RS1DFS - RS1MFS
Taiwan Semiconductor
1A, 200V - 1000V Surface Mount Fast Recovery Rectifier
FEATURES
KEY PARAMETERS
Glass passivated junction chip
Ideal for automated placement
Low profile package
Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
Halogen-free according to IEC 61249-2-21
APPLICATIONS
High frequency rectification
PARAMETER
VALUE
UNIT
IF(AV)
1
A
VRRM
200 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
SOD-128
Configuration
Single die
Freewheeling application
Switching mode converters and inverters in
computer,automotive and telecommunication
MECHANICAL DATA
Case: SOD-128
Molding compound meets UL 94V-0 flammability rating
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound
(halogen-free)
SOD-128
Moisture sensitivity level: level 1, per J-STD-020
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.027 g (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
RS1DFS RS1GFS RS1JFS RS1KFS RS1MFS UNIT
RS1DFS
RS1GFS
RS1JFS
RS1KFS RS1MFS
Repetitive peak reverse voltage
VRRM
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
560
700
V
Forward current
Surge peak forward current, 8.3 ms
single half sine-wave superimposed
on rated load per diode
Junction temperature
IF(AV)
1
A
IFSM
30
A
TJ
- 55 to +150
°C
Storage temperature
T STG
- 55 to +150
°C
1
Version:A1708
RS1DFS - RS1MFS
THERMAL PERFORMANCE
PARAMETER
SYMBOL
LIMIT
UNIT
Junction-to-lead thermal resistance per diode
R
JL
29
°C/W
Junction-to-ambient thermal resistance per diode
R
JA
84
°C/W
Junction-to-case thermal resistance per diode
R
JC
30
°C/W
Thermal Performance Note: Units mounted on recommended PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 0.5A, TJ = 25°C
Forward voltage per diode
IF = 1.0A, TJ = 25°C
(1)
IF = 0.5A, TJ = 125°C
VF
IF = 1.0A, TJ = 125°C
Reverse current @ rated VR per diode
TJ = 25°C
(2)
IR
TJ = 125°C
Junction capacitance
1 MHz, VR=4.0V
RS1DFS
RS1GFS
Reverse recovery time
IF=0.5A ,IR=1.0A
RS1JFS
IRR=0.25A
RS1KFS
CJ
trr
RS1MFS
TYP
MAX
UNIT
0.94
1.10
1.01
1.30
0.79
1.00
0.88
1.20
5
µA
50
µA
7
pF
150
ns
250
ns
500
ns
V
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PART NO.
SUFFIX(*)
RS1xFS
(Note 1, 2)
H
PACKING
PACKING CODE
CODE
SUFFIX
MW
G
MX
Notes:
1. "xx" defines voltage from 200V (RS1DFS) to 1000V (RS1MFS)
2. Whole series with green compound (halogen-free)
*: Optional available
PACKAGE
PACKING
SOD-128
3,500 / 7" Plastic reel
SOD-128
14,000 / 13" Plastic reel
EXAMPLE P/N
EXAMPLE P/N
PART NO.
PART NO.
SUFFIX
PACKING
CODE
PACKING CODE
SUFFIX
DESCRIPTION
RS1DFSHMWG
RS1DFS
H
MW
G
AEC-Q101 qualified
Green compound
2
Version:A1708
RS1DFS - RS1MFS
CHARACTERISTICS CURVES
(T A = 25°C unless otherwise noted)
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1.5
100
1
10
0.5
1
Heat sink
5mm x 5mm
Cu pad test board
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
1
10
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE ( C)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
10
10
TJ=125 C
1
TJ=125 C
1
0.1
TJ=25 C
TJ=25 C
0.01
0.001
1% duty cycle
0.1
10
40
50
60
70
80
90
100
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.7
0.8
0.9
1
1.1
1.2
1.3
1.4
1.5
1.6
FORWARD VOLTAGE (V)
3
Version:A1708
RS1DFS - RS1MFS
PACKAGE OUTLINE DIMENSIONS
SOD-128
DIM
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
3.60
4.00
0.142
0.157
B
2.30
2.70
0.091
0.106
C
1.60
1.90
0.063
0.075
D
0.90
1.10
0.035
0.043
E
0.10
0.22
0.004
0.009
F
0.00
0.10
0.000
0.004
G
0.30
0.60
0.012
0.024
H
0.40
0.80
0.016
0.031
I
4.40
5.00
0.173
0.197
SUGGESTED PAD LAYOUT
DIM
Unit (mm)
Unit (inch)
A
1.40
0.055
B
3.00
0.118
C
2.10
0.082
D
4.40
0.173
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version:A1708
RS1DFS - RS1MFS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version:A1708
很抱歉,暂时无法提供与“RS1DFS MWG”相匹配的价格&库存,您可以联系我们找货
