HIN202CB-T
HIN202CB-T
    L3HARRIS
    SOIC-16_9.9X3.9MM
    IC TRANSCEIVER FULL 2/2 16SOIC
HIN202CB-T 数据手册
HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 ® Data Sheet July 27, 2005 FN3980.18 +5V Powered RS-232 Transmitters/Receivers with 0.1Microfarad External Capacitors Features The HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 family of RS-232 transmitters/receivers interface circuits meet all ElA RS-232E and V.28 specifications, and are particularly suited for those applications where ±12V is not available. They require a single +5V power supply and feature onboard charge pump voltage converters which generate +10V and -10V supplies from the 5V supply. The family of devices offers a wide variety of RS-232 transmitter/receiver combinations to accommodate various applications (see Selection Table). • Meets All RS-232E and V.28 Specifications • Pb-Free Plus Anneal Available (RoHS Compliant) (See Ordering Info) • Requires Only 0.1µF or Greater External Capacitors • High Data Rate. . . . . . . . . . . . . . . . . . . . . . . . . . .120kbit/s • Two Receivers Active in Shutdown Mode (HIN213) • Requires Only Single +5V Power Supply • Onboard Voltage Doubler/Inverter • Low Power Consumption (Typ) . . . . . . . . . . . . . . . . . 5mA • Low Power Shutdown Function (Typ) . . . . . . . . . . . . .1µA The HIN206, HIN211 and HIN213 feature a low power shutdown mode to conserve energy in battery powered applications. In addition, the HIN213 provides two active receivers in shutdown mode allowing for easy “wakeup” capability. • Three-State TTL/CMOS Receiver Outputs • Multiple Drivers - ±10V Output Swing for +5V lnput - 300Ω Power-Off Source Impedance - Output Current Limiting - TTL/CMOS Compatible - 30V/µs Maximum Slew Rate The drivers feature true TTL/CMOS input compatibility, slew rate-limited output, and 300Ω power-off source impedance. The receivers can handle up to ±30V input, and have a 3kΩ to 7kΩ input impedance. The receivers also feature hysteresis to greatly improve noise rejection. • Multiple Receivers - ±30V Input Voltage Range - 3kΩ to 7kΩ Input Impedance - 0.5V Hysteresis to Improve Noise Rejection Applications • Any System Requiring RS-232 Communications Port - Computer - Portable, Mainframe, Laptop - Peripheral - Printers and Terminals - Instrumentation - Modems Selection Table POWER SUPPLY VOLTAGE NUMBER OF RS-232 DRIVERS NUMBER OF RS-232 RECEIVERS NUMBER OF 0.1µF EXTERNAL CAPACITORS LOW POWER SHUTDOWN/TTL THREE-STATE NUMBER OF RECEIVERS ACTIVE IN SHUTDOWN HIN202 +5V 2 2 4 Capacitors No/No 0 HIN206 +5V 4 3 4 Capacitors Yes/Yes 0 HIN207 +5V 5 3 4 Capacitors No/No 0 HIN208 +5V 4 4 4 Capacitors No/No 0 HIN211 +5V 4 5 4 Capacitors Yes/Yes 0 HIN213 +5V 4 5 4 Capacitors Yes/Yes 2 PART NUMBER 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2001-2005. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Ordering Information (Continued) Ordering Information PART NO. TEMP. RANGE (°C) PACKAGE PKG. DWG. # PART NO. TEMP. RANGE (°C) PACKAGE PKG. DWG. # HIN202CB 0 to 70 16 Ld SOIC (W) M16.3 HIN208CB 0 to 70 24 Ld SOIC M24.3 HIN202CB-T 0 to 70 16 Ld SOIC (W) Tape and Reel M16.3 HIN208CB-T 0 to 70 24 Ld SOIC Tape and Reel M24.3 HIN202CBZ (See Note) 0 to 70 16 Ld SOIC (W) (Pb-free) M16.3 HIN208CBZ (See Note) 0 to 70 24 Ld SOIC (Pb-free) M24.3 HIN202CBZ-T (See Note) 0 to 70 16 Ld SOIC (W) Tape and Reel (Pb-free) M16.3 HIN208CBZ-T (See Note) 0 to 70 24 Ld SOIC Tape and Reel (Pb-free) M24.3 HIN202CBN 0 to 70 16 Ld SOIC (N) M16.15 HIN211CA 0 to 70 28 Ld SSOP M28.209 HIN202CBN-T 0 to 70 16 Ld SOIC (N) Tape and Reel M16.15 HIN211CA-T 0 to 70 28 Ld SSOP Tape and Reel M28.209 HIN202CBNZ (See Note) 0 to 70 16 Ld SOIC (N) (Pb-free) M16.15 HIN211CAZ (See Note) 0 to 70 28 Ld SSOP (Pb-free) M28.209 HIN202CBNZ-T (See Note) 0 to 70 16 Ld SOIC (N) Tape and Reel (Pb-free) M16.15 HIN211CAZ-T (See Note) 0 to 70 28 Ld SSOP Tape and Reel (Pb-free) M28.209 HIN202CP 0 to 70 16 Ld PDIP E16.3 HIN211CB 0 to 70 28 Ld SOIC M28.3 HIN202IB -40 to 85 16 Ld SOIC (W) M16.3 HIN211CB-T 0 to 70 28 Ld SOIC Tape and Reel M28.3 HIN202IBZ (See Note) -40 to 85 16 Ld SOIC (W) (Pb-free) M16.3 HIN211CBZ (See Note) 0 to 70 28 Ld SOIC (Pb-free) M28.3 HIN202IBN -40 to 85 16 Ld SOIC (N) M16.15 16 Ld SOIC (N) Tape and Reel M16.15 28 Ld SOIC Tape and Reel (Pb-free) M28.3 -40 to 85 HIN211CBZ-T (See Note) 0 to 70 HIN202IBN-T HIN202IBNZ (See Note) -40 to 85 16 Ld SOIC (N) (Pb-free) M16.15 HIN213CA 0 to 70 28 Ld SSOP M28.209 HIN213CA-T 0 to 70 -40 to 85 16 Ld SOIC (N) Tape and Reel (Pb-free) M16.15 28 Ld SSOP Tape and Reel M28.209 HIN202IBNZ-T (See Note) HIN213CAZ (See Note) 0 to 70 28 Ld SSOP (Pb-free) M28.209 HIN213CAZ-T (See Note) 0 to 70 28 Ld SSOP Tape and Reel (Pb-free) M28.209 HIN206CB 0 to 70 24 Ld SOIC M24.3 HIN207CA 0 to 70 24 Ld SSOP M24.209 HIN207CAZ (See Note) 0 to 70 24 Ld SSOP (Pb-free) M24.209 HIN207CAZ-T (See Note) 0 to 70 24 Ld SSOP Tape and Reel (Pb-free) M24.209 HIN207CB 0 to 70 24 Ld SOIC M24.3 HIN207CB-T 0 to 70 24 Ld SOIC Tape and Reel M24.3 2 NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Pin Descriptions PIN VCC FUNCTION Power Supply Input 5V ±10%, (5V ±5% HIN207). V+ Internally generated positive supply (+10V nominal). V- Internally generated negative supply (-10V nominal). GND Ground Lead. Connect to 0V. C1+ External capacitor (+ terminal) is connected to this lead. C1- External capacitor (- terminal) is connected to this lead. C2+ External capacitor (+ terminal) is connected to this lead. C2- External capacitor (- terminal) is connected to this lead. TIN Transmitter Inputs. These leads accept TTL/CMOS levels. An internal 400kΩ pull-up resistor to VCC is connected to each lead. TOUT RIN ROUT Transmitter Outputs. These are RS-232 levels (nominally ±10V). Receiver Inputs. These inputs accept RS-232 input levels. An internal 5kΩ pull-down resistor to GND is connected to each input. Receiver Outputs. These are TTL/CMOS levels. EN, EN Receiver enable Input. With EN = 5V (HIN213 EN = 0V), the receiver outputs are placed in a high impedance state. SD, SD Shutdown Input. With SD = 5V (HIN213 SD = 0V), the charge pump is disabled, the receiver outputs are in a high impedance state (except R4 and R5 of HIN213) and the transmitters are shut off. NC No Connect. No connections are made to these leads. 3 HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Pinouts HIN202 (PDIP, SOIC) TOP VIEW HIN206 (SOIC) TOP VIEW C1+ 1 16 VCC V+ 2 15 GND C1- 3 14 T1OUT C2+ 4 13 R1IN C2- 5 12 R1OUT T3OUT 1 24 T4OUT T1OUT 2 23 R2IN T2OUT 3 22 R2OUT R1IN 4 21 SD R1OUT 5 20 EN 19 T4IN T2IN 6 6 11 T1IN T1IN 7 18 T3IN T2OUT 7 10 T2IN GND 8 17 R3OUT VCC 9 16 R3IN V- 9 R2OUT R2IN 8 C1+ 10 15 V- V+ 11 14 C2- C1- 12 13 C2+ +5V +5V 9 16 1 0.1µF + 3 4 0.1µF T1IN T2IN + 5 11 10 0.1µF VCC C1+ C1C2+ C2- +5V TO 10V VOLTAGE INVERTER +10V TO -10V VOLTAGE INVERTER +5V 400kΩ +5V 400kΩ V+ 2 + 14 0.1µF T1IN V- 6 + T1 0.1µF 0.1µF T2IN T1OUT T3IN T2 7 T2OUT T4IN 10 C1+ + 12 C113 C2+ + 14 C2- VCC +5V TO 10V VOLTAGE DOUBLER V+ +10V TO -10V VOLTAGE INVERTER V- 15 12 13 R1IN T1 +5V 400kΩ T2 6 18 +5V 400kΩ T3 +5V 400kΩ 19 T4 2 3 1 24 R2OUT 8 0.1µF T1OUT T2OUT T3OUT T4OUT R1IN 5kΩ R1 22 9 0.1µF 4 R1OUT 5kΩ R1 + + +5V 400kΩ 7 5 R1OUT 11 23 R2IN R2OUT 5kΩ R2 R2IN 5kΩ R2 17 16 R3IN R3OUT GND 15 20 5kΩ R3 SD EN GND 8 4 21 HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Pinouts (Continued) HIN207 (SOIC, SSOP) TOP VIEW HIN208 (SOIC) TOP VIEW T3OUT 1 24 T4OUT T2OUT 1 24 T3OUT T1OUT 2 23 R2IN T1OUT 2 23 R3IN T2OUT 3 22 R2OUT R2IN 3 22 R3OUT R2OUT 4 21 T4IN T1IN 5 20 T4OUT R1OUT 6 19 T3IN R1IN 4 R1OUT 21 T5IN 20 T5OUT 5 T2IN 6 19 T4IN T1IN 7 18 T3IN R1IN 7 18 T2IN GND 8 17 R3OUT GND 8 17 R4OUT VCC 9 16 R3IN VCC 9 16 R4IN 15 V- C1+ 10 C1+ 10 14 C2- V+ 11 14 C2- C1- 12 13 C2+ C1- 12 13 C2+ +5V +5V 9 9 0.1µF 0.1µF T1IN T2IN T3IN T4IN T5IN 10 C1+ + 12 C113 C2+ + 14 C2- 0.1µF VCC 11 +5V TO 10V VOLTAGE DOUBLER V+ +10V TO -10V VOLTAGE INVERTER V- 15 T1 +5V 400kΩ T2 6 18 +5V 400kΩ T3 +5V 400kΩ 19 T4 +5V 400kΩ + 0.1µF 0.1µF + +5V 400kΩ 7 21 15 V- V+ 11 2 3 1 24 0.1µF T1OUT T1IN T2OUT T2IN T3OUT T3IN T4OUT T4IN 10 C1+ + 12 C113 C2+ + 14 C2- VCC +5V TO 10V VOLTAGE DOUBLER V+ +10V TO -10V VOLTAGE INVERTER V- 15 20 5 T5OUT + + +5V 400kΩ 5 T1 +5V 400kΩ T2 18 19 +5V 400kΩ T3 +5V 400kΩ 21 T4 2 1 24 20 6 T5 11 0.1µF 0.1µF T1OUT T2OUT T3OUT T4OUT 7 R1IN R1OUT 5kΩ R1 4 R1IN R1OUT 4 3 R2IN R2OUT 5kΩ R1 5kΩ R2 22 23 R2IN R2OUT 5kΩ R2 22 23 R3IN R3OUT 5kΩ R3 17 16 R3IN R3OUT 5kΩ R3 17 16 R4IN R4OUT 5kΩ R4 GND GND 8 8 5 HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Pinouts (Continued) HIN211 (SOIC, SSOP) TOP VIEW HIN213 (SSOP) TOP VIEW T3OUT 1 28 T4OUT T3OUT 1 28 T4OUT T1OUT 2 27 R3IN T1OUT 2 27 R3IN T2OUT 3 26 R3OUT T2OUT 3 26 R3OUT R2IN 4 25 SD R2IN 4 25 SD R2OUT 5 24 EN R2OUT 5 24 EN T2IN 6 23 R4IN T2IN 6 23 R4IN T1IN 7 22 R4OUT T1IN 7 22 R4OUT R1OUT 8 21 T4IN R1OUT 8 21 T4IN R1IN 9 20 T3IN R1IN 9 20 T3IN GND 10 19 R5OUT GND 10 19 R5OUT VCC 11 18 R5IN VCC 11 18 R5IN C1+ 12 17 V- C1+ 12 17 V- V+ 13 16 C2- V+ 13 16 C2- C1- 14 15 C2+ C1- 14 15 C2+ NOTE: R4 and R5 active in shutdown. +5V +5V 11 0.1µF 0.1µF T1IN T2IN T3IN T4IN R1OUT 12 C1+ + 14 C115 C2+ + 16 C2- VCC 13 +5V TO 10V VOLTAGE DOUBLER V+ +10V TO -10V VOLTAGE INVERTER V- 17 + 0.1µF 0.1µF + +5V 400kΩ 7 T1 +5V 400kΩ T2 6 20 +5V 400kΩ T3 21 +5V 400kΩ T4 2 3 1 28 9 8 0.1µF T1OUT T1IN T2OUT T2IN T3OUT T3IN T4OUT T4IN R1IN R1OUT 5 4 R2IN 26 R3IN +5V 400kΩ T2 6 20 +5V 400kΩ T3 21 +5V 400kΩ T4 R4IN SD R1IN 5kΩ 4 5kΩ 27 R3IN 5kΩ 22 23 R4IN R4OUT 5kΩ 19 18 R5IN R5OUT 24 5kΩ R5 25 EN GND 10 T4OUT 9 26 25 GND 28 R2IN 5kΩ EN T3OUT R3OUT 18 R5 T2OUT 1 R4 R5IN T1OUT 3 8 5kΩ R5OUT 0.1µF 2 5 23 19 + R3 R4OUT R4 V- 17 T1 5kΩ 22 +10V TO -10V VOLTAGE INVERTER + R2OUT 27 R3 V+ R2 R3OUT 13 +5V TO 10V VOLTAGE DOUBLER +5V 400kΩ 7 5kΩ R2 0.1µF VCC R1 R2OUT 6 12 C1+ + 14 C115 C2+ + 16 C2- 5kΩ R1 24 11 0.1µF 10 SD HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Absolute Maximum Ratings Thermal Information VCC to Ground. . . . . . . . . . . . . . . . . . . . . . (GND -0.3V)
HIN202CB-T 价格&库存
很抱歉,暂时无法提供与“HIN202CB-T”相匹配的价格&库存,您可以联系我们找货
