MC9S12E128CPV
MC9S12E128CPV
    ROCHESTER(罗切斯特)
    LQFP112
    IC MCU 16BIT 128KB FLASH 112LQFP
MC9S12E128CPV 数据手册
DOCUMENT NUMBER 9S12E128DGV1/D MC9S12E-Family Device User Guide V01.04 Original Release Date: 4 APR 2003 Revised: 04 NOV 2003 Motorola, Inc. Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters which may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. Motorola and are registered trademarks of Motorola, Inc. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. ©Motorola, Inc., 2003 1 DOCUMENT NUMBER 9S12E128DGV1/D Revision History Version Revision Number Date Author Description of Changes 01.00 04.APR.03 01.01 24.JUN.03 Minor typo corrections. 01.02 9.OCT.03 MC9S12E32 added. 31.OCT.03 Added Colpitts and Pierce connections to 2.3.8. Updated input capacitance. Updated Table A-8. Changed pin name ROMONE to ROMCTL. Added S12 LRAE to Flash section. Added EXTAL VIH and VIL min/max values and hysteresis value to Oscillator Characteristics. New wording on NVM Reliability. 04.NOV.03 Updated PCB layouts. Changed PP6 to PK7 on Table 4-1. Updated DAC Supply min voltage and Operating frequency. Added Non-multiplexed Address and Chip Select external bus timing. 01.03 01.04 Original Version. Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters which may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. Motorola and are registered trademarks of Motorola, Inc. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. ©Motorola, Inc., 2003 2 Device User Guide — 9S12E128DGV1/D V01.04 Table of Contents Section 1 Introduction 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Overview. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Modes of Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Device Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Detailed Register Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 Part ID Assignments. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74 Section 2 Signal Description 2.1 Device Pinout . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 76 2.2 Signal Properties Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78 2.3 Detailed Signal Descriptions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 2.3.1 EXTAL, XTAL — Oscillator Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 2.3.2 RESET — External Reset Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 2.3.3 TEST — Test Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 2.3.4 XFC — PLL Loop Filter Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 2.3.5 BKGD / TAGHI / MODC — Background Debug, Tag High & Mode Pin . . . . . . . 80 2.3.6 PA[7:0] / ADDR[15:8] / DATA[15:8] — Port A I/O Pins . . . . . . . . . . . . . . . . . . . . 80 2.3.7 PB[7:0] / ADDR[7:0] / DATA[7:0] — Port B I/O Pins . . . . . . . . . . . . . . . . . . . . . . 80 2.3.8 PE7 / NOACC / XCLKS — Port E I/O Pin 7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81 2.3.9 PE6 / MODB / IPIPE1 — Port E I/O Pin 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 2.3.10 PE5 / MODA / IPIPE0 — Port E I/O Pin 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 2.3.11 PE4 / ECLK— Port E I/O Pin 4 / E-Clock Output . . . . . . . . . . . . . . . . . . . . . . . . . 83 2.3.12 PE3 / LSTRB / TAGLO — Port E I/O Pin 3 / Low-Byte Strobe (LSTRB) . . . . . . . 83 2.3.13 PE2 / R/W — Port E I/O Pin 2 / Read/Write. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 2.3.14 PE1 / IRQ — Port E input Pin 1 / Maskable Interrupt Pin . . . . . . . . . . . . . . . . . . 84 2.3.15 PE0 / XIRQ — Port E input Pin 0 / Non Maskable Interrupt Pin . . . . . . . . . . . . . 84 2.3.16 PK7 / ECS / ROMCTL — Port K I/O Pin 7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84 2.3.17 PK6 / XCS — Port K I/O Pin 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84 2.3.18 PK[5:0] / XADDR[19:14] — Port K I/O Pins [5:0] . . . . . . . . . . . . . . . . . . . . . . . . . 84 2.3.19 2.3.20 PAD[15:0] / AN[15:0] / KWAD[15:0] — Port AD I/O Pins [15:0] . . . . . . . . . . . . . . 85 PM7 / SCL — Port M I/O Pin 7. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 3 Device User Guide — 9S12E128DGV1/D V01.04 2.3.21 PM6 / SDA — Port M I/O Pin 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 2.3.22 PM5 / TXD2 — Port M I/O Pin 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 2.3.23 PM4 / RXD2 — Port M I/O Pin 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 2.3.24 PM3 — Port M I/O Pin 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 2.3.25 PM1 / DAO1 — Port M I/O Pin 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.26 PM0 / DAO2 — Port M I/O Pin 0 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.27 PP[5:0] / PW0[5:0] — Port P I/O Pins [5:0] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.28 PQ[6:4] / IS[2:0] — Port Q I/O Pins [6:4] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.29 PQ[3:0] / FAULT[3:0] — Port Q I/O Pins [3:0] . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.30 PS7 / SS — Port S I/O Pin 7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 2.3.31 PS6 / SCK — Port S I/O Pin 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.32 PS5 / MOSI — Port S I/O Pin 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.33 PS4 / MISO — Port S I/O Pin 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.34 PS3 / TXD1 — Port S I/O Pin 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.35 PS2 / RXD1 — Port S I/O Pin 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.36 PS1 / TXD0 — Port S I/O Pin 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 2.3.37 PS0 / RXD0 — Port S I/O Pin 0 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 2.3.38 PT[7:4] / IOC1[7:4]— Port T I/O Pins [7:4] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 2.3.39 PT[3:0] / IOC0[7:4]— Port T I/O Pins [3:0] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 2.3.40 PU[7:6] — Port U I/O Pins [7:6] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 2.3.41 PU[5:4] / PW1[5:4] — Port U I/O Pins [5:4] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 2.3.42 PU[3:0] / IOC2[7:4]/PW1[3:0] — Port U I/O Pins [3:0] . . . . . . . . . . . . . . . . . . . . . 88 2.4 Power Supply Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89 2.4.1 VDDX,VSSX — Power & Ground Pins for I/O Drivers . . . . . . . . . . . . . . . . . . . . . 89 2.4.2 VDDR, VSSR — Power Supply Pins for I/O Drivers & for Internal Voltage Regulator 89 2.4.3 VDD1, VDD2, VSS1, VSS2 — Power Supply Pins for Internal Logic . . . . . . . . . 89 2.4.4 VDDA, VSSA — Power Supply Pins for ATD and VREG . . . . . . . . . . . . . . . . . . 89 2.4.5 VRH, VRL — ATD Reference Voltage Input Pins . . . . . . . . . . . . . . . . . . . . . . . . 89 2.4.6 VDDPLL, VSSPLL — Power Supply Pins for PLL . . . . . . . . . . . . . . . . . . . . . . . . 89 Section 3 System Clock Description Section 4 Modes of Operation 4.1 Overview. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 4.2 Chip Configuration Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 4 Device User Guide — 9S12E128DGV1/D V01.04 4.3 Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93 4.3.1 Securing the Microcontroller . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93 4.3.2 Operation of the Secured Microcontroller . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93 4.3.3 Unsecuring the Microcontroller . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93 4.4 Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 4.4.1 Stop . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 4.4.2 Pseudo Stop. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 4.4.3 Wait . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 4.4.4 Run. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 Section 5 Resets and Interrupts 5.1 Overview. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 5.2 Vectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 5.3 Resets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96 5.3.1 Effects of Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 Section 6 HCS12 Core Block Description 6.1 6.2 6.3 6.4 6.5 6.6 CPU12 Block Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 HCS12 Background Debug Module (BDM) Block Description . . . . . . . . . . . . . . . . . 97 HCS12 Debug (DBG) Block Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 HCS12 Interrupt (INT) Block Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 HCS12 Multiplexed External Bus Interface (MEBI) Block Description . . . . . . . . . . . 97 HCS12 Module Mapping Control (MMC) Block Description . . . . . . . . . . . . . . . . . . . 98 Section 7 Analog to Digital Converter (ATD) Block Description Section 8 Clock Reset Generator (CRG) Block Description 8.1 Device-specific information. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98 8.1.1 XCLKS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98 Section 9 Digital to Analog Converter (DAC) Block Description Section 10 Flash EEPROM Block Description Section 11 IIC Block Description Section 12 Oscillator (OSC) Block Description 5 Device User Guide — 9S12E128DGV1/D V01.04 Section 13 Port Integration Module (PIM) Block Description Section 14 Pulse width Modulator with Fault protection (PMF) Block Description Section 15 Pulse Width Modulator (PWM) Block Description Section 16 Serial Communications Interface (SCI) Block Description Section 17 Serial Peripheral Interface (SPI) Block Description Section 18 Timer (TIM) Block Description Section 19 Voltage Regulator (VREG) Block Description 19.1 19.2 VREGEN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 VDD1, VDD2, VSS1, VSS2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 Section 20 Printed Circuit Board Layout Proposals Appendix A Electrical Characteristics A.1 General. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105 A.1.1 Parameter Classification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105 A.1.2 Power Supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105 A.1.3 Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106 A.1.4 Current Injection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106 A.1.5 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107 A.1.6 ESD Protection and Latch-up Immunity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108 A.1.7 Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108 A.1.8 Power Dissipation and Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 109 A.1.9 I/O Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 111 A.1.10 Supply Currents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114 Appendix B Electrical Specifications B.1 Voltage Regulator (VREG_3V3) Operating Characteristics . . . . . . . . . . . . . . . . . . 117 B.2 Chip Power-up and LVI/LVR graphical explanation . . . . . . . . . . . . . . . . . . . . . . . . 118 B.3 Output Loads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 118 B.3.1 Resistive Loads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 118 6 Device User Guide — 9S12E128DGV1/D V01.04 B.3.2 B.4 B.4.1 B.4.2 B.4.3 B.5 B.5.1 B.5.2 B.6 B.6.1 B.6.2 B.7 B.7.1 B.7.2 B.7.3 B.7.4 B.7.5 B.8 B.8.1 Capacitive Loads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 119 Reset, Oscillator and PLL. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 121 Startup . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 121 Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 Phase Locked Loop . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 124 Flash NVM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 NVM timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 NVM Reliability. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 Master Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 Slave Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 ATD Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 ATD Operating Characteristics - 5V Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 ATD Operating Characteristics - 3.3V Range . . . . . . . . . . . . . . . . . . . . . . . . . . 140 Factors influencing accuracy. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 ATD accuracy - 5V Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 ATD accuracy - 3.3V Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 DAC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 DAC Operating Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 Appendix C External Bus Timing Appendix D Package Information D.1 D.2 80-pin QFP package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 153 112-pin LQFP package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154 7 Device User Guide — 9S12E128DGV1/D V01.04 8 Device User Guide — 9S12E128DGV1/D V01.04 List of Figures Figure 0-1 Figure 1-1 Figure 1-2 Figure 1-3 Figure 1-4 Figure 1-5 Figure 2-1 Figure 2-2 Figure 2-3 Figure 2-4 Figure 3-1 Figure 20-1 Figure 20-2 Figure B-1 Figure B-2 Figure B-3 Figure B-4 Figure B-5 Figure B-6 Figure B-7 Figure B-8 Figure C-1 Figure D-1 Order Part Number Coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 MC9S12E-Family Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 MC9S12E256 User Configurable Memory Map . . . . . . . . . . . . . . . . . . . . . . 23 MC9S12E128 User Configurable Memory Map . . . . . . . . . . . . . . . . . . . . . . 24 MC9S12E64 User Configurable Memory Map . . . . . . . . . . . . . . . . . . . . . . . 25 MC9S12E32 User configurable Memory Map . . . . . . . . . . . . . . . . . . . . . . . . 26 Pin assignments 112 LQFP for MC9S12E-Family. . . . . . . . . . . . . . . . . . . . . 76 Pin assignments in 80 QFP for MC9S12E-Family. . . . . . . . . . . . . . . . . . . . . 77 Colpitts Oscillator Connections (PE7=1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 Pierce Oscillator Connections (PE7=0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 Clock Connections. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 Recommended PCB Layout (112 LQFP) . . . . . . . . . . . . . . . . . . . . . . . . . . 102 Recommended PCB Layout (80 QFP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 Voltage Regulator - Chip Power-up and Voltage Drops (not scaled) . . . . 118 Basic PLL functional diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 124 Jitter Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 126 SPI Master Timing (CPHA=0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 SPI Master Timing (CPHA=1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134 SPI Slave Timing (CPHA=0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 SPI Slave Timing (CPHA=1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 ATD Accuracy Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 144 General External Bus Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148 80-pin QFP Mechanical Dimensions (case no. 841B) . . . . . . . . . . . . . . . . 153 9 Device User Guide — 9S12E128DGV1/D V01.04 10 Device User Guide — 9S12E128DGV1/D V01.04 List of Tables Table 0-1 Table 0-2 Table 0-3 Table 0-4 Table 1-1 Table 1-2 Table 1-3 Table 2-1 Table 2-2 Table 3-1 Table 4-1 Table 4-2 Table 5-1 Table 5-2 Table 20-1 Table A-1 Table A-2 Table A-3 Table A-4 Table A-5 Table A-6 Table A-7 Table A-8 Table 20-2 Table B-1 Table B-2 Table B-3 Table B-4 Table B-5 Table B-6 Table B-7 Table B-8 Table B-9 Document References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Part Number Coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Package Option Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 List of MC9S12E-Family members . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Device Register Map Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Assigned Part ID Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74 Memory size registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 Signal Properties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78 MC9S12E-Family Power and Ground Connection Summary . . . . . . . . . . . . . 90 Clock Selection Based on PE7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 Mode Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 Clock Selection Based on PE7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 Interrupt Vector Locations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 Reset Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96 Recommended decoupling capacitor choice . . . . . . . . . . . . . . . . . . . . . . . . . 101 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107 ESD and Latch-up Test Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108 ESD and Latch-Up Protection Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 108 Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 109 Thermal Package Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 111 5V I/O Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112 Preliminary 3.3V I/O Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113 Supply Current Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 115 VREG_3V3 - Operating Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 117 Voltage Regulator - Capacitive Loads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 119 Startup Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 121 Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 PLL Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 127 NVM Timing Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 NVM Reliability Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 131 Measurement Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 SPI Master Mode Timing Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . 134 SPI Slave Mode Timing Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 11 Device User Guide — 9S12E128DGV1/D V01.04 Table B-10 Table B-11 Table B-12 Table B-14 Table B-13 Table B-15 Table B-16 Table C-1 Table C-2 12 5V ATD Operating Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 3.3V ATD Operating Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 ATD Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141 3.3V ATD Conversion Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 5V ATD Conversion Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 DAC Electrical Characteristics (Operating) . . . . . . . . . . . . . . . . . . . . . . . . . . 145 DAC Timing/Performance Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 Expanded Bus Timing Characteristics (5V Range). . . . . . . . . . . . . . . . . . . . 149 Expanded Bus Timing Characteristics (3.3V Range) . . . . . . . . . . . . . . . . . . 151 Device User Guide — 9S12E128DGV1/D V01.04 Preface The Device User Guide provides information about the MC9S12E-Family devices made up of standard HCS12 blocks and the HCS12 processor core. This document is part of the customer documentation. A complete set of device manuals also includes all the individual Block Guides of the implemented modules. In a effort to reduce redundancy, all module specific information is located only in the respective Block Guide. If applicable, special implementation details of the module are given in the block description sections of this document. See Table 0-1 for names and versions of the referenced documents throughout the Device User Guide. Table 0-1 Document References E256 Version E128, E64 Version E32 Version Document Order Number CPU12 Reference Manual V02 V02 V02 S12CPUV2/D HCS12 Background Debug (BDM) V04 V04 V04 S12BDMV4/D HCS12 Debug (DBG) V01 V01 V01 S12DBGV1/D HCS12 Interrupt (INT) V01 V01 V01 S12INTV1/D HCS12 Multiplexed Expanded Bus Interface (MEBI) V03 V03 V03 S12MEBIV3/D HCS12 Module Mapping Control (MMC) V04 V04 V04 S12MMCV4/D Analog to Digital Converter: 10-Bit, 16 Channels (ATD_10B16C) V04 V02 V04 S12ATD10B16CVx/D1 Block Guide Clock and Reset Generator (CRG) V04 V04 V04 S12CRGV4/D Digital to Analog Converter: 8-Bit, 1 Channel (DAC_8B1C) V01 V01 V01 S12DAC8B1CV1/D 256Kbyte Flash EEPROM (FTS256K2) V01 N/A N/A S12FTS256K2V1/D 128Kbyte Flash EEPROM (FTS128K1) N/A V01 N/A S12FTS128K1V1/D S12FTS32KV2/D 32Kbyte Flash EEPROM (FTS32K) N/A N/A V02 Inter IC Bus (IIC) V02 V02 V02 S12IICV2/D Oscillator (OSC) V02 V02 V02 S12OSCV2/D Port Integration Module (PIM_9E128) V01 V01 V01 S12PIM9E128V1/D Pulse Modulator with Fault Protection: 15-Bit, 6 Channels (PMF_15B6C) V02 V02 V02 S12PMF15B6CV2/D Pulse Width Modulator: 8-Bit, 6 Channels (PWM_8B6C) V01 V01 V01 S12PWM8B6CV1/D Serial Communications Interface (SCI) V04 V03 V04 S12SCIVy/D2 Serial Peripheral Interface (SPI) V03 V03 V03 S12SPIV3/D Timer: 16-Bit, 4 Channels (TIM_16B4C) V01 V01 V01 S12TIM16B4CV1/D Voltage Regulator (VREG_3V3) V02 V02 V02 S12VREG3V3V2/D NOTES: 1. x in S12ATD10B16CVx/D is 2 for E64 and E128, and 4 for E32 and E256. 2. y in S12SCIVy/D is 3 for E64 and E128, and 4 for E32 and E256. 13 Device User Guide — 9S12E128DGV1/D V01.04 Part Number Figure 0-1 provides an ordering number example. MC9S12 E128 C FU Package Option Temperature Option Package Options FC = 64QFN FU = 80QFP PV = 112LQFP Temperature Options C = -40°C to 85°C V = -40°C to 105°C M = -40°C to 125°C Device Title Controller Family Figure 0-1 Order Part Number Coding Table 0-2 lists the part number coding based on the package and temperature. Table 0-2 Part Number Coding Part Number 14 Temp. Package Description MC9S12E256CFU -40°C, 85°C 80QFP MC9S12E256 MC9S12E256CPV -40°C, 85°C 112LQFP MC9S12E256 MC9S12E256MFU -40°C, 125°C 80QFP MC9S12E256 MC9S12E256MPV -40°C, 125°C 112LQFP MC9S12E256 MC9S12E128CFU -40°C, 85°C 80QFP MC9S12E128 MC9S12E128CPV -40°C, 85°C 112LQFP MC9S12E128 MC9S12E128MFU -40°C, 125°C 80QFP MC9S12E128 MC9S12E128MPV -40°C, 125°C 112LQFP MC9S12E128 MC9S12E64CFU -40°C, 85°C 80QFP MC9S12E64 MC9S12E64CPV -40°C, 85°C 112LQFP MC9S12E64 MC9S12E64MFU -40°C, 125°C 80QFP MC9S12E64 MC9S12E64MPV -40°C, 125°C 112LQFP MC9S12E64 MC9S12E32CFU -40°C, 85°C 80QFP MC9S12E32 MC9S12E32MFU -40°C, 125°C 80QFP MC9S12E32 Device User Guide — 9S12E128DGV1/D V01.04 Table 0-3 summarizes the package option and size configuration. Table 0-3 Package Option Summary Temp.1 Options Package Device 80QFP MC9S12E256 MC9S12E256 M, C 112LQFP MC9S12E256 MC9S12E256 M, C MC9S12E128 MC9S12E128 M, C 112LQFP MC9S12E128 MC9S12E128 M, C 80QFP Part Number 80QFP MC9S12E64 MC9S12E64 M, C 112LQFP MC9S12E64 MC9S12E64 M, C 64QFN MC9S12E32 MC9S12E32 M, C 80QFP MC9S12E32 MC9S12E32 M, C Flash RAM 256K 16K 128K 8K 64K 4K 32K 2K I/O2 60 92 60 92 60 92 44 60 NOTES: 1. C: TA = 85¯C, f = 25MHz. M: TA= 125¯C, f = 25MHz 2. I/O is the sum of ports capable to act as digital input or output. Table 0-4 List of MC9S12E-Family members Device Flash RAM Package MEBI E256 E128 256K 128K 16K 8K E64 64K 4K E32 32K 2K 112 LQFP 1 80 QFP 0 112 LQFP 1 80 QFP 0 112 LQFP 1 80 QFP 0 80 QFP 0 TIM SCI SPI IIC A/D D/A PWM PMF KWU 12 3 1 1 16 2 6 6 16 12 3 1 1 16 2 6 6 16 12 3 1 1 16 2 6 6 16 8 2 1 1 16 2 0 6 16 I/O 92 60 92 60 92 60 60 • Pin out explanations: — TIM is the number of channels. — A/D is the number of A/D channels. — D/A is the number of D/A channels. — PWM is the number of channels. — PMF is the number of channels. — KWU is the number of key wake up interrupt pins. — I/O is the sum of ports capable to act as digital input or output. 112 Pin Packages: Port A = 8, B = 8, E = 6 + 2 input only, K = 8, M = 7, P = 6, Q = 7, S = 8, T = 8, U = 8, AD = 16. 18 inputs provide Interrupt capability (AD = 16, IRQ, XIRQ) 80 Pin Packages: E = 2 + 2 input only, M = 7, P = 6, Q = 7, S = 8, T = 8, U = 4, AD = 16. 18 inputs provide Interrupt capability (AD = 16, IRQ, XIRQ) — Versions with 3 SCI modules will have SCI0, SCI1 and SCI2. — Versions with 2 SCI modules will have SCI0 and SCI1. — Versions with 3 TIM modules will have TIM0, TIM1 and TIM2. — Versions with 2 TIM modules will have TIM0 and TIM1. 15 Device User Guide — 9S12E128DGV1/D V01.04 16 Device User Guide — 9S12E128DGV1/D V01.04 Section 1 Introduction 1.1 Overview The MC9S12E-Family is a 112/80 pin low cost general purpose MCU family. All members of the MC9S12E-Family are comprised of standard on-chip peripherals including a 16-bit central processing unit (HCS12 CPU), up to 256K bytes of Flash EEPROM, up to 16K bytes of RAM, three asynchronous serial communications interface modules (SCI), a serial peripheral interface (SPI), an Inter-IC Bus (IIC), three 4-channel 16-bit timer modules (TIM), a 6-channel 15-bit Pulse Modulator with Fault protection module (PMF), a 6-channel 8-bit Pulse Width Modulator (PWM), a 16-channel 10-bit analog-to-digital converter (ADC), and two 1-channel 8-bit digital-to-analog converters (DAC). The MC9S12E-Family has full 16-bit data paths throughout. The inclusion of a PLL circuit allows power consumption and performance to be adjusted to suit operational requirements. In addition to the I/O ports available on each module, 16 dedicated I/O port bits are available with Wake-Up capability from STOP or WAIT mode. Furthermore, an on chip bandgap based voltage regulator (VREG) generates the internal digital supply voltage of 2.5V (VDD) from a 3.135V to 5.5V external supply range. 1.2 Features • 16-bit HCS12 CORE – HCS12 CPU i. Upward compatible with M68HC11 instruction set ii. Interrupt stacking and programmer’s model identical to M68HC11 iii. Instruction queue iv. Enhanced indexed addressing • – Module Mapping Control (MMC) – Interrupt Control (INT) – Background Debug Module (BDM) – Debugger (DBG12) including breakpoints and change-of-flow trace buffer – Multiplexed External Bus Interface (MEBI) Wake-Up interrupt inputs – • • Up to 16 port bits available for wake up interrupt function with digital filtering Memory options – 32K, 64K, 128K or 256K Byte Flash EEPROM – 2K, 4K, 8K or 16K Byte RAM Two 1-channel Digital-to-Analog Converters (DAC) – 8-bit resolution 17 Device User Guide — 9S12E128DGV1/D V01.04 • • • • • • 18 Analog-to-Digital Converter (ADC) – 16-channel module with 10-bit resolution – External conversion trigger capability Three 4-channel Timers (TIM) – Programmable input capture or output compare channels – Simple PWM mode – Counter Modulo Reset – External Event Counting – Gated Time Accumulation 6 PWM channels (PWM) – Programmable period and duty cycle – 8-bit 6-channel or 16-bit 3-channel – Separate control for each pulse width and duty cycle – Center-aligned or left-aligned outputs – Programmable clock select logic with a wide range of frequencies – Fast emergency shutdown input 6-channel Pulse width Modulator with Fault protection (PMF) – Three independent 15-bit counters with synchronous mode – Complementary channel operation – Edge and center aligned PWM signals – Programmable dead time insertion – Integral reload rates from 1 to 16 – Four fault protection shut down input pins – Three current sense input pins Serial interfaces – Three asynchronous serial communication interfaces (SCI) – Synchronous serial peripheral interface (SPI) – Inter-IC Bus (IIC) Clock and Reset Generator (CRG) – Windowed COP watchdog – Real Time interrupt – Clock Monitor Device User Guide — 9S12E128DGV1/D V01.04 • – Pierce or low current Colpitts oscillator – Phase-locked loop clock frequency multiplier – Self Clock mode in absence of external clock – Low power 0.5 to 16Mhz crystal oscillator reference clock Operating frequency – • • • 50MHz equivalent to 25MHz Bus Speed Internal 2.5V Regulator – Input voltage range from 3.135V to 5.5V – Low power mode capability – Includes low voltage reset (LVR) circuitry – Includes low voltage interrupt (LVI) circuitry 112-Pin LQFP or 80-Pin QFP package – Up to 90 I/O lines with 5V input and drive capability (112 pin package) – Up to two dedicated 5V input only lines (IRQ and XIRQ) – Sixteen 3.3V/5V A/D converter inputs Development Support. – Single-wire background debugTM mode – On-chip hardware breakpoints – Enhanced debug features 1.3 Modes of Operation User modes (Expanded modes are only available in the 112 pin package version) • • Normal modes – Normal Single-Chip Mode – Normal Expanded Wide Mode – Normal Expanded Narrow Mode – Emulation Expanded Wide Mode – Emulation Expanded Narrow Mode Special Operating Modes – Special Single-Chip Mode with active Background Debug Mode – Special Test Mode (Motorola use only) – Special Peripheral Mode (Motorola use only) 19 Device User Guide — 9S12E128DGV1/D V01.04 • 20 Low power modes – Stop Mode – Pseudo Stop Mode – Wait Mode Device User Guide — 9S12E128DGV1/D V01.04 1.4 Block Diagram PW10 PW11 PW12 PW13 PW14 PW15 PWM Multiplexed Address/Data Bus PTB Multiplexed Narrow Bus ADDR15 ADDR14 ADDR13 ADDR12 ADDR11 ADDR10 ADDR9 ADDR8 ADDR7 ADDR6 ADDR5 ADDR4 ADDR3 ADDR2 ADDR1 ADDR0 DATA15 DATA14 DATA13 DATA12 DATA11 DATA10 DATA9 DATA8 DATA7 DATA6 DATA5 DATA4 DATA3 DATA2 DATA1 DATA0 DATA7 DATA6 DATA5 DATA4 DATA3 DATA2 DATA1 DATA0 Multiplexed Wide Bus Voltage Regulator 3.3V/5V VDDR VSSR PLL 2.5V VDDPLL VSSPLL TIM2 AN0 AN1 AN2 AN3 ADC AN4 AN5 AN6 AN7 AN8 AN9 AN10 AN11 AN12 AN13 AN14 AN15 ADC/DAC 3.3V/5V Voltage Reference I/O Driver 3.3V/5V VDDX VSSX VRH VRL VDDA VSSA Internal Logic 2.5V VDD1,2 VSS1,2 Signals shown in Bold are not available on the 80 Pin Package DDRP DDRQ PT0 PT1 PT2 PT3 PT4 PT5 PT6 PT7 PU0 PU1 PU2 PU3 PU4 PU5 PU6 PU7 IOC24 IOC25 IOC26 IOC27 PB7 PB6 PB5 PB4 PB3 PB2 PB1 PB0 PTA PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 DDRB MUX PTP TIM1 PTQ TIM0 TEST DDRA IOC04 IOC05 IOC06 IOC07 IOC14 IOC15 IOC16 IOC17 PTS SPI DDRS SCI1 PS0 PS1 PS2 PS3 PS4 PS5 PS6 PS7 PTT RXD0 TXD0 RXD1 TXD1 MISO MOSI SCK SS SCI0 XIRQ IRQ R/W System LSTRB/TAGLO Integration ECLK Module MODA/IPIPE0 (SIM) MODB/IPIPE1 NOACC/XCLKS XADDR14 XADDR15 XADDR16 XADDR17 XADDR18 XADDR19 XCS ECS DDRE PTE PTK PK0 PK1 PK2 PK3 PK4 PK5 PK6 PK7 Generation DDRK PE0 PE1 PE2 PE3 PE4 PE5 PE6 PE7 Clock and CRG Reset PQ0 PQ1 PQ2 PQ3 PQ4 PQ5 PQ6 SCI2 IIC KWAD0 KWAD1 KWAD2 KWAD3 KWAD4 KWAD5 KWAD6 KWAD7 KWAD8 KWAD9 KWAD10 KWAD11 KWAD12 KWAD13 KWAD14 KWAD15 DAC0 DAO0 DAC1 DAO1 RXD2 TXD2 SDA SCL PAD XFC CPU12 Periodic Interrupt COP Watchdog Clock Monitor Debugger(DBG12) Breakpoints PP0 PP1 PP2 PP3 PP4 PP5 PAD0 PAD1 PAD2 PAD3 PAD4 PAD5 PAD6 PAD7 PAD8 PAD9 PAD10 PAD11 PAD12 PAD13 PAD14 PAD15 PM0 PM1 PTM Single-wire Background Debug Module EXTAL XTAL RESET FAULT0 FAULT1 FAULT2 FAULT3 IS0 IS1 IS2 MODC/TAGHI DDRAD BKGD PMF Voltage Regulator DDRM VDDR VSSR DDRT 2K -16K Byte RAM DDRU PW00 PW01 PW02 PW03 PW04 PW05 32K - 256K Byte Flash EEPROM PTU Figure 1-1 MC9S12E-Family Block Diagram PM3 PM4 PM5 PM6 PM7 21 Device User Guide — 9S12E128DGV1/D V01.04 1.5 Device Memory Map Table 1-1 shows the device register map of the MC9S12E-Family after reset. The following figures (, Figure 1-3, and Figure 1-4) illustrate the full device memory map with Flash and RAM. Table 1-1 Device Register Map Overview Address 22 Module Size $000 - $017 CORE (Ports A, B, E, Modes, Inits, Test) $018 Reserved 24 1 $019 Voltage Regulator (VREG) 1 $01A - $01B Device ID register (PARTID) 2 $01C - $01F CORE (MEMSIZ, IRQ, HPRIO) $020 - $02F CORE (DBG) $030 - $033 CORE (PPAGE, Port K) $034 - $03F Clock and Reset Generator (PLL, RTI, COP) 4 16 4 12 $040 - $06F Standard Timer 16-bit 4 channels (TIM0) 48 $070 - $07F Reserved 16 $080 - $0AF Analog to Digital Converter 10-bit 16 channels (ATD) 48 $0B0 - $0C7 Reserved 24 $0C8 - $0CF Serial Communications Interface 0 (SCI0) 8 $0D0 - $0D7 Serial Communications Interface 1 (SCI1) 8 $0D8 - $0DF Serial Peripheral Interface (SPI) 8 $0E0 - $0E7 Inter IC Bus 8 $0E8 - $0EF Serial Communications Interface 2 (SCI2) 8 $0F0 - $0F3 Digital to Analog Converter 8-bit 1-channel (DAC0) 4 $0F4 - $0F7 Digital to Analog Converter 8-bit 1-channel (DAC1) 4 $0F8 - $0FF Reserved 8 $100- $10F Flash Control Register 16 $110 - $13F Reserved 48 $140 - $16F Standard Timer 16-bit 4 channels (TIM1) 48 $170 - $17F Reserved 16 $180 - $1AF Standard Timer 16-bit 4 channels (TIM2) 48 $1B0 - $1DF Reserved 48 $1E0 - $1FF Pulse Width Modulator 8-bit 6 channels (PWM) 32 $200 - $23F Pulse Width Modulator with Fault 15-bit 6 channels (PMF) 64 $240 - $27F Port Integration Module (PIM) $280 - $3FF Reserved 64 384 Device User Guide — 9S12E128DGV1/D V01.04 $0000 $0400 $0000 1K Register Space $03FF Mappable to any 2K Boundary $4000 16K Bytes RAM $4000 Mappable to any 16K Boundary $7FFF $8000 $8000 16K Page Window sixteen * 16K Flash EEPROM Pages EXT $BFFF $C000 $C000 16K Fixed Flash EEPROM $FFFF 2K, 4K, 8K or 16K Protected Boot Sector $FF00 $FF00 $FFFF VECTORS VECTORS VECTORS NORMAL SINGLE CHIP EXPANDED SPECIAL SINGLE CHIP $FFFF BDM (If Active) The figure shows a useful map, which is not the map out of reset. After reset the map is: $0000 - $03FF: Register Space $0000 - $3FFF: 16K RAM (only 15K RAM visible $0400 - $3FFF) Figure 1-2 MC9S12E256 User Configurable Memory Map 23 Device User Guide — 9S12E128DGV1/D V01.04 $0000 $0400 $0000 1K Register Space $03FF Mappable to any 2K Boundary $2000 8K Bytes RAM $3FFF Mappable to any 8K Boundary $4000 0.5K, 1K, 2K or 4K Protected Sector $2000 $4000 $7FFF 16K Fixed Flash EEPROM $8000 $8000 16K Page Window eight * 16K Flash EEPROM Pages EXT $BFFF $C000 $C000 16K Fixed Flash EEPROM $FFFF 2K, 4K, 8K or 16K Protected Boot Sector $FF00 $FF00 $FFFF VECTORS VECTORS VECTORS NORMAL SINGLE CHIP EXPANDED SPECIAL SINGLE CHIP $FFFF BDM (If Active) The figure shows a useful map, which is not the map out of reset. After reset the map is: $0000 - $03FF: Register Space $0000 - $1FFF: 8K RAM (only 7K RAM visible $0400 - $1FFF) Figure 1-3 MC9S12E128 User Configurable Memory Map 24 Device User Guide — 9S12E128DGV1/D V01.04 $0000 $0400 $0000 1K Register Space $03FF Mappable to any 2K Boundary $3000 4K Bytes RAM $3FFF Mappable to any 4K Boundary $4000 0.5K, 1K, 2K or 4K Protected Sector $3000 $4000 $7FFF 16K Fixed Flash EEPROM $8000 $8000 16K Page Window four * 16K Flash EEPROM Pages EXT $BFFF $C000 $C000 16K Fixed Flash EEPROM $FFFF 2K, 4K, 8K or 16K Protected Boot Sector $FF00 $FF00 $FFFF VECTORS VECTORS VECTORS NORMAL SINGLE CHIP EXPANDED SPECIAL SINGLE CHIP $FFFF BDM (If Active) The figure shows a useful map, which is not the map out of reset. After reset the map is: $0000 - $03FF: Register Space $0000 - $0FFF: 4K RAM (only 3K RAM visible $0400 - $0FFF) Figure 1-4 MC9S12E64 User Configurable Memory Map 25 Device User Guide — 9S12E128DGV1/D V01.04 $0000 $0400 $0000 1K Register Space $03FF Mappable to any 2K Boundary $3700 2K Bytes RAM $3FFF Mappable to any 2K Boundary $4000 0.5K, 1K, 2K or 4K Protected Sector $3000 $4000 $7FFF 16K Fixed Flash EEPROM $8000 $8000 16K Page Window two * 16K Flash EEPROM Pages EXT $BFFF $C000 $C000 16K Fixed Flash EEPROM $FFFF 2K, 4K, 8K or 16K Protected Boot Sector $FF00 $FF00 $FFFF VECTORS VECTORS VECTORS NORMAL SINGLE CHIP EXPANDED SPECIAL SINGLE CHIP $FFFF BDM (If Active) The figure shows a useful map, which is not the map out of reset. After reset the map is: $0000 - $03FF: Register Space $0000 - $07FF: 2K RAM (only 1K RAM visible $0400 - $07FF) Figure 1-5 MC9S12E32 User configurable Memory Map 1.6 Detailed Register Map The detailed register map of the MC9S12E-Family is listed in address order below. For detailed information about register function please refer to the appropriate block guide. 26 Device User Guide — 9S12E128DGV1/D V01.04 $0000 - $000F Addres s Name $0000 PORTA $0001 PORTB $0002 DDRA $0003 DDRB $0004 Reserved $0005 Reserved $0006 Reserved $0007 Reserved $0008 PORTE $0009 DDRE $000A PEAR MEBI map 1 of 3 (HCS12 Multiplexed External Bus Interface) Bit 7 Read : Bit 7 Write : Read : Bit 7 Write : Read : Bit 7 Write : Read : Bit 7 Write : Read 0 : Write : Read 0 : Write : Read 0 : Write : Read 0 : Write : Read : Bit 7 Write : Read : Bit 7 Write : Read : NOACC E Write : Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 6 5 4 3 2 1 Bit 0 6 5 4 3 2 1 Bit 0 6 5 4 3 2 1 Bit 0 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 1 Bit 0 6 5 4 3 2 0 0 0 0 6 5 4 3 Bit 2 PIPOE NECLK LSTRE RDWE 0 27 Device User Guide — 9S12E128DGV1/D V01.04 $0000 - $000F $000B MODE $000C PUCR $000D RDRIV $000E EBICTL $000F Reserved $0010 - $0014 Addres s 28 Name $0010 INITRM $0011 INITRG $0012 INITEE $0013 MISC $0014 MTST0 MEBI map 1 of 3 (HCS12 Multiplexed External Bus Interface) Read : MODC Write : Read : PUPKE Write : Read : RDPK Write : Read 0 : Write : Read 0 : Write : 0 0 MODB MODA IVIS 0 0 0 EMK 0 PUPEE 0 0 PUPBE PUPAE 0 0 RDPE 0 0 0 EME RDPB 0 0 RDPA 0 ESTR 0 0 0 0 0 0 0 MMC map 1 of 4 (HCS12 Module Mapping Control) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Read 0 0 : RAMHA RAM15 RAM14 RAM13 RAM12 RAM11 L Write : Read 0 0 0 0 : REG14 REG13 REG12 REG11 Write : Read 0 0 : EE15 EE14 EE13 EE12 EE11 EEON Write : Read 0 0 0 0 : EXSTR1 EXSTR0 ROMHM ROMON Write : Read Bit 7 6 5 4 3 2 1 Bit 0 : Write : Device User Guide — 9S12E128DGV1/D V01.04 $0015 - $0016 Addres s INT map 1 of 2 (HCS12 Interrupt) Name $0015 ITCR $0016 ITEST Read : Write : Read : Write : $0017 - $0017 Addres s $0017 Read : Write : $0018 - $0018 Addres s $0018 Read : Write : $0019 - $0019 Addres s Bit 5 0 0 0 INTE INTC INTA Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 WRINT ADR3 ADR2 ADR1 ADR0 INT8 INT6 INT4 INT2 INT0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Miscellaneous Peripherals (Device User Guide) Name Reserved Bit 6 MMC map 2 of 4 (HCS12 Module Mapping Control) Name MTST1 Bit 7 Name Read : $0019 VREGCTRL Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 Bit 1 Bit 0 LVIE LVIF VREG3V3 (Voltage Regulator) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 0 0 0 0 0 LVDS 29 Device User Guide — 9S12E128DGV1/D V01.04 $001A - $001B Addres s $001A $001B Miscellaneous Peripherals (Device User Guide) Name PARTIDH PARTIDL Read : Write : Read : Write : $001C - $001D User Guide) Addres s $001C $001D MEMSIZ1 $001E $001F - $001F Addres s $001F 30 Name HPRIO Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ID15 ID14 ID13 ID12 ID11 ID10 ID9 ID8 ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 Bit 6 Bit 5 Bit 4 Bit 3 Read eep_sw eep_sw reg_sw0 0 : 1 0 Write : Read rom_sw rom_sw 0 0 : 1 0 Write : 0 0 Bit 2 Bit 1 Bit 0 ram_sw ram_sw ram_sw 2 1 0 0 pag_sw pag_sw 1 0 MEBI map 2 of 3 (HCS12 Multiplexed External Bus Interface) Name INTCR Bit 5 Bit 7 $001E - $001E Addres s Bit 6 MMC map 3 of 4 (HCS12 Module Mapping Control, Device Name MEMSIZ0 Bit 7 Read : Write : Bit 7 Bit 6 IRQE IRQEN Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 Bit 0 INT map 2 of 2 (HCS12 Interrupt) Bit 7 Read : PSEL7 Write : Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 PSEL6 PSEL5 PSEL4 PSEL3 PSEL2 PSEL1 0 Device User Guide — 9S12E128DGV1/D V01.04 $0020 - $002F Addres s $0020 $0021 $0022 $0023 $0024 $0025 $0026 $0027 $0028 $0029 $002A $002B $002C $002D $002E $002F DBG (including BKP) map 1of 1 (HCS12 Debug) Name DBGC1 - DBGSC DBGTBH DBGTBL DBGCNT DBGCCX DBGCCH DBGCCL - DBGC2 BKPCT0 DBGC3 BKPCT1 DBGCAX BKP0X DBGCAH BKP0H DBGCAL BKP0L DBGCBX BKP1X DBGCBH BKP1H DBGCBL BKP1L Bit 7 $0030 read write read write read write read write read write $0031 Reserved Bit 4 Bit 3 Bit 2 Bit 1 ARM TRGSEL BEGIN DBGBRK BF CF 0 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TBF 0 0 read write read write read write read write read write Bit 0 CAPMOD TRG CNT PAGSEL EXTCMP Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 RWCEN RWC RWBEN RWB read BKABEN FULL BDM TAGAB BKCEN TAGC write read BKAMBH BKAMBL BKBMBH BKBMBL RWAEN RWA write read PAGSEL EXTCMP write Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 PAGSEL EXTCMP Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 MMC map 4 of 4 (HCS12 Module Mapping Control) Name PPAGE Bit 5 read DBGEN write AF read write read Bit 15 write $0030 - $0031 Addres s Bit 6 Read : Write : Read : Write : Bit 7 Bit 6 0 0 0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PIX5 PIX4 PIX3 PIX2 PIX1 PIX0 0 0 0 0 0 0 31 Device User Guide — 9S12E128DGV1/D V01.04 $0032 - $0033 Addres s Name $0032 PORTK $0033 DDRK $0034 - $003F Addres s $0034 $0035 $0036 $0037 $0038 $0039 $003A $003B 32 MEBI map 3 of 3 (HCS12 Multiplexed External Bus Interface) Name Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ECS XCS XAB19 XAB18 XAB17 XAB16 XAB15 XAB14 Bit 7 6 5 4 3 2 1 Bit 0 CRG (Clock and Reset Generator) Bit 7 Bit 6 Bit 5 Read 0 0 : SYNR SYN5 Write : Read 0 0 0 : REFDV Write : Read TOUT7 TOUT6 TOUT5 : CTFLG TEST ONLY Write : Read 0 : CRGFLG RTIF PROF Write : Read 0 0 : CRGINT RTIE Write : Read : CLKSEL PLLSEL PSTP SYSWAI Write : Read : PLLCTL CME PLLON AUTO Write : Read 0 : RTICTL RTR6 RTR5 Write : Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SYN4 SYN3 SYN2 SYN1 SYN0 0 TOUT4 REFDV REFDV REFDV REFDV 3 2 1 0 TOUT3 TOUT2 LOCK TRACK LOCKIF TOUT1 TOUT0 SCM SCMIF 0 0 LOCKIE 0 SCMIE ROAWA PLLWAI I CWAI RTIWAI COPWA I PRE PCE SCME RTR2 RTR1 RTR0 0 ACQ RTR4 RTR3 Device User Guide — 9S12E128DGV1/D V01.04 $0034 - $003F Addres s Name CRG (Clock and Reset Generator) Bit 7 Bit 6 Read : $003C COPCTL WCOP RSBCK Write : Read : FORBYP COPBY $003D RTIBYP TEST ONLY Write P : Read TCTL7 TCTL6 : CTCTL $003E TEST ONLY Write : Read 0 0 : $003F ARMCOP Write Bit 7 6 : $0040 - $006F Addres s Name $0040 TIOS $0041 CFORC $0042 OC7M $0043 OC7D $0044 TCNT (hi) $0045 TCNT (lo) Bit 5 Bit 4 Bit 3 0 0 0 0 0 Bit 2 Bit 1 Bit 0 CR2 CR1 CR0 0 PLLBYP 0 FCM TCTL5 TCTL4 TCLT3 TCTL2 TCTL1 TCTL0 0 0 0 0 0 0 5 4 3 2 1 Bit 0 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 11 10 9 Bit 8 3 2 1 Bit 0 TIM0 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Read : IOS7 IOS6 IOS5 IOS4 Write : Read 0 0 0 0 : Write FOC7 FOC6 FOC5 FOC4 : Read : OC7M7 OC7M6 OC7M5 OC7M4 Write : Read : OC7D7 OC7D6 OC7D5 OC7D4 Write : Read Bit 15 14 13 12 : Write : Read Bit 7 6 5 4 : Write : 33 Device User Guide — 9S12E128DGV1/D V01.04 $0040 - $006F Addres s 34 Name $0046 TSCR1 $0047 TTOV $0048 TCTL1 $0049 Reserved $004A TCTL3 $004B Reserved $004C TIE $004D TSCR2 $004E TFLG1 $004F TFLG2 $0050 Reserved TIM0 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Read 0 0 0 0 : TEN TSWAI TSFRZ TFFCA Write : Read 0 0 0 0 : TOV7 TOV6 TOV5 TOV4 Write : Read : OM7 OL7 OM6 OL6 OM5 OL5 OM4 OL4 Write : Read 0 0 0 0 0 0 0 0 : Write : Read : EDG7B EDG7A EDG6B EDG6A EDG5B EDG5A EDG4B EDG4A Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 : C7I C6I C5I C4I Write : Read 0 0 0 : TOI TCRE PR2 PR1 PR0 Write : Read 0 0 0 0 : C7F C6F C5F C4F Write : Read 0 0 0 0 0 0 0 : TOF Write : Read 0 0 0 0 0 0 0 0 : Write : Device User Guide — 9S12E128DGV1/D V01.04 $0040 - $006F Addres s TIM0 (Timer 16 Bit 4 Channels) Name $0051 Reserved $0052 Reserved $0053 Reserved $0054 Reserved $0055 Reserved $0056 Reserved $0057 Reserved $0058 TC4 (hi) $0059 TC4 (lo) $005A TC5 (hi) $005B TC5 (lo) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 35 Device User Guide — 9S12E128DGV1/D V01.04 $0040 - $006F Addres s 36 TIM0 (Timer 16 Bit 4 Channels) Name $005C TC6 (hi) $005D TC6 (lo) $005E TC7 (hi) $005F TC7 (lo) $0060 PACTL $0061 PAFLG $0062 PACNT (hi) $0063 PACNT (lo) $0064 Reserved $0065 Reserved $0066 Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 PAEN PAMOD PEDGE CLK1 CLK0 PAOVI PAI 0 0 0 0 0 PAOVF PAIF 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0040 - $006F Addres s TIM0 (Timer 16 Bit 4 Channels) Name $0067 Reserved $0068 Reserved $0069 Reserved $006A Reserved $006B Reserved $006C Reserved $006D Reserved $006E Reserved $006F Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : $0070 - $007F $0070 $007F Reserved Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Reserved Read : Write : 0 37 Device User Guide — 9S12E128DGV1/D V01.04 $0080 - $00AF Addres s $0080 38 ATD (Analog to Digital Converter 10 Bit 16 Channel) Name ATDCTL0 $0081 ATDCTL1 $0082 ATDCTL2 $0083 ATDCTL3 $0084 ATDCTL4 $0085 ATDCTL5 $0086 ATDSTAT0 $0087 Reserved $0088 ATDTEST0 $0089 ATDTEST1 $008A ATDSTAT0 Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 0 0 0 0 0 0 0 AFFC AWAI S8C S4C S2C SMP1 SMP0 PRS4 ETRIGS EL2 ADPU Bit 3 Bit 2 Bit 1 Bit 0 WRAP31 WRAP21 WRAP11 WRAP01 ETRIGC ETRIGC ETRIGC ETRIGC H32 H22 H12 H02 ETRIGL ETRIGP E ASCIF ETRIG ASCIE S1C FIFO FRZ1 FRZ0 PRS3 PRS2 PRS1 PRS0 CC CB CA 0 CC2 CC1 CC0 0 SRES8 0 DJM DSGN SCAN MULT ETORF FIFOR 0 SCF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 SC CCF15 CCF14 CCF13 CCF12 CCF11 CCF10 CCF9 CCF8 Device User Guide — 9S12E128DGV1/D V01.04 $0080 - $00AF Addres s Name $008B ATDSTAT1 $008C ATDDIEN0 $008D ATDDIEN1 $008E PORTAD0 $008F PORTAD1 $0090 ATDDR0H $0091 ATDDR0L $0092 ATDDR1H $0093 ATDDR1L $0094 ATDDR2H $0095 ATDDR2L ATD (Analog to Digital Converter 10 Bit 16 Channel) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Read CCF7 CCF6 CCF5 CCF4 CCF3 : Write : Read : IEN15 IEN14 IEN13 IEN12 IEN11 Write : Read : IEN7 IEN6 IEN5 IEN4 IEN3 Write : Read PTAD15 PTAD14 PTAD13 PTAD12 PTAD11 : Write : Read PTAD7 PTAD6 PTAD5 PTAD4 PTAD3 : Write : Read Bit15 14 13 12 11 : Write : Read Bit7 Bit6 0 0 0 : Write : Read Bit15 14 13 12 11 : Write : Read Bit7 Bit6 0 0 0 : Write : Read Bit15 14 13 12 11 : Write : Read Bit7 Bit6 0 0 0 : Write : Bit 2 Bit 1 Bit 0 CCF2 CCF1 CCF0 IEN10 IEN9 IEN8 IEN2 IEN1 IEN0 PTAD10 PTAD9 PTAD8 PTAD2 PTAD1 PTAD0 10 9 Bit8 0 0 0 10 9 Bit8 0 0 0 10 9 Bit8 0 0 0 39 Device User Guide — 9S12E128DGV1/D V01.04 $0080 - $00AF Addres s 40 ATD (Analog to Digital Converter 10 Bit 16 Channel) Name $0096 ATDDR3H $0097 ATDDR3L $0098 ATDDR4H $0099 ATDDR4L $009A ATDDR5H $009B ATDDR5L $009C ATDDR6H $009D ATDDR6L $009E ATDDR7H $009F ATDDR7L $00A0 ATDDR8H Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Device User Guide — 9S12E128DGV1/D V01.04 $0080 - $00AF Addres s Name $00A1 ATDDR8L $00A2 ATDDR9H $00A3 ATDDR9L $00A4 ATDDR10H $00A5 ATDDR10L $00A6 ATDDR11H $00A7 ATDDR11L $00A8 ATDDR12H $00A9 ATDDR12L $00AA ATDDR13H $00AB ATD (Analog to Digital Converter 10 Bit 16 Channel) ATDDR13L Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 41 Device User Guide — 9S12E128DGV1/D V01.04 $0080 - $00AF Addres s ATD (Analog to Digital Converter 10 Bit 16 Channel) Name Read : $00AC ATDDR14H Write : Read : $00AD ATDDR14L Write : Read : $00AE ATDDR15H Write : Read : $00AF ATDDR15L Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 Bit15 14 13 12 11 10 9 Bit8 Bit7 Bit6 0 0 0 0 0 0 0 0 0 NOTES: 1. WRAP0-3 bits are available in version V04 of ATD10B16C 2. ETRIGSEL and ETRIGCH0-3 bits are available in version V04 of ATD10B16C $00B0 - $00C7 $00B0 $00C7 Reserved $00C8 - $00CF Addres s 42 Name $00C8 SCIBDH $00C9 SCIBDL $00CA SCICR1 Reserved Read : Write : 0 0 0 0 0 SCI0 (Asynchronous Serial Interface) Bit 7 Bit 6 Bit 5 Read : IREN TNP1 TNP0 Write : Read : SBR7 SBR6 SBR5 Write : Read : SCISWA LOOPS RSRC I Write : Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SBR12 SBR11 SBR10 SBR9 SBR8 SBR4 SBR3 SBR2 SBR1 SBR0 M WAKE ILT PE PT Device User Guide — 9S12E128DGV1/D V01.04 $00C8 - $00CF Addres s SCI0 (Asynchronous Serial Interface) Name $00CB SCICR2 $00CC SCISR1 $00CD SCISR2 $00CE SCIDRH $00CF SCIDRL Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TIE TCIE RIE ILIE TE RE RWU SBK TDRE TC RDRF IDLE OR NF FE PF 0 0 0 R8 TXPOL1 RXPOL1 BRK13 RAF TXDIR 0 0 0 0 0 0 T8 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 NOTES: 1. TXPOL and RXPOL bits are available in version V04 of SCI $00D0 - $00D7 Addres s Name $00D0 SCIBDH $00D1 SCIBDL $00D2 SCICR1 $00D3 SCICR2 SCI1 (Asynchronous Serial Interface) Bit 7 Bit 6 Bit 5 Read : IREN TNP1 TNP0 Write : Read : SBR7 SBR6 SBR5 Write : Read : SCISWA LOOPS RSRC I Write : Read : TIE TCIE RIE Write : Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SBR12 SBR11 SBR10 SBR9 SBR8 SBR4 SBR3 SBR2 SBR1 SBR0 M WAKE ILT PE PT ILIE TE RE RWU SBK 43 Device User Guide — 9S12E128DGV1/D V01.04 $00D0 - $00D7 $00D4 SCISR1 $00D5 SCISR2 $00D6 SCIDRH $00D7 SCIDRL SCI1 (Asynchronous Serial Interface) Read : Write : Read : Write : Read : Write : Read : Write : TDRE TC RDRF 0 0 0 IDLE OR 1 NF 1 TXPOL RXPOL R8 FE PF RAF BRK13 TXDIR 0 0 0 0 0 0 T8 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 NOTES: 1. TXPOL and RXPOL are available in version V04 of SCI $00D8 - $00DF Addres s $00D8 44 SPI (Serial Peripheral Interface) Name SPICR1 $00D9 SPICR2 $00DA SPIBR $00DB SPISR $00DC Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SPIE SPE SPTIE MSTR CPOL CPHA SSOE LSBFE 0 0 0 SPISWAI SPC0 SPR2 SPR1 SPR0 MODFE BIDIRO N E 0 0 0 SPPR2 SPPR1 SPPR0 SPIF 0 SPTEF MODF 0 0 0 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $00D8 - $00DF Addres s SPI (Serial Peripheral Interface) Name $00DD SPIDR $00DE Reserved $00DF Reserved Read : Write : Read : Write : Read : Write : $00E0 - $00E7 Addres s IBAD $00E1 IBFD $00E2 IBCR $00E3 IBSR $00E4 IBDR Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit7 6 5 4 3 2 1 Bit0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 0 IIC (Inter-IC Bus) Name $00E0 Bit 7 Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 ADR7 ADR6 ADR5 ADR4 ADR3 ADR2 ADR1 IBC7 IBC6 IBC5 IBC4 IBC3 IBC2 IBC1 0 0 IBEN IBIE MS/SL Tx/Rx TXAK 0 IBC0 IBSWAI RSTA TCF IAAS IBB 0 SRW IBAL D7 D6 D5 D4 RXAK IBIF D3 D2 D1 D0 45 Device User Guide — 9S12E128DGV1/D V01.04 $00E0 - $00E7 Addres s Name $00E5 Reserved $00E6 Reserved $00E7 Reserved $00E8 - $00EF Addres s 46 IIC (Inter-IC Bus) Name $00E8 SCIBDH $00E9 SCIBDL $00EA SCICR1 $00EB SCICR2 $00EC SCISR1 Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 SCI2 (Asynchronous Serial Interface) Bit 7 Bit 6 Bit 5 Read : IREN TNP1 TNP0 Write : Read : SBR7 SBR6 SBR5 Write : Read : SCISWA LOOPS RSRC I Write : Read : TIE TCIE RIE Write : Read TDRE TC RDRF : Write : Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SBR12 SBR11 SBR10 SBR9 SBR8 SBR4 SBR3 SBR2 SBR1 SBR0 M WAKE ILT PE PT ILIE TE RE RWU SBK IDLE OR NF FE PF Device User Guide — 9S12E128DGV1/D V01.04 $00E8 - $00EF $00ED SCISR2 $00EE SCIDRH $00EF SCIDRL SCI2 (Asynchronous Serial Interface) Read : Write : Read : Write : Read : Write : 0 0 R8 0 TXPOL1 RXPOL1 BRK13 RAF TXDIR 0 0 0 0 0 0 T8 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 Bit 3 Bit 2 Bit 1 Bit 0 DJM DSGN DACWAI DACOE NOTES: 1. TXPOL and RXPOL are available in version V04 of SCI $00F0 - $00F3 Addres s DAC0 (Digital-to-Analog Converter) Name $00F0 DACC0 $00F1 DACC1 $00F2 DACD $00F3 DACD Bit 7 Read : Write : Read : Write : Read : Write : Read : Write : Bit 6 Bit 5 Bit 4 DACTE 0 0 DACE 0 0 0 0 0 0 0 0 BIT7 BIT6 BIT5 BIT4 BIT3 BIT2 BIT1 BIT0 BIT7 BIT6 BIT5 BIT4 BIT3 BIT2 BIT1 BIT0 47 Device User Guide — 9S12E128DGV1/D V01.04 $00F4 - $00F7 Addres s DAC1 (Digital-to-Analog Converter) Name $00F4 DACC0 $00F5 DACC1 $00F6 DACD $00F7 DACD Bit 7 Read : Write : Read : Write : Read : Write : Read : Write : $00F8 - $00FF $00F8 $00FF Reserved $0100 - $010F Addres s Name Bit 6 Bit 5 Bit 4 DACTE 0 0 DACE Bit 2 Bit 1 Bit 0 DJM DSGN DACWAI DACOE 0 0 0 0 0 0 0 0 BIT7 BIT6 BIT5 BIT4 BIT3 BIT2 BIT1 BIT0 BIT7 BIT6 BIT5 BIT4 BIT3 BIT2 BIT1 BIT0 0 0 0 0 0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FDIV5 FDIV4 FDIV3 FDIV2 FDIV1 FDIV0 NV5 NV4 NV3 NV2 SEC1 SEC0 0 0 0 0 0 0 Reserved Read : Write : 0 0 Flash Control Register Bit 7 Bit 6 Read FDIVLD : $0100 FCLKDIV PRDIV8 Write : Read KEYEN NV6 : 1 $0101 FSEC Write : Read 0 0 : Reserved for $0102 Factory Test Write : 48 Bit 3 Device User Guide — 9S12E128DGV1/D V01.04 $0100 - $010F Addres s Name $0103 FCNFG $0104 FPROT $0105 FSTAT $0106 FCMD $0107 Reserved for Factory Test $0108 Reserved for Factory Test $0109 Reserved for Factory Test $010A Reserved for Factory Test $010B Reserved for Factory Test $010C Reserved Flash Control Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Read 0 0 0 : KEYAC CBEIE CCIE C Write : Read : FPOPE NV6 FPHDIS FPHS1 FPHS0 FPLDIS N Write : Read CCIF 0 : ACCER CBEIF PVIOL BLANK R Write : Read 0 0 0 : CMDB6 CMDB5 CMDB2 Write : Read 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 : Write : Bit 1 Bit 0 0 0 FPLS1 FPLS0 0 0 0 CMDB0 0 0 0 0 0 0 0 0 0 0 0 0 49 Device User Guide — 9S12E128DGV1/D V01.04 $0100 - $010F Addres s Flash Control Register Name $010D Reserved $010E Reserved $010F Reserved Read : Write : Read : Write : Read : Write : $0110 - $013F $0110 $013F Reserved $0140 - $016F Addres s $0140 TIOS $0141 CFORC $0142 OC7M $0143 OC7D $0144 50 Name TCNT (hi) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 11 10 9 Bit 8 Reserved Read : Write : 0 TIM1 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Read : IOS7 IOS6 IOS5 IOS4 Write : Read 0 0 0 0 : Write FOC7 FOC6 FOC5 FOC4 : Read : OC7M7 OC7M6 OC7M5 OC7M4 Write : Read : OC7D7 OC7D6 OC7D5 OC7D4 Write : Read Bit 15 14 13 12 : Write : Device User Guide — 9S12E128DGV1/D V01.04 $0140 - $016F Addres s Name $0145 TCNT (lo) $0146 TSCR1 $0147 TTOV $0148 TCTL1 $0149 Reserved $014A TCTL3 $014B Reserved $014C TIE $014D TSCR2 $014E TFLG1 $014F TFLG2 TIM1 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Read Bit 7 6 5 4 3 2 1 Bit 0 : Write : Read 0 0 0 0 : TEN TSWAI TSFRZ TFFCA Write : Read 0 0 0 0 : TOV7 TOV6 TOV5 TOV4 Write : Read : OM7 OL7 OM6 OL6 OM5 OL5 OM4 OL4 Write : Read 0 0 0 0 0 0 0 0 : Write : Read : EDG7B EDG7A EDG6B EDG6A EDG5B EDG5A EDG4B EDG4A Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 : C7I C6I C5I C4I Write : Read 0 0 0 : TOI TCRE PR2 PR1 PR0 Write : Read 0 0 0 0 : C7F C6F C5F C4F Write : Read 0 0 0 0 0 0 0 : TOF Write : 51 Device User Guide — 9S12E128DGV1/D V01.04 $0140 - $016F Addres s 52 TIM1 (Timer 16 Bit 4 Channels) Name $0150 Reserved $0151 Reserved $0152 Reserved $0153 Reserved $0154 Reserved $0155 Reserved $0156 Reserved $0157 Reserved $0158 TC4 (hi) $0159 TC4 (lo) $015A TC5 (hi) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Device User Guide — 9S12E128DGV1/D V01.04 $0140 - $016F Addres s TIM1 (Timer 16 Bit 4 Channels) Name $015B TC5 (lo) $015C TC6 (hi) $015D TC6 (lo) $015E TC7 (hi) $015F TC7 (lo) $0160 PACTL $0161 PAFLG $0162 PACNT (hi) $0163 PACNT (lo) $0164 Reserved $0165 Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 PAEN PAMOD PEDGE CLK1 CLK0 PAOVI PAI 0 0 0 0 0 PAOVF PAIF 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 53 Device User Guide — 9S12E128DGV1/D V01.04 $0140 - $016F Addres s 54 TIM1 (Timer 16 Bit 4 Channels) Name $0166 Reserved $0167 Reserved $0168 Reserved $0169 Reserved $016A Reserved $016B Reserved $016C Reserved $016D Reserved $016E Reserved $016F Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0170 - $017F $0110 $013F Reserved $0180 - $01AF Addres s Name $0180 TIOS $0181 CFORC $0182 OC7M $0183 OC7D $0184 TCNT (hi) $0185 TCNT (lo) $0186 TSCR1 $0187 TTOV $0188 TCTL1 Reserved Read : Write : 0 0 0 0 0 0 0 0 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 11 10 9 Bit 8 3 2 1 Bit 0 0 0 0 0 0 0 0 0 OM5 OL5 OM4 OL4 TIM2 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Read : IOS7 IOS6 IOS5 IOS4 Write : Read 0 0 0 0 : Write FOC7 FOC6 FOC5 FOC4 : Read : OC7M7 OC7M6 OC7M5 OC7M4 Write : Read : OC7D7 OC7D6 OC7D5 OC7D4 Write : Read Bit 15 14 13 12 : Write : Read Bit 7 6 5 4 : Write : Read : TEN TSWAI TSFRZ TFFCA Write : Read : TOV7 TOV6 TOV5 TOV4 Write : Read : OM7 OL7 OM6 OL6 Write : 55 Device User Guide — 9S12E128DGV1/D V01.04 $0180 - $01AF Addres s 56 Name $0189 Reserved $018A TCTL3 $018B Reserved $018C TIE $018D TSCR2 $018E TFLG1 $018F TFLG2 $0190 Reserved $0191 Reserved $0192 Reserved $0193 Reserved TIM2 (Timer 16 Bit 4 Channels) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Read 0 0 0 0 0 0 0 0 : Write : Read : EDG7B EDG7A EDG6B EDG6A EDG5B EDG5A EDG4B EDG4A Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 : C7I C6I C5I C4I Write : Read 0 0 0 : TOI TCRE PR2 PR1 PR0 Write : Read 0 0 0 0 : C7F C6F C5F C4F Write : Read 0 0 0 0 0 0 0 : TOF Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 0 0 : Write : Read 0 0 0 0 0 0 0 0 : Write : Device User Guide — 9S12E128DGV1/D V01.04 $0180 - $01AF Addres s TIM2 (Timer 16 Bit 4 Channels) Name $0194 Reserved $0195 Reserved $0196 Reserved $0197 Reserved $0198 TC4 (hi) $0199 TC4 (lo) $015A TC5 (hi) $019B TC5 (lo) $019C TC6 (hi) $019D TC6 (lo) $019E TC7 (hi) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 57 Device User Guide — 9S12E128DGV1/D V01.04 $0180 - $01AF Addres s 58 TIM2 (Timer 16 Bit 4 Channels) Name $019F TC7 (lo) $01A0 PACTL $01A1 PAFLG $01A2 PACNT (hi) $01A3 PACNT (lo) $01A4 Reserved $01A5 Reserved $01A6 Reserved $01A7 Reserved $01A8 Reserved $01A9 Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 PAEN PAMOD PEDGE CLK1 CLK0 PAOVI PAI 0 0 0 0 0 PAOVF PAIF 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0180 - $01AF Addres s TIM2 (Timer 16 Bit 4 Channels) Name $01AA Reserved $01AB Reserved $01AC Reserved $01AD Reserved $01AE Reserved $01AF Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : $01B0 - $01DF $01B0 $01DF Reserved Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Reserved Read : Write : 0 59 Device User Guide — 9S12E128DGV1/D V01.04 $01E0 - $01FF Addres s Name Read : $01E0 PWME Write : Read : $01E1 PWMPOL Write : Read : $01E2 PWMCLK Write : Read : $01E3 PWMPRCLK Write : Read : $01E4 PWMCAE Write : Read : $01E5 PWMCTL Write : Read : PWMTST $01E6 Test Only Write : Read : $01E7 PWMPRSC Write : Read : $01E8 PWMSCLA Write : Read : $01E9 PWMSCLB Write : Read : $01EA PWMSCNTA Write : 60 PWM (Pulse Width Modulator) Bit 7 Bit 6 0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PWME5 PWME4 PWME3 PWME2 PWME1 PWME0 0 0 0 PPOL5 PPOL4 PPOL3 PPOL2 PPOL1 PPOL0 PCLK5 PCLK4 PCLK3 PCLK2 PCLK1 PCLK0 PCKB1 PCKB0 PCKA2 PCKA1 PCKA0 CAE5 CAE4 CAE3 CAE2 CAE1 CAE0 0 0 PSWAI PFRZ 0 0 0 PCKB2 0 0 0 CON45 CON23 CON01 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $01E0 - $01FF Addres s Name Read : $01EB PWMSCNTB Write : Read : $01EC PWMCNT0 Write : Read : $01ED PWMCNT1 Write : Read : $01EE PWMCNT2 Write : Read : $01EF PWMCNT3 Write : Read : $01F0 PWMCNT4 Write : Read : $01F1 PWMCNT5 Write : Read : $01F2 PWMPER0 Write : Read : $01F3 PWMPER1 Write : Read : $01F4 PWMPER2 Write : Read : $01F5 PWMPER3 Write : PWM (Pulse Width Modulator) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 61 Device User Guide — 9S12E128DGV1/D V01.04 $01E0 - $01FF Addres s 62 Name $01F6 PWMPER4 $01F7 PWMPER5 $01F8 PWMDTY0 $01F9 PWMDTY1 $01FA PWMDTY2 $01FB PWMDTY3 $01FC PWMDTY4 $01FD PWMDTY5 $01FE PWMSDN $01FF Reserved PWM (Pulse Width Modulator) Bit 7 Bit 6 Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : Bit 7 6 Write : Read : PWMIF PWMIE Write : Read 0 0 : Write : Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 5 4 3 2 1 Bit 0 0 PWM5I N 0 PWMRSTR T PWMLV L 0 0 0 0 PWM5I NL 0 PWM5E NA 0 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s $0200 PMF (Pulse width Modulator with Fault protection) Name PMFCFG0 $0201 PMFCFG1 $0202 PMFCFG2 $0203 PMFCFG3 $0204 PMFFCTL $0205 PMFFPIN $0206 PMFFSTA $0207 PMFQSMP $0208 PMFDMPA $0209 PMFDMPB $020A PMFDMPC Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 WP MTG EDGEC EDGEB EDGEA INDEPC INDEPB INDEPA BOTNEGC TOPNEGC BOTNEGB TOPNEGB BOTNEGA TOPNEGA MSK5 MSK4 MSK3 MSK2 MSK1 MSK0 SWAPC SWAPB SWAPA FIE1 FMODE0 FIE0 0 ENHA 0 0 0 PMFWAI PMFFRZ FMODE3 FIE3 VLMODE FMODE2 FIE2 0 0 0 FPINE3 FPINE1 0 FFLAG3 QSMP3 0 FPINE2 0 0 FMODE1 0 FFLAG2 QSMP2 FPINE0 FFLAG1 QSMP1 FFLAG0 QSMP0 DMP13 DMP12 DMP11 DMP10 DMP03 DMP02 DMP01 DMP00 DMP33 DMP32 DMP31 DMP30 DMP23 DMP22 DMP21 DMP20 DMP53 DMP52 DMP51 DMP50 DMP43 DMP42 DMP41 DMP40 63 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s 64 PMF (Pulse width Modulator with Fault protection) Name $020B Reserved $020C PMFOUTC $020D PMFOUTB $020E PMFDTMS $020F PMFCCTL $0210 PMFVAL0 $0211 PMFVAL0 $0212 PMFVAL1 $0213 PMFVAL1 $0214 PMFVAL2 $0215 PMFVAL2 Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 OUTCTL OUTCTL OUTCTL OUTCTL OUTCTL OUTCTL 5 4 3 2 1 0 OUT5 OUT4 OUT3 OUT2 OUT1 OUT0 DT5 DT4 DT3 DT2 DT1 DT0 IPOLC IPOLB IPOLA 0 ISENS Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s PMF (Pulse width Modulator with Fault protection) Name $0216 PMFVAL3 $0217 PMFVAL3 $0218 PMFVAL4 $0219 PMFVAL4 $021A PMFVAL5 $021B PMFVAL5 $021C Reserved $021D Reserved $021E Reserved $021F Reserved $0220 PMFENCA Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 LDOKA PWMRIEA PWMENA 65 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s $0221 $0222 $0223 $0224 $0225 $0226 $0227 $0228 $0229 $022A $022B 66 Name Read : PMFFQCA Write : Read : PMFCNTA Write : Read : PMFCNTA Write : Read : PMFMODA Write : Read : PMFMODA Write : Read : PMFDTMA Write : Read : PMFDTMA Write : Read : PMFENCB Write : Read : PMFFQCB Write : Read : PMFCNTB Write : Read : PMFCNTB Write : PMF (Pulse width Modulator with Fault protection) Bit 7 Bit 6 Bit 5 Bit 4 LDFQA Bit 3 Bit 2 HALFA Bit 1 PRSCA Bit 0 PWMRFA 0 Bit 14 13 12 11 10 9 Bit 8 6 5 4 3 2 1 Bit 0 Bit 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 Bit 11 10 9 Bit 8 1 Bit 0 LDOKB PWMRIEB Bit 7 0 Bit 7 PWMENB 6 5 4 3 2 0 0 0 0 0 LDFQB HALFB PRSCB PWMRFB 0 Bit 7 Bit 14 13 12 11 10 9 Bit 8 6 5 4 3 2 1 Bit 0 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s PMF (Pulse width Modulator with Fault protection) Name $022C PMFMODB $022D PMFMODB $022E PMFDTMB $022F PMFDTMB $0230 PMFENCC $0231 PMFFQCC $0232 PMFCNTC $0233 PMFCNTC $0234 PMFMODC $0235 PMFMODC $0236 PMFDTMC Bit 7 Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 Bit 11 10 9 Bit 8 1 Bit 0 LDOKC PWMRIEC 0 Bit 7 PWMENC 6 5 4 3 2 0 0 0 0 0 LDFQC HALFC PRSCC PWMRFC 0 Bit 14 13 12 11 10 9 Bit 8 6 5 4 3 2 1 Bit 0 Bit 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 Bit 11 10 9 Bit 8 Bit 7 0 67 Device User Guide — 9S12E128DGV1/D V01.04 $0200 - $023F Addres s 68 PMF (Pulse width Modulator with Fault protection) Name $0237 PMFDTMC $0238 Reserved $0239 Reserved $023A Reserved $023B Reserved $023C Reserved $023D Reserved $023E Reserved $023F Reserved Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $0240 PTT $0241 PTIT $0242 DDRT $0243 RDRT $0244 PERT $0245 PPST $0246 Reserved $0247 Reserved $0248 PTS $0249 PTIS $024A DDRS $024B RDRS PIM (Port Interface Module) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : PTT7 PTT6 PTT5 PTT4 PTT3 PTT2 PTT1 PTT0 PTIT7 PTIT6 PTIT5 PTIT4 PTIT3 PTIT2 PTIT1 PTIT0 DDRT7 DDRT7 DDRT5 DDRT4 DDRT3 DDRT2 DDRT1 DDRT0 RDRT7 RDRT6 RDRT5 RDRT4 RDRT3 RDRT2 RDRT1 RDRT0 PERT7 PERT6 PERT5 PERT4 PERT3 PERT2 PERT1 PERT0 PPST7 PPST6 PPST5 PPST4 PPST3 PPST2 PPST1 PPST0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 PTS7 PTS6 PTS5 PTS4 PTS3 PTS2 PTS1 PTS0 PTIS7 PTIS6 PTIS5 PTIS4 PTIS3 PTIS2 PTIS1 PTIS0 DDRS7 DDRS6 DDRS5 DDRS4 DDRS3 DDRS2 DDRS1 DDRS0 RDRS7 RDRS6 RDRS5 RDRS4 RDRS3 RDRS2 RDRS1 RDRS0 69 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $024C PERS $024D PPSS $024E WOMS $024F Reserved $0250 PTM $0251 PTIM $0252 DDRM $0253 RDRM $0254 PERM $0255 PPSM $0256 WOMM $0257 70 Reserved PIM (Port Interface Module) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : PERS7 PERS6 PERS5 PERS4 PERS3 PERS2 PERS1 PERS0 PPSS7 PPSS6 PPSS5 PPSS4 PPSS3 PPSS2 PPSS1 PPSS0 WOMS7 WOMS6 WOMS5 WOMS4 WOMS3 WOMS2 WOMS1 WOMS0 0 0 0 0 0 0 0 0 PTM7 PTM6 PTM5 PTM4 PTM3 PTM1 PTM0 PTIM7 PTIM6 PTIM5 PTIM4 PTIM3 PTIM1 PTIM0 DDRM7 DDRM6 DDRM5 DDRM4 DDRM3 DDRM1 DDRM0 RDRM1 RDRM0 PERM1 PERM0 PPSM1 PPSM0 0 0 0 0 RDRM7 RDRM6 RDRM5 RDRM4 RDRM3 PERM7 PERM6 PERM5 PERM4 PERM3 0 0 PPSM7 PPSM6 PPSM5 PPSM4 PPSM3 0 0 0 0 0 0 0 0 WOMM7 WOMM6 WOMM5 WOMM4 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $0258 PTP $0259 PTIP $025A DDRP $025B RDRP $025C PERP $025D PPSP $025E Reserved $025F Reserved $0260 PTQ $0261 PTIQ $0262 DDRQ $0263 RDRQ PIM (Port Interface Module) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : 0 0 0 0 0 0 0 0 0 PTP5 PTP4 PTP3 PTP2 PTP1 PTP0 PTIP5 PTIP4 PTIP3 PTIP2 PTIP1 PTIP0 DDRP5 DDRP4 DDRP3 DDRP2 DDRP1 DDRP0 RDRP5 RDRP4 RDRP3 RDRP2 RDRP1 RDRP0 PERP5 PERP4 PERP3 PERP2 PERP1 PERP0 PPSP5 PPSP4 PPSP3 PPSP2 PPSP1 PPSP0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 PTQ6 PTQ5 PTQ4 PTQ3 PTQ2 PTQ1 PTQ0 PTIQ6 PTIQ5 PTIQ4 PTIQ3 PTIQ2 PTIQ1 PTIQ0 DDRQ6 DDRQ5 DDRQ4 DDRQ3 DDRQ2 DDRQ1 DDRQ0 RDRQ6 RDRQ5 RDRQ4 RDRQ3 RDRQ2 RDRQ1 RDRQ0 0 0 0 0 71 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $0264 $0265 PPSQ $0266 Reserved $0267 Reserved $0268 PTU $0269 PTIU $026A DDRU $026B RDRU $026C PERU $026D PPSU $026E MODRR $026F 72 PERQ Reserved PIM (Port Interface Module) Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : Read : Write : 0 PERQ6 PERQ5 PERQ4 PERQ3 PERQ2 PERQ1 PERQ0 PPSQ6 PPSQ5 PPSQ4 PPSQ3 PPSQ2 PPSQ1 PPSQ0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 PTU7 PTU6 PTU5 PTU4 PTU3 PTU2 PTU1 PTU0 PTIU7 PTIU6 PTIU5 PTIU4 PTIU3 PTIU2 PTIU1 PTIU0 DDRU7 DDRU6 DDRU5 DDRU4 DDRU3 DDRU2 DDRU1 DDRU0 RDRU7 RDRU6 RDRU5 RDRU4 RDRU3 RDRU2 RDRU1 RDRU0 PERU7 PERU6 PERU5 PERU4 PERU3 PERU2 PERU1 PERU0 PPSU7 PPSU6 PPSU5 PPSU4 PPSU3 PPSU2 PPSU1 PPSU0 0 0 0 0 0 MODRR3 MODRR2 MODRR1 MODRR0 0 0 0 0 0 0 0 0 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $0270 PTAD(H) $0271 PTAD(L) $0272 PTIAD(H) $0273 PTIAD(L) $0274 DDRAD(H) $0275 DDRAD(L) $0276 RDRAD(H) $0277 RDRAD(L) $0278 PERAD(H) $0279 PERAD(L) $027A PPSAD(H) $027B PPSAD(L) $027C PIEAD(H) PIM (Port Interface Module) Read : Write : Read : Write : Read : Write : Read : Write : Read: Write: PTAD15 PTAD14 PTAD13 PTAD12 PTAD11 PTAD10 PTAD9 PTAD8 PTAD7 PTAD6 PTAD5 PTAD4 PTAD3 PTAD2 PTAD1 PTAD0 PTIAD15 PTIAD14 PTIAD13 PTIAD12 PTIAD11 PTIAD10 PTIAD9 PTIAD8 PTIAD7 PTIAD6 PTIAD5 PTIAD4 PTIAD3 PTIAD2 PTIAD1 PTIAD0 DDRAD15 DDRAD14 DDRAD13 DDRAD12 DDRAD11 DDRAD10 DDRAD9 DDRAD8 Read : DDRAD7 DDRAD6 DDRAD5 DDRAD4 DDRAD3 DDRAD2 DDRAD1 DDRAD0 Write : Read : RDRAD15 RDRAD14 RDRAD13 RDRAD12 RDRAD11 RDRAD10 RDRAD9 RDRAD8 Write : Read : RDRAD7 RDRAD6 RDRAD5 RDRAD4 RDRAD3 RDRAD2 RDRAD1 RDRAD0 Write : Read : PERAD15 PERAD14 PERAD13 PERAD12 PERAD11 PERAD10 PERAD9 PERAD8 Write : Read : PERAD7 PERAD6 PERAD5 PERAD4 PERAD3 PERAD2 PERAD1 PERAD0 Write : Read: Write: PPSAD15 PPSAD14 PPSAD13 PPSAD12 PPSAD11 PPSAD10 PPSAD9 PPSAD8 Read : PPSAD7 PPSAD6 PPSAD5 PPSAD4 PPSAD3 PPSAD2 PPSAD1 PPSAD0 Write : Read : PIEAD15 PIEAD14 PIEAD13 PIEAD12 PIEAD11 PIEAD10 PIEAD9 PIEAD8 Write : 73 Device User Guide — 9S12E128DGV1/D V01.04 $0240 - $027F $027D PIEAD(L) $027E PIFAD(H) $027F PIFAD(L) PIM (Port Interface Module) Read : PIEAD7 PIEAD6 PIEAD5 PIEAD4 PIEAD3 PIEAD2 PIEAD1 Write : Read : PIFAD15 PIFAD14 PIFAD13 PIFAD12 PIFAD11 PIFAD10 PIFAD9 Write : Read : PIFAD7 PIFAD6 PIFAD5 PIFAD4 PIFAD3 PIFAD2 PIFAD1 Write : $0280 - $03FF Addres s PIEAD0 PIFAD8 PIFAD0 Reserved space Name Read : Reserved Write : Read $0300 : Unimplement ed Write $03FF : $0280 - $2FF Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1.7 Part ID Assignments The part ID is located in two 8-bit registers PARTIDH and PARTIDL (addresses $001A and $001B after reset. The read-only value is a unique part ID for each revision of the chip. Table 1-2 shows the assigned part ID numbers. Table 1-2 Assigned Part ID Numbers Device Mask Set Number Part ID1 MC9S12E256 TBD $5000 MC9S12E128 2L15P $5102 MC9S12E64 2L15P $5200 MC9S12E32 TBD $5300 NOTES: 1. The coding is as follows: Bit 15-12: Major family identifier Bit 11-8: Minor family identifier Bit 7-4: Major mask set revision number including FAB transfers Bit 3-0: Minor - non full - mask set revision 74 Device User Guide — 9S12E128DGV1/D V01.04 The device memory sizes are located in two 8-bit registers MEMSIZ0 and MEMSIZ1 (addresses $001C and $001D after reset). Table 1-3 shows the read-only values of these registers. Refer to HCS12 Module Mapping Control (MMC) Block Guide for further details. Table 1-3 Memory size registers Device Register name Value MC9S12E32 MEMSIZ0 $00 MC9S12E32 MEMSIZ1 $80 MC9S12E64 MEMSIZ0 $03 MC9S12E64 MEMSIZ1 $80 MC9S12E128 MEMSIZ0 $03 MC9S12E128 MEMSIZ1 $80 MC9S12E256 MEMSIZ0 $07 MC9S12E256 MEMSIZ1 $81 75 Device User Guide — 9S12E128DGV1/D V01.04 Section 2 Signal Description MC9S12E-Family 112LQFP 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 VRH VDDA PAD07/AN07/KWAD07 PAD06/AN06/KWAD06 PAD05/AN05/KWAD05 PAD04/AN04/KWAD04 PAD03/AN03/KWAD03 PAD02/AN02/KWAD02 PAD01/AN01/KWAD01 PAD00/AN00/KWAD00 PA7/ADDR15/DATA15 PA6/ADDR14/DATA14 PA5/ADDR13/DATA13 PA4/ADDR12/DATA12 VSS2 VDD2 PA3/ADDR11/DATA11 PA2/ADDR10/DATA10 PA1/ADDR9/DATA9 PA0/ADDR8/DATA8 PS7/SS PS6/SCK PS5/MOSI PS4/MISO PS3/TXD1 PS2/RXD1 PS1/TXD0 PS0/RXD0 IOC15/PT5 IOC16/PT6 IOC17/PT7 PW10/IOC24/PU0 PW11/IOC25/PU1 PW14/PU4 PW15/PU5 XCLKS/NOACC/PE7 MODB/IPIPE1/PE6 MODA/IPIPE0/PE5 ECLK/PE4 VSSR VDDR RESET VDDPLL XFC VSSPLL EXTAL XTAL TEST PU6 PU7 PW12/IOC26/PU2 PW13/IOC27PU3 LSTRB/TAGLO/PE3 R/W/PE2 IRQ/PE1 XIRQ/PE0 PM3 RXD2/PM4 TXD2/PM5 SDA/PM6 SCL/PM7 FAULT0/PQ0 FAULT1/PQ1 FAULT2/PQ2 FAULT3/PQ3 ADDR0/DATA0/PB0 ADDR1/DATA1/PB1 ADDR2/DATA2/PB2 ADDR3/DATA3/PB3 VDDX VSSX ADDR4/DATA4/PB4 ADDR5/DATA5/PB5 ADDR6/DATA6/PB6 ADDR7/DATA7/PB7 IS0/PQ4 IS1/PQ5 IS2/PQ6 MODC/TAGHI/BKGD IOC04/PT0 IOC05/PT1 IOC06/PT2 IOC07/PT3 IOC14/PT4 112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 PP0/PW00 PP1/PW01 PP2/PW02 PP3/PW03 PP4/PW04 PP5/PW05 PK7/ECS/ROMCTL PK6/XCS PK5/XADDR19 PK4/XADDR18 VDD1 VSS1 PK3/XADDR17 PK2/XADDR16 PK1/XADDR15 PK0/XADDR14 PM1/DA1 PM0/DA0 PAD15/AN15/KWAD15 PAD14/AN14/KWAD14 PAD13/AN13/KWAD13 PAD12/AN12/KWAD12 PAD11/AN11/KWAD11 PAD10/AN10/KWAD10 PAD09/AN09/KWAD09 PAD08/AN08/KWAD08 VSSA VRL 2.1 Device Pinout Signals shown in Bold are not available on the 80 Pin Package Figure 2-1 Pin assignments 112 LQFP for MC9S12E-Family 76 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 MC9S12E-Family 80 QFP 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 VRH VDDA PAD07/AN07/KWAD07 PAD06/AN06/KWAD06 PAD05/AN05/KWAD05 PAD04/AN04/KWAD04 PAD03/AN03/KWAD03 PAD02/AN02/KWAD02 PAD01/AN01/KWAD01 PAD00/AN00/KWAD00 VSS2 VDD2 PS7/SS PS6/SCK PS5/MOSI PS4/MISO PS3/TXD1 PS2/RXD1 PS1/TXD0 PS0/RXD0 IOC15/PT5 IOC16/PT6 IOC17/PT7 PW10/IOC24/PU0 PW11/IOC25/PU1 XCLKS/NOACC/PE7 ECLK/PE4 VSSR VDDR RESET VDDPLL XFC VSSPLL EXTAL XTAL TEST PW12/IOC26/PU2 PW13/IOC27/PU3 IRQ/PE1 XIRQ/PE0 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 PM3 RXD2/PM4 TXD2/PM5 SDA/PM6 SCL/PM7 FAULT0/PQ0 FAULT1/PQ1 FAULT2/PQ2 FAULT3/PQ3 VDDX VSSX IS0/PQ4 IS1/PQ5 IS2/PQ6 MODC/TAGHI/BKGD IOC04/PT0 IOC05/PT1 IOC06/PT2 IOC07/PT3 IOC14/PT4 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 PP0/PW00 PP1/PW01 PP2/PW02 PP3/PW03 PP4/PW04 PP5/PW05 VDD1 VSS1 PM1/DA1 PM0/DA0 PAD15/AN15/KWAD15 PAD14/AN14/KWAD14 PAD13/AN13/KWAD13 PAD12/AN12/KWAD12 PAD11/AN11/KWAD11 PAD10/AN10/KWAD10 PAD09/AN09/KWAD09 PAD08/AN08/KWAD08 VSSA VRL Device User Guide — 9S12E128DGV1/D V01.04 Figure 2-2 Pin assignments in 80 QFP for MC9S12E-Family 77 Device User Guide — 9S12E128DGV1/D V01.04 2.2 Signal Properties Summary Table 2-1 Signal Properties Pin Name Power Function 3 Domain Internal Pull Resistor Pin Name Function 1 Pin Name Function 2 EXTAL — — VDDPLL NA NA XTAL — — VDDPLL NA NA XFC — — VDDPLL NA NA CTRL Description Reset State Oscillator pins PLL loop filter pin RESET — — VDDX None None BKGD MODC TAGHI VDDX Up Up Background debug, mode pin, tag signal high TEST VPP — NA NA NA Test pin only Disabled Port AD I/O Pins, ATD inputs, keypad Wake-up External reset pin PAD[15:0] AN[15:0] KWAD[15:0} VDDX PERAD/ PPSAD PA[7:0] ADDR[15:8]/ DATA[15:8] — VDDX PUCR Disabled Port A I/O pin, multiplexed address/data PB[7:0] ADDR[7:0]/ DATA[7:0] — VDDX PUCR Disabled Port B I/O pin, multiplexed address/data PE7 NOACC XCLKS VDDX Input Input Port E I/O pin, access, clock select PE6 IPIPE1 MODB VDDX While RESET is low: Down PE5 IPIPE0 MODA VDDX While RESET is low: Down PE4 ECLK — VDDX PUCR PE3 LSTRB TAGLO VDDX PUCR Mode Dep(1) Port E I/O pin, low strobe, tag signal low PE2 R/W — VDDX PUCR Mode Dep(1) Port E I/O pin, R/W in expanded modes PE1 IRQ — VDDX PUCR PE0 XIRQ — VDDX PK[7] ECS ROMCTL VDDX Mode Dep1 Port E I/O pin, pipe status, mode selection Port E I/O pin, pipe status, mode selection Port E I/O pin, bus clock output Up Port E input, external interrupt pin PUCR Up Port E input, non-maskable interrupt pin PUCR Up Port K I/O Pin, Emulation Chip Select PK[6] XCS — VDDX PUCR Up Port K I/O Pin, External Chip Select PK[5:0] XADDR[19:14] — VDDX PUCR Up Port K I/O Pins, Extended Addresses PM7 SCL — VDDX PERM/ PPSM Up Port M I/O Pin, IIC SCL signal PM6 SDA — VDDX PERM/ PPSM Up Port M I/O Pin, IIC SDA signal PM5 TXD2 — VDDX PERM/ PPSM Up Port M I/O Pin, SCI2 transmit signal PM4 RXD2 — VDDX PERM/ PPSM Up Port M I/O Pin, SCI2 receive signal PM3 — — VDDX PERM/ PPSM Disabled Port M I/O Pin, IIC SDA signal PM1 DAO1 — VDDX PERM/ PPSM Disabled Port M I/O Pin, DAC1 output PM0 DAO0 — VDDX PERM/ PPSM Disabled Port M I/O Pin, DAC0 output PP[5:0] PW0[5:0] — VDDX PERP/ PPSP Disabled Port P I/O Pins, PWM output 78 Device User Guide — 9S12E128DGV1/D V01.04 Pin Name Function 1 Pin Name Function 2 Pin Name Power Function 3 Domain PQ[6:4] IS[6:4] — PQ[3:0] FAULT[3:0] PS7 Internal Pull Resistor Description CTRL Reset State VDDX PERQ/ PPSQ Disabled Port Q I/O Pins, IS[6:4] input — VDDX PERQ/ PPSQ Disabled Port Q I/O Pins, Fault[3:0] input SS — VDDX PERS/ PPSS Up Port S I/O Pin, SPI SS signal PS6 SCK — VDDX PERS/ PPSS Up Port S I/O Pin, SPI SCK signal PS5 MOSI — VDDX PERS/ PPSS Up Port S I/O Pin, SPI MOSI signal PS4 MISO — VDDX PERS/ PPSS Up Port S I/O Pin, SPI MISO signal PS3 TXD1 — VDDX PERS/ PPSS Up Port S I/O Pin, SCI1 transmit signal PS2 RXD1 — VDDX PERS/ PPSS Up Port S I/O Pin, SCI1 receive signal PS1 TXD0 — VDDX PERS/ PPSS Up Port S I/O Pin, SCI0 transmit signal PS0 RXD0 — VDDX PERS/ PPSS Up Port S I/O Pin, SCI0 receive signal PT[7:4] IOC1[7:4] — VDDX PERT/ PPST Disabled Port T I/O Pins, timer (TIM1) PT[3:0] IOC0[7:4] — VDDX PERT/ PPST Disabled Port T I/O Pins, timer (TIM0) PU[7:6] — — VDDX PERU/ PPSU Disabled Port U I/O Pins PU[5:4] PW1[5:4] — VDDX PERU/ PPSU Disabled Port U I/O Pins, PWM outputs PU[3:0] IOC2[7:4] PW1[3:0] VDDX PERU/ PPSU Disabled Port U I/O Pins, timer (TIM2), PWM outputs NOTES: 1. The Port E output buffer enable signal control at reset is determined by the PEAR register and is mode dependent. For example, in special test mode RDWE = LSTRE = 1 which enables the PE[3:2] output buffers and disables the pull-ups. Refer to the S12 MEBI Block Guide for PEAR register details. NOTE: Signals shown in bold are not available in the 80 pin package. NOTE: If the port pins are not bonded out in the chosen package the user should initialize the registers to be inputs with enabled pull resistance to avoid excess current consumption. This applies to the following pins: (80QFP): Port A[7:0], Port B[7:0], Port E[6,5,3,2], Port K[7:0], Port U[7:4] 79 Device User Guide — 9S12E128DGV1/D V01.04 2.3 Detailed Signal Descriptions 2.3.1 EXTAL, XTAL — Oscillator Pins EXTAL and XTAL are the external clock and crystal driver pins. On reset all the device clocks are derived from the EXTAL input frequency. XTAL is the crystal output. 2.3.2 RESET — External Reset Pin RESET is an active low bidirectional control signal that acts as an input to initialize the MCU to a known start-up state. It also acts as an open-drain output to indicate that an internal failure has been detected in either the clock monitor or COP watchdog circuit. External circuitry connected to the RESET pin should not include a large capacitance that would interfere with the ability of this signal to rise to a valid logic one within 32 ECLK cycles after the low drive is released. Upon detection of any reset, an internal circuit drives the RESET pin low and a clocked reset sequence controls when the MCU can begin normal processing The RESET pin includes an internal pull up device. 2.3.3 TEST — Test Pin The TEST pin is reserved for test and must be tied to VSS in all applications. 2.3.4 XFC — PLL Loop Filter Pin Dedicated pin used to create the PLL loop filter. See appendix B.4.3.1and the CRG Block Guide for more detailed information. 2.3.5 BKGD / TAGHI / MODC — Background Debug, Tag High & Mode Pin The BKGD / TAGHI / MODC pin is used as a pseudo-open-drain pin for the background debug communication. It is used as a MCU operating mode select pin during reset. The state of this pin is latched to the MODC bit at the rising edge of RESET. In MCU expanded modes of operation, when instruction tagging is on, an input low on this pin during the falling edge of E-clock tags the high half of the instruction word being read into the instruction queue. This pin always has an internal pull up. 2.3.6 PA[7:0] / ADDR[15:8] / DATA[15:8] — Port A I/O Pins PA[7:0] are general purpose input or output pins. In MCU expanded modes of operation, these pins are used for the multiplexed external address and data bus. PA[7:0] pins are not available in the 80 pin package version. 2.3.7 PB[7:0] / ADDR[7:0] / DATA[7:0] — Port B I/O Pins PB[7:0] are general purpose input or output pins. In MCU expanded modes of operation, these pins are used for the multiplexed external address and data bus. PB[7:0] pins are not available in the 80 pin package version. 80 Device User Guide — 9S12E128DGV1/D V01.04 2.3.8 PE7 / NOACC / XCLKS — Port E I/O Pin 7 PE7 is a general purpose input or output pin. During MCU expanded modes of operation, the NOACC signal, when enabled, is used to indicate that the current bus cycle is an unused or “free cycle”. This signal will assert when the CPU is not using the bus. The XCLKS is an input signal which controls whether a crystal in combination with the internal Colpitts (low power) oscillator is used or whether Pierce oscillator/external clock circuitry is used. The state of this pin is latched at the rising edge of RESET. If the input is a logic low the EXTAL pin is configured for an external clock drive or a Pierce Oscillator. If the input is a logic high a Colpitts oscillator circuit is configured on EXTAL and XTAL. Since this pin is an input with a pull-up device during reset, if the pin is left floating, the default configuration is a Colpitts oscillator circuit on EXTAL and XTAL. 81 Device User Guide — 9S12E128DGV1/D V01.04 Figure 2-3 Colpitts Oscillator Connections (PE7=1) EXTAL CDC * MCU C1 Crystal or ceramic resonator XTAL C2 VSSPLL * Due to the nature of a translated ground Colpitts oscillator a DC voltage bias is applied to the crystal .Please contact the crystal manufacturer for crystal DC Figure 2-4 Pierce Oscillator Connections (PE7=0) EXTAL C1 MCU XTAL RB RS* Crystal or ceramic resonator C2 VSSPLL * Rs can be zero (shorted) when use with higher frequency crystals. Refer to manufacturer’s data. 2.3.9 PE6 / MODB / IPIPE1 — Port E I/O Pin 6 PE6 is a general purpose input or output pin. It is used as a MCU operating mode select pin during reset. The state of this pin is latched to the MODB bit at the rising edge of RESET. This pin is shared with the 82 Device User Guide — 9S12E128DGV1/D V01.04 instruction queue tracking signal IPIPE1. This pin is an input with a pull-down device which is only active when RESET is low. PE6 is not available in the 80 pin package version. 2.3.10 PE5 / MODA / IPIPE0 — Port E I/O Pin 5 PE5 is a general purpose input or output pin. It is used as a MCU operating mode select pin during reset. The state of this pin is latched to the MODA bit at the rising edge of RESET. This pin is shared with the instruction queue tracking signal IPIPE0. This pin is an input with a pull-down device which is only active when RESET is low. PE5 is not available in the 80 pin package version. 2.3.11 PE4 / ECLK— Port E I/O Pin 4 / E-Clock Output PE4 is a general purpose input or output pin. In Normal Single Chip mode PE4 is configured with an active pull-up while in reset and immediately out of reset. The pullup can be turned off by clearing PUPEE in the PUCR register. In all modes except Normal Single Chip Mode, the PE4 pin is initially configured as the output connection for the internal bus clock(ECLK). ECLK is used as a timing reference and to demultiplex the address and data in expanded modes. The ECLK frequency is equal to 1/2 the crystal frequency out of reset. The ECLK output function depends upon the settings of the NECLK bit in the PEAR register, the IVIS bit in the MODE register and the ESTR bit in the EBICTL register. All clocks, including the ECLK, are halted when the MCU is in STOP mode. It is possible to configure the MCU to interface to slow external memory. ECLK can be stretched for such accesses. The PE4 pin is initially configured as ECLK output with stretch in all expanded modes. Reference the MISC register (EXSTR[1:0] bits) for more information. In normal expanded narrow mode, the ECLK is available for use in external select decode logic or as a constant speed clock for use in the external application system. 2.3.12 PE3 / LSTRB / TAGLO — Port E I/O Pin 3 / Low-Byte Strobe (LSTRB) PE3 can be used as a general-purpose I/O in all modes and is an input with an active pull-up out of reset. The pullup can be turned off by clearing PUPEE in the PUCR register. PE3 can also be configured as a Low-Byte Strobe (LSTRB). The LSTRB signal is used in write operations, so external low byte writes will not be possible until this function is enabled. LSTRB can be enabled by setting the LSTRE bit in the PEAR register. In Expanded Wide and Emulation Narrow modes, and when BDM tagging is enabled, the LSTRB function is multiplexed with the TAGLO function. When enabled a logic zero on the TAGLO pin at the falling edge of ECLK will tag the low byte of an instruction word being read into the instruction queue. PE3 is not available in the 80 pin package version. 2.3.13 PE2 / R/W — Port E I/O Pin 2 / Read/Write PE2 can be used as a general-purpose I/O in all modes and is configured an input with an active pull-up out of reset. The pullup can be turned off by clearing PUPEE in the PUCR register. If the read/write function is required it should be enabled by setting the RDWE bit in the PEAR register. External writes will not be possible until the read/write function is enabled. The PE2 pin is not available in the 80 pin package version. 83 Device User Guide — 9S12E128DGV1/D V01.04 2.3.14 PE1 / IRQ — Port E input Pin 1 / Maskable Interrupt Pin PE1 is always an input and can always be read. The PE1 pin is also the IRQ input used for requesting an asynchronous interrupt to the MCU. During reset, the I bit in the condition code register (CCR) is set and any IRQ interrupt is masked until software enables it by clearing the I bit. The IRQ is software programmable to either falling edge-sensitive triggering or level-sensitive triggering based on the setting of the IRQE bit in the IRQCR register. The IRQ is always enabled and configured to level-sensitive triggering out of reset. It can be disabled by clearing IRQEN bit in the IRQCR register. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPEE in the PUCR register. 2.3.15 PE0 / XIRQ — Port E input Pin 0 / Non Maskable Interrupt Pin PE0 is always an input and can always be read. The PE0 pin is also the XIRQ input for requesting a nonmaskable asynchronous interrupt to the MCU. During reset, the X bit in the condition code register (CCR) is set and any XIRQ interrupt is masked until MCU software enables it by clearing the X bit. Because the XIRQ input is level sensitive triggered, it can be connected to a multiple-source wired-OR network. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPEE in the PUCR register. 2.3.16 PK7 / ECS / ROMCTL — Port K I/O Pin 7 PK7 is a general purpose input or output pin. During MCU expanded modes of operation, when the EMK bit in the MODE register is set to 1, this pin is used as the emulation chip select output (ECS). In expanded modes the PK7 pin can be used to determine the reset state of the ROMON bit in the MISC register. At the rising edge of RESET, the state of the PK7 pin is latched to the ROMON bit. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPKE in the PUCR register. Refer to the HCS12 MEBI Block Guide for further details. PK7 is not available in the 80 pin package version. 2.3.17 PK6 / XCS — Port K I/O Pin 6 PK6 is a general purpose input or output pin. During MCU expanded modes of operation, when the EMK bit in the MODE register is set to 1, this pin is used as an external chip select signal for most external accesses that are not selected by ECS. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPKE in the PUCR register. Refer to the HCS12 MEBI Block Guide for further details. PK6 is not available in the 80 pin package version. 2.3.18 PK[5:0] / XADDR[19:14] — Port K I/O Pins [5:0] PK[5:0] are general purpose input or output pins. In MCU expanded modes of operation, when the EMK bit in the MODE register is set to 1, PK[5:0] provide the expanded address XADDR[19:14] for the external bus. There are active pull-ups on PK[5:0] pins while in reset and immediately out of reset. The pullup can be turned off by clearing PUPKE in the PUCR register. Refer to the HCS12 MEBI Block Guide for further details. PK[5:0] are not available in the 80 pin package version. 84 Device User Guide — 9S12E128DGV1/D V01.04 2.3.19 PAD[15:0] / AN[15:0] / KWAD[15:0] — Port AD I/O Pins [15:0] PAD[15:0] are the analog inputs for the analog to digital converter (ADC). They can also be configured as general purpose digital input or output pin. When enabled as digital inputs or outputs, the PAD[15:0] can also be configured as Keypad Wake-up pins (KWU) and generate interrupts causing the MCU to exit STOP or WAIT mode. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the ATD_10B16C Block Guide for information about pin configurations. 2.3.20 PM7 / SCL — Port M I/O Pin 7 PM7 is a general purpose input or output pin. When the IIC module is enabled it becomes the serial clock line (SCL) for the IIC module (IIC). While in reset and immediately out of reset the PM7 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the IIC Block Guide for information about pin configurations. 2.3.21 PM6 / SDA — Port M I/O Pin 6 PM6 is a general purpose input or output pin. When the IIC module is enabled it becomes the Serial Data Line (SDL) for the IIC module (IIC). While in reset and immediately out of reset the PM6 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the IIC Block Guide for information about pin configurations. 2.3.22 PM5 / TXD2 — Port M I/O Pin 5 PM5 is a general purpose input or output. When the Serial Communications Interface 2 (SCI2) transmitter is enabled the PM5 pin is configured as the transmit pin TXD2 of SCI2. While in reset and immediately out of reset the PM5 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 2.3.23 PM4 / RXD2 — Port M I/O Pin 4 PM4 is a general purpose input or output. When the Serial Communications Interface 2 (SCI2) receiver is enabled the PM4 pin is configured as the receive pin RXD2 of SCI2. While in reset and immediately out of reset the PM4 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 2.3.24 PM3 — Port M I/O Pin 3 PM3 is a general purpose input or output pin. While in reset and immediately out of reset the PM3 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide for information about pin configurations. 85 Device User Guide — 9S12E128DGV1/D V01.04 2.3.25 PM1 / DAO1 — Port M I/O Pin 1 PM1 is a general purpose input or output pin. When the Digital to Analog module 1 (DAC1) is enabled the PM1 pin is configured as the analog output DA01 of DAC1. While in reset and immediately out of reset the PM1 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the DAC_8B1C Block Guide for information about pin configurations. 2.3.26 PM0 / DAO2 — Port M I/O Pin 0 PM0 is a general purpose input or output pin. When the Digital to Analog module 2 (DAC2) is enabled the PM0 pin is configured as the analog output DA02 of DAC2. While in reset and immediately out of reset the PM0 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the DAC_8B1C Block Guide for information about pin configurations. 2.3.27 PP[5:0] / PW0[5:0] — Port P I/O Pins [5:0] PP[5:0] are general purpose input or output pins. When the Pulse width Modulator with Fault protection (PMF) is enabled the PP[5:0] output pins, as a whole or as pairs, can be configured as PW0[5:0] outputs. While in reset and immediately out of reset the PP[5:0] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the PMF_15B6C Block Guide for information about pin configurations. 2.3.28 PQ[6:4] / IS[2:0] — Port Q I/O Pins [6:4] PQ[6:4] are general purpose input or output pins. When enabled in the Pulse width Modulator with Fault protection module (PMF), the PQ[6:4] pins become the current status input pins, IS[2:0], for top/bottom pulse width correction. While in reset and immediately out of reset PP[5:0] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the PMF_15B6C Block Guide for information about pin configurations. 2.3.29 PQ[3:0] / FAULT[3:0] — Port Q I/O Pins [3:0] PQ[3:0] are general purpose input or output pins. When enabled in the Pulse width Modulator with Fault protection module (PMF), the PQ[3:0] pins become the Fault protection inputs pins, FAULT[3:0], of the PMF. While in reset and immediately out of reset the PQ[3:0] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the PMF_15B6C Block Guide for information about pin configurations. 2.3.30 PS7 / SS — Port S I/O Pin 7 PS7 is a general purpose input or output. When the Serial Peripheral Interface (SPI) is enabled PS7 becomes the slave select pin SS. While in reset and immediately out of reset the PS7 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SPI Block Guide for information about pin configurations. 86 Device User Guide — 9S12E128DGV1/D V01.04 2.3.31 PS6 / SCK — Port S I/O Pin 6 PS6 is a general purpose input or output pin. When the Serial Peripheral Interface (SPI) is enabled PS6 becomes the serial clock pin, SCK. While in reset and immediately out of reset the PS6 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SPI Block Guide for information about pin configurations. 2.3.32 PS5 / MOSI — Port S I/O Pin 5 PS5 is a general purpose input or output pin. When the Serial Peripheral Interface (SPI) is enabled PS5 is the master output (during master mode) or slave input (during slave mode) pin. While in reset and immediately out of reset the PS5 pin is configured as a high impedance input pin Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SPI Block Guide for information about pin configurations. 2.3.33 PS4 / MISO — Port S I/O Pin 4 PS4 is a general purpose input or output pin. When the Serial Peripheral Interface (SPI) is enabled PS4 is the master input (during master mode) or slave output (during slave mode) pin. While in reset and immediately out of reset the PS4 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SPI Block Guide for information about pin configurations. 2.3.34 PS3 / TXD1 — Port S I/O Pin 3 PS3 is a general purpose input or output. When the Serial Communications Interface 1 (SCI1) transmitter is enabled the PS3 pin is configured as the transmit pin, TXD1, of SCI1. While in reset and immediately out of reset the PS3 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 2.3.35 PS2 / RXD1 — Port S I/O Pin 2 PS2 is a general purpose input or output. When the Serial Communications Interface 1 (SCI1) receiver is enabled the PS2 pin is configured as the receive pin RXD1 of SCI1. While in reset and immediately out of reset the PS2 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 2.3.36 PS1 / TXD0 — Port S I/O Pin 1 PS1 is a general purpose input or output. When the Serial Communications Interface 0 (SCI0) transmitter is enabled the PS1 pin is configured as the transmit pin, TXD0, of SCI0. While in reset and immediately out of reset the PS1 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 87 Device User Guide — 9S12E128DGV1/D V01.04 2.3.37 PS0 / RXD0 — Port S I/O Pin 0 PS0 is a general purpose input or output. When the Serial Communications Interface 0 (SCI0) receiver is enabled the PS0 pin is configured as the receive pin RXD0 of SCI0. While in reset and immediately out of reset the PS0 pin is configured as a high impedance input pin. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the SCI Block Guide for information about pin configurations. 2.3.38 PT[7:4] / IOC1[7:4]— Port T I/O Pins [7:4] PT[7:4] are general purpose input or output pins. When the Timer system 1 (TIM1) is enabled they can also be configured as the TIM1 input capture or output compare pins IOC1[7-4]. While in reset and immediately out of reset the PT[7:4] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the TIM_16B4C Block Guide for information about pin configurations. 2.3.39 PT[3:0] / IOC0[7:4]— Port T I/O Pins [3:0] PT[3:0] are general purpose input or output pins. When the Timer system 0 (TIM0) is enabled they can also be configured as the TIM0 input capture or output compare pins IOC0[7-4]. While in reset and immediately out of reset the PT[3:0] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the TIM_16B4C Block Guide for information about pin configurations. 2.3.40 PU[7:6] — Port U I/O Pins [7:6] PU[7:6] are general purpose input or output pins. While in reset and immediately out of reset the PU[7:6] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 for information about pin configurations. PU[7:6] are not available in the 80 pin package version. 2.3.41 PU[5:4] / PW1[5:4] — Port U I/O Pins [5:4] PU[5:4] are general purpose input or output pins. When the Pulse Width Modulator (PWM) is enabled the PU[5:4] output pins, individually or as a pair, can be configured as PW1[5:4] outputs. While in reset and immediately out of reset the PU[5:4] pins are configured as a high impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide and the PWM_8B6C Block Guide for information about pin configurations. PU[5:4] are not available in the 80 pin package version. 2.3.42 PU[3:0] / IOC2[7:4]/PW1[3:0] — Port U I/O Pins [3:0] PU[3:0] are general purpose input or output pins. When the Timer system 2 (TIM2) is enabled they can also be configured as the TIM2 input capture or output compare pins IOC2[7-4]. When the Pulse Width Modulator (PWM) is enabled the PU[3:0] output pins, individually or as a pair, can be configured as PW1[3:0] outputs. The MODRR register in the Port Integration Module determines if the TIM2 or PWM function is selected. While in reset and immediately out of reset the PU[3:0] pins are configured as a high 88 Device User Guide — 9S12E128DGV1/D V01.04 impedance input pins. Consult the Port Integration Module (PIM) PIM_9E128 Block Guide, TIM_16B4C Block Guide, and the PWM_8B6C Block Guide for information about pin configurations. 2.4 Power Supply Pins 2.4.1 VDDX,VSSX — Power & Ground Pins for I/O Drivers External power and ground for I/O drivers. Bypass requirements depend on how heavily the MCU pins are loaded. 2.4.2 VDDR, VSSR — Power Supply Pins for I/O Drivers & for Internal Voltage Regulator External power and ground for I/O drivers and input to the internal voltage regulator. Bypass requirements depend on how heavily the MCU pins are loaded. 2.4.3 VDD1, VDD2, VSS1, VSS2 — Power Supply Pins for Internal Logic Power is supplied to the MCU through VDD and VSS. This 2.5V supply is derived from the internal voltage regulator. There is no static load on those pins allowed. The internal voltage regulator is turned off, if VDDR is tied to ground. 2.4.4 VDDA, VSSA — Power Supply Pins for ATD and VREG VDDA, VSSA are the power supply and ground input pins for the voltage regulator and the analog to digital converter. 2.4.5 VRH, VRL — ATD Reference Voltage Input Pins VRH and VRL are the reference voltage input pins for the analog to digital converter. 2.4.6 VDDPLL, VSSPLL — Power Supply Pins for PLL Provides operating voltage and ground for the Oscillator and the Phased-Locked Loop. This allows the supply voltage to the Oscillator and PLL to be bypassed independently.This 2.5V voltage is generated by the internal voltage regulator. 89 Device User Guide — 9S12E128DGV1/D V01.04 Table 2-2 MC9S12E-Family Power and Ground Connection Summary NOTE: 90 Mnemonic Nominal Voltage VDD1 VDD2 2.5 V VSS1 VSS2 0V VDDR 3.3/5.0 V VSSR 0V VDDX 3.3/5.0 V VSSX 0V VDDA 3.3/5.0 V VSSA 0V VRH 3.3/5.0 V VRL 0V VDDPLL 2.5 V VSSPLL 0V Description Internal power and ground generated by internal regulator. These also allow an external source to supply the core VDD/VSS voltages and bypass the internal voltage regulator. External power and ground, supply to internal voltage regulator. To disable voltage regulator attach VDDR to VSSR. External power and ground, supply to pin drivers. Operating voltage and ground for the analog-to-digital converter, the reference for the internal voltage regulator and the digital-to-analog converters, allows the supply voltage to the A/D to be bypassed independently. Reference voltage high for the ATD converter, and DAC. Reference voltage low for the ATD converter. Provides operating voltage and ground for the Phased-Locked Loop. This allows the supply voltage to the PLL to be bypassed independently. Internal power and ground generated by internal regulator. All VSS pins must be connected together in the application. Because fast signal transitions place high, short-duration current demands on the power supply, use bypass capacitors with high-frequency characteristics and place them as close to the MCU as possible. Bypass requirements depend on MCU pin load. Device User Guide — 9S12E128DGV1/D V01.04 Section 3 System Clock Description The Clock and Reset Generator provides the internal clock signals for the core and all peripheral modules. Figure 3-1 shows the clock connections from the CRG to all modules. Consult the CRG Block Guide for details on clock generation. HCS12 CORE Core Clock BDM CPU MEBI MMC INT DBG Flash RAM ATD DAC IIC EXTAL PIM OSC CRG PMF Bus Clock PWM Oscillator Clock XTAL SCI0, SCI1, SCI2 SPI TIM0, TIM1, TIM2 VREG Figure 3-1 Clock Connections Table 3-1Clock Selection Based on PE7 PE7 = XCLKS Description 1 Colpitts Oscillator selected 0 Pierce Oscillator/external clock selected 91 Device User Guide — 9S12E128DGV1/D V01.04 Section 4 Modes of Operation 4.1 Overview Eight possible modes determine the operating configuration of the MC9S12E-Family. Each mode has an associated default memory map and external bus configuration controlled by a further pin. Three low power modes exist for the device. 4.2 Chip Configuration Summary The operating mode out of reset is determined by the states of the MODC, MODB, and MODA pins during reset. The MODC, MODB, and MODA bits in the MODE register show the current operating mode and provide limited mode switching during operation. The states of the MODC, MODB, and MODA pins are latched into these bits on the rising edge of the reset signal. The ROMCTL signal allows the setting of the ROMON bit in the MISC register thus controlling whether the internal Flash is visible in the memory map. ROMON = 1 mean the Flash is visible in the memory map. The state of the ROMCTL pin is latched into the ROMON bit in the MISC register on the rising edge of the reset signal. Table 4-1 Mode Selection BKGD = MODC PE6 = MODB PE5 = MODA PK7 = ROMCTL ROMON Bit 0 0 0 X 1 0 0 1 0 1 1 0 0 1 0 X 0 0 1 1 0 X 1 0 0 1 1 X 1 0 0 1 1 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 Mode Description Special Single Chip, BDM allowed and ACTIVE. BDM is allowed in all other modes but a serial command is required to make BDM active. Emulation Expanded Narrow, BDM allowed Special Test (Expanded Wide), BDM allowed Emulation Expanded Wide, BDM allowed Normal Single Chip, BDM allowed Normal Expanded Narrow, BDM allowed Peripheral; BDM allowed but bus operations would cause bus conflicts (must not be used) Normal Expanded Wide, BDM allowed For further explanation on the modes refer to the HCS12 MEBI Block Guide. Table 4-2 Clock Selection Based on PE7 PE7 = XCLKS 92 Description 1 Colpitts Oscillator selected 0 Pierce Oscillator/external clock selected Device User Guide — 9S12E128DGV1/D V01.04 4.3 Security The device will make available a security feature preventing the unauthorized read and write of the memory contents. This feature allows: • Protection of the contents of FLASH, • Operation in single-chip mode, • Operation from external memory with internal FLASH disabled. The user must be reminded that part of the security must lie with the user’s code. An extreme example would be user’s code that dumps the contents of the internal program. This code would defeat the purpose of security. At the same time the user may also wish to put a back door in the user’s program. An example of this is the user downloads a key through the SCI which allows access to a programming routine that updates parameters. 4.3.1 Securing the Microcontroller Once the user has programmed the FLASH, the part can be secured by programming the security bits located in the FLASH module. These non-volatile bits will keep the part secured through resetting the part and through powering down the part. The security byte resides in a portion of the Flash array. Check the Flash Block Guide for more details on the security configuration. 4.3.2 Operation of the Secured Microcontroller 4.3.2.1 Normal Single Chip Mode This will be the most common usage of the secured part. Everything will appear the same as if the part was not secured with the exception of BDM operation. The BDM operation will be blocked. 4.3.2.2 Executing from External Memory The user may wish to execute from external space with a secured microcontroller. This is accomplished by resetting directly into expanded mode. The internal FLASH will be disabled. BDM operations will be blocked. 4.3.3 Unsecuring the Microcontroller In order to unsecure the microcontroller, the internal FLASH must be erased. This can be done through an external program in expanded mode. Once the user has erased the FLASH, the part can be reset into special single chip mode. This invokes a program that verifies the erasure of the internal FLASH. Once this program completes, the user can erase and program the FLASH security bits to the unsecured state. This is generally done through the BDM, but the user could also change to expanded mode (by writing the mode bits through the BDM) and jumping to 93 Device User Guide — 9S12E128DGV1/D V01.04 an external program (again through BDM commands). Note that if the part goes through a reset before the security bits are reprogrammed to the unsecure state, the part will be secured again. 4.4 Low Power Modes The microcontroller features three main low power modes. Consult the respective Block Guide for information on the module behavior in Stop, Pseudo Stop, and Wait Mode. An important source of information about the clock system is the Clock and Reset Generator (CRG) Block Guide. 4.4.1 Stop Executing the CPU STOP instruction stops all clocks and the oscillator thus putting the chip in fully static mode. Wake up from this mode can be done via reset or external interrupts. 4.4.2 Pseudo Stop This mode is entered by executing the CPU STOP instruction. In this mode the oscillator is still running and the Real Time Interrupt (RTI) or Watchdog (COP) sub module can stay active. Other peripherals are turned off. This mode consumes more current than the full STOP mode, but the wake up time from this mode is significantly shorter. 4.4.3 Wait This mode is entered by executing the CPU WAI instruction. In this mode the CPU will not execute instructions. The internal CPU signals (address and databus) will be fully static. All peripherals stay active. For further power consumption the peripherals can individually turn off their local clocks. 4.4.4 Run Although this is not a low power mode, unused peripheral modules should not be enabled in order to save power. 94 Device User Guide — 9S12E128DGV1/D V01.04 Section 5 Resets and Interrupts 5.1 Overview Consult the Exception Processing section of the CPU12 Reference Manual for information on resets and interrupts. System resets can be generated through external control of the RESET pin, through the clock and reset generator module CRG or through the low voltage reset (LVR) generator of the voltage regulator module. Refer to the CRG and VREG Block Guides for detailed information on reset generation. 5.2 Vectors Table 5-1 lists interrupt sources and vectors in default order of priority. Table 5-1 Interrupt Vector Locations Interrupt Source CCR Mask Local Enable HPRIO Value to Elevate $FFFE, $FFFF External Reset, Power On Reset or Low Voltage Reset (see CRG Flags Register to determine reset source) None None – $FFFC, $FFFD Clock Monitor fail reset None COPCTL (CME, FCME) – $FFFA, $FFFB COP failure reset None COP rate select – $FFF8, $FFF9 Unimplemented instruction trap None None – $FFF6, $FFF7 SWI None None – $FFF4, $FFF5 XIRQ X-Bit None – $FFF2, $FFF3 IRQ I-Bit INTCR (IRQEN) $F2 $FFF0, $FFF1 Real Time Interrupt I-Bit CRGINT (RTIE) $F0 Vector Address $FFE8 to $FFEF Reserved $FFE6, $FFE7 Standard Timer 0 channel 4 I-Bit TIE (C4I) $E6 $FFE4, $FFE5 Standard Timer 0 channel 5 I-Bit TIE (C5I) $E4 $FFE2, $FFE3 Standard Timer 0 channel 6 I-Bit TIE (C6I) $E2 $FFE0, $FFE1 Standard Timer 0 channel 7 I-Bit TIE (C7I) $E0 $FFDE, $FFDF Standard Timer overflow I-Bit TSCR2 (TOI) $DE $FFDC, $FFDD Pulse accumulator overflow I-Bit PACTL(PAOVI) $DC $FFDA, $FFDB Pulse accumulator input edge I-Bit PACTL (PAI) $DA $FFD8, $FFD9 SPI I-Bit SPICR1 (SPIE, SPTIE) $D8 $D6 $FFD6, $FFD7 SCI0 I-Bit SCICR2 (TIE, TCIE, RIE, ILIE) $FFD4, $FFD5 SCI1 I-Bit SCICR2 (TIE, TCIE, RIE, ILIE) $D4 $FFD2, $FFD3 SCI2 I-Bit SCICR2 (TIE, TCIE, RIE, ILIE) $D2 $FFD0, $FFD1 ATD I-Bit ATDCTL2 (ASCIE) $D0 $FFCE, $FFCF Port AD (KWU) I-Bit PTADIF (PTADIE) $CE $FFC8 to $FFCD Reserved $FFC6, $FFC7 CRG PLL lock I-Bit PLLCR (LOCKIE) $C6 $FFC4, $FFC5 CRG Self Clock Mode I-Bit PLLCR (SCMIE) $C4 95 Device User Guide — 9S12E128DGV1/D V01.04 $FFC2, $FFC3 Reserved $FFC0, $FFC1 IIC Bus I-Bit $FFBA to $FFBF IBCR (IBIE) $C0 Reserved $FFB8, $FFB9 FLASH I-Bit FCNFG (CCIE, CBEIE) $B8 $FFB6, $FFB7 Standard Timer 1 channel 4 I-Bit TIE (C4I) $B6 $FFB4, $FFB5 Standard Timer 1 channel 5 I-Bit TIE (C5I) $B4 $FFB2, $FFB3 Standard Timer 1 channel 6 I-Bit TIE (C6I) $B2 $FFB0, $FFB1 Standard Timer 1 channel 7 I-Bit TIE (C7I) $B0 $FFAE, $FFAF Standard Timer 1 overflow I-Bit TSCR2 (TOI) $AE $FFAC, $FFAD Standard Timer 1 Pulse accumulator overflow I-Bit PACTL (PAOVI) $AC $FFAA, $FFAB Standard Timer 1 Pulse accumulator input edge I-Bit PACTL (PAI) $AA $FFA8, $FFA9 Reserved $FFA6, $FFA7 Standard Timer 2 channel 4 I-Bit TIE (C4I) $A6 $FFA4, $FFA5 Standard Timer 2 channel 5 I-Bit TIE (C5I) $A4 $FFA2, $FFA3 Standard Timer 2 channel 6 I-Bit TIE (C6I) $A2 $FFA0, $FFA1 Standard Timer 2 channel 7 I-Bit TIE (C7I) $A0 $FF9E, $FF9F Standard Timer overflow I-Bit TSCR2 (TOI) $9E $FF9C, $FF9D Standard Timer 2 Pulse accumulator overflow I-Bit PACTL (PAOVI) $9C $FF9A, $FF9B Standard Timer 2 Pulse accumulator input edge I-Bit PACTL (PAI) $9A $FF98, $FF99 PMF Generator A Reload I-Bit PMFENCA (PWMRIEA) $98 $FF96, $FF97 PMF Generator B Reload I-Bit PMFENCB (PWMRIEB) $96 $FF94, $FF95 PMF Generator C Reload I-Bit PMFENCC (PWMRIEC) $94 $FF92, $FF93 PMF Fault 0 I-Bit PMFFCTL (FIE0) $92 $FF90, $FF91 PMF Fault 1 I-Bit PMFFCTL (FIE1) $90 $FF8E, $FF8F PMF Fault 2 I-Bit PMFFCTL (FIE2) $8E $FF8C, $FF8D PMF Fault 3 I-Bit PMFFCTL (FIE3) $8C $FF8A, $FF8B VREG LVI I-Bit CTRL0 (LVIE) $8A $FF88, $FF89 PWM Emergency Shutdown I-Bit PWMSDN(PWMIE) $88 $FF80 to $FF87 Reserved 5.3 Resets Resets are a subset of the interrupts featured inTable 5-1. The different sources capable of generating a system reset are summarized in Table 5-2. Table 5-2 Reset Summary 96 Reset Priority Source Power-on Reset 1 CRG Module Vector $FFFE, $FFFF External Reset 1 RESET pin $FFFE, $FFFF Low Voltage Reset 1 VREG Module $FFFE, $FFFF Clock Monitor Reset 2 CRG Module $FFFC, $FFFD Device User Guide — 9S12E128DGV1/D V01.04 Table 5-2 Reset Summary COP Watchdog Reset 3 CRG Module $FFFA, $FFFB 5.3.1 Effects of Reset When a reset occurs, MCU registers and control bits are changed to known start-up states. Refer to the respective module Block Guides for register reset states. Refer to the HCS12 MEBI Block Guide for mode dependent pin configuration of port A, B and E out of reset. Refer to the PIM Block Guide for reset configurations of all peripheral module ports. Refer to Table 1-1 for locations of the memories depending on the operating mode after reset. The RAM array is not automatically initialized out of reset. Section 6 HCS12 Core Block Description 6.1 CPU12 Block Description Consult the CPU12 Reference Manual for information about the Central Processing Unit. When the CPU12 Reference Manual refers to cycles this is equivalent to Bus Clock periods. So 1 cycle is equivalent to 1 Bus Clock period. 6.2 HCS12 Background Debug Module (BDM) Block Description Consult the HCS12 BDM Block Guide for information about the Background Debug Module. When the BDM Block Guide refers to alternate clock this is equivalent to Oscillator Clock. 6.3 HCS12 Debug (DBG) Block Description Consult the HCS12 DBG Block Guide for information about the Debug module. 6.4 HCS12 Interrupt (INT) Block Description Consult the HCS12 INT Block Guide for information about the Interrupt module. 6.5 HCS12 Multiplexed External Bus Interface (MEBI) Block Description Consult the HCS12 MEBI Block Guide for information about the Multiplexed External Bus Interface module. 97 Device User Guide — 9S12E128DGV1/D V01.04 6.6 HCS12 Module Mapping Control (MMC) Block Description Consult the HCS12 MMC Block Guide for information about the Module Mapping Control module. Section 7 Analog to Digital Converter (ATD) Block Description Consult the ATD_10B16C Block Guide for further information about the A/D Converter module. Note that V04 of the ATD has an external trigger (ETRIG) function which is tied off and not available for use. Section 8 Clock Reset Generator (CRG) Block Description Consult the CRG Block Guide for information about the Clock and Reset Generator module. 8.1 Device-specific information The Low Voltage Reset feature uses the low voltage reset signal from the VREG module as an input to the CRG module. When the regulator output voltage supply to the internal chip logic falls below a specified threshold the LVR signal from the VREG module causes the CRG module to generate a reset. Consult the VREG Block Guide for voltage level specifications. 3F. 8.1.1 XCLKS The XCLKS input signal is active low (see 2.3.8 PE7 / NOACC / XCLKS — Port E I/O Pin 7). Section 9 Digital to Analog Converter (DAC) Block Description There are two digital to analog converter modules (DAC0, DAC1). Consult the DAC Block Guide for information about the DAC Module. Section 10 Flash EEPROM Block Description Consult the FTS32K Block Guide for information about the flash module for the MC9S12E32. Consult the FTS128K1 Block Guide for information about the flash module for the MC9S12E64. Consult the FTS128K1 Block Guide for information about the flash module for the MC9S12E128. 98 Device User Guide — 9S12E128DGV1/D V01.04 Consult the FTS256K2 Block Guide for information about the flash module for the MC9S12E256. The "S12 LRAE" is a generic Load RAM and Execute (LRAE) program which will be programmed into the flash memory of this device during manufacture. This LRAE program will provide greater programming flexibility to the end users by allowing the device to be programmed directly using SCI after it is assembled on the PCB. Use of the LRAE program is at the discretion of the end user and, if not required, it must simply be erased prior to flash programming. For more details of the S12 LRAE and its implementation, please see the S12 LREA Application Note (AN2546/D) . It is planned that most HC9S12 devices manufactured after Q1 of 2004 will be shipped with the S12 LRAE programmed in the Flash . Exact details of the changeover (ie blank to programmed) for each product will be communicated in advance via GPCN and will be traceable by the customer via datecode marking on the device. Please contact Motorola SPS Sales if you have any additional questions. Section 11 IIC Block Description Consult the IIC Block Guide for information about the IIC Module. Section 12 Oscillator (OSC) Block Description Consult the OSC Block Guide for information about the Oscillator module. Section 13 Port Integration Module (PIM) Block Description Consult the PIM_9E128 Block Guide for information about the Port Integration Module. Section 14 Pulse width Modulator with Fault protection (PMF) Block Description Consult the PMF_15B6C Block Guide for information about the Pulse width Modulator with Fault protection Module. Section 15 Pulse Width Modulator (PWM) Block Description Consult the PWM_8B6C Block Guide for information about the Pulse Width Modulator Module. Section 16 Serial Communications Interface (SCI) Block 99 Device User Guide — 9S12E128DGV1/D V01.04 Description There are three Serial Communications Interface modules (SCI0, SCI1, SCI2). Consult the SCI Block Guide for information about the Serial Communications Interface module. Section 17 Serial Peripheral Interface (SPI) Block Description Consult the SPI Block Guide for information about the Serial Peripheral Interface module. Section 18 Timer (TIM) Block Description There are three timer modules (TIM0, TIM1, TIM2). Consult the TIM_16B4C Block Guide for information about the Timer module. Section 19 Voltage Regulator (VREG) Block Description Consult the VREG Block Guide for information about the dual output linear voltage regulator. 19.1 VREGEN On the MC9S12E-Family the regulator enable signal (VREGEN) is not available externally and is connected internally to VDDR. 19.2 VDD1, VDD2, VSS1, VSS2 In both the 112 pin LQFP and the 80 pin QFP package versions, both internal VDD and VSS of the 2.5V domain are bonded out on 2 sides of the device as two pin pairs (VDD1, VSS1 & VDD2, VSS2). VDD1 and VDD2 are connected together internally. VSS1 and VSS2 are connected together internally. This allows systems to employ better supply routing and further decoupling. Section 20 Printed Circuit Board Layout Proposals The Printed Circuit Board (PCB) must be carefully laid out to ensure proper operation of the voltage regulator as well as the MCU itself. The following rules must be observed: • 100 Every supply pair must be decoupled by a ceramic capacitor connected as near as possible to the corresponding pins (C1 - C6). Device User Guide — 9S12E128DGV1/D V01.04 • Central point of the ground star should be the VSSR pin. • Use low ohmic low inductance connections between VSS1, VSS2 and VSSR. • VSSPLL must be directly connected to VSSR. • Keep traces of VSSPLL, EXTAL and XTAL as short as possible and occupied board area for C7, C8, C11 and Q1 as small as possible. • Do not place other signals or supplies underneath area occupied by C7, C8, C10 and Q1 and the connection area to the MCU. • Central power input should be fed in at the VDDA/VSSA pins. Table 20-1 Recommended decoupling capacitor choice Component Purpose Type Value C1 VDD1 filter cap ceramic X7R 100 - 220nF C2 VDD2 filter cap (80 QFP only) ceramic X7R 100 - 220nF C3 VDDA filter cap ceramic X7R 100nF C4 VDDR filter cap X7R/tantalum >=100nF C5 VDDPLL filter cap ceramic X7R 100nF C6 VDDX filter cap X7R/tantalum >=100nF C7 OSC load cap C8 OSC load cap C9 PLL loop filter cap C10 PLL loop filter cap C11 DC cutoff cap R1 PLL loop filter res Q1 Quartz See PLL specification chapter 101 Device User Guide — 9S12E128DGV1/D V01.04 Figure 20-1 Recommended PCB Layout (112 LQFP) NOTE: Oscillator in Colpitts mode. C1 VDD1 VSSA VSS1 C3 VDDA VDDX VSS2 C2 C6 VDD2 VSSX VSSR C4 C7 C8 102 C10 C9 R1 C11 C5 VDDR Q1 VSSPLL VDDPLL Device User Guide — 9S12E128DGV1/D V01.04 Figure 20-2 Recommended PCB Layout (80 QFP) NOTE: Oscillator in Colpitts mode. VSSA C1 VDD1 C3 VSS1 VDDA VSS2 VDDX C2 C6 VDD2 VSSX VSSR C4 C7 C8 C11 C5 VDDR C10 C9 Q1 VSSPLL R1 VDDPLL 103 Device User Guide — 9S12E128DGV1/D V01.04 104 Device User Guide — 9S12E128DGV1/D V01.04 Appendix A Electrical Characteristics A.1 General NOTE: The electrical characteristics given in this section are preliminary and should be used as a guide only. Values cannot be guaranteed by Motorola and are subject to change without notice. NOTE: The part is specified and tested over the 5V and 3.3V ranges. For the intermediate range, generally the electrical specifications for the 3.3V range apply, but the part is not tested in production test in the intermediate range. This supplement contains the most accurate electrical information for the MC9S12E-Family microcontroller available at the time of publication. The information should be considered PRELIMINARY and is subject to change. This introduction is intended to give an overview on several common topics like power supply, current injection etc. A.1.1 Parameter Classification The electrical parameters shown in this supplement are guaranteed by various methods. To give the customer a better understanding the following classification is used and the parameters are tagged accordingly in the tables where appropriate. NOTE: This classification will be added at a later release of the specification P: Those parameters are guaranteed during production testing on each individual device. C: Those parameters are achieved by the design characterization by measuring a statistically relevant sample size across process variations. They are regularly verified by production monitors. T: Those parameters are achieved by design characterization on a small sample size from typical devices. All values shown in the typical column are within this category. D: Those parameters are derived mainly from simulations. A.1.2 Power Supply The MC9S12E-Family utilizes several pins to supply power to the I/O ports, A/D converter, oscillator, PLL and internal logic. The VDDA, VSSA pair supplies the A/D converter and D/A converter. The VDDX, VSSX pair supplies the I/O pins The VDDR, VSSR pair supplies the internal voltage regulator. VDD1, VSS1, VDD2 and VSS2 are the supply pins for the internal logic. VDDPLL, VSSPLL supply the oscillator and the PLL. 105 Device User Guide — 9S12E128DGV1/D V01.04 VSS1 and VSS2 are internally connected by metal. VDD1 and VDD2 are internally connected by metal. VDDA, VDDX, VDDR as well as VSSA, VSSX, VSSR are connected by anti-parallel diodes for ESD protection. NOTE: In the following context VDD5 is used for either VDDA, VDDR and VDDX; VSS5 is used for either VSSA, VSSR and VSSX unless otherwise noted. IDD5 denotes the sum of the currents flowing into the VDDA, VDDX and VDDR pins. VDD is used for VDD1, VDD2 and VDDPLL, VSS is used for VSS1, VSS2 and VSSPLL. IDD is used for the sum of the currents flowing into VDD1 and VDD2. A.1.3 Pins There are four groups of functional pins. A.1.3.1 3.3V/5V I/O pins Those I/O pins have a nominal level of 3.3V or 5V depending on the application operating point. This group of pins is comprised of all port I/O pins, the analog inputs, BKGD pin and the RESET inputs.The internal structure of all those pins is identical, however some of the functionality may be disabled. A.1.3.2 Analog Reference This group of pins is comprised of the VRH and VRL pins. A.1.3.3 Oscillator The pins XFC, EXTAL, XTAL dedicated to the oscillator have a nominal 2.5V level. They are supplied by VDDPLL. A.1.3.4 TEST This pin is used for production testing only. A.1.4 Current Injection Power supply must maintain regulation within operating VDD5 or VDD range during instantaneous and operating maximum current conditions. If positive injection current (Vin > VDD5) is greater than IDD5, the injection current may flow out of VDD5 and could result in external power supply going out of regulation. Insure external VDD5 load will shunt current greater than maximum injection current. This will be the greatest risk when the MCU is not consuming power; e.g. if no system clock is present, or if clock rate is very low which would reduce overall power consumption. 106 Device User Guide — 9S12E128DGV1/D V01.04 A.1.5 Absolute Maximum Ratings Absolute maximum ratings are stress ratings only. A functional operation under or outside those maxima is not guaranteed. Stress beyond those limits may affect the reliability or cause permanent damage of the device. This device contains circuitry protecting against damage due to high static voltage or electrical fields; however, it is advised that normal precautions be taken to avoid application of any voltages higher than maximum-rated voltages to this high-impedance circuit. Reliability of operation is enhanced if unused inputs are tied to an appropriate logic voltage level (e.g., either VSS5 or VDD5). Table A-1 Absolute Maximum Ratings Num Rating Symbol Min Max Unit 1 I/O, Regulator and Analog Supply Voltage VDD5 -0.3 6.5 V 2 Internal Logic Supply Voltage1 VDD -0.3 3.0 V 3 PLL Supply Voltage (1) VDDPLL -0.3 3.0 V 4 Voltage difference VDDX to VDDR and VDDA ∆VDDX -0.3 0.3 V 5 Voltage difference VSSX to VSSR and VSSA ∆VSSX -0.3 0.3 V 6 Digital I/O Input Voltage VIN -0.3 6.5 V 7 Analog Reference VRH, VRL -0.3 6.5 V 8 XFC, EXTAL, XTAL inputs VILV -0.3 3.0 V 9 TEST input VTEST -0.3 10.0 V 10 Instantaneous Maximum Current Single pin limit for all digital I/O pins 2 I D -25 +25 mA 11 Instantaneous Maximum Current Single pin limit for XFC, EXTAL, XTAL3 IDL -25 +25 mA 12 Instantaneous Maximum Current Single pin limit for TEST4 I DT -0.25 0 mA 13 Operating Temperature Range (packaged) TA – 40 125 °C 14 Operating Temperature Range (junction) TJ – 40 140 °C 15 Storage Temperature Range Tstg – 65 155 °C NOTES: 1. The device contains an internal voltage regulator to generate the logic and PLL supply out of the I/O supply. The absolute maximum ratings apply when the device is powered from an external source. 2. All digital I/O pins are internally clamped to VSSX and VDDX, VSSR and VDDR or VSSA and VDDA. 3. These pins are internally clamped to VSSPLL and VDDPLL 4. This pin is clamped low to VSSR, but not clamped high. This pin must be tied low in applications. 107 Device User Guide — 9S12E128DGV1/D V01.04 A.1.6 ESD Protection and Latch-up Immunity All ESD testing is in conformity with CDF-AEC-Q100 Stress test qualification for Automotive Grade Integrated Circuits. During the device qualification ESD stresses were performed for the Human Body Model (HBM), the Machine Model (MM) and the Charge Device Model. A device will be defined as a failure if after exposure to ESD pulses the device no longer meets the device specification. Complete DC parametric and functional testing is performed per the applicable device specification at room temperature followed by hot temperature, unless specified otherwise in the device specification. Table A-2 ESD and Latch-up Test Conditions Model Description Human Body Machine Latch-up Symbol Value Unit Series Resistance R1 1500 Ohm Storage Capacitance C 100 pF Number of Pulse per pin positive negative - 3 3 Series Resistance R1 0 Ohm Storage Capacitance C 200 pF Number of Pulse per pin positive negative - 3 3 Minimum input voltage limit -2.5 V Maximum input voltage limit 7.5 V Table A-3 ESD and Latch-Up Protection Characteristics Num C 1 C 2 Rating Symbol Min Max Unit Human Body Model (HBM) VHBM 2000 - V C Machine Model (MM) VMM 200 - V 3 C Charge Device Model (CDM) VCDM 500 - V 4 C Latch-up Current at 125°C positive negative ILAT +100 -100 - mA 5 C Latch-up Current at 27°C positive negative ILAT +200 -200 - mA A.1.7 Operating Conditions This chapter describes the operating conditions of the device. Unless otherwise noted those conditions apply to all the following data. 108 Device User Guide — 9S12E128DGV1/D V01.04 NOTE: Instead of specifying ambient temperature all parameters are specified for the more meaningful silicon junction temperature. For power dissipation calculations refer to Section A.1.8 Power Dissipation and Thermal Characteristics. Table A-4 Operating Conditions Rating Symbol Min Typ Max Unit I/O, Regulator and Analog Supply Voltage VDD5 3.135 3.3/5 5.5 V Internal Logic Supply Voltage1 VDD 2.35 2.5 2.75 V PLL Supply Voltage (1) VDDPLL 2.35 2.5 2.75 V Voltage Difference VDDX to VDDA ∆VDDX -0.1 0 0.1 V Voltage Difference VSSX to VSSR and VSSA ∆VSSX -0.1 0 0.1 V Oscillator fosc 0.5 - 16 MHz Bus Frequency2 fbus 0.25 - 25 MHz Operating Junction Temperature Range TJ -40 - 140 °C NOTES: 1. The device contains an internal voltage regulator to generate the logic and PLL supply out of the I/O supply. The given operating range applies when this regulator is disabled and the device is powered from an external source. 2. Some blocks e.g. ATD (conversion) and NVMs (program/erase) require higher bus frequencies for proper operation. A.1.8 Power Dissipation and Thermal Characteristics Power dissipation and thermal characteristics are closely related. The user must assure that the maximum operating junction temperature is not exceeded. The average chip-junction temperature (TJ) in °C can be obtained from: T J = T A + ( P D • Θ JA ) T J = Junction Temperature, [°C ] T A = Ambient Temperature, [°C ] P D = Total Chip Power Dissipation, [W] Θ JA = Package Thermal Resistance, [°C/W] The total power dissipation can be calculated from: P D = P INT + P IO P INT = Chip Internal Power Dissipation, [W] Two cases with internal voltage regulator enabled and disabled must be considered: 109 Device User Guide — 9S12E128DGV1/D V01.04 1. Internal Voltage Regulator disabled P INT = I DD ⋅ V DD + I DDPLL ⋅ V DDPLL + I DDA ⋅ V DDA 2 P IO = R DSON ⋅ I IO i i ∑ Which is the sum of all output currents on I/O ports associated with VDDX and VDDM. For RDSON is valid: respectively V OL R DSON = ------------ ;for outputs driven low I OL V DD5 – V OH R DSON = ------------------------------------ ;for outputs driven high I OH 2. Internal voltage regulator enabled P INT = I DDR ⋅ V DDR + I DDA ⋅ V DDA IDDR is the current shown in Table A-8 and not the overall current flowing into VDDR, which additionally contains the current flowing into the external loads with output high. 2 P IO = R DSON ⋅ I IO i i ∑ Which is the sum of all output currents on I/O ports associated with VDDX and VDDR. 110 Device User Guide — 9S12E128DGV1/D V01.04 Table A-5 Thermal Package Characteristics1 Num C 1 T 2 Rating Symbol Min Typ Max Unit Thermal Resistance LQFP112, single sided PCB2 θJA – – 54 °oC/W T Thermal Resistance LQFP112, double sided PCB with 2 internal planes3 θJA – – 41 oC/W 3 T Junction to Board LQFP112 θJB – – 31 °oC/W 4 T Junction to Case LQFP112 θJC – – 11 o C/W 5 T Junction to Package Top LQFP112 ΨJT – – 2 o C/W 6 T Thermal Resistance QFP 80, single sided PCB θJA – – 51 °oC/W 7 T Thermal Resistance QFP 80, double sided PCB with 2 internal planes θJA – – 41 o 8 T Junction to Board QFP80 θJB – – 27 °oC/W 9 T Junction to Case QFP80 θJC – – 14 oC/W 10 T Junction to Package Top QFP80 ΨJT – – 3 oC/W C/W NOTES: 1. The values for thermal resistance are achieved by package simulations 2. PC Board according to EIA/JEDEC Standard 51-3 3. PC Board according to EIA/JEDEC Standard 51-7 A.1.9 I/O Characteristics This section describes the characteristics of all 3.3V/5V I/O pins. All parameters are not always applicable, e.g. not all pins feature pull up/down resistances. 111 Device User Guide — 9S12E128DGV1/D V01.04 Table A-6 5V I/O Characteristics Conditions are shown in Table A-4 unless otherwise noted Num 1 2 3 4 C Rating Symbol Min Typ Max Unit P Input High Voltage VIH 0.65*VDD5 - - V T Input High Voltage VIH - - VDD5 + 0.3 V P Input Low Voltage VIL - - 0.35*VDD5 V T Input Low Voltage VIL VSS5 - 0.3 - - V C Input Hysteresis P Input Leakage Current (pins in high ohmic input mode)1 or V V =V in DD5 VHYS I 250 mV in –2.5 - 2.5 µA SS5 5 C Output High Voltage (pins in output mode) Partial Drive IOH = –2mA VOH VDD5 – 0.8 - - V 6 P Output High Voltage (pins in output mode) Full Drive IOH = –10mA VOH VDD5 – 0.8 - - V 7 C Output Low Voltage (pins in output mode) Partial Drive IOL = +2mA VOL - - 0.8 V 8 P Output Low Voltage (pins in output mode) Full Drive IOL = +10mA VOL - - 0.8 V 9 P Internal Pull Up Device Current, tested at V Max. IPUL - - -130 µA 10 C Internal Pull Up Device Current, tested at VIH Min. IPUH -10 - - µA 11 P Internal Pull Down Device Current, tested at V Min. IPDH - - 130 µA 12 C Internal Pull Down Device Current, tested at VIL Max. IPDL 10 - - µA 13 D Input Capacitance Cin 6 - pF 14 T Injection current2 Single Pin limit Total Device Limit. Sum of all injected currents IICS IICP - 2.5 25 mA 15 P Port AD Interrupt Input Pulse filtered3 tPIGN 3 µs 16 P Port AD Interrupt Input Pulse passed(3) tPVAL IL IH -2.5 -25 10 µs NOTES: 1. Maximum leakage current occurs at maximum operating temperature. Current decreases by approximately one-half for each 8°C to 12°C in the temperature range from 50°C to 125°C. 2. Refer to Section A.1.4 Current Injection, for more details 3. Parameter only applies in STOP or Pseudo STOP mode. 112 Device User Guide — 9S12E128DGV1/D V01.04 Table A-7 Preliminary 3.3V I/O Characteristics Conditions are shown in Table A-4 unless otherwise noted Num 1 2 3 4 C Rating Symbol Min Typ Max Unit P Input High Voltage VIH 0.65*VDD5 - - V T Input High Voltage VIH - - VDD5 + 0.3 V P Input Low Voltage VIL - - 0.35*VDD5 V T Input Low Voltage VIL VSS5 - 0.3 - - V C Input Hysteresis P Input Leakage Current (pins in high ohmic input mode)1 or V V =V in DD5 VHYS 250 mV Iin –2.5 - 2.5 µA SS5 5 C Output High Voltage (pins in output mode) Partial Drive IOH = –0.75mA VOH VDD5 – 0.4 - - V 6 P Output High Voltage (pins in output mode) Full Drive IOH = –4.5mA VOH VDD5 – 0.4 - - V 7 C Output Low Voltage (pins in output mode) Partial Drive IOL = +0.9mA VOL - - 0.4 V 8 P Output Low Voltage (pins in output mode) Full Drive IOL = +5.5mA VOL - - 0.4 V 9 P Internal Pull Up Device Current, tested at VIL Max. IPUL - - –60 µA 10 C Internal Pull Up Device Current, tested at VIH Min. IPUH -6 - - µA 11 P Internal Pull Down Device Current, tested at V Min. IPDH - - 60 µA 12 C Internal Pull Down Device Current, tested at VIL Max. IPDL 6 - - µA 13 D Input Capacitance Cin 6 - pF 14 T Injection current2 Single Pin limit Total Device Limit. Sum of all injected currents IICS IICP - 2.5 25 mA 15 P Port AD Interrupt Input Pulse filtered3 tPIGN 3 µs 16 P Port AD Interrupt Input Pulse passed(3) tPVAL IH -2.5 -25 10 µs NOTES: 1. Maximum leakage current occurs at maximum operating temperature. Current decreases by approximately one-half for each 8°C to 12°C in the temperature range from 50°C to 125°C. 2. Refer to Section A.1.4 Current Injection, for more details 3. Parameter only applies in STOP or Pseudo STOP mode. 113 Device User Guide — 9S12E128DGV1/D V01.04 A.1.10 Supply Currents This section describes the current consumption characteristics of the device as well as the conditions for the measurements. A.1.10.1 Measurement Conditions All measurements are without output loads. Unless otherwise noted the currents are measured in single chip mode, internal voltage regulator enabled and at 25MHz bus frequency using a 4MHz oscillator. A.1.10.2 Additional Remarks In expanded modes the currents flowing in the system are highly dependent on the load at the address, data and control signals as well as on the duty cycle of those signals. No generally applicable numbers can be given. A very good estimate is to take the single chip currents and add the currents due to the external loads. 114 Device User Guide — 9S12E128DGV1/D V01.04 Table A-8 Supply Current Characteristics Conditions are shown in Table A-4 unless otherwise noted Num C Rating Symbol Min Typ Max 1 P Run supply currents Single Chip, Internal regulator enabled IDD5 65 2 P P IDDW 40 5 Unit mA Wait Supply current 3 4 5 C C C C C C C C P C C P C P C P C P C C P C P C P All modules enabled only RTI enabled Pseudo Stop Current (RTI and COP enabled) 1, 2 -40°C 27°C 70°C 85°C 105°C 125°C 140°C Pseudo Stop Current (RTI and COP disabled) (1),(2) -40°C 27°C 70°C 85°C "C" Temp Option 100°C 105°C "V" Temp Option 120°C 125°C "M" Temp Option 140°C Stop Current IDDPS IDDPS 570 600 650 750 850 1200 1500 370 400 450 550 600 650 800 850 1200 mA µA 500 1600 µA 2100 5000 (2) -40°C 27°C 70°C 85°C "C" Temp Option 100°C 105°C "V" Temp Option 120°C 125°C "M" Temp Option 140°C IDDS 12 30 100 130 160 200 350 400 600 100 1200 µA 1700 5000 NOTES: 1. PLL off 2. At those low power dissipation levels TJ = TA can be assumed 115 Device User Guide — 9S12E128DGV1/D V01.04 116 Device User Guide — 9S12E128DGV1/D V01.04 Appendix B Electrical Specifications B.1 Voltage Regulator (VREG_3V3) Operating Characteristics This section describes the characteristics of the on chip voltage regulator. Table 20-2 VREG_3V3 - Operating Conditions Num C 1 P Input Voltages 2 P P 3 4 P Characteristic Symbol Min Typical Max Unit VVDDR,A 3.135 — 5.5 V Regulator Current Reduced Power Mode Shutdown Mode IREG — — 20 12 50 40 µA µA Output Voltage Core Full Performance Mode Reduced Power Mode Shutdown Mode VDD 2.35 1.6 — 2.5 2.5 2.75 2.75 — V V V 2.35 2.0 1.6 — 2.5 2.5 2.5 4 2.75 2.75 2.75 — Output Voltage PLL Full Performance Mode Reduced Power Mode2 Reduced Power Mode3 Shutdown Mode VDDPLL 1 V V V V 5 P Low Voltage Interrupt5 Assert Level Deassert Level VLVIA VLVID 4.1 4.25 4.37 4.52 4.66 4.77 V V 5 P Low Voltage Reset6 Assert Level Deassert Level VLVRA VLVRD 2.25 — — — — 2.55 V V 7 C Power-on Reset7 Assert Level Deassert Level VPORA VPORD 0.97 — ----- — 2.05 V V NOTES: 1. High Impedance Output 2. Current IDDPLL = 1mA (Colpitts Oscillator) 3. Current IDDPLL = 3mA (Pierce Oscillator) 4. High Impedance Output 5. Monitors VDDA, active only in Full Performance Mode. Indicates I/O & ADC performance degradation due to low supply voltage. 6. Monitors VDD, active only in Full Performance Mode. VLVRA and VPORD must overlap 7. Monitors VDD. Active in all modes. NOTE: The electrical characteristics given in this section are preliminary and should be used as a guide only. Values in this section cannot be guaranteed by Motorola and are subject to change without notice. 117 Device User Guide — 9S12E128DGV1/D V01.04 B.2 Chip Power-up and LVI/LVR graphical explanation Voltage regulator sub modules LVI (low voltage interrupt), POR (power-on reset) and LVR (low voltage reset) handle chip power-up or drops of the supply voltage. Their function is described in Figure B-1. Figure B-1 Voltage Regulator - Chip Power-up and Voltage Drops (not scaled) V VDDA VLVID VLVIA VDD VLVRD VLVRA VPORD t LVI POR LVI enabled LVI disabled due to LVR LVR B.3 Output Loads B.3.1 Resistive Loads The on-chip voltage regulator is intended to supply the internal logic and oscillator circuits allows no external DC loads. 118 Device User Guide — 9S12E128DGV1/D V01.04 B.3.2 Capacitive Loads The capacitive loads are specified in Table B-1. Ceramic capacitors with X7R dielectricum are required. Table B-1 Voltage Regulator - Capacitive Loads Num Characteristic 1 VDD external capacitive load 2 VDDPLL external capacitive load Symbol Min Typical Max Unit CDDext 200 440 12000 nF CDDPLLext 90 220 5000 nF 119 Device User Guide — 9S12E128DGV1/D V01.04 120 Device User Guide — 9S12E128DGV1/D V01.04 B.4 Reset, Oscillator and PLL This section summarizes the electrical characteristics of the various startup scenarios for Oscillator and Phase-Locked-Loop (PLL). B.4.1 Startup Table B-2 summarizes several startup characteristics explained in this section. Detailed description of the startup behavior can be found in the Clock and Reset Generator (CRG) Block User Guide. Table B-2 Startup Characteristics Conditions are shown in Table A-4 unless otherwise noted Num C Rating Symbol Min Typ Max Unit 1 T POR release level VPORR 2.07 V 2 T POR assert level VPORA 0.97 V 3 D Reset input pulse width, minimum input time PWRSTL 2 tosc 4 D Startup from Reset nRST 192 5 D Interrupt pulse width, IRQ edge-sensitive mode PWIRQ 20 6 D Wait recovery startup time tWRS 7 P LVR release level VLVRR 8 P LVR assert level VLVRA 196 nosc ns 14 2.25 tcyc V 2.55 V B.4.1.1 POR The release level VPORR and the assert level VPORA are derived from the VDD Supply. They are also valid if the device is powered externally. After releasing the POR reset the oscillator and the clock quality check are started. If after a time tCQOUT no valid oscillation is detected, the MCU will start using the internal self clock. The fastest startup time possible is given by nuposc. B.4.1.2 LVR The release level VLVRR and the assert level VLVRA are derived from the VDD Supply. They are also valid if the device is powered externally. After releasing the LVR reset the oscillator and the clock quality check are started. If after a time tCQOUT no valid oscillation is detected, the MCU will start using the internal self clock. The fastest startup time possible is given by nuposc. B.4.1.3 SRAM Data Retention Provided an appropriate external reset signal is applied to the MCU, preventing the CPU from executing code when VDD5 is out of specification limits, the SRAM contents integrity is guaranteed if after the reset the PORF bit in the CRG Flags Register has not been set. 121 Device User Guide — 9S12E128DGV1/D V01.04 B.4.1.4 External Reset When external reset is asserted for a time greater than PWRSTL the CRG module generates an internal reset, and the CPU starts fetching the reset vector without doing a clock quality check, if there was an oscillation before reset. B.4.1.5 Stop Recovery Out of STOP the controller can be woken up by an external interrupt. A clock quality check as after POR is performed before releasing the clocks to the system. B.4.1.6 Pseudo Stop and Wait Recovery The recovery from Pseudo STOP and Wait are essentially the same since the oscillator was not stopped in both modes. The controller can be woken up by internal or external interrupts. After twrs the CPU starts fetching the interrupt vector. 122 Device User Guide — 9S12E128DGV1/D V01.04 B.4.2 Oscillator The device features an internal Colpitts and Pierce oscillator. The selection of Colpitts oscillator or Pierce oscillator/external clock depends on the XCLKS signal which is sampled during reset. Pierce oscillator/external clock mode allows the input of a square wave. Before asserting the oscillator to the internal system clocks the quality of the oscillation is checked for each start from either power-on, STOP or oscillator fail. tCQOUT specifies the maximum time before switching to the internal self clock mode after POR or STOP if a proper oscillation is not detected. The quality check also determines the minimum oscillator start-up time tUPOSC. The device also features a clock monitor. A Clock Monitor Failure is asserted if the frequency of the incoming clock signal is below the Assert Frequency fCMFA. Table B-3 Oscillator Characteristics Conditions are shown in Table A-4 unless otherwise noted Num C Rating Symbol Min Typ Max Unit 1a C Crystal oscillator range (Colpitts) fOSC 0.5 16 MHz 1b C Crystal oscillator range (Pierce) 1 fOSC 0.5 40 MHz 2 P Startup Current iOSC 100 3 C Oscillator start-up time (Colpitts) tUPOSC 4 D Clock Quality check time-out tCQOUT 0.45 5 P Clock Monitor Failure Assert Frequency fCMFA 50 6 P External square wave input frequency 4 fEXT 0.5 7 D External square wave pulse width low(4) tEXTL 9.5 ns 8 D External square wave pulse width high(4) tEXTH 9.5 ns 9 D External square wave rise time(4) tEXTR 1 ns 10 D External square wave fall time(4) tEXTF 1 ns 11 D Input Capacitance (EXTAL, XTAL pins) 12 C 13 P EXTAL Pin Input High Voltage(4) VIH,EXTAL T EXTAL Pin Input High Voltage(4) VIH,EXTAL VDDPLL + 0.3 V P EXTAL Pin Input Low Voltage(4) VIL,EXTAL 0.3*VDDPLL V T EXTAL Pin Input Low Voltage(4) VIL,EXTAL 14 15 DC Operating Bias in Colpitts Configuration on EXTAL Pin C EXTAL Pin Input Hysteresis(4) µA 82 100 1003 ms 2.5 s 200 KHz 50 MHz CIN 7 pF VDCBIAS 1.1 V 0.7*VDDPLL V VSSPLL - 0.3 VHYS,EXTAL V 250 mV NOTES: 1. Depending on the crystal a damping series resistor might be necessary 2. fosc = 4MHz, C = 22pF. 3. Maximum value is for extreme cases using high Q, low frequency crystals 4. Only valid if Pierce oscillator/external clock mode is selected 123 Device User Guide — 9S12E128DGV1/D V01.04 B.4.3 Phase Locked Loop The oscillator provides the reference clock for the PLL. The PLL´s Voltage Controlled Oscillator (VCO) is also the system clock source in self clock mode. B.4.3.1 XFC Component Selection This section describes the selection of the XFC components to achieve a good filter characteristics. Cp VDDPLL R Phase Cs fosc fref 1 refdv+1 ∆ fcmp XFC Pin VCO KΦ KV fvco Detector Loop Divider 1 synr+1 1 2 Figure B-2 Basic PLL functional diagram The following procedure can be used to calculate the resistance and capacitance values using typical values for K1, f1 and ich from Table B-4. The grey boxes show the calculation for fVCO = 50MHz and fref = 1MHz. E.g., these frequencies are used for fOSC = 4MHz and a 25MHz bus clock. The VCO Gain at the desired VCO frequency is approximated by: KV = K1 ⋅ e ( f 1 – f vco ) ----------------------K 1 ⋅ 1V = – 100 ⋅ e ( 60 – 50 ) -----------------------– 100 = -90.48MHz/V The phase detector relationship is given by: K Φ = – i ch ⋅ K V ich is the current in tracking mode. 124 = 316.7Hz/Ω Device User Guide — 9S12E128DGV1/D V01.04 The loop bandwidth fC should be chosen to fulfill the Gardner’s stability criteria by at least a factor of 10, typical values are 50. ζ = 0.9 ensures a good transient response. 2 ⋅ ζ ⋅ f ref f ref 1 Þ ------ → f C < ------------- ;( ζ = 0.9 ) f C < -----------------------------------------10 4 ⋅ 10 2 π ⋅ ζ + 1 + ζ  fC < 25kHz   And finally the frequency relationship is defined as f VCO n = ------------- = 2 ⋅ ( synr + 1 ) f ref = 50 With the above values the resistance can be calculated. The example is shown for a loop bandwidth fC=10kHz: 2 ⋅ π ⋅ n ⋅ fC R = ---------------------------- = 2*π*50*10kHz/(316.7Hz/Ω)=9.9kΩ=~10kΩ KΦ The capacitance Cs can now be calculated as: 2 2⋅ζ 0.516 C s = ---------------------- ≈ --------------- ;( ζ = 0.9 ) = 5.19nF =~ 4.7nF π ⋅ fC ⋅ R fC ⋅ R The capacitance Cp should be chosen in the range of: C s ⁄ 20 ≤ C p ≤ C s ⁄ 10 Cp = 470pF B.4.3.2 Jitter Information The basic functionality of the PLL is shown in Figure B-2. With each transition of the clock fcmp, the deviation from the reference clock fref is measured and input voltage to the VCO is adjusted accordingly.The adjustment is done continuously with no abrupt changes in the clock output frequency. Noise, voltage, temperature and other factors cause slight variations in the control loop resulting in a clock jitter. This jitter affects the real minimum and maximum clock periods as illustrated in Figure B-3. NOTE: This section is under construction The basic functionality of the PLL is shown in Figure B-2. With each transition of the clock fcmp, the deviation from the reference clock fref is measured and input voltage to the VCO is adjusted 125 Device User Guide — 9S12E128DGV1/D V01.04 accordingly.The adjustment is done continuously with no abrupt changes in the clock output frequency. Noise, voltage, temperature and other factors cause slight variations in the control loop resulting in a clock jitter. This jitter affects the real minimum and maximum clock periods as illustrated in Figure B-3. 1 0 2 3 N-1 N tmin1 tnom tmax1 tminN tmaxN Figure B-3 Jitter Definitions The relative deviation of tnom is at its maximum for one clock period, and decreases towards zero for larger number of clock periods (N). Defining the jitter as: t min ( N )  t max ( N )  J ( N ) = max  1 – -------------------- , 1 – -------------------- N ⋅ t nom N ⋅ t nom   For N < 100, the following equation is a good fit for the maximum jitter: j1 J ( N ) = ------- + j2 N 126 Device User Guide — 9S12E128DGV1/D V01.04 J(N) 1 5 10 20 N This is very important to notice with respect to timers, serial modules where a pre-scaler will eliminate the effect of the jitter to a large extent. Table B-4 PLL Characteristics Conditions are shown in Table A-4 unless otherwise noted Num C 1 P 2 Rating Symbol Min Self Clock Mode frequency fSCM D VCO locking range 3 D Lock Detector transition from Acquisition to Tracking mode 4 D Lock Detection 5 D 6 Typ Max Unit 1 5.5 MHz fVCO 8 50 MHz |∆trk| 3 4 %1 |∆Lock| 0 1.5 %(1) Un-Lock Detection |∆unl| 0.5 2.5 %(1) D Lock Detector transition from Tracking to Acquisition mode |∆unt| 6 8 %(1) 7 C PLLON Total Stabilization delay (Auto Mode) 2 tstab 0.5 ms 8 D PLLON Acquisition mode stabilization delay (2) tacq 0.3 ms 9 D PLLON Tracking mode stabilization delay (2) tal 0.2 ms 10 D Fitting parameter VCO loop gain K1 -100 MHz/V 11 D Fitting parameter VCO loop frequency f1 60 MHz 12 D Charge pump current acquisition mode | ich | 38.5 µA 13 D Charge pump current tracking mode | ich | 3.5 µA 14 C Jitter fit parameter 1(2) j1 1.1 % 15 C Jitter fit parameter 2(2) j2 0.13 % NOTES: 1. % deviation from target frequency 2. fOSC = 4MHz, fBUS = 25MHz equivalent fVCO = 50MHz: REFDV = #$03, SYNR = #$018, Cs = 4.7nF, Cp = 470pF, Rs = 10KΩ. 127 Device User Guide — 9S12E128DGV1/D V01.04 128 Device User Guide — 9S12E128DGV1/D V01.04 B.5 Flash NVM B.5.1 NVM timing The time base for all NVM program or erase operations is derived from the oscillator. A minimum oscillator frequency fNVMOSC is required for performing program or erase operations. The NVM modules do not have any means to monitor the frequency and will not prevent program or erase operation at frequencies above or below the specified minimum. Attempting to program or erase the NVM modules at a lower frequency a full program or erase transition is not assured. The Flash program and erase operations are timed using a clock derived from the oscillator using the FCLKDIV register. The frequency of this clock must be set within the limits specified as fNVMOP. The minimum program and erase times shown in Table B-5 are calculated for maximum fNVMOP and maximum fbus. The maximum times are calculated for minimum fNVMOP and a fbus of 2MHz. B.5.1.1 Single Word Programming The programming time for single word programming is dependent on the bus frequency as a well as on the frequency f¨NVMOP and can be calculated according to the following formula. 1 1 t swpgm = 9 ⋅ --------------------- + 25 ⋅ ---------f bus f NVMOP B.5.1.2 Row Programming Flash programming where up to 32 words in a row can be programmed consecutively by keeping the command pipeline filled. The time to program a consecutive word can be calculated as: 1 1 t bwpgm = 4 ⋅ --------------------- + 9 ⋅ ---------f bus f NVMOP The time to program a whole row is: t brpgm = t swpgm + 31 ⋅ t bwpgm Row programming is more than 2 times faster than single word programming. B.5.1.3 Sector Erase Erasing a 512 byte Flash sector takes: 1 t era ≈ 4000 ⋅ --------------------f NVMOP The setup times can be ignored for this operation. 129 Device User Guide — 9S12E128DGV1/D V01.04 B.5.1.4 Mass Erase Erasing a NVM block takes: 1 t mass ≈ 20000 ⋅ --------------------f NVMOP The setup times can be ignored for this operation. B.5.1.5 Blank Check The time it takes to perform a blank check on the Flash is dependant on the location of the first non-blank word starting at relative address zero. It takes one bus cycle per word to verify plus a setup of the command. t check ≈ location ⋅ t cyc + 10 ⋅ t cyc Table B-5 NVM Timing Characteristics Conditions are shown in Table A-4 unless otherwise noted Num C 1 D 2 Rating Symbol Min Typ Max Unit External Oscillator Clock fNVMOSC 0.5 501 MHz D Bus frequency for Programming or Erase Operations fNVMBUS 1 3 D Operating Frequency fNVMOP 150 200 kHz 4 P Single Word Programming Time tswpgm 462 74.53 µs 5 D Flash Burst Programming consecutive word tbwpgm 20.42 313 µs 6 D Flash Burst Programming Time for 32 Words tbrpgm 678.42 1035.53 µs 7 P Sector Erase Time tera 204 26.73 ms 8 P Mass Erase Time tmass 1004 1333 ms 9 D Blank Check Time Flash per block t check 115 327786 tcyc MHz NOTES: 1. Restrictions for oscillator in crystal mode apply! 2. Minimum Programming times are achieved under maximum NVM operating frequency f NVMOP and maximum bus frequency fbus. 3. Maximum Erase and Programming times are achieved under particular combinations of f NVMOP and bus frequency f bus. Refer to formulae in Sections A.3.1.1 - A.3.1.4 for guidance. 4. Minimum Erase times are achieved under maximum NVM operating frequency f NVMOP. 5. Minimum time, if first word in the array is not blank 6. Maximum time to complete check on an erased block. B.5.2 NVM Reliability The reliability of the NVM blocks is guaranteed by stress test during qualification, constant process monitors and burn-in to screen early life failures. 130 Device User Guide — 9S12E128DGV1/D V01.04 The failure rates for data retention and program/erase cycling are specified at
MC9S12E128CPV 价格&库存
很抱歉,暂时无法提供与“MC9S12E128CPV”相匹配的价格&库存,您可以联系我们找货
