NJU77002E-TE2
NJU77002E-TE2
    JRC(⽇本无线)
    SOP-8
    IC CMOS 2 CIRCUIT 8SOP
NJU77002E-TE2 数据手册
NJU77000/NJU77001 NJU77002/NJU77004 1.5V, 0.23µA/ch, Ultra-Low Power, Excellent EMI Immunity, Rail-to-Rail Input/Output, CMOS Operational Amplifiers FEATURES (V+=5V) DESCRIPTION ●Supply Voltage 1.5V to 5.5V ●Input Offset Voltage NJU77000 / NJU77001 1.0mV max. NJU77002 1.3mV max. NJU77004 1.5mV max. ●Input Offset Voltage Drift 0.65μV/°C typ. ●Input Bias Current 10pA max. ●Integrated EMI Filter EMIRR=89dB typ. @f=900MHz ●Rail-to-Rail Input / Output ●CMOS Technology ●Slew Rate 0.7V/ms ●Unity Gain Frequency 1.0kHz ●Ultra-Low Power Supply Current NJU77000 / NJU77001 0.29µA typ. NJU77002 / NJU77004 0.23µA/ch typ. ●Package NJU77000 SOT-23-5 NJU77001 SC-88A, SOT-23-5 NJU77002 SOP8 JEDEC 150mil MSOP8 (TVSP8)* *JEDEC MO-187-DA / thin type DFN8-U1 (ESON8-U1) SSOP14 NJU77004 APPLICATIONS ●Battery-Powered Instruments ●Micro-Power Oxygen Sensors and Gas Sensors ●Power Line Monitoring ●Micro Power Current Sensing ●Healthcare Instruments ■ TYPICAL CHARACTERISTIC Supply Current per Amplifier [μA] These devices also feature rail-to-rail I/O and input offset voltage of 1.0mV max. (single), 1.3mV max. (dual), 1.5mV max. (quad). Moreover, this series has excellent characteristics ideal for battery-powered applications, such as 0.65uV/°C typ. input offset voltage drift, input bias current of 10pA max. and ability of capacity load drive of 470pF. NJU77000 series has normal grade (NJU7700x) and AGrade (NJU7700xA). A-Grade has improved offset voltage and supply voltage than normal grade, and other characteristics are also guaranteed from -40 to 105 °C. The NJU77000 is available in a 5-pin SOT-23 package. NJU77001 is offered in 5-pin SOT-23 and SC-88A packages. NJU77000 and NJU77001 have different pin functions (see pin configurations). The NJU77002 is offered in 8-pin SOP JEDEC 150mil, MSOP (TVSP JEDEC MO-187-DA / thin type) and DFN (ESON) that is thin and 2mm square small package. The NJU77004 is a 14-pin SSOP package. ■ TYPICAL APPLICATION Supply Current per Amplifier vs. Temperature (NJU77002/NJU77004) GV=0dB, VCOM=V+/2 0.4 The NJU77000/NJU77001/NJU77002/NJU77004 are single/dual/quad ultra-low power CMOS operational amplifiers designed specifically to extend battery life and performance for portable applications. The supply voltage range is 1.5V to 5.5V and supply current is 0.29µA typ. (single), 0.23µA/ch typ. (dual/quad). The supply current is stable against ambient temperature and voltage change, making them suitable for micro power oxygen sensors, gas sensors, and remote sensor applications. 1.8V To ADC VIN VO 0.3 V+=5.0V 10MΩ 100kΩ 0.2 V+=1.5V VO=VIN x 101 ISUPPLY=0.23µA/ch V+=1.8V V+=3V to 2V @ end of life 0.1 CR2032: coin type battery 220mAh = 13 years @ 4 circuit 0 -50 Ver.6.1 100kΩ Sensor -25 0 25 50 75 100 Ambient Temperature [°C] 40dB micro power sensor amplifier 125 www.njr.com -1- NJU77000/NJU77001 NJU77002/NJU77004 ■ PRODUCT INFORMATION (Ta=25°C) VO max. ISUPPLY max. IB max. 1.8mV 0.49μA 1.0mV PACKAGE / PRODUCT NAME MSOP8 SOP8 JEDEC 150 mil (TVSP8) DFN8-U1 (ESON8-U1) SSOP14 - - - - - - - - NJU77002E NJU77002RB1 NJU77002KU1 - - - NJU77002AE NJU77002ARB1 NJU77002AKU1 - - - - - - NJU77004V - - - - - NJU77004AV SC-88A SOT-23-5 - NJU77001F3 NJU77000F NJU77001F - 0.39μA 10pA NJU77001AF3 NJU77000AF NJU77001AF 2.0mV 0.76μA - - 1.3mV 0.66μA 10pA 2.2mV 1.32μA - 1.5mV 1.22μA 10pA ■ PIN CONFIGURATIONS PRODUCT NAME NJU77000F NJU77000AF NJU77001F NJU77001AF NJU77001F3 NJU77001AF3 Package SOT-23-5 SOT-23-5 SC-88A 1 V- 2 +INPUT 3 Pin Functions NJU77002RB1 NJU77002ARB1 SOP8 MSOP8 (TVSP8) JEDEC 150 mil (Top View) (Top View) (Top View) OUTPUT NJU77002E NJU77002AE 5 4 V+ -INPUT +INPUT 1 V- 2 -INPUT 3 5 4 V+ OUTPUT A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A +INPUT 3 6 B -INPUT V- 4 5 B +INPUT PRODUCT NAME NJU77002KU1 NJU77002AKU1 NJU77004V / NJU77004AV Package DFN8-U1 (ESON8-U1) SSOP14 (Top View) (Top View) A OUTPUT Pin Functions A -INPUT 1 8 2 A +INPUT 3 V- 4 7 Exposed Pad on Underside V+ B OUTPUT 6 B -INPUT 5 B +INPUT A OUTPUT 1 14 D OUTPUT A -INPUT 2 13 D -INPUT A +INPUT 3 12 D +INPUT V+ 4 11 V- B +INPUT 5 10 C +INPUT B -INPUT 6 9 C -INPUT B OUTPUT 7 8 C OUTPUT ■ PRODUCT NAME INFORMATION NJU77000 Part Number Ver.6.1 F Package (TE2) Taping Form www.njr.com -2- NJU77000/NJU77001 NJU77002/NJU77004 ■ ORDER INFORMATION PRODUCT NAME NJU77000F NJU77000AF NJU77001F NJU77001AF NJU77001F3 NJU77001AF3 NJU77002E NJU77002AE NJU77002RB1 NJU77002ARB1 NJU77002KU1 NJU77002AKU1 NJU77004V NJU77004AV PACKAGE RoHS HALOGENFREE TERMINAL FINISH MARKING WEIGHT (mg) MOQ (pcs) SOT-23-5 SOT-23-5 SOT-23-5 SOT-23-5 SC-88A SC-88A SOP8 JEDEC 150 mil SOP8 JEDEC 150 mil MSOP8 (TVSP8) MSOP8 (TVSP8) DFN8-U1(ESON8-U1) DFN8-U1(ESON8-U1) SSOP14 SSOP14 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi 17 1A 16 18 AH AK 77002 77002A 77002 77002A 77002 77002A 77004 77004A 15 15 15 15 7.5 7.5 76 76 18 18 5.3 5.3 65 65 3000 3000 3000 3000 3000 3000 2000 2000 2000 2000 3000 3000 2000 2000 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage Differential Input Voltage(1) Input Voltage Power Dissipation (Ta=25°C) SOT-23-5 SC-88A SOP8 JEDEC 150 mil MSOP8 (TVSP8) DFN8-U1 (ESON8-U1) SSOP14 Storage Temperature Maximum Junction Temperature Ver.6.1 SYMBOL + - V -V VID VIN PD Tstg Tjmax www.njr.com RATING UNIT 7 ±7(2) V--0.3 to V++0.3(3) 2-Layer / 4-Layer(4) 390 / 520 280 / 390 500 / 700 410 / 540 360 / 940(5) 400 / 500 V V V -55 to 125 125 mW °C °C -3- NJU77000/NJU77001 NJU77002/NJU77004 ■ THERMAL CHARACTERISTICS PACKAGE SYMBOL VALUE UNIT Junction-to-Ambient Thermal Resistance 2-Layer / 4-Layer(4) SOT-23-5 256 / 192 SC-88A 357 / 256 Θja °C/W SOP8 JEDEC 150 mil 182 / 122 MSOP8 (TVSP8) 244 / 185 DFN8-U1 (ESON8-U1) 278 / 106(5) SSOP14 250 / 200 Junction-to-Top of Package Characterization Parameter 2-Layer / 4-Layer(4) SOT-23-5 67 / 58 SC-88A 91 / 73 Ψjt °C/W SOP8 JEDEC 150 mil 32 / 27 MSOP8 (TVSP8) 51 / 45 DFN8-U1 (ESON8-U1) 42 / 25(5) SSOP14 53 / 52 (1) Differential voltage is the voltage difference between +INPUT and -INPUT. (2) For supply voltage less than 7V, the absolute maximum rating is equal to the supply voltage. (3) The absolute maximum input voltage is limited at 7V. (4) 2-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 2-layer FR-4) 4-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 4-layer FR-4), internal Cu area: 74.2×74.2mm (5) 2-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 2-Layer FR-4) with exposed pad. 4-Layer: Mounted on glass epoxy board (101.5 mm × 114.5 mm × 1.6 mm: based on EIA/JEDEC standard, 4-Layer FR-4) with exposed pad. (For 4-layer: Applying 99.5 mm × 99.5 mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5.) ■ POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 2-Layer 4-Layer 600 1000 900 500 Power Dissipation PD [mW] Power Dissipation PD [mW] SSOP14 MSOP8 (TVSP8) 400 300 SOP8 JEDEC 150 mil SOT-23-5 200 DFN8-U1 (ESON8-U1) 100 800 SOP8 JEDEC 150 mil 700 MSOP8(TVSP8) 600 DFN8-U1 (ESON8-U1) 500 400 300 SOT-23-5 200 SSOP14 SSOP14 100 SC-88A SC-88A SC-88A 0 0 0 25 50 75 100 0 125 25 50 75 100 125 Ambient Temperature [°C] Ambient Temperature [°C] ■ RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Operating Temperature Ver.6.1 SYMBOL V+ - V- CONDITIONS Ta=25°C Topr www.njr.com VALUE UNIT 1.5 to 5.5 V -40 to 105 °C -4- NJU77000/NJU77001 NJU77002/NJU77004 ■ ELECTRICAL CHARACTERISTICS (V+=5V, V-=0V, VCOM=2.5V, RL=100kΩ to 2.5V, Ta=25°C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN NJU7700xA TYP MAX MIN NJU7700x TYP MAX UNIT INPUTCHARACTERISTICS Input Offset Voltage NJU77000 / NJU77001 VCOM=0V - 0.35 0.35 0.35 - 1 1.2 1.3 1.5 1.5 1.7 - 0.35 0.35 0.35 - 1.8 2.0 2.2 - -10 -100 -10 -100 70 70 60 60 0 0 0.65 0.65 0.65 1 1 100 80 - 17 21 24 10 100 10 100 5 5 70 60 0 - 0.65 0.65 0.65 1 1 100 80 - 5 - 4.9 4.9 - 4.95 0.05 - 0.1 0.1 4.9 - 4.95 0.05 - 0.1 - 70 70 0.29 0.46 0.92 90 - 0.39 0.39 0.66 0.66 1.22 1.22 - 70 - 0.29 0.46 0.92 90 - 0.49 0.76 1.32 - - 0.8 0.7 - - 0.8 0.7 - V/ms - 1.1 1.0 60 30 - - 1.1 1.0 60 30 - kHz - 600 700 - - 600 700 - nV/√Hz Ta=-40°C to 105°C NJU77002 VIO Ta=-40°C to 105°C NJU77004 Input Offset Voltage Drift NJU77000 / NJU77001 NJU77002 NJU77004 Ta=-40°C to 105°C VCOM=0V, Ta=-40°C to 105°C ΔVIO/ΔT Input Bias Current IB Input Offset Current IIO Open-Loop Voltage Gain AV Common-Mode Rejection Ratio CMR Common-Mode Input Voltage Range VICM Ta=-40°C to 105°C Ta=-40°C to 105°C VO=0.5V to 4.5V Ta=-40°C to 105°C VCOM=0V to 5V Ta=-40°C to 105°C CMR≥60dB Ta=-40°C to 105°C mV μV/°C pA pA dB dB V OUTPUT CHARACTERISTICS VOH Maximum Output Voltage VOL Ta=-40°C to 105°C Ta=-40°C to 105°C V V POWER SUPPLY Supply Current (All Amplifiers) NJU77000 / NJU77001 No Signal Ta=-40°C to 105°C NJU77002 ISUPPLY Ta=-40°C to 105°C NJU77004 Supply Voltage Rejection Ratio SVR Ta=-40°C to 105°C V+=1.5V to 5.5V, VCOM=0V Ta=-40°C to 105°C µA dB AC CHARACTERISTICS Slew Rate NJU77000 / NJU77001 NJU77002 / NJU77004 Unity-Gain Frequency NJU77000 / NJU77001 NJU77002 / NJU77004 Phase Margin Gain Margin Equivalent Input Noise Current NJU77000 / NJU77001 NJU77002 / NJU77004 Ver.6.1 GV=0dB, CL=20pF, VIN=1VPP SR GV=20dB, CL=20pF fT ΦM GM CL=20pF CL=20pF f=100Hz VNI www.njr.com deg dB -5- NJU77000/NJU77001 NJU77002/NJU77004 ■ ELECTRICAL CHARACTERISTICS (V+=1.8V, V-=0V, VCOM=0.9V, RL=100kΩ to 0.9V, Ta=25°C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN NJU7700xA TYP MAX MIN NJU7700x TYP MAX UNIT INPUT CHARACTERISTICS Input Offset Voltage NJU77000 / NJU77001 VCOM=0V - 0.35 0.35 0.35 - 1 1.2 1.3 1.5 1.5 1.7 - 0.35 0.35 0.35 - 1.8 2.0 2.2 - -10 -100 -10 -100 70 70 55 55 0 0 0.65 0.65 0.65 1 1 100 80 - 17 21 24 10 100 10 100 1.8 1.8 70 55 0 - 0.65 0.65 0.65 1 1 100 80 - 1.8 - 1.7 1.7 - 1.75 0.05 - 0.1 0.1 1.7 - 1.75 0.05 - 0.1 - 70 70 0.26 0.42 0.84 90 - 0.36 0.36 0.62 0.62 1.17 1.17 - 70 - 0.26 0.42 0.84 90 - 0.49 0.72 1.27 - - 0.7 0.6 - - 0.7 0.6 - V/ms - 1.0 0.9 60 30 - 1.0 0.9 60 30 - kHz - 700 800 - - 700 800 - nV/√Hz Ta=-40°C to 105°C NJU77002 VIO Ta=-40°C to 105°C NJU77004 Input Offset Voltage Drift NJU77000 / NJU77001 NJU77002 NJU77004 Ta=-40°C to 105°C VCOM=0V, Ta=-40°C to 105°C ΔVIO/ΔT Input Bias Current IB Input Offset Current IIO Open-Loop Voltage Gain AV Common-Mode Rejection Ratio CMR Common-Mode Input Voltage Range VICM Ta=-40°C to 105°C Ta=-40°C to 105°C VO=0.5V to 1.3V Ta=-40°C to 105°C VCOM=0V to 1.8V Ta=-40°C to 105°C CMR≥55dB Ta=-40°C to 105°C mV μV/°C pA pA dB dB V OUTPUT CHARACTERISTICS VOH Maximum Output Voltage VOL Ta=-40°C to 105°C Ta=-40°C to 105°C V V POWER SUPPLY Supply Current (All Amplifiers) NJU77000 / NJU77001 No Signal Ta=-40°C to 105°C NJU77002 ISUPPLY Ta=-40°C to 105°C NJU77004 Supply Voltage Rejection Ratio SVR Ta=-40°C to 105°C V+=1.5V to 5.5V, VCOM=0V Ta=-40°C to 105°C µA dB AC CHARACTERISTICS Slew Rate NJU77000 / NJU77001 NJU77002 / NJU77004 Unity-Gain Frequency NJU77000 / NJU77001 NJU77002 / NJU77004 Phase Margin Gain Margin Equivalent Input Noise Current NJU77000 / NJU77001 NJU77002 / NJU77004 Ver.6.1 GV=0dB, CL=20pF, VIN=1VPP SR GV=20dB, CL=20pF fT ΦM GM CL=20pF CL=20pF f=100Hz VNI www.njr.com deg dB -6- NJU77000/NJU77001 NJU77002/NJU77004 ■ TYPICAL CHARACTERISTICS Supply Current vs. Supply Voltage Supply Current vs. Temperature (NJU77000/NJU77001) GV=0dB, VCOM=V+/2 0.5 0.4 Ta=105°C Supply Current [μA] Supply Current [μA] 0.4 Ta=25°C 0.3 0.2 Ta=-40°C 0.1 V+=5.0V 0.3 0.2 V+=1.5V 0 0 1 2 3 4 5 Supply Voltage V+ [V] 6 7 -50 (NJU77002/NJU77004) GV=0dB, VCOM=V+/2 Ta=105°C 0.3 Ta=25°C 0.2 Ta=-40°C 0.1 125 0.3 V+=5.0V 0.2 V+=1.8V V+=1.5V 0.1 0 0 0 1 2 3 4 5 Supply Voltage [V] 6 -50 7 Input Offset Voltage vs. Temperature -25 0 25 50 75 100 Ambient Temperature [°C] 125 Input Offset Voltage vs. Temperature V+=5.0V, VCOM =0V, n=200 1.5 V+=1.8V, VCOM =0V, n=200 1.5 1.0 Input Offset Voltage [mV] Input Offset Voltage [mV] 0 25 50 75 100 Ambient Temperature [°C] (NJU77002/NJU77004) GV=0dB, VCOM =V+/2 0.4 Supply Current per Amplifier [μA] 0.4 -25 Supply Current per Amplifier vs. Temperature Supply Current per Amplifier vs. Supply Voltage 0.5 0.0 -0.5 -1.0 -1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -50 Ver.6.1 V+=1.8V 0.1 0 Supply Current per Amplifier [μA] (NJU77000/NJU77001) GV=0dB, VCOM =V+/2 0.5 -25 0 25 50 75 100 Ambient Temperature [°C] 125 www.njr.com -50 -25 0 25 50 75 100 Ambient Temperature [°C] 125 -7- NJU77000/NJU77001 NJU77002/NJU77004 ■ TYPICAL CHARACTERISTICS Input Offset Voltage Drift Distribution Input Offset Voltage Drift Distribution V+=5.0V, VCOM=0V, n=3000 25% 20% 20% Percent of Amplifiers Percent of Amplifiers V+=1.8V, VCOM=0V, n=3000 25% 15% 10% 5% 15% 10% 5% 0% 0% -4 -3.2 -2.4 -1.6 -0.8 0 0.8 1.6 2.4 3.2 Input Offset Voltage Drift [μV/°C] 4 -4 -3.2 -2.4 -1.6 -0.8 0 0.8 1.6 2.4 3.2 Input Offset Voltage Drift [μV/°C] Input Offset Voltage vs. Common-Mode Input Voltage Input Offset Voltage vs. Common-Mode Input Voltage V+=1.8V V+=5.0V 1.5 1.0 Input Offset Voltage [mV] Input Offset Voltage [mV] 1.5 Ta=-40°C 0.5 0.0 Ta=25°C Ta=105°C -0.5 -1.0 1.0 Ta=-40°C Ta=105°C 0.5 0.0 Ta=25°C -0.5 -1.0 -1.5 -1.5 0 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 Common-Mode Input Voltage [V] 1.0 2.0 3.0 4.0 4.55.0 Common-Mode Input Voltage [V] Common-Mode and Supply Voltage Rejection Ratio vs. Temperature Input Offset Voltage vs. Supply Voltage VCOM =0V 120 Common Mode and Supply Voltage Rejection Ratio [dB] Input Offset Voltage [mV] 1.5 1.0 Ta=-40°C 0.5 0.0 Ta=25°C Ta=105°C -0.5 -1.0 SVR 110 100 CMR(V+=5.0V) 90 80 70 CMR(V+=1.8V) 60 -1.5 0 Ver.6.1 4 1 2 3 4 5 Supply Voltage V+ [V] 6 -50 7 www.njr.com -25 0 25 50 75 100 Ambient Temperature [°C] 125 -8- NJU77000/NJU77001 NJU77002/NJU77004 ■ TYPICAL CHARACTERISTICS Maximum Output Voltage vs. Output Current Maximum Output Voltage vs. Output Current V+=5.0V, GV=OPEN Maximum Output Voltage [V] Maximum Output Voltage [V] ISOURCE Ta=-40°C 4.0 Ta=25°C Ta=105°C 3.0 2.0 Ta=105°C Ta=25°C 1.0 V+=1.8V, GV=OPEN 1.8 Ta=-40°C ISOURCE 1.6 Ta=-40°C 1.4 Ta=25°C Ta=105°C 1.2 1.0 0.8 Ta=105°C 0.6 Ta=25°C Ta=-40°C 0.4 0.2 ISINK 0.0 0.01 0.1 1 10 Output Current [mA] ISINK 0.0 0.01 100 0.1 1 Output Current [mA] Voltage Gain vs. Temperature Voltage Gain/Phase vs. Frequency VCOM =V+/2, RL=100kΩ to V+/2 120 10 V+=5.0V, GV=20dB, Ta=25°C 30 Gain V+=5.0V 20 110 CL=20pF Voltage Gain [dB] Voltage Gain [dB] 10 100 V+=1.8V 90 80 0 CL=100pF Phase 0 -30 -10 -60 CL=470pF CL=330pF -20 -90 CL=20pF -30 Phase [deg] 5.0 -120 CL=100pF 70 -40 -150 CL=330pF CL=470pF 60 -50 -50 -25 0 25 50 75 100 Ambient Temperature [°C] 125 -180 10 Pulse Response CL=20pF CL=550pF Time [2ms/div] Ver.6.1 V+=5.0V, GV=0dB, RL=100kΩ, Ta=25°C 1400 Equivalent Input Noise Voltage [nV/√Hz] Voltage [0.5V/div] 3.0 2.0 10k Voltage Noise vs. Frequency V+=5.0V, GV=0dB, RL=100kΩ to 2.5V, Ta=25°C 2.5 100 1k Frequency [Hz] 1200 1000 NJU77002 / NJU77004 800 600 400 NJU77000 / NJU77001 200 0 1 www.njr.com 10 100 Frequency [Hz] 1k -9- NJU77000/NJU77001 NJU77002/NJU77004 ■ TEST CIRCUIT ● ISUPPLY ● VIO, CMR, SVR RG=50Ω, RF=50kΩ V+ RF A V+ RG VO RG VCOM VCOM V- RF VVS=V+-V- ● VOH, VOL ● GBW RG=1kΩ, RF=100kΩ VOH; Vin+ = V+/2 + 0.1V, Vin- = V+/2, VCOM=V+/2 + + + VOL; Vin+ = V /2, Vin- = V /2 + 0.1V, VCOM=V /2 RF V+ V+ RG VO VO RL Vin+ Vin- V- 50Ω VCOM V- CL ● SR 90% V+ Vo VO 50Ω Ver.6.1 V- RL 90% ΔV ΔV 10% Δt Δt 10% CL www.njr.com - 10 - NJU77000/NJU77001 NJU77002/NJU77004 ■ APPLICATION NOTE Capacitive Load The unity gain follower is the most sensitive configuration to capacitive loading. The combination of capacitive load placed directly on the output of an amplifier along with the output impedance of the amplifier creates a phase lag which in turn reduces the phase margin of the amplifier. If phase margin is significantly reduced, the response will be either underdamped or the amplifier will oscillate. The NJU77000/NJU77001/NJU77002/NJU77004 can directly drive capacitive loads of up to 470pF without oscillating. To drive heavier capacitive loads, an isolation resistor, RISO as shown Figure1, should be used. RISO improves the feedback loop’s phase margin by making the output load resistive at higher frequencies. The larger the value of RISO, the more stable the output voltage will be. However, larger values of RISO result in reduced output swing, reduced output current drive and reduced frequency bandwidth. Figure2 shows RISO values at unity gain follower without oscillating. After selecting RISO for your circuit, double-check the resulting frequency response peaking and step response overshoot. Modify RISO’s value until the response is reasonable. EMIRR (EMI Rejection Ratio) Definition EMIRR is a parameter indicating the EMI robustness of an Op-Amp. The definition of EMIRR is given by the following equation1. EMIRR = 20 ∙ log ൬ Vୖ୊_୔୉୅୏ ൰ |∆V୍୓ | − − − eq. 1 Vୖ୊_୔୉୅୏ : RF Signal Amplitude [VP] ∆V୍୓ : Input offset voltage shift quantity [V] The tolerance of the RF signal can be grasped by measuring an RF signal and offset voltage shift quantity. Offset voltage shift is small so that a value of EMIRR is big. And it understands that the tolerance for the RF signal is high. In addition, about the input offset voltage shift with the RF signal, there is the thinking that influence applied to the input terminal is dominant. Therefore, generally the EMIRR becomes value that applied an RF signal to +INPUT terminal. EMIRR vs. Frequency V+/V-= ±2.5V, Ta=25°C 140 120 100 EMIRR [dB] RISO VOUT VIN CL 80 60 40 Figure1. Isolating capacitive load 20 0 10M Isolation Resistance vs. Capacitive Load Isolation Resistance RISO [KΩ] 100 GV=+1, Ta=25°C 100M 1G Frequency [Hz] 10G *For details, refer to “Application Note for EMI Immunity" in our HP: http://www.njr.com/ Stable 10 1 0.1 100p 100 Unstable 1n 10n 100n 1k 10k 100k Capacitive Load CL [F] 1µ 1M Figure2. Isolation resistance to improve stability Ver.6.1 www.njr.com - 11 - NJU77000/NJU77001 NJU77002/NJU77004 SOT-23-5 Unit: mm ■ PACKAGE DIMENSIONS 2.9 ±0.2 0 ∼15 ° 1.9 ±0.2 4 0.6 2.8 ±0.2 1.6 +0.2 -0.1 0.2 5 2 1 3 0.1 0.95 ±0.1 +0.1 -0.03 0.4 ±0.1 0.1 0.1max 1.1 ±0.1 0.6max ■ EXAMPLE OF SOLDER PADS DIMENSIONS 2. 4 1 .0 0.7 0. 9 5 Ver.6.1 0.95 www.njr.com - 12 - NJU77000/NJU77001 NJU77002/NJU77004 SC-88A Unit: mm 0 . 42 5 ± 0. 2 ■ PACKAGE DIMENSIONS 2.0 ±0.2 1.3 ±0.2 5 2 ( 0 .2 45 ) 2. 1 ± 0. 2 1 . 25 ± 0 .1 0.23 +0.1 -0.03 4 3 0 .4 2 5 ± 0. 2 1 0.13 +0.1 -0.05 0 ∼ 10 ° 0.1 +0.05 -0.15 0 . 95 0. 05 ±0 . 05 0 .9 ± 0 .1 +0.2 0 . 2 -0.1 0.65 ± 0.07 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 1 .9 0 .8 0.3 0.65 Ver.6.1 0.65 www.njr.com - 13 - NJU77000/NJU77001 NJU77002/NJU77004 SOP8 JEDEC 150mil (EMP8) Unit: mm ■ PACKAGE DIMENSIONS 0 ∼10 ゜ 5.0 ±0.3 +0.1 1 .5 ± 0. 15 0.74max 0.1 0.4 ±0.1 0 .8 ± 0. 2 3 .9 ± 0. 2 4 1.27 0.12 M 0.2 -0.05 0 .1 5 ± 0 .1 1 6 .0 ± 0. 4 5 8 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 1. 27 5 . 72 1. 2 7 0.72 3.81 Ver.6.1 www.njr.com - 14 - NJU77000/NJU77001 NJU77002/NJU77004 MSOP8 (TVSP8) MEET JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKAGE DIMENSIONS 2.9 ±0.1 0 ∼10゚ 1 0 .5 5 ± 0 .1 4. 0 ± 0 .2 5 2. 8 ± 0 .1 8 4 0.127 +0.05 -0.03 0.65 0.08 0.2 ±0.05 0.05 M 0. 1 ± 0 .0 5 1. 0m ax 0.475 ±0.1 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3. 5 1 .0 0.23 1.95 Ver.6.1 www.njr.com - 15 - NJU77000/NJU77001 NJU77002/NJU77004 DFN8-U1 (ESON8-U1) Unit: mm ■ PACKAGE DIMENSIONS ■EXAMPLE OF SOLDER PADS DIMENSIONS 0 .2 8 0.5 2.20 1.02 2.0 ±0.05 0.31 2.0 ±0.05 0.075 0.01 +0.010 -0.008 S 0.397 ± 0.03 1 .5 4 1 .7 8 S S 0.05 A 0.21 -0.04 +0.06 1.6 +0.06 -0.04 0.25 C0 .3 3- R0 .3 1.08 -0.04 +0.06 B 0.5 0.26 +0.06 -0.04 Ver.6.1 φ0.05 M S AB www.njr.com - 16 - NJU77000/NJU77001 NJU77002/NJU77004 SSOP14 Unit: mm ■ PACKAGE DIMENSIONS 5.0 0 ∼ 10゚ +0.3 -0.1 7 +0.1 1.15 ±0.1 0.65 0.15 -0.05 0.1 ±0.1 0.67max 0.10 0.22 ±0.1 0.5 ±0.2 4.4 ±0.2 1 6.4 ±0.3 8 14 0.10 M ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.35 5.90 1.00 0.65 3.90 Ver.6.1 www.njr.com - 17 - NJU77000/NJU77001 NJU77002/NJU77004 SOT-23-5 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 Feed direction P0 φD0 T B W1 W F E P2 A K0 φ D1 P1 T2 DIMENSION 3.3±0.1 3.2±0.1 1.55 1.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.82 1.5±0.1 8.0±0.3 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1MAX REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE2) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.6.1 www.njr.com - 18 - NJU77000/NJU77001 NJU77002/NJU77004 SC-88A Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction P0 φ D0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 T2 φD1 DIMENSION 2.3±0.1 2.5±0.1 1.55±0.05 1.05±0.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.3±0.1 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE2) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.6.1 www.njr.com - 19 - NJU77000/NJU77001 NJU77002/NJU77004 SOP8 JEDEC 150mil (EMP8) Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ire c tio n P0 φD 0 T B W1 W F E P2 A T2 φD 1 P1 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 DIMENSION 6.6 5.4 +0.1 1.5 0 1.7±0.1 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 2.2 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 C SYMBOL A B C D E W W1 B A D E DIMENSION φ330±2 φ 80±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE2) Empty tape Feed direction Devices more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.6.1 www.njr.com - 20 - NJU77000/NJU77001 NJU77002/NJU77004 MSOP8 MEET JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ir ec ti on P0 φD0 T B W1 W F E P2 A P1 T2 φD1 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 1.75 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) (TE2) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.6.1 www.njr.com - 21 - NJU77000/NJU77001 NJU77002/NJU77004 DFN8-U1 (ESON8-U1) Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Fe ed d ir ect i on P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 T B W1 W F E P2 K0 A T2 φD1 P1 DIMENSION 2.25±0.05 2.25±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.00±0.07 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION 0 φ180 -1.5 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel Empty tape Covering tape more than 25 pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.6.1 www.njr.com - 22 - NJU77000/NJU77001 NJU77002/NJU77004 SSOP14 Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction φ D0 P0 T B W1 W F E P2 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 A φ D1 P1 T2 DIMENSION 6.95 5.4 1.55±0.05 1.55±0.1 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.3±0.05 2.2 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction PACKING STATE more than 20pitch Devices 2000pcs/reel Label Empty tape Covering tape more than 20pitch reel more than 1round Label Put a reel into a box Ver.6.1 www.njr.com - 23 - NJU77000/NJU77001 NJU77002/NJU77004 ■ RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING PROFILE f 260°C e 230°C 220°C a d b 180°C c d e f g 150°C Temperature ramping rate Pre-heating temperature Pre-heating time Temperature ramp rate 220°C or higher time 230°C or higher time Peak temperature Temperature ramping rate 1 to 4°C/s 150 to 180°C 60 to 120s 1 to 4°C/s shorter than 60s shorter than 40s lower than 260°C 1 to 6°C/s The temperature indicates at the surface of mold package. Room Temp. a b c g ■ REVISION HISTORY Date November 24, 2021 Ver.6.1 Revision Changes Ver.6.1 Changed datasheet format. Updated about EMIRR in application notes. Corrected order information. www.njr.com - 24 - NJU77000/NJU77001 NJU77002/NJU77004 [ CAUTION ] 1. NJR strives to produce reliable and high quality semiconductors. NJR’s semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of NJR's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial property rights. All other trademarks mentioned herein are the property of their respective companies. 3. To ensure the highest levels of reliability, NJR products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. NJR offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact NJR's Sale's Office if you are uncertain about the products listed in this datasheet. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in this datasheet may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment.        7. 8. 9. Ver.6.1 Aerospace Equipment Equipment Used in the Deep Sea Power Generator Control Equipment (Nuclear, steam, hydraulic, etc.) Life Maintenance Medical Equipment Fire Alarms / Intruder Detectors Vehicle Control Equipment (Airplane, railroad, ship, etc.) Various Safety Devices NJR's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. NJR shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. The products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. Warning for handling Gallium and Arsenic (GaAs) Products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. The product specifications and descriptions listed in this datasheet are subject to change at any time, without notice. www.njr.com - 25 -
NJU77002E-TE2 价格&库存
很抱歉,暂时无法提供与“NJU77002E-TE2”相匹配的价格&库存,您可以联系我们找货
