SK32B – SK320B
Taiwan Semiconductor
3A, 20V - 200V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
20 - 200
V
IFSM
70
A
TJ MAX
125, 150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.100g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SK SK SK SK SK SK SK
32B 33B 34B 35B 36B 39B 310B
SK
SK
SK
SK
SK
SK
SK
40
50
60
90
100
14
21
28
35
42
63
70
SK
SK
UNIT
315B 320B
SK
SK
315B 320B
150 200
V
105
140
V
IF
3
A
IFSM
70
A
dV/dt
10,000
V/μs
TJ
- 55 to +125
TSTG
- 55 to +150
- 55 to +150
1
°C
°C
Version: O2102
SK32B – SK320B
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
23
°C/W
Junction-to-ambient thermal resistance
RӨJA
63
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.50
V
0.75
V
0.85
V
0.95
V
500
µA
100
µA
10
mA
5
mA
mA
mA
mA
2
mA
SK32B
SK33B
SK34B
SK35B
Forward voltage
(1)
SK36B
IF = 3A, TJ = 25°C
VF
SK39B
SK310B
SK315B
SK320B
Reverse current @ rated VR
(2)
(2)
(2)
SK32B
SK33B
SK34B
SK35B
SK36B
SK39B
SK310B
SK315B
SK320B
SK32B
SK33B
SK34B
SK35B
SK36B
SK39B
SK310B
SK315B
SK320B
SK32B
SK33B
SK34B
SK35B
SK36B
SK39B
SK310B
SK315B
SK320B
TJ = 25°C
IR
TJ = 100°C
TJ = 125°C
IR
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: O2102
SK32B – SK320B
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SK3xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 20V(SK32B) to 200V(SK320B)
3
Version: O2102
SK32B – SK320B
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SK32B - SK34B
SK35B - SK320B
SK35B - SK36B
3
2
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
4
SK32B - SK34B
1
100
SK39B - SK320B
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
Fig.4 Typical Forward Characteristics
SK32B-SK34B
SK35B-SK320B
10
TJ=125oC
1
0.1
TJ=75oC
0.01
0.001
40
50
60
70
80
90
100
100
10
10 1
TJ=125°C
1
TJ=25°C
0.1
TJ=25oC
0.01
0.1
0.001
0.3
0.01
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
TJUF1DLW
=125oC
(A)
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
TJ=25oC
10
0.4
0.2
0.5
0.4
0.6
0.6
Pulse width
SK32B-SK34B
SK35B-SK36B
SK39B-SK320B
0.7
0.8
0.9
1
1.1
0.8
1
1.2
1.4
FORWARD VOLTAGE (V)
4
Version: O2102
1.2
SK32B – SK320B
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
80
70
8.3ms single half sine wave
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
T-PULSE DURATION(s)
5
Version: O2102
SK32B – SK320B
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: O2102
SK32B – SK320B
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: O2102
很抱歉,暂时无法提供与“SK39B R5G”相匹配的价格&库存,您可以联系我们找货
