S-13R1B34-N4T1U3
S-13R1B34-N4T1U3
    ABLIC(艾普凌科)
    SC-82A
    IC REG LINEAR 3.4V 150MA SC82AB
S-13R1B34-N4T1U3 数据手册
S-13R1 Series www.ablic.com 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 © ABLIC Inc., 2012-2018 The S-13R1 Series, developed by using the CMOS technology, is a positive voltage regulator IC of 150 mA output current, which has low dropout voltage, high-accuracy output voltage and low current consumption. Even with low current consumption of 5 μA typ., it has high ripple-rejection of 70 dB typ., and a ceramic capacitor of 1.0 μF or more can be used as the input and output capacitors. The S-13R1 Series includes an overcurrent protection circuit that prevents the load current from exceeding the current capacity of the output transistor and a thermal shutdown circuit that prevents damage because of overheating. Due to the built-in reverse current protection function, the reverse current flowing from the VOUT pin to the VIN pin can be controlled as the small value 0.09 μA max. Therefore, IC protection diode is not needed.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors: • Ripple rejection: • Reverse current protection function: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 1.2 V to 4.0 V, selectable in 0.05 V step 2.0 V to 5.5 V ±1.0% (1.2 V to 1.45 V output product: ±15 mV) 150 mV typ. (3.0 V output product, IOUT = 100 mA) During operation: 5 μA typ., 9 μA max. During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 150 mA (VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. 70 dB typ. (3.0 V output product, f = 1.0 kHz) IREV = 0.09 μA max. Limits overcurrent of output transistor. Prevents damage caused by heat. Ensures long battery life. Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C *1. Attention should be paid to the power dissipation of the package when the output current is large.  Applications • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for portable equipment • Constant-voltage power supply for home electric appliance • Constant-voltage power supply for mobile phone  Packages • SOT-23-5 • SC-82AB • HSNT-4 (1010) 1 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Block Diagrams 1. S-13R1 Series A type VOUT Function Status ON / OFF logic Active "H" Discharge shunt Available function Constant current Available source pull-down VOUT Function Status ON / OFF logic Active "H" Discharge shunt Available function Constant current Unavailable source pull-down Reverse current detection circuit VIN Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit ON / OFF + − *1 Reference voltage circuit *1 VSS *1. Parasitic diode Figure 1 2. S-13R1 Series B type Reverse current detection circuit VIN Overcurrent protection circuit Thermal shutdown circuit ON / OFF ON / OFF circuit + − *1 Reference voltage circuit *1 VSS *1. Parasitic diode Figure 2 2 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 3. S-13R1 Series C type VOUT Function Status ON / OFF logic Active "H" Discharge shunt Unavailable function Constant current Available source pull-down VOUT Function Status ON / OFF logic Active "H" Discharge shunt Unavailable function Constant current Unavailable source pull-down Reverse current detection circuit VIN Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit ON / OFF + − *1 Reference voltage circuit VSS *1. Parasitic diode Figure 3 4. S-13R1 Series D type Reverse current detection circuit VIN Overcurrent protection circuit Thermal shutdown circuit ON / OFF ON / OFF circuit + − *1 Reference voltage circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Product Name Structure Users can select the product type, output voltage, and package type for the S-13R1 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product types" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name lists" regarding details of the product name. 1. Product name S-13R1 x xx - xxxx U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape N4T1: SC-82AB, Tape A4T2: HSNT-4 (1010), Tape Output voltage*2 12 to 40 (e.g., when the output voltage is 1.2 V, it is expressed as 12.) Product type*3 A to D *1. *2. *3. 2. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to "2. Function list of product types". Function list of product types Table 1 Product Type A B C D 3. ON / OFF Logic Active "H" Active "H" Active "H" Active "H" Constant Current Source Pull-down Available Unavailable Available Unavailable Packages Table 2 4 Discharge Shunt Function Available Available Unavailable Unavailable Package Name SOT-23-5 Dimension MP005-A-P-SD SC-82AB NP004-A-P-SD HSNT-4 (1010) PL004-A-P-SD Package Drawing Codes Tape MP005-A-C-SD NP004-A-C-SD NP004-A-C-S1 PL004-A-C-SD Reel MP005-A-R-SD Land − NP004-A-R-SD − PL004-A-R-SD PL004-A-L-SD 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 4. Product name lists 4. 1 S-13R1 Series A type ON / OFF logic: Discharge shunt function: Active "H" Available Constant current source pull-down: Available Table 3 Output Voltage 1.2 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% 3.6 V ± 1.0% 3.7 V ± 1.0% 3.8 V ± 1.0% 3.9 V ± 1.0% 4.0 V ± 1.0% Remark SOT-23-5 S-13R1A12-M5T1U3 S-13R1A13-M5T1U3 S-13R1A14-M5T1U3 S-13R1A15-M5T1U3 S-13R1A16-M5T1U3 S-13R1A17-M5T1U3 S-13R1A18-M5T1U3 S-13R1A1J-M5T1U3 S-13R1A19-M5T1U3 S-13R1A20-M5T1U3 S-13R1A21-M5T1U3 S-13R1A22-M5T1U3 S-13R1A23-M5T1U3 S-13R1A24-M5T1U3 S-13R1A25-M5T1U3 S-13R1A26-M5T1U3 S-13R1A27-M5T1U3 S-13R1A28-M5T1U3 S-13R1A2J-M5T1U3 S-13R1A29-M5T1U3 S-13R1A30-M5T1U3 S-13R1A31-M5T1U3 S-13R1A32-M5T1U3 S-13R1A33-M5T1U3 S-13R1A34-M5T1U3 S-13R1A35-M5T1U3 S-13R1A36-M5T1U3 S-13R1A37-M5T1U3 S-13R1A38-M5T1U3 S-13R1A39-M5T1U3 S-13R1A40-M5T1U3 SC-82AB S-13R1A12-N4T1U3 S-13R1A13-N4T1U3 S-13R1A14-N4T1U3 S-13R1A15-N4T1U3 S-13R1A16-N4T1U3 S-13R1A17-N4T1U3 S-13R1A18-N4T1U3 S-13R1A1J-N4T1U3 S-13R1A19-N4T1U3 S-13R1A20-N4T1U3 S-13R1A21-N4T1U3 S-13R1A22-N4T1U3 S-13R1A23-N4T1U3 S-13R1A24-N4T1U3 S-13R1A25-N4T1U3 S-13R1A26-N4T1U3 S-13R1A27-N4T1U3 S-13R1A28-N4T1U3 S-13R1A2J-N4T1U3 S-13R1A29-N4T1U3 S-13R1A30-N4T1U3 S-13R1A31-N4T1U3 S-13R1A32-N4T1U3 S-13R1A33-N4T1U3 S-13R1A34-N4T1U3 S-13R1A35-N4T1U3 S-13R1A36-N4T1U3 S-13R1A37-N4T1U3 S-13R1A38-N4T1U3 S-13R1A39-N4T1U3 S-13R1A40-N4T1U3 HSNT-4 (1010) S-13R1A12-A4T2U3 S-13R1A13-A4T2U3 S-13R1A14-A4T2U3 S-13R1A15-A4T2U3 S-13R1A16-A4T2U3 S-13R1A17-A4T2U3 S-13R1A18-A4T2U3 S-13R1A1J-A4T2U3 S-13R1A19-A4T2U3 S-13R1A20-A4T2U3 S-13R1A21-A4T2U3 S-13R1A22-A4T2U3 S-13R1A23-A4T2U3 S-13R1A24-A4T2U3 S-13R1A25-A4T2U3 S-13R1A26-A4T2U3 S-13R1A27-A4T2U3 S-13R1A28-A4T2U3 S-13R1A2J-A4T2U3 S-13R1A29-A4T2U3 S-13R1A30-A4T2U3 S-13R1A31-A4T2U3 S-13R1A32-A4T2U3 S-13R1A33-A4T2U3 S-13R1A34-A4T2U3 S-13R1A35-A4T2U3 S-13R1A36-A4T2U3 S-13R1A37-A4T2U3 S-13R1A38-A4T2U3 S-13R1A39-A4T2U3 S-13R1A40-A4T2U3 Please contact our sales office for products with specifications other than the above. 5 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 4. 2 S-13R1 Series B type ON / OFF logic: Discharge shunt function: Active "H" Available Constant current source pull-down: Unavailable Table 4 Output Voltage 1.2 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% 3.6 V ± 1.0% 3.7 V ± 1.0% 3.8 V ± 1.0% 3.9 V ± 1.0% 4.0 V ± 1.0% Remark 6 SOT-23-5 S-13R1B12-M5T1U3 S-13R1B13-M5T1U3 S-13R1B14-M5T1U3 S-13R1B15-M5T1U3 S-13R1B16-M5T1U3 S-13R1B17-M5T1U3 S-13R1B18-M5T1U3 S-13R1B1J-M5T1U3 S-13R1B19-M5T1U3 S-13R1B20-M5T1U3 S-13R1B21-M5T1U3 S-13R1B22-M5T1U3 S-13R1B23-M5T1U3 S-13R1B24-M5T1U3 S-13R1B25-M5T1U3 S-13R1B26-M5T1U3 S-13R1B27-M5T1U3 S-13R1B28-M5T1U3 S-13R1B2J-M5T1U3 S-13R1B29-M5T1U3 S-13R1B30-M5T1U3 S-13R1B31-M5T1U3 S-13R1B32-M5T1U3 S-13R1B33-M5T1U3 S-13R1B34-M5T1U3 S-13R1B35-M5T1U3 S-13R1B36-M5T1U3 S-13R1B37-M5T1U3 S-13R1B38-M5T1U3 S-13R1B39-M5T1U3 S-13R1B40-M5T1U3 SC-82AB S-13R1B12-N4T1U3 S-13R1B13-N4T1U3 S-13R1B14-N4T1U3 S-13R1B15-N4T1U3 S-13R1B16-N4T1U3 S-13R1B17-N4T1U3 S-13R1B18-N4T1U3 S-13R1B1J-N4T1U3 S-13R1B19-N4T1U3 S-13R1B20-N4T1U3 S-13R1B21-N4T1U3 S-13R1B22-N4T1U3 S-13R1B23-N4T1U3 S-13R1B24-N4T1U3 S-13R1B25-N4T1U3 S-13R1B26-N4T1U3 S-13R1B27-N4T1U3 S-13R1B28-N4T1U3 S-13R1B2J-N4T1U3 S-13R1B29-N4T1U3 S-13R1B30-N4T1U3 S-13R1B31-N4T1U3 S-13R1B32-N4T1U3 S-13R1B33-N4T1U3 S-13R1B34-N4T1U3 S-13R1B35-N4T1U3 S-13R1B36-N4T1U3 S-13R1B37-N4T1U3 S-13R1B38-N4T1U3 S-13R1B39-N4T1U3 S-13R1B40-N4T1U3 HSNT-4 (1010) S-13R1B12-A4T2U3 S-13R1B13-A4T2U3 S-13R1B14-A4T2U3 S-13R1B15-A4T2U3 S-13R1B16-A4T2U3 S-13R1B17-A4T2U3 S-13R1B18-A4T2U3 S-13R1B1J-A4T2U3 S-13R1B19-A4T2U3 S-13R1B20-A4T2U3 S-13R1B21-A4T2U3 S-13R1B22-A4T2U3 S-13R1B23-A4T2U3 S-13R1B24-A4T2U3 S-13R1B25-A4T2U3 S-13R1B26-A4T2U3 S-13R1B27-A4T2U3 S-13R1B28-A4T2U3 S-13R1B2J-A4T2U3 S-13R1B29-A4T2U3 S-13R1B30-A4T2U3 S-13R1B31-A4T2U3 S-13R1B32-A4T2U3 S-13R1B33-A4T2U3 S-13R1B34-A4T2U3 S-13R1B35-A4T2U3 S-13R1B36-A4T2U3 S-13R1B37-A4T2U3 S-13R1B38-A4T2U3 S-13R1B39-A4T2U3 S-13R1B40-A4T2U3 Please contact our sales office for products with specifications other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 4. 3 S-13R1 Series C type ON / OFF logic: Discharge shunt function: Active "H" Unavailable Constant current source pull-down: Available Table 5 Output Voltage 1.2 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% 3.6 V ± 1.0% 3.7 V ± 1.0% 3.8 V ± 1.0% 3.9 V ± 1.0% 4.0 V ± 1.0% Remark SOT-23-5 S-13R1C12-M5T1U3 S-13R1C13-M5T1U3 S-13R1C14-M5T1U3 S-13R1C15-M5T1U3 S-13R1C16-M5T1U3 S-13R1C17-M5T1U3 S-13R1C18-M5T1U3 S-13R1C1J-M5T1U3 S-13R1C19-M5T1U3 S-13R1C20-M5T1U3 S-13R1C21-M5T1U3 S-13R1C22-M5T1U3 S-13R1C23-M5T1U3 S-13R1C24-M5T1U3 S-13R1C25-M5T1U3 S-13R1C26-M5T1U3 S-13R1C27-M5T1U3 S-13R1C28-M5T1U3 S-13R1C2J-M5T1U3 S-13R1C29-M5T1U3 S-13R1C30-M5T1U3 S-13R1C31-M5T1U3 S-13R1C32-M5T1U3 S-13R1C33-M5T1U3 S-13R1C34-M5T1U3 S-13R1C35-M5T1U3 S-13R1C36-M5T1U3 S-13R1C37-M5T1U3 S-13R1C38-M5T1U3 S-13R1C39-M5T1U3 S-13R1C40-M5T1U3 SC-82AB S-13R1C12-N4T1U3 S-13R1C13-N4T1U3 S-13R1C14-N4T1U3 S-13R1C15-N4T1U3 S-13R1C16-N4T1U3 S-13R1C17-N4T1U3 S-13R1C18-N4T1U3 S-13R1C1J-N4T1U3 S-13R1C19-N4T1U3 S-13R1C20-N4T1U3 S-13R1C21-N4T1U3 S-13R1C22-N4T1U3 S-13R1C23-N4T1U3 S-13R1C24-N4T1U3 S-13R1C25-N4T1U3 S-13R1C26-N4T1U3 S-13R1C27-N4T1U3 S-13R1C28-N4T1U3 S-13R1C2J-N4T1U3 S-13R1C29-N4T1U3 S-13R1C30-N4T1U3 S-13R1C31-N4T1U3 S-13R1C32-N4T1U3 S-13R1C33-N4T1U3 S-13R1C34-N4T1U3 S-13R1C35-N4T1U3 S-13R1C36-N4T1U3 S-13R1C37-N4T1U3 S-13R1C38-N4T1U3 S-13R1C39-N4T1U3 S-13R1C40-N4T1U3 HSNT-4 (1010) S-13R1C12-A4T2U3 S-13R1C13-A4T2U3 S-13R1C14-A4T2U3 S-13R1C15-A4T2U3 S-13R1C16-A4T2U3 S-13R1C17-A4T2U3 S-13R1C18-A4T2U3 S-13R1C1J-A4T2U3 S-13R1C19-A4T2U3 S-13R1C20-A4T2U3 S-13R1C21-A4T2U3 S-13R1C22-A4T2U3 S-13R1C23-A4T2U3 S-13R1C24-A4T2U3 S-13R1C25-A4T2U3 S-13R1C26-A4T2U3 S-13R1C27-A4T2U3 S-13R1C28-A4T2U3 S-13R1C2J-A4T2U3 S-13R1C29-A4T2U3 S-13R1C30-A4T2U3 S-13R1C31-A4T2U3 S-13R1C32-A4T2U3 S-13R1C33-A4T2U3 S-13R1C34-A4T2U3 S-13R1C35-A4T2U3 S-13R1C36-A4T2U3 S-13R1C37-A4T2U3 S-13R1C38-A4T2U3 S-13R1C39-A4T2U3 S-13R1C40-A4T2U3 Please contact our sales office for products with specifications other than the above. 7 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 4. 4 S-13R1 Series D type ON / OFF logic: Discharge shunt function: Active "H" Unavailable Constant current source pull-down: Unavailable Table 6 Output Voltage 1.2 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% 3.6 V ± 1.0% 3.7 V ± 1.0% 3.8 V ± 1.0% 3.9 V ± 1.0% 4.0 V ± 1.0% Remark 8 SOT-23-5 S-13R1D12-M5T1U3 S-13R1D13-M5T1U3 S-13R1D14-M5T1U3 S-13R1D15-M5T1U3 S-13R1D16-M5T1U3 S-13R1D17-M5T1U3 S-13R1D18-M5T1U3 S-13R1D1J-M5T1U3 S-13R1D19-M5T1U3 S-13R1D20-M5T1U3 S-13R1D21-M5T1U3 S-13R1D22-M5T1U3 S-13R1D23-M5T1U3 S-13R1D24-M5T1U3 S-13R1D25-M5T1U3 S-13R1D26-M5T1U3 S-13R1D27-M5T1U3 S-13R1D28-M5T1U3 S-13R1D2J-M5T1U3 S-13R1D29-M5T1U3 S-13R1D30-M5T1U3 S-13R1D31-M5T1U3 S-13R1D32-M5T1U3 S-13R1D33-M5T1U3 S-13R1D34-M5T1U3 S-13R1D35-M5T1U3 S-13R1D36-M5T1U3 S-13R1D37-M5T1U3 S-13R1D38-M5T1U3 S-13R1D39-M5T1U3 S-13R1D40-M5T1U3 SC-82AB S-13R1D12-N4T1U3 S-13R1D13-N4T1U3 S-13R1D14-N4T1U3 S-13R1D15-N4T1U3 S-13R1D16-N4T1U3 S-13R1D17-N4T1U3 S-13R1D18-N4T1U3 S-13R1D1J-N4T1U3 S-13R1D19-N4T1U3 S-13R1D20-N4T1U3 S-13R1D21-N4T1U3 S-13R1D22-N4T1U3 S-13R1D23-N4T1U3 S-13R1D24-N4T1U3 S-13R1D25-N4T1U3 S-13R1D26-N4T1U3 S-13R1D27-N4T1U3 S-13R1D28-N4T1U3 S-13R1D2J-N4T1U3 S-13R1D29-N4T1U3 S-13R1D30-N4T1U3 S-13R1D31-N4T1U3 S-13R1D32-N4T1U3 S-13R1D33-N4T1U3 S-13R1D34-N4T1U3 S-13R1D35-N4T1U3 S-13R1D36-N4T1U3 S-13R1D37-N4T1U3 S-13R1D38-N4T1U3 S-13R1D39-N4T1U3 S-13R1D40-N4T1U3 HSNT-4 (1010) S-13R1D12-A4T2U3 S-13R1D13-A4T2U3 S-13R1D14-A4T2U3 S-13R1D15-A4T2U3 S-13R1D16-A4T2U3 S-13R1D17-A4T2U3 S-13R1D18-A4T2U3 S-13R1D1J-A4T2U3 S-13R1D19-A4T2U3 S-13R1D20-A4T2U3 S-13R1D21-A4T2U3 S-13R1D22-A4T2U3 S-13R1D23-A4T2U3 S-13R1D24-A4T2U3 S-13R1D25-A4T2U3 S-13R1D26-A4T2U3 S-13R1D27-A4T2U3 S-13R1D28-A4T2U3 S-13R1D2J-A4T2U3 S-13R1D29-A4T2U3 S-13R1D30-A4T2U3 S-13R1D31-A4T2U3 S-13R1D32-A4T2U3 S-13R1D33-A4T2U3 S-13R1D34-A4T2U3 S-13R1D35-A4T2U3 S-13R1D36-A4T2U3 S-13R1D37-A4T2U3 S-13R1D38-A4T2U3 S-13R1D39-A4T2U3 S-13R1D40-A4T2U3 Please contact our sales office for products with specifications other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series  Pin Configurations 1. SOT-23-5 Top view 5 4 1 2 3 Table 7 Pin No. 1 2 3 4 5 Symbol VIN VSS ON / OFF NC*1 VOUT Description Input voltage pin GND pin ON / OFF pin No connection Output voltage pin Figure 5 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 2. SC-82AB Top view 4 3 1 2 Table 8 Pin No. 1 2 3 4 Symbol ON / OFF VSS VOUT VIN Description ON / OFF pin GND pin Output voltage pin Input voltage pin Figure 6 3. HSNT-4 (1010) Top view 1 2 4 3 Bottom view 4 3 Table 9 Pin No. 1 2 3 4 Symbol VOUT VSS ON / OFF VIN Description Output voltage pin GND pin ON / OFF pin Input voltage pin 1 2 *1 Figure 7 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. 9 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Absolute Maximum Ratings Table 10 Item Symbol VIN VON / OFF VOUT IOUT Input voltage Output voltage Output current SOT-23-5 PD SC-82AB HSNT-4 (1010) Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 Power dissipation Caution (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VSS + 6.0 200 600*1 400*1 340*1 −40 to +85 −40 to +125 The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power Dissipation (PD) [mW] 1200 Figure 8 SOT-23-5 1000 SC-82AB 800 HSNT-4 (1010) 600 400 200 0 10 V V V mA mW mW mW °C °C 0 150 100 50 Ambient Temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series Power Dissipation of HSNT-4 (1010) (Reference) Power dissipation of package differs depending on the mounting conditions. Consider the power dissipation characteristics under the following conditions as reference. [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Test conditions: (5) Land pattern: 40 mm × 40 mm × t0.8 mm Glass epoxy resin (four layers) 50% When mounted on board (wind speed: 0 m/s) Refer to the recommended land pattern (drawing code: PL004-A-L-SD) Power Dissipation (PD) [mW] 1200 1000 800 600 400 200 0 Figure 9 0 150 100 50 Ambient Temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) Table 11 Condition HSNT-4 (1010) (When mounted on board) Power Dissipation (Reference) 870 mW Thermal Resistance Value (θj−a) 115°C/W 11 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Electrical Characteristics Table 12 (1 /2) Item Symbol Output voltage*1 Output current *2 Dropout voltage*3 Line regulation Load regulation Output voltage temperature *4 coefficient Current consumption during operation Reverse current Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" ON / OFF pin input current "H" VOUT(E) IOUT Vdrop Condition VIN = VOUT(S) + 1.0 V, IOUT = 30 mA 1.2 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 4.0 V VIN ≥ VOUT(S) + 1.0 V IOUT = 100 mA 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.6 V 1.6 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 1.8 V 1.8 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) < 3.0 V 3.0 V ≤ VOUT(S) ≤ 4.0 V 2.0 V ≤ VIN ≤ 5.5 V, 1.2 V ≤ VOUT(S) < 1.5 V ΔVOUT1 IOUT = 30 mA ΔVIN•VOUT VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, 1.5 V ≤ VOUT(S) ≤ 4.0 V IOUT = 30 mA ΔVOUT2 VIN = VOUT(S) + 1.0 V, 10 μA ≤ IOUT ≤ 100 mA ΔVOUT VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, ΔTa•VOUT −40°C ≤ Ta ≤ +85°C ISS1 IREV ISS2 VIN VSH VSL ISH VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load 0 V ≤ VIN < VOUT VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level B / D type (without constant current source pull-down) VIN = 5.5 V, VON / OFF = 5.5 V A / C type (with constant current source pull-down) (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) V V 1 − 0.015 OUT(S) + 0.015 VOUT(S) VOUT(S) VOUT(S) V 1 × 0.99 × 1.01 *5 150 mA 3 − − 0.80 0.84 0.88 V 1 0.74 0.78 − V 1 0.64 0.68 − V 1 0.54 0.58 − V 1 0.44 0.48 − V 1 0.34 0.38 − V 1 0.24 0.28 − V 1 0.19 0.28 − V 1 0.17 0.23 − V 1 0.15 0.23 − V 1 − 0.05 0.2 %/V 1 − 0.05 0.2 %/V 1 − 25 40 mV 1 − ±100 − ppm/°C 1 − 5.0 9.0 μA 2 − − 0.09 μA 6 − 0.1 1.0 μA 2 2.0 − 5.5 V − 1.0 − − V 4 − − 0.3 V 4 −0.1 − 0.1 μA 4 0.05 0.10 0.20 μA 4 −0.1 − 0.1 μA 4 − 70 − dB 5 ON / OFF pin input current "L" ISL VIN = VOUT(S) + 1.0 V, VON / OFF = 0 V Ripple rejection |RR| VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 100 mA Limit current ILIM VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON 200 250 400 mA 3 Short-circuit current Ishort VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V − 30 − mA 3 Junction temperature − 150 − °C − Junction temperature − 120 − °C − Thermal shutdown T detection temperature SD Thermal shutdown TSR release temperature 12 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series Table 12 (2 /2) Item Discharge shunt resistance during power-off Reverse current protection mode detection voltage Reverse current protection mode release voltage Symbol Condition RLOW VIN = 5.5 V, VOUT = 0.1 V VREVD VREVR A / B type (with discharge shunt function) (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit − 35 − Ω 3 0 V ≤ VIN ≤ 5.5 V, VOUT ≥ 0.5 V, VREVD = VIN − VOUT 20 45 100 mV 6 0 V ≤ VIN ≤ 5.5 V, VOUT ≥ 0.5 V, VREVR = VIN − VOUT 50 75 120 mV 6 *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 13 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Test Circuits + VOUT VIN ON / OFF VSS V A + Set to ON Figure 10 + A Test Circuit 1 VOUT VIN ON / OFF VSS Set to VIN or GND Figure 11 Test Circuit 2 VOUT VIN A ON / OFF V + VSS Set to VIN or GND Figure 12 Test Circuit 3 VOUT VIN + A ON / OFF V + VSS Figure 13 Test Circuit 4 VOUT VIN ON / OFF V + VSS Set to ON Figure 14 Test Circuit 5 VOUT VIN ON / OFF Set to ON 14 A + V VSS Figure 15 RL Test Circuit 6 + RL 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series  Standard Circuit Input Output VOUT VIN CIN *1 ON / OFF VSS Single GND CL *2 GND *1. CIN is a capacitor for stabilizing the input. *2. A ceramic capacitor of 1.0 F or more can be used as CL. Figure 16 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): 1.0 F or more 1.0 F or more Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-13R1 Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 F or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 F or more. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN  1.0 F, CL  1.0 F; however, when selecting the output capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device. 15 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT(S) < 1.5 V: ±15 mV, when VOUT(S) ≥ 1.5 V: ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. ΔVOUT1  Line regulation  ΔVIN•VOUT  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 16 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 6. ΔVOUT  Output voltage temperature coefficient  ΔTa•VOUT  The shaded area in Figure 17 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±100 ppm/°C. Example of S-13R1A30 typ. product VOUT [V] +0.30 mV/°C VOUT(E)*1 −0.30 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 17 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 17 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Operation 1. Basic operation Figure 18 shows the block diagram of the S-13R1 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs, Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 18 2. Output transistor In the S-13R1 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Since there exists a parasitic diode between the VIN pin and the VOUT pin, the reverse current arises when potential of VOUT becomes higher than VIN. However, the reverse current detection circuit prevents the current from flowing from the VOUT pin in the S-13R1 Series. Therefore, the IC is not damaged even when the potential of VOUT becomes higher than VIN. 18 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.3 V to 1.0 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 19 and Figure 20. 3. 1 S-13R1 Series A / C type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. 3. 2 S-13R1 Series B / D type The ON / OFF pin is not internally pulled down to the VSS pin, so do not use this pin in the floating status. When not using the ON / OFF pin, connect the pin to the VIN pin. Table 13 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption *1 A/B/C/D "H": ON Operate Set value ISS1 A/B "L": OFF Stop VSS level ISS2 C/D "L": OFF Stop High-Z ≅ VSS level ISS2 *1. Note that the IC’s current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-13R1 Series A / C type is operating (refer to Figure 19). VIN VIN ON / OFF ON / OFF VSS Figure 19 S-13R1 Series A / C type VSS Figure 20 S-13R1 Series B / D type 19 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 4. Discharge shunt function (S-13R1 Series A / B type) The S-13R1 Series A / B type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-13R1 Series C / D type does not have a discharge shunt circuit, the VOUT pin is not discharged. The S-13R1 Series A / B type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-13R1 Series Output transistor: OFF VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF Pin : OFF Current flow GND VSS *1. Parasitic diode Figure 21 5. Constant current source pull-down (S-13R1 Series A / C type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-13R1 Series A / C type is operating. 20 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 6. Overcurrent protection circuit The S-13R1 Series has an overcurrent protection circuit having the characteristics shown in "1. Output voltage vs. Output current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data)", in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and the VSS pin. The current (Ishort) when the output pin is short-circuited is internally set at approx. 30 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 7. Thermal shutdown circuit The S-13R1 Series has a thermal shutdown circuit to protect the device from damage due to overheat. When the junction temperature rises to 150°C typ., the thermal shutdown circuit operates to stop regulating. When the junction temperature drops to 120°C typ., the thermal shutdown circuit is released to restart regulating. Due to self-heating of the S-13R1 Series, if the thermal shutdown circuit starts operating, it stops regulating so that the output voltage drops. When regulation stops, the S-13R1 Series does not itself generate heat and the IC's temperature drops. When the temperature drops, the thermal shutdown circuit is released to restart regulating, thus the S-13R1 Series generates heat again. Repeating this procedure makes the waveform of the output voltage into a pulse-like form. Stop or restart of regulation continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Table 14 Thermal Shutdown Circuit Operate: 150°C typ.*1 Release: 120°C typ.*1 *1. Junction temperature VOUT Pin Voltage VSS level Set value 21 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 8. Reverse current protection function 8. 1 Detection and release of reverse current protection mode The reverse current protection function compares values of the VIN pin voltage (VIN) and the VOUT pin voltage (VOUT), and prevents the current from flowing to the VIN pin and the VSS pin from the VOUT pin. Also, in the S-13R1 Series A / B type, the current flows from the VOUT pin to the VSS pin due to a discharge shunt circuit. During the reverse current protection mode, the connection direction of parasitic diode of the output transistor is switched by the reverse current protection circuit, and the feedback resistors (Rs, Rf) and the VSS pin are disconnected. The reverse current is prevented by switching the reverse current protection mode before VIN becomes lower than VOUT. As shown in Figure 24, in the case of VIN − VOUT > VREVD, the S-13R1 Series is in normal operation mode. The reverse current protection mode is detected when VIN − VOUT ≤ VREVD. In order to insure the stable operation, there is also a hysteresis for detection and release of the reverse current protection mode. Therefore, the reverse current protection mode is released when VIN − VOUT ≥ VREVR. The reverse current detection circuit operates at 0 V ≤ VIN ≤ 5.5 V and VOUT ≥ 0.5 V. Current flow VIN VIN Current supply Error amplifier Current supply − Error amplifier − + + Reverse current detection circuit Reference voltage circuit VOUT Reverse current detection circuit Rf Rf VOUT Reference voltage circuit Rs Rs Reverse current (IREV) Current flow VSS VSS Figure 22 Normal Operation Mode VIN Figure 23 Reverse current protection mode detection voltage (VREVD) Reverse Current Protection Mode Reverse current protection mode release voltage (VREVR) VOUT + VREVR VOUT + VREVD VOUT Normal operation mode Reverse current protection mode Figure 24 22 Normal operation mode 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 8. 2 Power-on (ON / OFF pin = ON) At power-on, the reverse current protection mode and the normal operation mode may be repeated during the time period of VIN − VOUT ≤ VREVD. VIN = VON / OFF VOUT VIN − VOUT Reverse current protection mode / normal operation mode Normal operation mode Figure 25 23 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and the capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (10 μA or less). If the S-13R1 Series is used at low load current (several hundred nA), the output voltage may increase due to the leakage current from an output driver at high temperature, and the reverse current protection mode may not be released. Perform sufficient evaluation with the actual device in use. • Note that the output voltage may increase due to the leakage current from an output driver even if the ON / OFF pin is at OFF level when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-13R1 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "5. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)" in " Reference Data" for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN): Output capacitor (CL): 1.0 μF or more 1.0 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply's fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage's fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 12 in " Electrical Characteristics" and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 24 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series  Characteristics (Typical Data) Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1 VOUT(S) = 1.2 V VOUT [V] VOUT(S) = 3.0 V 3.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 3.0 VIN = 2.0 V VIN = 2.2 V VIN = 3.2 V VIN = 3.5 V VIN = 4.0 V VIN = 5.0 V VIN = 5.5 V 2.4 1.8 1.2 0.6 VIN = 5.5 V 0 1. 3 1. 2 VOUT [V] 1. 0 50 100 150 200 250 300 350 400 IOUT [mA] 0 50 100 150 200 250 300 350 400 IOUT [mA] VOUT(S) = 4.0 V 4.5 VOUT [V] 3.6 Remark VIN = 4.5 V VIN = 5.0 V VIN = 5.5 V 2.7 1.8 0.9 0 0 50 100 150 200 250 300 350 400 IOUT [mA] Output voltage vs. Input voltage (Ta = +25°C) VOUT [V] 2. 1 VOUT(S) = 1.2 V 2. 2 3.6 1.2 3.0 0.9 IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 0.6 0.3 IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 1.8 1.2 0 0 VOUT [V] 2.4 0.6 0 2. 3 VOUT(S) = 3.0 V 1.5 VOUT [V] 2. In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 of Table 12 in " Electrical Characteristics" 2. The package power dissipation 1 2 3 VIN [V] 4 5 6 0 1 2 3 VIN [V] 4 5 6 VOUT(S) = 4.0 V 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 0 1 2 3 VIN [V] 4 5 6 25 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 Dropout voltage vs. Output current 3. 1 VOUT(S) = 1.2 V Vdrop [V] 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 Ta = +85°C Ta = +25°C Ta = −40°C 0 3. 3 Vdrop [V] 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 50 100 75 IOUT [mA] 125 150 125 150 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 Ta = +85°C Ta = +25°C Ta = −40°C 0 25 50 100 75 IOUT [mA] 125 Ta = +85°C Ta = +25°C Ta = −40°C 25 50 100 75 IOUT [mA] Vdrop [V] Dropout voltage vs. Set output voltage 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 IOUT = 150 mA IOUT = 100 mA IOUT = 30 mA IOUT = 10 mA IOUT = 1 mA 1.0 Remark 26 25 VOUT(S) = 3.0 V VOUT(S) = 4.0 V 0 4. 3. 2 Vdrop [V] 3. 1.6 2.2 2.8 VOUT(S) [V] 3.4 4.0 In dashed line areas, the reverse current protection mode and the normal operation mode are repeated. 150 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series Output voltage vs. Ambient temperature VOUT [V] 5. 1 VOUT(S) = 1.2 V 5. 2 3.30 1.26 3.15 1.20 1.08 3.00 2.85 1.14 5. 3 VOUT(S) = 3.0 V 1.32 VOUT [V] 5. −40 −25 2.70 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 75 85 50 VOUT(S) = 4.0 V 4.20 VOUT [V] 4.10 4.00 3.90 3.80 6. −40 −25 Current consumption vs. Input voltage 6. 1 VOUT(S) = 1.2 V 6. 2 10 ISS1 [μA] ISS1 [μA] 8 6 4 2 0 1 2 3 VIN [V] 6 Ta = +85°C Ta = +25°C Ta = −40°C 4 2 Ta = −40°C 0 6. 3 10 Ta = +85°C Ta = +25°C 8 VOUT(S) = 3.0 V 0 4 5 6 4 5 6 0 1 2 3 VIN [V] 4 5 6 VOUT(S) = 4.0 V 10 ISS1 [μA] 8 Ta = +85°C Ta = +25°C Ta = −40°C 6 4 2 0 0 1 2 3 VIN [V] 27 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 7. Reverse current vs. VOUT pin voltage 7. 1 VIN = 0 V 100 Ta = +85°C Ta = +25°C IREV [nA] 80 60 40 Ta = −40°C 20 0 0 8. 1 2 3 4 VOUT [V] 5 6 Ripple rejection (Ta = +25°C) 8. 1 VOUT(S) = 1.2 V 8. 2 VOUT(S) = 3.0 V 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 8. 3 100 1k 10k 100k Frequency [Hz] 1M VOUT(S) = 4.0 V Ripple Rejection [dB] VIN = 5.0 V, CL = 1.0 μF 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 28 100 1k 10k 100k Frequency [Hz] VIN = 4.0 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.2 V, CL = 1.0 μF 1M 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series  Reference Data 1. Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT(S) = 1.2 V 1. 2 IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 4.0 V ↔ 5.0 V, tr = tf = 5.0 μs 7.0 3.20 6.0 3.15 5.0 3.10 VIN 4.0 3.05 3.0 3.00 VOUT 2.0 2.95 1.0 2.90 0 2.85 −400 −200 0 200 400 600 800 t [μs] VIN [V] VIN [V] VOUT [V] VOUT [V] IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 2.2 V ↔ 3.2 V, tr = tf = 5.0 μs 4.0 1.40 3.5 1.35 3.0 1.30 2.5 1.25 VIN 2.0 1.20 VOUT 1.5 1.15 1.0 1.10 0.5 1.05 0 1.00 −400 −200 0 200 400 600 800 t [μs] 1. 3 VOUT(S) = 4.0 V VOUT(S) = 3.0 V VIN [V] VOUT [V] IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 5.0 V ↔ 5.5 V, tr = tf = 5.0 μs 7.0 4.15 6.0 4.10 VIN 5.0 4.05 4.0 4.00 VOUT 3.0 3.95 2.0 3.90 1.0 3.85 0 3.80 −400 −200 0 200 400 600 800 t [μs] Transient response characteristics of load (Ta = +25°C) VOUT(S) = 1.2 V 2. 2 IOUT VOUT −200 −100 0 100 t [μs] 200 300 400 200 100 0 −100 −200 −300 −400 −500 −600 VOUT [V] 1.40 1.35 1.30 1.25 1.20 1.15 1.10 1.05 1.00 VIN = 2.2 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA IOUT [mA] VOUT [V] VIN = 2.2 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA 2.00 1.80 1.60 IOUT 1.40 1.20 VOUT 1.00 0.80 0.60 −200 −100 VOUT −400 −200 0 200 t [μs] 400 600 800 VIN = 4.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA VOUT [V] IOUT 200 100 0 −100 −200 −300 −400 −500 −600 IOUT [mA] VOUT [V] 100 200 300 400 500 t [μs] VOUT(S) = 3.0 V VIN = 4.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA 3.20 3.15 3.10 3.05 3.00 2.95 2.90 2.85 2.80 0 200 100 0 −100 −200 −300 −400 −500 IOUT [mA] 2. 1 3.80 3.60 3.40 IOUT 3.20 3.00 VOUT 2.80 2.60 2.40 2.20 −400 −200 0 200 400 600 800 1000 t [μs] 200 100 0 −100 −200 −300 −400 −500 −600 IOUT [mA] 2. 29 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 VOUT(S) = 4.0 V VOUT −400 −200 0 200 t [μs] 400 800 3. 2 VIN = 2.2 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 2.2 V, tr = 1.0 μs 6 5 4 4 4 VON / OFF 3 2 2 0 VOUT 1 −2 0 0 3. 3 100 200 300 t [μs] 400 500 600 −4 VOUT −800 −400 0 400 t [μs] 800 1200 1600 4 VON / OFF VOUT 3 2 2 0 1 −2 0 0 200 400 600 800 1000 1200 1400 t [μs] −4 3 VIN = 4.0 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 4.0 V, tr = 1.0 μs 6 VON / OFF 4 VOUT 2 2 0 1 −2 0 VIN = 5.0 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 5.0 V, tr = 1.0 μs 6 4 VOUT(S) = 3.0 V 0 VOUT(S) = 4.0 V 5 VOUT [V] 5 VOUT [V] IOUT 200 100 0 −100 −200 −300 −400 −500 −600 200 400 600 800 1000 1200 1400 t [μs] −4 VON / OFF [V] VOUT(S) = 1.2 V VON / OFF [V] 3. 1 30 4.60 4.40 4.20 4.00 3.80 3.60 3.40 3.20 3.00 Transient response characteristics of ON / OFF pin when rising (Ta = +25°C) 3. VOUT [V] 600 VOUT [V] IOUT 200 100 0 −100 −200 −300 −400 −500 −600 VON / OFF [V] VOUT [V] 4.20 4.15 4.10 4.05 4.00 3.95 3.90 3.85 3.80 VIN = 5.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA IOUT [mA] VIN = 5.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA IOUT [mA] 2. 3 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 4. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) tDSC [ms] VIN = VOUT(S) + 1.0 V, CIN = 1.0 μF, IOUT = no load, VON / OFF = VOUT(S) + 1.0 V → 0 V, tf = 1.0 μs 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 1.0 μs VON / OFF VOUT(S) = 1.2 V VOUT(S) = 3.0 V VOUT(S) = 4.0 V VSS tDSC VOUT 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 26 S-13R1 Series A / B type (with discharge shunt function) 5. Figure 27 Test Condition of Discharge Time Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF RESR [Ω] 100 CIN Stable ON / OFF 0 0.01 VIN VOUT VSS CL *1 RESR 150 IOUT [mA] *1. Figure 28 CL: ROHM Co.,Ltd. MCH184FN105Z (1.0 μF) Figure 29 31 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00  Marking Specifications 1. SOT-23-5 Top view 5 (1) to (3): (4): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code 1. 1 S-13R1 Series A type Product Name S-13R1A12-M5T1U3 S-13R1A13-M5T1U3 S-13R1A14-M5T1U3 S-13R1A15-M5T1U3 S-13R1A16-M5T1U3 S-13R1A17-M5T1U3 S-13R1A18-M5T1U3 S-13R1A1J-M5T1U3 S-13R1A19-M5T1U3 S-13R1A20-M5T1U3 S-13R1A21-M5T1U3 S-13R1A22-M5T1U3 S-13R1A23-M5T1U3 S-13R1A24-M5T1U3 S-13R1A25-M5T1U3 S-13R1A26-M5T1U3 S-13R1A27-M5T1U3 S-13R1A28-M5T1U3 S-13R1A2J-M5T1U3 S-13R1A29-M5T1U3 S-13R1A30-M5T1U3 S-13R1A31-M5T1U3 S-13R1A32-M5T1U3 S-13R1A33-M5T1U3 S-13R1A34-M5T1U3 S-13R1A35-M5T1U3 S-13R1A36-M5T1U3 S-13R1A37-M5T1U3 S-13R1A38-M5T1U3 S-13R1A39-M5T1U3 S-13R1A40-M5T1U3 32 1. 2 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) A A A B A C A D A E A F A G A 5 A H A I A J A K A L A M A N A O A P A Q A 6 A R A S A T A U A V A W A X A Y A Z A 2 A 3 A 4 S-13R1 Series B type Product Name S-13R1B12-M5T1U3 S-13R1B13-M5T1U3 S-13R1B14-M5T1U3 S-13R1B15-M5T1U3 S-13R1B16-M5T1U3 S-13R1B17-M5T1U3 S-13R1B18-M5T1U3 S-13R1B1J-M5T1U3 S-13R1B19-M5T1U3 S-13R1B20-M5T1U3 S-13R1B21-M5T1U3 S-13R1B22-M5T1U3 S-13R1B23-M5T1U3 S-13R1B24-M5T1U3 S-13R1B25-M5T1U3 S-13R1B26-M5T1U3 S-13R1B27-M5T1U3 S-13R1B28-M5T1U3 S-13R1B2J-M5T1U3 S-13R1B29-M5T1U3 S-13R1B30-M5T1U3 S-13R1B31-M5T1U3 S-13R1B32-M5T1U3 S-13R1B33-M5T1U3 S-13R1B34-M5T1U3 S-13R1B35-M5T1U3 S-13R1B36-M5T1U3 S-13R1B37-M5T1U3 S-13R1B38-M5T1U3 S-13R1B39-M5T1U3 S-13R1B40-M5T1U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) B A B B B C B D B E B F B G B 5 B H B I B J B K B L B M B N B O B P B Q B 6 B R B S B T B U B V B W B X B Y B Z B 2 B 3 B 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 1. 3 S-13R1 Series C type Product Name S-13R1C12-M5T1U3 S-13R1C13-M5T1U3 S-13R1C14-M5T1U3 S-13R1C15-M5T1U3 S-13R1C16-M5T1U3 S-13R1C17-M5T1U3 S-13R1C18-M5T1U3 S-13R1C1J-M5T1U3 S-13R1C19-M5T1U3 S-13R1C20-M5T1U3 S-13R1C21-M5T1U3 S-13R1C22-M5T1U3 S-13R1C23-M5T1U3 S-13R1C24-M5T1U3 S-13R1C25-M5T1U3 S-13R1C26-M5T1U3 S-13R1C27-M5T1U3 S-13R1C28-M5T1U3 S-13R1C2J-M5T1U3 S-13R1C29-M5T1U3 S-13R1C30-M5T1U3 S-13R1C31-M5T1U3 S-13R1C32-M5T1U3 S-13R1C33-M5T1U3 S-13R1C34-M5T1U3 S-13R1C35-M5T1U3 S-13R1C36-M5T1U3 S-13R1C37-M5T1U3 S-13R1C38-M5T1U3 S-13R1C39-M5T1U3 S-13R1C40-M5T1U3 1. 4 Product Code (1) (2) (3) 2 C A 2 C B 2 C C 2 C D 2 C E 2 C F 2 C G 2 C 5 2 C H 2 C I 2 C J 2 C K 2 C L 2 C M 2 C N 2 C O 2 C P 2 C Q 2 C 6 2 C R 2 C S 2 C T 2 C U 2 C V 2 C W 2 C X 2 C Y 2 C Z 2 C 2 2 C 3 2 C 4 S-13R1 Series D type Product Name S-13R1D12-M5T1U3 S-13R1D13-M5T1U3 S-13R1D14-M5T1U3 S-13R1D15-M5T1U3 S-13R1D16-M5T1U3 S-13R1D17-M5T1U3 S-13R1D18-M5T1U3 S-13R1D1J-M5T1U3 S-13R1D19-M5T1U3 S-13R1D20-M5T1U3 S-13R1D21-M5T1U3 S-13R1D22-M5T1U3 S-13R1D23-M5T1U3 S-13R1D24-M5T1U3 S-13R1D25-M5T1U3 S-13R1D26-M5T1U3 S-13R1D27-M5T1U3 S-13R1D28-M5T1U3 S-13R1D2J-M5T1U3 S-13R1D29-M5T1U3 S-13R1D30-M5T1U3 S-13R1D31-M5T1U3 S-13R1D32-M5T1U3 S-13R1D33-M5T1U3 S-13R1D34-M5T1U3 S-13R1D35-M5T1U3 S-13R1D36-M5T1U3 S-13R1D37-M5T1U3 S-13R1D38-M5T1U3 S-13R1D39-M5T1U3 S-13R1D40-M5T1U3 Product Code (1) (2) (3) 2 D A 2 D B 2 D C 2 D D 2 D E 2 D F 2 D G 2 D 5 2 D H 2 D I 2 D J 2 D K 2 D L 2 D M 2 D N 2 D O 2 D P 2 D Q 2 D 6 2 D R 2 D S 2 D T 2 D U 2 D V 2 D W 2 D X 2 D Y 2 D Z 2 D 2 2 D 3 2 D 4 33 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 2. SC-82AB Top view 4 (1) to (3): 3 Product code (Refer to Product name vs. Product code) (1) (2) (3) 1 2 Product name vs. Product code 2. 1 S-13R1 Series A type Product Name S-13R1A12-N4T1U3 S-13R1A13-N4T1U3 S-13R1A14-N4T1U3 S-13R1A15-N4T1U3 S-13R1A16-N4T1U3 S-13R1A17-N4T1U3 S-13R1A18-N4T1U3 S-13R1A1J-N4T1U3 S-13R1A19-N4T1U3 S-13R1A20-N4T1U3 S-13R1A21-N4T1U3 S-13R1A22-N4T1U3 S-13R1A23-N4T1U3 S-13R1A24-N4T1U3 S-13R1A25-N4T1U3 S-13R1A26-N4T1U3 S-13R1A27-N4T1U3 S-13R1A28-N4T1U3 S-13R1A2J-N4T1U3 S-13R1A29-N4T1U3 S-13R1A30-N4T1U3 S-13R1A31-N4T1U3 S-13R1A32-N4T1U3 S-13R1A33-N4T1U3 S-13R1A34-N4T1U3 S-13R1A35-N4T1U3 S-13R1A36-N4T1U3 S-13R1A37-N4T1U3 S-13R1A38-N4T1U3 S-13R1A39-N4T1U3 S-13R1A40-N4T1U3 34 2. 2 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) A A A B A C A D A E A F A G A 5 A H A I A J A K A L A M A N A O A P A Q A 6 A R A S A T A U A V A W A X A Y A Z A 2 A 3 A 4 S-13R1 Series B type Product Name S-13R1B12-N4T1U3 S-13R1B13-N4T1U3 S-13R1B14-N4T1U3 S-13R1B15-N4T1U3 S-13R1B16-N4T1U3 S-13R1B17-N4T1U3 S-13R1B18-N4T1U3 S-13R1B1J-N4T1U3 S-13R1B19-N4T1U3 S-13R1B20-N4T1U3 S-13R1B21-N4T1U3 S-13R1B22-N4T1U3 S-13R1B23-N4T1U3 S-13R1B24-N4T1U3 S-13R1B25-N4T1U3 S-13R1B26-N4T1U3 S-13R1B27-N4T1U3 S-13R1B28-N4T1U3 S-13R1B2J-N4T1U3 S-13R1B29-N4T1U3 S-13R1B30-N4T1U3 S-13R1B31-N4T1U3 S-13R1B32-N4T1U3 S-13R1B33-N4T1U3 S-13R1B34-N4T1U3 S-13R1B35-N4T1U3 S-13R1B36-N4T1U3 S-13R1B37-N4T1U3 S-13R1B38-N4T1U3 S-13R1B39-N4T1U3 S-13R1B40-N4T1U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) B A B B B C B D B E B F B G B 5 B H B I B J B K B L B M B N B O B P B Q B 6 B R B S B T B U B V B W B X B Y B Z B 2 B 3 B 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 2. 3 S-13R1 Series C type Product Name S-13R1C12-N4T1U3 S-13R1C13-N4T1U3 S-13R1C14-N4T1U3 S-13R1C15-N4T1U3 S-13R1C16-N4T1U3 S-13R1C17-N4T1U3 S-13R1C18-N4T1U3 S-13R1C1J-N4T1U3 S-13R1C19-N4T1U3 S-13R1C20-N4T1U3 S-13R1C21-N4T1U3 S-13R1C22-N4T1U3 S-13R1C23-N4T1U3 S-13R1C24-N4T1U3 S-13R1C25-N4T1U3 S-13R1C26-N4T1U3 S-13R1C27-N4T1U3 S-13R1C28-N4T1U3 S-13R1C2J-N4T1U3 S-13R1C29-N4T1U3 S-13R1C30-N4T1U3 S-13R1C31-N4T1U3 S-13R1C32-N4T1U3 S-13R1C33-N4T1U3 S-13R1C34-N4T1U3 S-13R1C35-N4T1U3 S-13R1C36-N4T1U3 S-13R1C37-N4T1U3 S-13R1C38-N4T1U3 S-13R1C39-N4T1U3 S-13R1C40-N4T1U3 2. 4 Product Code (1) (2) (3) 2 C A 2 C B 2 C C 2 C D 2 C E 2 C F 2 C G 2 C 5 2 C H 2 C I 2 C J 2 C K 2 C L 2 C M 2 C N 2 C O 2 C P 2 C Q 2 C 6 2 C R 2 C S 2 C T 2 C U 2 C V 2 C W 2 C X 2 C Y 2 C Z 2 C 2 2 C 3 2 C 4 S-13R1 Series D type Product Name S-13R1D12-N4T1U3 S-13R1D13-N4T1U3 S-13R1D14-N4T1U3 S-13R1D15-N4T1U3 S-13R1D16-N4T1U3 S-13R1D17-N4T1U3 S-13R1D18-N4T1U3 S-13R1D1J-N4T1U3 S-13R1D19-N4T1U3 S-13R1D20-N4T1U3 S-13R1D21-N4T1U3 S-13R1D22-N4T1U3 S-13R1D23-N4T1U3 S-13R1D24-N4T1U3 S-13R1D25-N4T1U3 S-13R1D26-N4T1U3 S-13R1D27-N4T1U3 S-13R1D28-N4T1U3 S-13R1D2J-N4T1U3 S-13R1D29-N4T1U3 S-13R1D30-N4T1U3 S-13R1D31-N4T1U3 S-13R1D32-N4T1U3 S-13R1D33-N4T1U3 S-13R1D34-N4T1U3 S-13R1D35-N4T1U3 S-13R1D36-N4T1U3 S-13R1D37-N4T1U3 S-13R1D38-N4T1U3 S-13R1D39-N4T1U3 S-13R1D40-N4T1U3 Product Code (1) (2) (3) 2 D A 2 D B 2 D C 2 D D 2 D E 2 D F 2 D G 2 D 5 2 D H 2 D I 2 D J 2 D K 2 D L 2 D M 2 D N 2 D O 2 D P 2 D Q 2 D 6 2 D R 2 D S 2 D T 2 D U 2 D V 2 D W 2 D X 2 D Y 2 D Z 2 D 2 2 D 3 2 D 4 35 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION S-13R1 Series Rev.1.3_00 3. HSNT-4 (1010) Top view 4 (1) to (3): (4), (5): 3 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) (5) 1 2 Product name vs. Product code 3. 1 S-13R1 Series A type Product Name S-13R1A12-A4T2U3 S-13R1A13-A4T2U3 S-13R1A14-A4T2U3 S-13R1A15-A4T2U3 S-13R1A16-A4T2U3 S-13R1A17-A4T2U3 S-13R1A18-A4T2U3 S-13R1A1J-A4T2U3 S-13R1A19-A4T2U3 S-13R1A20-A4T2U3 S-13R1A21-A4T2U3 S-13R1A22-A4T2U3 S-13R1A23-A4T2U3 S-13R1A24-A4T2U3 S-13R1A25-A4T2U3 S-13R1A26-A4T2U3 S-13R1A27-A4T2U3 S-13R1A28-A4T2U3 S-13R1A2J-A4T2U3 S-13R1A29-A4T2U3 S-13R1A30-A4T2U3 S-13R1A31-A4T2U3 S-13R1A32-A4T2U3 S-13R1A33-A4T2U3 S-13R1A34-A4T2U3 S-13R1A35-A4T2U3 S-13R1A36-A4T2U3 S-13R1A37-A4T2U3 S-13R1A38-A4T2U3 S-13R1A39-A4T2U3 S-13R1A40-A4T2U3 36 3. 2 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) A A A B A C A D A E A F A G A 5 A H A I A J A K A L A M A N A O A P A Q A 6 A R A S A T A U A V A W A X A Y A Z A 2 A 3 A 4 S-13R1 Series B type Product Name S-13R1B12-A4T2U3 S-13R1B13-A4T2U3 S-13R1B14-A4T2U3 S-13R1B15-A4T2U3 S-13R1B16-A4T2U3 S-13R1B17-A4T2U3 S-13R1B18-A4T2U3 S-13R1B1J-A4T2U3 S-13R1B19-A4T2U3 S-13R1B20-A4T2U3 S-13R1B21-A4T2U3 S-13R1B22-A4T2U3 S-13R1B23-A4T2U3 S-13R1B24-A4T2U3 S-13R1B25-A4T2U3 S-13R1B26-A4T2U3 S-13R1B27-A4T2U3 S-13R1B28-A4T2U3 S-13R1B2J-A4T2U3 S-13R1B29-A4T2U3 S-13R1B30-A4T2U3 S-13R1B31-A4T2U3 S-13R1B32-A4T2U3 S-13R1B33-A4T2U3 S-13R1B34-A4T2U3 S-13R1B35-A4T2U3 S-13R1B36-A4T2U3 S-13R1B37-A4T2U3 S-13R1B38-A4T2U3 S-13R1B39-A4T2U3 S-13R1B40-A4T2U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) B A B B B C B D B E B F B G B 5 B H B I B J B K B L B M B N B O B P B Q B 6 B R B S B T B U B V B W B X B Y B Z B 2 B 3 B 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-13R1 Series 3. 3 S-13R1 Series C type Product Name S-13R1C12-A4T2U3 S-13R1C13-A4T2U3 S-13R1C14-A4T2U3 S-13R1C15-A4T2U3 S-13R1C16-A4T2U3 S-13R1C17-A4T2U3 S-13R1C18-A4T2U3 S-13R1C1J-A4T2U3 S-13R1C19-A4T2U3 S-13R1C20-A4T2U3 S-13R1C21-A4T2U3 S-13R1C22-A4T2U3 S-13R1C23-A4T2U3 S-13R1C24-A4T2U3 S-13R1C25-A4T2U3 S-13R1C26-A4T2U3 S-13R1C27-A4T2U3 S-13R1C28-A4T2U3 S-13R1C2J-A4T2U3 S-13R1C29-A4T2U3 S-13R1C30-A4T2U3 S-13R1C31-A4T2U3 S-13R1C32-A4T2U3 S-13R1C33-A4T2U3 S-13R1C34-A4T2U3 S-13R1C35-A4T2U3 S-13R1C36-A4T2U3 S-13R1C37-A4T2U3 S-13R1C38-A4T2U3 S-13R1C39-A4T2U3 S-13R1C40-A4T2U3 3. 4 Product Code (1) (2) (3) 2 C A 2 C B 2 C C 2 C D 2 C E 2 C F 2 C G 2 C 5 2 C H 2 C I 2 C J 2 C K 2 C L 2 C M 2 C N 2 C O 2 C P 2 C Q 2 C 6 2 C R 2 C S 2 C T 2 C U 2 C V 2 C W 2 C X 2 C Y 2 C Z 2 C 2 2 C 3 2 C 4 S-13R1 Series D type Product Name S-13R1D12-A4T2U3 S-13R1D13-A4T2U3 S-13R1D14-A4T2U3 S-13R1D15-A4T2U3 S-13R1D16-A4T2U3 S-13R1D17-A4T2U3 S-13R1D18-A4T2U3 S-13R1D1J-A4T2U3 S-13R1D19-A4T2U3 S-13R1D20-A4T2U3 S-13R1D21-A4T2U3 S-13R1D22-A4T2U3 S-13R1D23-A4T2U3 S-13R1D24-A4T2U3 S-13R1D25-A4T2U3 S-13R1D26-A4T2U3 S-13R1D27-A4T2U3 S-13R1D28-A4T2U3 S-13R1D2J-A4T2U3 S-13R1D29-A4T2U3 S-13R1D30-A4T2U3 S-13R1D31-A4T2U3 S-13R1D32-A4T2U3 S-13R1D33-A4T2U3 S-13R1D34-A4T2U3 S-13R1D35-A4T2U3 S-13R1D36-A4T2U3 S-13R1D37-A4T2U3 S-13R1D38-A4T2U3 S-13R1D39-A4T2U3 S-13R1D40-A4T2U3 Product Code (1) (2) (3) 2 D A 2 D B 2 D C 2 D D 2 D E 2 D F 2 D G 2 D 5 2 D H 2 D I 2 D J 2 D K 2 D L 2 D M 2 D N 2 D O 2 D P 2 D Q 2 D 6 2 D R 2 D S 2 D T 2 D U 2 D V 2 D W 2 D X 2 D Y 2 D Z 2 D 2 2 D 3 2 D 4 37 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 2.0±0.2 1.3±0.2 4 3 0.05 0.3 +0.1 -0.05 +0.1 0.16 -0.06 2 1 +0.1 0.4 -0.05 No. NP004-A-P-SD-2.0 TITLE SC82AB-A-PKG Dimensions NP004-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 1.1±0.1 4.0±0.1 0.2±0.05 ø1.05±0.1 (0.7) 2.2±0.2 2 1 3 4 Feed direction No. NP004-A-C-SD-3.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-SD-3.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.1 ø1.5 1.1±0.1 +0.1 -0 4.0±0.1 0.2±0.05 ø1.05±0.1 2.3±0.15 2 1 3 4 Feed direction No. NP004-A-C-S1-2.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-S1-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. NP004-A-R-SD-1.1 TITLE SC82AB-A-Reel No. NP004-A-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.05 0.25±0.05 +0.1 1.12±0.05 2 1 3 4 ø0.5 -0 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-1.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-13R1B34-N4T1U3
物料型号:S-13R1 Series,由ABLIC公司开发,是一款5.5V输入、150mA输出电流的正电压调节器IC。
器件简介:S-13R1系列采用CMOS技术开发,具有低 dropout 电压、高准确度输出电压和低电流消耗的特点。即使在典型值为5μA的低电流消耗下,也能提供高达70dB的高纹波抑制,并且可以使用1.0μF或更大的陶瓷电容器作为输入和输出电容器。
引脚分配: - SOT-23-5封装:1. VIN(输入电压引脚),2. VSS(地引脚),3. ON/OFF(开关引脚),4. NC(无连接),5. VOUT(输出电压引脚)。 - SC-82AB封装:1. ON/OFF(开关引脚),2. VSS(地引脚),3. VOUT(输出电压引脚),4. VIN(输入电压引脚)。 - HSNT-4 (1010)封装:1. VOUT(输出电压引脚),2. VSS(地引脚),3. ON/OFF(开关引脚),4. VIN(输入电压引脚)。
参数特性: - 输出电压:1.2V至4.0V,以0.05V步进可调。 - 输入电压:1.2V至5.5V。 - 输出电压精度:±1.0%(1.2V至1.45V输出产品为±15mV)。 - dropout电压:典型值为150mV(3.0V输出产品,IOUT=100mA)。 - 电流消耗:在操作期间典型值为5μA,最大值为9μA;在关闭电源时典型值为0.1μA,最大值为1.0μA。 - 输出电流:可达150mA(VIN ≥ VOUT(S) + 1.0V)。 - 纹波抑制:典型值为70dB(3.0V输出产品,频率=1.0kHz)。 - 反向电流保护功能:最大反向电流为0.09μA。
功能详解: - 包括过流保护电路,防止负载电流超过输出晶体管的电流容量。 - 热关断电路,防止因过热而损坏。 - 内置的反向电流保护功能,可以控制从VOUT引脚流向VIN引脚的反向电流。 - 可选择的放电旁路功能和下拉功能。
应用信息: - 适用于电池供电设备的恒压电源、便携设备、家用电器和手机的恒压电源。
封装信息:S-13R1系列提供SOT-23-5、SC-82AB和HSNT-4 (1010)三种封装类型。
S-13R1B34-N4T1U3 价格&库存
很抱歉,暂时无法提供与“S-13R1B34-N4T1U3”相匹配的价格&库存,您可以联系我们找货
