GS1D
GS1D
    SMCDIODESOLUTIONS(桑德斯)
    SMA(DO-214AC)
    SMT GLASS PASSIVATED RECTIFIER
GS1D 数据手册
GS1A-GS1M Technical Data Data Sheet N0553, Rev. B GS1A THRU GS1M 1.0A SURFACE MOUNT GLASS PASSIVATED RECTIFIER Features Glass Passivated Die Construction Ideally Suited for Automatic Assembly Low Forward Voltage Drop Low Power Loss Built-in Strain Relief Plastic Case Material has UL Flammability Classification Rating 94V-0 This is a Pb − Free Device “-HF” suffix is for Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request           SMA Circuit Diagram Mechanical Data      Case: SMA molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.06 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol GS1A GS1B GS1D GS1G GS1J GS1K GS1M Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Average Rectified Output Current @TL= 100°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) Forward Voltage @ IF = 1.0 A IO 1.0 A IFSM 30 A VF 1.10 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IRM 5.0 200 μA Reverse Recovery Time(Note1) trr 2.5 μS Typical Junction Capacitance(Note2) CJ 15 pF Typical Thermal Resistance Junction to Lead (Note 3) RθJL 30 °C/W Operating and Storage Temperature Range TJ,TSTG -65 to +175 Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Mounted on P.C.B.with 8.0mm² land areas.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  °C GS1A-GS1M Technical Data Data Sheet N0553, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  GS1A-GS1M Technical Data Data Sheet N0553, Rev. B Mechanical Dimensions SMA SYMBOL Ordering Information Device GS1A-GS1M GS1ATR-GS1MTR Package SMA SMA Millimeters Inches Min. Max. Min. Max. A 2.40 2.84 0.094 0.112 B 3.99 4.75 0.157 0.187 C 1.05 1.70 0.041 0.067 D 0.15 0.51 0.006 0.020 E 4.80 5.66 0.189 0.223 F 1.90 2.95 0.075 0.116 G 0.05 0.203 0.002 0.008 H 0.76 1.52 0.030 0.600 Marking Diagram Shipping 5000pcs / reel 5000pcs / reel First row: Part Number (GS1A, GS1B, GS1D, GS1G, GS1J, GS1K, GS1M) Second row: YYWWL HF is Halogen Free YY is the manufacture year, WW is the manufacture week code, L is the wafer’s Lot Number For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Carrier Tape Specification SMA SYMBOL A B C d E F P P0 P1 T W Min. 2.97 5.70 2.32 1.40 1.40 5.60 3.90 3.90 1.90 0.25 Millimeters Max. 11.80  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  3.17 5.90 2.52 1.60 1.60 5.70 4.10 4.10 2.10 0.35 12.20 GS1A-GS1M Technical Data Data Sheet N0553, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
很抱歉,暂时无法提供与“GS1D”相匹配的价格&库存,您可以联系我们找货
