SPX1117HM3-L-5-0/TR
SPX1117HM3-L-5-0/TR
    ROCHESTER(罗切斯特)
    TO261-4
    IC REG LINEAR 4.90V 800MA
SPX1117HM3-L-5-0/TR 数据手册
SPX1117 800mA Low Dropout Voltage Regulator FEATURES ■ Guaranteed 0.8A Output Current ■ Guaranteed 1A Peak Current ■ Three Terminal Adjustable or Fixed 1.5V, 1.8V, 2.5V, 2.85V, 3.0V, 3.3V and 5V ■ Low Quiescent Current ■ Low Dropout Voltage of 1.1V at 0.8A ■ 0.1% Line and 0.2% Load Regulation ■ Stable with 2.2uF Ceramic Capacitor ■ Overcurrent and Thermal Protection ■ Lead Free, RoHS Compliant Packages: APPLICATIONS ■ Desktop PC's Servers ■ SCSI-II Active Terminator ■ Portable/ Palm Top / Notebook Computers ■ Cordless Phones ■ Battery Chargers ■ Disk Drives ■ Portable Consumer Equipment ■ Portable Instrumentation ■ SMPS Post-Regulator SOT-223,TO-252, TO-220, and TO-263 DESCRIPTION The SPX1117 is a low power positive-voltage regulator designed to satisfy moderate power requirements with a cost effective, small footprint solution. This device is an excellent choice for use in battery-powered applications and portable computers. The SPX1117 features very low quiescent current and a low dropout voltage of 1.1V at a full load. As output current decreases, quiescent current flows into the load, increasing efficiency. SPX1117 is available in adjustable or fixed 1.5V, 1.8V, 2.5V,2.5V, 2.85V, 3.0V, 3.3V and 5V output voltages. The SPX1117 is offered in several 3-pin surface mount packages: SOT-223, TO-252, TO-220 and TO-263. An output capacitor of 10µF provides unconditional stability while a smaller 2.2µF capacitor is sufficient for most applications. FUNCTIONAL DIAGRAM VIN + Current Limit VOUT + ICL AMP - 1.25V VREF + Thermal Limit – ADJ/GND IADJ ~ 50µA – I TL Apr 20-07 Rev B SPX1117 800mA Low Dropout Voltage Regulator 1 © 2007 Sipex Corporation ABSOLUTE MAXIMUM RATINGS Power Dissipation.......................................Internally Limited Lead Temperature (soldering, 5 seconds) ...............260°C Storage Temperature Range.......................-65°C to +150°C Operating Junction Temperature Range.....-40°C to +125°C Input Supply Voltage .................................................... +20V Input to Output Voltage ................................................ 18.8V ESD Rating.................................................................2kV min These are sterss ratings only and functional operation of the device at these ratings or any other above those indicated in the operation sections of the specifications below is not implied. Exposure to absolute maximum rating conditions for extended periods of time may affect reliability. ELECTRICAL CHARACTERISTICS TA = 25°C, CIN = COUT = 10µF, unless otherwise specified. The Boldface applies over the full operating temperature range. PARAMETER CONDITIONS MIN TYP MAX UNITS IOUT = 5mA, VIN =3.0V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 2.9V ≤ VIN ≤ 10V 1.485 1.470 1.500 1.515 1.530 V IOUT = 5mA, VIN =3.3V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 3.2V ≤ VIN ≤ 10V 1.782 1.764 1.800 1.818 1.836 V IOUT = 5mA, VIN =4.0V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 3.9V ≤ VIN ≤ 10V 2.475 2.450 2.500 2.525 2.550 V IOUT = 5mA, VIN =4.35V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 4.25V ≤ VIN ≤ 10V 2.821 2.793 2.850 2.878 2.907 V IOUT = 5mA, VIN =4.5V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 4.4V ≤ VIN ≤ 10V 2.970 2.940 3.000 3.030 3.060 V IOUT = 5mA, VIN =4.8V, TJ = 25ºC 5mA ≤ IOUT ≤ 800mA, 4.7V ≤ VIN ≤ 10V 3.267 3.234 3.300 3.333 3.366 V IOUT = 5mA, VIN =6.5V 5mA ≤ IOUT ≤ 800mA, 6.4V ≤ VIN ≤ 12V 4.950 4.90 5 5.050 5.10 V IOUT=5mA, (VIN - VOUT )= 2V, TJ = 25ºC 5mA≤IOUT≤ 800mA, 1.4V≤(VIN-VOUT)≤ 10V 1.238 1.225 1.250 1.262 1.270 V 1.5V Version Output Voltage 1.8V Version Output Voltage 2.5V Version Output Voltage 2.85V Version Output Voltage 3.00V Version Output Voltage 3.30V Version Output Voltage 5V Version Output Voltage All Voltage Options Reference Voltage Output Voltage Temperature Stability 0.3 % Line Regulation (Note 1) VINMIN ≤VIN≤ 12V,VOUT=Fixed/Adj, IOUT=5mA 3 7 mV Load Regulation (Note 1) 5mA≤IOUT≤ 800mA,VOUT=Fixed/Adj 6 12 mV Dropout Voltage (Note 2) IOUT=100mA IOUT=500mA IOUT=800mA 1.00 1.05 1.10 1.20 1.25 1.30 V Quiescent Current 4.25V≤VIN≤ 6.5V 5 10 mA Apr 20-07 Rev B SPX1117 800mA Low Dropout Voltage Regulator 2 © 2007 Sipex Corporation ELECTRICAL CHARACTERISTICS TA = 25°C, CIN = COUT = 10µF, unless otherwise specified. The Boldface applies over the full operating temperature range. PARAMETER CONDITIONS MIN TYP Adjust Pin Current Current Limit (VIN-VOUT)=5V 1.0 50 1.5 120 2.0 µA A Thermal Regulation 25°C, 30mS pulse 0.01 0.1 %/W Ripple Rejection fRIPPLE=120Hz, (VIN-VOUT)=2V, VRIPPLE=1VPP Long Term Stability RMS Output Noise 60 MAX UNITS 75 dB 125°C, 1000Hrs 0.03 % % of VOUT, 10Hz≤f≤10kHz 0.003 % *Note 1 - For fixed option, VINMIN = VOUT + 1.5V - For adjustable option, VINMIN = VIN - VOUT = 1.4V *Note 2 - Dropout voltage is the input voltage minus output voltage that produces a 1% decrease in output voltage with respect to the nominal output voltage at VIN = VOUT + 1.5V Apr 20-07 Rev B SPX1117 800mA Low Dropout Voltage Regulator 3 © 2007 Sipex Corporation 3.320 3.315 3.310 3.305 3.300 3.295 3.290 3.285 3.280 3.325 3.320 Vout (V) Output Voltage TYPICAL PERFORMANCE CHARACTERISTICS 3.315 3.310 3.305 3.300 10 100 4.5 1000 6.5 8.5 1.3 1.2 1.1 1.0 0.9 200 300 400 500 600 700 800 900 1000 1.50 1.00 0.50 0.00 -50 -25 0 25 Indicating Current Limit Starts Vout (V) Output Deviation (mV) 125 1.27 -100 1.5 Output Current (A) 100 1.275 0 1.0 V = 4.0V V =3.3V Fixed 1 =10mA C =1µF Tan Cap C =2.2µF Tan Cap IN 0.5 IN O IN 0 OUT 0.2 0.3 0.4 0.5 0.6 Time (ms) 0.7 0.8 0.9 1.265 1.26 1.255 1.25 1.245 1.24 1.235 1.23 1.225 -50 1.25v Adj -30 1.0 -10 10 30 50 70 90 110 130 Temp (C) Figure 5. Current Limit for SPX1117M3-3.3, Output Voltage Deviation with IOUT=10mA to 1A Step Apr 20-07 Rev B 75 Figure 4. Current Limit for SP1117M3-3.3; VIN=4.8V, CIN=COUT=1µF, IOUT pulsed from 10mA to Current Limit 125°C 22µF 0.1 50 Temp ( oC) Figure 3. Dropout Voltage vs Output Current for SPX1117M3-3.3; VIN=4.8V, COUT=2.2µF 0 14.5 2.00 Io (mA) 100 12.5 Figure 2. Line Regulation for SPX1117M3-3.3; IOUT=10mA Current Limit (A) Dropout Voltage (V) Figure 1. Load Regulation for SPX1117M3-3.3; VIN=4.8V 100 10.5 Vin (V) Output Current (mA) Figure 6. VOUT vs Temperature, VIN=2.5V, IOUT=10mA SPX1117 800mA Low Dropout Voltage Regulator 4 © 2007 Sipex Corporation TYPICAL PERFORMANCE CHARACTERISTICS: Continued 1.53 1.84 1.5v Adj 1.5v Fixed 1.52 Vout (V) Vout (V) 1.5 1.49 1.47 -50 1.8 1.79 1.77 -30 -10 10 30 50 Temp (C) 70 90 110 1.76 -50 130 Figure 7. VIN=3.0V, IOUT=10mA 2.55 2.54 2.53 2.52 2.51 2.5 2.49 2.48 2.47 2.46 2.45 -50 -10 10 70 90 110 2.88 2.86 2.84 2.82 -30 -10 10 30 50 Temp (C) 70 90 110 2.8 -50 130 -30 -10 10 30 50 Temp (C) 70 90 110 130 Figure 10. VIN=4.85V, IOUT=10mA 3.38 3v Adj 3v Fixed 3.04 3.3v Adj 3.3v Fixed 3.36 3.02 Vout (V) 3.34 3 2.98 2.96 3.32 3.3 3.28 -30 -10 10 30 50 70 90 110 3.26 -50 130 -30 -10 10 Temp (C) 30 50 70 90 110 130 Temp (C) Figure 12. VIN=5.0V, IOUT=10mA Figure 11. VIN=4.85V, IOUT=10mA 6 4 2 V out, V 0 -2 -4 -6 -8 -40 -20 0 20 40 60 80 100 1.816 1.815 1.814 1.813 1.812 1.811 1.81 1.809 1.808 1.807 1.806 800mA 400mA 10mA -40 Ambient Temperature,*C -20 0 20 40 Ambient Temperature, *C 60 80 0.4 0.3 -40°C 0.2 +25°C 0.1 +85°C 0 -0.1 -0.2 -0.3 3 4 5 6 Vin, V Figure 15. Line Regulation at ILOAD=800mA over Temperature, VOUT=1.8V adjustable Apr 20-07 Rev B 100 Figure 14. Output Voltage vs Temperature at different Current Loads, VIN=3.3V, VOUT = 1.8V Adjustable Figure 13. Line Regulation vs Temperature. VOUT=1.8V (adjustable), VIN= 3.3V Vout tolerance,% 130 2.85v Adj 2.85v Fixed 2.9 3.06 Output Voltage Change, mV 30 50 Temp (C) 2.92 2.5v Adj 2.5v Fixed Figure 9. VIN=4.0V, IOUT=10mA 2.94 -50 -30 Figure 8. VIN=3.3V, IOUT=10mA Vout (V) Vout (V) 1.82 1.81 1.78 1.48 Vout (V) 1.8v Adj 1.8v Fixed 1.83 1.51 SPX1117 800mA Low Dropout Voltage Regulator 5 © 2007 Sipex Corporation APPLICATION INFORMATION Output Capacitor To ensure the stability of the SPX1117, an output capacitor of at least 2.2µF (tantalum or ceramic) or 10µF (aluminum) is required. The value may change based on the application requirements of the output load or temperature range. The value of ESR can vary based on the type of capacitor used in the applications to guarantee stability. The recommended value for ESR is 0.5Ω or less. A larger value of output capacitance (up to 100µF) can improve the load transient response. Soldering Methods The SPX1117 SOT-223 package is designed to be compatible with infrared reflow or vapor-phase reflow soldering techniques. During soldering, the non-active or mildly active fluxes may be used. The SPX1117 die is attached to the heatsink lead which exits opposite the input, output, and ground pins. Hand soldering and wave soldering should be avoided since these methods can cause damage to the device with excessive thermal gradients on the package. The SOT-223 recommended soldering method are as follows: vapor phase reflow and infrared reflow with the component preheated to within 65°C of the soldering temperature range. Figure 16. Load Step Response (0 to 800mA), Vin=3.3V, Vout=1.8V, Cin=10µF, Cout=2.2µF, Ceramic; 1 = Vout, 4= Iload Figure 17. Load Step Response (0 to 800mA), Vin=3.3V, Vout=1.8V, Cin=10µF, Cout=2.2µF, OSCON; 1 = Vout, 4= Iload Apr 20-07 Rev B SPX1117 800mA Low Dropout Voltage Regulator 6 © 2007 Sipex Corporation APPLICATION INFORMATION: Continued Ripple Rejection Ripple rejection can be improved by adding a capacitor between the ADJ pin and ground as shown in Figure 23. When ADJ pin bypassing is used, the value of the output capacitor required increases to its maximum. If the ADJ pin is not bypassed, the value of the output capacitor can be lowered to 10µF for an electrolytic aluminum capacitor or 2.2µF for a ceramic or solid tantalum capacitor (Fig 22). Thermal Characteristics The thermal resistance of SPX1117 (SOT-223 Package) is 15°C/W from junction to tab and 31 °C/W from tab to ambient for a total of 46 °C/W from junction to ambient (Table 1). The SPX1117 features the internal thermal limiting to protect the device during overload conditions. Special care needs to be taken during continuous load conditions such that the maximum junction temperature does not exceed 125 °C. Thermal protection is activated at >155°C and deactiviated at
SPX1117HM3-L-5-0/TR 价格&库存
很抱歉,暂时无法提供与“SPX1117HM3-L-5-0/TR”相匹配的价格&库存,您可以联系我们找货
