CGHV1F006S
CGHV1F006S
    WOLFSPEED
    VFDFN12
    CGHV1F006S
CGHV1F006S 数据手册
CGHV1F006S 6 W, DC - 15 GHz, 40 V, GaN HEMT Description Cree’s CGHV1F006S is an unmatched, gallium nitride (GaN) high electron mobility transistor (HEMT) designed specifically for high efficiency, high gain and wide bandwidth capabilities. The device can be deployed for L, S, C, X and Ku-Band amplifier applications. The datasheet specifications are based on a C-Band (5.5 - 6.5 GHz) amplifier. Additional application circuits are available for C-Band at 5.8 GHz - 7.2 GHz and X-Band at 7.9 - 8.4 GHz and 8.5 - 9.6 GHz. The CGHV1F006S operates on a 40 volt rail circuit while housed in a 3mm x 4mm, surface mount, dual-flat-no-lead (DFN) package. Under reduced power, the transistor can operate below 40V to as low as 20V VDD, maintaining high gain and efficiency. Package Type: 3x4 DFN PN: CGHV1F006S Typical Performance Over 5.5 - 6.5 GHz (TC = 25˚C), 40 V Parameter 5.5 GHz 6.0 GHz 6.5 GHz Units Small Signal Gain 15.4 16.5 17.8 dB Output Power @ PIN = 28 dBm 38.6 39.3 39.0 dBm Drain Efficiency @ PIN = 28 dBm 55 57 52 % Note: Measured in the CGHV1F006S-AMP application circuit. Pulsed 100 μs 10% duty Features for 40 V in CGHV1F006S-AMP • • • • Up to 15 GHz Operation 8 W Typical Output Power 17 dB Gain at 6.0 GHz 15 dB Gain at 9.0 GHz • • Application circuits for 5.8 - 7.2 GHz, 7.9 - 8.4 GHz, and 8.5 - 9.6 GHz. High degree of APD and DPD correction can be applied Listing of Available Hardware Application Circuits / Demonstration Circuits Application Circuit Operating Frequency Amplifier Class Operating Voltage CGHV1F006S-AMP1 5.85 - 7.2 GHz Class A/B 40 V CGHV1F006S-AMP2 7.9 - 8.4 GHz Class A/B 40 V CGHV1F006S-AMP3 8.5 - 9.6 GHz Class A/B 40 V CGHV1F006S-AMP4 4.9 - 5.9 GHz Class A/B 20 V Large Signal Models Available for ADS and MWO Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 2 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Units Notes Drain-Source Voltage VDSS 120 Volts 25˚C Gate-to-Source Voltage VGS -10, +2 Volts 25˚C Storage Temperature TSTG -65, +150 ˚C Operating Junction Temperature TJ 225 ˚C Maximum Forward Gate Current IGMAX 1.2 mA 25˚C Maximum Drain Current IDMAX 0.95 A 25˚C TS 245 ˚C TC -40, +150 ˚C RθJC 14.5 ˚C/W 1 Soldering Temperature 2 Case Operating Temperature 3,4 Thermal Resistance, Junction to Case5 Notes: 1 Current limit for long term, reliable operation 2 Refer to the Application Note on soldering at wolfspeed.com/rf/document-library 3 Simulated at PDISS = 2.4 W 4 TC = Case temperature for the device. It refers to the temperature at the ground tab underneath the package. The PCB will add additional thermal resistance 5 85˚C The RTH for Cree’s application circuit, CGHV1F006S-AMP, with 31 (Ø11 mil) via holes designed on a 20 mil thick Rogers 5880 PCB, is 3.9°C/W. The total RTH from the heat sink to the junction is 14.5°C/W + 3.9°C/W = 18.4°C/W Electrical Characteristics (TC = 25˚C), 40 V Typical Characteristics Symbol Min. Typ. Max. Units Conditions Gate Threshold Voltage VGS(th) -3.6 -3.0 -2.4 VDC VDS = 10 V, ID = 1.2 mA Gate Quiescent Voltage VGS(Q) – -2.7 – VDC VDS = 40 V, ID = 60 mA Saturated Drain Current2 IDS 0.86 1.2 – A VDS = 6.0 V, VGS = 2.0 V Drain-Source Breakdown Voltage V(BR)DSS 100 – – VDC VGS = -8 V, ID = 1.2 mA DC Characteristics 1 RF Characteristics (TC = 25˚C, F0 = 5.925 GHz unless otherwise noted) 3 Small Signal Gain3,4 G 15.15 17.4 - dB VDD = 40 V, IDQ = 60 mA, PIN = 10 dBm Output Power POUT 37.5 38.7 – dBm VDD = 40 V, IDQ = 60 mA, PIN = 25.5 dBm η 35 52 - % VDD = 40 V, IDQ = 60 mA, PIN = 25.5 dBm VSWR - 10 : 1 - Y No damage at all phase angles, VDD = 40 V, IDQ = 60 mA, PIN = 25.5 dBm CGS – 1.3 – pF VDS = 40 V, Vgs = -8 V, f = 1 MHz Output Capacitance CDS – 0.31 – pF VDS = 40 V, Vgs = -8 V, f = 1 MHz Feedback Capacitance CGD – 0.04 – pF VDS = 40 V, Vgs = -8 V, f = 1 MHz 3,4 Drain Efficiency 3,4 Output Mismatch Stress4 Dynamic Characteristics Input Capacitance5 5 Notes: 1 Measured on wafer prior to packaging 2 Scaled from PCM data 3 Measured in Cree’s production test fixture. This fixture is designed for high volume testing at 5.925 GHz 4 Unmodulated Pulsed Signal 100 μs, 10% duty cycle 5 Includes package Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 3 Electrical Characteristics When Tested in CGHV1F006S-AMP1 at C-Band Under OQPSK Characteristics Symbol Min. Typ. Max. Units Conditions RF Characteristics1 (TC = 25˚C, F0 = 5.8 - 7.2 GHz unless otherwise noted) Gain G – 17.5 – dB VDD = 40 V, IDQ = 60 mA, PIN = 0 dBm Output Power2 POUT – 39 – dBm VDD = 40 V, IDQ = 60 mA, PIN = 27 dBm Drain Efficiency2 η – 55 – % VDD = 40 V, IDQ = 60 mA, PIN = 27 dBm OQPSK3 ACLR – -36 – dBc VDD = 40 V, IDQ = 60 mA, POUT = 33 dBm Output Mismatch Stress2 VSWR – 10:1 – Y No damage at all phase angles, VDS = 40 V, IDQ = 60 mA Notes: 1 Measured in CGH1F006S-AMP1 Application Circuit 2 Pulsed 100 μs, 10% duty cycle 3 OQPSK modulated signal, 1.6 msps, PN23, Alpha Filter = 0.2 Offset = 1.6 MHz Typical Performance - CGHV1F006S-AMP1 at C-Band Under OQPSK Figure 1. Typical Small Signal Response of CGHV1F006S-AMP1 Application Circuit VDD = 40 V, IDQ = 60 mA 30 Magnitude (dB) Magnitude (dB) 20 10 0 -10 -20 S11 S21 S22 -30 5.0 5.5 6.0 6.5 Frequency (GHz) 7.0 7.5 8.0 Frequency (GHz) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 4 Typical Performance in Application Circuit CGHV1F006S-AMP1 Figure 2. Typical Gain, Efficiency and OQPSK Performance vs Frequency POUT = 33 dBm. VDD = 40 V, IDQ = 60 mA CGHV1F006S OQPSK Performance at 33dBm 40 0 Efficiency Gain 30 -10 25 -15 20 -20 Gain 15 -25 10 -30 OQPSK Offset (dBc) Gain (dB) and Efficiency (%) Gain (dB) and Efficiency (%) -5 Efficiency Offset OQPSK Offset (dBc) 35 Offset 5 0 -35 5.8 6.0 6.2 6.4 6.6 Frequency (GHz) 6.8 7.0 7.2 -40 Frequency (GHz) CGHV1F006S OQPSK Transfer @ 7.2GHz Figure 3. Typical Gain, Efficiency and OQPSK Performance vs Input Power OQPSK Transfer Frequency = 7.2 GHz, VDD = 40 V, IDQ = 60 mA 35 -15 DEff 30 -20 Gain_ Gain Gain(dB) (dB) Efficiency(%) (%) Efficiency 25 +Oset_ 20 -25 Efficiency -30 Gain 15 -35 Offset 10 -40 5 -45 0 10 15 20 25 30 35 OQPSK Offset (dBc) OQPSK Offset (dBc) -Oset_ -50 InputPower Power (dBm) Input (dBm) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 5 Typical Performance in Application Circuit CGHV1F006S-AMP1 Drain Efficiency (%) Output Power (dBm) Figure 4. Typical Pulsed Power Response VDD = 40 V, IDQ = 60 mA, 100 μs, 10% Duty, PIN = 27 dBm Frequency (GHz) CGHV1F006S-AMP1 Application Circuit Bill of Materials, OQPSK CGHV1F006S-AMP1 Application Circuit Designator Description Qty R1 RES, 15, OHM, +1/-1%, 1/16 W, 0402 1 R2 RES, 100, OHM, +1/-1%, 1/16 W, 0603 1 C1, C14 CAP, 1.8 pF, ±0.1 pF, 0603, ATC 2 C2 CAP, 2.0 pF, ±0.1 pF, 0402, ATC 1 C3, C8 CAP, 1.5 pF, ±0.1 pF, 0402, ATC 2 C4 CAP, 10 pF, ±5%, 0603, ATC 1 C5, C10 CAP, 470 pF, 5%, 100 V, 0603, X 2 C6, C11 CAP, 33000 pF, 0805, 100V, X7R 2 C7 CAP, 10 UF, 16 V, TANTALUM 1 C9 CAP, 20 pF, ±5%, 0603, ATC 1 C12 CAP, 1.0 UF, 100V, 10% X7R, 1210 1 C13 CAP, 33 UF, 20%, G CASE 1 J1, J2 CONN, SMA, PANEL MOUNT JACK, FLANGE 2 PCB, RT5880, 0.020” THK, CGHV1F006S 1 J3 HEADER RT>PLZ .1CEN LK 5POS 1 Q1 QFN TRANSISTOR CGHV1F006S 1 Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 6 CGHV1F006S-AMP1 Application Circuit Schematic, OQPSK Vg=-2.0V to -3.5V typ GND Vd=+40V 5 C7 10 C6 0.033 C5 470 pF C4 10 pF R2 100 Ohm C1 1.8 pF 4 3 2 1 J3 C8 C9 C11 C10 1.5 pF 20 pF 470 pF 0.033 C3 1.5 pF C12 1 C13 33 C14 1.8 pF R1 15 Ohm Q1 2 J2 1 J1 C2 2.0 pF 3 CGHV1F006S-AMP1 Application Circuit Outline, OQPSK Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 7 Electrical Characteristics When Tested in CGHV1F006S-AMP2 at X-Band, SATCOM Characteristics Symbol Min. Typ. Max. Units Conditions RF Characteristics (TC = 25˚C, F0 = 7.9 - 8.4 GHz unless otherwise noted) 1 Gain G – 15 - dB VDD = 40 V, IDQ = 60 mA, PIN = 0 dBm Output Power2 POUT – 39 – dBm VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm Drain Efficiency2 η – 55 - % VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm OQPSK3 ACLR – -37 dBc VDD = 40 V, IDQ = 60 mA, POUT = 33 dBm Output Mismatch Stress2 VSWR – 10 : 1 Y No damage at all phase angles, VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm – Notes: 1 Measured in CGHV1F006S-AMP2 Application Circuit 2 Pulsed 100 μs, 10% duty cycle 3 OQPSK modulated signal, 1.6 msps, PN23, Alpha Filter = 0.2 Offset = 1.6 MHz Typical Performance in Application Circuit CGHV1F006S-AMP2 at X-Band, SATCOM Figure 5. Typical Small Signal Response of CGHV1F006S-AMP2 Application Circuit VDD = 40 V, IDQ = 60 mA 30 Magnitude (dB) Magnitude (dB) 20 10 0 -10 S21 -20 S11 S22 -30 7.0 7.2 7.4 7.6 7.8 8.0 8.2 8.4 8.6 8.8 9.0 Frequency (GHz) Frequency (GHz) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 8 Typical Performance in Application Circuit CGHV1F006S-AMP2 Figure 6. Typical OQPSK Response VDD = 40 V, IDQ = 60 mA, 1.6 MSPS, POUT = 33 dBm -30 35 -31 Drain Efficiency -32 Gain 25 -33 Drain Efficiency 20 -34 ACLR Gain 15 -35 10 -36 ACL 5 0 7.90 7.95 8.00 8.05 8.10 8.15 8.20 ACLR (dBc) 30 ACLR (dBc) Gain (dB) & Drain Efficiency (%) Gain (dB) & Drain Efficiency (%) 40 -37 8.25 8.30 8.35 -38 8.40 Frequency (GHz) Frequency (GHz) Typical Performance in Application Circuit CGHV1F006S-AMP2 Figure 7. OQPSK Transfer Response VDD = 40 V, IDQ = 60 mA, 1.6 MSPS, Frequency = 8.4 GHz 35 -10 Gain 30 -15 Eff +Oset -20 -25 15 -30 10 -35 5 -40 0 15 20 25 30 Output Power (dBm) 35 40 OQPSK Offset (dBc) 20 OQPSK Offset (dBc) Gain (dB) and Drain Efficiency (%) Gain (dB) & Drain Efficiency (%) -Oset 25 -45 Output Power (dBm) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 9 Typical Performance in Application Circuit CGHV1F006S-AMP2 Figure 8. Typical Pulsed Power Response VDD = 40 V, IDQ = 60 mA, 100 μs, 10% Duty, PIN = 28 dBm 40.0 75 Output Power 39.5 70 38.5 60 Drain Efficiency 38.0 55 37.5 50 37.0 45 Output Power 36.5 36.0 7.80 Drain Efficiency 7.90 8.00 8.10 8.20 Frequency (GHz) 8.30 8.40 Drain Efficiency (%) 65 Drain Efficiency (%) Output Power (dBm) Output Power (dBm) 39.0 40 35 8.50 Frequency (GHz) CGHV1F006S-AMP2 Application Circuit Bill of Materials, SATCOM CGHV1F006S-AMP2 Application Circuit Designator Description Qty R1 RES, 15, OHM, +1/-1%, 1/16 W, 0402 1 R2 RES, 100, OHM, +1/-1%, 1/16 W, 0603 1 C3, C8 CAP, 1.0pF, ±0.05 pF, 0402, ATC 2 C14 CAP, 1.0pF, ±5%, 0603, ATC 1 C1 CAP, 1.2pF, ±5%, 0603, ATC 1 C2 CAP, 1.6pF, ±5%, 0402, ATC 1 C4 CAP, 10pF, ±5%, 0603, ATC 1 C5, C10 CAP, 470pF, 5%, 100V, 0603, X 2 C6,C11 CAP, 33000pF, 0805, 100V, X7R 2 C7 CAP, 10 UF, 16 V, TANTALUM 1 C9 CAP, 20 pF, ±5%, 0603, ATC 1 C12 CAP, 1.0 UF, 100V, 10% X7R, 1210 1 C13 CAP, 33 UF, 20%, G CASE 1 J1, J2 CONN, SMA, PANEL MOUNT JACK, FLANGE 2 PCB, RT5880, 0.020” THK, CGHV1F006S 1 BASEPLATE, AL, 2.60 X 1.70 X 2.50 1 HEADER RT>PLZ .1CEN LK 5POS 1 2-56 SOC HD SCREW 1/4 SS 4 #2 SPLIT LOCKWASHER SS 4 QFN TRANSISTOR CGHV1F006S 1 J3 Q1 Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 10 CGHV1F006S-AMP2 Application Circuit Schematic, SATCOM CGHV1F006S-AMP2 Application Circuit Outline, SATCOM Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 11 Electrical Characteristics When Tested in CGHV1F006S-AMP3 at X-Band, RADAR Characteristics Symbol Min. Typ. Max. Units Conditions RF Characteristics (TC = 25˚C, F0 = 8.5 - 9.6 GHz unless otherwise noted) 1 Gain G – 14.5 - dB VDD = 40 V, IDQ = 60 mA, PIN = 0 dBm Output Power POUT – 38.5 – dBm VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm Drain Efficiency2 η – 52 - % VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm Output Mismatch Stress2 VSWR – 10 : 1 – Y VDD = 40 V, IDQ = 60 mA, PIN = 28 dBm 2 Notes: 1 Measured in CGHV1F006S-AMP3 Application Circuit 2 Pulsed 100 μs, 10% duty cycle Typical Performance in Application Circuit CGHV1F006S-AMP3 at X-Band, RADAR Figure 9. Typical Small Signal Response VDD = 40 V, IDQ = 60 mA 30 Magnitude (dB) Magnitude (dB) 20 10 0 -10 -20 S21 S11 S22 -30 7.5 8.0 8.5 9.0 Frequency (GHz) 9.5 10.0 10.5 Frequency (GHz) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 12 Typical Performance in Application Circuit CGHV1F006S-AMP3 Figure 10. Typical Pulsed Power Response VDD = 40 V, IDQ = 60 mA, 100 μs, 10% Duty, PIN = 28 dBm 40.0 75 39.5 70 65 38.5 60 38.0 55 Drain Efficiency 37.5 50 37.0 45 36.5 Drain Efficiency (%) Output Power Drain Efficiency (%) Output Power (dBm) Output Power (dBm) 39.0 40 Output Power Drain Efficiency 36.0 8.4 8.6 8.8 9.0 Frequency (GHz) 9.2 9.4 9.6 35 Frequency (GHz) CGHV1F006S-AMP3 Application Circuit Bill of Materials, RADAR CGHV1F006S-AMP3 Application Circuit Designator Description Qty R1 RES, 15, OHM, +1/-1%, 1/16 W, 0402 1 R2 RES, 100, OHM, +1/-1%, 1/16 W, 0603 1 C1, C14 CAP, 1.0 pF, ±0.05 pF, 0603, ATC 2 C2 CAP, 1.0 pF, ±0.05 pF, 0402, ATC 1 C3, C8 CAP, 0.8 pF, ±0.05 pF, 0402, ATC 2 C4 CAP, 10 pF, ±5%, 0603, ATC 1 C5, C10 CAP, 470 pF, 5%, 100 V, 0603, X 2 C6, C11 CAP, 33000 pF, 0805, 100V, X7R 2 C7 CAP, 10 UF, 16 V, TANTALUM 1 C9 CAP, 20 pF, ±5%, 0603, ATC 1 C12 CAP, 1.0 UF, 100V, 10% X7R, 1210 1 C13 CAP, 33 UF, 20%, G CASE 1 J1, J2 CONN, SMA, PANEL MOUNT JACK, FLANGE 2 J3 HEADER RT>PLZ .1CEN LK 5POS 1 Q1 QFN TRANSISTOR CGHV1F006S 1 Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 13 CGHV1F006S-AMP3 Application Circuit Schematic, RADAR Vg=-2.0V to -3.5V typ GND Vd=+40V 5 C7 10 C6 0.033 C5 470 pF C4 10 pF R2 100 Ohm 4 3 2 1 J3 C8 C9 C11 C10 1.0 pF 20 pF 470 pF 0.033 C3 1.0 pF C13 33 C14 1.0 pF R1 15 Ohm C1 1.0 pF C12 1 Q1 2 J2 1 J1 C2 1.0 pF 3 5 4 3 2 1 CGHV1F006S-AMP3 Application Circuit Outline, RADAR Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 14 Electrical Characteristics When Tested in CGHV1F006S-AMP4 at 802.11 Characteristics Symbol Min. Typ. Max. Units Conditions RF Characteristics1 (TC = 25˚C, F0 = 4.9 - 5.9 GHz unless otherwise noted) Gain G – 13 - dB VDD = 20 V, IDQ = 30 mA, PIN = 27 dBm Drain Efficiency2 η – 27 - % VDD = 20 V, IDQ = 30 mA, PIN = 27 dBm OQPSK3 ACLR - -43 - dBc VDD = 20 V, IDQ = 30 mA, POUT = 27 dBm Output Mismatch Stress2 VSWR – 10 : 1 – Y No damage at all phase angles, VDD = 20 V, IDQ = 30 mA, PIN = 27 dBm Notes: 1 Measured in CGHV1F006S-AMP4 Application Circuit 2 Single carrier WCDMA, 3GPP Test Model 1, G4 DPCH, 45% clipping, PAR = 7.5 dB @ 0.01% probability on CCDF Typical Performance - CGHV1F006S-AMP4 at 802.11 Figure 11. Typical Small Signal Response Figure 11. - Typical Small Signal Response VVDD = 20 V, IDQ= =3030 mA DD = 20 V, IDQ mA 15 10 Magnitude (dB) Magnitude (dB) 5 0 -5 -10 S11 -15 S21 S22 -20 4 4.25 4.5 4.75 5 5.25 5.5 Frequency (GHz) 5.75 6 6.25 6.5 Frequency (GHz) Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 15 Typical Performance in Application Circuit CGHV1F006S-AMP4 Figure 12. Typical Gain, Efficiency and WCDMA Performance vs Frequency VDD = 20 V, IDQ = 30 mA, POUT = 27 dBm 40 -37 Gain -38 Drain Efficiency 30 ACLR -39 Drain Efficiency -40 ACLR 20 -41 15 -42 Gain 10 -43 5 -44 0 4.9 5.0 5.1 5.2 5.3 5.4 5.5 5.6 5.7 5.8 5.9 ACLR (dBc) 25 ACLR (dBc) Gain (dB) & Drain Efficiency (%) Gain (dB) & Drain Efficiency (%) 35 -45 Frequency (GHz) Frequency (GHz) CGHV1F006S-AMP4 Application Circuit Bill of Materials at 802.11 CGHV1F006S-AMP4 Application Circuit Designator Description Qty R1, R3 RES, 1, OHM, +/-1%, 1/16 W, 0402 2 R2 RES, 51.1, OHM, +/-1%, 1/16W, 0603 1 C2, C6, C11 CAP, 1.8 pF, +/-0.1 pF, 0603, ATC 3 C1 CAP, 0.2 pF, +/-0.05 pF, 0402, ATC 1 C3, C7, C12 CAP, 470 pF, 5%, 100 V, 0603, X 3 C4, C8, C13 CAP, 33000 pF, 0805, 100 V, X7R 3 C5 CAP, 10 UF, 16 V, TANTALUM 1 C15 CAP, 6.8 pF, ±0.25 pF, 100 V, 0603 1 C9, C14 CAP, 1.0 UF, 100V, 10% X7R, 1210 2 C10 CAP, 33 UF, 20%, G CASE 1 J1, J2 CONN, SMA, PANEL MOUNT JACK, FLANGE 2 PCB, RO4350B, 0.020” THK, CGHV1F006S 1 BASEPLATE, CGH35015, 2.60 X 1.7 1 HEADER RT>PLZ .1CEN LK 5POS 1 2-56 SOC HD SCREW 1/4 SS 4 #2 SPLIT LOCKWASHER SS 4 QFN TRANSISTOR CGHV1F006S 1 J3 Q1 Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 16 CGHV1F006S-AMP4 Application Circuit Schematic CGHV1F006S-AMP4 Application Circuit Outline Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 17 CGHV1F006S Power Dissipation De-rating Curve Figure 13. CGHV1F006S Transient Power Dissipation De-Rating Curve 12 Power Dissipation (W) Power dissipation (W) 10 8 Note 1 6 4 2 0 0 25 50 75 100 125 150 175 200 225 250 Maximum CaseTemperature ( C) Maximum Case Temperature (˚C) Note 1. Area exceeds Maximum Case Temperature (See Page 2) Electrostatic Discharge (ESD) Classifications Parameter Symbol Class Test Methodology Human Body Model HBM 1B (≥ 500 V) JEDEC JESD22 A114-D Charge Device Model CDM II (≥ 200 V) JEDEC JESD22 C101-C Moisture Sensitivity Level (MSL) Classification Parameter Symbol Level Test Methodology Moisture Sensitivity Level MSL 3 (168 hours) IPC/JEDEC J-STD-20 Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 18 Source and Load Impedances D Z Source Z Load G S Rev 5.7 – May 2021 Frequency (GHz) Z Source Z Load 1 49.67 + j32.81 184.11 + j6.66 3 11.54 + j3.96 38.83 + j56.37 6 5.94 - j17.97 13.03 + j16.16 10 11.87 - j77.62 11.79 - j17.43 12 47.42 - j205.35 16.39 - j46.22 15 33.78 + j251.03 163.61 - j268.44 Note 1. VDD = 40 V, IDQ = 60 mA Note 2. Impedances are extracted from source and load pull data derived from the transistor 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 19 Product Dimensions CGHV1F006S (Package 3 x 4 DFN) Pin Input/Output 1 GND 2 NC 3 RF IN 4 RF IN 5 NC 6 GND 7 GND 8 NC 9 RF OUT 10 RF OUT 11 NC 12 GND Note: Leadframe finish for 3x4 DFN package is Nickel/Palladium/Gold. Gold is the outer layer Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 20 Part Number System CGHV1F006S Package Power Output (W) Upper Frequency (GHz) Cree GaN High Voltage Table 1. Parameter Value Units Upper Frequency1 15.0 GHz Power Output 6 W Package Surface Mount - Note1: Alpha characters used in frequency code indicate a value greater than 9.9 GHz. See Table 2 for value. Table 2. Rev 5.7 – May 2021 Character Code Code Value A 0 B 1 C 2 D 3 E 4 F 5 G 6 H 7 J 8 K 9 Examples: 1A = 10.0 GHz 2H = 27.0 GHz 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 21 Product Ordering Information Order Number Description Unit of Measure CGHV1F006S GaN HEMT Each CGHV1F006S-AMP1 Test board with GaN HEMT installed, 5.85 - 7.2 GHz, 50 V C-Band under OQPSK Each CGHV1F006S-AMP2 Test board with GaN HEMT installed, 7.9 - 8.4 GHz, 28 V X-Band SATCOM Each CGHV1F006S-AMP3 Test board with GaN HEMT installed, 8.5 - 9.6 GHz, 28 V X-Band RADAR Each CGHV1F006S-AMP4 Test board with GaN HEMT installed, 4.9 - 5.9 GHz, 50 V 802.11 Each Rev 5.7 – May 2021 Image 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV1F006S 22 For more information, please contact: 4600 Silicon Drive Durham, North Carolina, USA 27703 www.wolfspeed.com/rf Sales Contact rfsales@cree.com Notes & Disclaimer Specifications are subject to change without notice. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. Cree products are not warranted or authorized for use as critical components in medical, life-saving, or life-sustaining applications, or other applications where a failure would reasonably be expected to cause severe personal injury or death. No responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from use of the information contained herein. No license is granted by implication or otherwise under any patent or patent rights of Cree. © 2013 - 2021 Cree, Inc. All rights reserved. Wolfspeed® and the Wolfspeed logo are registered trademarks of Cree, Inc. Rev 5.7 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com
CGHV1F006S 价格&库存
很抱歉,暂时无法提供与“CGHV1F006S”相匹配的价格&库存,您可以联系我们找货
CGHV1F006S
    • 1+1042.57800
    • 250+415.99440
    • 500+402.09480
    • 1000+395.22600
