CD74HCT646M96
CD74HCT646M96
    L3HARRIS
    SOIC24
    IC TXRX NON-INVERT 5.5V 24SOIC
CD74HCT646M96 数据手册
CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 D D D D D D D D D D CD54HC646 . . . F PACKAGE CD74HCT646 . . . M PACKAGE (TOP VIEW) 2-V to 6-V VCC Operation (CD54HC646) 4.5-V to 5.5-V VCC Operation (CD74HCT646) Wide Operating Temperature Range of –55°C to 125°C Balanced Propagation Delays and Transition Times Standard Outputs Drive Up To 15 LS-TTL Loads Significant Power Reduction Compared to LS-TTL Logic ICs Inputs Are TTL-Voltage Compatible (CD74HCT646) Independent Registers for A and B Buses Multiplexed Real-Time and Stored Data True Data Paths CLKAB SAB DIR A1 A2 A3 A4 A5 A6 A7 A8 GND 1 24 2 23 3 22 4 21 5 20 6 19 7 18 8 17 9 16 10 15 11 14 12 13 VCC CLKBA SBA OE B1 B2 B3 B4 B5 B6 B7 B8 description/ordering information The CD54HC646 and CD74HCT646 consist of bus-transceiver circuits with 3-state outputs, D-type flip-flops, and control circuitry arranged for multiplexed transmission of data directly from the input bus or from the internal registers. Data on the A or B bus is clocked into the registers on the low-to-high transition of the appropriate clock (CLKAB or CLKBA) input. Figure 1 illustrates the four fundamental bus-management functions that can be performed with these devices. Output-enable (OE) and direction-control (DIR) inputs control the transceiver functions. In the transceiver mode, data present at the high-impedance port can be stored in either or both registers. The select-control (SAB and SBA) inputs can multiplex stored and real-time (transparent mode) data. DIR determines which bus receives data when OE is active (low). In the isolation mode (OE high), A data can be stored in one register and /or B data can be stored in the other register. When an output function is disabled, the input function still is enabled and can be used to store data. Only one of the two buses, A or B, can be driven at a time. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. ORDERING INFORMATION –55°C 55°C to 125°C ORDERABLE PART NUMBER PACKAGE† TA TOP-SIDE MARKING SOIC – M Tape and reel CD74HCT646M96 HCT646M CDIP – F Tube CD54HC646F3A CD54HC646F3A † Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2003, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. On products compliant to MIL-PRF-38535, all parameters are tested unless otherwise noted. On all other products, production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 FUNCTION TABLE INPUTS DATA I/O OE DIR CLKAB CLKBA SAB SBA A1– A8 B1– B8 X X ↑ X X X Input Unspecified† OPERATION OR FUNCTION X X X ↑ X X Unspecified† Input Store A, B unspecified† Store B, A unspecified† H X ↑ ↑ X X Input Input Store A and B data H X H or L H or L X X Input disabled Input disabled Isolation, hold storage L L X X X L Output Input Real-time B data to A bus L L X H or L X H Output Input Stored B data to A bus L H X X L X Input Output Real-time A data to B bus L H H or L X H X Input Output Stored A data to B bus † The data-output functions can be enabled or disabled by various signals at OE and DIR. Data-input functions always are enabled; i.e., data at the bus terminals is stored on every low-to-high transition of the clock inputs. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS 21 OE L 3 DIR L 1 23 CLKAB CLKBA X X 2 SAB X BUS B BUS A BUS A BUS B SCHS278B – APRIL 2003 – REVISED APRIL 2003 22 SBA L 21 OE L 3 DIR H 3 DIR X X X 1 23 CLKAB CLKBA X ↑ X ↑ ↑ ↑ 2 SAB X X X 2 SAB L 22 SBA X BUS B BUS A BUS A 21 OE X X H 23 CLKBA X REAL-TIME TRANSFER BUS A TO BUS B BUS B REAL-TIME TRANSFER BUS B TO BUS A 1 CLKAB X 22 SBA X X X STORAGE FROM A, B, OR A AND B 21 OE L L 3 DIR L H 1 CLKAB X H or L 23 CLKBA H or L X 2 SAB X H 22 SBA H X TRANSFER STORED DATA TO A AND/OR B Figure 1. Bus-Management Functions POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 logic diagram (positive logic) 21 OE 3 DIR 2 To Channels 2–8 SAB 22 SBA 1 CLKAB CLKBA 23 CLK D VCC P 4 A1 N VCC GND P 20 B1 N GND Q C C D VCC C P P N N 24 12 C P N C C P N C C GND F/F 4 One of Eight Identical Channels POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V Input clamp current, IIK (VI < 0 or VI > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Output clamp current, IOK (VO < 0 or VO > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Continuous output drain current per output, IO (VO = 0 to VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±35 mA Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Package thermal impedance, θJA (see Note 2) M package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. The package thermal impedance is calculated in accordance with JESD 51-7. recommended operating conditions for CD54HC646 (see Note 3) VCC VIH Supply voltage VCC = 2 V VCC = 4.5 V High-level input voltage VCC = 6 V VCC = 2 V VIL Low-level input voltage VI VO Input voltage tt MIN MAX 2 6 V 3.15 4.2 0.5 1.35 V 1.8 0 0 VCC = 2 V VCC = 4.5 V Input transition (rise and fall) time V 1.5 VCC = 4.5 V VCC = 6 V Output voltage UNIT VCC VCC V V 1000 500 ns VCC = 6 V 400 TA Operating free-air temperature –55 125 °C NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. recommended operating conditions for CD74HCT646 (see Note 3) VCC VIH Supply voltage VIL VI Low-level input voltage VO tt Output voltage High-level input voltage MIN MAX 4.5 5.5 2 Input voltage Input transition (rise and fall) time UNIT V V 0.8 V VCC VCC V 500 ns V TA Operating free-air temperature –55 125 °C NOTE 4: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 electrical characteristics for CD54HC646 over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS VCC IOH = –20 µA VOH VI = VIH or VIL IOH = –6 mA IOH = –7.8 mA VOL VI = VCC or 0 VO = VCC or 0 ICC Ci VI = VCC or 0, TA = –55°C TO 125°C TA = –40°C TO 85°C MIN MIN MIN MAX MAX 2V 1.9 1.9 1.9 4.5 V 4.4 4.4 4.4 6V 5.9 5.9 5.9 4.5 V 3.98 3.7 3.84 6V 5.48 5.2 UNIT MAX V 5.34 2V 0.1 0.1 0.1 IOL = 20 µA 4.5 V 0.1 0.1 0.1 6V 0.1 0.1 0.1 IOL = 6 mA IOL = 7.8 mA 4.5 V 0.26 0.4 0.33 6V 0.26 0.4 0.33 6V ±0.1 ±1 ±1 µA 6V ±0.5 ±10 ±5 µA VI = VIH or VIL II IOZ TA = 25°C IO = 0 6V Co V 8 160 80 µA 10 10 10 pF 20 20 20 pF electrical characteristics for CD74HCT646 over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS TA = 25°C VCC MIN VOH VI = VIH or VIL IOH = –20 µA IOH = –6 mA 45V 4.5 VOL VI = VIH or VIL IOL = 20 µA IOL = 6 mA 45V 4.5 II IOZ VI = VCC to GND VO = VCC or 0 5.5 V 5.5 V ICC VI = VCC or 0, IO = 0 One input at VCC – 2.1 V, Other inputs at 0 or VCC 5.5 V ∆ICC† TYP MIN MIN MAX 4.4 4.4 4.4 3.7 3.84 4.5 V to 5.5 V 100 Co † Additional quiescent supply current per input pin, TTL inputs high, 1 unit load POST OFFICE BOX 655303 TA = –40°C TO 85°C 3.98 Ci 6 MAX TA = –55°C TO 125°C • DALLAS, TEXAS 75265 UNIT MAX V 0.1 0.1 0.1 0.26 0.4 0.33 ±0.1 ±1 ±1 µA ±0.5 ±10 ±5 µA 8 160 80 µA 360 490 450 µA 10 10 10 pF 20 20 20 pF V CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 HCT INPUT LOADING TABLE INPUT UNIT LOAD† OE 1.3 DIR 0.75 CLKAB or CLKBA 0.6 SAB or SBA 0.45 A or B 0.3 † Unit Load is ∆ICC limit specified in electrical characteristics table (e.g., 360 µA max at 25°C). timing requirements for CD54HC646 over recommended operating free-air temperature range (unless otherwise noted) (see Figure 2) VCC fclock Clock frequency TA = 25°C TA = –55°C TO 125°C TA = –40°C TO 85°C MIN MIN MIN MAX tsu th Pulse duration, CLKBA or CLKAB high or low Setup time, A before CLKAB↑ ↑ or B before CLKBA↑ ↑ Hold time, A after CLKAB↑ ↑ or B after CLKBA↑ ↑ UNIT MAX 2V 6 4 5 4.5 V 30 20 25 6V tw MAX 35 23 MHz 29 2V 80 120 100 4.5 V 16 24 20 6V 14 20 17 2V 60 90 75 4.5 V 12 18 15 6V 10 15 13 2V 35 55 45 4.5 V 7 11 9 6V 6 9 8 ns ns ns timing requirements for CD74HCT646 over recommended operating free-air temperature range, VCC = 4.5 V (unless otherwise noted) (see Figure 3) TA = 25°C TA = –55°C TO 125°C TA = –40°C TO 85°C MIN MIN MIN MAX 25 MAX fclock tw Clock frequency Pulse duration, CLKBA or CLKAB high or low 25 38 31 ns tsu Setup time, A before CLKAB↑ or B before CLKBA↑ 12 18 15 ns th Hold time, A after CLKAB↑ or B after CLKBA↑ 5 5 5 ns POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 17 UNIT MAX 20 MHz 7 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 switching characteristics for CD54HC646 over recommended operating free-air temperature range (unless otherwise noted) (see Figure 2) PARAMETER FROM (INPUT) TO (OUTPUT) LOAD CAPACITANCE CL = 50 pF fmax CLKBA or CLKAB A or B A or B B or A A or B OE A or B tt OE A or B Any MIN MIN MAX 2V 6 4 5 4.5 V 30 20 25 6V 35 23 29 220 330 275 44 66 55 6V 37 56 47 2V 135 205 170 4.5 V 27 41 34 6V 23 35 29 2V 170 255 215 4.5 V 34 51 43 6V 29 43 37 2V 175 265 220 4.5 V 35 53 44 6V 30 45 37 2V 175 265 220 4.5 V 35 53 44 6V 30 45 37 CL = 50 pF CL = 50 pF CL = 50 pF 60 5V 18 5V 5V 14 5V ns 14 CL = 15 pF 5V 2V 60 90 75 CL = 50 pF 4.5 V 12 18 15 POST OFFICE BOX 655303 ns 12 ns 14 6V 10 15 † These parameters are measured with the internal output state of the storage register opposite that of the bus input. 8 MHz 2V CL = 50 pF UNIT MAX 4.5 V CL = 15 pF tdis di MAX CL = 50 pF CL = 15 pF ten TYP TA = –40°C TO 85°C 5V CL = 15 pF SBA or SAB† MIN TA = –55°C TO 125°C CL = 15 pF CL = 15 pF tpd d TA = 25°C VCC • DALLAS, TEXAS 75265 13 ns CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 switching characteristics for CD74HCT646 over recommended operating free-air temperature range (unless otherwise noted) (see Figure 3) PARAMETER FROM (INPUT) TO (OUTPUT) fmax tpd d CLKBA or CLKAB A or B A or B B or A SBA or SAB† A or B ten OE A or B tdis di OE A or B LOAD CAPACITANCE VCC CL = 50 pF 4.5 V CL = 15 pF 5V CL = 50 pF 4.5 V CL = 15 pF 5V CL = 50 pF 4.5 V CL = 15 pF 5V CL = 50 pF 4.5 V TA = 25°C MIN CL = 15 pF 5V CL = 50 pF 4.5 V CL = 15 pF 5V CL = 50 pF 4.5 V CL = 15 pF 5V TYP MAX 25 TA = –55°C TO 125°C TA = –40°C TO 85°C MIN MIN MAX 17 UNIT MAX 20 MHz 45 44 66 55 37 56 46 46 69 58 45 68 56 35 53 44 18 15 ns 19 19 14 tt CL = 50 pF 4.5 V 12 18 † These parameters are measured with the internal output state of the storage register opposite that of the bus input. 15 ns ns ns operating characteristics, VCC = 5 V, TA = 25°C PARAMETER Cpd TYP Power dissipation capacitance 52 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 UNIT pF 9 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 PARAMETER MEASUREMENT INFORMATION – CD54HC646 VCC Test Point From Output Under Test PARAMETER S1 ten RL = 1 kΩ tdis CL (see Note A) S2 S1 S2 tPZH Open Closed tPZL Closed Open tPHZ Open Closed tPLZ Closed Open Open Open tpd or tt tw LOAD CIRCUIT VCC Input 50% VCC 50% VCC 0V VOLTAGE WAVEFORMS PULSE DURATION CLR Input VCC Reference Input VCC 50% VCC 50% VCC 0V 0V tsu trec Data 50% Input 10% VCC 50% VCC CLK 90% VOLTAGE WAVEFORMS RECOVERY TIME 50% VCC 50% VCC tPLH tPHL 50% 10% 90% 90% tr tPHL Out-of-Phase Output 90% tf tf VCC VOH 50% VCC 10% VOL tf 50% 10% 90% tr VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES 50% VCC 50% VCC 0V tPLZ tPZL ≈VCC Output Waveform 1 (see Note B) 50% VCC Output Waveform 2 (see Note B) 10% VOL tPHZ tPZH VOH VOL VCC Output Control tPLH 50% VCC 10% VCC 50% VCC 10% 0 V VOLTAGE WAVEFORMS SETUP AND HOLD AND INPUT RISE AND FALL TIMES 0V In-Phase Output 90% tr 0V Input th 50% VCC 90% VOH ≈0 V VOLTAGE WAVEFORMS OUTPUT ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. Phase relationships between waveforms were chosen arbitrarily. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 6 ns, tf = 6 ns. D. For clock inputs, fmax is measured with the input duty cycle at 50%. E. The outputs are measured one at a time with one input transition per measurement. F. tPLZ and tPHZ are the same as tdis. G. tPZL and tPZH are the same as ten. H. tPLH and tPHL are the same as tpd. Figure 2. Load Circuit and Voltage Waveforms 10 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54HC646, CD74HCT646 OCTAL BUS TRANSCEIVERS AND REGISTERS WITH 3-STATE OUTPUTS SCHS278B – APRIL 2003 – REVISED APRIL 2003 PARAMETER MEASUREMENT INFORMATION – CD74HCT646 VCC Test Point From Output Under Test PARAMETER S1 ten 1 kΩ tdis CL (see Note A) S2 S1 S2 tPZH Open Closed tPZL Closed Open tPHZ Open Closed tPLZ Closed Open Open Open tpd or tt tw LOAD CIRCUIT 3V 1.3 V Input 1.3 V 0V VOLTAGE WAVEFORMS PULSE DURATION CLR Input 3V Reference Input 3V 1.3 V 1.3 V 0V 0V tsu trec Data 1.3 V Input 0.3 V 3V 1.3 V CLK th 2.7 V 3V 2.7 V 1.3 V 0.3 V 0 V tf tr 0V VOLTAGE WAVEFORMS RECOVERY TIME VOLTAGE WAVEFORMS SETUP AND HOLD AND INPUT RISE AND FALL TIMES 3V Input 1.3 V 1.3 V 0V tPLH In-Phase Output 1.3 V 10% 90% tPHL 90% 1.3 V 1.3 V 0V tPHL 90% tr Out-of-Phase Output 3V Output Control VOH 1.3 V 10% tf VOL 1.3 V 10% tf 1.3 V 10% tr VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES 1.3 V Output Waveform 2 (see Note B) 10% VOL tPHZ tPZH VOH VOL ≈VCC Output Waveform 1 (see Note B) tPLH 90% tPLZ tPZL 1.3 V 90% VOH ≈0 V VOLTAGE WAVEFORMS OUTPUT ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. Phase relationships between waveforms were chosen arbitrarily. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 6 ns, tf = 6 ns. D. For clock inputs, fmax is measured with the input duty cycle at 50%. E. The outputs are measured one at a time with one input transition per measurement. F. tPLZ and tPHZ are the same as tdis. G. tPZL and tPZH are the same as ten. H. tPLH and tPHL are the same as tpd. Figure 3. Load Circuit and Voltage Waveforms POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 11 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) 5962-8688501JA ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8688501JA CD54HC646F3A CD54HC646F3A ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8688501JA CD54HC646F3A CD74HCT646M96 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT646M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HCT646M96 价格&库存
很抱歉,暂时无法提供与“CD74HCT646M96”相匹配的价格&库存,您可以联系我们找货
