NJU7056F-TE1
NJU7056F-TE1
    JRC(⽇本无线)
    SOT23-5
    IC CMOS 1 CIRCUIT SOT23-5
NJU7056F-TE1 数据手册
NJU7056/NJU7057/NJU7058 Low Noise, Low Offset Voltage Drift, Rail-to-Rail Output, Excellent EMI Immunity, CMOS Operational Amplifier ■ FEATURES (V+=5V, V-=0V, Ta=25°C) ●Low Noise ●Low Offset Voltage Drift ●Offset Voltage ●Rail-to-Rail Output RL=10kΩ RL=600Ω ●Gain Bandwidth Product ●Slew Rate ●Supply Current ●Supply Voltage ●Thin and Ultra Small Package ■ DESCRIPTION 15nV/√Hz 0.7µV/°C typ. 4mV max. 50mV from rail 140mV from rail 2.1MHz 0.8V/µs 260µA/ch typ. 1.8V to 5.5V DFN8-U1(ESON8-U1) 2.0 x 2.0 x 0.4 mm ●Integrated EMI Filter ●Ground Sensing ●Unity-Gain Stable ●Package NJU7056 NJU7057 EMIRR=59dB typ. @f=900MHz SOT-23-5, SC-88A MSOP8(TVSP8)* DFN8-U1(ESON8-U1) *meet JEDEC MO-187-DA / thin type NJU7058 The NJU7056/NJU7057/NJU7058 are Single/Dual/ Quad rail-to-rail output CMOS operational amplifiers. Low noise of 15nV/√Hz and low offset drift of 0.7µV/°C typ. make them suitable for several sensor amplifiers and preamplifiers. NJU7056/NJU7057/NJU7058 operate from 1.8V to 5.5V supply voltage. They are optimized for 2-cell battery systems and 1-cell Li-ion battery systems. The NJU7056/NJU7057/NJU7068 have high-impedance inputs with ground sensing, rail-to-rail output that swings within 50mV from rail with 10kΩ load at 1.8V supply, 2.1MHz gain bandwidth and 0.8V/µs Slew rate. These characteristics make them excellent performance for general-purpose applications. The NJU7056 is available in 5-pin SC-88A and SOT23 packages. NJU7057 is offered in 8-pin MSOP (TVSP): meet JEDEC MO-187-DA / thin type package and DFN that is thin and 2mm square small package. NJU7058 is offered in 14-pin SSOP package. SSOP14 ■ APPLICATIONS ■ RELATED PRODUCTS ●Battery-Powered Instruments ●Current Sensor Amplifiers ●Audio Pre/Microphone Amplifiers ●Power Line Monitoring ●Current to Voltage Converter Features Single 13µA/ch, Rail-to-Rail Output (Low power type) 9V/µs, 5MHz, Rail-to-Rail I/O (High slew rate type) Dual Quad NJU7026 NJU7027 NJU7028 NJU7046 NJU7047 NJU7048 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Temperature Voltage Noise Density vs. Frequency V+=5V, Ta=25ºC Input Offset Voltage [mV] Equivalent Input Noise Voltage [nV/√Hz] 70 60 50 40 30 20 2 1 0 -1 -2 10 -3 0 10 Ver.9.1 V+=5V, VICM=0V, n=130 3 80 100 1k Frequency [Hz] 10k -50 http://www.njr.com/ -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -1- NJU7056/NJU7057/NJU7058 ■ PIN CONFIGURATIONS PRODUCT NAME NJU7056F Package SOT-23-5 NJU7056F3 SC-88A (Top View) +INPUT 1 V- 2 -INPUT 3 Pin Functions 5 V+ 4 OUTPUT PRODUCT NAME NJU7057RB1 NJU7057KU1 Package MSOP8 (TVSP8) ESON8-U1 (Top View) (Top View) Pin Functions A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A +INPUT 3 6 B -INPUT V- 4 5 B +INPUT A OUTPUT 1 A -INPUT 2 A +INPUT 3 V- 4 Exposed Pad on Underside 8 V+ 7 B OUTPUT 6 B -INPUT 5 B +INPUT *Connect to exposed pad to V- PRODUCT NAME NJU7058V (Top View) SSOP14 Package A OUTPUT 1 14 D OUTPUT A -INPUT 2 13 D -INPUT A +INPUT 3 12 D +INPUT V+ 4 11 V- B +INPUT 5 10 C +INPUT B -INPUT 6 9 C -INPUT B OUTPUT 7 8 C OUTPUT Pin Functions ■ PRODUCT NAME INFORMATION NJU7057 RB1 (TE1) Part Number Package Taping Form ■ ORDERING INFORMATION PRODUCT PACKAGE NAME NJU7056F SOT-23-5 NJU7056F3 SC-88A NJU7057RB1 MSOP8(TVSP8) NJU7057KU1 DFN8-U1 (ESON8-U1) NJU7058V SSOP14 Ver.9.1 RoHS HALOGENFREE TERMINAL FINISH MARKING WEIGHT (mg) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi 115 AG 7057 7057 7058 15 7.5 18 5.3 65 http://www.njr.com/ MOQ (pcs) 3000 3000 2000 3000 2000 -2- NJU7056/NJU7057/NJU7058 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL V+- Supply Voltage Input Voltage (1) Input Current (2) Differential Input Voltage (3) Power Dissipation(Ta=25℃) SOT-23-5(4) SC-88A(4) MSOP8 (TVSP8) (4) DFN8-U1 (ESON8-U1) (5) SSOP14(4) Junction Temperature Range Storage Temperature Range V- RATING UNIT 7 - 0.3 to V+ + 0.3 10 ±7 2-Layer / 4-Layer 480 / 650 360 / 490 510 / 680 450 / 1200 500 / 620 150 - 55 to 150 V V mA V V- VIN IIN VID PD Tjmax Tstg mW °C °C (1) The absolute maximum input voltage is limited at 7V. (2) Input voltages outside the supply voltage will be clamped by ESD protection diodes. If the input voltage exceeds the supply voltage, the input current must be limited 10 mA or less by using a restriction resistance. (3) Differential voltage is the voltage difference between +INPUT and - INPUT. For supply voltage less than 7V, the absolute maximum rating is equal to the supply voltage. ■ THERMAL CHARACTERISTICS PARAMETER SYMBOL Junction-to-ambient thermal resistance SOT-23-5(4) SC-88A(4) MSOP8 (TVSP8)(4) DFN8-U1 (ESON8-U1)(5) SSOP14(5) Junction-to-Top of package characterization parameter SOT-23-5(4) SC-88A(4) MSOP8 (TVSP8)(4) DFN8-U1 (ESON8-U1) (5) SSOP14(4) VALUE 2-Layer / 4-Layer 259 / 193 352 / 256 244 / 185 278 / 107 249 / 201 2-Layer / 4-Layer 67 / 58 91 / 73 51 / 45 42 / 25 53 / 52 θja ψjt UNIT °C /W °C /W (4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2-layer FR-4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4-layer FR-4), internal Cu area: 74.2 x 74.2mm (5) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2-layer FR-4, with Exposed Pad) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4-layer FR-4, with Exposed Pad) *For 4-layer: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) ■ POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 2-Layer 4-Layer 600 MSOP8(TVSP8) Power Dissipation PD [mW] Power Dissipation PD [mW] 700 500 SSOP14 400 300 SOT-23-5 200 DFN8-U1(ESON8-U1) 100 SC-88A 0 0 Ver.9.1 25 50 75 100 125 Ambient Temperature [ºC] 150 1300 1200 1100 1000 900 800 700 600 500 400 300 200 100 0 DFN8-U1(ESON8-U1) MSOP8(TVSP8) SOT-23-5 SSOP14 SC-88A 0 http://www.njr.com/ 25 50 75 100 125 Ambient Temperature [ºC] 150 -3- NJU7056/NJU7057/NJU7058 ■ RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Single Supply Dual Supply Operating Temperature Range SYMBOL RATING UNIT V+- VV+ / VTopr 1.8 to 5.5 ±0.9 to ±2.75 - 40 to 125 V °C ■ ELECTRICAL CHARACTERISTICS (V+=5V, V-=0V, Ta=25°C, unless otherwise noted.) PARAMETER DC CHARACTERISTICS Input Offset Voltage Input Offset Voltage Drift Input Bias Current Input Offset Current Open-Loop Voltage Gain Common-Mode Rejection Ratio Supply Voltage Rejection Ratio Common-Mode Input Voltage Range SYMBOL VIO ΔVIO/ΔT IB IIO AV CMR SVR VICM High-Level Output Voltage VOH Low-Level Output Voltage VOL Supply Current (All Amplifiers) NJU7056 NJU7057 NJU7058 AC CHARACTERISTICS Slew Rate(6) Gain Bandwidth Product ISUPPLY SR GBW Phase Margin Gain Margin ΦM GM Equivalent Input Noise Voltage VNI Total Harmonic Distortion + Noise Channel Separation THD+N CS TEST CONDITIONS VCOM=0V Ta = -40°C to 125°C RL=10kΩ to 2.5V VICM=0V to 4.1V V+=1.8V to 5.5V CMR≥65dB RL=10kΩ to 2.5V RL=10kΩ to 0V ISOURCE=2mA RL=10kΩ to 2.5V RL=10kΩ to 0V ISINK=2mA No Signal GV=0dB, RL=10kΩ to 2.5V, CL=20pF, VIN=3VPP (1V to 4V) RL=10kΩ to 2.5V, CL=20pF, f=100kHz RL=10kΩ to 2.5V, CL=20pF RL=10kΩ to 2.5V, CL=20pF f=1kHz GV=6dB, VO=4VPP, f=1kHz f=1kHz, NJU7057/NJU7058 MIN TYP MAX UNIT 70 65 70 0 4.9 4.9 4.8 - 0.8 0.7 1 1 90 80 90 4.95 4.95 4.85 0.05 0.02 0.15 4 4.1 0.1 0.05 0.2 mV µV/°C pA pA dB dB dB V - 0.26 0.52 1.1 0.42 0.84 1.7 - 0.8 - V/µs - 2.1 - MHz - 80 10 - deg dB - 15 - nV/√Hz - 0.002 - % - -120 - dB V V mA (6) Slew rate is defined by the lower value of the rise or fall. Ver.9.1 http://www.njr.com/ -4- NJU7056/NJU7057/NJU7058 ■ ELECTRICAL CHARACTERISTICS (continued) (V+=1.8V, V-=0V, Ta=25°C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT 65 65 70 0 1.7 1.7 1.5 - 0.8 0.8 1 1 90 80 90 1.75 1.75 1.55 0.05 0.02 0.25 4 0.9 0.1 0.05 0.3 mV µV/°C pA pA dB dB dB V - 0.22 0.44 0.9 0.38 0.76 1.5 - 0.6 - V/µs - 1.7 - MHz - 80 13 18 0.005 - deg dB nV/√Hz % - -110 - dB DC CHARACTERISTICS Input Offset Voltage Input Offset Voltage Drift Input Bias Current Input Offset Current Open-Loop Voltage Gain Common-Mode Rejection Ratio Supply Voltage Rejection Ratio Common-Mode Input Voltage Range VIO ΔVIO/ΔT IB IIO AV CMR SVR VICM High-Level Output Voltage VOH Low-Level Output Voltage VOL Supply Current (All Amplifiers) NJU7056 NJU7057 NJU7058 AC CHARACTERISTICS Slew Rate(6) Gain Bandwidth Product Phase Margin Gain Margin Equivalent Input Noise Voltage Total Harmonic Distortion + Noise Channel Separation ISUPPLY SR GBW ΦM GM VNI THD+N CS VCOM=0V Ta = -40°C to 125°C RL=10kΩ to 0.9V VICM=0V to 0.9V V+=1.8V to 5.5V CMR≥65dB RL=10kΩ to 0.9V RL=10kΩ to 0V ISOURCE=1mA RL=10kΩ to 0.9V RL=10kΩ to 0V ISINK=1mA No Signal GV=0dB, RL=10kΩ to 0.9V, CL=20pF, VIN=0.5VPP (0.3V to 0.8V) RL=10kΩ to 0.9V, CL=20pF, f=100kHz RL=10kΩ to 0.9V, CL=20pF RL=10kΩ to 0.9V, CL=20pF f=1kHz GV=6dB, VO=1VPP, f=1kHz f=1kHz, NJU7057/NJU7058 V V mA (6) Slew rate is defined by the lower value of the rise or fall. Ver.9.1 http://www.njr.com/ -5- NJU7056/NJU7057/NJU7058 ■ TYPICAL CHARACTERISTICS Input Offset Voltage Distribution Input Offset Voltage Distribution V+=5V, VICM=0V, Ta=25ºC, n=130 35% 30% Percent of Amplifiers 30% Percent of Amplifiers V+=1.8V, VICM=0V, Ta=25ºC, n=130 35% 25% 20% 15% 10% 25% 20% 15% 10% 5% 5% 0% 0% -3.0 -2.0 -1.0 0.0 1.0 2.0 Input Offset Voltage [mV] -3.0 3.0 Input Offset Voltage Drift Distribution 40% Percent of Amplifiers Percent of Amplifiers V+=1.8V, VICM=0V, Ta=25ºC, n=130 50% 30% 20% 10% 40% 30% 20% 10% 0% 0% -4.2 -2.8 -1.4 0.0 1.4 2.8 Input Offset Voltage Drift [μV/ºC] 4.2 -4.8 Input Offset Voltage vs. Temperature 2 1 0 -1 -2 4.8 V+=1.8V, VICM=0V, n=130 3 Input Offset Voltage [mV] Input Offset Voltage [mV] -3.2 -1.6 0.0 1.6 3.2 Input Offset Voltage Drift [μV/ºC] Input Offset Voltage vs. Temperature V+=5V, VICM=0V, n=130 3 2 1 0 -1 -2 -3 -3 -50 Ver.9.1 3.0 Input Offset Voltage Drift Distribution V+=5V, VICM=0V, Ta=25ºC, n=130 50% -2.0 -1.0 0.0 1.0 2.0 Input Offset Voltage [mV] -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 http://www.njr.com/ -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -6- NJU7056/NJU7057/NJU7058 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage V+=5V 1.5 1.0 1.0 Input Offset Voltage [mV] Input Offset Voltage [mV] Input Offset Voltage vs. Supply Voltage 1.5 0.5 Ta=25ºC Ta=-40ºC 0.0 -0.5 -1.0 Ta=125ºC -1.5 Ta=-40ºC -0.5 -1.0 Ta=125ºC -2.0 0 1 2 3 4 5 Supply Voltage V+ [V] 6 7 -1 Input Offset Voltage vs. Common-Mode Input Voltage Common-Mode and Supply Voltage Rejection Ratio [dB] 1.5 1.0 0.5 Ta=-40ºC Ta=25ºC 0.0 -0.5 -1.0 Ta=125ºC -1.5 -2.0 -0.9 -0.6 -0.3 0 0.3 0.6 0.9 1.2 1.5 1.8 Common-Mode Input Voltage [V] 110 SVR 100 90 80 CMR(V+=5V) 70 CMR(V+=1.8V) 60 50 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Bias Current vs. Temperature RL=10kΩ to V+/2 VCM=V+/2 100n 120 10n Input Bias Current [A] Open-Loop Voltage Gain [dB] 5 120 Open-Loop Voltage Gain vs. Temperature 130 0 1 2 3 4 Common-Mode Input Voltage [V] Common-Mode and Supply Voltage Rejection Ratio vs. Temperature 130 V+=1.8V 110 V+=5V 100 90 80 V+=1.8V 70 1n 100p V+=5V 10p V+=1.8V 1p 60 50 100f -50 Ver.9.1 Ta=25ºC 0.0 -1.5 -2.0 Input Offset Voltage [mV] 0.5 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] 0 http://www.njr.com/ 25 50 75 100 125 Ambient Temperature [ºC] 150 -7- NJU7056/NJU7057/NJU7058 ■ TYPICAL CHARACTERISTICS Maximum Output Voltage vs. Output Current Maximum Output Voltage vs. Output Current V+=5V V+=1.8V 5.0 1.8 4.0 3.0 Ta=125ºC 2.0 Ta=25ºC Ta=-40ºC 1.0 ISINK 1.4 1.2 1.0 Ta=125ºC 0.8 0.6 Ta=25ºC 0.4 Ta=-40ºC ISINK 0.2 Ta=25ºC Ta=25ºC 0.0 0.0 30 60 Output Current [mA] 90 0 Maximum Output Voltage vs. Load Resistance Ta=25ºC Ta=-40ºC 1.5 Ta=125ºC VOL 1 1.0 0.5 0 10 High-level Output Voltage V OH [V] 3 Low-level Output Voltage VOL [mV] 4 2 0.0 100k 100 1k 10k Load Resistance RL [Ω] VOH 1.6 Ta=-40ºC 1.4 1.2 1.0 Ta=25ºC 0.8 Ta=-40ºC 0.6 3 Ta=125ºC VOL 0.4 2 0.2 1 0.0 10 Maximum Output Voltage vs. Load Resistance 100 1k 10k Load Resistance RL [Ω] 0 100k Maximum Output Voltage vs. Load Resistance V+/V-=±2.5V, Gv=open, RL connected to 0V 2.5 V+=1.8V, Gv=open, RL connected to 0V 1.8 VOH Ta=-40ºC 10 Maximum Output Voltage vs. Load Resistance V+=5V, Gv=open, RL connected to 0V 5 5 Output Current [mA] Low-level Output Voltage VOL [mV] 0 High-level Output Voltage V OH [V] ISOURCE 1.6 Maximum Output Voltage [V] Maximum Output Voltage [V] ISOURCE V+/V-=±0.9V, Gv=open, RL connected to 0V 0.9 1.5 Maximum Output Voltage [V] Maximum Output Voltage [V] 2.0 Ta=-40ºC 1.0 Ta=25ºC 0.5 Ta=125ºC 0.0 -0.5 Ta=25ºC -1.0 -1.5 Ta=-40ºC 0.6 Ta=-40ºC Ta=25ºC 0.3 Ta=125ºC 0.0 -0.3 Ta=25ºC Ta=-40ºC -0.6 -2.0 -2.5 -0.9 10 Ver.9.1 100 1k 10k Load Resistance RL [Ω] 100k 10 http://www.njr.com/ 100 1k 10k Load Resistance RL [Ω] 100k -8- NJU7056/NJU7057/NJU7058 ■ TYPICAL CHARACTERISTICS Supply Current per Amplifler vs. Temperture Supply Current per Amplifer vs. Supply Voltage AV=0dB AV=0dB 0.40 0.35 0.35 Supply Current per Amplifier [mA] Ta=25ºC 0.30 0.25 0.20 0.15 Ta=125ºC Ta=-40ºC 0.10 0.05 0.00 0 1 2 3 4 5 Supply Voltage V+ [V] 6 V+=5V 0.30 0.25 0.20 0.15 V+=1.8V 0.10 0.05 0.00 -50 7 40dB Voltage Gain vs. Frequency V+=1.8V, GV=40dB, RL=10kΩ to V+/2, Ta=25ºC 60 Gain Gain 40 Phase 0 0 CL=330pF CL=100pF -20 -40 -60 -120 CL=330pF Phase [deg] CL=20pF 20 Voltage Gain [dB] 40 Voltage Gain [dB] 0 25 50 75 100 125 150 Ambient Temperature [ºC] 40dB Voltage Gain vs. Frequency V+=5V, GV=40dB, RL=10kΩ to V+/2, Ta=25ºC 60 -25 CL=20pF 20 Phase 0 0 CL=330pF CL=100pF -20 -40 1k 10k 100k Frequency [Hz] 1M -180 10M CL=20pF -60 1k 100k Frequency [Hz] 1M GBW vs. Temperature Pulse Response V+=5V, GV=0dB, RL=10kΩ to V+/2, Ta=25ºC -180 10M 2.8 V+=5V 2.4 2.0 1.6 1.2 CL=20pF CL=100pF V+=1.8V CL=330pF 0.8 0.4 -50 Ver.9.1 10k f=100kHz, RL=10kΩ to V+/2, CL=20pF Voltage [1V/div] Gain Bandwidth Product GBW [MHz] 3.2 -120 CL=100pF CL=20pF -60 -60 CL=330pF CL=100pF Phase [deg] SUpply Current per Amplifier [mA] 0.40 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] http://www.njr.com/ Time [2μs/div] -9- NJU7056/NJU7057/NJU7058 ■ TYPICAL CHARACTERISTICS Slew Rate vs. Temperature Voltage Noise Density vs. Frequency GV=0dB, RL=100kΩ, CL=10pF 1.8 V+=5V, Ta=25ºC Equivalent Input Noise Voltage [nV/√Hz] 80 Slew Rate [V/μs] 1.6 Rise(V+=5V) 1.4 1.2 Fall(V+=5V) 1.0 Rise(V+=1.8V) 0.8 0.6 70 60 50 40 30 20 10 Fall(V+=1.8V) 0.4 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] 10 100 1k Frequency [Hz] 10k THD+N vs. Output Voltage V+=5V, Gv=6V, Ta=25ºC THD+N [%] 1 0.1 f=1kHz 0.01 f=500Hz f=100Hz 0.001 0.01 Ver.9.1 0.1 1 Output Voltage Vpp [Vpp] 10 http://www.njr.com/ - 10 - NJU7056/NJU7057/NJU7058 ■ TEST CIRCUITS ● ISUPPLY ● VIO, CMR, SVR VCOM=V+/2 RG=50Ω, RF=50kΩ V+ RF A V+ RG VO RG VCOM VCOM V- RF VVS=V+-V- ● VOH, VOL ● GBW VOH; Vin+ = V+/2 +0.3V , Vin- = V+/2, VCOM=V+/2, V+ + + RG=1kΩ, RF=100kΩ - VOL; Vin+ = V /2 , Vin- = V /2 +0.3V, VCOM=V /2, V RF V+ V+ VO RG RL Vin+ Vin- VO V- VCOM 50Ω V- CL V+ VO V/I Source Vin+ Vin- V- ● SR 90% V+ Vo VO 50Ω Ver.9.1 V- RL 90% ΔV ΔV 10% Δt Δt 10% CL http://www.njr.com/ - 11 - NJU7056/NJU7057/NJU7058 ■ APPLICATION NOTE Single and Dual Supply Voltage Operation The NJU7056/NJU7057/NJU7058 works with both single supply and dual supply when the voltage supplied is between V+ and V−. These amplifiers operate from single +1.8 to +5.5V supply and dual ±0.9V to ±2.75V supply. Common-Mode Input Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of commonmode input voltage is as follows: − + VICM (typ.) = V to V -0.9 (Ta = 25°C) Difference of VICM when Temperature change, refer to typical characteristic graph. During designing, consider variations in characteristics for use with allowance. Maximum Output Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of the typ. value of the maximum output voltage is as follows: VOM (typ.) = V-+50mV to V+-50mV (RL=20kΩ to V+/2, Ta=25°C) During designing, consider variations in characteristics and temperature characteristics for use with allowance. In addition, also note that the output voltage range becomes narrow as shown in typical characteristics graph when an output current increases. Input Voltage Exceeding the Supply Voltage Inputs of the NJU7056/NJU7057/NJU7058 are protected by ESD diodes (shown in Figure1) that will conduct if the input voltages exceed the power supplies by more than approximately 300mV. Momentary voltages greater than 300mV beyond the power supply, inputs can be tolerated if the current is limited to 10mA. Figure2 is easily accomplished with an input resistor. If the input voltage exceeds the supply voltage, the input current must be limited 10mA or less by using a restriction resistance (RLIMIT) as shown in figure2. V+ Current Limit 10mA Vin Vout RLIMIT VFigure2. Input Current Protection for Voltages exceeding the Supply Voltage. Capacitive Load The NJU7056/NJU7057/NJU7058 can use at unity gain follower, but the unity gain follower is the most sensitive configuration to capacitive loading. The combination of capacitive load placed directly on the output of an amplifier along with the output impedance of the amplifier creates a phase lag which in turn reduces the phase margin of the amplifier. If phase margin is significantly reduced, the response will cause overshoot and ringing in the step response. The NJU7056/NJU7057/NJU7058 is unity gain stable for capacitive loads of 200pF. To drive heavier capacitive loads, an isolation resistor, RISO as shown Figure3, should be used. RISO improves the feedback loop’s phase margin by making the output load resistive at higher frequencies. The larger the value of RISO, the more stable the output voltage will be. However, larger values of RISO result in reduced output swing, reduced output current drive and reduced frequency bandwidth. V+ R Vin ISO Vout C L VV+ Figure3. Isolating capacitive load +INPUT OUTPUT -INPUT V- Figure1. Simplified Schematic Ver.9.1 http://www.njr.com/ - 12 - NJU7056/NJU7057/NJU7058 ■ APPLICATION NOTE EMIRR (EMI Rejection Ratio) Definition EMIRR is a parameter indicating the EMI robustness of an Op-Amp. The definition of EMIRR is given by the following equation1. EMIRR = 20 ∙ log ൬ Vୖ୊_୔୉୅୏ ൰ |∆V୍୓ | − − − eq. 1 Vୖ୊_୔୉୅୏ : RF Signal Amplitude [VP] ∆V୍୓ : Input offset voltage shift quantity [V] The tolerance of the RF signal can be grasped by measuring an RF signal and offset voltage shift quantity. Offset voltage shift is small so that a value of EMIRR is big. And it understands that the tolerance for the RF signal is high. In addition, about the input offset voltage shift with the RF signal, there is the thinking that influence applied to the input terminal is dominant. Therefore, generally the EMIRR becomes value that applied an RF signal to +INPUT terminal. EMIRR vs. Frequency V+/V-=±2.5V, Ta=25°C 90 80 EMIRR [dB] 70 60 50 40 30 20 10 0 10M 100M 1G Frequency [Hz] 10G *For details, refer to “Application Note for EMI Immunity" in our HP: http://www.njr.com/ Ver.9.1 http://www.njr.com/ - 13 - NJU7056/NJU7057/NJU7058 SOT-23-5 Unit: mm ■ PACKAGE DIMENSIONS 2.9 ±0.2 0 ∼15 ° 1.9 ±0.2 4 0.6 2.8 ±0.2 1.6 +0.2 -0.1 0.2 5 2 1 3 0.1 0.95 ±0.1 +0.1 -0.03 0.4 ±0.1 0.1 0.1max 1.1 ±0.1 0.6max ■EXAMPLE OF SOLDER PADS DIMENSIONS 2. 4 1 .0 0.7 0. 9 5 Ver.9.1 0.95 http://www.njr.com/ - 14 - NJU7056/NJU7057/NJU7058 SC-88A Unit: mm 0 . 42 5 ± 0. 2 ■ PACKAGE DIMENSIONS 2.0 ±0.2 1.3 ±0.2 5 2 ( 0 .2 45 ) 2. 1 ± 0. 2 1 . 25 ± 0 .1 0.23 +0.1 -0.03 4 3 0 .4 2 5 ± 0. 2 1 0.13 +0.1 -0.05 0 ∼ 10 ° 0.1 +0.05 -0.15 0 . 95 0. 05 ±0 . 05 0 .9 ± 0 .1 +0.2 0 . 2 -0.1 0.65 ± 0.07 ■EXAMPLE OF SOLDER PADS DIMENSIONS 1 .9 0 .8 0.3 0.65 Ver.9.1 0.65 http://www.njr.com/ - 15 - NJU7056/NJU7057/NJU7058 MSOP8 (TVSP8) JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKAGE DIMENSIONS 2.9 ±0.1 0 ∼10゚ 1 0 .5 5 ± 0 .1 4. 0 ± 0 .2 5 2. 8 ± 0 .1 8 4 0.127 +0.05 -0.03 0.65 0.08 0.2 ±0.05 0.05 M 0. 1 ± 0 .0 5 1. 0m ax 0.475 ±0.1 ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3. 5 1 .0 0.23 1.95 Ver.9.1 http://www.njr.com/ - 16 - NJU7056/NJU7057/NJU7058 DFN8-U1 (ESON8-U1) Unit: mm ■ PACKAGE DIMENSIONS ■EXAMPLE OF SOLDER PADS DIMENSIONS 0 .2 8 0.5 2.20 1.02 2.0 ±0.05 0.31 2.0 ±0.05 0.075 0.01 +0.010 -0.008 S 0.397 ± 0.03 1 .5 4 1 .7 8 S S 0.05 A 0.21 -0.04 +0.06 1.6 +0.06 -0.04 0.25 C0 .3 3- R0 .3 1.08 -0.04 +0.06 B 0.5 0.26 +0.06 -0.04 Ver.9.1 φ0.05 M S AB http://www.njr.com/ - 17 - NJU7056/NJU7057/NJU7058 SSOP14 Unit: mm ■ PACKAGE DIMENSIONS 5.0 0 ∼ 10゚ +0.3 -0.1 7 1.15 ±0.1 0.65 +0.1 0.15 -0.05 0.1 ±0.1 0.67max 0.10 0.22 ±0.1 0.5 ±0.2 4.4 ±0.2 1 6.4 ±0.3 8 14 0.10 M ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.35 5.90 1.00 0.65 3.90 Ver.9.1 http://www.njr.com/ - 18 - NJU7056/NJU7057/NJU7058 SOT-23-5 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 Feed direction P0 φD0 T B W1 W F E P2 A K0 φ D1 P1 T2 DIMENSION 3.3±0.1 3.2±0.1 1.55 1.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.82 1.5±0.1 8.0±0.3 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1MAX REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.9.1 http://www.njr.com/ - 19 - NJU7056/NJU7057/NJU7058 SC-88A Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction P0 φ D0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 T2 φD1 DIMENSION 2.3±0.1 2.5±0.1 1.55±0.05 1.05±0.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.3±0.1 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.9.1 http://www.njr.com/ - 20 - NJU7056/NJU7057/NJU7058 MSOP8 (TVSP8) MEET JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ir ec ti on P2 P0 φD0 B W1 W F E T A P1 T2 φD1 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 1.75 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.9.1 http://www.njr.com/ - 21 - NJU7056/NJU7057/NJU7058 DFN8-U1 (ESON8-U1) Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ir ect i on P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 T B W1 W F E P2 K0 A T2 φD1 P1 DIMENSION 2.25±0.05 2.25±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.00±0.07 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION 0 φ180 -1.5 +1 φ 60 0 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel Empty tape Covering tape more than 25 pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.9.1 http://www.njr.com/ - 22 - NJU7056/NJU7057/NJU7058 SSOP14 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction φ D0 P0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A φ D1 P1 T2 DIMENSION 6.95 5.4 1.55±0.05 1.55±0.1 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.3±0.05 2.2 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction PACKING STATE more than 20pitch Devices 2000pcs/reel Label Empty tape Covering tape more than 20pitch reel more than 1round Label Put a reel into a box Ver.9.1 http://www.njr.com/ - 23 - NJU7056/NJU7057/NJU7058 ■ RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING PROFILE f 260°C e 230°C 220°C a d b 180°C c d e f g 150°C Temperature ramping rate Pre-heating temperature Pre-heating time Temperature ramp rate 220°C or higher time 230°C or higher time Peak temperature Temperature ramping rate 1 to 4°C/s 150 to 180°C 60 to 120s 1 to 4°C/s shorter than 60s shorter than 40s lower than 260°C 1 to 6°C/s The temperature indicates at the surface of mold package. Room Temp. a b c g ■ REVISION HISTORY DATA REVISION CHANGES 2. Aug. 2016 Ver.6 Data sheet format revision. 12. Jun. 2017 Ver.7 Changed ψjt data for thermal characteristics table. 25. Oct. 2017 Ver.8 Corrected test condition of electrical characteristics. 22. Feb. 2019 Ver.9 Revision data sheet format, application note and add EMIRR. 26. Oct. 2020 Ver.9.1 Corrected the unit of Supply Current per Amplifer vs. Supply Voltage. Corrected the unit of Supply Current per Amplifler vs. Temperture. Ver.9.1 http://www.njr.com/ - 24 - NJU7056/NJU7057/NJU7058 [ CAUTION ] 1. NJR strives to produce reliable and high quality semiconductors. NJR’s semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of NJR's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial property rights. All other trademarks mentioned herein are the property of their respective companies. 3. To ensure the highest levels of reliability, NJR products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. NJR offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact NJR's Sale's Office if you are uncertain about the products listed in this datasheet. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in this datasheet may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment.        7. 8. 9. Ver.9.1 Aerospace Equipment Equipment Used in the Deep Sea Power Generator Control Equipment (Nuclear, steam, hydraulic, etc.) Life Maintenance Medical Equipment Fire Alarms / Intruder Detectors Vehicle Control Equipment (Airplane, railroad, ship, etc.) Various Safety Devices NJR's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. NJR shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. The products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. Warning for handling Gallium and Arsenic (GaAs) Products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. The product specifications and descriptions listed in this datasheet are subject to change at any time, without notice. http://www.njr.com/ - 25 -
NJU7056F-TE1 价格&库存
很抱歉,暂时无法提供与“NJU7056F-TE1”相匹配的价格&库存,您可以联系我们找货
