FM1608B-SG
FM1608B-SG
    ROCHESTER(罗切斯特)
    SOIC28
    IC FRAM 64KBIT PARALLEL 28SOIC
FM1608B-SG 数据手册
Pre-Production FM1608B 64Kb Bytewide 5V F-RAM Memory Features 64Kbit Ferroelectric Nonvolatile RAM  Organized as 8,192 x 8 bits  High Endurance 1 Trillion (1012) Read/Writes  38 year Data Retention (@ +75C)  NoDelay™ Writes  Advanced High-Reliability Ferroelectric Process Superior to BBSRAM Modules  No Battery Concerns  Monolithic Reliability  True Surface Mount Solution, No Rework Steps  Superior for Moisture, Shock, and Vibration  Resistant to Negative Voltage Undershoots Description The FM1608B is a 64-kilobit nonvolatile memory employing an advanced ferroelectric process. A ferroelectric random access memory or F-RAM is nonvolatile but operates in other respects as a RAM. It provides data retention for 38 years while eliminating the reliability concerns, functional disadvantages and system design complexities of battery-backed SRAM (BBSRAM). Fast write timing and high write endurance make F-RAM superior to other types of nonvolatile memory. In-system operation of the FM1608B is very similar to other RAM devices. Minimum read- and writecycle times are equal. The F-RAM memory, however, is nonvolatile due to its unique ferroelectric memory process. Unlike BBSRAM, the FM1608B is a truly monolithic nonvolatile memory. It provides the same functional benefits of a fast write without the disadvantages associated with modules and batteries or hybrid memory solutions. These capabilities make the FM1608B ideal for nonvolatile memory applications requiring frequent or rapid writes in a bytewide environment. The availability of a true surface-mount package improves the manufacturability of new designs. Device specifications are guaranteed over an industrial temperature range of -40°C to +85°C. This is a product in the pre-production phase of development. Device characterization is complete and Ramtron does not expect to change the specifications. Ramtron will issue a Product Change Notice if any specification changes are made. Rev. 2.0 Jan. 2012 SRAM & EEPROM Compatible  JEDEC 8Kx8 SRAM & EEPROM pinout  70 ns Access Time  130 ns Cycle Time Low Power Operation  15 mA Active Current  25 A (typ.) Standby Current Industry Standard Configuration  Industrial Temperature -40C to +85C  28-pin “Green”/RoHS SOIC Package Pin Configuration NC 1 28 VDD A12 2 27 WE A7 3 26 NC A6 4 25 A8 A5 5 24 A9 A4 6 23 A11 A3 7 22 OE A2 8 21 A10 A1 9 20 CE A0 10 19 DQ7 DQ0 11 18 DQ6 DQ1 12 17 DQ5 DQ2 13 16 DQ4 VSS 14 15 DQ3 Ordering Information FM1608B-SG 28-pin “Green”/RoHS SOIC Ramtron International Corporation 1850 Ramtron Drive, Colorado Springs, CO 80921 (800) 545-FRAM, (719) 481-7000 http://www.ramtron.com Page 1 of 11 FM1608B – 64Kb Bytewide 5V F-RAM A0-A12 Address Latch & Decoder A0-A12 8,192 x 8 FRAM Array CE Control Logic WE I/O Latch Bus Driver OE DQ0-7 Figure 1. Block Diagram Pin Description Pin Name A(12:0) Type Input DQ(7:0) /CE I/O Input /OE Input /WE Input VDD VSS Supply Supply Functional Truth Table /CE /WE H X X  L H L  Description Address: The 13 address lines select one of 8,192 bytes in the F-RAM array. The address value is latched on the falling edge of /CE. Data: 8-bit bi-directional data bus for accessing the F-RAM array. Chip Enable: /CE selects the device when low. Asserting /CE low causes the address to be latched internally. Address changes that occur after /CE goes low will be ignored until the next falling edge occurs. Output Enable: Asserting /OE low causes the FM1608B to drive the data bus when valid data is available. Deasserting /OE high causes the DQ pins to be tri-stated. Write Enable: Asserting /WE low causes the FM1608B to write the contents of the data bus to the address location latched by the falling edge of /CE. Supply Voltage: 5V Ground Function Standby/Precharge Latch Address (and Begin Write if /WE=low) Read Write Note: The /OE pin controls only the DQ output buffers. Rev. 2.0 Jan. 2012 Page 2 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Overview The FM1608B is a bytewide F-RAM memory. The memory array is logically organized as 8,192 x 8 and is accessed using an industry standard parallel interface. All data written to the part is immediately nonvolatile with no delay. Functional operation of the F-RAM memory is the same as SRAM type devices, except the FM1608B requires a falling edge of /CE to start each memory cycle. Memory Architecture Users access 8,192 memory locations each with 8 data bits through a parallel interface. The complete 13-bit address specifies each of the 8,192 bytes uniquely. Internally, the memory array is organized into 1024 rows of 8-bytes each. This row segmentation has no effect on operation, however the user may wish to group data into blocks by its endurance characteristics as explained on page 4. The cycle time is the same for read and write memory operations. This simplifies memory controller logic and timing circuits. Likewise the access time is the same for read and write memory operations. When /CE is deasserted high, a precharge operation begins, and is required of every memory cycle. Thus unlike SRAM, the access and cycle times are not equal. Writes occur immediately at the end of the access with no delay. Unlike an EEPROM, it is not necessary to poll the device for a ready condition since writes occur at bus speed. It is the user’s responsibility to ensure that VDD remains within datasheet tolerances to prevent incorrect operation. Also proper voltage level and timing relationships between VDD and /CE must be maintained during power-up and power-down events. See Power Cycle Timing diagram on page 9. Memory Operation The FM1608B is designed to operate in a manner similar to other bytewide memory products. For users familiar with BBSRAM, the performance is comparable but the bytewide interface operates in a slightly different manner as described below. For users familiar with EEPROM, the obvious differences result from the higher write performance of F-RAM technology including NoDelay writes and much higher write endurance. Read Operation A read operation begins on the falling edge of /CE. At this time, the address bits are latched and a memory cycle is initiated. Once started, a full memory cycle must be completed internally even if Rev. 2.0 Jan. 2012 /CE goes inactive. Data becomes available on the bus after the access time has been satisfied. After the address has been latched, the address value may be changed upon satisfying the hold time parameter. Unlike an SRAM, changing address values will have no effect on the memory operation after the address is latched. The FM1608B will drive the data bus when /OE is asserted low. If /OE is asserted after the memory access time has been satisfied, the data bus will be driven with valid data. If /OE is asserted prior to completion of the memory access, the data bus will not be driven until valid data is available. This feature minimizes supply current in the system by eliminating transients caused by invalid data being driven onto the bus. When /OE is inactive the data bus will remain tri-stated. Write Operation Writes occur in the FM1608B in the same time interval as reads. The FM1608B supports both /CEand /WE-controlled write cycles. In all cases, the address is latched on the falling edge of /CE. In a /CE controlled write, the /WE signal is asserted prior to beginning the memory cycle. That is, /WE is low when /CE falls. In this case, the part begins the memory cycle as a write. The FM1608B will not drive the data bus regardless of the state of /OE. In a /WE controlled write, the memory cycle begins on the falling edge of /CE. The /WE signal falls after the falling edge of /CE. Therefore, the memory cycle begins as a read. The data bus will be driven according to the state of /OE until /WE falls. The timing of both /CE- and /WE-controlled write cycles is shown in the electrical specifications. Write access to the array begins asynchronously after the memory cycle is initiated. The write access terminates on the rising edge of /WE or /CE, whichever is first. Data set-up time, as shown in the electrical specifications, indicates the interval during which data cannot change prior to the end of the write access. Unlike other truly nonvolatile memory technologies, there is no write delay with F-RAM. Since the read and write access times of the underlying memory are the same, the user experiences no delay through the bus. The entire memory operation occurs in a single bus cycle. Therefore, any operation including read or write can occur immediately following a write. Data polling, a technique used with EEPROMs to determine if a write is complete, is unnecessary. Page 3 of 11 FM1608B – 64Kb Bytewide 5V F-RAM accesses per second to the same row for over 10 years. Precharge Operation The precharge operation is an internal condition that prepares the memory for a new access. All memory cycles consist of a memory access and a precharge. The precharge is initiated by deasserting the /CE pin high. It must remain high for at least the minimum precharge time tPC. F-RAM Design Considerations When designing with F-RAM for the first time, users of SRAM will recognize a few minor differences. First, bytewide F-RAM memories latch each address on the falling edge of chip enable. This allows the address bus to change after starting the memory access. Since every access latches the memory address on the falling edge of /CE, users cannot ground it as they might with SRAM. The user determines the beginning of this operation since a precharge will not begin until /CE rises. However, the device has a maximum /CE low time specification that must be satisfied. Endurance Users who are modifying existing designs to use FRAM should examine the memory controller for timing compatibility of address and control pins. Each memory access must be qualified with a low transition of /CE. In many cases, this is the only change required. An example of the signal relationships is shown in Figure 2 below. Also shown is a common SRAM signal relationship that will not work for the FM1608B. Internally, a F-RAM operates with a read and restore mechanism. Therefore, each read and write cycle involves a change of state. The memory architecture is based on an array of rows and columns. Each read or write access causes an endurance cycle for an entire row. In the FM1608B, a row is 64 bits wide. Every 8-byte boundary marks the beginning of a new row. Endurance can be optimized by ensuring frequently accessed data is located in different rows. Regardless, F-RAM offers substantially higher write endurance than other nonvolatile memories. The rated endurance limit of 1012 cycles will allow 3,000 The reason for /CE to strobe for each address is twofold: it latches the new address and creates the necessary precharge period while /CE is high. Valid Strobing of /CE CE FRAM Signaling Address A1 A2 Data D1 D2 Invalid Strobing of /CE CE SRAM Signaling Address Data A1 A2 D1 D2 Figure 2. Chip Enable and Memory Address Relationships Rev. 2.0 Jan. 2012 Page 4 of 11 FM1608B – 64Kb Bytewide 5V F-RAM A second design consideration relates to the level of VDD during operation. Battery-backed SRAMs are forced to monitor VDD in order to switch to battery backup. They typically block user access below a certain VDD level in order to prevent loading the battery with current demand from an active SRAM. The user can be abruptly cut off from access to the nonvolatile memory in a power down situation with no warning or indication. below VDD min. (4.5V). Figure 3 shows a pullup resistor on /CE which will keep the pin high during power cycles assuming the MCU/MPU pin tri-states during the reset condition. The pullup resistor value should be chosen to ensure the /CE pin tracks VDD yet a high enough value that the current drawn when /CE is low is not an issue. F-RAM memories do not need this system overhead. The memory will not block access at any VDD level that complies with the specified operating range. The user should take measures to prevent the processor from accessing memory when VDD is out-oftolerance. The common design practice of holding a processor in reset during powerdown may be sufficient. It is recommended that Chip Enable is pulled high and allowed to track VDD during powerup and powerdown cycles. It is the user’s responsibility to ensure that chip enable is high to prevent accesses R Rev. 2.0 Jan. 2012 VDD FM1608B CE MCU/ MPU WE OE A(12:0) DQ Figure 3. Use of Pullup Resistor on /CE Page 5 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Electrical Specifications Absolute Maximum Ratings Symbol Description VDD Power Supply Voltage with respect to VSS VIN Voltage on any pin with respect to VSS TSTG TLEAD VESD Storage Temperature Lead Temperature (Soldering, 10 seconds) Electrostatic Discharge Voltage - Human Body Model (AEC-Q100-002 Rev. E) - Charged Device Model (AEC-Q100-011 Rev. B) - Machine Model (AEC-Q100-003 Rev. E) Package Moisture Sensitivity Level Ratings -1.0V to +7.0V -1.0V to +7.0V and VIN < VDD+1.0V -55C to + 125C 260 C 4kV 1.25kV 300V MSL-2 Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only, and the functional operation of the device at these or any other conditions above those listed in the operational section of this specification is not implied. Exposure to absolute maximum ratings conditions for extended periods may affect device reliability. DC Operating Conditions (TA = -40 C to + 85 C, VDD = 4.5V to 5.5V unless otherwise specified) Symbol Parameter Min Typ Max VDD Power Supply 4.5 5.0 5.5 IDD VDD Supply Current 15 ISB1 Standby Current (TTL) 1.8 ISB2 Standby Current (CMOS ) 25 50 ILI Input Leakage Current 1 ILO Output Leakage Current 1 VIH Input High Voltage 2.0 VDD+0.3 VIL Input Low Voltage -0.3 0.8 VOH1 Output High Voltage (IOH = -2 mA) 2.4 VOH2 Output High Voltage (IOH = -100 A) VDD-0.2 VOL1 Output Low Voltage (IOL = 4.2 mA) 0.4 VOL2 Output Low Voltage (IOL = 150 A) 0.2 Units V mA mA A A A V V V V V V Notes 1 2 3 4 4 Notes 1. VDD = 5.5V, /CE cycling at minimum cycle time. All inputs at CMOS levels, all outputs unloaded. 2. VDD = 5.5V, /CE at VIH, All other pins at TTL levels. 3. VDD = 5.5V, /CE at VIH, All other pins at CMOS levels (0.2V or VDD-0.2V). 4. VIN, VOUT between VDD and VSS. Rev. 2.0 Jan. 2012 Page 6 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Read Cycle AC Parameters (TA = -40 C to + 85 C, VDD = 4.5V to 5.5V unless otherwise specified) Symbol Parameter Min Max Units tCE Chip Enable Access Time (to data valid) 70 ns tCA Chip Enable Active Time 70 ns tRC Read Cycle Time 130 ns tPC Precharge Time 60 ns tAS Address Setup Time 0 ns tAH Address Hold Time 15 ns tOE Output Enable Access Time 12 ns tHZ Chip Enable to Output High-Z 15 ns tOHZ Output Enable to Output High-Z 15 ns Write Cycle AC Parameters (TA = -40 C to + 85 C, VDD = 4.5V to 5.5V unless otherwise specified) Symbol Parameter Min Max Units tCA Chip Enable Active Time 70 ns tCW Chip Enable to Write High 70 ns tWC Write Cycle Time 130 ns tPC Precharge Time 60 ns tAS Address Setup Time 0 ns tAH Address Hold Time 15 ns tWP Write Enable Pulse Width 40 ns tDS Data Setup 30 ns tDH Data Hold 0 ns tWZ Write Enable Low to Output High Z 15 ns tWX Write Enable High to Output Driven 10 ns tHZ Chip Enable to Output High-Z 15 ns tWS Write Enable Setup 0 ns tWH Write Enable Hold 0 ns Notes 1 1 Notes 1 1 1 2 2 Notes 1 This parameter is periodically sampled and not 100% tested. 2 The relationship between /CE and /WE determines if a /CE- or /WE-controlled write occurs. There is no timing specification associated with this relationship. Data Retention Symbol Parameter TDR @ +85ºC @ +80ºC @ +75ºC Rev. 2.0 Jan. 2012 Min 10 19 38 Max - Units Years Years Years Notes Page 7 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Capacitance (TA = 25 C, f=1.0 MHz, VDD = 5V) Symbol Parameter CI/O Input/Output Capacitance (DQ) CIN Input Capacitance AC Test Conditions Input Pulse Levels Input rise and fall times Input and output timing levels Min - Max 8 6 Units pF pF Notes Equivalent AC Load Circuit 0 to 3V 10 ns 1.5V Read Cycle Timing tRC tCA tPC CE tAS tAH A(12:0) tOE OE tOHZ DQ(7:0) tCE tHZ Write Cycle Timing - /CE Controlled Timing tWC tCA tPC CE tAS tAH A(12:0) tWS tWH WE OE tDS tDH DQ(7:0) Rev. 2.0 Jan. 2012 Page 8 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Write Cycle Timing - /WE Controlled Timing tWC tCA tPC tC W CE tAS tAH A(12:0) tWH tWS tWP WE OE tWZ tWX DQ(7:0) out tDS tDH DQ(7:0) in Power Cycle Timing VDD VDD (min) VDD (min) t PD t PU t PC CE VIH (min) VIH (min) VIL (max) Power Cycle Timing (TA = -40 C to + 85 C, VDD = 4.5V to 5.5V unless otherwise specified) Symbol Parameter Min Max Units tPU VDD(min) to First Access Start 10 ms tPD Last Access Complete to VDD(min) 0 s tVR VDD Rise Time 30 s/V tVF VDD Fall Time 30 s/V Notes 1 1 Notes 1 Slope measured at any point on VDD waveform. Rev. 2.0 Jan. 2012 Page 9 of 11 FM1608B – 64Kb Bytewide 5V F-RAM 28-pin SOIC (JEDEC MS-013 variation AE) All dimensions in millimeters 7.50 ±0.10 10.30 ±0.30 0.25 0.75 Pin 1 17.90 ±0.20 2.35 2.65 45 0.23 0.32 0?- 8? 1.27 typ 0.10 0.30 0.33 0.51 0.10 0.40 1.27 SOIC Package Marking Scheme RAMTRON XXXXXXX-P RYYWWLLLLLLL Legend: XXXXXX= part number, P= package type (-SG) R=rev code, YY=year, WW=work week, LLLLLL= lot code Example: FM1608B, 70ns speed, “Green”/RoHS SOIC package, A die rev., Year 2010, Work Week 37, Lot code 00002G RAMTRON FM1608B-SG A103700002G Rev. 2.0 Jan. 2012 Page 10 of 11 FM1608B – 64Kb Bytewide 5V F-RAM Revision History Revision 1.0 1.1 1.2 2.0 Rev. 2.0 Jan. 2012 Date 11/22/2010 12/20/2010 3/14/2011 1/6/2012 Summary Initial Release Updated MSL rating. Changed tPU and tVF spec limits. Changed to Pre-Production status. Changed tVF spec. Page 11 of 11
FM1608B-SG
1. 物料型号:FM1608B 2. 器件简介: - 采用先进的铁电工艺的64千字节非易失性F-RAM存储器。 - 与传统的BBSRAM相比,F-RAM具有更高的写入速度和耐久性,且无需电池支持。 - 适用于需要频繁或快速写入的非易失性存储应用。 3. 引脚分配: - 28针“绿色”/RoHS SOIC封装。 - 包括地址输入A(12:0)、数据输入输出DQ(7:0)、控制信号/CE、/OE、/WE等。 4. 参数特性: - 兼容JEDEC 8Kx8 SRAM和EEPROM引脚。 - 访问时间70ns,周期时间130ns。 - 活跃电流15mA,待机电流25μA(典型值)。 - 数据保持期长达38年(在+75°C下)。 - 写入耐久性高达1万亿次读写。 5. 功能详解: - F-RAM存储器的操作与其他RAM设备类似,但具有非易失性,数据立即非易失且写入无延迟。 - 读/写操作的最小周期时间和访问时间相等,写入操作立即在访问结束时发生,无需等待。 - 支持/CE和/WE控制的写入周期。 6. 应用信息: - 适用于工业温度范围-40°C至+85°C。 - 适用于需要高可靠性和高写入耐久性的应用。 7. 封装信息: - 28针SOIC封装,符合JEDEC标准。
FM1608B-SG 价格&库存
很抱歉,暂时无法提供与“FM1608B-SG”相匹配的价格&库存,您可以联系我们找货
