S4M V6G
S4M V6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE GEN PURP 4A DO214AB
S4M V6G 数据手册
S4A – S4M Taiwan Semiconductor 4A, 50V - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High current capability High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 4 A VRRM 50 - 1000 V IFSM 100 A TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.210g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S4A S4B S4D S4G S4J S4K S4M UNIT S4A S4B S4D S4G S4J S4K S4M Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 4 A IFSM 100 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: K2102 S4A – S4M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 13 °C/W Junction-to-ambient thermal resistance RӨJA 47 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage (1) Reverse current @ rated VR IF = 4A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.15 V - 10 µA - 250 µA CJ 60 - pF trr 1500 - ns IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S4x DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 50V(S4A) to 1000V(S4M) 2 Version: K2102 S4A – S4M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 4 CAPACITANCE (pF) 3 2 1 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 1 150 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 1 TJ=25°C 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.6 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.8 0.4 0.5 1.0 0.6 0.7 1.2 0.8 0.9 1.4 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 120 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 0.1 100 (A) AVERAGE FORWARD CURRENT (A) 5 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2102 1.2 S4A – S4M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram 4 Version: K2102 S4A – S4M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: K2102 S4A – S4M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2102
S4M V6G
物料型号:S4A – S4M,由台湾半导体公司生产。
器件简介:这些是表面安装整流器,具有以下特点: - 玻璃钝化芯片结 - 适合自动化放置 - 低正向电压降 - 高电流能力 - 高浪涌电流能力 - 符合J-STD-020标准的1级湿度敏感度 - 符合RoHS标准 - 根据IEC 61249-2-21标准无卤素
引脚分配:文档中提供了DO-214AB (SMC)封装的引脚图,其中阴极和阳极的位置被标记。
参数特性:关键参数包括: - 正向电流(IF):4A - 反向击穿电压(VRRM):50V至1000V - 峰值正向浪涌电流(IFSM):100A - 最大结温(TJMAX):150°C - 封装类型:DO-214AB(SMC) - 配置:单芯片
功能详解:器件适用于开关电源(SMPS)、适配器、照明应用和转换器。
应用信息:适用于开关模式电源供应、适配器、照明应用和转换器。
封装信息:器件采用DO-214AB (SMC)封装,封装材料满足UL 94V-0阻燃等级,引脚为镀锡,可焊性符合J-STD-002标准,并通过JESD 201的2级晶须测试。
S4M V6G 价格&库存
很抱歉,暂时无法提供与“S4M V6G”相匹配的价格&库存,您可以联系我们找货
