ESH2B – ESH2D
Taiwan Semiconductor
2A, 100V - 200V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Ultra Fast recovery time for high efficiency
Moisture sensitivity level: level 1 per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
100 - 200
V
IFSM
60
A
TJ MAX
175
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ESH2B
ESH2C
ESH2D
ESH2B
ESH2C
ESH2D
UNIT
Repetitive peak reverse voltage
VRRM
100
150
200
V
Reverse voltage, total rms value
VR(RMS)
70
105
140
V
Forward current
Surge peak forward current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
2
A
IFSM
60
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: J2102
ESH2B – ESH2D
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 2A,TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
VF
0.9
V
2
µA
50
µA
CJ
25
pF
trr
ns
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ESH2x
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 100V(ESH2B) to 200V(ESH2D)
2
Version: J2102
ESH2B – ESH2D
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
60
50
CAPACITANCE (pF)
2
1
40
30
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
LEAD TEMPERATURE
150
175
0.1
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
TJ=125°C
1
TJ=25°C
0.1
30
40
50
60
70
100
Fig.4 Typical Forward Characteristics
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
1
(oC)
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100
10
1
10
UF1DLW
TJ=125°C
TJ=25°C
0.1
(A)
AVERAGE FORWARD CURRENT (A)
3
1
0.01
0.001
0.1 0.3
0.4
0.4
0.6
0.5
0.8
0.6
0.7
1
Pulse width
Pulse width=300μs
1% duty cycle
0.8
0.9
1
1.1
1.2
1.4
1.6
FORWARD VOLTAGE (V)
3
Version: J2102
1.8
1.2
ESH2B – ESH2D
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
70
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2102
ESH2B – ESH2D
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: J2102
ESH2B – ESH2D
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2102
很抱歉,暂时无法提供与“ESH2D R5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.11268
- 25+2.11090
- 50+2.10824
- 100+2.10558
- 国内价格 香港价格
- 1+5.928521+0.70876
- 10+3.9495810+0.47218
- 100+2.70210100+0.32304
