S5MBHM4G
S5MBHM4G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
S5MBHM4G 数据手册
S5GB – S5MB Taiwan Semiconductor 5A, 400V - 1000V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 5 A VRRM 400 - 1000 V IFSM 200 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Monitor TV MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S5GB S5JB S5KB S5MB UNIT S5GB S5JB S5KB S5MB Repetitive peak reverse voltage VRRM 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 280 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Surge peak forward current, 1.0ms single half sine-wave superimposed on rated load IF TJ = 25°C TJ = 125°C TJ = 25°C IFSM TJ = 125°C 5 A 200 A 150 A 540 A 290 A Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2102 S5GB – S5MB Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 47 °C/W Junction-to-lead thermal resistance RӨJL 13 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 5A, TJ = 25°C (2) Junction capacitance TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V SYMBOL TYP MAX UNIT VF - 1.1 V - 10 μA - 250 μA 40 - pF IR CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S5xB DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 400V(S5GB) to 1000V(S5MB) 2 Version: D2102 S5GB – S5MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 5 CAPACITANCE (pF) 4 3 2 10 1 f=1.0MHz Vsig=50mVp-p 0 1 0 25 50 75 100 125 150 1 10 100 LEAD TEMPERATURE(°C) REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 100 TJ=125°C 10 1 TJ=25°C 0.1 10 0.1 20 30 40 50 60 70 80 90 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) 100 100 10 TJ=125°C TJ=125°C 10 TJ=25°C 0.1 TJ=25°C 10.01 0.001 0.3 0.1 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 1 (A) AVERAGE FORWARD CURRENT (A) 6 0.6 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 Pulse width Pulse Width=300μs 1% Duty Cycle 0.8 0.9 1 1.1 1.1 1.2 1.3 1.4 FORWARD VOLTAGE (V) 3 Version: D2102 1.2 S5GB – S5MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 240 8.3ms single half sine wave 200 160 120 80 40 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: D2102 S5GB – S5MB Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: D2102 S5GB – S5MB Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: D2102
S5MBHM4G 价格&库存
很抱歉,暂时无法提供与“S5MBHM4G”相匹配的价格&库存,您可以联系我们找货
