S10KCHM6G
S10KCHM6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE GEN PURP 800V 10A DO214AB
S10KCHM6G 数据手册
S10GC – S10MC Taiwan Semiconductor 10A, 400V - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Low forward voltage drop Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 10 A VRRM 400 - 1000 V IFSM 250 A TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.270g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S10GC S10JC S10KC S10MC UNIT S10GC S10JC S10KC S10MC Repetitive peak reverse voltage VRRM 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 10 A IFSM 250 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2102 S10GC – S10MC Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 10 °C/W Junction-to-ambient thermal resistance RӨJA 47 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 10A, TJ = 25°C (2) Junction capacitance TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 1 µA - 250 µA 60 - pF IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S10xC DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 400V(S10GC) to 1000V(S10MC) 2 Version: D2102 S10GC – S10MC Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Maximum Non-Repetitive Forward Surge Current 300 PEAK FORWARD SURGE CURRENT (A) 10 5 0 0 25 50 75 100 125 8.3ms single half sine wave 250 200 150 100 50 0 150 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 TJ=125°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 100 NUMBER OF CYCLES AT 60 Hz Fig.3 Typical Reverse Characteristics 10 10 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 10 1 UF1DLW TJ=125°C TJ=125°C TJ=25°C 0.1 1 (A) AVERAGE FORWARD CURRENT (A) 15 TJ=25°C 0.01 0.1 0.001 0.4 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.6 0.4 0.5 0.8 0.6 0.7 1.0 0.8 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) 3 Version: D2102 1.2 S10GC – S10MC Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: D2102 S10GC – S10MC Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2102
S10KCHM6G 价格&库存
很抱歉,暂时无法提供与“S10KCHM6G”相匹配的价格&库存,您可以联系我们找货
