ICL3224E, ICL3226E, ICL3244E
Data Sheet
February 27, 2006
+/-15kV ESD Protected, +3V to +5.5V,
1Microamp, 250kbps, RS-232
Transceivers with Enhanced Automatic
Powerdown
The Intersil ICL32XXE devices are 3.0V to 5.5V powered
RS-232 transmitters/receivers which meet ElA/TIA-232 and
V.28/V.24 specifications, even at VCC = 3.0V. Additionally,
they provide ±15kV ESD protection (IEC61000-4-2 Air Gap
and Human Body Model) on transmitter outputs and receiver
inputs (RS-232 pins). Targeted applications are PDAs,
Palmtops, and notebook and laptop computers where the
low operational, and even lower standby, power consumption
is critical. Efficient on-chip charge pumps, coupled with
manual and enhanced automatic powerdown functions,
reduce the standby supply current to a 1µA trickle. Small
footprint packaging, and the use of small, low value
capacitors ensure board space savings as well. Data rates
greater than 250kbps are guaranteed at worst case load
conditions. This family is fully compatible with 3.3V only
systems, mixed 3.3V and 5.0V systems, and 5.0V only
systems.
The ICL3244E is a 3 driver, 5 receiver device that provides a
complete serial port suitable for laptop or notebook
computers. It also includes a noninverting always-active
receiver for “wake-up” capability.
These devices, feature an enhanced automatic
powerdown function which powers down the on-chip powersupply and driver circuits. This occurs when all receiver and
transmitter inputs detect no signal transitions for a period of
30 seconds. These devices power back up, automatically,
whenever they sense a transition on any transmitter or
receiver input.
Table 1 summarizes the features of the devices represented
by this data sheet, while Application Note AN9863
summarizes the features of each device comprising the
ICL32XXE 3V family.
FN4899.6
Features
• Pb-Free Plus Anneal Available (RoHS Compliant)
• ESD Protection for RS-232 I/O Pins to ±15kV (IEC61000)
• Manual and Enhanced Automatic Powerdown Features
• Drop in Replacements for MAX3224E, MAX3226E,
MAX3244E
• Meets EIA/TIA-232 and V.28/V.24 Specifications at 3V
• RS-232 Compatible with VCC = 2.7V
• Latch-Up Free
• On-Chip Voltage Converters Require Only Four External
0.1µF Capacitors
• Guaranteed Mouse Driveability (ICL3244E)
• “Ready to Transmit” Indicator Output (ICL3224E/26E)
• Receiver Hysteresis For Improved Noise Immunity
• Guaranteed Minimum Data Rate . . . . . . . . . . . . . 250kbps
• Guaranteed Minimum Slew Rate . . . . . . . . . . . . . . . 6V/µs
• Wide Power Supply Range. . . . . . . . Single +3V to +5.5V
• Low Supply Current in Powerdown State . . . . . . . . . . .1µA
Applications
• Any System Requiring RS-232 Communication Ports
- Battery Powered, Hand-Held, and Portable Equipment
- Laptop Computers, Notebooks, Palmtops
- Modems, Printers and other Peripherals
- Digital Cameras
- Cellular/Mobile Phones
Related Literature
• Technical Brief TB363 “Guidelines for Handling and
Processing Moisture Sensitive Surface Mount Devices
(SMDs)”
TABLE 1. SUMMARY OF FEATURES
PART
NUMBER
NO. OF NO. OF
Tx.
Rx.
NO. OF
MONITOR Rx.
(ROUTB)
DATA
RATE
(kbps)
Rx. ENABLE
FUNCTION?
READY
OUTPUT?
MANUAL
POWERDOWN?
ENHANCED
AUTOMATIC
POWERDOWN
FUNCTION?
ICL3224E
2
2
No
Yes
Yes
Yes
ICL3226E
1
1
No
Yes
Yes
Yes
ICL3244E
3
5
1
250
No
No
Yes
Yes
1
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright Intersil Americas Inc. 2000, 2001, 2003-2006. All Rights Reserved.
All other trademarks mentioned are the property of their respective owners.
Ordering Information
PART NO.
PART MARKING
TEMP. RANGE (°C)
PACKAGE
PKG. DWG. #
ICL3224ECAZ (Note)
3224ECAZ
0 to 70
20 Ld SSOP (Pb-free)
M20.209
ICL3224ECAZ-T (Note)
3224ECAZ
0 to 70
20 Ld SSOP Tape and Reel (Pb-free)
M20.209
ICL3224EIA
ICL3224EIA
-40 to 85
20 Ld SSOP
M20.209
ICL3224EIA-T
ICL3224EIA
-40 to 85
M20.209
ICL3224EIAZ (Note)
3224EIAZ
-40 to 85
M20.209
ICL3224EIAZ-T (Note)
3224EIAZ
-40 to 85
M20.209
ICL3226ECA
ICL3226ECA
0 to 70
16 Ld SSOP
M16.209
ICL3226ECA-T
ICL3226ECA
0 to 70
16 Ld SSOP Tape and Reel
M16.209
ICL3226ECAZ (Note)
3226ECAZ
0 to 70
16 Ld SSOP (Pb-free)
M16.209
ICL3226ECAZ-T
3226ECAZ
0 to 70
16 Ld SSOP Tape and Reel (Pb-free)
M16.209
ICL3226EIA
ICL3226EIA
-40 to 85
16 Ld SSOP
M16.209
ICL3226EIA-T
ICL3226EIA
-40 to 85
M16.209
ICL3226EIAZ
3226EIAZ
-40 to 85
M16.209
ICL3226EIAZ-T
3226EIAZ
-40 to 85
M16.209
ICL3244ECA
ICL3244ECA
0 to 70
28 Ld SSOP
M28.209
ICL3244ECA-T
ICL3244ECA
0 to 70
28 Ld SSOP Tape and Reel
M28.209
ICL3244ECAZ (Note)
ICL3244ECAZ
0 to 70
28 Ld SSOP (Pb-free)
M28.209
ICL3244ECAZ-T (Note)
ICL3244ECAZ
0 to 70
28 Ld SSOP Tape and Reel (Pb-free)
M28.209
ICL3244EIA
ICL3244EIA
-40 to 85
28 Ld SSOP
M28.209
ICL3244EIA-T
ICL3244EIA
-40 to 85
M28.209
ICL3244EIAZ (Note)
ICL3244EIAZ
-40 to 85
M28.209
ICL3244EIAZ-T (Note)
ICL3244EIAZ
-40 to 85
M28.209
ICL3244EIB
ICL3244EIB
-40 to 85
28 Ld SOIC
M28.3
NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin
plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are
MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020.
Pinouts
ICL3224E (SSOP)
TOP VIEW
READY
20 FORCEOFF
1
C1+ 2
19 VCC
3
ICL3226E (SSOP)
TOP VIEW
READY
1
16 FORCEOFF
C1+ 2
15 VCC
3
14 GND
18 GND
V+
C1- 4
17 T1OUT
C1- 4
13 T1OUT
C2+ 5
16 R1IN
C2+ 5
12 FORCEON
C2- 6
15 R1OUT
C2- 6
11 T1IN
V+
V-
14 FORCEON
7
T2OUT 8
13 T1IN
R2IN 9
12 T2IN
11 INVALID
R2OUT 10
2
V-
7
R1IN 8
10 INVALID
9 R1OUT
Pinouts
(Continued)
ICL3244E (SOIC, SSOP)
TOP VIEW
C2+ 1
28 C1+
C2- 2
27 V+
3
26 VCC
R1IN 4
25 GND
R2IN 5
24 C1-
R3IN 6
23 FORCEON
R4IN 7
22 FORCEOFF
V-
R5IN 8
21 INVALID
T1OUT 9
20 R2OUTB
T2OUT 10
19 R1OUT
T3OUT 11
18 R2OUT
T3IN 12
17 R3OUT
T2IN 13
16 R4OUT
T1IN 14
15 R5OUT
Pin Descriptions
PIN
VCC
FUNCTION
System power supply input (3.0V to 5.5V).
V+
Internally generated positive transmitter supply (+5.5V).
V-
Internally generated negative transmitter supply (-5.5V).
GND
Ground connection.
C1+
External capacitor (voltage doubler) is connected to this lead.
C1-
C2+
External capacitor (voltage inverter) is connected to this lead.
C2-
TIN
TTL/CMOS compatible transmitter Inputs.
TOUT
RIN
ROUT
±15kV ESD Protected, RS-232 level (nominally ±5.5V) transmitter outputs.
±15kV ESD Protected, RS-232 compatible receiver inputs.
TTL/CMOS level receiver outputs.
ROUTB
TTL/CMOS level, noninverting, always enabled receiver outputs.
INVALID
Active low output that indicates if no valid RS-232 levels are present on any receiver input.
READY
Active high output that indicates when the ICL32XXE is ready to transmit (i.e., V- ≤ -4V)
FORCEOFF Active low to shut down transmitters and on-chip power supply. This overrides any automatic circuitry and FORCEON (see Table 2).
FORCEON
Active high input to override automatic powerdown circuitry thereby keeping transmitters active. (FORCEOFF must be high).
3
Typical Operating Circuits
ICL3224E
+3.3V
C1
0.1µF
C2
0.1µF
T1IN
T2IN
TTL/CMOS
LOGIC LEVELS
R1OUT
R2OUT
0.1µF
2
4
5
6
19
C1+
VCC
V+
C1C2+
V- 7
C2T1
13
17
T2
12
8
15
16
R1
5kΩ
R2
5kΩ
10
9
1
READY
14
3
FORCEOFF
INVALID
FORCEON
+ C3
0.1µF
C4
0.1µF
T1OUT
T2OUT
R1IN
RS-232
LEVELS
R2IN
VCC
TO POWER
CONTROL LOGIC
GND
18
ICL3226E
+3.3V
15
0.1µF
C1
0.1µF
C2
0.1µF
TTL/CMOS
LOGIC LEVELS
T1IN
R1OUT
2
4
C1+
3
VCC
V+
C15
C2+
6
C2-
V- 7
13
9
1
8
READY
16
FORCEON
GND
INVALID
14
4
T1OUT
R1IN
RS-232
LEVELS
5kΩ
R1
FORCEOFF
12
C4
+ 0.1µF
T1
11
+ C3
0.1µF
10
VCC
TO POWER
CONTROL LOGIC
(Continued)
ICL3244E
+3.3V
C1
0.1µF
C2
0.1µF
0.1µF
28
C1+
26
VCC
24
C11
C2+
2
C2-
27
VT1
14
V+
3
C4
0.1µF
9
T1IN
T2IN
C3
0.1µF
T1OUT
13
T2
12
T3
10
T2OUT
RS-232
LEVELS
11
T3IN
T3OUT
R2OUTB
TTL/CMOS
LOGIC LEVELS
19
4
R1OUT
R1IN
R1
R2OUT
5kΩ
18
5
R2
17
6
R3OUT
R3IN
R3
5kΩ
16
7
R4OUT
R4IN
R4
5kΩ
R5
FORCEON
5kΩ
15
R5OUT
23
VCC
TO POWER
CONTROL LOGIC
8
22
FORCEOFF
21
INVALID GND
25
5
R2IN
5kΩ
R5IN
RS-232
LEVELS
m
Absolute Maximum Ratings
Thermal Information
VCC to Ground. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 6V
V+ to Ground . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 7V
V- to Ground. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +0.3V to -7V
V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14V
Input Voltages
TIN, FORCEOFF, FORCEON. . . . . . . . . . . . . . . . . . . -0.3V to 6V
RIN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±25V
Output Voltages
TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±13.2V
ROUT, INVALID, READY. . . . . . . . . . . . . . . . . -0.3V to VCC +0.3V
Short Circuit Duration
TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous
ESD Rating . . . . . . . . . . . . . . . . . . . . . . . . . See Specification Table
Thermal Resistance (Typical, Note 1)
θJA (°C/W)
28 Ld SOIC Package . . . . . . . . . . . . . . . . . . . . . . . .
75
16 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . .
140
20 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . .
125
28 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . .
100
Maximum Junction Temperature (Plastic Package) . . . . . . . 150°C
Maximum Storage Temperature Range . . . . . . . . . . . -65°C to 150°C
Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . 300°C
(Lead Tips Only)
Operating Conditions
Temperature Range
ICL32XXEC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C
ICL32XXEI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to 85°C
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the
device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTE:
1. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details.
Test Conditions: VCC = 3V to 5.5V, C1 - C4 = 0.1µF; Unless Otherwise Specified.
Typicals are at TA = 25°C
Electrical Specifications
PARAMETER
TEST CONDITIONS
TEMP
(°C)
MIN
TYP
MAX
UNITS
DC CHARACTERISTICS
Supply Current, Automatic
Powerdown
All RIN Open, FORCEON = GND, FORCEOFF = VCC
25
1.0
10
µA
Supply Current, Powerdown
FORCEOFF = GND
25
1.0
10
µA
Supply Current,
Automatic Powerdown Disabled
All Outputs Unloaded, FORCEON = FORCEOFF = VCC
25
0.3
1.0
mA
Full
0.8
V
VCC = 3.3V
Full
2.0
V
VCC = 5.0V
Full
2.4
V
25
0.5
V
LOGIC AND TRANSMITTER INPUTS AND RECEIVER OUTPUTS
Input Logic Threshold Low
TIN, FORCEON, FORCEOFF
Input Logic Threshold High
Transmitter Input Hysteresis
Input Leakage Current
Full
±0.01
±1.0
µA
Output Leakage Current
FORCEOFF = GND, ICL3244E Only
Full
±0.05
±10
µA
Output Voltage Low
IOUT = 1.6mA
Full
0.4
V
Output Voltage High
IOUT = -1.0mA
Full
V
VCC -0.6 VCC -0.1
RECEIVER INPUTS
Input Voltage Range
Input Threshold Low
6
Full
-25
25
V
VCC = 3.3V
25
0.6
1.2
V
VCC = 5.0V
25
0.8
1.5
V
Typicals are at TA = 25°C (Continued)
TEMP
(°C)
MIN
TYP
MAX
UNITS
VCC = 3.3V
25
1.5
2.4
V
VCC = 5.0V
25
1.8
2.4
V
Input Hysteresis
25
0.5
V
Input Resistance
25
3
5
7
kΩ
PARAMETER
TEST CONDITIONS
Input Threshold High
TRANSMITTER OUTPUTS
Output Voltage Swing
All Transmitter Outputs Loaded with 3kΩ to Ground
Full
±5.0
±5.4
V
Output Resistance
VCC = V+ = V- = 0V, Transmitter Output = ±2V
Full
300
10M
Ω
Full
±35
±60
mA
Full
±25
µA
Full
±5
V
Output Short-Circuit Current
VOUT = ±12V, VCC = 0V or 3V to 5.5V
Automatic Powerdown or FORCEOFF = GND
MOUSE DRIVEABILITY (ICL3244E Only)
T1IN = T2IN = GND, T3IN = VCC, T3OUT Loaded with 3kΩ
to GND, T1OUT and T2OUT Loaded with 2.5mA Each
Transmitter Output Voltage
(See Figure 11)
ENHANCED AUTOMATIC POWERDOWN (FORCEON = GND, FORCEOFF = VCC)
Receiver Input Thresholds to
INVALID High
See Figure 6
Full
-2.7
2.7
V
INVALID Low
See Figure 6
Full
-0.3
0.3
V
INVALID, READY Output Voltage IOUT = 1.6mA
Low
Full
0.4
V
INVALID, READY Output Voltage IOUT = -1.0mA
High
Full
VCC-0.6
V
Receiver Positive or Negative
Threshold to INVALID High Delay
(tINVH)
25
1
µs
Threshold to INVALID Low Delay
(tINVL)
25
30
µs
Receiver or Transmitter Edge to
Note 2
Transmitters Enabled Delay (tWU)
25
100
µs
Note 2
Full
15
30
60
sec
Maximum Data Rate
RL = 3kΩ, CL = 1000pF, One Transmitter Switching
Full
250
500
kbps
Receiver Propagation Delay
Receiver Input to Receiver
Output, CL = 150pF
tPHL
25
0.15
µs
tPLH
25
0.15
µs
Transmitters Disabled Delay
(tAUTOPWDN)
TIMING CHARACTERISTICS
Receiver Output Enable Time
Normal Operation (ICL3244E Only)
25
200
ns
Receiver Output Disable Time
25
200
ns
Transmitter Skew
tPHL - tPLH
25
100
ns
7
TEMP
(°C)
MIN
TYP
MAX
UNITS
25
50
ns
CL = 150pF to 1000pF
25
6
30
V/µs
CL = 150pF to 2500pF
25
4
8
30
V/µs
Human Body Model
25
±15
kV
IEC61000-4-2 Contact Discharge
25
±8
kV
IEC61000-4-2 Air Gap Discharge
25
±15
kV
Human Body Model
25
±3
kV
PARAMETER
TEST CONDITIONS
Receiver Skew
tPHL - tPLH
Transition Region Slew Rate
VCC = 3.3V,
RL = 3kΩ to 7kΩ,
Measured From 3V to -3V or -3V
to 3V
ESD PERFORMANCE
RS-232 Pins (TOUT, RIN)
All Other Pins
NOTE:
2. An “edge” is defined as a transition through the transmitter or receiver input thresholds.
Detailed Description
These ICL32XXE interface ICs operate from a single +3V to
+5.5V supply, guarantee a 250kbps minimum data rate,
require only four small external 0.1µF capacitors, feature low
power consumption, and meet all ElA RS-232C and V.28
specifications. The circuit is divided into three sections: The
charge pump, the transmitters, and the receivers.
Charge-Pump
Intersil’s new ICL32XXE family utilizes regulated on-chip
dual charge pumps as voltage doublers, and voltage
inverters to generate ±5.5V transmitter supplies from a VCC
supply as low as 3.0V. This allows these devices to maintain
RS-232 compliant output levels over the ±10% tolerance
range of 3.3V powered systems. The efficient on-chip power
supplies require only four small, external 0.1µF capacitors
for the voltage doubler and inverter functions at VCC = 3.3V.
See the “Capacitor Selection” section, and Table 3 for
capacitor recommendations for other operating conditions.
The charge pumps operate discontinuously (i.e., they turn off
as soon as the V+ and V- supplies are pumped up to the
nominal values), resulting in significant power savings.
Transmitters
All devices guarantee a 250kbps data rate for full load
conditions (3kΩ and 1000pF), VCC ≥ 3.0V, with one
transmitter operating at full speed. Under more typical
conditions of VCC ≥ 3.3V, RL = 3kΩ, and CL = 250pF, one
transmitter easily operates at 1Mbps.
Transmitter inputs float if left unconnected, and may cause
ICC increases. Connect unused inputs to GND for the best
performance.
Receivers
All the ICL32XXE devices contain standard inverting
receivers, but only the ICL3244E receivers can three-state,
via the FORCEOFF control line. Additionally, the ICL3244E
includes a noninverting (monitor) receiver (denoted by the
ROUTB label) that is always active, regardless of the state of
any control lines. Both receiver types convert RS-232 signals
to CMOS output levels and accept inputs up to ±25V while
presenting the required 3kΩ to 7kΩ input impedance (see
Figure 1) even if the power is off (VCC = 0V). The receivers’
Schmitt trigger input stage uses hysteresis to increase noise
immunity and decrease errors due to slow input signal
transitions.
VCC
The transmitters are proprietary, low dropout, inverting
drivers that translate TTL/CMOS inputs to EIA/TIA-232
output levels. Coupled with the on-chip ±5.5V supplies, these
transmitters deliver true RS-232 levels over a wide range of
single supply system voltages.
Transmitter outputs disable and assume a high impedance
state when the device enters the powerdown mode (see
Table 2). These outputs may be driven to ±12V when
disabled.
8
RXOUT
RXIN
-25V ≤ VRIN ≤ +25V
5kΩ
GND ≤ VROUT ≤ VCC
GND
FIGURE 1. INVERTING RECEIVER CONNECTIONS
The ICL3244E inverting receivers disable during forced
(manual) powerdown, but not during automatic powerdown
(see Table 2). Conversely, the monitor receiver remains
active even during manual powerdown making it extremely
useful for Ring Indicator monitoring. Standard receivers
driving powered down peripherals must be disabled to
prevent current flow through the peripheral’s protection
diodes (see Figures 2 and 3). This renders them useless for
wake up functions, but the corresponding monitor receiver
can be dedicated to this task as shown in Figure 3.
TABLE 2. POWERDOWN LOGIC TRUTH TABLE
RCVR OR
XMTR
EDGE
WITHIN 30
SEC?
(NOTE 3)
FORCEOFF FORCEON TRANSMITTER RECEIVER
ROUTB
INPUT
INPUT
OUTPUTS
OUTPUTS OUTPUTS
RS-232
LEVEL
PRESENT
AT
RECEIVER
INPUT?
INVALID
OUTPUT
MODE OF OPERATION
ICL3224E, ICL3226E
NO
H
H
Active
Active
N.A.
NO
L
NO
H
H
Active
Active
N.A.
YES
H
YES
H
L
Active
Active
N.A.
NO
L
YES
H
L
Active
Active
N.A.
YES
H
NO
H
L
High-Z
Active
N.A.
NO
L
NO
H
L
High-Z
Active
N.A.
YES
H
X
L
X
High-Z
Active
N.A.
NO
L
X
L
X
High-Z
Active
N.A.
YES
H
Normal Operation (Enhanced
Auto Powerdown Disabled)
Auto Powerdown Enabled)
Powerdown Due to Enhanced
Auto Powerdown Logic
Manual Powerdown
ICL322XE - INVALID DRIVING FORCEON AND FORCEOFF (EMULATES AUTOMATIC POWERDOWN)
X
NOTE 4
NOTE 4
Active
Active
N.A.
YES
H
Normal Operation
X
NOTE 4
NOTE 4
High-Z
Active
N.A.
NO
L
Forced Auto Powerdown
NO
H
H
Active
Active
Active
NO
L
NO
H
H
Active
Active
Active
YES
H
YES
H
L
Active
Active
Active
NO
L
YES
H
L
Active
Active
Active
YES
H
NO
H
L
High-Z
Active
Active
NO
L
NO
H
L
High-Z
Active
Active
YES
H
X
L
X
High-Z
High-Z
Active
NO
L
X
L
X
High-Z
High-Z
Active
YES
H
ICL3244E
Manual Powerdown
ICL3244E - INVALID DRIVING FORCEON AND FORCEOFF (EMULATES AUTOMATIC POWERDOWN)
X
NOTE 4
NOTE 4
Active
Active
Active
YES
H
Normal Operation
X
NOTE 4
NOTE 4
High-Z
High-Z
Active
NO
L
NOTES:
3. Applies only to the ICL3244E.
4. Input is connected to INVALID Output.
9
VCC
active and powerdown modes, under logic or software
control, only the FORCEOFF input need be driven. The
FORCEON state isn’t critical, as FORCEOFF dominates
over FORCEON. Nevertheless, if strictly manual control over
powerdown is desired, the user must strap FORCEON high
to disable the enhanced automatic powerdown circuitry.
ICL3244E inverting (standard) receiver outputs also disable
when the device is in powerdown, thereby eliminating the
possible current path through a shutdown peripheral’s input
protection diode (see Figures 2 and 3).
VCC
CURRENT
FLOW
VCC
VOUT = VCC
Rx
POWERED
DOWN
UART
Tx
SHDN = GND
GND
Connecting FORCEOFF and FORCEON together disables
the enhanced automatic powerdown feature, enabling them
to function as a manual SHUTDOWN input (see Figure 4).
OLD
RS-232 CHIP
FORCEOFF
FIGURE 2. POWER DRAIN THROUGH POWERED DOWN
PERIPHERAL
PWR
MGT
LOGIC
FORCEON
VCC
INVALID
ICL32XXE
TRANSITION
DETECTOR
TO
WAKE-UP
LOGIC
VCC
ICL3244E
I/O
UART
R2OUTB
RX
VOUT = HI-Z
R2OUT
POWERED
DOWN
TX
UART
CPU
R2IN
T1IN
T1OUT
FORCEOFF = GND
FIGURE 3. DISABLED RECEIVERS PREVENT POWER DRAIN
Powerdown Functionality
This 3V family of RS-232 interface devices requires a
nominal supply current of 0.3mA during normal operation
(not in powerdown mode). This is considerably less than the
5mA to 11mA current required of 5V RS-232 devices. The
already low current requirement drops significantly when the
device enters powerdown mode. In powerdown, supply
current drops to 1µA, because the on-chip charge pump
turns off (V+ collapses to VCC, V- collapses to GND), and
the transmitter outputs three-state. Inverting receiver outputs
may or may not disable in powerdown; refer to Table 2 for
details. This micro-power mode makes these devices ideal
for battery powered and portable applications.
Software Controlled (Manual) Powerdown
These devices allow the user to force the IC into the low
power, standby state, and utilize a two pin approach where
the FORCEON and FORCEOFF inputs determine the IC’s
mode. For always enabled operation, FORCEON and
FORCEOFF are both strapped high. To switch between
10
FIGURE 4. CONNECTIONS FOR MANUAL POWERDOWN
WHEN NO VALID RECEIVER SIGNALS ARE
PRESENT
With any of the above control schemes, the time required to
exit powerdown, and resume transmission is only 100µs.
When using both manual and enhanced automatic
powerdown (FORCEON = 0), the ICL32XXE won’t power up
from manual powerdown until both FORCEOFF and
FORCEON are driven high, or until a transition occurs on a
receiver or transmitter input. Figure 5 illustrates a circuit for
ensuring that the ICL32XXE powers up as soon as
FORCEOFF switches high. The rising edge of the Master
Powerdown signal forces the device to power up, and the
ICL32XXE returns to enhanced automatic powerdown mode
an RC time constant after this rising edge. The time constant
isn’t critical, because the ICL32XXE remains powered up for
30 seconds after the FORCEON falling edge, even if there
are no signal transitions. This gives slow-to-wake systems
(e.g., a mouse) plenty of time to start transmitting, and as
long as it starts transmitting within 30 seconds both systems
remain enabled.
POWER
MANAGEMENT
UNIT
MASTER POWERDOWN LINE
0.1µF
FORCEOFF
1MΩ
FORCEON
ICL32XXE
FIGURE 5. CIRCUIT TO ENSURE IMMEDIATE POWER UP
WHEN EXITING FORCED POWERDOWN
INVALID Output
The INVALID output always indicates (see Table 2) whether
or not 30µs have elapsed with invalid RS-232 signals (see
Figures 6 and 8) persisting on all of the receiver inputs,
giving the user an easy way to determine when the interface
block should power down. Invalid receiver levels occur
whenever the driving peripheral’s outputs are shut off
(powered down) or when the RS-232 interface cable is
disconnected. In the case of a disconnected interface cable
where all the receiver inputs are floating (but pulled to GND
by the internal receiver pull down resistors), the INVALID
logic detects the invalid levels and drives the output low. The
power management logic then uses this indicator to power
down the interface block. Reconnecting the cable restores
valid levels at the receiver inputs, INVALID switches high,
and the power management logic wakes up the interface
block. INVALID can also be used to indicate the DTR or
RING INDICATOR signal, as long as the other receiver
inputs are floating, or driven to GND (as in the case of a
powered down driver).
VALID RS-232 LEVEL - INVALID = 1
2.7V
INDETERMINATE
0.3V
INVALID LEVEL - INVALID = 0
whenever it detects a transition on one of these inputs. This
automatic powerdown feature provides additional system
power savings without changes to the existing operating
system.
Enhanced automatic powerdown operates when the
FORCEON input is low, and the FORCEOFF input is high.
Tying FORCEON high disables automatic powerdown, but
manual powerdown is always available via the overriding
FORCEOFF input. Table 2 summarizes the enhanced
automatic powerdown functionality.
Figure 7 illustrates the enhanced powerdown control logic.
Note that once the ICL32XXE enters powerdown (manually
or automatically), the 30 second timer remains timed out
(set), keeping the ICL32XXE powered down until FORCEON
transitions high, or until a transition occurs on a receiver or
transmitter input.
FORCEOFF
T_IN
EDGE
DETECT
S
30s
TIMER
R_IN
AUTOSHDN
R
EDGE
DETECT
FORCEON
FIGURE 7. ENHANCED AUTOMATIC POWERDOWN LOGIC
The INVALID output signal switches low to indicate that
invalid levels have persisted on all of the receiver inputs for
more than 30µs (see Figure 8), but this has no direct effect
on the state of the ICL32XXE (see the next sections for
methods of utilizing INVALID to power down the device).
INVALID switches high 1µs after detecting a valid RS-232
level on a receiver input. INVALID operates in all modes
(forced or automatic powerdown, or forced on), so it is also
useful for systems employing manual powerdown circuitry.
-0.3V
INDETERMINATE
The time to recover from automatic powerdown mode is
typically 100µs.
Emulating Standard Automatic Powerdown
-2.7V
FIGURE 6. DEFINITION OF VALID RS-232 RECEIVER LEVELS
Even greater power savings is available by using these
devices which feature an enhanced automatic powerdown
function. When the enhanced powerdown logic determines
that no transitions have occurred on any of the transmitter
nor receiver inputs for 30 seconds, the charge pump and
transmitters powerdown, thereby reducing supply current to
1µA. The ICL32XXE automatically powers back up
11
If enhanced automatic powerdown isn’t desired, the user can
implement the standard automatic powerdown feature
(mimics the function on the ICL3221E/23E/43E) by
connecting the INVALID output to the FORCEON and
FORCEOFF inputs, as shown in Figure 9. After 30µs of
invalid receiver levels, INVALID switches low and drives the
ICL32XXE into a forced powerdown condition. INVALID
switches high as soon as a receiver input senses a valid
RS-232 level, forcing the ICL32XXE to power on. See the
“INVALID DRIVING FORCEON AND FORCEOFF” section
of Table 2 for an operational summary. This operational
mode is perfect for handheld devices that communicate with
RECEIVER
INPUTS
} INVALID
REGION
TRANSMITTER
INPUTS
TRANSMITTER
OUTPUTS
tINVH
INVALID
OUTPUT
tINVL
tAUTOPWDN
tAUTOPWDN
tWU
tWU
READY
OUTPUT
V+
VCC
V-
FORCEOFF
INVALID
another computer via a detachable cable. Detaching the
cable allows the internal receiver pull-down resistors to pull
the inputs to GND (an invalid RS-232 level), causing the
30µs timer to time-out and drive the IC into powerdown.
Reconnecting the cable restores valid levels, causing the IC
to power back up.
FORCEON
FIGURE 8. ENHANCED AUTOMATIC POWERDOWN, INVALID AND READY TIMING DIAGRAMS
ICL32XXE
Hybrid Automatic Powerdown Options
For devices which communicate only through a detachable
cable, connecting INVALID to FORCEOFF (with
FORCEON = 0) may be a desirable configuration. While the
cable is attached INVALID and FORCEOFF remain high, so
the enhanced automatic powerdown logic powers down the
RS-232 device whenever there is 30 seconds of inactivity on
the receiver and transmitter inputs. Detaching the cable
allows the receiver inputs to drop to an invalid level (GND),
so INVALID switches low and forces the RS-232 device to
power down. The ICL32XXE remains powered down until
the cable is reconnected (INVALID = FORCEOFF = 1) and a
transition occurs on a receiver or transmitter input (see
Figure 7). For immediate power up when the cable is
reattached, connect FORCEON to FORCEOFF through a
network similar to that shown in Figure 5.
I/O
UART
CPU
FIGURE 9. CONNECTIONS FOR AUTOMATIC POWERDOWN
PRESENT
Ready Output (ICL3224E and ICL3226E only)
The Ready output indicates that the ICL322XE is ready to
transmit. Ready switches low whenever the device enters
powerdown, and switches back high during power-up when
V- reaches -4V or lower.
Capacitor Selection
The charge pumps require 0.1µF capacitors for 3.3V
operation. For other supply voltages refer to Table 3 for
capacitor values. Do not use values smaller than those listed
in Table 3. Increasing the capacitor values (by a factor of 2)
reduces ripple on the transmitter outputs and slightly
reduces power consumption. C2, C3, and C4 can be
increased without increasing C1’s value, however, do not
increase C1 without also increasing C2, C3, and C4 to
maintain the proper ratios (C1 to the other capacitors).
12
TABLE 3. REQUIRED CAPACITOR VALUES
VCC
(V)
C1
(µF)
C2, C3, C4
(µF)
3.0 to 3.6
0.1
0.1
4.5 to 5.5
0.047
0.33
3.0 to 5.5
0.1
0.47
Power Supply Decoupling
In most circumstances a 0.1µF bypass capacitor is
adequate. In applications that are particularly sensitive to
power supply noise, decouple VCC to ground with a
capacitor of the same value as the charge-pump capacitor C1.
Connect the bypass capacitor as close as possible to the IC.
Mouse Driveability
The ICL3244E is specifically designed to power a serial
mouse while operating from low voltage supplies. Figure 11
shows the transmitter output voltages under increasing load
current. The on-chip switching regulator ensures the
transmitters will supply at least ±5V during worst case
conditions (15mA for paralleled V+ transmitters, 7.3mA for
single V- transmitter).
6
TRANSMITTER OUTPUT VOLTAGE (V)
When using minimum required capacitor values, make sure
that capacitor values do not degrade excessively with
temperature. If in doubt, use capacitors with a larger nominal
value. The capacitor’s equivalent series resistance (ESR)
usually rises at low temperatures and it influences the
amount of ripple on V+ and V-.
5
VOUT+
4
3
VCC = 3.0V
2
1
T1
VOUT+
-1
T2
-2
ICL3244E
-3
VCC
-4
T3
-5
1
2
3
4
6
5
7
8
9
10
LOAD CURRENT PER TRANSMITTER (mA)
ICL32XXE transmitter outputs meet RS-562 levels (±3.7V),
at full data rate, with VCC as low as 2.7V. RS-562 levels
typically ensure inter operability with RS-232 devices.
FIGURE 11. TRANSMITTER OUTPUT VOLTAGE vs LOAD
CURRENT (PER TRANSMITTER, i.e., DOUBLE
CURRENT AXIS FOR TOTAL VOUT+ CURRENT)
High Data Rates
Transmitter Outputs when Exiting
Powerdown
Figure 10 shows the response of two transmitter outputs
when exiting powerdown mode. As they activate, the two
transmitter outputs properly go to opposite RS-232 levels,
with no glitching, ringing, nor undesirable transients. Each
transmitter is loaded with 3kΩ in parallel with 2500pF. Note
that the transmitters enable only when the magnitude of the
supplies exceed approximately 3V.
The ICL32XXE maintain the RS-232 ±5V minimum
transmitter output voltages even at high data rates. Figure 12
details a transmitter loopback test circuit, and Figure 13
illustrates the loopback test result at 120kbps. For this test,
all transmitters were simultaneously driving RS-232 loads in
parallel with 1000pF, at 120kbps. Figure 14 shows the
loopback results for a single transmitter driving 1000pF and
an RS-232 load at 250kbps. The static transmitters were
also loaded with an RS-232 receiver.
VCC
5V/DIV.
VOUT -
-6
Operation Down to 2.7V
VOUT -
0.1µF
FORCEOFF
T1
VCC = +3.3V
C1 - C4 = 0.1µF
VCC
C1+
V+
C1
C1-
C3
ICL32XXE
2V/DIV.
V-
C2+
C2
C4
C2TIN
T2
5V/DIV.
ROUT
READY
TIME (20µs/DIV.)
FIGURE 10. TRANSMITTER OUTPUTS WHEN EXITING
POWERDOWN
FORCEON
VCC
TOUT
RIN
1000pF
5K
FORCEOFF
FIGURE 12. TRANSMITTER LOOPBACK TEST CIRCUIT
13
±15kV ESD Protection
5V/DIV.
All pins on ICL32XX devices include ESD protection
structures, but the ICL32XXE family incorporates advanced
structures which allow the RS-232 pins (transmitter outputs
and receiver inputs) to survive ESD events up to ±15kV. The
RS-232 pins are particularly vulnerable to ESD damage
because they typically connect to an exposed port on the
exterior of the finished product. Simply touching the port
pins, or connecting a cable, can cause an ESD event that
might destroy unprotected ICs. These new ESD structures
protect the device whether or not it is powered up, protect
without allowing any latchup mechanism to activate, and
don’t interfere with RS-232 signals as large as ±25V.
T1IN
T1OUT
R1OUT
VCC = +3.3V
C1 - C4 = 0.1µF
5µs/DIV.
FIGURE 13. LOOPBACK TEST AT 120kbps
Human Body Model (HBM) Testing
As the name implies, this test method emulates the ESD
event delivered to an IC during human handling. The tester
delivers the charge through a 1.5kΩ current limiting resistor,
making the test less severe than the IEC61000 test which
utilizes a 330Ω limiting resistor. The HBM method
determines an ICs ability to withstand the ESD transients
typically present during handling and manufacturing. Due to
the random nature of these events, each pin is tested with
respect to all other pins. The RS-232 pins on “E” family
devices can withstand HBM ESD events to ±15kV.
5V/DIV.
T1IN
T1OUT
IEC61000-4-2 Testing
R1OUT
VCC = +3.3V
C1 - C4 = 0.1µF
2µs/DIV.
FIGURE 14. LOOPBACK TEST AT 250kbps
Interconnection with 3V and 5V Logic
The ICL32XXE directly interfaces with 5V CMOS and TTL
logic families. Nevertheless, with the ICL32XX at 3.3V, and
the logic supply at 5V, AC, HC, and CD4000 outputs can
drive ICL32XX inputs, but ICL32XX outputs do not reach the
minimum VIH for these logic families. See Table 4 for more
information.
TABLE 4. LOGIC FAMILY COMPATIBILITY WITH VARIOUS
SUPPLY VOLTAGES
VCC
SYSTEM
POWER-SUPPLY SUPPLY
VOLTAGE
VOLTAGE
(V)
(V)
3.3
3.3
5
5
5
3.3
The IEC 61000 test method applies to finished equipment,
rather than to an individual IC. Therefore, the pins most likely to
suffer an ESD event are those that are exposed to the outside
world (the RS-232 pins in this case), and the IC is tested in its
typical application configuration (power applied) rather than
testing each pin-to-pin combination. The lower current limiting
resistor coupled with the larger charge storage capacitor yields
a test that is much more severe than the HBM test. The extra
ESD protection built into this device’s RS-232 pins allows the
design of equipment meeting level 4 criteria without the need
for additional board level protection on the RS-232 port.
AIR-GAP DISCHARGE TEST METHOD
For this test method, a charged probe tip moves toward the IC
pin until the voltage arcs to it. The current waveform delivered to
the IC pin depends on approach speed, humidity, temperature,
etc., so it is difficult to obtain repeatable results. The “E” device
RS-232 pins withstand ±15kV air-gap discharges.
CONTACT DISCHARGE TEST METHOD
COMPATIBILITY
Compatible with all CMOS
families.
Compatible with all TTL and
CMOS logic families.
Compatible with ACT and HCT
CMOS, and with TTL. ICL32XX
outputs are incompatible with AC,
HC, and CD4000 CMOS inputs.
14
During the contact discharge test, the probe contacts the
tested pin before the probe tip is energized, thereby
eliminating the variables associated with the air-gap
discharge. The result is a more repeatable and predictable
test, but equipment limits prevent testing devices at voltages
higher than ±8kV. All “E” family devices survive ±8kV contact
discharges on the RS-232 pins.
Typical Performance Curves
VCC = 3.3V, TA = 25°C
25
VOUT+
4
SLEW RATE (V/µs)
6
2
1 TRANSMITTER AT 250kbps
OTHER TRANSMITTERS AT 30kbps
-SLEW
15
+SLEW
10
-4
VOUT -
-6
2000
3000
4000
5
5000
3000
FIGURE 15. TRANSMITTER OUTPUT VOLTAGE vs LOAD
CAPACITANCE
5000
FIGURE 16. SLEW RATE vs LOAD CAPACITANCE
35
40
ICL3226E
ICL3224E
30
35
SUPPLY CURRENT (mA)
250kbps
30
25
120kbps
20kbps
250kbps
25
120kbps
15
10
20kbps
5
10
2000
3000
4000
1000
2000
3000
4000
5000
LOAD CAPACITANCE (pF)
FIGURE 17. SUPPLY CURRENT vs LOAD CAPACITANCE
WHEN TRANSMITTING DATA
FIGURE 18. SUPPLY CURRENT vs LOAD CAPACITANCE
3.5
45
NO LOAD
ALL OUTPUTS STATIC
ICL3244E
40
3.0
250kbps
35
SUPPLY CURRENT (mA)
SUPPLY CURRENT (mA)
4000
SUPPLY CURRENT (mA)
2000
30
120kbps
25
20kbps
15
2.5
2.0
1.5
1.0
0.5
10
2000
3000
4000
5000
FIGURE 19. SUPPLY CURRENT vs LOAD CAPACITANCE
15
3.0
3.5
4.0
4.5
5.0
5.5
SUPPLY VOLTAGE (V)
FIGURE 20. SUPPLY CURRENT vs SUPPLY VOLTAGE
6.0
Die Characteristics
SUBSTRATE POTENTIAL (POWERED UP)
GND
TRANSISTOR COUNT
ICL3224E: 937
ICL3226E: 825
ICL3244E: 1109
PROCESS
Si Gate CMOS
16
Shrink Small Outline Plastic Packages (SSOP)
M20.209 (JEDEC MO-150-AE ISSUE B)
N
20 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
-B1
2
3
0.25
0.010
SEATING PLANE
-A-
SYMBOL
GAUGE
PLANE
A
D
-C-
α
e
C
0.10(0.004)
C A M
B S
MILLIMETERS
MIN
MAX
NOTES
A
0.068
0.078
1.73
1.99
0.002
0.008’
0.05
0.21
A2
0.066
0.070’
1.68
1.78
B
0.010’
0.015
0.25
0.38
C
0.004
0.008
0.09
0.20’
D
0.278
0.289
7.07
7.33
3
E
0.205
0.212
5.20’
5.38
4
0.026 BSC
0.301
0.311
7.65
7.90’
L
0.025
0.037
0.63
0.95
8 deg.
0 deg.
N
0 deg.
9
0.65 BSC
H
α
NOTES:
MAX
A1
e
A2
A1
B
0.25(0.010) M
L
MIN
6
8 deg.
Rev. 3 11/02
1. Symbols are defined in the “MO Series Symbol List” in Section
2.2 of Publication Number 95.
2. Dimensioning and tolerancing per ANSI Y14.5M-1982.
3. Dimension “D” does not include mold flash, protrusions or gate
burrs. Mold flash, protrusion and gate burrs shall not exceed
0.20mm (0.0078 inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.20mm (0.0078
inch) per side.
5. The chamfer on the body is optional. If it is not present, a visual
index feature must be located within the crosshatched area.
6. “L” is the length of terminal for soldering to a substrate.
7. “N” is the number of terminal positions.
8. Terminal numbers are shown for reference only.
9. Dimension “B” does not include dambar protrusion. Allowable
dambar protrusion shall be 0.13mm (0.005 inch) total in excess
of “B” dimension at maximum material condition.
10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact.
17
M16.209 (JEDEC MO-150-AC ISSUE B)
N
INDEX
AREA
16 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
H
0.25(0.010) M
2
GAUGE
PLANE
3
0.25
0.010
SEATING PLANE
-A-
INCHES
E
-B-
1
B M
A
D
-C-
α
e
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.078
2.00
A1
0.002
0.05
A2
0.065
0.072
1.65
1.85
B
0.009
0.014
0.22
0.38
9
C
0.004
0.009
0.09
0.25
D
0.233
0.255
5.90
6.50
3
E
0.197
0.220
5.00
5.60
4
e
A2
A1
B
0.25(0.010) M
L
B S
1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of
3. Dimension “D” does not include mold flash, protrusions or gate burrs.
Mold flash, protrusion and gate burrs shall not exceed 0.20mm (0.0078
inch) per side.
flash and protrusions shall not exceed 0.20mm (0.0078 inch) per side.
5. The chamfer on the body is optional. If it is not present, a visual index
9. Dimension “B” does not include dambar protrusion. Allowable dambar
protrusion shall be 0.13mm (0.005 inch) total in excess of “B” dimension at maximum material condition.
18
0.026 BSC
H
0.292
L
0.022
N
α
NOTES:
MILLIMETERS
0.65 BSC
0.322
7.40
0.037
0.55
16
0°
8.20
0.95
6
16
8°
0°
7
8°
Rev. 3
6/05
M28.209 (JEDEC MO-150-AH ISSUE B)
N
INDEX
AREA
28 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
H
0.25(0.010) M
2
GAUGE
PLANE
3
0.25
0.010
SEATING PLANE
-A-
INCHES
E
-B-
1
B M
A
D
-C-
α
e
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.078
2.00
A1
0.002
0.05
A2
0.065
0.072
1.65
1.85
B
0.009
0.014
0.22
0.38
9
C
0.004
0.009
0.09
0.25
D
0.390
0.413
9.90
10.50
3
E
0.197
0.220
5.00
5.60
4
e
A2
A1
B
0.25(0.010) M
L
B S
NOTES:
inch) per side.
dambar protrusion shall be 0.13mm (0.005 inch) total in excess of
19
0.026 BSC
H
0.292
L
0.022
N
α
MILLIMETERS
0.65 BSC
0.322
7.40
0.037
0.55
28
0°
0.95
6
28
8°
0°
8.20
7
8°
Rev. 2 6/05
Small Outline Plastic Packages (SOIC)
M28.3 (JEDEC MS-013-AE ISSUE C)
N
28 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
SYMBOL
-B-
1
2
3
L
SEATING PLANE
-A-
h x 45o
A
D
-C-
e
A1
B
C
0.10(0.004)
0.25(0.010) M
C A M
B S
MIN
MAX
NOTES
A
0.0926
0.1043
2.35
2.65
0.0040
0.0118
0.10
0.30
B
0.013
0.0200
0.33
0.51
9
C
0.0091
0.0125
0.23
0.32
D
0.6969
0.7125
17.70
18.10
3
E
0.2914
0.2992
7.40
7.60
4
0.05 BSC
1.27 BSC
H
0.394
0.419
10.00
10.65
h
0.01
0.029
0.25
0.75
5
L
0.016
0.050
0.40
1.27
6
8o
0o
N
α
NOTES:
MILLIMETERS
MAX
A1
e
α
MIN
28
0o
28
7
8o
Rev. 0 12/93
0.15mm (0.006 inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010
inch) per side.
9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater
above the seating plane, shall not exceed a maximum value of
0.61mm (0.024 inch)
All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems.
Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality
Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without
notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and
reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result
from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries.
For information regarding Intersil Corporation and its products, see www.intersil.com
