RS2117YN
RS2117YN
    RUNIC(润石)
    MSOP-10
    IC SWITCH DUAL SPDT 10MSOP
RS2117YN 数据手册
RS2117 4Ω,400MHz Bandwidth, Dual-Channel SPDT Analog Switch with Negative Signaling Capability FEATURES • -3dB Bandwidth: 400MHz • Supply Range: +2.5V to +5.5V • Negative Signal Swing Capability: -2V to V+ • Break-Before-Make Switching • Fast tON, tOFF Times • 1.8V Logic Control • Extended Industrial Temperature Range: -40°C to +85°C • Small Package Available in Green QFN-1.4x1.8-10L Package DESCRIPTION The RS2117 is a bidirectional, dual-channel singlepole double-throw (SPDT) analog switch that is designed to operate from 2.5V to 5.5V, and the switches can handle negative signal down to -2.0V. The device also offers a low ON-state resistance of 4Ω (typical), which is matched to within 1 Ω between channels. This device is available packaged in QFN1.4x1.8-10L. Functional Block Diagram SPDT NC1 COM1 APPLICATIONS • Wearable Devices • Battery-Operated Equipment • Signal Gating, Chopping, Modulation or Demodulation (Modem) • Portable Computing • Cell Phones REV B.1 NO1 IN 1 SPDT COM2 NC2 NO2 IN 2 1 / 15 www.run-ic.com RS2117 PIN CONFIGURATIONS (TOP VIEW) NC2 GND 7 6 IN2 8 5 NC1 COM2 9 4 IN1 NO2 10 3 COM1 1 2 V+ NO1 QFN-1.4x1.8-10L PIN DESCRIPTION NAME PIN FUNCTION V+ 1 NO1, NO2 2,10 Normally-Open Terminal COM1, COM2 3,9 Common Terminal IN1, IN2 4,8 Digital Control Pin NC1, NC2 5,7 Normally-Closed Terminal GND 6 Power Supply Ground NOTE: NOX, NCX and COMX terminals may be an input or output. FUNCTION TABLE LOGIC NO NC 0 OFF ON 1 ON OFF NOTE: Switches shown for logic “0” input. 2 / 15 www.run-ic.com RS2117 PIN CONFIGURATIONS (TOP VIEW) V+ 1 10 NO2 NO1 2 9 COM2 COM1 3 8 IN2 IN1 4 7 NC2 NC1 5 6 GND MSOP-10 PIN DESCRIPTION NAME PIN FUNCTION V+ 1 NO1, NO2 2,10 Normally-Open Terminal COM1, COM2 3,9 Common Terminal IN1, IN2 4,8 Digital Control Pin NC1, NC2 5,7 Normally-Closed Terminal GND 6 Power Supply Ground NOTE: NOX, NCX and COMX terminals may be an input or output. FUNCTION TABLE LOGIC NO NC 0 OFF ON 1 ON OFF NOTE: Switches shown for logic “0” input. 3 / 15 www.run-ic.com RS2117 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) SYMBOL PARAMETER MIN MAX V+ Supply Voltage -0.3 6.0 VIN Input Voltage(2) -0.3 6.0 Analog Voltage Range -2.0 (V+)+0.3 Digital Voltage Range -0.3 (V+)+0.3 Continuous Current NO, NC, or COM -100 +100 Peak Current NO, NC, or COM -150 +150 -65 +150 IPEAK TJ Junction Temperature Tstg Storage temperature 150 UNIT V mA °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.3V beyond the supply rails should be current-limited to 10mA or less. ESD Ratings V(ESD) Electrostatic discharge VALUE UNIT Human-body model (HBM) ±2000 V Machine Model (MM) ±200 V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) (3) SYMBOL PARAMETER MIN MAX UNIT VCC Supply Voltage 2.5 5.5 V TA Operating temperature -40 +85 °C Thermal Information RS2117 10 PINS THERMAL METRIC UNIT MSOP-10 QFN-1.4x1.8-10L Junction-to-ambient thermal resistance 180.7 120 °C/W Junction-to-case(top) thermal resistance 66.2 46.0 °C/W RϴJB Junction-to-board thermal resistance 103.2 44.5 °C/W ѰJT Junction-to-top characterization parameter 11.2 1.5 °C/W ѰJB Junction-to-board characterization parameter 101.3 44.5 °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A 31.2 °C/W RϴJA RϴJC(top) 4 / 15 www.run-ic.com RS2117 PACKAGE/ORDERING INFORMATION PRODUCT ORDERING NUMBER TEMPERATURE RANGE PACKAGE LEAD PACKAGE MARKING (1/2) PACKAGE OPTION RS2117 RS2117YUTQK10 -40°C ~+85°C QFN-1.4x1.8-10L 2117X Tape and Reel,4000 RS2117 RS2117YN -40°C ~+85°C MSOP-10 RS2117 Tape and Reel,4000 NOTE: (1) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the environmental category on the device. (2) X = Date Code. MARKING INFORMATION 2117 X Date code Product name 5 / 15 www.run-ic.com RS2117 ELECTRICAL CHARACTERISTICS V+ = 5.0 V, TA= –40°C to 85°C (unless otherwise noted) PARAMETER SYMBOL CONDITIONS V+ TA MIN TYP MAX UNITS ANALOG SWITCH Analog Signal Range VNO, VNC, VCOM On-Resistance On-Resistance Match Between Channels On-Resistance Flatness RON ∆RON RFLAT(ON) 2.5V ≤V+≤3.5V FULL 3.5V ≤V+≤ 5.5V 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 NC, NO OFF Leakage Current INC(OFF), INO(OFF) VNO or VNC = 0.3V, V+/2 VCOM = V+/2, 0.3V See Figure 2 NC, NO, COM ON Leakage Current INC(ON), INO(ON), VNO or VNC = 0.3V, Open VCOM = ICOM(ON) Open, 0.3V See Figure 3 -2.0 V+ (V+)-5.5 V+ 7 Ω 7.5 Ω 9 Ω 9.5 Ω 0.5 Ω 0.6 Ω 0.85 Ω 1.0 Ω 2 Ω 2.5 Ω 5 Ω 5.4 Ω 2.5V to FULL 5.5V 1 μA 2.5V to FULL 5.5V 1 μA 5V 3.3V 5V 3.3V 5V 3.3V +25°C 4 V FULL +25°C 6 FULL +25°C 0.15 FULL +25°C 0.25 FULL +25°C 1 FULL +25°C 3 FULL DIGITAL CONTROL INPUTS(1) Input High Voltage VINH Input Low Voltage VINL Input Leakage Current IIN 5V FULL 1.5 V 3.3V FULL 1.3 V 5V FULL 0.5 V 3.3V FULL 0.4 V 1 μA 2.5V to FULL 5.5V VIN = VIO or 0 (1) All unused digital inputs of the device must be held at VIO or GND to ensure proper device operation. 6 / 15 www.run-ic.com RS2117 ELECTRICAL CHARACTERISTICS (continued) V+ = 5.0 V, TEMP= –40°C to 85°C (unless otherwise noted)) PARAMETER SYMBOL CONDITIONS V+ 5V TEMP MIN TYP MAX UNITS DYNAMIC CHARACTERISTICS Turn-On Time tON VCOM = V+, RL = 300Ω, CL = 35pF, See Figure 5 Turn-Off Time tOFF VCOM = V+, RL = 300Ω, CL = 35pF, See Figure 5 Break-Before-Make Time Delay tBBM VNO1 = VNC1 = VNO2 = VNC2 = V+/2, RL = 300Ω, CL = 35pF,See Figure 6 Charge Injection Q Off Isolation OISO -3dB Bandwidth Channel-to-Channel Crosstalk NC, NO OFF Capacitance NC, NO, COM ON Capacitance BW 3.3V 5V 3.3V 5V 3.3V 15 +25°C ns 25 10 +25°C ns 15 5 +25°C ns 10 5V +25°C 15 3.3V +25°C 10 RL = 50Ω, Switch OFF, f = 1MHz See Figure 8 f = 10MHz +25°C -70 dB +25°C -50 dB Switch ON, RL = 50Ω See Figure 7 +25°C 400 MHz +25°C -72 dB +25°C -52 dB +25°C 10 pF +25°C 25 pF VG=GND, RG=0Ω, CL=1.0nF, See Figure 10 Signal=0dBm, RL = f = 1MHz 50Ω, CL = 5pF, See f = 10MHz Figure 9 CNC(OFF), VNC or VNO=V+/2 or GND, Switch CNO(OFF) OFF See Figure 4 CNC(ON), CNO(ON), VNC or VNO=V+/2 or GND, Switch CCOM(ON) ON See Figure 4 XTALK pC POWER REQUIREMENTS Power Supply Range V+ Power Supply Current I+ FULL VIN = GND or V+ 7 / 15 5.5V FULL 2.5 5.5 V 1 μA www.run-ic.com RS2117 TYPICAL CHARACTERISTICS BANDWIDTH 3 0 0 Gain(dB) Gain(dB) BANDWIDTH 3 -3 -3 -6 -6 -9 -9 1 10 100 1,000 1 Frequency(MHz) V+=3.3V 10 100 1,000 Frequency(MHz) V+=5V Typical Ron as a Function of Input Voltage (VI ) for VI = 0 to V+ 12 10 Ron(Ω) 8 6 4 2 0 -2 -1 0 V+=2.5V 1 2 V+=3.3V 8 / 15 3 V+=4V 4 5 V+=5.5V www.run-ic.com RS2117 Parameter Measurement Information Figure 1.ON-State Resistance (ron) Figure 2.OFF-State Leakage Current (ICOM(OFF), INO(OFF)) Figure 3.ON-State Leakage Current (ICOM(ON), INO(ON)) 9 / 15 www.run-ic.com RS2117 Figure 4. Capacitance (CI, CCOM(OFF), CCOM(ON), CNO(OFF), CNO(ON)) Figure 5.Turn-On (tON) and Turn-Off Time (tOFF) Figure 6.Break-Before-Make Time (tBBM) 10 / 15 www.run-ic.com RS2117 Figure 7. Bandwidth (BW) Figure 8.OFF Isolation (OISO) Figure 9. Crosstalk (XTALK) 11 / 15 www.run-ic.com RS2117 Figure 10. Charge Injection (QC) Figure11.Total Harmonic Distort 12 / 15 www.run-ic.com RS2117 TYPICAL APPLICATION Analog signals that range over the entire supply voltage VCC to GND can be passed with very little change in ON-state resistance. The switches are bidirectional, so the NO, NC, and COM pins can be used as either inputs or outputs. Pull the digitally controlled input select pin IN to V CC or GND to avoid unwanted switch states that could result if the logic control pin is left floating. 5V V+ System Digital Control Signal Path INx NOx Device 1 NCx Device 2 5V COMx 5V GND Figure 12. Typical Application Schematic 13 / 15 www.run-ic.com RS2117 PACKAGE OUTLINE DIMENSIONS QFN-1.4x1.8-10L E c L1 e PIN #1 IDENTIFICA TION CHAMFER 0.350 ×45° (×9) D d L2 PIN #1 D OT BY MARKING TOP V IEW b a BOTTOM VIEW 2.100 0.563 A 1.700 A2 A1 0.663 0.225 SIDE VIEW 0.20 0.40 RECOMMENDED LAND PATTERN Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.500 0.600 0.020 0.024 A1 0.000 0.050 0.000 0.002 A2 0.203 REF 0.008 REF a 0.050 0.150 0.002 0.006 b 0.150 0.250 0.006 0.010 c 0.450 0.550 0.018 0.022 d 0.800 REF 0.031 REF D 1.350 1.450 0.053 0.057 E 1.750 1.850 0.069 0.073 e 0.400 TYP 0.016 TYP L1 0.350 0.450 0.014 0.018 L2 0.450 0.550 0.018 0.022 14 / 15 www.run-ic.com RS2117 MSOP-10 b e E 4.65 E1 1.02 0.31 D 0.5 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol A c L Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.180 0.280 0.007 0.011 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.50(BSC) 0.020(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 15 / 15 www.run-ic.com
RS2117YN 价格&库存
很抱歉,暂时无法提供与“RS2117YN”相匹配的价格&库存,您可以联系我们找货
RS2117YN
    • 1+1.33000
    • 30+1.28250
    • 100+1.23500
    • 500+1.14000
    • 1000+1.09250
    • 2000+1.06400
