HER108-T/B
HER108-T/B
    MDD(辰达半导体)
    DO-204AL
    High Efficiency DO-41 1KV 1A
HER108-T/B 数据手册
PART CODE: DO41HER108A10A SPECIFICATION SHEET SPECIFICATION SHEET NO. N0310-DO41HER108A10A DATE Mar. 10, 2021 REVISION A0 DESCRIPITION Axial Lead High Efficiency Rectifier, DO-41 series, HER108-T/B Type 2 Pins Reverse Voltage 1000V Max. Forward Current 1.0A Max. Operating Temp. Range -55°C ~+150°C Package in AMMO Pack, 5000pcs/Tape, Tape/Box RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD HER108 –T/B PART CODE DO41HER108A10A VENDOR APPROVE Issued/Checked/Approved DATE: March 10, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Fast switching for high efficiency • High forward surge current capability • High temperature soldering guaranteed, 250 °C/10 seconds 0.375”(9.5mm) lead length, 5 lbs. • Low reverse leakage APPLICATION • For printed circuit board RFQ PART CODE GUIDE Request For Quotation DO41 HER108 A 10A 1 2 3 4 1) ) DO41: Axial Lead High Efficiency Rectifier, 2 Pins, DO-41 series 2) HER108: Type code for original part number HER108-T/B 3) A: Package code, Package in AMMO Pack, 5000pcs/Tape, Tape/Box 4) 10A: Specification code for Reverse Voltage 1000V Max. Forward Current 1.0A Max. MORE ITEMS AVAILABLE DO41HER101A105 DO41HER102A110 DO41HER103A120 DO41HER106A160 DO41HER107A170 DO41HER108A10A DO41UF4001A105 DO41UF4002A110 DO41UF4003A120 DO41UF4006A180 DO41UF4007A10A NextGen Components, Inc. DO41HER104A130 DO41HER105A140 DO41UF4004A140 DO41UF4005A160 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: HER108 DO-41 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC DO-41 molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.012 Ounce, 0.373 grams MAX. RATING & CHARACTERISTICS Parameter SYMBOLS VALUE Min. Typical UNITS Max. Repetitive peak reverse voltage V RRM 1000 Volts RMS voltage V RMS 700 Volts DC blocking voltage V DC 1000 Volts Average forward output rectified current I AV 1.0 A at TL= 50°C I FSM Peak forward surge current 8.3ms single half 30 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 1.0A DC reverse current at rated DC blocking voltage TA=25℃ VF 1.70 Volts IR 5 µA 100 µA 70 ns TA=100℃ Reverse recovery time (NOTE 2) T rr Junction capacitance (Note 3) CJ 12 pF Thermal resistance (Note 4 ) R QJA 50 °C/W Operating junction temperature range Storage temperature range TJ -65 +150 °C T STG -65 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 3. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage 4. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, PCB. Mounted. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES AMMO BOX (Unit: mm) • All Devices are packed in accordance with EIA standard RS-296-D and specifications. • Each component lead shall be sandwiched between taps for A minimum of 3.2 mm (-.126”) Item Symbol DO-41 Uni(mm) DO-41 Unit (Inch) Component Alignment Z 1.2 Max. 0.048 Max. Tape Width T 6.0 +/- 0.4 0.236 +/- 0.016 Exposed Adhesive E 0.8 Max. 0.032 Max. Body Eccentricity L1 – L2 1.0 Max. 0.040 Max. Component Pitch A (2.0mm/20 pitch) A 5.0 0.197 Component Pitch B (2.0mm/20 pitch) B 26.0 1.023 Component Pitch A (2.0mm/10 pitch) A 5.0 0.197 Component Pitch B (2.0mm/10 pitch) B 52.4 2.063 Box Length L 255.0 +/- 5.0 10.04 +/- 0.197 Box Width W 78.0 +/- 5.0 3.07 +/- 0.197 Box Height H 150.0 +/- 5.0 5.91 +/- 0.197 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41HER108A10A HIGH EFFICIENCY RECTIFIER DO-41 SERIES AMMO PACK IN TAPE/BOX (Unit: mm) Case Code DO-41 Qty. Per Reel (pcs) Component Space (mm) Tape Space (mm) Inner Box L*W*H (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W 5000 5.0 52.4 198*86*21 450*215*250 50,000 12.45 (kg) DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
HER108-T/B 价格&库存
很抱歉,暂时无法提供与“HER108-T/B”相匹配的价格&库存,您可以联系我们找货
