CD74FCT623M
CD74FCT623M
    L3HARRIS
    SOIC20
    IC TXRX NON-INVERT 5.25V 20SOIC
CD74FCT623M 数据手册
CD74FCT623 BiCMOS OCTAL BUS TRANSCEIVER WITH 3-STATE OUTPUTS SCBS736 – JULY 2000 D D D D D D D D D E, M, OR SM PACKAGE (TOP VIEW) BiCMOS Technology With Low Quiescent Power Buffered Inputs Noninverted Outputs Input/Output Isolation From VCC Controlled Output Edge Rates 64-mA Output Sink Current Output Voltage Swing Limited to 3.7 V SCR Latch-Up-Resistant BiCMOS Process and Circuit Design Package Options Include Plastic Small-Outline (M) and Shrink Small-Outline (SM) Packages and Standard Plastic (E) DIP OEAB A1 A2 A3 A4 A5 A6 A7 A8 GND 1 20 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 VCC OEBA B1 B2 B3 B4 B5 B6 B7 B8 description The CD74FCT623 is an octal bus transceiver that uses a small-geometry BiCMOS technology. The output stage is a combination of bipolar and CMOS transistors that limits the output high level to two diode drops below VCC. This resultant lowering of output swing (0 V to 3.7 V) reduces power-bus ringing [a source of electromagnetic interference (EMI)] and minimizes VCC bounce and ground bounce and their effects during simultaneous output switching. The output configuration also enhances switching speed and is capable of sinking 64 mA. This device is a noninverting, 3-state, bidirectional transceiver-buffer intended for two-way transmission from A bus to B bus or B bus to A bus, depending on the logic levels of the output-enable (OEAB, OEBA) inputs. The dual output-enable provision gives these devices the capability to store data by simultaneously enabling OEAB and OEBA. Each output reinforces its input under these conditions, and when all other data sources to the bus lines are at high impedance, both sets of bus lines remain in their last states. The CD74FCT623 is characterized for operation from 0°C to 70°C. FUNCTION TABLE INPUTS OEBA OEAB OPERATION L L B data to A bus H H H L A data to B bus Isolation† L H B data to A bus, A data to B bus † To prevent excess current in the high-impedance (isolation) state, all I/O terminals should be terminated with 10-kΩ to 1-MΩ resistors. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2000, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 CD74FCT623 BiCMOS OCTAL BUS TRANSCEIVER WITH 3-STATE OUTPUTS SCBS736 – JULY 2000 logic symbol† 19 OEBA 1 OEAB 2 A1 EN1 EN2 2 3 A2 A3 A4 A5 A6 A7 A8 18 1 17 4 16 5 15 6 14 7 13 8 12 9 11 B1 B2 B3 B4 B5 B6 B7 B8 † This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. logic diagram (positive logic) OEBA OEAB A1 19 1 2 18 To Seven Other Transceivers 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 B1 CD74FCT623 BiCMOS OCTAL BUS TRANSCEIVER WITH 3-STATE OUTPUTS SCBS736 – JULY 2000 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† DC supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 6 V DC input clamp current, IIK (VI < –0.5 V) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –20 mA DC output clamp current, IOK (VO < –0.5 V) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –50 mA DC output sink current per output pin, IOL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 mA DC output source current per output pin, IOH . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –30 mA Continuous current through VCC, ICC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 mA Continuous current through GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 528 mA Package thermal impedance, θJA (see Note 1): E package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69°C/W M package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58°C/W SM package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: The package thermal impedance is calculated in accordance with JESD 51. recommended operating conditions (see Note 2) MIN MAX UNIT 4.75 5.25 V VCC VIH Supply voltage VIL VI Low-level input voltage Input voltage 0 VO IOH Output voltage 0 IOL ∆t/∆v High-level input voltage 2 V 0.8 V VCC VCC V High-level output current –15 mA Low-level output current 64 mA 10 ns/V Input transition rise or fall rate 0 V TA Operating free-air temperature 0 70 °C NOTE 2: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS VCC TA = 25°C MIN MAX VIK VOH II = –18 mA IOH = –15 mA 4.75 V VOL II IOL = 64 mA VI = VCC or GND 4.75 V 0.55 5.25 V IOZ IOS‡ VO = VCC or GND VI = VCC or GND, 5.25 V ICC VI = VCC or GND, One input at 3.4 V, Other inputs at VCC or GND ∆ICC§ Ci 4.75 V VO = 0 IO = 0 5.25 V MIN –1.2 2.4 UNIT –1.2 V 2.4 V 0.55 V ±0.1 ±1 mA ±0.5 ±10 mA –60 –60 mA 5.25 V 8 80 mA 5.25 V 1.6 1.6 mA 10 10 pF 15 pF VI = VCC or GND VO = VCC or GND Co 15 ‡ Not more than one output should be tested at a time, and the duration of the test should not exceed 100 ms. § This is the increase in supply current for each input at one of the specified TTL voltage levels rather than 0 V or VCC. POST OFFICE BOX 655303 MAX • DALLAS, TEXAS 75265 3 CD74FCT623 BiCMOS OCTAL BUS TRANSCEIVER WITH 3-STATE OUTPUTS SCBS736 – JULY 2000 switching characteristics over recommended operating conditions (unless otherwise noted) (see Figure 1) PARAMETER FROM (INPUT) TO (OUTPUT) TA = 25°C TYP MIN tpd A or B B or A 5.3 1.5 7 OEBA A 7.1 1.5 9.5 OEAB B 7.1 1.5 9.5 OEBA A 5.6 1.5 7.5 OEAB B 5.6 1.5 7.5 TYP MAX ten tdis di MAX UNIT ns ns ns noise characteristics, VCC = 5 V, CL = 50 pF, TA = 25°C PARAMETER MIN UNIT VOL(P) VOH(V) Quiet output, maximum dynamic VOL 1 V Quiet output, minimum dynamic VOH 0.5 V VIH(D) VIL(D) High-level dynamic input voltage 2 Low-level dynamic input voltage V 0.8 V TYP UNIT operating characteristics, TA = 25°C PARAMETER Cpd 4 TEST CONDITIONS Power dissipation capacitance No load, POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 f = 1 MHz 48 pF CD74FCT623 BiCMOS OCTAL BUS TRANSCEIVER WITH 3-STATE OUTPUTS SCBS736 – JULY 2000 PARAMETER MEASUREMENT INFORMATION 7V CL = 50 pF (see Note A) 500 Ω From Output Under Test Test Point From Output Under Test Open TEST GND CL = 50 pF (see Note A) 500 Ω S1 S1 Open 7V Open 7V tPLH/tPHL tPLZ/tPZL tPHZ/tPZH 500 Ω Open Drain LOAD CIRCUIT FOR 3-STATE AND OPEN-DRAIN OUTPUTS LOAD CIRCUIT FOR TOTEM-POLE OUTPUTS 90% 1.5 V 10% 3V 1.5 V 10% 0 V 90% tr tf VOLTAGE WAVEFORM INPUT RISE AND FALL TIMES 3V 1.5 V Timing Input 0V tw tsu 3V 1.5 V 1.5 V Input th 3V 1.5 V 1.5 V Data Input 0V 0V VOLTAGE WAVEFORMS PULSE DURATION VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 3V 1.5 V 1.5 V Input 0V tPLH tPHL 1.5 V 1.5 V VOL tPHL Out-of-Phase Output tPLZ ≈3.5 V 1.5 V tPZH VOH 1.5 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES INVERTING AND NONINVERTING OUTPUTS 1.5 V 0V Output Waveform 1 (see Note B) tPLH 1.5 V 1.5 V tPZL VOH In-Phase Output 3V Output Control Output Waveform 2 (see Note B) VOL + 0.3 V VOL tPHZ 1.5 V V VOH – 0.3 V OH ≈0 V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES LOW- AND HIGH-LEVEL ENABLING NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr and tf = 2.5 ns. D. The outputs are measured one at a time with one input transition per measurement. E. tPLZ and tPHZ are the same as tdis. F. tPZL and tPZH are the same as ten. G. tPHL and tPLH are the same as tpd. Figure 1. Load Circuit and Voltage Waveforms POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) CD74FCT623M ACTIVE Package Type Package Pins Package Drawing Qty SOIC DW 20 25 Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM Op Temp (°C) Device Marking (4/5) 0 to 70 74FCT623M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74FCT623M 价格&库存
很抱歉,暂时无法提供与“CD74FCT623M”相匹配的价格&库存,您可以联系我们找货
