ICL7611, ICL7612
Data Sheet
April 26, 2007
FN2919.9
1.4MHz, Low Power CMOS Operational
Amplifiers
Features
The ICL761X series is a family of CMOS operational
amplifiers. These devices provide the designer with high
performance operation at low supply voltages and selectable
quiescent currents, and are an ideal design tool when ultra
low input current and low power dissipation are desired.
• High Input Impedance . . . . . . . . . . . . . . . . . . . . . . 1012Ω
The basic amplifier will operate at supply voltages ranging
from ±1V to ±8V, and may be operated from a single
Lithium cell.
A unique quiescent current programming pin allows setting
of standby current to 1mA, 100μA, or 10μA, with no external
components. This results in power consumption as low as
20μW. The output swing ranges to within a few millivolts of
the supply voltages.
Of particular significance is the extremely low (1pA) input
current, input noise current of 0.01pA/√Hz, and 1012Ω input
impedance. These features optimize performance in very
high source impedance applications.
The inputs are internally protected. Outputs are fully
protected against short circuits to ground or to either supply.
• Wide Operating Voltage Range . . . . . . . . . . . ±1V to ±8V
• Programmable Power Consumption . . . . . Low as 20μW
• Input Current Lower Than BIFETs . . . . . . . . . . . 1pA (Typ)
• Output Voltage Swing . . . . . . . . . . . . . . . . . . . V+ and V• Input Common Mode Voltage Range Greater Than Supply
Rails (ICL7612)
• Pb-Free Plus Anneal Available (RoHS Compliant)
Applications
• Portable Instruments
• Telephone Headsets
• Hearing Aid/Microphone Amplifiers
• Meter Amplifiers
• Medical Instruments
• High Impedance Buffers
AC performance is excellent, with a slew rate of 1.6V/μs, and
unity gain bandwidth of 1MHz at IQ = 1mA.
Because of the low power dissipation, junction temperature
rise and drift are quite low. Applications utilizing these
features may include stable instruments, extended life
designs, or high density packages.
Pinouts
ICL7611, ICL7612
(8 LD PDIP, 8 LD SOIC)
TOP VIEW
BAL
1
-IN
2
+IN
3
V-
4
1
8
IQ SET
7
V+
6
OUT
5
BAL
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright © Intersil Americas Inc. 2004-2007. All Rights Reserved
All other trademarks mentioned are the property of their respective owners.
ICL7611, ICL7612
Ordering Information
PART NUMBER
PART MARKING
TEMP. RANGE (°C)
PACKAGE
PKG. DWG. #
ICL7611DCBA
7611 DCBA
0 to +70
8 Ld SOIC (150 mil)
M8.15
ICL7611DCBAZ (Note)
7611 DCBAZ
0 to +70
8 Ld SOIC (150 mil) (Pb-free)
M8.15
ICL7611DCBA-T
7611 DCBA
0 to +70
8 Ld SOIC (150 mil) Tape and Reel
M8.15
ICL7611DCBAZ-T (Note)
7611 DCBAZ
0 to +70
8 Ld SOIC (150 mil) Tape and Reel (Pb-free)
M8.15
ICL7611DCPA
7611 DCPA
0 to +70
8 Ld PDIP
E8.3
ICL7611DCPAZ (Note)
7611 DCPAZ
0 to +70
8 Ld PDIP* (Pb-free)
E8.3
ICL7612BCPA
7612 BCPA
0 to +70
8 Ld PDIP
E8.3
ICL7612BCPAZ
7612 BCPAZ
0 to +70
E8.3
ICL7612DCBA
7612 DCBA
0 to +70
8 Ld SOIC (150 mil)
M8.15
ICL7612DCBA-T
7612 DCBA
0 to +70
M8.15
ICL7612DCBAZ (Note)
7612 DCBAZ
0 to +70
M8.15
ICL7612DCBAZ-T (Note)
7612 DCBAZ
0 to +70
M8.15
ICL7612DCPA
7612 DCPA
0 to +70
8 Ld PDIP
E8.3
ICL7612DCPAZ (Note)
7612 DCPAZ
0 to +70
E8.3
*Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications.
NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin
plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are
MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020.
2
FN2919.9
April 26, 2007
ICL7611, ICL7612
Absolute Maximum Ratings
Thermal Information
Supply Voltage V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18V
Input Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . V- -0.3 to V+ +0.3V
Differential Input Voltage (Note 1) . . . . . . . . [(V+ +0.3) - (V- -0.3)]V
Duration of Output Short Circuit (Note 2). . . . . . . . . . . . . . Unlimited
Thermal Resistance (Typical, Note 3)
θJA (°C/W)
PDIP Package* . . . . . . . . . . . . . . . . . . . . . . . . . . . .
130
SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
170
Maximum Junction Temperature (Plastic Package) . . . . . . . +150°C
Maximum Storage Temperature Range . . . . . . . . . -65°C to +150°C
Pb-free reflow profile . . . . . . . . . . . . . . . . . . . . . . . . . .see link below
http://www.intersil.com/pbfree/Pb-FreeReflow.asp
Operating Conditions
Temperature Range
ICL761XC. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C
applications.
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the
device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTES:
1. Long term offset voltage stability will be degraded if large input differential voltages are applied for long periods of time.
2. The outputs may be shorted to ground or to either supply, for VSUPPLY ≤10V. Care must be taken to insure that the dissipation rating is not
exceeded.
3. θJA is measured with the component mounted on an evaluation PC board in free air.
VSUPPLY = ±5V, Unless Otherwise Specified.
Electrical Specifications
PARAMETER
SYMBOL
Input Offset Voltage
VOS
TEST
CONDITIONS
RS ≤ 100kΩ
ΔVOS/ΔT RS ≤ 100kΩ
Temperature Coefficient of VOS
Input Offset Current
IOS
Input Bias Current
IBIAS
(ICL7611 Only)
VCMR
Extended Common Mode Voltage
Range (ICL7612 Only)
VCMR
VOUT
Large Signal Voltage Gain
AVOL
3
ICL7612B
ICL7611D, ICL7612D
TEMP
(°C)
MIN
TYP
MAX
MIN
TYP
MAX
UNITS
+25
5
15
mV
Full
7
mV
15
25
μV/°C
+25
0.5
30
0.5
30
pA
Full
300
300
pA
+25
1.0
50
1.0
50
pA
Full
400
400
pA
IQ = 10μA
+25
±4.4
V
IQ = 100μA
+25
±4.2
V
IQ = 1mA
+25
±3.7
V
IQ = 10μA
+25
±5.3
±5.3
V
IQ = 100μA
+25
+5.3,
-5.1
+5.3, 5.1
V
IQ = 1mA
+25
+5.3, 4.5
+5.3, 4.5
V
IQ = 10μA, RL = 1MΩ
+25
±4.9
±4.9
V
Full
±4.8
±4.8
V
IQ = 100μA, RL = 100kΩ
+25
±4.9
±4.9
V
Full
±4.8
±4.8
V
IQ = 1mA, RL = 10kΩ
+25
±4.5
±4.5
V
Full
±4.3
±4.3
V
VO = ±4.0V, RL = 1MΩ,
IQ = 10μA
+25
80
104
80
104
dB
Full
75
75
dB
VO = ±4.0V, RL = 100kΩ,
IQ = 100μA
+25
80
102
80
102
dB
Full
75
75
dB
VO = ±4.0V, RL = 10kΩ,
IQ = 1mA
+25
76
83
76
83
dB
Full
72
72
dB
FN2919.9
April 26, 2007
ICL7611, ICL7612
VSUPPLY = ±5V, Unless Otherwise Specified. (Continued)
PARAMETER
SYMBOL
Unity Gain Bandwidth
GBW
Input Resistance
TEST
CONDITIONS
CMRR
Power Supply Rejection Ratio
(VSUPPLY = ±8V to ±2V)
PSRR
ICL7611D, ICL7612D
MIN
TYP
MAX
MIN
TYP
MAX
UNITS
IQ = 10μA
+25
0.044
0.044
MHz
IQ = 100μA
+25
0.48
0.48
MHz
IQ = 1mA
+25
1.4
1.4
MHz
+25
1012
1012
Ω
RS ≤ 100kΩ, IQ = 10μA
+25
70
96
70
96
dB
RS ≤ 100kΩ, IQ = 100μA
+25
70
91
70
91
dB
RIN
Common Mode Rejection Ratio
ICL7612B
TEMP
(°C)
RS ≤ 100kΩ, IQ = 1mA
+25
60
87
60
87
dB
+25
80
94
80
94
dB
RS ≤ 100kΩ,
IQ = 100μA
+25
80
86
80
86
dB
+25
70
77
70
77
dB
Input Referred Noise Voltage
eN
RS = 100Ω, f = 1kHz
+25
100
100
nV/√Hz
Input Referred Noise Current
iN
RS = 100Ω, f = 1kHz
+25
0.01
0.01
pA/√Hz
Supply Current (No Signal, No
Load)
ISUPPLY IQ SET = +5V, Low Bias
+25
0.01
0.02
0.01
0.02
mA
IQ SET = 0V,
Medium Bias
+25
0.1
0.25
0.1
0.25
mA
Channel Separation
VO1/VO2 AV = 100
IQ SET = -5V, High Bias
Slew Rate
(AV = 1, CL = 100pF, VIN = 8VP-P)
Rise Time
(VIN = 50mV, CL = 100pF)
SR
tr
Overshoot Factor
OS
+25
1.0
2.5
1.0
2.5
mA
+25
120
120
dB
IQ = 10μA, RL = 1MΩ
+25
0.016
0.016
V/μs
+25
0.16
0.16
V/μs
IQ = 1mA, RL = 10kΩ
+25
1.6
1.6
V/μs
IQ = 10μA, RL = 1MΩ
+25
μs
IQ = 100μA,
RL = 100kΩ
+25
2
2
μs
IQ = 1mA, RL = 10kΩ
+25
0.9
0.9
μs
IQ = 10μA, RL = 1MΩ
+25
5
5
IQ = 100μA,
RL = 100kΩ
+25
10
10
IQ = 1mA, RL = 10kΩ
+25
40
40
VSUPPLY = ±1V, IQ = 10μA, Unless Otherwise Specified.
PARAMETER
SYMBOL
VOS
TEST
CONDITIONS
RS ≤ 100kΩ
ΔVOS/ΔT RS ≤ 100kΩ
IOS
Input Bias Current
IBIAS
Voltage Range
VCMR
4
ICL7612B
TEMP (°C)
MIN
TYP
MAX
UNITS
+25
5
mV
Full
7
mV
15
μV/°C
+25
0.5
30
pA
Full
300
pA
+25
1.0
50
pA
Full
500
pA
+25
+0.6 to -1.1
V
FN2919.9
April 26, 2007
ICL7611, ICL7612
VSUPPLY = ±1V, IQ = 10μA, Unless Otherwise Specified. (Continued)
PARAMETER
SYMBOL
VOUT
TEMP (°C)
MIN
TYP
MAX
UNITS
+25
±0.98
V
Full
±0.96
V
+25
90
dB
Full
80
dB
+25
0.044
MHz
+25
1012
Ω
RL = 1MΩ
VO = ±0.1V, RL = 1MΩ
AVOL
ICL7612B
TEST
CONDITIONS
GBW
Input Resistance
RIN
CMRR
RS ≤ 100kΩ
+25
80
dB
PSRR
RS ≤ 100kΩ
+25
80
dB
eN
RS = 100Ω, f = 1kHz
+25
100
nV/√Hz
iN
RS = 100Ω, f = 1kHz
+25
0.01
pA/√Hz
No Signal, No Load
+25
6
15
μA
AV = 1, CL = 100pF,
VIN = 0.2VP-P, RL = 1MΩ
+25
0.016
V/μs
Supply Current
ISUPPLY
Slew Rate
SR
Rise Time
tr
VIN = 50mV, CL = 100pF RL = 1MΩ
+25
μs
OS
VIN = 50mV, CL = 100pF, RL = 1MΩ
+25
5
Overshoot Factor
Schematic Diagram
IQ
SETTING STAGE
INPUT STAGE
OUTPUT STAGE
V+
3k
900k
3k
QP5
BAL
BAL
QP1
QP1
QP6
QP7
QP3
6.3V
QP8
100k
QP4
V+
+INPUT
QP9
QN1
QN2
CFF = 9pF
OUTPUT
VV+
CC = 33pF
-INPUT
QN7
QN4
V-
QN6
QN3
QN11
QN9 QN10
QN5
6.3V
QN8
V-
V+
5
IQ SET
FN2919.9
April 26, 2007
ICL7611, ICL7612
Application Information
Static Protection
All devices are static protected by the use of input diodes.
However, strong static fields should be avoided, as it is
possible for the strong fields to cause degraded diode
junction characteristics, which may result in increased input
leakage currents.
Latchup Avoidance
Junction-isolated CMOS circuits employ configurations which
produce a parasitic 4-layer (PNPN) structure. The 4-layer
structure has characteristics similar to an SCR, and under
certain circumstances may be triggered into a low impedance
state resulting in excessive supply current. To avoid this
condition, no voltage greater than 0.3V beyond the supply
rails may be applied to any pin. In general, the op amp
supplies must be established simultaneously with, or before
any input signals are applied. If this is not possible, the drive
circuits must limit input current flow to 2mA to prevent latchup.
Choosing the Proper IQ
IQ = 10μA, nulling may not be possible with higher values
of VOS .
Frequency Compensation
The ICL7611 and ICL7612 are internally compensated, and
are stable for closed loop gains as low as unity with
capacitive loads up to 100pF.
Extended Common Mode Input Range
The ICL7612 incorporates additional processing which
allows the input CMVR to exceed each power supply rail by
0.1V for applications where VSUPP ≥ ±1.5V. For those
applications where VSUPP ≤ ±1.5V the input CMVR is limited
in the positive direction, but may exceed the negative supply
rail by 0.1V in the negative direction (e.g., for VSUPPLY = ±1V,
the input CMVR would be +0.6V to -1.1V).
Operation At VSUPPLY = ±1V
Operation at VSUPPLY = ±1V is guaranteed at IQ = 10μA for
A and B grades only.
The ICL7611 and ICL7612 have a similar IQ set-up scheme,
which allows the amplifier to be set to nominal quiescent
currents of 10μA, 100μA or 1mA. These current settings
change only very slightly over the entire supply voltage
range. The ICL7611 and ICL7612 have an external IQ
control terminal, permitting user selection of quiescent
current. To set the IQ connect the IQ terminal as follows:
Output swings to within a few millivolts of the supply rails are
achievable for RL ≥ 1MΩ. Guaranteed input CMVR is ±0.6V
minimum and typically +0.9V to -0.7V at VSUPPLY = ±1V. For
applications where greater common mode range is
desirable, refer to the description of ICL7612 above.
IQ = 10μA - IQ pin to V+
The user is cautioned that, due to extremely high input
impedances, care must be exercised in layout, construction,
board cleanliness, and supply filtering to avoid hum and
noise pickup.
IQ = 100μA - IQ pin to ground. If this is not possible, any
voltage from V+ - 0.8 to V- +0.8 can be used.
IQ = 1mA - IQ pin to VNOTE: The output current available is a function of the quiescent
current setting. For maximum peak-to-peak output voltage swings
into low impedance loads, IQ of 1mA should be selected.
Typical Applications
Note that in no case is IQ shown. The value of IQ must be
chosen by the designer with regard to frequency response
and power dissipation.
Output Stage and Load Driving Considerations
Each amplifiers’ quiescent current flows primarily in the
output stage. This is approximately 70% of the IQ settings.
This allows output swings to almost the supply rails for
output loads of 1MΩ, 100kΩ, and 10kΩ, using the output
stage in a highly linear class A mode. In this mode,
crossover distortion is avoided and the voltage gain is
maximized. However, the output stage can also be operated
in Class AB for higher output currents. (See graphs under
Typical Operating Characteristics). During the transition from
Class A to Class B operation, the output transfer
characteristic is non-linear and the voltage gain decreases.
VIN
VOUT
ICL7612
RL ≥10k
FIGURE 1. SIMPLE FOLLOWER (NOTE 4)
+5
VIN
+5
VOUT
TO CMOS OR
LPTTL LOGIC
ICL7612
100k
Input Offset Nulling
1M
Offset nulling may be achieved by connecting a 25k pot
between the BAL terminals with the wiper connected to V+.
At quiescent currents of 1mA and 100μA the nulling range
provided is adequate for all VOS selections; however with
6
NOTE:
4. By using the ICL7612 in this application, the circuit will follow rail
to rail inputs.
FIGURE 2. LEVEL DETECTOR (NOTE 4)
FN2919.9
April 26, 2007
ICL7611, ICL7612
1μF
1M
ICL7611
ICL7611
VOUT
ICL7611
λ
1M
1M
VV+
DUTY CYCLE
680kΩ
WAVEFORM GENERATOR
NOTE: Since the output range swings exactly from rail to rail, frequency
and duty cycle are virtually independent of power supply variations.
NOTE: Low leakage currents allow integration times up to several
hours.
FIGURE 4. PRECISE TRIANGLE/SQUARE WAVE
GENERATOR
FIGURE 3. PHOTOCURRENT INTEGRATOR
1M
+8V
VOH
0.5μF 10k
VIN
20k
2.2M
10μF
TO
SUCCEEDING
INPUT
STAGE
20k
ICL7611
1.8k = 5%
SCALE
ADJUST
OUT
IQ
VOL
V-
V+
ICL7611
COMMON
TA = +125°C
+ V+
-8V
FIGURE 6. BURN-IN AND LIFE TEST CIRCUIT
FIGURE 5. AVERAGING AC TO DC CONVERTER FOR A/D
CONVERTERS SUCH AS ICL7106, ICL7107,
ICL7109, ICL7116, ICL7117
VIN
BAL
VOUT
+ BAL
25k
V+
FIGURE 7. VOS NULL CIRCUIT
7
FN2919.9
April 26, 2007
ICL7611, ICL7612
0.2μF
30k
0.2μF
0.2μF
160k
680k
100k
51k
ICL7611
ICL7611
360k
INPUT
0.1μF
0.2μF
1M
0.1μF
360k (NOTE 5)
OUTPUT
1M
(NOTE 5)
NOTES:
5. Note that small capacitors (25pF to 50pF) may be needed for stability in some cases.
6. The low bias currents permit high resistance and low capacitance values to be used to achieve low frequency cutoff. fC = 10Hz, AVCL = 4,
Passband ripple = 0.1dB.
FIGURE 8. FIFTH ORDER CHEBYCHEV MULTIPLE FEEDBACK LOW PASS FILTER
Typical Performance Curves
104
10k
V+ - V- = 10V
NO LOAD
NO SIGNAL
IQ = 1mA
SUPPLY CURRENT (μA)
SUPPLY CURRENT (μA)
TA = +25°C
NO LOAD
NO SIGNAL
1k
IQ = 100μA
100
IIQQ == 10μA
1mA
10
1
4
6
8
10
SUPPLY VOLTAGE (V)
12
14
100
10
1.0
100
FIGURE 11. INPUT BIAS CURRENT vs TEMPERATURE
8
IQ = 100μA
IQ = 10μA
10
-25
50
75
100
125
FIGURE 10. SUPPLY CURRENT PER AMPLIFIER vs FREE-AIR
TEMPERATURE
DIFFERENTIAL VOLTAGE GAIN (kV/V)
INPUT BIAS CURRENT (pA)
VS = ±5V
50
75
FREE-AIR TEMPERATURE (°C)
102
1000
-25
IQ = 1mA
1
-50
16
FIGURE 9. SUPPLY CURRENT PER AMPLIFIER vs SUPPLY
VOLTAGE
0.1
-50
103
125
1000
VSUPP = 10V
VOUT = 8V
RL = 1MΩ
IQ = 10μA
100
RL = 100kΩ
IQ = 100μA
RL = 10kΩ
IQ = 1mA
10
1
-75
-50
-25
50
75
100
125
FIGURE 12. LARGE SIGNAL DIFFERENTIAL VOLTAGE GAIN
vs FREE-AIR TEMPERATURE
FN2919.9
April 26, 2007
ICL7611, ICL7612
(Continued)
105
IQ = 100μA
IQ = 1mA
104
103
PHASE SHIFT
(IQ = 1mA)
102
90
135
10
IQ = 10μA
1
0.1
1.0
10
100
1k
10k
FREQUENCY (Hz)
180
1M
100k
SUPPLY VOLTAGE REJECTION RATIO (dB)
FIGURE 13. LARGE SIGNAL FREQUENCY RESPONSE
VSUPP = 10V
95
90
IQ = 100μA
85
IQ = 10μA
80
75
70
65
-75
-50
-25
50
IQ = 10μA
95
IQ = 100μA
90
IQ = 1mA
85
80
75
70
-75
-50
-25
25
50
75
100
125
75
100
125
600
TA = +25°C
3V ≤ VSUPP ≤ 16V
500
400
300
200
100
100
FIGURE 15. POWER SUPPLY REJECTION RATIO vs FREE-AIR
TEMPERATURE
1k
FREQUENCY (Hz)
10k
100k
FIGURE 16. EQUIVALENT INPUT NOISE VOLTAGE vs
FREQUENCY
16
16
TA = +25°C
14
IQ = 1mA
VSUPP
= ±8V
12
MAXIMUM OUTPUT VOLTAGE (VP-P)
FIGURE 14. COMMON MODE REJECTION RATIO vs FREE-AIR
TEMPERATURE
100
IQ = 1mA
VSUPP = 10V
100
EQUIVALENT INPUT NOISE VOLTAGE (nV/√Hz)
106
COMMON MODE REJECTION RATIO (dB)
105
TA = +25°C
VSUPP = 15V
PHASE SHIFT (°)
DIFFERENTIAL VOLTAGE GAIN (V/V)
107
IQ = 10μA
IQ = 100μA
10
8
VSUPP
= ±5V
6
4
2
VSUPP
= ±2V
1k
10k
100k
FREQUENCY (Hz)
1M
FIGURE 17. OUTPUT VOLTAGE vs FREQUENCY
9
10M
VSUPP = 10V
IQ = 1mA
14
12
10
TA = -55°C
8
TA = +25°C
6
TA = +125°C
4
2
10k
100k
1M
FREQUENCY (Hz)
10M
FIGURE 18. OUTPUT VOLTAGE vs FREQUENCY
FN2919.9
April 26, 2007
ICL7611, ICL7612
(Continued)
12
TA = +25°C
16
14
12
RL = 100kΩ - 1MΩ
10
RL = 10kΩ
8
6
4
2
4
6
8
10
12
SUPPLY VOLTAGE (V)
14
6
RL = 2kΩ
4
VSUPP = 10V
IQ = 1mA
2
-50
-25
50
75
125
0.01
40
IQ = 1mA
30
4
6
8
10
12
14
IQ = 10μA
0.1
IQ = 100μA
1.0
IQ = 1mA
10
16
4
6
8
10
SUPPLY VOLTAGE (V)
SUPPLY VOLTAGE (V)
FIGURE 21. OUTPUT SOURCE CURRENT vs SUPPLY VOLTAGE
12
10
8
6
4
2
14
16
8
TA = +25°C
V+ - V- = 10V
IQ = 1mA
INPUT AND OUTPUT VOLTAGE (V)
14
12
FIGURE 22. OUTPUT SINK CURRENT vs SUPPLY VOLTAGE
16
100
FIGURE 20. OUTPUT VOLTAGE vs FREE-AIR TEMPERATURE
MAXIMUM OUTPUT SINK CURRENT (mA)
MAXIMUM OUTPUT SOURCE CURRENT (mA)
RL = 10kΩ
8
16
FIGURE 19. OUTPUT VOLTAGE vs SUPPLY VOLTAGE
RL = 100kΩ
10
6
TA = +25°C, VSUPP = 10V
RL = 10kΩ, CL = 100pF
4
2
OUTPUT
INPUT
-4
-6
1.0
10
LOAD RESISTANCE (kΩ)
FIGURE 23. OUTPUT VOLTAGE vs LOAD RESISTANCE
10
100
4
6
TIME (μs)
8
10
12
FIGURE 24. VOLTAGE FOLLOWER LARGE SIGNAL PULSE
RESPONSE (IQ = 1mA)
FN2919.9
April 26, 2007
ICL7611, ICL7612
(Continued)
8
6
RL = 100kΩ, CL = 100pF
8
4
2
OUTPUT
INPUT
-4
-6
6
4
2
OUTPUT
INPUT
-2
-4
-6
60
TIME (μs)
80
100
120
FIGURE 25. VOLTAGE FOLLOWER LARGE SIGNAL PULSE
RESPONSE (IQ = 100μA)
11
RL = 1MΩ, CL = 100pF
400
600
TIME (μs)
800
1000
1200
FIGURE 26. VOLTAGE FOLLOWER LARGE SIGNAL PULSE
RESPONSE (IQ = 10μA)
FN2919.9
April 26, 2007
ICL7611, ICL7612
Small Outline Plastic Packages (SOIC)
M8.15 (JEDEC MS-012-AA ISSUE C)
N
8 LEAD NARROW BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
SYMBOL
-B-
1
2
3
L
SEATING PLANE
-A-
A
D
h x 45°
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
MIN
MAX
MIN
MAX
NOTES
A
0.0532
0.0688
1.35
1.75
A1
0.0040
0.0098
0.10
0.25
B
0.013
0.020
0.33
0.51
9
C
0.0075
0.0098
0.19
0.25
D
0.1890
0.1968
4.80
5.00
3
E
0.1497
0.1574
3.80
4.00
4
e
α
B S
0.050 BSC
0.2284
0.2440
5.80
6.20
h
0.0099
0.0196
0.25
0.50
5
L
0.016
0.050
0.40
1.27
6
α
1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of
Publication Number 95.
1.27 BSC
H
N
NOTES:
MILLIMETERS
8
0°
8
8°
0°
7
8°
Rev. 1 6/05
2. Dimensioning and tolerancing per ANSI Y14.5M-1982.
3. Dimension “D” does not include mold flash, protrusions or gate burrs.
Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006
inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per
side.
5. The chamfer on the body is optional. If it is not present, a visual index
feature must be located within the crosshatched area.
6. “L” is the length of terminal for soldering to a substrate.
7. “N” is the number of terminal positions.
8. Terminal numbers are shown for reference only.
9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater
above the seating plane, shall not exceed a maximum value of
0.61mm (0.024 inch).
10. Controlling dimension: MILLIMETER. Converted inch dimensions
are not necessarily exact.
12
FN2919.9
April 26, 2007
ICL7611, ICL7612
Dual-In-Line Plastic Packages (PDIP)
E8.3 (JEDEC MS-001-BA ISSUE D)
N
8 LEAD DUAL-IN-LINE PLASTIC PACKAGE
E1
INDEX
AREA
1 2 3
INCHES
N/2
-B-
-AD
E
BASE
PLANE
-C-
SEATING
PLANE
A2
A
L
D1
e
B1
D1
A1
eC
B
0.010 (0.25) M
C A B S
MILLIMETERS
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.210
5.33
4
A1
0.015
0.39
4
A2
0.115
0.195
2.93
4.95
B
0.014
0.022
0.356
0.558
C
L
B1
0.045
0.070
1.15
1.77
8, 10
eA
C
0.008
0.014
0.204
C
D
0.355
0.400
9.01
eB
NOTES:
1. Controlling Dimensions: INCH. In case of conflict between
English and Metric dimensions, the inch dimensions control.
5
D1
0.005
0.13
5
E
0.300
0.325
7.62
8.25
6
E1
0.240
0.280
6.10
7.11
5
e
0.100 BSC
eA
0.300 BSC
3. Symbols are defined in the “MO Series Symbol List” in Section
2.2 of Publication No. 95.
eB
L
0.115
4. Dimensions A, A1 and L are measured with the package seated
in JEDEC seating plane gauge GS-3.
0.355
10.16
N
2.54 BSC
7.62 BSC
0.430
0.150
2.93
8
6
10.92
7
3.81
4
8
5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch
(0.25mm).
6. E and eA are measured with the leads constrained to be perpendicular to datum -C- .
9
Rev. 0 12/93
7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater.
8. B1 maximum dimensions do not include dambar protrusions.
Dambar protrusions shall not exceed 0.010 inch (0.25mm).
9. N is the maximum number of terminal positions.
10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3,
E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch
(0.76 - 1.14mm).
All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems.
Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality
Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without
notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and
reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result
from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries.
For information regarding Intersil Corporation and its products, see www.intersil.com
13
FN2919.9
April 26, 2007
