NJM2717
SINGLE SUPPLY HI-SLEW RATE DUAL OPERATIONAL AMPLIFER
■GENERAL DESCRIPTION
The NJM2717 is a high slew rate single supply dual operational
amplifier. It offers excellent features of a 40V/us (typ.) high slew rate
in a single supply and low operating voltage from 2.7V, which provide
a benefit to buffer, filter and ground level signal detection circuit
design. Therefore The NJM2717 is suitable for CCD buffer and
AD/DA converter buffer using in facsimile/scanner, current detector in
inverter controller, PWM motor controller and Tuner/Communication
devices.
The NJM2717 is available in a wide variety packages 8-lead DIP,
and 8-lead surface-mount packages of SOP (DMP), SSOP and
MSOP (TVSP).
■ FEATURES
●Single Supply
●Operating Voltage
●High Slew Rate
●Operating Current
●Output Voltage Range
●Bipolar Technology
●Package Outline
■ PACKAGE OUTLINE
NJM2717D
(DIP8)
NJM2717V
(SSOP8)
NJM2717M
(DMP8)
NJM2717RB1
(MSOP8 (TVSP8))
2.7V to 12V
40V/µs Typ. (at V+=5V)
8mA typ. (at V+=5V)
VOH ≥4.5V Typ. (at V+=5V, RL=4kΩ)
VOL ≤0.05V Typ. (at V+=5V, RL=4kΩ)
DIP8,
DMP8,
SSOP8,
MSOP8 (TVSP8)
■ PIN CONFIGRATION
1
8
2
7
3
6
4
5
MEET JEDEC MO-187-DA / THIN TYPE
PIN FUNCTION
1. A OUTPUT
2. A -INPUT
3. A +INPUT
4. GND
5. B +INPUT
6. B –INPUT
7. B OUTPUT
8. V+
NJM2717D
NJM2717M
NJM2717V
NJM2717RB1
(Top View)
Ver.2012-09-14
-1-
NJM2717
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
Supply Voltage
Differential Input Voltage
Input Common Mode
Voltage Range
Power Dissipation
Output Sink Current
Operating Temperature Range
Storage Temperature Range
SYMBOL
V+
V ID
V ICM
PD
I SI NK
T opr
T st g
(Ta=25˚C )
RATINGS
15.0
± 3
-0.3 to +15.0(Note 1)
(DIP8) 500
(DMP8) 300
(SSOP8) 250
(MSOP8 (TVSP8)) 320
10
-40 to +85
-40 to +125
UNIT
V
V
V
mW
mA
˚C
˚C
(Note 1) For supply voltage less than 15V, the absolute maximum input voltage is equal to the supply voltage.
■ RECOMMENDED OPERATING CONDITION
PARAMETER
Supply Voltage
SYMBOL
V+
(Ta=25˚C )
RATING
2.7 to 12.0
UNIT
V
■ ELECTRICAL CHARACTERISTICS
●DC CHARACTERISTICS
PARAMETER
Operating Current
Input Offset Voltage
Input Bias Current
Input Offset Current
Voltage Gain
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Output Voltage 1
Output Voltage 2
Output Source Current
Output Sink Current
Input Common Mode
Voltage Range
SYMBOL
I CC
V IO
IB
I IO
AV
CMR
SVR
V OH 1
V OL 1
V OH 2
V OL 2
(V+=5V,Ta=25˚C )
TEST CONDITION
R L =∞, no signal
R S =0Ω
R L ≥ 10kΩ, VO=1.5V to 3.5V
0V ≤ V CM ≤ 3.8V
V + =4V to 8V
R L =4kΩ to GND
R L =4kΩ to 2.5V
I SO URCE
I SI NK
V ICM
MIN
TYP
MAX
UNIT
60
45
50
4.3
4.5
1
2.5
0 to 3.8
8.0
1
2
0.2
75
80
85
4.5
0.05
4.7
0.1
2.5
6
11.0
11
4.4
0.5
0.1
0.5
mA
mV
µA
µA
dB
dB
dB
V
V
V
V
mA
mA
V
(V+=5V,Ta=25˚C )
●AC CHARACTERISTICS
PARAMETER
Unity Gain Bandwidth
SYMBOL
TEST CONDITION
fT
MIN
TYP
MAX
UNIT
MHz
(V+=5V,Ta=25˚C )
●TRANSIENT CHARACTERISTICS
PARAMETER
Slew Rate
-2-
SYMBOL
SR
TEST CONDITION
MIN
TYP
MAX
UNIT
40
V/µs
Ver.2012-09-14
NJM2717
●DC CHARACTERISTICS
PARAMETER
Operating Current
Input Bias Current
Voltage Gain
Output Voltage 1
Output Voltage 2
Output Sink Current
Input Common Mode
Voltage Range
SYMBOL
I CC
V IO
IB
I IO
AV
CMR
SVR
V OH 1
V OL 1
V OH 2
V OL 2
(V+=12V,Ta=25˚C )
TEST CONDITION
R L =∞, no signal
R S =0Ω
R L ≥ 10kΩ, VO=2V to 10V
0V ≤ V CM ≤ 10.8V
V + =8V to 12V
R L =10kΩ to GND
R L =10kΩ to 6V
I SO URCE
I SI NK
V ICM
MIN
TYP
MAX
UNIT
60
45
50
11.3
11.5
1
2.5
0 to 10.8
10.0
1
2.1
0.2
80
80
85
11.5
0.1
11.7
0.1
3
8
14.5
12
4.4
1
0.3
0.5
mA
mV
µA
µA
dB
dB
dB
V
V
V
V
mA
mA
V
(V+=12V,Ta=25˚C )
●AC CHARACTERISTICS
PARAMETER
SYMBOL
TEST CONDITION
fT
MIN
TYP
MAX
UNIT
21
MHz
(V+=12V,Ta=25˚C )
PARAMETER
Slew Rate
Ver.2012-09-14
SYMBOL
SR
TEST CONDITION
MIN
TYP
MAX
UNIT
45
V/µs
-3-
NJM2717
●DC CHARACTERISTICS
PARAMETER
Operating Current
Input Bias Current
Voltage Gain
Output Voltage 1
Output Voltage 2
Output Sink Current
Input Common Mode
Voltage Range
SYMBOL
I CC
V IO
IB
I IO
AV
CMR
SVR
V OH 1
V OL 1
V OH 2
V OL 2
(V+=2.7V,Ta=25˚C )
TEST CONDITION
R L =∞, no signal
R S =0Ω
R L ≥10kΩ, VO=0.85V to 1.85V
0V ≤ V CM ≤ 1.5V
V + =2.7V to 4V
R L =4kΩ to GND
R L =4kΩ to 1.35V
I SO URCE
I SI NK
V ICM
MIN
TYP
MAX
UNIT
60
45
50
2.5
2.6
1
2.5
0 to 1.5
6
1
1.7
0.2
73
80
75
2.6
0.05
2.65
0.1
2.5
5
8.5
10
4.4
0.5
0.1
0.2
mA
mV
µA
µA
dB
dB
dB
V
V
V
V
mA
mA
V
(V+=2.7V,Ta=25˚C )
●AC CHARACTERISTICS
PARAMETER
SYMBOL
TEST CONDITION
fT
MIN
TYP
MAX
UNIT
19
MHz
(V+=2.7V,Ta=25˚C )
PARAMETER
Slew Rate
-4-
SYMBOL
SR
TEST CONDITION
MIN
TYP
MAX
UNIT
30
V/µs
Ver.2012-09-14
NJM2717
■ Typical Characteristics
Operating Current vs. Ambient temperature
Operating Current vs. Supply Voltage
16
o
Ta=+85 C
14
Operating Current [mA]
18
Ta=+25oC
12
10
8
6
Ta=-40oC
4
2
16
14
V+/V-=±6.0V
V+/V-=±2.5V
12
10
8
6
V+/V-=±1.35V
4
2
4
6
8
10
12
Supply Voltage V+ [V]
14
16
-50
50
75
100
Ambien t Temperature [oC]
125
Input Offset Voltage vs. Ambient Tmperature
Input Offset Voltage vs. Supply Voltage
5
3
2
4
o
Ta=-40 C
1
Input Offset Voltage [mV]
-25
Ta=+25oC
-1
-2
-3
Ta=+85oC
-4
-5
-6
3
2
1
V+/V-=±2.5V
-2
V+/V-=±1.35V
-3
V+/V-=±6.0V
-4
-7
-5
Ver.2012-09-14
2
4
6
8
10 12
Supply voltage V+ [V]
14
16
-50
-25
50
75
100
125
Ambient Temperature [oC]
-5-
NJM2717
vs. Input Common Mode Vltage
vs. Input Common Mode Voltage
V+/V-=±1.35V
V+/V-=±2.5V
5
5
4
4
3
3
2
1
o
Ta=-40 C
-2
Ta=+85oC
-3
Ta=+25oC
-4
Ta=-40oC
1
-2
Ta=+85oC
Ta=+25oC
-3
-4
-5
-0.5
1
1.5
Input Common Mode Voltage [V]
-5
-0.5
2
Input Bias Current
V+/V-=±6.0V
V+/V-=±1.35V
5
7
4
6
3
5
2
Ta=-40oC
1
-2
-3
o
Ta=+85 C
Ta=+25oC
-4
4
-1
Ta=-40oC
3
2
1
Ta=+25oC
Ta=+85oC
-1
-3
-0.5
1
3
5
7
9
11
Input Bias Current
6
Input Bias Current [uA]
7
6
Ta=-40oC
4
3
2
1
o
Ta=+85 C
o
Ta=+25 C
-1
-2
-3
-0.5
2
V+/V-=±6.0V
7
5
1
1.5
Input Bias Current
V+/V-=±2.5V
4.5
-2
-5
-6-
0.5
1.5
2.5
3.5
vs. Input Common Mode Voltage Range
2
5
Ta=-40oC
4
3
2
1
Ta=+85oC
Ta=+25oC
-1
-2
-3
0.5
1.5
2.5
3.5
4.5
-1
1
3
5
7
9
11
Ver.2012-09-14
NJM2717
Maximum Output Voltage
vs. Ambient Temperature
Maximum Output Voltage vs. Supply Voltage
GV=OPEN, RL=4kΩ
V+/V-=±6.0V
6
Maximum Output Voltage [V]
GV=OPEN,RL=4KΩ
6
8
4
2
Ta=- 40ºC
Ta=+ 25ºC
Ta=+ 85ºC
-4
-6
-8
4
V+/V-=±2.5V
2
V+/V-=±1.35V
-2
-4
-6
4
6
Supply Voltage V+/V- [V]
8
-50
vs. Load Resistance
125
V+/V-=±1.35V, GV=OPEN
6.0
3.0
V+/V-=±6.0V
4.0
+VOM
V+/V-=±2.5V
2.0
V+/V-=±1.35V
0.0
-2.0
-4.0
-VOM
50
75
100
vs. Load Resistance
GV=OPEN, Ta=+25ºC
-6.0
2.0
+VOM
1.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
0.0
-1.0
-VOM
-2.0
-3.0
0.1
1.0
10.0
Load Resistance [kΩ]
100.0
0.1
vs. Load Resistance
1.0
10.0
100.0
Maximum Output voltage
vs. Load Resistance
V+/V-=±2.5V, GV=OPEN
V+/V-=±6.0V, GV=OPEN
6.0
2.0
3.0
-25
+VOM
Ta=-40oC
Ta=+25oC
Ta=+85oC
1.0
0.0
-1.0
-VOM
-2.0
-3.0
+VOM
4.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
2.0
0.0
-2.0
-4.0
-VOM
-6.0
0.1
Ver.2012-09-14
1.0
10.0
100.0
0.1
1.0
10.0
100.0
-7-
NJM2717
vs. Load Resistance
vs. Load Resistance
V =+2.7V,V =GND,GV=OPEN
V+=+2.7V, V-=GND,GV=OPEN
0.50
+VOM
4.0
5.0
3.0
2.0
Ta=+85oC
Ta=+25oC
Ta=-40oC
1.0
-VOM
0.0
0.40
0.30
Ta=+85oC
0.20
o
Ta=+25 C
Ta=-40oC
-VOM
0.10
0.00
0.1
1
10
100
0.1
vs. Load Resistance
V+=+5.0V, V-=GND, GV=OPEN
0.50
5.0
+VOM
4.0
Ta=+85oC
Ta=+25oC
Ta=-40oC
3.0
2.0
1.0
-VOM
0.0
0.40
0.30
Ta=+85oC
0.20
o
Ta=+25 C
Ta=-40oC
-VOM
0.10
0.00
0.1
1
10
100
0.1
vs. Load Resistance
1
10
100
vs. Load Resistance
V+=+12.0V,V-=GND, GV=OPEN
V+=+12.0V, V-=GND, GV=OPEN
0.50
10.0
12.0
100
vs. Load Resistance
V+=+5.0V, V-=GND,GV=OPEN
+VOM
8.0
Ta=+85oC
Ta=+25oC
Ta=-40oC
6.0
4.0
2.0
-VOM
0.40
0.30
Ta=+85oC
Ta=+25oC
0.20
Ta=-40oC
0.10
-VOM
0.00
0.0
0.1
-8-
1
10
1
10
100
0.1
1
10
100
Ver.2012-09-14
NJM2717
vs. Output Source Current
vs. Output Sink Current
V+/V-=±1.35V,GV=OPEN
0.0
2.5
-0.5
3.0
2.0
1.5
1.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
0.5
-1.0
-1.5
Ta=-40oC
Ta=+25oC
Ta=+85oC
-2.0
-2.5
-3.0
0.0
0.01
0.1
1
Output Source Current [mA]
0.01
10
V+/V-=±2.5V,GV=OPEN
0.0
2.5
-0.5
V+/V-=±2.5V,GV=OPEN
2.0
1.5
Ta=-40oC
Ta=+25oC
Ta=+85oC
0.5
0.0
-1.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
-1.5
-2.0
-2.5
-3.0
0.01
0.1
1
10
0.01
100
V+/V-=±6.0V,GV=OPEN
0.0
5.0
-1.0
6.0
4.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
3.0
0.1
1
10
Output Sink Current [mA]
V+/V-=±6.0V,GV=OPEN
100
3.0
1.0
0.1
1
10
2.0
1.0
-2.0
-3.0
Ta=-40oC
Ta=+25oC
Ta=+85oC
-4.0
-5.0
-6.0
0.0
0.01
Ver.2012-09-14
0.1
1
10
0.01
0.1
1
10
100
-9-
NJM2717
Voltage Gain vs. Frequency
Voltage Gain/Phase vs. Frequency
(Voltage Follower)
V+/V-,GV=0dB, RL=2kΩ to GND, Ta=25oC
GV=40dB, RL=2kΩ to GND, CL=10pF, Ta=25oC
50
8
6
V+/V-=±6.0V
-90
V /V =±1.35V
10
Voltage Gain [dB]
Phase
30
Phase [deg]
0.01
10
-180
100
CL=10pF
-4
V+/V-=±1.35V
+ V /V =±2.5V
V+/V-=±6.0V
0.1
1
10
100
Frequency [MHz]
1000
Pulse Response
Pulse Response
V+/V-=±2.5V,AV=0dB,f=1MHz,VIN=±1V,
RL=10KΩ,Ta=25oC
RL=10KΩ,Ta=25oC
1.5
2.0
0.5
1.0
1.5
1.0
-0.5
0.5
CL=100pF
-1.0
0.0
CL=10pF
-0.5
OUTPUT
-2.0
-400
-200
Time [nsec]
400
Input Voltage [V]
0.0
Output Voltage [V]
CL=220pF
Input Voltage [V]
-2
-10
INPUT
-600
V+/V-=±1.35V,AV=0dB,f=1MHz,VIN=±0.5V,
1.0
-1.5
CL=100pF
-8
0.1
1
Frequency [MHz]
V+/V-=±1.35V
V+/V-=±2.5V
V+/V-=±6.0V
2
-6
V+/V-=±2.5V
4
2.5
INPUT
2.0
0.5
1.5
0.0
1.0
-0.5
CL=220pF
CL=100pF
-1.0
CL=10pF
-1.5
-2.0
-600
-400
0.0
-0.5
-1.0
OUTPUT
-2.5
-1.0
600
0.5
Output Voltagve [V]
Gain
40
Voltage Gain [dB]
10
45
-200
Time [nsec]
400
-1.5
600
Pulse Response
V+/V-=±6.0V,AV=0dB,f=1MHz,
VIN=±1V,RL=10KΩ,Ta=25oC
1.5
2.5
1.0
2.0
0.5
1.5
0.0
1.0
-0.5
CL=220pF
CL=100pF
-1.0
CL=10pF
-1.5
-2.0
-2.5
- 10 -
-400
0.0
-0.5
-1.0
OUTPUT
-600
0.5
-200
Time [nsec]
400
-1.5
600
Output Voltage [V]
Input Voltage [V]
INPUT
[CAUTION]
The specifications on this data book are only given for information,
without any guarantee as regards either mistakes or omissions. The
application circuits in this data book are described only to show
representative usages of the product and not intended for the
guarantee or permission of any right including the industrial rights.
Ver.2012-09-14
