S2A – S2V
Taiwan Semiconductor
2A, 50V - 1400V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1400
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL S2A S2B S2D S2G S2J S2K S2M S2Q S2V UNIT
Marking code on the device
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800 1000 1200 1400
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
V
700
840
980
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: N2102
S2A – S2V
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
16
°C/W
Junction-to-ambient thermal resistance
RӨJA
53
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage
(1)
Reverse current @ rated VR
IF = 2A, TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
VF
1.15
V
1
µA
125
µA
CJ
30
pF
trr
1500
ns
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S2x
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(S2A) to 1400V(S2V)
2
Version: N2102
S2A – S2V
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
3
2
1
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
0.1
150
1
Fig.4 Typical Forward Characteristics
TJ=125°C
10
1
TJ=75°C
0.1
TJ=25°C
0.001
60
80
100
10
10
TJ=125°C
TJ=125°C
TJ=25°C
1 0.1
TJ=25°C
0.01
0.001
0.3
0.1
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
0.01
10
0.4
0.6
0.5
0.6
0.8
0.7
width
PulsePulse
width=300μs
1% duty cycle
0.8
0.9
1
1.1
1
1.2
1.4
FORWARD VOLTAGE (V)
3
Version: N2102
1.2
S2A – S2V
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: N2102
S2A – S2V
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: N2102
S2A – S2V
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: N2102
很抱歉,暂时无法提供与“S2A M4G”相匹配的价格&库存,您可以联系我们找货
