HFA1412IP
HFA1412IP
    L3HARRIS
    DIP-14
    BUFFER AMPLIFIER, 4 FUNC, BIPOLA
HFA1412IP 数据手册
HFA1412 IGNS E W D ES N R O F ND E D EMENT COMME REPL A C D E N OT R E D N ter at E OM M port Cen /tsc January 23, 2006 p u S l NO REC DataecSheet a m nic tersil.co our T h contact ERSIL or www.in T 1-888-IN Quad, 350MHz, Low Power, Programmable Gain Buffer Amplifier FN4152.4 Features The HFA1412 is a quad closed loop Buffer featuring user programmable gain and high speed video performance. A unique feature of the HFA1412’s pinout allows the user to select a voltage gain of +1, -1, or +2 (see the “Application Information” section). The on-chip gain setting resistors eliminate eight external resistors, thus saving board space or freeing up space for termination resistors. The on-chip feedback resistor is preset at the optimum value, and also eliminates worries about parasitic feedback capacitance. Additionally, the capacitance sensitive summing node is buried inside the package where it is unaffected by PCB parasitics. Compatibility with existing op amp pinouts provides flexibility to upgrade low gain amplifiers, while decreasing component count. Unlike most buffers, the standard pinout provides an upgrade path should a higher closed loop gain be needed at a future date. The HFA1412 is an excellent choice for component and composite video systems as indicated by the excellent gain flatness, and 0.03%/0.02 Degree Differential Gain/Phase specifications (RL = 150). Its ability to deliver a gain of +2 with no external resistors makes it particularly desirable for applications driving double terminated cables. • User Programmable For Closed-Loop Gains of +1, -1 or +2 Without Use of External Resistors • Wide -3dB Bandwidth. . . . . . . . . . . . . . . . . . . . . . 350MHz • Low Supply Current . . . . . . . . . . . . . . . . . . . . 6mA/Buffer • Excellent Gain Flatness (to 100MHz). . . . . . . . . . 0.08dB • Low Differential Gain and Phase . . . . 0.03%/0.02 Degree • Very Fast Slew Rate . . . . . . . . . . . . . . . . . . . . . 1650V/s • Fast Settling Time (0.1%). . . . . . . . . . . . . . . . . . . . . 28ns • High Output Current . . . . . . . . . . . . . . . . . . . . . . . . . 55mA • Excellent Gain Accuracy . . . . . . . . . . . . . . . . . . . 0.99V/V • Overdrive Recovery . . . . . . . . . . . . . . . . . . . . . . . .
HFA1412IP 价格&库存
很抱歉,暂时无法提供与“HFA1412IP”相匹配的价格&库存,您可以联系我们找货
