NJW1616F1-AT-TE2
NJW1616F1-AT-TE2
    NJR(新日本无线)
    SOT23-6
    600MA, 500KHZ, STEP-DOWN SWITCHI
NJW1616F1-AT-TE2 数据手册
NJW1616-T 600mA, 500kHz, Step-Down Switching Regulator in SOT-23 GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJW1616 is a switching regulator IC for buck converter that operates wide input voltage range from 4.5V to 20V. The wide input range makes the NJW1616 suitable for several applications such as 12V commodity supplies, and the other unregulated voltage sources. It corresponds to Low ESR output capacitor (MLCC), high operating frequency of 500kHz, internally compensated and small SOT-23 package. Therefore, the NJW1616 can realize downsizing of applications with a few and tiny external parts so that adopts current mode control. Also, it has a soft start function, over current protection and thermal shutdown circuit. NJW1616F1 FEATURES ● Pin compatible with LT1616 and LT2736. Also it is possible to reduce an external part ● Maximum Rating Input Voltage: 25V ● Wide Operating Voltage Range: 4.5 V to 20V ● Switching Current: 0.8A (min.) ● Fixed Operating Frequency: 500kHz (A-version) ● Uses Tiny Capacitors and Inductors ● Soft Start Function ● Low Shutdown Current 1 A ● Internally Compensated ● Under Voltage Lockout (UVLO) ● Output Adjustable Down to 1.25V ● Over Current Protection / Thermal Shutdown Protection ● Package Outline: SOT-23-6-1 PIN CONFIGURATION N.C. 1 6 SW GND 2 5 VIN FB 3 4 SHDN NJW1616F1 Ver.2016-03-01 -1- NJW1616-T ■ PIN DESCRIPTIONS N.C. GND PIN NUMBER 1 2 FB 3 SHDN 4 VIN SW 5 6 PIN NAME FUNCTION Unused pin GND pin Output Voltage Detecting pin Connects output voltage through the resistor divider tap to this pin in order to voltage of the FB pin become 1.245V. Standby Control pin Normal Operation at the time of High Level. Standby Mode at the time of Low Level or Open. Power Supply pin for Power Line Switch Output pin of Power MOSFET BLOCK DIAGRAM VIN CURRENT SENSE UVLO ∑ OSC OCP SHDN S Soft Start Q Buffer R TSD FB SW Vref Error AMP PWM 1.245V GND -2- Ver.2016-03-01 NJW1616-T (Ta=25 C) RATINGS UNIT V 0.3 to 25 V 0.3 to 25 V 0.3 to 25 V 0.3 to 6 510 (*1) Power Dissipation PD mW 710 (*2) Junction Temperature Tj 40 to 150 C Operating Temperature Topr 40 to 105 C Storage Temperature Tstg 50 to 150 C (*1): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers) (*2): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers), internal Cu area: 74.2×74.2mm ■ ABSOLUTE MAXIMUM RATINGS PARAMETER Input Voltage VIN-SW pin voltage SHDN Voltage Feedback Pin Voltage SYNBOL VIN VV-SW VSHDN VFB ■ RECOMMENDED OPERATING CONDITION PARAMETER Input Voltage Ver.2016-03-01 SYMBOL VIN MIN. 4.5 TYP. – MAX. 20 (Ta=25ºC) UNIT V -3- NJW1616-T ■ ELECTRICAL CHARACTERISTICS (Specifications in standard type face are for Ta= 25°C and those with boldface type apply over the bellow Operating Temperature Range (Ta= 40°C to 105°C). Minimum and Maximum specs are guaranteed through test. Unless otherwise noted, VIN= VSHDN=12V, Ta= 25°C) PARAMETER SYMBOL CONDITIONS MIN. TYP. MAX. UNIT Under Voltage Lockout Block ON Threshold Voltage OFF Threshold Voltage Hysteresis Width Oscillation Block Oscillation Frequency1 Oscillation Frequency2 Error Amplifier Block Feedback Voltage FB Pin Bias Current VT_ON VT_OFF VHYS VIN = L VIN = H H L 4.2 4.1 – 4.35 4.25 100 4.5 4.4 – V V mV fOSC1 fOSC2 VFB=1.1V VFB=0V 400 – 500 80 600 – kHz kHz VB IB VFB=1.3V 1.6 – 1.245 10 1.6 100 V nA 88 – 94 100 – 160 ns 0.8 – – 1.1 1 – 1.5 1.6 1 A ISW=400mA VSHDN = 0V, VIN=25V, VSW=0V VSHDN = L H VSHDN = H L VSHDN = 2.3V VSHDN = 0V 2.3 0 – – – – 5 0.01 VIN 0.3 10 0.1 V V A A – – – 1.6 2.2 – 2.5 3.2 1 mA mA A PWM Comparator Block Maximum Duty Cycle Minimum ON Time Output Block Switching Current Limit Output ON Resistance Switch Leakage Current SHDN Block SHDN ON Control Voltage SHDN OFF Control Voltage SHDN Bias Current1 SHDN Bias Current2 MAXDUTY tON_min ILIM RON ILEAK VSHDN(ON) VSHDN(OFF) ISHDN_BIAS1 ISHDN_BIAS2 VFB=1.1V A General Quiescent Current1 Quiescent Current2 Quiescent Current in SHDN -4- IDD1 IDD2 IDD_SHDN Not Switching, VFB=1.3V No Load, VFB=1.1V VSHDN = 0V Ver.2016-03-01 NJW1616-T THERMAL CHARACTERISTICS PARAMETER SYMBOL VALUE UNIT Junction-to-ambient 245 (*3) ja C/W thermal resistance 175 (*4) Junction-to-Top of package 70 (*3) jt C/W characterization parameter 60 (*4) (*3): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers) (*4): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers), internal Cu area: 74.2×74.2mm POWER DISSIPATION vs. AMBIENT TEMPERATURE NJW1616F1 Power Dissipation vs. Ambient Temperature (Topr=-40 to +105ºC, Tj= ~150ºC) 800 *4) At on 4-layer PC Board Power Dissipation PD [mW] 700 600 *3) At on 2-layer PC Board 500 400 300 200 100 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature Ta [ºC] Ver.2016-03-01 -5- NJW1616-T TYPICAL APPLICATIONS VIN VIN NJW1616 VSHDN SHDN L SW VOUT FB GND SBD R2 CIN R1 Efficiency vs. Output Current 100 VOUT=5V 90 80 Efficiency [%] COUT VOUT=3.3V 70 60 50 40 VIN=12V Ta=25ºC 30 20 D1 = MBRM140 L1= CDRH6D28NP: 22uH/1.2A 10 0 -6- 0 100 200 300 400 Output Current [mA] 500 600 Ver.2016-03-01 NJW1616-T TYPICAL CHARACTERISTICS Efficiency vs.Output Current 100 Efficiency vs.Output Current 100 VIN=12V VIN=12V 80 Efficiency [%] Efficiency [%] 80 60 Ta=25ºC VOUT=3.3V setting 40 20 0 Ta=25ºC VOUT=5V setting D1 = MBRM140 L1= CDRH6D28NP: 22uH/1.2A 100 200 300 400 Output Current [mA] 500 0 600 0 200 300 400 500 600 Oscillation Frequency vs.FB Pin Voltage 600 Oscillation Frequency [kHz] 4.5 VT_ON 4.4 100 Output Current [mA] Under Voltage Lockout Voltage vs. Ambient Temperature Under Voltage Lockout Voltage [V] 40 20 D1 = MBRM140 L1= CDRH6D28NP: 22uH/1.2A 0 4.3 4.2 VT_OFF 4.1 VIN=12V Ta=25ºC 500 400 300 200 100 0 4.0 -50 530 0 50 100 150 Ambient Temperature [ºC] 0 0.5 1 FB Pin Voltage [V] Oscillation Frequency vs. Input Voltage Oscillation Frequency vs. Ambient Temperature 1.5 600 VIN=12V VFB=1.1V 520 Oscillation Frequency [kHz] Oscillation Frequency [kHz] 60 510 500 490 480 470 550 500 450 400 0 Ver.2016-03-01 5 10 15 Input Voltage [V] 20 -50 0 50 100 150 Ambient Temperature [ºC] -7- NJW1616-T TYPICAL CHARACTERISTICS Feedback Voltage vs. Ambient Temperature Feedback Voltage vs.Input Voltage 1.26 1.260 VIN=12V 1.255 Feedback Voltage [V] Feedback Voltage [V] 1.255 1.250 1.245 1.240 1.25 1.245 1.24 1.235 1.235 1.23 1.230 -50 0 50 100 150 0 5 Ambient Temperature [ºC] 10 15 Input Voltage [V] 20 Minimum ON Time vs.Ambient Temperature Maximum Duty Cycle vs.Ambient Temperature 100 VIN=4.5V 99 Maximum Duty Cycle [%] (VFB=1.1V) 160 VIN=12V Minimum ON Time [ns] 98 97 96 95 94 93 92 140 120 100 80 91 60 90 -50 0 50 100 -50 150 150 1200 VIN=12V Ta=25ºC Switching Current Limit [mA] Switching Current Limit [mA] 100 Switching Current Limit vs. Ambient Temperature Switching Current Limit vs.SHDN Pin Voltage 1000 800 600 400 200 0 VIN=12V VSHDN=2.3V 1000 800 600 400 200 0 0 -8- 50 Ambient Temperature[ºC] Ambient Temperature[ºC] 1200 0 1 2 SHDN Pin Voltage [V] 3 -50 0 50 100 150 Ambient Temperature [ºC] Ver.2016-03-01 NJW1616-T TYPICAL CHARACTERISTICS Output ON Resistance vs. Ambient Temperature 2.0 VIN=12V Output ON Resistnce [Ω] 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 -50 0 50 100 150 Ambient Temperature [ºC] SHDN Pin Bias Current vs. SHDN Pin Voltage 250 SHDN Pin Bias Current [μA] VIN=12V Ta=25ºC 200 150 100 50 0 0 5 10 15 SHDN Pin Voltage [V] Quiescent Current1 vs.Input Voltage 3 VFB=1.1V Ta=25ºC VFB=1.3V Ta=25ºC 2.5 Quiescent Current2 vs.Input Voltage 3 Quiescent Current2 [mA] Quiescent Current1 [mA] 20 2 1.5 1 0.5 0 2.5 2 1.5 1 0.5 0 0 5 10 Input Voltage [V] Ver.2016-03-01 15 20 0 5 10 15 20 Input Voltage [V] -9- NJW1616 Application Manual NJW1616-T Technical Information Description of Block Features 1. Basic Functions / Features Error Amplifier Section (ER AMP) 1.245V±1.6% (Ta= 40°C to +105°C) precise reference voltage is connected to the non-inverted input of this section. To set the output voltage, connects converter's output to inverted input of this section (FB pin). If requiring output voltage of more than 1.245V, should insert resistor divider. Because the optimized compensation circuit is built-in, the application circuit can be composed of minimum external parts. PWM Comparator Section (PWM), Oscillation Circuit Section (OSC) The NJW1616 is a constant frequency, current mode step down regulator. The oscillation frequency is 500kHz (typ.) (A-version). The PWM signal is output by feedback of output voltage and slope compensation switching current at the PWM comparator block. The maximum duty ratio is 94% (typ.). Table 1. Minimum ON time of NJW1616 NJW1616F1-AT Product Name (fOSC =500kHz) Minimum 100ns (typ.) ON-time The ON time of buck converter is decided with the following equation. ton VOUT s VIN fOSC VIN means the input voltage and VOUT means the output voltage. When the ON time becomes below tON-min, in order to maintain the stable output voltage, change of duty or pulse skip operation may be performed. Power MOSFET (SW Output Section) The power is stored in the inductor by the switch operation of built-in power MOSFET. The output current is limited to 0.8A (min.) the overcurrent protection function. In case of step-down converter, the forward direction bias voltage is generated with inductance current that flows into the external regenerative diode when MOSFET is turned off. The SW pin allows voltage between the VIN pin and the SW pin up to +25V. However, you should use an Schottky diode that has low saturation voltage. Power Supply, GND pin (VIN and GND) Along with switching element drive according to oscillation frequency, a transient current flows into the NJW1616. If the power supply impedance of the power supply circuit is large the input voltage fluctuation occurs. As the result, it will not be possible to take sufficient advantage of the NJW1616 performance. Therefore, you should insert a bypass capacitor close to the VIN pin and the GND pin in order to lower high frequency impedance. - 10 - Ver.2016-03-01 NJW1616 Application Manual NJW1616-T Technical Information Description of Block Features (Continued) 2. Additional and Protection Functions / Features Under Voltage Lockout (UVLO) The NJW1616 includes an undervoltage lockout to prevent switching when VIN is less than 4.35V (typ.). The NJW1616 has 100mV (typ.) width hysteresis voltage at rise and decay of power supply voltage. The hysteresis prevents the malfunction at the time of UVLO operating and releasing. Soft Start Function (Soft Start) The SHDN pin can be used to soft-start the NJW1616, reducing the maximum input current during start up. The SHDN pin is driven through an external RC filter to create a voltage ramp at this pin. By adjusting the RC time constant, the peak start up current can be reduced to the current that is required to regulate the output, with no overshoot. And the soft-start operation is able to adjust, too. Moreover, the switching current limit value is limited by applied voltage to the SHDN pin. When the applying voltage is 2.3V, ILIM becomes maximum spec. (Refer to "Switching Current Limit vs.SHDN Pin Voltage" characteristics on ELECTRICAL CHARACTERISTICS) Choose the value of the resistor so that it can supply 20μA or more when the SHDN pin reaches 2.3V. Ver.2016-03-01 - 11 - NJW1616 Application Manual NJW1616-T Technical Information Description of Block Features (Continued) Over Current Protection Circuit (OCP) The NJW1616 contains overcurrent protection circuit. The overcurrent protection circuit is able to decrease heat generation at the overload. The NJW1616 output returns automatically along with release of the over current condition. At when the switching current becomes ILIM or more, the overcurrent protection circuit is stopped the MOSFET output. Then at next switching period, the switching operation is returned. The oscillator reduces the NJW1616’s operating frequency when the voltage at the FB pin is low. This frequency foldback helps to control the output current during startup and overload by decreasing minimum ON Duty. 1.245V FB pin Voltage 0V ON SW pin OFF Switching Current ILIM 0 Pulse by Pulse Static Status Frequency Foldback Detect Overcurrent Static Status Fig. 1. Timing Chart at Over Current Detection Thermal Shutdown Function (TSD) When Junction temperature of the NJW1616 exceeds the 175°C*, internal thermal shutdown circuit function stops SW function. When junction temperature decreases to 145°C* or less, SW operation returns with soft start operation. The purpose of this function is to prevent malfunctioning of IC at the high junction temperature. Therefore it is not something that urges positive use. You should make sure to operate within the junction temperature range rated ( 150 C). (* Design value) Standby Function The SHDN pin is used to place the NJW1616 in shutdown, disconnecting the output and reducing the input current to less than 1μA. The NJW1616 stops the operating and becomes standby status when the SHDN pin becomes less than 0.3V or OPEN. You should connect to the VIN pin when you do not use standby function. - 12 - Ver.2016-03-01 NJW1616 Application Manual NJW1616-T Technical Information Application Information Inductors Because a large current flows to the inductor, you should select the inductor with the large current capacity not to saturate. Optimized inductor value is determined by the input voltage and output voltage. The Inductor setting example is shown in Table 2. When increasing inductor value, it is necessary to increasing capacity of an output capacitor and to secure the stability of application. The minimum of inductor value is restricted from the following equation, when ON duty exceeds 50%. VIN L 2 D ON 0.4 1 [ H] Reducing L decreases the size of the inductor. However a peak current increases and adversely affects the efficiency. (Fig.2) Moreover, you should be aware that the output current is limited because it becomes easy to operating to the overcurrent limit. The peak current is decided the following equation. IL Ipk VIN VOUT VOUT [A] L VIN f OSC IL [A] 2 IOUT Current Peak Current IPK Indunctor Ripple Current IL Peak Current IPK Output Current IOUT Indunctor Ripple Current IL 0 tON tOFF Reducing L Value tON tOFF Increasing L value Fig.2 Inductor Current State Transition (Continuous Conduction Mode) Ver.2016-03-01 - 13 - NJW1616 Application Manual NJW1616-T Technical Information Application Information (Continued) Input Capacitor Transient current flows into the input section of a switching regulator responsive to frequency. If the power supply impedance of the power supply circuit is large the input voltage fluctuation occurs. As the result, it will not be possible to take sufficient advantage of the NJW1616 performance. Therefore insert an input capacitor as close to the MOSFET as possible. A ceramic capacitor is the optimal for input capacitor. The effective input current can be expressed by the following equation. IRMS VOUT IOUT VIN VIN VOUT [ A] In the above equation, the maximum current is obtained when VIN = 2 VOUT, and the result in this case is IRMS = IOUT (MAX) 2. When selecting the input capacitor, carry out an evaluation based on the application, and should use a capacitor that has adequate margin. Output Capacitor An output capacitor stores power from the inductor and stabilizes the voltage provided to the output. Because the NJW1616 corresponds to the output capacitor of low ESR the ceramic capacitor is the optimal for compensation. Table.2 shown the output capacitor setting example. Table2 Output Capacitor Setting Example Input Voltage Output Voltage Inductor VIN VOUT L 3.3V 22 H 12V 5.0V 22 H 8.0V 22 H Output Capacitor COUT 22 F 2 / 6.3V 47 F / 6.3V 22 F/ 25V Part Number GRM31CB30J226ME18: Murata GRM31CB30J476KE18: Murata GRM32EB31E226KE15: Murata To consider using output capacitor capacity bigger than Table2. In addition, you should consider varied characteristics of capacitor (a frequency characteristic, a temperature characteristic, a DC bias characteristic and so on) and unevenness peculiar to a capacitor supplier enough. Therefore when selecting a capacitors, you should confirm the characteristics with supplier datasheets. When selecting an output capacitor, you must consider Equivalent Series Resistance (ESR) characteristics, ripple current, and breakdown voltage. If using low ESR type capacitors, it is possible to reduce the ripple voltage. The output ripple noise can be expressed by the following equation. Vripple(p p) ESR IL [ V ] The effective ripple current that flows in a capacitor (Irms) is obtained by the following equation. Irms - 14 - IL 2 3 [ Arms] Ver.2016-03-01 NJW1616 Application Manual NJW1616-T Technical Information Application Information (Continued) Catch Diode When the switch element is in OFF cycle, the stored power in the inductor flows via the catch diode to the output capacitor. Therefore during each cycle the current flows to the diode in response to load current. Because a diode forward saturation voltage and current accumulation are cause of power loss, a Schottky Barrier Diode (SBD), that has a low forward saturation voltage is ideal. An SBD also has a short reverse recovery time. If the reverse recovery time is long, shoot through current flows when the switching transistor transitions from OFF cycle to ON cycle. This current may lower efficiency and affect such factors as noise generation. Setting Output Voltage, Compensation Capacitor The output voltage VOUT is determined by the relative resistances of R1/R2. The current that flows in R1/R2 must be a value that can ignore the bias current that flows in Error AMP. R2 1 R1 VOUT VB [ V ] The zero points are formed by parallel addition CFB to R2, and it can improve the phase compensation of the NJW1616 The zero point is decided the following equation. f Z1 2 1 [Hz] R2 C FB You should set the zero point as a guide from 40kHz to 70kHz. Ver.2016-03-01 - 15 - NJW1616 Application Manual NJW1616-T Technical Information Application Information (Continued) Board Layout In the switching regulator application, because the current flow corresponds to the oscillation frequency, the substrate (PCB) layout becomes an important. You should attempt the transition voltage decrease by making a current loop area minimize as much as possible. Therefore, you should make a current flowing line thick and short as much as possible. Fig.3. shows a current loop at step-down converter. Especially, should lay out high priority the loop of CIN-SW-SBD that occurs rapid current change in the switching. It is effective in reducing noise spikes caused by parasitic inductance. NJW1616 Built-in SW V IN CIN NJW1616 Built-in SW L SBD COUT V IN CIN (a) Buck Converter SW ON L SBD COUT (b) Buck Converter SW OFF Fig.3 Current Loop at Buck Converter Concerning the GND line, it is preferred to separate the power system and the signal system, and use single ground point. The voltage sensing feedback line should be as far away as possible from the inductance. Because this line has high impedance, it is laid out to avoid the influence noise caused by flux leaked from the inductance. Fig.4 shows example of wiring at buck converter. Fig.5 shows the PCB layout example. L VIN VIN VOUT SW CIN SBD COUT RL (Bypass Capacitor) NJW1616 CFB FB R2 GND Separate Digital(Signal) GND from Power GND R1 To avoid the influence of the voltage drop, the output voltage should be detected near the load. Because FB pin is high impedance, the voltage detection resistance: R1/R2 is put as much as possible near IC(FB). Fig.4 Board Layout at Buck Converter - 16 - Ver.2016-03-01 NJW1616 Application Manual NJW1616-T Technical Information Application Information (Continued) Connect Signal GND line and Power GND line on backside pattern Fig.5 Layout Example (upper view) Ver.2016-03-01 - 17 - NJW1616-T NJW1616 Application Manual Technical Information Calculation of Power Dissipation A lot of the power consumption of buck converter occurs from the internal switching element (Power MOSFET). Power consumption of NJW1616 is roughly estimated as follows. Input Power: Output Power: Diode Loss: NJW1616 Power Consumption: Where: VIN VOUT VF OFF duty PIN = VIN IIN [W] POUT = VOUT IOUT [W] PDIODE = VF IL(avg) OFF duty [W] PLOSS = PIN POUT PDIODE [W] : Input Voltage for Converter : Output Voltage of Converter : Diode's Forward Saturation Voltage : Switch OFF Duty IIN IOUT IL(avg) : Input Current for Converter : Output Current of Converter : Inductor Average Current The efficiency ( ) is calculated the following equation. = (POUT PIN) 100 [%] You should consider temperature derating to the calculated power consumption: PD. You should design power consumption in rated range referring to the Power Dissipation vs. Ambient Temperature characteristics. - 18 - Ver.2016-03-01 NJW1616 Application Manual NJW1616-T Technical Information ■ APPLICATION EXAMPLE ● Buck Converter Specification IC :NJW1616F1-AT Input Voltage :VIN=12V Output Voltage :VOUT=3.3V Output Current :IOUT=0.6A Oscillation Frequency :fosc=500kHz VIN VIN NJW1616 VSHDN SHDN L SW VOUT FB GND R2 CIN SYMBOL IC L SBD CIN1 COUT R1 R2 Ver.2016-03-01 QTY. 1 1 1 1 1 1 1 PART NUMBER NJW1616F1-AT CDRH6D28NP-220NC MBRM140T3G GRM31CB31H225KA87 GRM32EB31C476ME15 3.3k 5.6k R1 SBD COUT DESCRIPTION 0.6A MOSFET built-in SW.REG. IC Inductor 22 H, 1.2A Schottky Diode 40V, 1A Ceramic Capacitor 3216 2.2 F, 50V, B Ceramic Capacitor 3225 47 F, 16V, B Resistor 1608 3.3k , 1%, 0.1W Resistor 1608 5.6k , 1%, 0.1W MFR. New JRC Sumida ON Semiconductor Murata Murata Std. Std. - 19 - NJW1616 Application Manual NJW1616-T Technical Information ■ APPLICATION EXAMPLE ● Buck Converter Specification IC :NJW1616F1-AT Input Voltage :VIN=12V Output Voltage :VOUT=5V Output Current :IOUT=0.6A Oscillation Frequency :fosc=500kHz VIN VIN NJW1616 VSHDN SHDN L SW VOUT FB GND R2 CIN SYMBOL IC L SBD CIN1 COUT R1 R2 - 20 - QTY 1 1 1 1 1 1 1 PART NUMBER NJW1616F1-AT CDRH6D28NP-220NC MBRM140T3G GRM31CB31H225KA87 GRM32EB31C476ME15 3.9k 12k R1 SBD COUT DESCRIPTION 0.6A MOSFET built-in SW.REG. IC Inductor 22 H, 1.2A Schottky Diode 40V, 1A Ceramic Capacitor 3216 2.2 F, 50V, B Ceramic Capacitor 3225 47 F, 16V, B Resistor 1608 3.9k , 1%, 0.1W Resistor 1608 12k , 1%, 0.1W MFR New JRC Sumida ON Semiconductor Murata Murata Std. Std. Ver.2016-03-01 NJW1616-T PACKAGE OUT LINE SOT-23-6-1 NOTES All linear dimensions are in millimeters. This drawing is subject to change without notice. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. Ver.2016-03-01 - 21 -
NJW1616F1-AT-TE2 价格&库存
很抱歉,暂时无法提供与“NJW1616F1-AT-TE2”相匹配的价格&库存,您可以联系我们找货
