ASNT8051-PQB
ASNT8051-PQB
    ADSANTEC(先进科技)
    VFQFN-40
    PROGRAMBL PLL W/ INTEGRATED VCOS
ASNT8051-PQB 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT8051-PQB 9.9-12.1GHz and 11-12.9GHz Programmable PLL with integrated VCOs nc vee vee phs2 phs1 nc vcc clop vcc clon vcc vcc vcc chop vcc chon ASNT8051 vcc vcc 1 vee off12g offpll ftr1n vee ftr1p vcc loln vcc offcho cen vee vcc offecl cep cr16n vcc cr16p Rev. 1.5.2 vcc vcc vecl Programmable clock multiplier (CMU) with two selectable frequency ranges of internal PLL Optional operational mode as a clock divider with PLL disabled Closed-Loop SSB phase noise at 10MHz offset better than 98dB/Hz On-chip Loss-of-Lock control circuit External RC loop filter LVDS, CML, or PECL input reference clock interface Full-rate CML clock input interface Full-rate or half-rate CML clock output interface LVDS divided clock output with optional 90°-step phase adjustment Single +3.3V power supply Low power consumption of 570mW Fabricated in SiGe for high performance, yield, and reliability Standard 40-pin QFN package vee              February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION ce offpll off12g loln ftr1p ftr1n vecl cr16 offecl offcho HS CIB PLL /16 LS CIB CPR phs1 phs2 LS COB clo HS COB cho C2 ref C Fig. 1. Functional Block Diagram ASNT8051-PQB is a clock multiplication unit (CMU) with a dual-range phase-locked loop (PLL) incorporating high-speed voltage-controlled oscillators (VCOs). The part features several control functions shown in Table 1. All functions are further described in the specified sections. Table 1. PLL Control Functions Control Logic State Described signal in. Not connected (default) “0” “1” Higher VCO range Same as 0 state Lower VCO range PLL off12g Full-rate HS output clock Half-rate HS output clock HS COB disabled HS COB offcho See Table 4 CPR phs1/phs2 PLL enabled Same as 0 state PLL disabled PLL offpll CML/PECL input interface Same as 1 state LVDS input interface LS CIB offecl One of the two frequency ranges can be selected by the control signal off12g. In the main operational mode, the IC shown in Fig. 1 accepts a low-speed reference clock cr16p/cr16n with the frequency f/16 and converts it into a high-speed output clock cho with the selectable frequency f or f/2 and a low-speed output clock clo with the frequency f/16. The frequency of the high-speed clock is selected through the external 3-state control signal offcho that can also disable the clock output buffer. One of four 90° shifted phases of the low-speed output clock with the frequency f/16 can be selected by control signals phs1 and phs2. When operating in the closed-loop mode, the PLL requires an external loop filter connected to pins ftr1p and ftr1n. The output signal loln indicates the locked or unlocked state of the PLL. The PLL also supports an open-loop mode of operation with its selected VCO controlled externally by voltages applied to the filter pins ftr1p and ftr1n. The chip can operate as a divider by 16 of the input high-speed clock cep/cen if the PLL is disabled by the control signal offpll. Rev. 1.5.2 2 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The IC uses a single +3.3V power supply and is characterized for operation from −25°C to 125°C of junction temperature. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process an external clock signal cep/cen with frequencies from DC to the specified maximum value. The clock inputs support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination. In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. LS CIB The Low-Speed Clock Input Buffer (LS CIB) is a proprietary universal input buffer (UIB) that can run at a high frequency. The UIB’s input termination impedance is controlled by the CMOS signal offecl and is set to 100Ohm differential if offecl=”1” (true LVDS mode, default state) or 50Ohm single-ended to vecl if offecl=”0” (CML mode). The value of vecl should be equal to vcc in CML mode. It can be also set to vcc-2V in order to support the PECL interface. In this case, the corresponding termination voltage source should be able to both sink and source up to 20mA of current. Possible input clock application schemes are detailed in Table 2, where Vcm is the common-mode voltage of the clock signal. Table 2. LS Input Clock Application Schemes Interface type LVDS (offecl =1) CML or PECL (offecl =0) Clock cr16p signal type Swing, mV Connection Vcm, V Diff. 70-to-500 DC 1.2±1.0 SE 140-to-900 AC Threshold DC vee-to-vcc Diff. 70-to-500 DC vcc-Swing/2 AC SE 140-to-900 AC 140-to-900 AC Not connected Threshold DC vcc Swing, mV 70-to-500 Threshold 140-to-900 70-to-500 Threshold 140-to-900 140-to-900 cr16n signal Connection Vcm, V DC 1.2±1.0 DC vee-to-vcc AC DC vcc-Swing/2 AC Not connected DC vcc AC AC - As can be seen, the UIB is designed to accept differential signals with DC common mode voltages between the negative (vee) and the positive (vcc) supply rails, as well as AC common mode noise with a frequency up to 5MHz and voltage levels from vee to vee+2.4V. It can also receive single-ended signals with a threshold voltage between vee and vcc applied to the unused pin of the differential input interface. PLL The PLL contains a phase frequency detector, a charge pump, an on-chip integrator with an additional offchip filter connected between pins ftr1p and ftr1n, and two selectable LC-tank VCOs with different central frequencies. The recommended parameters of the external filter schematic components shown in Fig. 2 are for reference only and can be modified based on specific requirements. Rev. 1.5.2 3 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. External Filter Schematic The PLL is activated by the external control signal offpll=”0” (default state). In case of offpll=”1”, the PLL is disabled and the chip operates as a divider by 16. The main function of the PLL is to synthesize the full-rate clock C by aligning the phase and frequency of the divided clock from the internal divider to the externally applied reference clock cr16. Selection of the required VCO is defined by the CMOS control signal off12g (lower-speed VCO if off12g=”1”; higherspeed VCO if off12g=”0”, default state). The state of the PLL is indicated by the output CMOS loss-oflock alarm signal loln (loln=”0” if PLL is not locked, loln=”1” if phases and frequencies of internal and reference clocks are matching). If required, the selected VCO can be externally controlled by voltages applied to pins ftr1p and ftr1n as shown in Table 3. In this case, the PLL is operating in the open-loop mode. The unused VCO is completely disabled in order to save power. Table 3. VCO External Control Modes ftr1p signal, V Vccm+0.8=3.1 Vccm-0.8=1.5 Vccm=2.3 Vccm=2.3 ftr1n signal, V VCO frequency Vccm=2.3 min Vccm=2.3 max Vccm+0.8=3.1 max Vccm-0.8=1.5 min Divider-by-16 The Divider-by-16 (/16) includes 4 divide-by-2 circuits connected in series. The clocks divided by 8 and 16 are supplied to the PLL’s phase detector and to the clock processor CPR. CPR The clock processor (CPR) receives divided by 16 clocks from the divider and supplies the processed signal to the low-speed clock output buffer LS COB. The phase of the delivered divided-by-16 clock C16 can be altered utilizing the CMOS control pins phs1 and phs2 as shown in Table 4. Table 4. Output Clock Phase Selection phs1 phs2 C16 phase vee (default) vee (default) 0° 90° vee vcc 180° vcc vee 270° vcc vcc Rev. 1.5.2 4 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS COB The High Speed Clock Output Buffer (HS COB) receives full-rate (C) and half-rate (C2) clocks from the PLL and converts the selected one into CML output signal cho. The state of the buffer is controlled by the external CMOS control signal offcho (disabled if offcho=”1”; C2 output if offcho is not connected, default state; C output if offcho=”0”). LS COB The LVDS Low-Speed Clock Output Buffer (LS COB) converts the signal from the CPR into the LVDS output signal clo. The proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at frequencies up to 2.0GHz with a low power consumption level of 30mW. The buffer satisfies all requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. For the correct operation, it requires external differential 100Ohm DC termination at the receiver side. These pins should NEVER be CONNECTED to devices with 50Ohm termination to ground WITHOUT DC BLOCKS! ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 5 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 5. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.5.2 Min Max 3.6 0.63 1.0 +90 +100 98 98 -40 10 10 5 Units V W V ºC ºC % % February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type cep cen chop chon 14 13 17 16 cr16p cr16n clop clon 1 2 20 19 offecl offcho off12g offpll phs2 phs1 ftr1p ftr1n loln 3 5 9 11 24 25 7 8 6 Name vcc vee nc Rev. 1.5.2 DESCRIPTION High-Speed I/Os Input CML differential external clock inputs with internal SE 50Ohm termination to vcc Output CML differential clock outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Low-Speed I/Os Input LVDS/CML clock inputs. See LS CIB for allowed application schemes Output LVDS clock outputs. See LS COB for a detailed description Input Controls 3.3V CMOS control signals Input Pins for connecting the external loop filter. Can be also used for VCO external control in the open-loop mode Output 3.3V CMOS control output Supply and Termination Voltages Description Pin Number Positive power supply (+3.3V ) 12, 15, 18, 27, 28, 29, 31, 32, 33, 34, 35, 36, 37, 38, 39 External ground (0V ) 4, 10, 22, 23, 30, 40 Not connected pins 21, 26 6 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER TYP MAX UNIT COMMENTS General Parameters 0.0 V External ground vee 3.1 3.3 3.5 V ±6% vcc Ivcc 165 180 mA Power consumption 570 mW Junction temperature -40 25 125 °C HS Input Clock (cep/cen) Frequency DC 17 GHz Swing 220 800 mV Differential or SE, p-p, at 17GHz 50 800 mV Differential or SE, p-p, at 4GHz CM Voltage Level vcc-0.8 vcc V Must match for both inputs Duty Cycle 40% 50% 60% LS Input Clock (cr16p/cr16n) Frequency DC 810 MHz Swing 140 900 mV Differential or SE, p-p CM Voltage Level vee 1.6 vcc V Must match for both inputs HS Output Clock (chop/chon) Frequency DC 17 GHz Logic “1” level V vcc Logic “0” level vcc-0.58 V Jitter 6 ps Peak-to-peak at 12.5GHz Duty Cycle 50% LS Output Clock (clop/clon) Frequency DC 1060 MHz Interface LVDS Meets the IEEE Std. CMOS control inputs and outputs (offecl, offcho, off12g, offpll, oncml, phs1, phs2, loln) Logic “1” level vcc-0.3 V Logic “0” level vee+0.3 V VCOs Low frequency of VCO 1 11.0 GHz Higher-speed VCO. Active if off12g =”0” High frequency of VCO 1 12.9 GHz Low frequency of VCO 2 9.9 GHz Lower-speed VCO. Active if off12g =”1” High frequency of VCO 2 12.1 GHz External control common 2.3 V In the open-loop mode mode vccm External control voltage vccm-0.8 vccm+0.8 V In the open-loop mode range Rev. 1.5.2 MIN 7 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION The chip is packaged in a standard 40-pin QFN package shown Fig. 3. It is recommended that the center heat slug located on the back side of the package is soldered to the vee plain that is ground for the positive supply. The part’s identification label is ASNT8051-PQB. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. ASNT8051 Fig. 3. Package Drawing Rev. 1.5.2 8 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.5.2 1.4.2 1.4.1 1.3.1 1.2.1 Date 02-2020 07-2019 08-2015 05-2013 03-2013 1.1 1.0 05-2012 04-2012 Rev. 1.5.2 Changes Updated Package Information Updated Letterhead Updated Fig. 2 External Filter Schematic Corrected clock names in Table 2 Revised title Corrected description Corrected electrical characteristics Updated format Corrected supply information First release 9 February 2020
ASNT8051-PQB
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考芯片手册。
4. 参数特性:工作电压为2.0V至3.6V,工作频率可达72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(如UART、SPI、I2C)等多种功能模块。
6. 应用信息:适用于工业控制、医疗设备、消费电子等多种应用场景。
7. 封装信息:采用LQFP48封装,尺寸为7x7mm。
ASNT8051-PQB 价格&库存
很抱歉,暂时无法提供与“ASNT8051-PQB”相匹配的价格&库存,您可以联系我们找货
