TSP15U100S S1G
TSP15U100S S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMPC(TO-277A)
    肖特基二极管 VR=100V IF=15A IR=250μA TO227A
TSP15U100S S1G 数据手册
TSP15U100S Taiwan Semiconductor 15A, 100V Low VF Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss / high efficiency High forward surge capability Ideal for automated placement Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 15 A VRRM 100 V IFSM 150 A TJ MAX 150 °C Package TO-277A (SMPC) Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: TO-277A (SMPC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.095g (approximately) TO-277A (SMPC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSP15U100S UNIT 15U100 Repetitive peak reverse voltage VRRM 100 V Reverse voltage, total rms value VR(RMS) 70 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 15 A IFSM 150 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: E2103 TSP15U100S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 12 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS Reverse current @ rated VR TYP MAX UNIT IF = 5.0A, TJ = 25°C 0.49 - V IF = 7.5A, TJ = 25°C 0.52 - V 0.62 0.70 V 0.40 - V IF = 7.5A, TJ = 125°C 0.45 - V IF = 15.0A, TJ = 125°C 0.56 0.64 V - 250 µA - 20 mA IF = 15.0A, TJ = 25°C (1) IF = 5.0A, TJ = 125°C (2) TJ = 25°C SYMBOL VF IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSP15U100S TO-277A (SMPC) 6,000 / Tape & Reel 2 Version: E2103 TSP15U100S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 15 CAPACITANCE (pF) 12 9 6 1000 100 3 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 10 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 100 90 100 10010 10 1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.10.30.2 0.4 0.3 0.5 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.5 0.8 0.9 0.9 0.6 0.60.70.7 0.8 1.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 18 8.3ms single half sine wave 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: E2103 1.2 TSP15U100S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-277A (SMPC) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW F 4 = Marking Code = Date Code = Factory Code Version: E2103 TSP15U100S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: E2103
TSP15U100S S1G 价格&库存
很抱歉,暂时无法提供与“TSP15U100S S1G”相匹配的价格&库存,您可以联系我们找货
