CRF24010FE
CRF24010FE
    WOLFSPEED
    DO-15(DO204AC)
    FET RF 120V 1.95GHZ 440166
CRF24010FE 数据手册
CRF24010 10 W, SiC RF Power MESFET Cree’s CRF24010 is an unmatched silicon carbide (SiC) RF power MetalSemiconductor Field-Effect Transistor (MESFET). SiC has superior properties compared to silicon or gallium arsenide, including higher breakdown voltage, higher saturated electron drift velocity, and higher thermal conductivity. SiC MESFETs offer greater efficiency, greater power density, and wider bandwidths compared to Si and GaAs transistors. FEATURES Package Type s: 44 PN’s: CRF240 0196 and 440166 10P and CR F24010F APPLICATIONS • 15 dB Small Signal Gain • Wideband Military Communications • High Efficiency • Secure Comms for Homeland Defense • 10 W minimum P1dB • Class A, A/B Amplifiers • Up to 2700 MHz Operation • TDMA, EDGE, CDMA, W-CDMA • 48 V Operation • Broadband Amplifiers • High Breakdown Voltage • MMDS • High Temperature Operation Typical Performance il 2010 Rev 2.0 – Apr • • • Drain Efficiency of 45% at 1950 MHz IMD -31 dBc at 1950 MHz 15 dB Gain at 1950 MHz Note: Measured in amplifier circuit CRF24010-TB at VDS = 48 V, IDQ = 500 mA. Subject to change without notice. www.cree.com/wireless 1 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Units Drain-source Voltage VDSS 120 Volts Gate to source Voltage VGS -20, +3 Volts Storage Temperature TSTG -55, +150 ˚C Operating Junction Temperature TJ 255 ˚C Maximum Forward Gate Current IGMAX 6.0 mA Thermal Resistance, Junction to Case RθJC 5.6 ˚C/W Screw Torque1 T 60 in-oz Soldering Temperature TS 225 ˚C Electrical Characteristics (TC = 25˚C) Characteristics Symbol Min. Typ. Max. Units Conditions Gate Threshold Voltage VGS(th) -12 -10 – VDC VDS = 10 V, ID = 0.5 mA Gate Quiescent Voltage VGS(Q) – -9 – VDC VDS = 48 V, ID = 400 mA Zero Gate Voltage Drain Current IDSS 1.2 1.5 2.1 A VDS = 10 V, VGS = 0 V Drain-Source Breakdown Voltage V(BR)DSS 100 – – VDC VGS = 18, ID = 10 mA Forward Transconductance gm 140 160 – mS VDS = 48 V, ID = 250 mA Case Operating Temperature TC -30 – 125 ˚C Gain GSS 13 15 – dB VDD = 48 V, IDQ = 500 mA, f = 1950 MHz Power Output at 1 dB Compression P1dB 10 12 – W VDD = 48 V, IDQ = 500 mA, f = 1950 MHz Power Output at 3 dB Compression P3dB 15 17 – W VDD = 48 V, IDQ = 500 mA, f = 1950 MHz η 40 45 – % VDD = 48 V, IDQ = 250 mA, f = 1950 MHz POUT = P1dB Intermodulation Distortion IMD3 – -31 – dBc VDD = 48 V, IDQ = 250 mA, f1 = 1950 MHz, f2 = 1950.1 MHz, POUT = 10W PEP Minimum Noise Figure NFmin – 3.1 – dB VDD = 48 V, IDQ = 500 mA, f1 = 1950 MHz Output Mismatch Stress VSWR 10 : 1 – – Y No damage at all phase angles, VDD = 48 V, IDQ = 500 mA, f = 1950 MHz, POUT = 10W CW Input Capacitance CDS – 2.5 – pF VDS = 48 V, VGS = -16 V, f = 1 MHz Output Capacitance CGS – 1.9 – pF VDS = 48 V, VGS = -16 V, f = 1 MHz Reverse Transfer Capacitance CGD – 0.45 – pF VDS = 48 V, VGS = -16 V, f = 1 MHz DC Characteristics RF Characteristics Drain Efficiency2,3 Dynamic Characteristics Notes: 1 Torque for the 440166 package type. 2 Drain Efficiency = POUT / PDC 3 Power Added Efficiency (PAE) = (POUT - PIN) / PDC Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Electrostatic Discharge (ESD) Classifications Parameter Symbol Class Human Body Model HBM 1B Test Methodology JESD22-A114 Charge Device Model CDM C5 JESD22-C101 Typical Broadband Performance 20 45 19 44 18 43 17 42 16 41 15 40 14 39 13 38 12 37 11 36 10 35 9 34 8 33 7 32 6 31 5 1.90 1.95 2.00 2.05 2.10 2.15 2.20 2.25 2.30 2.35 2.40 2.45 2.50 2.55 P1dB (dBm) Gain (dB) Swept P1dB and Gain vs Frequency Performance of CRF24010 in a Broadband Amplifier Circuit VDD = 48 V, IDQ = 500 mA, TC = 25˚C Swept P1dB and Gain for the CRF24010 in a Broadband Test Fixture 30 2.60 Frequency (GHz) Note: The chart on this page displays the performance achievable with the CRF24010 product when a broadband amplifier is designed to operate from 1.7 GHz to 2.1 GHz. Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 3 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Typical Performance Data from the CRF24010-TB Demonstration Amplifier Swept CW Data vs Power at 1950 MHz 43 50 41 45 39 40 37 35 35 30 33 25 31 20 29 15 27 10 25 5 23 η (Drain Efficiency) (%) Pout (dBm) Performance of CRF24010 in Narrowband Amplifier Circuit CRF24010-TB In CRF24010-TB Fixture VDD = 48 V, IDQ = 500 mA, TC = 25˚C, Frequency = 1950 MHz 0 10 12 14 16 18 20 22 24 26 28 30 Pin (dBm) 18 42 17 41 16 40 15 39 14 38 13 37 12 36 11 35 10 34 9 33 8 Output Power at +26 dBm Input (dBm) Small Signal Gain (dB) at +10 dBm Input Swept CW DataSwept vs Frequency Performance CW Data vs Frequency of CRF24010 in a Narrowband Amplifier Circuit CRF24010-TB In CRF24010-TB Fixture VDD = 48 V, IDQ = 500 mA, TC = 25˚C 32 1.7 1.8 1.9 2.0 2.1 Frequency (GHz) Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless CRF-24010/22010-TB CRF24010-TB Demonstration Test Fixture Schematic Schematic (Rev. A) J3 L1 5 C3 C4 C5 C7 C6 C8 1 GND GND V_DD V_DD 1 FAN+ 4 L2 C9 3 2 C10 2 Q1 R1 C1 J1 RF IN V_GG FAN- J4 C2 J2 RF OUT C12 C11 CRF24010-TB Demonstration Test Fixture Bill of Materials Parts List Designator Designator Description C1,C2,C3,C6 CAP, 27pF, 0603, ATC600S270JW250XT 4 CAP, 0.1uF, 25V, 0805, CERAMIC 1 Value C4 Qty Designator R1 39 : 0.1 W, 0805 ChipC5 Resistor L1 C7 HI1206K101RCAP, 2.2nF, 100V, AVX08051C222MAT2A Ferrite, 80 ohms, Steward C4 0.1 uF, 25V, 08051Ceramic Capacitor L2 Ferrite, Murata BLM21P220SG J1, J2 Flange Mount SMA Female C7 2.2 nF, 100V Ceramic Capacitor, AVX 08051C222MAT2A C10 Connector CAP, 33uF, 100V, ALUMINUM ELECTROLYTIC 1 J3 5-pin Molex Male Connector C11 CAP, 3.9pF, 150V, PORCELAIN, ATC- 10 nF, 100V, 0805 Ceramic Capacitor C8 1 100B3R9OBW500X J4 2-pin Molex Male Connector C9 CAP, 2.4pF, 150V, PORCELAIN, ATC- 0.1 uF, 100V, 1206 Ceramic Capacitor 1 100B2R4OBW500X Q1 CRF-22010 C10 RES, 39 OHM, 0.1W, 0805 Substrate L1 h=32 mil Rogers RO4003, Hr=3.38, C8 CAP, 10nF, 100V, 0805, CERAMIC C9 CAP, 0.1uF, 100V, 1206 CERAMIC C12 R1 L2 Heatsink C5 27 pF, 100V Ceramic 1 Capacitor, ATC 12061C104MAT2A 1 10 uF, 25V Tantalum Capacitor 1 33 uF, 100V, Aluminum Electrolytic Capacitor 1 FERRITE, 80 OHM, C11 STEWARD HI1206K101R 1 3.9 pF, 150V Porcelain Capacitor, ATC FERRITE, MURATA BLM21P220SG 100B3R9OBW500X (exact value depends on tuning) 1 J1,J2 2 in long CONNECTOR, SMA,C12 FLANGE MOUNT, FEMALE 2 Thermalloy 74605 Extrusion, 2.4 pF, 150V Porcelain Capacitor, ATC 100B2R4OBW500X (exact value depends on tuning) J3 Fan C1, C2, C3, C6 CAP, 10uF, 25V, TANTALUM Value CONNECTOR, MOLEX, 5-PIN, MALE 1 CONNECTOR, Comair-Rotron FS48B3,J460 mm, 48V, 0.05 A, 18 cfm MOLEX, 2-PIN, MALE 1 Q1 CRF24010 1 Note: Some values may differ due to substitution in the event of temporarily unavailable parts. Note: Some values may differ due to substitution in the event of temporarily unavailable parts Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. © Cree, Inc. 2005 2 5 CRF24010 Rev 2.0 Specifications subject to change without notice http://www.cree.com/ Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless CRF24010-TB Demonstration Test Fixture CRF24010-TB Demonstration Test Fixture Diagram Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 6 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Typical Package S-Parameters (Small Signal, VDS = 48 V, IDQ = 250 mA, magnitude / angle) Frequency S(1,1) S(2,1) S(1,2) S(2,2) 100.0MHz 0.935 / -22.097 7.829 / 165.893 0.024 / 73.361 0.341 / -26.953 200.0MHz 0.920 / -42.676 7.370 / 152.734 0.045 / 62.187 0.356 / -50.854 300.0MHz 0.900 / -60.781 6.758 / 141.088 0.062 / 51.523 0.374 / -70.354 400.0MHz 0.881 / -76.139 6.110 / 131.067 0.074 / 42.232 0.392 / -85.633 500.0MHz 0.865 / -88.933 5.497 / 122.511 0.083 / 34.306 0.407 / -97.471 600.0MHz 0.852 / -99.537 4.950 / 115.167 0.090 / 27.540 0.420 / -106.682 700.0MHz 0.842 / -108.354 4.474 / 108.786 0.095 / 21.708 0.431 / -113.933 800.0MHz 0.834 / -115.739 4.064 / 103.160 0.098 / 16.614 0.441 / -119.725 900.0MHz 0.828 / -121.985 3.712 / 98.128 0.101 / 12.099 0.450 / -124.423 1.000GHz 0.824 / -127.324 3.408 / 93.564 0.103 / 8.043 0.458 / -128.294 1.100GHz 0.821 / -131.937 3.146 / 89.373 0.104 / 4.354 0.466 / -131.533 1.200GHz 0.819 / -135.963 2.917 / 85.485 0.105 / 0.962 0.473 / -134.284 1.300GHz 0.818 / -139.514 2.717 / 81.845 0.106 / -2.188 0.481 / -136.655 1.400GHz 0.818 / -142.674 2.541 / 78.410 0.107 / -5.136 0.488 / -138.729 1.500GHz 0.818 / -145.513 2.385 / 75.148 0.107 / -7.916 0.495 / -140.568 1.600GHz 0.818 / -148.084 2.246 / 72.032 0.107 / -10.553 0.502 / -142.219 1.700GHz 0.818 / -150.432 2.121 / 69.041 0.107 / -13.067 0.509 / -143.721 1.800GHz 0.819 / -152.591 2.009 / 66.159 0.108 / -15.476 0.516 / -145.104 1.900GHz 0.820 / -154.592 1.908 / 63.373 0.108 / -17.792 0.523 / -146.390 2.000GHz 0.821 / -156.457 1.816 / 60.670 0.108 / -20.028 0.530 / -147.598 2.100GHz 0.823 / -158.208 1.733 / 58.043 0.107 / -22.191 0.537 / -148.744 2.200GHz 0.824 / -159.860 1.657 / 55.482 0.107 / -24.290 0.544 / -149.838 2.300GHz 0.826 / -161.428 1.587 / 52.981 0.107 / -26.332 0.550 / -150.892 2.400GHz 0.824 / -162.924 1.523 / 50.536 0.107 / -28.322 0.557 / -151.911 2.500GHz 0.829 / -164.358 1.464 / 48.139 0.107 / -30.265 0.563 /-152.904 2.600GHz 0.831 / -165.738 1.410 / 45.789 0.107 / -32.166 0.569 / -153.875 2.700GHz 0.832 / -167.073 1.360 / 43.479 0.107 / -34.029 0.575 / -154.829 2.800GHz 0.834 / -168.368 1.314 / 41.208 0.106 / -35.856 0.581 / -155.768 2.900GHz 0.836 / -169.630 1.271 / 38.972 0.106 / -37.652 0.587 / -156.696 3.000GHz 0.837 / -170.865 1.231 / 36.767 0.106 / -39.418 0.592 / -157.616 3.100GHz 0.839 / -172.075 1.194 / 34.593 0.106 / -41.158 0.597 / -158.529 3.200GHz 0.841 / -173.266 1.160 / 32.446 0.106 / -42.874 0.602 / -159.437 3.300GHz 0.842 / -174.441 1.127 / 30.323 0.106 / -44.569 0.607 / -160.342 3.400GHz 0.844 / -175.604 1.098 / 28.223 0.106 / -46.244 0.612 / -161.246 3.500GHz 0.845 / -176.757 1.070 / 26.145 0.106 / -47.902 0.616 / -162.148 3.600GHz 0.846 / -177.904 1.044 / 24.085 0.106 / -49.544 0.621 / -163.051 3.700GHz 0.848 / -179.046 1.020 / 22.042 0.106 / -51.173 0.625 / -163.955 3.800GHz 0.849 / 179.813 0.997 / 20.014 0.106 / -52.790 0.628 / -164.862 3.900GHz 0.850 / 178.671 0.976 / 17.999 0.106 / -54.398 0.632 / -165.772 4.000GHz 0.852 / 177.526 0.957 / 15.996 0.106 / -55.998 0.635 / -166.687 Download this s-parameter file in “.s2p” format at http://www.cree.com/products/wireless_s-parameters.asp Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 7 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Typical Package S-Parameters (Small Signal, VDS = 48 V, IDQ = 500 mA, magnitude / angle) Frequency S(1,1) S(2,1) S(1,2) S(2,2) 100.0MHz 0.933 / -24.697 9.470 / 164.826 0.022 / 72.184 0.281 / -34.171 200.0MHz 0.917 / -47.336 8.814 / 150.896 0.041 / 60.244 0.311 / -62.220 300.0MHz 0.898 / -66.755 7.970 / 138.866 0.055 / 49.176 0.344 / -83.098 400.0MHz 0.881 / -82.780 7.113 / 128.773 0.066 / 39.787 0.372 / -98.337 500.0MHz 0.867 / -95.802 6.332 / 120.339 0.073 / 31.953 0.394 / -109.583 600.0MHz 0.856 / -106.375 5.654 / 113.216 0.078 / 25.378 0.411 / -118.050 700.0MHz 0.847 / -115.027 5.079 / 107.100 0.082 / 19.781 0.425 / -124.563 800.0MHz 0.841 / -122.187 4.592 / 101.752 0.084 / 14.932 0.436 / -129.678 900.0MHz 0.837 / -128.190 4.179 / 96.993 0.086 / 10.659 0.445 / -133.774 1.000GHz 0.834 / -133.288 3.828 / 92.961 0.088 / 6.834 0.454 / -137.115 1.100GHz 0.831 / -137.674 3.526 / 88.750 0.089 / 3.362 0.462 / -139.886 1.200GHz 0.830 / -141.491 3.266 / 85.096 0.090 / 0.172 0.469 / -142.221 1.300GHz 0.829 / -144.852 3.039 / 81.675 0.090 / -2.790 0.475 / -144.221 1.400GHz 0.829 / -147.841 2.840 / 78.445 0.091 / -5.564 0.482 / -145.960 1.500GHz 0.828 / -150.526 2.665 / 75.375 0.091 / -8.183 0.488 / -147.492 1.600GHz 0.829 / -152.959 2.509 / 72.440 0.091 / -10.671 0.495 / -148.863 1.700GHz 0.829 / -155.183 2.370 / 69.618 0.091 / -13.047 0.501 / -150.104 1.800GHz 0.830 / -157.231 2.246 / 66.896 0.091 / -15.328 0.507 / -151.244 1.900GHz 0.830 / -159.132 2.133 / 64.258 0.091 / -17.526 0.513 / -152.301 2.000GHz 0.831 / -160.907 2.032 / 61.696 0.091 / -19.652 0.519 / -153.294 2.100GHz 0.832 / -162.576 1.940 / 59.200 0.091 / -21.714 0.525 / -154.235 2.200GHz 0.833 / -164.155 1.855 / 56.763 0.091 / -23.720 0.530 / -155.136 2.300GHz 0.834 / -165.657 1.778 / 54.379 0.091 / -25.676 0.536 / -156.004 2.400GHz 0.836 / -167.092 1.708 / 52.042 0.091 / -27.587 0.542 / -156.847 2.500GHz 0.837 / -168.471 1.643 / 49.748 0.091 / -29.458 0.547 / -157.670 2.600GHz 0.838 / -169.802 1.583 / 47.492 0.091 / -31.294 0.552 / -158.479 2.700GHz 0.839 / -171.093 1.528 / 45.273 0.091 / -33.096 0.558 / -159.277 2.800GHz 0.840 / -172.348 1.477 / 43.085 0.091 / -34.870 0.563 / -160.067 2.900GHz 0.842 / -173.575 1.430 / 40.926 0.091 / -36.616 0.568 / -160.852 3.000GHz 0.843 / -174.777 1.386 / 38.795 0.091 / -38.340 0.572 / -161.634 3.100GHz 0.844 / -175.960 1.346 / 36.687 0.091 / -40.041 0.577 / -162.415 3.200GHz 0.845 / -177.126 1.308 / 34.602 0.091 / -41.724 0.581 / -163.197 3.300GHz 0.846 / -178.281 1.273 / 32.537 0.091 / -43.390 0.586 / -163.981 3.400GHz 0.848 / -179.426 1.240 / 30.490 0.091 / -45.041 0.590 / -164.768 3.500GHz 0.849 / 179.435 1.210 / 28.259 0.091 / -46.679 0.594 / -165.559 3.600GHz 0.850 / 178.299 1.181 / 26.443 0.091 / -48.306 0.597 / -166.355 3.700GHz 0.851 / 177.164 1.155 / 24.440 0.091 / -49.924 0.601 / -167.157 3.800GHz 0.852 / 176.027 1.130 / 22.447 0.091 / -51.534 0.604 / -167.96 3.900GHz 0.853 / 174.886 1.107 / 20.464 0.091 / -53.138 0.607 / -168.783 4.000GHz 0.853 / 173.738 1.086 / 18.489 0.091 / -54.738 0.610 / -169.607 Download this s-parameter file in “.s2p” format at http://www.cree.com/products/wireless_s-parameters.asp Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 8 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Product Dimensions - CRF24010P (Package Type ­— 440196) Product Dimensions - CRF24010F (Package Type ­— 440166) PRELIMINARY CREE Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 9 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless Disclaimer Specifications are subject to change without notice. Cree, Inc. believes the information contained within this data sheet to be accurate and reliable. However, no responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Cree. Cree makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. These values can and do vary in different applications, and actual performance can vary over time. All operating parameters should be validated by customer’s technical experts for each application. Cree products are not designed, intended, or authorized for use as components in applications intended for surgical implant into the body or to support or sustain life, in applications in which the failure of the Cree product could result in personal injury or death, or in applications for planning, construction, maintenance or direct operation of a nuclear facility. Cree and the Cree logo are registered trademarks of Cree, Inc. For more information, please contact: Cree, Inc. 4600 Silicon Drive Durham, NC 27703 www.cree.com/wireless Ryan Baker Cree, Marketing 919.287.7816 Tom Dekker Cree, Sales Director 919.313.5639 Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 10 CRF24010 Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.869.2733 www.cree.com/wireless
CRF24010FE
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需查看引脚图。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,工作电压2.0V-3.6V。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART、SPI、I2C)等模块的详细功能描述。
6. 应用信息:适用于工业控制、消费电子、医疗设备等领域。
CRF24010FE 价格&库存
很抱歉,暂时无法提供与“CRF24010FE”相匹配的价格&库存,您可以联系我们找货
