S-89120BPH-H4B-TFU
S-89120BPH-H4B-TFU
    ABLIC(艾普凌科)
    SMD8
    IC CMOS 2 CIRCUIT SNT8A
S-89120BPH-H4B-TFU 数据手册
S-89110/89120 Series www.ablic.com www.ablicinc.com MINI ANALOG SERIES CMOS OPERATIONAL AMPLIFIER © ABLIC Inc., 2009-2018 Rev.3.1_03 The mini-analog series is a group of ICs that incorporate a general purpose analog circuit in a small package. The S-89110/89120 Series is a CMOS type operational amplifier that has a phase compensation circuit, and operates at a low voltage with low current consumption. These features make this product the ideal solution for small battery-powered portable equipment. The S-89110A/89120A Series is a single operational amplifier (one circuit). The S-89110B/89120B Series is a dual operational amplifier (two circuits).  Features • Lower operating voltage than the conventional general-purpose: VDD = 1.8 V to 5.5 V • Low current consumption (per circuit): IDD = 50 μA (S-89110 Series) IDD = 10 μA (S-89120 Series) • Low input offset voltage: 4.0 mV max. • No external capacitors required for internal phase compensation • Output full swing • Lead-free, Sn 100%, halogen-free*1 *1. Refer to " Product Name Structure" for details.  Applications • • • • Mobile phone Notebook PC Digital camera Digital video camera  Packages • • • • SC-88A SOT-23-5 SNT-8A TMSOP-8 1 MINI ANALOG SERIES S-89110/89120 Series CMOS OPERATIONAL AMPLIFIER Rev.3.1_03  Block Diagrams 1. S-89110A/89120A Series single operational amplifier (one circuit) VDD IN(+) + OUT IN(−) − VSS Figure 1 2. S-89110B/89120B Series dual operational amplifier (two circuits) VDD IN1(+) + OUT1 IN1(−) IN2(+) − + OUT2 IN2(−) − VSS Figure 2 2 MINI ANALOG SERIES Rev.3.1_03 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series  Product Name Structure Users can select the product type for the S-89110/89120 Series. Refer to "1. Product name" regarding the contents of product name, "2. Packages" regarding the package drawings and "3. Product name list" regarding the product type. 1. Product name 1. 1 SC-88A S-891 x 0 A NC - xxx - TF x Environmental code S: Lead-free, halogen-free G: Lead-free (for details, please contact our sales office) IC direction in tape specifications*1 Product code (abbreviation)*2 Package name (abbreviation) NC: SC-88A Number of circuits A: 1 Current consumption (per circuit) 1: IDD = 50 μA 2: IDD = 10 μA *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 1. 2 SOT-23-5 S-891 x 0 A MC - xxx - TF U Environmental code U: Lead-free (Sn 100%), halogen-free IC direction in tape specifications*1 Product code (abbreviation)*2 Package name (abbreviation) MC: SOT-23-5 Number of circuits A: 1 Current consumption (per circuit) 1: IDD = 50 μA 2: IDD = 10 μA *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 3 MINI ANALOG SERIES S-89110/89120 Series 1. 3 CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 SNT-8A, TMSOP-8 S-891 x 0 B xx - xxx - TF U Environmental code U: Lead-free (Sn 100%), halogen-free IC direction in tape specifications*1 Product code (abbreviation)*2 Package name (abbreviation) PH: SNT-8A FM: TMSOP-8 Number of circuits B: 2 Current consumption (per circuit) 1: IDD = 50 μA 2: IDD = 10 μA *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 2. Packages Table 1 Dimension Tape Reel Land NP005-B-P-SD MP005-A-P-SD PH008-A-P-SD FM008-A-P-SD NP005-B-C-SD MP005-A-C-SD PH008-A-C-SD FM008-A-C-SD NP005-B-R-SD MP005-A-R-SD PH008-A-R-SD FM008-A-R-SD - - PH008-A-L-SD - Number of Circuit Package Package Name SC-88A SOT-23-5 SNT-8A TMSOP-8 3. Package Drawing Codes Product name list Table 2 Product Name Current Consumption (per circuit) S-89110ANC-1A1-TFz S-89110AMC-1A1-TFU S-89110BPH-H4A-TFU S-89110BFM-H4A-TFU S-89120ANC-1A2-TFz S-89120AMC-1A2-TFU S-89120BPH-H4B-TFU S-89120BFM-H4B-TFU *1. 50 μA 50 μA 50 μA 50 μA 10 μA 10 μA 10 μA 10 μA Gain-bandwidth 175 kHz 175 kHz 175 kHz 175 kHz 35 kHz 35 kHz 35 kHz 35 kHz *1 1 1 2 2 1 1 2 2 SC-88A SOT-23-5 SNT-8A TMSOP-8 SC-88A SOT-23-5 SNT-8A TMSOP-8 The value when VDD = 3.0 V Remark 1. z: G or S 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 MINI ANALOG SERIES Rev.3.1_03 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series  Pin Configurations 1. SC-88A Top view 5 Table 3 4 1 2 3 Figure 3 2. Pin No. Symbol 1 2 3 4 5 IN(+) VSS IN(−) OUT VDD (Product with 1 circuit) Description Non-inverted input pin GND pin Inverted input pin Output pin Positive power supply pin SOT-23-5 Top view 5 Table 4 4 1 2 3 Pin No. Symbol 1 2 3 4 5 IN(+) VSS IN(−) OUT VDD (Product with 1 circuit) Description Non-inverted input pin GND pin Inverted input pin Output pin Positive power supply pin Figure 4 3. SNT-8A Top view 1 2 3 4 Table 5 8 7 6 5 Figure 5 Pin No. Symbol 1 2 3 4 5 6 7 8 OUT1 IN1(−) IN1(+) VSS IN2(+) IN2(−) OUT2 VDD (Product with 2 circuits) Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin 4. TMSOP-8 Top view 1 2 3 4 Table 6 8 7 6 5 Figure 6 Pin No. 1 2 3 4 5 6 7 8 Symbol OUT1 IN1(−) IN1(+) VSS IN2(+) IN2(−) OUT2 VDD (Product with 2 circuits) Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin 5 MINI ANALOG SERIES S-89110/89120 Series CMOS OPERATIONAL AMPLIFIER Rev.3.1_03  Absolute Maximum Ratings Table 7 Item Power supply voltage Input voltage Output voltage Differential input voltage Output pin current SC-88A SOT-23-5 Power dissipation SNT-8A TMSOP-8 Operating ambient temperature Storage temperature *1. (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit VSS − 0.3 to VSS + 10.0 V VSS − 0.3 to VSS + 7.0 (7.0 max.) V VSS − 0.3 to VDD + 0.3 (7.0 max.) V ±7.0 V 13 mA 9 mA *1 350 mW 600*1 mW 450*1 mW 650*1 mW −40 to +85 °C −55 to +125 °C Symbol VDD VIN VOUT VIND ISINK ISOURCE PD Topr Tstg When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Board name: JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power Dissipation (PD) [mW] 700 600 TMSOP-8 500 SOT-23-5 400 SNT-8A 300 200 SC-88A 100 0 0 50 100 150 Ambient Temperature (Ta) [°C] Figure 7 6 Power Dissipation of Package (When Mounted on Board) MINI ANALOG SERIES Rev.3.1_03 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series  Electrical Characteristics Table 8 Item Range of operating power supply voltage 1. Symbol Condition − VDD (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 1.8 − 5.5 V − VDD = 5.0 V Table 9 (Ta = +25°C unless otherwise specified) DC Electrical Characteristics (VDD = 5.0 V) Item Symbol Current consumption (per circuit) IDD Input offset voltage VIO ΔVIO ΔTa Input offset voltage drift Input offset current Input bias current Common-mode input voltage range IIO IBIAS VCMR Voltage gain (open loop) AVOL Maximum output swing voltage VOH VOL Condition S-89110 Series S-89120 Series − Ta = −40°C to +85°C − − − VSS + 0.5 V ≤ VOUT ≤ VDD − 0.5 V, VCMR = 2.5 V RL = 1.0 MΩ RL = 1.0 MΩ Min. Typ. Max. Unit Test Circuit − − −4 50 10 ±3 120 30 +4 μA μA mV 5 5 1 − ±10 − μV/°C 1 − − 0 1 1 − − − 4.3 pA pA V − − 2 70 80 − dB 8 4.9 − − − − 0.1 V V 3 4 Common-mode input signal rejection ratio Power supply voltage rejection ratio CMRR − 60 70 − dB 2 PSRR Source current ISOURCE VOUT = 0 V − S-89110 Series S-89120 Series Sink current ISINK 60 120 25 9 70 − − − − − − − dB μA μA mA 1 6 6 7 VOUT = 0.5 V Table 10 (Ta = +25°C unless otherwise specified) AC Electrical Characteristics (VDD = 5.0 V) Item Symbol Slew rate SR Gain-bandwidth product GBP Condition Min. Typ. Max. Unit RL = 1.0 MΩ, CL = 15 pF S-89110 Series (Refer to Figure 16) S-89120 Series S-89110 Series S-89120 Series − − − − 0.07 0.015 180 40 − − − − V/μs V/μs kHz kHz 7 MINI ANALOG SERIES S-89110/89120 Series 2. CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 VDD = 3.0 V Table 11 (Ta = +25°C unless otherwise specified) DC Electrical Characteristics (VDD = 3.0 V) Item Symbol Current consumption (per circuit) IDD Input offset voltage VIO ΔVIO ΔTa Input offset voltage drift Input offset current Input bias current Common-mode input voltage range IIO IBIAS VCMR Voltage gain (open loop) AVOL Maximum output swing voltage VOH VOL Condition S-89110 Series S-89120 Series − Ta = −40°C to +85°C − − − VSS + 0.5 V ≤ VOUT ≤ VDD − 0.5 V, VCMR = 1.5 V RL = 1.0 MΩ RL = 1.0 MΩ Min. Typ. Max. Unit Test Circuit − − −4 50 10 ±3 120 30 +4 μA μA mV 5 5 1 − ±10 − μV/°C 1 − − 0 1 1 − − − 2.3 pA pA V − − 2 70 80 − dB 8 2.9 − − − − 0.1 V V 3 4 Common-mode input signal rejection ratio Power supply voltage rejection ratio CMRR − 60 70 − dB 2 PSRR Source current ISOURCE VOUT = 0 V − S-89110 Series S-89120 Series Sink current ISINK 60 120 25 8 70 − − − − − − − dB μA μA mA 1 6 6 7 VOUT = 0.5 V Table 12 AC Electrical Characteristics (VDD = 3.0 V) Item Symbol Slew rate SR Gain-bandwidth product GBP 8 (Ta = +25°C unless otherwise specified) Condition RL = 1.0 MΩ, CL = 15 pF S-89110 Series (Refer to Figure 16) S-89120 Series S-89110 Series S-89120 Series Min. − − − − Typ. 0.07 0.015 175 35 Max. − − − − Unit V/μs V/μs kHz kHz MINI ANALOG SERIES Rev.3.1_03 3. CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series VDD = 1.8 V Table 13 (Ta = +25°C unless otherwise specified) DC Electrical Characteristics (VDD = 1.8 V) Item Symbol Current consumption (per circuit) IDD Input offset voltage VIO ΔVIO ΔTa Input offset voltage drift Input offset current Input bias current Common-mode input voltage range IIO IBIAS VCMR Voltage gain (open loop) AVOL Maximum output swing voltage VOH VOL Condition S-89110 Series S-89120 Series − Ta = −40°C to +85°C − − − VSS + 0.5 V ≤ VOUT ≤ VDD − 0.5 V, VCMR = 0.9 V RL = 1.0 MΩ RL = 1.0 MΩ Min. Typ. Max. Unit Test Circuit − − −4 50 10 ±3 120 30 +4 μA μA mV 5 5 1 − ±10 − μV/°C 1 − − 0 1 1 − − − 1.1 pA pA V − − 2 70 80 − dB 8 1.7 − − − − 0.1 V V 3 4 Common-mode input signal rejection ratio Power supply voltage rejection ratio CMRR − 60 70 − dB 2 PSRR Source current ISOURCE VOUT = 0 V − S-89110 Series S-89120 Series Sink current ISINK 60 100 20 5 70 − − − − − − − dB μA μA mA 1 6 6 7 VOUT = 0.5 V Table 14 AC Electrical Characteristics (VDD = 1.8 V) Item Symbol Slew rate SR Gain-bandwidth product GBP (Ta = +25°C unless otherwise specified) Condition RL = 1.0 MΩ, CL = 15 pF S-89110 Series (Refer to Figure 16) S-89120 Series S-89110 Series S-89120 Series Min. − − − − Typ. 0.07 0.015 160 30 Max. − − − − Unit V/μs V/μs kHz kHz 9 MINI ANALOG SERIES S-89110/89120 Series CMOS OPERATIONAL AMPLIFIER Rev.3.1_03  Test Circuit (Per Circuit) 1. Power supply voltage rejection ratio, input offset voltage VDD • Power supply voltage rejection ratio (PSRR) The power supply voltage rejection ratio (PSRR) can be calculated by the following expression, with VOUT measured at each VDD. RF RS Test conditions: − VOUT + RS When VDD = 1.8 V: VDD = VDD1, VOUT = VOUT1, When VDD = 5.0 V: VDD = VDD2, VOUT = VOUT2 RF PSRR = 20 log VCMR = VDD / 2 × RF + RS  RS    • Input offset voltage (VIO) VDD  × RS VIO = VOUT − 2  RF + RS  Figure 8 2. VDD1 − VDD2   VDD1 VDD2   VOUT1 − 2  − VOUT2 − 2   Common-mode input signal rejection ratio, common-mode input voltage range VDD • Common-mode input signal rejection ratio (CMRR) The common-mode input signal rejection ratio (CMRR) can be calculated by the following expression, with VOUT measured at each VIN. RF RS − + RS Test conditions: VOUT When VIN = VCMR Max.: VIN = VIN1, VOUT = VOUT1, When VIN = VDD / 2: VIN = VIN2, VOUT = VOUT2 RF CMRR = 20 log VIN    VIN1 − VIN2 RF + RS  × RS  VOUT1 − VOUT2  VDD / 2 • Common-mode input voltage range (VCMR) Figure 9 10 The common-mode input voltage range is the range of VIN in which VOUT satisfies the common-mode input signal rejection ratio specifications. MINI ANALOG SERIES Rev.3.1_03 3. CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series Maximum output swing voltage (VOH) VDD • Maximum output swing voltage (VOH) − VOH + Test conditions: VDD VIN1 = 2 − 0.1 V VDD VIN2 = 2 + 0.1 V RL = 1 MΩ RL VIN1 VIN2 Figure 10 4. Maximum output swing voltage (VOL) VDD • Maximum output swing voltage (VOL) RL − + VIN1 VOL Test conditions: VDD VIN1 = 2 + 0.1 V VDD VIN2 = 2 − 0.1 V RL = 1 MΩ VIN2 Figure 11 5. Current consumption VDD • Current consumption (IDD) A − + VCMR = VDD / 2 Figure 12 11 MINI ANALOG SERIES S-89110/89120 Series 6. CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 Source current VDD • Source current (ISOURCE) Test conditions: VDD VIN1 = 2 − 0.5 V VDD VIN2 = 2 + 0.5 V − + VIN1 A VIN2 Figure 13 7. Sink current VDD VOUT • Sink current (ISINK) Test conditions: A − + VIN1 VIN2 Figure 14 12 VOUT = VSS + 0.5 V VDD VIN1 = 2 + 0.5 V VDD VIN2 = 2 − 0.5 V MINI ANALOG SERIES Rev.3.1_03 8. CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series Voltage gain (open loop) RF VDD VDDN RS − + D.U.T + RS VOUT NULL − RF VCMR = VDD / 2 VM VSSN Figure 15 • Voltage-gain (open loop) (AVOL) The voltage gain (AVOL) can be calculated by the following expression, with VOUT measured at each VM. Test conditions: When VM = VDD − 0.5 V: VM = VM1, VOUT = VOUT1, When VM = VSS + 0.5 V: VM = VM2, VOUT = VOUT2 AVOL = 20 log 9.    RF + RS  VM1 − VM2 × RS  VOUT1 − VOUT2  Slew rate (SR) Measured by the voltage follower circuit. tR = tF = 20 ns (VSS to VCMR Max.) VCMR Max. VIN(+) VSS (= 0 V) tTHL VCMR Max. × 0.9 VOUT (= VIN(−)) tTLH VCMR Max. × 0.1 VCMR Max. × 0.8 tTLH VCMR Max. × 0.8 SR = tTHL SR = Figure 16 13 MINI ANALOG SERIES S-89110/89120 Series CMOS OPERATIONAL AMPLIFIER Rev.3.1_03  Precautions • Generally an operational amplifier may cause oscillation, depending on the selection of external parts. Perform thorough evaluation using the actual application to set the constant. • Do not apply an electrostatic discharge to this IC that exceeds performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 14 MINI ANALOG SERIES Rev.3.1_03 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series  Characteristics (Typical Data) 1. Current consumption (per circuit) vs. Power supply voltage 1. 1 S-89110 Series 1. 2 S-89120 Series IDD − VDD, VSS = 0 V IDD − VDD, VSS = 0 V 100 20 85°C 25°C 15 60 IDD [μA] IDD [μA] 80 40 Ta = −40°C 20 0 0 1 2 3 25°C 10 Ta = −40°C 5 4 5 0 6 0 1 2 VDD [V] 3 VDD [V] 4 5 6 Voltage gain vs. Frequency 2. 1 S-89110 Series 2. 2 S-89120 Series AVOL − f, VDD = 3.0 V, VSS = 0 V 100 AVOL − f, VDD = 3.0 V, VSS = 0 V 100 25°C 60 25°C 80 85°C Ta = −40°C 40 20 0 0.001 0.01 AVOL[dB] 80 AVOL [dB] 2. 85°C 60 85°C Ta = −40°C 40 20 0.1 1 f [kHz] 10 100 1000 0 0.001 0.01 0.1 1 f [kHz] 10 100 1000 15 MINI ANALOG SERIES S-89110/89120 Series 3. CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 Output current 3. 1 ISOURCE vs. Power supply voltage 3. 1. 1 S-89110 Series 3. 1. 2 S-89120 Series ISOURCE − VDD, VOUT = 0 V, VSS = 0 V ISOURCE − VDD, VOUT = 0 V, VSS = 0 V 500 100 85°C 25°C 300 200 Ta = −40°C 100 60 40 Ta = −40°C 20 0 0 0 1 2 3 4 5 6 0 1 2 VDD [V] 3. 2 3 VDD [V] 4 S-89110 Series 3. 2. 2 6 S-89120 Series ISINK − VDD, VOUT = 0.5 V, VSS = 0 V ISINK − VDD, VOUT = 0.5 V, VSS = 0 V 40 30 30 ISINK [mA] 40 Ta = −40°C 20 25°C 10 Ta = −40°C 20 25°C 10 85°C 85°C 0 0 0 1 2 3 VDD [V] 16 5 ISINK vs. Power supply voltage 3. 2. 1 ISINK [mA] 85°C 25°C 80 ISOURCE [μA] ISOURCE [μA] 400 4 5 6 0 1 2 3 VDD [V] 4 5 6 MINI ANALOG SERIES Rev.3.1_03 3. 3 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series Output voltage (VOUT) vs. ISOURCE 3. 3. 1 S-89110 Series VOUT − ISOURCE, VDD = 1.8 V, VSS = 0 V VOUT − ISOURCE, VDD = 3.0 V, VSS = 0 V 2.0 3.0 2.5 25°C 2.0 VOUT [V] 1.5 1.0 VOUT [V] Ta = −40°C 85°C 0.5 25°C 85°C 1.5 1.0 Ta = −40°C 0.5 0.0 0.0 0 50 100 150 200 250 300 350 ISOURCE [μA] 0 50 100 150 200 250 300 350 ISOURCE [μA] VOUT − ISOURCE, VDD = 5.0 V, VSS = 0 V 5.0 25°C VOUT [V] 4.0 85°C 3.0 2.0 Ta = −40°C 1.0 0.0 0 3. 3. 2 50 100 150 200 250 300 350 ISOURCE [μA] S-89120 Series VOUT − ISOURCE, VDD = 1.8 V, VSS = 0 V VOUT − ISOURCE, VDD = 3.0 V, VSS = 0 V 2.0 3.0 85°C VOUT [V] VOUT [V] 1.5 1.0 0.5 25°C 2.5 25°C Ta = −40°C 2.0 85°C 1.5 1.0 Ta = −40°C 0.5 0.0 0.0 0 10 20 30 40 50 ISOURCE [μA] 60 70 0 10 20 30 40 50 ISOURCE [μA] 60 70 VOUT − ISOURCE, VDD = 5.0 V, VSS = 0 V 5.0 VOUT [V] 4.0 85°C 25°C 3.0 2.0 Ta = −40°C 1.0 0.0 0 10 20 30 40 50 ISOURCE [μA] 60 70 17 MINI ANALOG SERIES S-89110/89120 Series 3. 4 CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 Output voltage (VOUT) vs. ISINK 3. 4. 1 S-89110 Series VOUT − ISINK, VDD = 1.8 V, VSS = 0 V VOUT − ISINK, VDD = 3.0 V, VSS = 0 V 2.0 3.0 1.0 VOUT [V] VOUT [V] 2.5 25°C 1.5 85°C 0.5 Ta = −40°C 25°C 2.0 1.5 85°C 1.0 Ta = −40°C 0.5 0.0 0.0 0 5 10 ISINK [mA] 15 20 0 10 20 ISINK [mA] 30 40 VOUT − ISINK, VDD = 5.0 V, VSS = 0 V 5.0 VOUT [V] 4.0 25°C 3.0 2.0 85°C Ta = −40°C 1.0 0.0 0 3. 4. 2 20 40 ISINK [mA] 60 80 S-89120 Series VOUT − ISINK, VDD = 1.8 V, VSS = 0 V VOUT − ISINK, VDD = 3.0 V, VSS = 0 V 2.0 3.0 2.5 25°C 1.0 VOUT [V] VOUT [V] 1.5 85°C 0.5 Ta = −40°C 85°C 1.0 Ta = −40°C 0.0 0 5 10 ISINK [mA] 15 20 VOUT − ISINK, VDD = 5.0 V, VSS = 0 V 5.0 4.0 VOUT [V] 1.5 0.5 0.0 25°C 3.0 85°C 2.0 Ta = −40°C 1.0 0.0 0 18 25°C 2.0 20 40 ISINK [mA] 60 80 0 10 20 ISINK [mA] 30 40 MINI ANALOG SERIES Rev.3.1_03 CMOS OPERATIONAL AMPLIFIER S-89110/89120 Series  Marking Specifications 1. SC-88A Top view 5 (1) to (3): 4 Product Code (refer to Product Name vs. Product Code) (1) (2) (3) 1 2 3 Product Name vs. Product Code Product Code (1) (2) (3) Product Name S-89110ANC-1A1-TFz 1 A 1 S-89120ANC-1A2-TFz 1 A 2 Remark z: G or S 2. SOT-23-5 Top view 5 4 (1) to (3): Product Code (refer to Product Name vs. Product Code) (4): Lot number (1) (2) (3) (4) 1 2 3 Product Name vs. Product Code Product Name Product Code (1) (2) (3) S-89110AMC-1A1-TFU 1 A 1 S-89120AMC-1A2-TFU 1 A 2 19 MINI ANALOG SERIES S-89110/89120 Series 3. CMOS OPERATIONAL AMPLIFIER Rev.3.1_03 SNT-8A 8 Top view 7 6 5 (1): (2) to (4): (5), (6): (7) to (11): (1) (2) (3) (4) Blank Product Code (refer to Product Name vs. Product Code) Blank Lot number (5) (6) (7) (8) (9) (10) (11) 1 2 3 4 Product Name vs. Product Code Product Code (2) (3) (4) Product Name S-89110BPH-H4A-TFU H 4 A S-89120BPH-H4B-TFU H 4 B 4. TMSOP-8 8 Top view 7 6 5 (1): (2) to (4): (5): (6) to (8): (1) (2) (3) (4) (5) (6) (7) (8) 1 2 3 4 Product Name vs. Product Code Product Name Product Code (2) (3) (4) S-89110BFM-H4A-TFU H 4 A S-89120BFM-H4B-TFU H 4 B 20 Blank Product Code (refer to Product Name vs. Product Code) Blank Lot number 2.0±0.2 1.3±0.1 5 1 4 2 0.65 3 +0.1 0.15 -0.05 0.65 0.2 +0.1 -0.05 No. NP005-B-P-SD-1.2 TITLE SC88A-B-PKG Dimensions No. NP005-B-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.1 1.1±0.1 ø1.55±0.05 0.2±0.05 0.3 4.0±0.1 ø1.05±0.1 (2.25) 2.05±0.1 3 2 1 4 5 Feed direction No. NP005-B-C-SD-2.0 TITLE SC88A-B-Carrier Tape No. NP005-B-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. NP005-B-R-SD-2.1 TITLE SC88A-B-Reel No. NP005-B-R-SD-2.1 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-89120BPH-H4B-TFU 价格&库存
很抱歉,暂时无法提供与“S-89120BPH-H4B-TFU”相匹配的价格&库存,您可以联系我们找货
