RS1MLS RVG
RS1MLS RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD123H
    RS1MLS RVG
RS1MLS RVG 数据手册
RS1JLS – RS1MLS Taiwan Semiconductor 1.2A, 600V - 1000V Fast Recovery Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Compact package size High surge current capability Low power loss, high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1.2 A VRRM 600 - 1000 V IFSM 50 A TJ MAX 150 °C APPLICATIONS Package SOD-123HE Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123HE Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.022g (approximately) SOD-123HE ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device RS1JLS RS1KLS RS1MLS RJLS RKLS RMLS UNIT Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1.2 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2103 RS1JLS – RS1MLS Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 80 °C/W Junction-to-case thermal resistance RӨJC 26 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1.2A, TJ = 25°C (2) Reverse recovery time TJ = 25°C TJ = 125°C IF = 0.5A , IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT VF - 1.3 V - 5 µA - 150 µA - 300 ns IR trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING RS1xLS SOD-123HE 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 600V(RS1JLS) to 1000V(RS1MLS) 2 Version: D2103 RS1JLS – RS1MLS Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 1.4 14 1.2 12 1.0 10 CAPACITANCE (pF) 0.8 0.6 0.4 8 6 4 2 0.2 f=1.0MHz Vsig=50mVp-p 0 0.0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C 0.01 0.1 0.001 0.6 0.7 0.8 0.9 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.0 1.1 1.2 1.3 1.4 0.6 0.7 0.8 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2103 1.2 RS1JLS – RS1MLS Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: D2103 RS1JLS – RS1MLS Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123HE SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code YW = Date Code F = Factory Code Version: D2103 RS1JLS – RS1MLS Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: D2103
RS1MLS RVG 价格&库存
很抱歉,暂时无法提供与“RS1MLS RVG”相匹配的价格&库存,您可以联系我们找货
