +INPUT V+ 4 11 V- B +INPUT 5 10 C +INPUT B -INPUT 6 9 C -INPUT B OUTPUT 7 8 C OUTPUT ■ PRODUCT NAME INFORMATION NJU7076 Part Number F (TE1) Package Taping Form ■ ORDER INFORMATION PRODUCT NAME PACKAGE RoHS HALOGENFREE TERMINAL FINISH MARKING WEIGHT (mg) MOQ (pcs) NJU7076F SOT-23-5 Yes Yes Sn2Bi 11D 15 3000 NJU7077R MSOP8 (VSP8) Yes Yes Sn2Bi 7077 21 2000 NJU7078V SSOP14 Yes Yes Sn2Bi 7078 65 2000 Ver.6.2 www.njr.com -2- NJU7076/NJU7077/NJU7078 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL + Supply Voltage V -V Differential Input Voltage (1) - VID Input Voltage RATING UNIT 7 V ±7 (2) - VIN V (3) V -0.3 to V⁺+0.3 Power Dissipation (Ta=25°C) SOT-23-5 MSOP8 (VSP8) SSOP14 Storage Temperature Range Tstg 2-Layer / 4-Layer(4) 480 / 650 500 / 660 555 / 690 -55 to 150 Maximum Junction Temperature Tjmax 150 SYMBOL VALUE PD V mW °C °C ■ THERMAL CHARACTERISTICS PACKAGE Junction-to-Ambient Thermal Resistance SOT-23-5 MSOP8 (VSP8) SSOP14 Junction-to-Top of Package Characterization Parameter (1) (2) (3) (4) UNIT (4) 2-Layer / 4-Layer 260 / 192 250 / 189 225 / 181 2-Layer / 4-Layer(4) Θja ºC/W SOT-23-5 67 / 58 Ψjt ºC/W MSOP8 (VSP8) 62 / 53 SSOP14 53 / 52 Differential voltage is the voltage difference between +INPUT and -INPUT. For supply voltage less than 7V, the absolute maximum rating is equal to the supply voltage. The absolute maximum input voltage is limited at 7V. 2-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6 mm: based on EIA/JDEC standard, 2-layer FR-4) 4-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6 mm: based on EIA/JDEC standard, 4-layer FR-4), internal Cu area: 74.2 x 74.2 mm ■ POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 4-Layer 800 800 700 700 Power Dissipation PD [mW] Power Dissipation PD [mW] 2-Layer SSOP14 600 500 400 MSOP8 (VSP8) 300 200 SOT-23-5 100 0 SSOP14 600 MSOP8 (VSP8) 500 400 300 SOT-23-5 200 100 0 0 25 50 75 100 125 Ambient Temperature [°C] 150 0 25 50 75 100 125 Ambient Temperature [°C] 150 ■ RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Operating Temperature Range Ver.6.2 SYMBOL + V -V - CONDITIONS Ta=25˚C Topr www.njr.com VALUE UNIT 2.2 to 5.5 V -40 to 125 °C -3- NJU7076/NJU7077/NJU7078 ■ ELECTRICAL CHARACTERISTICS (V+=5V, V-=0V, VCOM=V+/2, Ta=25˚C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT 100 20 20 0.5 1 1 130 150 400 200 400 5 - 100 - - 70 70 70 70 4.95 4.95 4.85 4.85 4.9 4.85 0 0 90 90 4.98 4.92 4.96 0.02 0.08 0.04 - 0.05 0.05 0.15 0.2 0.1 0.15 4 4 - 0.6 1.2 2.3 - 0.9 0.9 1.8 1.8 3.5 3.5 - 1.3 - MHz - 60 - deg - 12 - dB - 10 - nV/√Hz - 0.5 - V/µs - 0.01 - % - 140 - dB DC CHARACTERISTICS Input Offset Voltage NJU7076 / NJU7077 VIO Ta=-40°C to 125°C NJU7078 Input Offset Voltage Drift Input Bias Current Input Offset Current ΔVIO/ΔT IB IIO Open-Loop Voltage Gain AV Common-Mode Rejection Ratio CMR Supply Voltage Rejection Ratio SVR High-level Output Voltage VOH Low-level Output Voltage VOL Common-Mode Input Voltage Range VICM Supply Current (All Amplifiers) NJU7076 NJU7077 ISUPPLY NJU7078 Ta=-40°C to 125°C Ta=-40°C to 125°C (5) Vo=0.5V to 4.5V, RL=10kΩ to 2.5V Vo=0.5V to 4.5V, RL=10kΩ to 2.5V, Ta= -40°C to 125°C VICM=0V to 4V VICM=0V to 4V, Ta= -40°C to 125°C V+=2.2V to 5.5V V+=2.2V to 5.5V, Ta= -40°C to 125°C RL=10kΩ to 2.5V RL=10kΩ to 2.5V, Ta= -40°C to 125°C RL=600Ω to 2.5V RL=600Ω to 2.5V, Ta= -40°C to 125°C ISOURCE=2mA ISOURCE =2mA, Ta= -40°C to 125°C RL=10kΩ to 2.5V RL=10kΩ to 2.5V, Ta= -40°C to 125°C RL=600Ω to 2.5V RL=600Ω to 2.5V, Ta= -40°C to 125°C ISINK=2mA ISINK=2mA, Ta= -40°C to 125°C CMR≥70dB CMR≥70dB, Ta= -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C µV µV/°C pA pA dB dB dB V V V mA AC CHARACTERISTICS GV=40dB, RF=100kΩ, RL=10kΩ to 2.5V, CL=20pF, f=100kHz GV=40dB, RF=100kΩ, RL=10kΩ to 2.5V, Phase Margin Φm CL=20pF GV=40dB, RF=100kΩ, RL=10kΩ to 2.5V, Gain Margin Gm CL=20pF Equivalent Input Noise Voltage en f=1kHz GV=0dB, RL=10kΩ to 2.5V, CL=20pF, Slew Rate SR VIN=3VPP GV=20dB, RL=10kΩ to 2.5V, f=1kHz, Total Harmonic Distortion + Noise THD+N VO=3VPP Channel Separation CS f=1kHz, NJU7077 / NJU7078 (5) Guaranteed by two points of Temperature -40˚C and 125˚C Gain Bandwidth Product Ver.6.2 GBW www.njr.com -4- NJU7076/NJU7077/NJU7078 ■ ELECTRICAL CHARACTERISTICS (V+=2.2V, V-=0V, VCOM=V+/2, Ta=25˚C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT 100 60 60 0.6 1 1 130 250 400 300 400 5 - 100 - - 70 70 2.15 2.15 2.1 2.05 2.05 2 0 0 90 2.18 2.14 2.13 0.02 0.06 0.07 - 0.05 0.05 0.1 0.15 0.15 0.2 1.2 1.2 - 0.55 1.0 2.0 - 0.82 0.82 1.5 1.5 3.0 3.0 - 1.2 - MHz - 60 - deg - 12 - dB - 10 - nV/√Hz - 0.5 - V/µs - 0.01 - % - 140 - dB DC CHARACTERISTICS Input Offset Voltage NJU7076 / NJU7077 VIO Ta= -40°C to 125°C NJU7078 Input Offset Voltage Drift Input Bias Current Input Offset Current ΔVIO/ΔT IB IIO Open-Loop Voltage Gain AV Common-Mode Rejection Ratio CMR High-level Output Voltage VOH Low-level Output Voltage VOL Common-Mode Input Voltage Range VICM Supply Current (All Amplifiers) NJU7076 NJU7077 ISUPPLY NJU7078 Ta= -40°C to 125°C Ta= -40°C to 125°C (5) Vo=0.6V to 1.6V, RL=10kΩ to 1.1V Vo=0.6V to 1.6V, RL=10kΩ to 1.1V, Ta= -40°C to 125°C VICM=0V to 1.2V VICM=0V to 1.2V, Ta= -40°C to 125°C RL=10kΩ to 1.1V RL=10kΩ to 1.1V, Ta= -40°C to 125°C RL=600Ω to 1.1V RL=600Ω to 1.1V, Ta= -40°C to 125°C ISOURCE=2mA ISOURCE=2mA, Ta= -40°C to 125°C RL=10kΩ to 1.1V RL=10kΩ to 1.1V, Ta= -40°C to 125°C RL=600Ω to 1.1V RL=600Ω to 1.1V, Ta= -40°C to 125°C ISINK=2mA ISINK=2mA, Ta= -40°C to 125°C CMR≥70dB CMR≥70dB, Ta= -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C No Signal No Signal, Ta = -40°C to 125°C µV µV/°C pA pA dB dB V V V mA AC CHARACTERISTICS GV=40dB, RF=100kΩ, RL=10kΩ to 1.1V, CL=20pF, f=100kHz GV=40dB, RF=100kΩ, RL=10kΩ to 1.1V, Phase Margin Φm CL=20pF GV=40dB, RF=100kΩ, RL=10kΩ to 1.1V, Gain Margin Gm CL=20pF Equivalent Input Noise Voltage en f=1kHz GV=0dB, RL=10kΩ to 1.1V, CL=20pF, Slew Rate SR VIN=1VPP GV=20dB, RL=10kΩ to 1.1V, f=1kHz, Total Harmonic Distortion + Noise THD+N VO=1VPP Channel Separation CS f=1kHz, NJU7077 / NJU7078 (5) Guaranteed by two points of Temperature -40˚C and 125˚C Gain Bandwidth Product Ver.6.2 GBW www.njr.com -5- NJU7076/NJU7077/NJU7078 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Temperature V+=2.2V, V-=0V, VCOM =V+/2 500 400 400 300 300 Input Offset Voltage [μV] Input Offset Voltage [μV] Input Offset Voltage vs. Temperature V+=5V, V-=0V, VCOM =V+/2 500 200 100 0 -100 -200 -300 -400 200 100 0 -100 -200 -300 -400 -500 -500 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 Input Offset Voltage Distribution Input Offset Voltage Distribution V+=5V, V-=0V, VCOM=V+/2, Ta=25ºC 40% Number of Amplifiers [%] Number of Amplifiers [%] 35% 30% 25% 20% 15% 10% 5% 30% 25% 20% 15% 10% 5% 0% 0% -200 -100 0 100 Input Offset Voltage [μV] 200 -200 Input Offset Voltage Drift Distribution -100 0 100 Input Offset Voltage [μV] 200 Input Offset Voltage Drift Distribution V+=5V, V-=0V, VCOM=V+/2 40% V+=2.2V, V-=0V, VCOM=V+/2 40% 35% Number of Amplifiers [%] 35% Number of Amplifiers [%] V+=2.2V, V-=0V, VCOM=V+/2, Ta=25ºC 40% 35% 30% 25% 20% 15% 10% 5% 30% 25% 20% 15% 10% 5% 0% 0% -2.5 Ver.6.2 0 25 50 75 100 125 150 Ambient Temperature [ºC] -1.5 -0.5 0.5 1.5 2.5 Input Offset Voltage Drift [μV/ºC] 3.5 -2.5 www.njr.com -1.5 -0.5 0.5 1.5 2.5 Input Offset Voltage Drift [μV/ºC] 3.5 -6- NJU7076/NJU7077/NJU7078 ■ TYPIC AL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage Input Offset Voltage vs. Supply Voltage V+=5V, V-=0V V-=0V, VCOM=V+/2 0.5 0.5 0.4 Input Offset Voltage [mV] Input Offset Voltage [mV] 0.4 0.3 0.2 Ta=125ºC Ta=25ºC 0.1 0 -0.1 -0.2 Ta=-40ºC -0.3 -0.4 0.2 Ta=25ºC 0 -0.1 -0.2 Ta=-40ºC -0.3 -0.5 0 1 2 3 4 5 Supply Voltage V+ [V] 6 7 -1 Warm-Up Vio Drift V+=2.2V, V-=0V V+=3.3V, V-=0V, VCOM=V+/2, Ta=25ºC 20 Input Offset Voltage Change [μV」 0.4 0.3 0.2 Ta=125ºC 0.1 Ta=25ºC 0 -0.1 -0.2 Ta=-40ºC -0.3 -0.4 5 15 10 5 0 -5 -10 -15 -20 -0.5 -1 -0.5 0 0.5 1 1.5 Common-Mode Input Voltage [V] 0 2 Input Bias Current vs. Temperature Open-Loop Voltage Gain [dB] 1500 1250 1000 V+=5V 500 20 30 40 Time [sec] 50 60 V-=0V, RL=10kΩ 160 1750 750 10 Open-Loop Voltage Gain vs. Temperature V-=0V, VCOM=V+/2 2000 Input Bias Current [pA] 0 1 2 3 4 Common-Mode Input Voltage [V] Input Offset Voltage vs. Common-Mode Input Voltage 0.5 V+=2.2V 250 0 150 V+=5.0V 140 130 120 V+=2.2V 110 100 90 80 25 Ver.6.2 Ta=125ºC 0.1 -0.4 -0.5 Input Offset Voltage [mV] 0.3 50 75 100 125 Ambient Temperature [ºC] 150 -50 www.njr.com -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -7- NJU7076/NJU7077/NJU7078 ■ TYPICAL CHARACTERISTICS CMR vs. Frequency V+=5V, V-=0V, VIN=1Vpp, RS=100Ω, RF=10kΩ, Ta=25ºC 120 Supply Voltage Rejection Ratio [dB] Common-Mode Rejection Ratio [dB] SVR vs. Frequency V+=5V, V-=0V, VIN=1Vpp, RS=100Ω, RF=10kΩ, Ta=25ºC 120 110 100 90 80 70 60 100 +SVR 80 60 -SVR 40 20 10 100 1k 10k Frequency [Hz] 100k 10 100 1k 10k Frequency [Hz] 100k Supply Current per Amplifier vs. Supply Voltage GV=0dB Supply Current per Amplifier [mA] 0.9 0.8 0.7 Ta=25°C 0.6 0.5 Ta=125°C 0.4 Ta=-40°C 0.3 0.2 0.1 0 0 1 2 3 4 5 Supply Voltage V+ [V] 6 7 Maximum Output Voltage vs. Output Current Maximum Output Voltage vs. Output Current V+=2.2V, V-=0V V+=5V, V-=0V 2.2 5.0 4.5 Output Voltage [V] Ta=25ºC 3.5 Ta=-40ºC 3.0 2.5 2.0 Ta=-40ºC 1.5 Ta=25ºC 1.0 Ta=25ºC 1.4 1.2 Ta=-40ºC 1.0 0.8 Ta=25ºC 0.6 Ta=125ºC 0.2 ISINK ISINK 0.0 0.0 0.1 Ver.6.2 Ta=125ºC 1.6 0.4 Ta=125ºC 0.5 ISOURCE 1.8 Ta=125ºC 4.0 Output Voltage [V] 2.0 ISOURCE 1 10 Output Current [mA] 100 0.1 www.njr.com 1 10 Output Current [mA] 100 -8- NJU7076/NJU7077/NJU7078 ■ TYPICAL CHARACTERISTICS 40dB Voltage Gain / Phase vs. Frequency 40dB Voltage Gain / Phase vs. Frequency V+=5V, V-=0V, Gv=40dB, RL=10kΩ, Ta=25ºC 60 V+=2.2V, V-=0V, Gv=40dB, RL=10kΩ, Ta=25ºC 60 40 40 0 Phase -60 -20 CL=680pF -40 Voltage Gain [dB] 0 Phase [deg] -120 20 0 0 Phase -60 -20 -40 CL=20pF -60 100 1k 10k 100k Frequency [Hz] 1M -180 10M CL=100pF CL=20pF -60 100 40dB Voltage Gain/Phase vs. Frequency 0 Phase -60 -20 Voltage Gain [dB] 0 Phase [deg] 20 -180 10M Gain 20 0 0 Phase -60 -20 Ta=+125ºC Ta=+125ºC -40 -120 Ta=+25ºC -120 -40 Ta=+25ºC Ta=-40ºC Ta=-40ºC -60 100 12 1k 10k 100k Frequency [Hz] 1M -180 10M -60 100 1k 10k 100k Frequency [Hz] 1M Voltage Gain vs. Frequency Voltage Gain vs. Frequency V+=5V, V-=0V, Gv=0dB, RL=10kΩ, Ta=25ºC V+=2.2V, V-=0V, Gv=0dB, RL=10kΩ, Ta=25ºC 12 10 -180 10M 10 8 6 Voltage Gain [dB] 8 Voltage Gain [dB] 1M 40 Gain CL=680pF 4 2 CL=100pF 0 -2 CL=20pF -4 CL=680pF 6 4 2 CL=100pF 0 -2 CL=20pF -4 -6 -6 -8 -8 10k Ver.6.2 10k 100k Frequency [Hz] V+=2.2V, V-=0V, Gv=40dB, RL=10kΩ, CL=20pF 60 40 Voltage Gain [dB] 1k 40dB Voltage Gain/Phase vs. Frequency V+=5V, V-=0V, Gv=40dB, RL=10kΩ, CL=20pF 60 -120 CL=680pF CL=100pF Phase [deg] Voltage Gain [dB] 20 Phase [deg] Gain Gain 100k 1M Frequency [Hz] 10M www.njr.com 10k 100k 1M Frequency [Hz] 10M -9- NJU7076/NJU7077/NJU7078 ■ TYPICAL CHARACTERISTICS 10 THD+N vs. Output Voltage THD+N vs. Output Voltage V+=5V, V-=0V, RG=1kΩ, RF=10kΩ, RL=Ω V+=2.2V, V-=0V, RG=1kΩ, RF=10kΩ, RL=Ω 10 1 1 f=20kHz THD+N [%] THD+N [%] f=20kHz 0.1 0.1 f=1kHz f=1kHz 0.01 0.01 f=20Hz f=20Hz 0.1 1 Output Voltage [Vrms] 10 0.001 0.01 Pulse Response V+=2.2V, V-=0V, RL=10kΩ, Gv=0dB, Ta=25ºC INPUT CL=20pF CL=100pF CL=680pF INPUT CL=20pF CL=100pF CL=680pF OUTPUT Time [2μs/div] Time [2μs/div] Voltage Noise Density vs. Frequency Equivalent Input Voltage Noise V+=5V, V-=0V, Ta=25ºC 100 VDD=5V, BP=1~100Hz,Ta=25ºC 2 Equivalent Input Noise Voltage[μV] Equivalent Input Noise Voltage [nV/√Hz] 10 Pulse Response OUTPUT 90 80 70 60 50 40 30 20 10 0 1 Ver.6.2 0.1 1 Output Voltage [Vrms] V+=5V, V-=0V, RL=10kΩ, Gv=0dB, Ta=25ºC Voltage [0.5V/div] Voltage [1.5V/div] 0.001 0.01 10 100 Frequency [Hz] 1k 10k 1.5 1 0.5 0 -0.5 -1 -1.5 -2 0 www.njr.com 2 4 Time[sec] 6 8 - 10 - NJU7076/NJU7077/NJU7078 ■ TYPICAL CHARACTERISTICS Channel Separation vs. Frequency VO=1Vpp, RS=100Ω, RF=10kΩ, Ta=25ºC 160 Channel Separation [dB] 150 V+=5V 140 130 V+=2.2V 120 110 100 90 80 10 Ver.6.2 100 1k 10k Frequency [Hz] 100k www.njr.com - 11 - NJU7076/NJU7077/NJU7078 ■ TEST CIRCUITS ● ISUPPLY ● VIO, CMR, SVR RG=50Ω, RF=50kΩ V+ RF A V+ RG VO RG VCOM VCOM V- RF VVS=V+-V- ● VOH, VOL ● GBW VOH; Vin+ = V+/2 + 1V, Vin- = V+/2, VCOM=V+/2 + + RG=1kΩ, RF=100kΩ + VOL; Vin+ = V /2, Vin- = V /2 + 1V, VCOM=V /2 RF V+ V+ VO RG RL Vin+ Vin- VO V- VCOM 50Ω V- CL V+ VO V/I Source Vin+ Vin- V- ● SR RL=100kΩ 90% V+ Vo VO 50Ω Ver.6.2 V- RL 90% ΔV ΔV 10% Δt Δt 10% CL www.njr.com - 12 - NJU7076/NJU7077/NJU7078 Common-Mode Input Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of common-mode input voltage is as follows: VICM (typ.) = V− to V+-1 (Ta = 25°C) Difference of VICM when Temperature change, refer to typical characteristic graph. During designing, consider variations in characteristics for use with allowance. Maximum Output Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of the typ. value of the maximum output voltage is as follows: VOM (typ.) = V-+20mV to V+-20mV (RL=10kΩ to V+/2, Ta=25°C) During designing, consider variations in characteristics and temperature characteristics for use with allowance. In addition, also note that the output voltage range becomes narrow as shown in typical characteristics graph when an output current increases. Capacitive Load The NJU7076/NJU7077/NJU7078 can use at unity gain follower, but the unity gain follower is the most sensitive configuration to capacitive loading. The combination of capacitive load placed directly on the output of an amplifier along with the output impedance of the amplifier creates a phase lag which in turn reduces the phase margin of the amplifier. If phase margin is significantly reduced, the response will cause overshoot and ringing in the step response. The NJU7076/NJU7077/NJU7078 are unity gain stable for capacitive loads of 470pF. To drive heavier capacitive loads, an isolation resistor, RISO as shown Figure1, should be used. RISO improves the feedback loop’s phase margin by making the output load resistive at higher frequencies. The larger the value of RISO, the more stable the output voltage will be. However, larger values of RISO result in reduced output swing, reduced output current drive and reduced frequency bandwidth. EMIRR (EMI Rejection Ratio) Definition EMIRR is a parameter indicating the EMI robustness of an Op-Amp. The definition of EMIRR is given by the following equation1. EMIRR = 20 ∙ log ൬ Vୖ୊_୔୉୅୏ ൰ |∆V୍୓ | − eq. 1 −− Vୖ୊_୔୉୅୏ : RF Signal Amplitude [VP] ∆V୍୓ : Input offset voltage shift quantity [V] The tolerance of the RF signal can be grasped by measuring an RF signal and offset voltage shift quantity. Offset voltage shift is small so that a value of EMIRR is big. And it understands that the tolerance for the RF signal is high. In addition, about the input offset voltage shift with the RF signal, there is the thinking that influence applied to the input terminal is dominant. Therefore, generally the EMIRR becomes value that applied an RF signal to +INPUT terminal. EMIRR vs. Frequency 100 V+/V-=±2.5V, Ta=25°C 90 80 70 EMIRR [dB] ■ APPLICATION NOTE Single and Dual Supply Voltage Operation The NJU7076/NJU7077/NJU7078 work with both single supply and dual supply when the voltage supplied is between V+ and V−. These amplifiers operate from single 2.2 to 5.5V supply and dual ±1.1V to ±2.75V supply. 60 50 40 30 20 10 0 10M 10 100M 1G 100 1k Frequency [Hz] 10G 10k *For details, refer to “Application Note for EMI Immunity" in our HP: http://www.njr.com/ V+ R Vin ISO Vout C L VFigure1. Isolating capacitive load Ver.6.2 www.njr.com - 13 - NJU7076/NJU7077/NJU7078 SOT-23-5 Unit: mm ■ PACKAGE DIMENSIONS 2.9 ±0.2 0 ∼15 ° 1.9 ±0.2 4 0.6 2.8 ±0.2 1.6 +0.2 -0.1 0.2 5 2 1 3 0.1 0.95 ±0.1 +0.1 -0.03 0.4 ±0.1 0.1 0.1max 1.1 ±0.1 0.6max ■ EXAMPLE OF SOLDER PADS DIMENSIONS 2. 4 1 .0 0.7 0. 9 5 Ver.6.2 0.95 www.njr.com - 14 - NJU7076/NJU7077/NJU7078 MSOP8 (VSP8) MEET JEDEC MO-187-DA Unit: mm ■ PACKAGE DIMENSIONS +0.3 -0.1 0 ∼10゚ 1 4 +0.1 0.127 -0.05 0.65 +0.1 0.1 -0.05 1.1 ± 0.1 0.6max 0.55 ± 0.2 5 2.8 ± 0.2 8 4.0 ±0.3 2.9 0.1 0.2 ±0.1 0.1 M ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3. 5 1 .0 0.23 1.95 Ver.6.2 www.njr.com - 15 - NJU7076/NJU7077/NJU7078 SSOP14 Unit: mm ■ PACKAGE DIMENSIONS 5.0 0 ∼10゚ +0.3 -0.1 7 +0.1 1.15 ±0.1 0.65 0.15 -0.05 0.1 ±0.1 0.67max 0.10 0.22 ± 0.1 0.5 ± 0.2 4.4 ±0.2 1 6.4 ±0.3 8 14 0.10 M ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.35 5.90 1.00 0.65 3.90 Ver.6.2 www.njr.com - 16 - NJU7076/NJU7077/NJU7078 SOT-23-5 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 Feed direction P0 φD0 T B W1 W F E P2 A K0 φ D1 P1 T2 DIMENSION 3.3±0.1 3.2±0.1 1.55 1.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.82 1.5±0.1 8.0±0.3 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1MAX REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.6.2 www.njr.com - 17 - NJU7076/NJU7077/NJU7078 MSOP8 (VSP8) MEET JEDEC MO-187-DA Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ire c tio n P2 P0 φ D0 B W1 W F E T A P1 T2 φ D1 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 2.0 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 C SYMBOL A B C D E W W1 B A D E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.6.2 www.njr.com - 18 - NJU7076/NJU7077/NJU7078 SSOP14 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction φD0 P0 T B W1 W F E P2 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 A φD1 P1 T2 DIMENSION 6.95 5.4 1.55±0.05 1.55±0.1 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.3±0.05 2.2 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction PACKING STATE more than 20pitch Devices 2000pcs/reel Label Empty tape Covering tape more than 20pitch reel more than 1round Label Put a reel into a box Ver.6.2 www.njr.com - 19 - NJU7076/NJU7077/NJU7078 ■ RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING PROFILE f 260°C e 230°C 220°C a d b 180°C c d e f g 150°C Temperature ramping rate Pre-heating temperature Pre-heating time Temperature ramp rate 220°C or higher time 230°C or higher time Peak temperature Temperature ramping rate 1 to 4°C/s 150 to 180°C 60 to 120s 1 to 4°C/s shorter than 60s shorter than 40s lower than 260°C 1 to 6°C/s The temperature indicates at the surface of mold package. Room Temp. a b c g ■ REVISION HISTORY DATA REVISION CHANGES May 23, 2019 Ver.6.0 Changed datasheet format. July 11, 2019 Ver.6.1 Err note correction. Dec 14, 2020 Ver.6.2 Supply Current per Amplifier vs. Supply Voltage condition correction. Ver.6.2 www.njr.com - 20 - NJU7076/NJU7077/NJU7078 [ CAUTION ] 1. NJR strives to produce reliable and high quality semiconductors. NJR’s semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of NJR's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial property rights. All other trademarks mentioned herein are the property of their respective companies. 3. To ensure the highest levels of reliability, NJR products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. NJR offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact NJR's Sale's Office if you are uncertain about the products listed in this datasheet. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in this datasheet may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment.        7. 8. 9. Ver.6.2 Aerospace Equipment Equipment Used in the Deep Sea Power Generator Control Equipment (Nuclear, steam, hydraulic, etc.) Life Maintenance Medical Equipment Fire Alarms / Intruder Detectors Vehicle Control Equipment (Airplane, railroad, ship, etc.) Various Safety Devices NJR's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. NJR shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. The products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. Warning for handling Gallium and Arsenic (GaAs) Products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. The product specifications and descriptions listed in this datasheet are subject to change at any time, without notice. www.njr.com - 21 -
NJU7077R-TE2 价格&库存
很抱歉,暂时无法提供与“NJU7077R-TE2”相匹配的价格&库存,您可以联系我们找货
