SST138C-600E
SST138C-600E
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    SST138C-600E
SST138C-600E 数据手册
SST138C-600E SST138C-800E Technical Data Data Sheet N2169, Rev.- SST138 Series 12A TRIACs Circuit Diagram TO-220C Description SST138 series triacs with low holding and latching current are especially recommended for use on middle and small resistance type power load. Maximum Ratings: Characteristics Symbol Max. Units Tstg - -40-150 ℃ Tj - -40-125 ℃ Repetitive peak off-state voltage(Tj=25℃) VDRM - 600/800 V Repetitive peak reverse voltage(Tj=25℃) VRRM - 600/800 V Non repetitive surge peak Off-state voltage VDSM - VDRM + 100 V Non repetitive peak reverse voltage VRSM - VRRM + 100 V 12 A 95 A A2 s A/μs PGM Ⅰ-Ⅱ-Ⅲ Ⅳ - 45 50 10 2 0.5 W PG(AV) - 5 W Storage junction temperature range Operating junction temperature range RMS on-state current Non repetitive surge peak on-state current (tp=20ms) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG =2×IGT) Peak gate current ITSM I2t dI/dt IGM Average gate power dissipation Peak gate power I(TRMS) Condition TO-220C(TC=110℃) -  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  A SST138C-600E SST138C-800E Technical Data Data Sheet N2169, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol Test Condition Quadrant Ⅰ-Ⅱ-Ⅲ IGT VD=12V RL=33Ω Ⅳ VGT VGD VD=VDRM Tj=125℃ RL=3.3KΩ Value Unit 10 MAX mA 25 ALL MAX 1.5 V ALL MIN 0.2 V Ⅰ- Ⅲ 30 IL IG=1.2IGT IH IT=100mA MAX 25 mA VD=2/3VDRM Gate Open Tj=125℃ MIN 50 V/μs dV/dt Ⅱ- Ⅳ MAX mA 40 Static Characteristics Symbol VTM IDRM IRRM Condition Max. Units Value Units 1.4 ℃/W 1.6 5 1 ITM=15A tp=380μs,Tj=25℃ VD=VDRM VR=VRRM, Tj=25℃ VD=VDRM VR=VRRM, Tj=125℃ V μA mA Thermal Resistances Symbol Rth(j-c) Condition Junction to case(AC) TO-220AC Ordering Information S ST 138 C -600 E SMC Diode Solutions Triacs E:IGT1-3 ≤ 10mA IGT4 ≤ 25mA IT(RMS):12A 600:VDRM/VRRM ≥ 600V 800:VDRM/VRRM ≥ 800V C:TO-220C Device SST138C-600E SST138C-800E Package Shipping TO-220C 50pcs/ Tube  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST138C-600E SST138C-800E Technical Data Data Sheet N2169, Rev.- Marking Diagram Where XXXXX is YYWWL SST138C-600E YY WW L = Part name = Year = Week = Lot Number Mechanical Dimensions TO-220C SYMBOL A B C C2 C3 D E F G H L1 L2 L3 ϕ Millimeters Min. 4.40 0.70 0.45 1.23 2.20 8.90 9.90 6.30 28.0 1.14 2.65 Typ. 2.54 3.39 3.6 Inches Max. Min. 4.60 0.90 0.60 1.32 2.60 9.90 10.3 6.90 0.173 0.028 0.018 0.048 0.087 0.350 0.39 0.248 29.8 1.102 1.70 2.95 0.045 0.104 Typ. Max. 0.181 0.035 0.024 0.052 0.102 0.390 0.406 0.272 0.1 0.133 0.142 1.173 0.067 0.116 Ratings and Characteristics Curves FIG.1: Maximum power dissipation versus RMS on-state current FIG.2: RMS on-state current versus case temperature IT(RMS) (A) 18 P(w) 20 α=180° 15 15 TO-220C 12 10 9 6 5 0 0 3 3 IT(RMS) (A) 6 9 12 15 0 0 Tc (℃) 25 50 75 100 FIG.3: Surge peak on-state current versus FIG.4: On-state characteristics (maximum  China - Germany - Korea - Singapore - United States  number of cycles values)  http://www.smc-diodes.com - sales@ smc-diodes.com  ITSM (A) 105 90 100 t=20ms One cycle ITM (A) 125 10 9 6 5 SST138C-600E SST138C-800E 3 Technical Data IT(RMS) (A) 0 Data Sheet 0 N2169, 3 Rev.- 6 9 12 Tc (℃) 0 0 15 FIG.3: Surge peak on-state current versus number of cycles 25 50 75 FIG.4: On-state characteristics (maximum values) t=20ms One cycle 90 75 Tj=Tjmax 60 10 45 30 Tj=25℃ 15 Number of cycles 10 100 0 1 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST138C-600E 价格&库存
很抱歉,暂时无法提供与“SST138C-600E”相匹配的价格&库存,您可以联系我们找货
SST138C-600E
    • 1+12.110851+1.56980
