SRA2060HC0G
SRA2060HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 60V 20A TO220AC
SRA2060HC0G 数据手册
SRA2020 – SRA20150 Taiwan Semiconductor 20A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC/DC converters PARAMETER VALUE UNIT IF 20 A VRRM 20 - 150 V IFSM 300 A TJ MAX 125, 150 °C Package TO-220AC Configuration Single die MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.90g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SRA 2020 SRA 2020 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device SRA 2030 SRA 2030 30 SRA 2040 SRA 2040 40 SRA 2050 SRA 2050 50 SRA 2060 SRA 2060 60 21 28 35 42 SRA SRA SRA UNIT 2090 20100 20150 SRA SRA SRA 2090 20100 20150 90 100 150 V 63 70 105 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 20 A IFSM 300 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: K2103 SRA2020 – SRA20150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 1.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRA2020 SRA2030 SRA2040 SRA2050 SRA2060 SRA2090 SRA20100 SRA20150 SRA2020 SRA2030 SRA2040 SRA2050 SRA2060 SRA2090 SRA20100 SRA20150 SRA2020 SRA2030 SRA2040 SRA2050 SRA2060 SRA2090 SRA20100 SRA20150 SRA2020 SRA2030 SRA2040 SRA2050 SRA2060 SRA2090 SRA20100 SRA20150 IF = 20A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.92 V - 1.02 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRA20x TO-220AC 50 / Tube SRA20xH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRA2020) to 150V(SRA20150) 2. “H” means AEC-Q101 qualified 2 Version: K2103 SRA2020 – SRA20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRA2050-SRA20150 20 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 24 16 12 SRA2020-SRA2040 8 1000 4 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) 1 TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 100 10 SRA2050-SRA2060 1 UF1DLW SRA2020-SRA2040 10 TJ=125°C TJ=25°C 0.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.01 SRA2090-SRA20150 0.001 0.1 0.5 0.20.3 0.30.4 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 0.6 0.5 0.7 0.6 0.8 0.7 0.9 0.8 10.9 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 350 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 300 250 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 SRA2020 – SRA20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: K2103 SRA2020 – SRA20150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 SRA2020 – SRA20150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
SRA2060HC0G 价格&库存
很抱歉,暂时无法提供与“SRA2060HC0G”相匹配的价格&库存,您可以联系我们找货
