M262ZIAAE
M262ZIAAE
    NUVOTON(新唐)
    WFQFN32
    M262ZIAAE
M262ZIAAE 数据手册
M261/M262/M263 Series Arm® Cortex® -M 32-bit Microcontroller NuMicro® Family M261/M262/M263 Series Product Brief Nuvoton is providing this document only for reference purposes of NuMicro microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Mar. 28, 2019 Page 1 of 24 Rev. 1.00 M261/M262/M263 SERIES PRODUCT BRIEF The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. M261/M262/M263 Series 1 GENERAL DESCRIPTION ® ® The NuMicro M261/M262/M263 series is a low-power microcontroller platform based on Arm ® Cortex -M23 core for Armv8-M architecture. It runs up to 64 MHz with 512 Kbytes embedded Flash memory in dual bank mode supporting Over-The-Air (OTA) firmware update and 96 Kbytes embedded SRAM. The 32-bit low-power microcontrollers supports low supply voltage from 1.8 ~ 3.6V and operating temperature range from -40 ~ +105 ℃. Low-power Technology for IoT application Low power and robust security are two major vitals for Internet-of-Things (IoT) applications. The ® NuMicro M261/M262/M263 series provides multi power modes for diverse operating scenarios, such as Power-down mode (PD), Fast Wake-up Power-down mode (FWPD), Low Leakage Power-down mode (LLPD), Ultra Low Leakage Power-down mode (ULLPD), Standby Power® down mode (SPD) and Deep Power-down mode (DPD). The NuMicro M261/M262/M263 series also integrates RTC with independent VBAT voltage source pin to support low power mode with ® main power off and VBAT only. Regarding the power consumption of the NuMicro M261/M262/M263 series, 97 μA/MHz (LDO mode) and 45 μA/MHz (DC-DC mode) in normal run mode, 2.8 μA in Standby Power-down mode, and less than 2μA in Deep Power-down mode. It’s low power, wide supply voltage and fast wake-up features make it suitable for battery-powered IoT applications. Secure Boot - Make sure your products in secure execution ® The NuMicro M261/M262/M263 series provides secure boot function for a system developer to create a secure execution system in the microcontroller. The secure boot is a chain of secure process for verifying each software identity and integrity on the system. Secure boot can help to make sure that a device boots using only software that is trusted by the original developer. When the MCU starts, the firmware checks the signature of boot software, if the signatures are valid, the MCU boots, and the firmware gives control to the operating system. Otherwise, the system will not run at all. M261/M262/M263 SERIES PRODUCT BRIEF eXecute-Only-Memory (XOM) - Protect the intelligent property of developers ® The NuMicro M261/M262/M263 series provides 4-region programable eXecute-Only-Memory (XOM) to secure critical program codes. The AES 256/192/128 hardware accelerator and True Random Number Generator (TRNG) are built-in for data encryption. Up to six tamper detection pins are implemented to avoid malicious damage from hacker. Accompany with 96-bit Unique Identification (UID) and 128-bit Unique Customer Identification (UCID) to enhance the product security. Voltage Adjustable Interface (VAI) - Support 2 nd I/O voltage without level-shifter ® The NuMicro M261/M262/M263 series integrates Voltage Adjustable Interface (VAI), up to 6 I/O nd pins to support the 2 I/O voltage from 1.8 ~ 3.6V to save level shifter components while connecting to external devices. Secure Digital Host Controller (SDHC) ® The NuMicro M261/M262/M263 series integrates one set of Secure Digital Host Controllers (SDHC), compliant with SD Memory Card Specification Version 2.0. It supports 50 MHz to achieve 200 Mbps at 3.3V operation, and dedicated DMA master with Scatter-Gather function to accelerate the data transfer between system memory and SD/SDHC/SDIO card. Rich Pheripherals for comprehensive product application scenarios ® The NuMicro M261/M262/M263 series is equipped with plenty of peripherals such as Timers, Watchdog Timers, RTC, PDMA, External Bus Interface (EBI), Low-power UART, Universal Serial 2 Control Interface (USCI), Qual SPI (QSPI), SPI/I²S, I C, Smart Card Interface (ISO-7816-3), GPIOs, up to 24 channels of PWM, makes it highly suitable for connecting comprehensive ® external modules and LED lighting control. The NuMicro M261/M262/M263 series also integrates high performance analog front-end circuit blocks, such as one 16 channels of 12-bit 3.76 MSPS SAR ADC, two 12-bit 1 MSPS voltage type DAC, two rail-to-rail analog comparator Mar. 28, 2019 Page 2 of 24 Rev. 1.00 M261/M262/M263 Series (ACMP), temperature sensor, low voltage reset (LVR) and brown-out detector (BOD) to enhance product performance, reduce external components and form factor simultaneously. USB 2.0 Full Speed On-The-Go (OTG) supporting Crystal-less function ® ® The part numbers of NuMicro M262/M263 series are all based on NuMicro M261 series, it integrates USB 2.0 Full Speed On-The-Go (OTG) transceiver, compliant with USB OTG Supplement 2.0, can configurable as host-only, device only or ID-dependent. It also integrates ® USB 1.1 Host Controller and USB 2.0 Full Speed Device Controller. The NuMicro M262/M263 series supports crystall-less function that can generate precise frequency required by USB protocol without the need of external crystal, to reduce both the BOM cost and PCB size. Controller Area Network (CAN) ® ® The part numbers of NuMicro M263 series are all based on NuMicro M261 series, it supports one set of CAN 2.0B controllers, the bit rate can be programmed to values up to 1MBit/s. This CAN bus can be set to be one of six paired I/Os by PinConfigure. Available Packages ® The NuMicro M261/M262/M263 series provides 9 product part numbers. The package types of ® NuMicro M261/M262/M263 series includes QFN33 (5mm x 5mm)、LQFP64 (7mm x 7mm) and LQFP128 (14mm x 14mm). Pin-to-pin compatible in same package makes optimizing product features and performance easily Hardware/Software Developing Environment Nuvoton NuMaker M261/M262/M263 evaluation boards (NK-M263KI) and Nu-Link debugger are available for evaluation and product development. 3rd Party IDEs such as Keil MDK, IAR EWARM and NuEclipse IDE with GNU GCC compilers, are also supported. 1.1 M261/M262/M263 Series Key Features 1 1 RTC (VBAT) USB OTG 2 Tamper CAN 1 Crypto LIN 2 DAC (12-bit) SDHC 1 ADC (12-bit) USCI 3 Analog Comp. I2S 4 EBI I2C 1 PDMA SPI/ I2S 3 PWM QSPI 6 Timer ISO-7816-3 Line LPUART Product 4 24 16 V 2 16 2 V 6 V M261/ M262/ M263 ® Table 1-1 NuMicro M261/M262/M263 Series Key Features Support Table ® The NuMicro M261/M262/M263 series is suitable for a wide range of applications such as:  Smart Home / Smart Home Appliance / Smart Door lock  Industrial Control / Industrial Automation  Smart City Facilities / Security Alarm System  IoT Device / Wireless Sensor Node Device / Communication Modules  Electronic Payments  Portable Wireless Data Collector  Handheld Medical Device Mar. 28, 2019 Page 3 of 24 Rev. 1.00 M261/M262/M263 SERIES PRODUCT BRIEF Connectivity M261/M262/M263 Series 2 FEATURES  Operating Characteristics – Supports independent mode for PWM output / Capture input channel – Supports complementary mode for 3 complementary paired PWM output channel – Voltage range: 1.8V ~ 3.6V – Temperature range: -40℃ ~ +105℃  Core ® ® – Arm Cortex -M23 processor, Armv8-M, runs up to 64 MHz – 32-bit hardware multiplier/divider  Memories – – – – – – Dual bank 512KB Flash for OTA upgrade 96KB SRAM 4KB LDROM 4KB Key Protection ROM (KPROM) 4-region eXecute-Only-Memory (XOM) Supports Secure Boot – 4 ~ 24 MHz external high speed crystal oscillator (HXT) for precise timing operation – 32.768 kHz external low speed crystal oscillator (LXT) for RTC function and lowpower system operation – 12 MHz internal high speed RC oscillator (HIRC) for system operation (After auto-trim ± 0.25%) – 48 MHz internal high speed RC oscillator (HIRC48) for system operation (After auto-trim ±0.25%) – 10 kHz internal low speed RC oscillator (LIRC) for Watchdog Timer and wake-up operation – 32 kHz internal low speed RC oscillator (LIRC32) for RTC function M261/M262/M263 SERIES PRODUCT BRIEF  Power management – Dual voltage regulator is available for DC-DC converter or LDO – Supports 1.2V and 0.9V core voltage – Supports Power-down mode, Standby Powerdown mode, Low Leakage Power-down mode, Ultra Low Leakage Power-down mode, Fast Wake-up Power-down mode, and Deep Power-down mode – Supports external power pin VBAT (Standalone VBAT for RTC power domain)  Low Power Consumption – 97 μA/MHz (LDO) and 45 μA/MHz (DC-DC) in operating mode – 2.8 μA in Standby Power-down mode – Less than 2 μA in Deep Power-down mode  RTC – 80 bytes of battery-powered backup registers, which can be cleared by tamper pins – Supports 6 static and dynamic tamper pins – Up to four 32-bit timers  PDMA – Up to 16 channels  PWM – Up to 24-channels PWM – Supports trigger ADC or DAC Mar. 28, 2019 – Up to 16 channels 12-bit 3.76 MSPS ADC – Up to 2 sets of rail-to-rail comparators (ACMP) – Up to 2 sets of 12-bit 1 MSPS voltage type DAC – Supports external VREF pin or internal reference voltage VREF: 1.6V, 2.0V, 2.5V, and 3.0V  Communication interfaces  Clocks  Timers  Analog – – – – – – – – Up to 6 sets of LPUART interface Up to 3 sets of I²C interface Up to 1 set of QSPI interface Up to 4 sets of SPI/I²S interface (Configured as SPI or I²S) Up to 3 sets of Smart Card Interface (ISO7816-3, ISO-7816-3 supports full duplex UART mode) Up to 2 sets of USCI (Configured as UART, SPI or I²C) Up to 1 set of Secure Digital Host Controllers (SDHC), compliant with SD Memory Card Specification Version 2.0 16/8-bits EBI (External Bus Interface) interface  VAI (Voltage Adjustable Interface) nd – Up to 6 I/O pins to support the 2 I/O voltage from 1.8 ~ 3.6V, applied voltage to the VDDIO pin  USB 2.0 Full Speed OTG (Crystal-less) – USB 2.0 Full Speed OTG (On-The-Go) – USB 1.1 Host Controller – USB 2.0 Full Speed Device Controller  CAN (Controller Area Network) – Supports 1 set of CAN 2.0B controller – Supports power-down wake-up function  Utility Support ® – Arm Keil MDK and IAR EWARM IDE support for debugging – Free GNU compiler with NuEclipse IDE support – ICP (In Circuit Programmer) support for updating internal code via Nu-Link debugger – PinView for real time monitor the status of all IO pins – PinConfigure tool for pin assignment, initial code generation and OrCAD/Protel part generation – ClockConfigure tool for generating the initial source code of system clock  96-bit Unique ID (UID)  128-bit Unique Customer ID (UCID)  Packages – QFN33 (5mm x 5mm), LQFP64 (7mm x 7mm), LQFP128 (14mm x 14mm) Page 4 of 24 Rev. 1.00 M261/M262/M263 Series 3 BLOCK DIAGRAM M261/M262/M263 SERIES PRODUCT BRIEF Figure 3-1 NuMicro® M261/M262/M263 Block Diagram Mar. 28, 2019 Page 5 of 24 Rev. 1.00 M261/M262/M263 Series 4 PARTS INFORMATION 4.1 M261/M262/M263 Series Naming Rule M2 61 Z I A A E Core Line Package Flash SRAM Reserve Temperature Cortex®M23 61: Control Z: QFN33 62: USB (5x5 mm) 63: USB/CAN S: LQFP64 I: 512 KB A: 96 KB E: -40℃ ~ +105℃ (7x7 mm) K: LQFP128 (14x14 mm) M261/M262/M263 SERIES PRODUCT BRIEF Mar. 28, 2019 Page 6 of 24 Rev. 1.00 M261/M262/M263 Series 4.2 M261/M262/M263 Series Selection Guide 4.2.1 M261 Control Series M261 PART NUMBER ZIAAE SIAAE Flash (KB) 512 SRAM (KB) 96 ISP Loader ROM (KB) 4 I/O 25 51 32-bit Timer Tamper - 1 V LPUART 6 ISO-7816-3 3* Quad SPI 1 SPI/I S 107 4 RTC 2 KIAAE 3 4 Connectivity I2S 6 4 1 2 3 USCI** 2 LIN 2 CAN - SDHC 1 16-bit EPWM 12 16-bit BPWM 12 QEI 1 2 2 ECAP - 1 2 USB 2.0 FS OTG 12-bit ADC 9 16 12-bit DAC 2 Analog Comparator 2 Cryptography V External Bus Interface Package M261/M262/M263 SERIES PRODUCT BRIEF IC 16 - V V QFN 33 LQFP 64 LQFP 128 Note: * ISO-7816-3 supports full duplex UART mode ** USCI can be configured as UART, SPI or I²C Mar. 28, 2019 Page 7 of 24 Rev. 1.00 M261/M262/M263 Series 4.2.2 M262 USB Series M262 PART NUMBER ZIAAE SIAAE Flash (KB) 512 SRAM (KB) 96 ISP Loader ROM (KB) 4 I/O 25 51 32-bit Timer Tamper 107 4 - 1 RTC V LPUART 6 ISO-7816-3 3* Quad SPI 1 SPI/I2S KIAAE 3 4 Connectivity M261/M262/M263 SERIES PRODUCT BRIEF 2 IS 1 I2C 3 USCI** 2 LIN 2 CAN - SDHC 1 16-bit EPWM 12 16-bit BPWM 12 6 4 QEI 1 2 2 ECAP - 1 2 USB 2.0 FS OTG 12-bit ADC V 9 16 12-bit DAC 2 Analog Comparator 2 Cryptography V External Bus Interface Package 16 - V V QFN 33 LQFP 64 LQFP 128 Note: * ISO-7816-3 supports full duplex UART mode ** USCI can be configured as UART, SPI or I²C Mar. 28, 2019 Page 8 of 24 Rev. 1.00 M261/M262/M263 Series 4.2.3 M263 USB/CAN Series M263 PART NUMBER ZIAAE SIAAE Flash (KB) 512 SRAM (KB) 96 ISP Loader ROM (KB) 4 I/O 25 51 32-bit Timer Tamper 107 4 - 1 RTC V LPUART 6 ISO-7816-3 3* Quad SPI 1 SPI/I2S KIAAE 3 4 Connectivity IS 1 I2C 3 USCI** 2 LIN 2 CAN 1 SDHC 1 16-bit EPWM 12 16-bit BPWM 12 4 QEI 1 2 2 ECAP - 1 2 USB 2.0 FS OTG 12-bit ADC V 9 16 12-bit DAC 2 Analog Comparator 2 Cryptography V External Bus Interface Package M261/M262/M263 SERIES PRODUCT BRIEF 2 6 16 - V V QFN 33 LQFP 64 LQFP 128 Note: * ISO-7816-3 supports full duplex UART mode ** USCI can be configured as UART, SPI or I²C Mar. 28, 2019 Page 9 of 24 Rev. 1.00 M261/M262/M263 Series PIN CONFIGURATION VSS 25 Vsw PA.15 PA.14 PA.13 PA.12 PC.0 PC.1 PF.1 PF.0 23 22 21 20 19 18 17 M261 Series QFN 33-Pin Diagram 24 nRESET 26 15 VDDIO VDD 27 14 PA.0 LDO_CAP 28 13 PA.1 PB.14 29 12 PA.2 PB.13 30 11 PA.3 PB.12 31 10 PF.2 9 PF.3 QFN33 33 VSS 3 4 5 6 7 8 PB.2 PB.1 PB.0 PF.5 PF.4 32 PB.3 AVDD Top transparent view 2 M261/M262/M263 SERIES PRODUCT BRIEF 16 PB.4 5.1.1 M261 Series Pin Diagram 1 5.1 PB.5 5 VDDIO power domain Figure 5-1 M261 Series QFN 33-pin Diagram Mar. 28, 2019 Page 10 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.0 PD.1 PD.2 PD.3 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 M261 Series LQFP 64-Pin Diagram 48 5.1.2 VSS 49 32 nRESET Vsw 50 31 VDDIO VDD 51 30 PA.0 LDO_CAP 52 29 PA.1 PB.15 53 28 PA.2 PB.14 54 27 PA.3 PB.13 55 26 PA.4 PB.12 56 25 PA.5 AVDD 57 24 LDO_CAP VREF 58 23 VDD LQFP64 12 13 14 15 16 VBAT PF.5 PF.4 PF.3 PA.9 PF.6 10 PA.10 11 9 PA.11 VDDIO power domain PA.8 8 PF.2 7 PB.7 PB.0 PC.7 17 PB.1 18 64 6 63 5 PB.8 PB.2 PC.6 PB.3 PA.7 19 4 20 62 3 61 PB.9 PB.4 PB.10 2 PA.6 1 VSS 21 PB.5 22 60 PB.6 59 M261/M262/M263 SERIES PRODUCT BRIEF AVSS PB.11 VBAT power domain ® Figure 5-2 NuMicro M261 Series LQFP 64-pin Diagram Mar. 28, 2019 Page 11 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.13 PD.0 PD.1 PD.2 PD.3 PD.4 PD.5 PD.6 PD.7 PG.15 PG.14 PG.13 PG.12 PG.11 PG.10 PG.9 VDD VSS PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PD.8 PD.9 PF.1 PF.0 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 M261 Series LQFP 128-Pin Diagram 96 5.1.3 97 64 nRESET PE.6 98 63 PE.15 PE.5 99 62 PE.14 PE.4 100 61 VDDIO PE.3 101 60 PA.0 PE.2 102 59 PA.1 VSS 103 58 PA.2 VDD 104 57 PA.3 PE.1 105 56 PA.4 PE.0 106 55 PA.5 PH.8 107 54 LDO_CAP PH.9 108 53 VDD PH.10 109 52 VSS PH.11 110 51 PA.6 PD.14 111 50 PA.7 VSS 112 49 PC.6 Vsw 113 48 PC.7 VDD 114 47 PC.8 LDO_CAP 115 46 PE.13 PB.15 116 45 PE.12 PB.14 117 44 PE.11 PB.13 118 43 PE.10 PB.12 119 42 PE.9 AVDD 120 41 PE.8 VREF 121 40 VDD AVSS 122 39 VSS PB.11 123 38 PF.2 PB.10 124 37 PF.3 PB.9 125 36 PH.7 PB.8 126 35 PH.6 PB.7 127 34 PH.5 PB.6 128 33 PH.4 22 23 24 25 26 27 28 29 30 31 32 PG.3 PG.4 PF.11 PF.10 PF.9 PF.8 PF.7 PF.6 VBAT PF.5 PF.4 18 PD.12 21 17 PC.13 PG.2 16 PA.8 20 15 PA.9 PD.10 14 PA.10 19 13 PA.11 VDDIO power domain PD.11 12 8 PC.9 VDD 7 PC.10 11 6 PC.11 VSS 5 PC.12 10 4 PB.2 PB.0 3 PB.3 9 2 PB.1 1 PB.4 LQFP128 PB.5 M261/M262/M263 SERIES PRODUCT BRIEF PE.7 VBAT power domain ® Figure 5-3 NuMicro M261 Series LQFP 128-pin Diagram Mar. 28, 2019 Page 12 of 24 Rev. 1.00 M261/M262/M263 Series VSS 25 Vsw PA.15 PA.14 PA.13 PA.12 PC.0 PC.1 PF.1 PF.0 24 23 22 21 20 19 18 17 M262 Series QFN 33-Pin Diagram nRESET 26 15 VDDIO VDD 27 14 PA.0 LDO_CAP 28 13 PA.1 PB.14 29 12 PA.2 PB.13 30 11 PA.3 PB.12 31 10 PF.2 9 PF.3 33 VSS 2 3 4 5 6 7 8 PB.3 PB.2 PB.1 PB.0 PF.5 PF.4 32 PB.4 AVDD QFN33 M261/M262/M263 SERIES PRODUCT BRIEF 16 Top transparent view 1 5.2.1 M262 Series Pin Diagram PB.5 5.2 VDDIO power domain USB function pins ® Figure 5-4 NuMicro M262 Series QFN 33-pin Diagram Mar. 28, 2019 Page 13 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.0 PD.1 PD.2 PD.3 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 M262 Series LQFP 64-Pin Diagram 48 5.2.2 49 32 nRESET Vsw 50 31 VDDIO VDD 51 30 PA.0 LDO_CAP 52 29 PA.1 PB.15 53 28 PA.2 PB.14 54 27 PA.3 PB.13 55 26 PA.4 PB.12 56 25 PA.5 AVDD 57 24 LDO_CAP VREF 58 23 VDD AVSS 59 22 VSS PB.11 60 21 PA.6 PB.10 61 20 PA.7 PB.9 62 19 PC.6 PB.8 63 18 PC.7 PB.7 64 17 PF.2 16 PF.3 PA.9 15 10 PA.10 14 9 PA.11 PF.4 8 PB.0 PF.5 7 PB.1 13 6 PB.2 12 5 PB.3 VBAT 4 PF.6 3 PB.4 11 2 VDDIO power domain PA.8 1 PB.5 LQFP64 PB.6 M261/M262/M263 SERIES PRODUCT BRIEF VSS VBAT power domain USB function pins ® Figure 5-5 NuMicro M262 Series LQFP 64-pin Diagram Mar. 28, 2019 Page 14 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.13 PD.0 PD.1 PD.2 PD.3 PD.4 PD.5 PD.6 PD.7 PG.15 PG.14 PG.13 PG.12 PG.11 PG.10 PG.9 VDD VSS PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PD.8 PD.9 PF.1 PF.0 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 M262 Series LQFP 128-Pin Diagram 96 5.2.3 97 64 nRESET PE.6 98 63 PE.15 PE.5 99 62 PE.14 PE.4 100 61 VDDIO PE.3 101 60 PA.0 PE.2 102 59 PA.1 VSS 103 58 PA.2 VDD 104 57 PA.3 PE.1 105 56 PA.4 PE.0 106 55 PA.5 PH.8 107 54 LDO_CAP PH.9 108 53 VDD PH.10 109 52 VSS PH.11 110 51 PA.6 PD.14 111 50 PA.7 VSS 112 49 PC.6 Vsw 113 48 PC.7 VDD 114 47 PC.8 LDO_CAP 115 46 PE.13 PB.15 116 45 PE.12 PB.14 117 44 PE.11 PB.13 118 43 PE.10 PB.12 119 42 PE.9 AVDD 120 41 PE.8 VREF 121 40 VDD AVSS 122 39 VSS PB.11 123 38 PF.2 PB.10 124 37 PF.3 PB.9 125 36 PH.7 PB.8 126 35 PH.6 PB.7 127 34 PH.5 PB.6 128 33 PH.4 22 23 24 25 26 27 28 29 30 31 32 PG.3 PG.4 PF.11 PF.10 PF.9 PF.8 PF.7 PF.6 VBAT PF.5 PF.4 18 PD.12 21 17 PC.13 PG.2 16 PA.8 20 15 PA.9 PD.10 14 PA.10 19 13 PA.11 VDDIO power domain PD.11 12 8 PC.9 VDD 7 PC.10 11 6 PC.11 VSS 5 PC.12 10 4 PB.2 PB.0 3 PB.3 9 2 PB.4 PB.1 1 PB.5 LQFP128 VBAT power domain USB function pins ® Figure 5-6 NuMicro M262 Series LQFP 128-pin Diagram Mar. 28, 2019 Page 15 of 24 Rev. 1.00 M261/M262/M263 SERIES PRODUCT BRIEF PE.7 M261/M262/M263 Series VSS 25 Vsw PA.15 PA.14 PA.13 PA.12 PC.0 PC.1 PF.1 PF.0 24 23 22 21 20 19 18 17 M263 Series QFN 33-Pin Diagram nRESET 26 15 VDDIO VDD 27 14 PA.0 LDO_CAP 28 13 PA.1 PB.14 29 12 PA.2 PB.13 30 11 PA.3 PB.12 31 10 PF.2 9 PF.3 QFN33 33 VSS 3 4 5 6 7 8 PB.3 PB.2 PB.1 PB.0 PF.5 PF.4 32 2 AVDD Top transparent view PB.4 M261/M262/M263 SERIES PRODUCT BRIEF 16 1 5.3.1 M263 Series Pin Diagram PB.5 5.3 VDDIO power domain USB function pins CAN function pins ® Figure 5-7 NuMicro M263 Series QFN 33-pin Diagram Mar. 28, 2019 Page 16 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.0 PD.1 PD.2 PD.3 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 M263 Series LQFP 64-Pin Diagram 48 5.3.2 49 32 nRESET Vsw 50 31 VDDIO VDD 51 30 PA.0 LDO_CAP 52 29 PA.1 PB.15 53 28 PA.2 PB.14 54 27 PA.3 PB.13 55 26 PA.4 PB.12 56 25 PA.5 AVDD 57 24 LDO_CAP VREF 58 23 VDD AVSS 59 22 VSS PB.11 60 21 PA.6 PB.10 61 20 PA.7 PB.9 62 19 PC.6 PB.8 63 18 PC.7 PB.7 64 17 PF.2 16 PF.3 PA.9 15 10 PA.10 14 9 PA.11 PF.4 8 PB.0 PF.5 7 PB.1 13 6 PB.2 12 5 PB.3 VBAT 4 PF.6 3 PB.4 11 2 PB.5 PA.8 1 PB.6 LQFP64 VDDIO power domain VBAT power domain USB function pins CAN function pins M261/M262/M263 SERIES PRODUCT BRIEF VSS ® Figure 5-8 NuMicro M263 Series LQFP 64-pin Diagram Mar. 28, 2019 Page 17 of 24 Rev. 1.00 M261/M262/M263 Series PA.15 PA.14 PA.13 PA.12 PD.13 PD.0 PD.1 PD.2 PD.3 PD.4 PD.5 PD.6 PD.7 PG.15 PG.14 PG.13 PG.12 PG.11 PG.10 PG.9 VDD VSS PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PD.8 PD.9 PF.1 PF.0 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 M263 Series LQFP 128-Pin Diagram 97 64 nRESET PE.6 98 63 PE.15 PE.5 99 62 PE.14 PE.4 100 61 VDDIO PE.3 101 60 PA.0 PE.2 102 59 PA.1 VSS 103 58 PA.2 VDD 104 57 PA.3 PE.1 105 56 PA.4 PE.0 106 55 PA.5 PH.8 107 54 LDO_CAP PH.9 108 53 VDD PH.10 109 52 VSS PH.11 110 51 PA.6 PD.14 111 50 PA.7 VSS 112 49 PC.6 Vsw 113 48 PC.7 VDD 114 47 PC.8 LDO_CAP 115 46 PE.13 PB.15 116 45 PE.12 PB.14 117 44 PE.11 PB.13 118 43 PE.10 PB.12 119 42 PE.9 AVDD 120 41 PE.8 VREF 121 40 VDD AVSS 122 39 VSS PB.11 123 38 PF.2 PB.10 124 37 PF.3 PB.9 125 36 PH.7 PB.8 126 35 PH.6 PB.7 127 34 PH.5 PB.6 128 33 PH.4 22 23 24 25 26 27 28 29 30 31 32 PG.3 PG.4 PF.11 PF.10 PF.9 PF.8 PF.7 PF.6 VBAT PF.5 PF.4 18 PD.12 21 17 PC.13 PG.2 16 PA.8 20 15 PA.9 PD.10 14 PA.10 19 13 PA.11 PD.11 12 8 PC.9 VDD 7 PC.10 11 6 PC.11 VSS 5 PC.12 10 4 PB.2 PB.0 3 PB.3 9 2 PB.1 1 LQFP128 PB.4 M261/M262/M263 SERIES PRODUCT BRIEF PE.7 PB.5 5.3.3 VDDIO power domain VBAT power domain USB function pins CAN function pins ® Figure 5-9 NuMicro M263 Series LQFP 128-pin Diagram Mar. 28, 2019 Page 18 of 24 Rev. 1.00 M261/M262/M263 Series 6 UTILITIES 6.1 Programmer and Debugger Nu-Link Basic full speed USB2.0 hardware debugger/programmer Nu-Link-Pro Advance hardware debugger/programmer with programming counter Nu-Link 2.0 Advance high speed USB2.0 hardware debugger/programmer with multi-functions Nu-Link-Gang Off-line hardware programmer supports up to four chips programming for mass-production ISP In system programming, a software programming tool support UART/USB ICP In Chip Programming, a software programming tool support Nu-Link programmer 6.2 Development Environment Programming IDE Keil MDK, IAR, NuEclipse(GCC) Software Package Board Support Package(BSP), Sample Code, Development IDE NuTool PinView, NuTool PinConfig, NuTool ClockConfig, NuConsole RTOS Mbed, FreeRTOS, Amazon FreeRTOS, Ali-OS HMI Support emWin with font create tool and easy GUI builder Programming IDE Keil MDK, IAR, NuEclipse(GCC) EVB NuMaker Part Number Feature M261ZIAAE, M261SIAAE, M261KIAAE, NK-M263KI M262ZIAAE, M262SIAAE, M262KIAAE, Support Expand Connector, Arduino Uno Interface M263ZIAAE, M263SIAAE, M263KIAAE, Mar. 28, 2019 Page 19 of 24 Rev. 1.00 M261/M262/M263 SERIES PRODUCT BRIEF 6.3 Development Board M261/M262/M263 Series 7 PACKAGE DIMENSIONS 7.1 QFN 33-pin (5X5x0.8 mm3, Pitch: 0.50 mm) M261/M262/M263 SERIES PRODUCT BRIEF Mar. 28, 2019 Page 20 of 24 Rev. 1.00 M261/M262/M263 Series 7.2 LQFP 64-pin (7x7x1.4 mm3, footprint 2.0mm) M261/M262/M263 SERIES PRODUCT BRIEF Mar. 28, 2019 Page 21 of 24 Rev. 1.00 M261/M262/M263 Series 7.3 LQFP 128-pin (14x14x1.4 mm3, footprint 2.0mm) M261/M262/M263 SERIES PRODUCT BRIEF Mar. 28, 2019 Page 22 of 24 Rev. 1.00 M261/M262/M263 Series 8 REVISION HISTORY Date Revision Description 2019.02.14 0.10 Preliminary version 2019.03.28 1.00 Initial version M261/M262/M263 SERIES PRODUCT BRIEF Mar. 28, 2019 Page 23 of 24 Rev. 1.00 M261/M262/M263 Series M261/M262/M263 SERIES PRODUCT BRIEF Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Mar. 28, 2019 Page 24 of 24 Rev. 1.00
M262ZIAAE 价格&库存
很抱歉,暂时无法提供与“M262ZIAAE”相匹配的价格&库存,您可以联系我们找货
M262ZIAAE
    • 1+12.81960
    库存:5
