S-89140BC-K8T2U
S-89140BC-K8T2U
    ABLIC(艾普凌科)
    TMSOP8_2.9X2.8MM
    IC CMOS 2 CIRCUIT 8TMSOP
S-89140BC-K8T2U 数据手册
S-89130/89140 Series www.ablic.com www.ablicinc.com MINI ANALOG SERIES CMOS OPERATIONAL AMPLIFIER © ABLIC Inc., 2011 Rev.1.0_02 The mini-analog series is a group of ICs that incorporate a general purpose analog circuit in a small package. S-89130/89140 Series is a CMOS type operational amplifier that has a phase compensation circuit, and operates at a low voltage with low current consumption. S-89130/89140 Series can operate within a wide temperature range of 40C to 125C. This product is a dual operational amplifier (two circuits).  Features  Lower operating voltage :  Low current consumption (per circuit) :     VDD  2.7 V to 5.5 V IDD  1.00 mA typ. (S-89130 Series, VDD  5.0 V) IDD  0.27 mA typ. (S-89140 Series, VDD  5.0 V) Low input offset voltage : VIO  6.0 mV max. (S-89130 Series) VIO  7.0 mV max. (S-89140 Series) Operational temperature range : 40C to 125C No external capacitors required for internal phase compensation Lead-free (Sn 100%), halogen-free *1 *1. Refer to “ Product Name Structure” for details.  Applications      Current sensing Signal amplification Buffer Active filter Electronics devices  Packages  SNT-8A  TMSOP-8 Caution This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable. 1 MINI ANALOG SERIES S-89130/89140 Series CMOS OPERATIONAL AMPLIFIER Rev.1.0_02  Block Diagram VDD IN1()  IN1()  OUT1 IN2()  IN2()  OUT2 VSS Figure 1 2 MINI ANALOG SERIES Rev.1.0_02 CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series  Product Name Structure Users can select the product type for the S-89130/89140 Series. Refer to “1. Product name” regarding the contents of product name, “2. Packages” regarding the package drawings and “3. Product name list” regarding the product type. 1. Product name S-891 x 0 B C  xxxx U Environmental code U : Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 I8T1 : SNT-8A, tape K8T2 : TMSOP-8, tape Number of circuits B :2 Current consumption (per circuit) 3 : IDD  1.00 mA (VDD  5.0 V) 4 : IDD  0.27 mA (VDD  5.0 V) *1. 2. Refer to the tape specifications Packages Package Name SNT-8A TMSOP-8 3. Package PH008-A-P-SD FM008-A-P-SD Drawing Code Tape Reel PH008-A-C-SD PH008-A-R-SD FM008-A-C-SD FM008-A-R-SD Land PH008-A-L-SD  Product name list Table 1 Product name Current consumption *1 (per circuit) S-89130BC-I8T1U S-89130BC-K8T2U S-89140BC-I8T1U S-89140BC-K8T2U *1. The value when VDD  5.0 V 1.00 mA 1.00 mA 0.27 mA 0.27 mA Gain-bandwidth*1 3.0 MHz 3.0 MHz 1.0 MHz 1.0 MHz Package SNT-8A TMSOP-8 SNT-8A TMSOP-8 3 MINI ANALOG SERIES S-89130/89140 Series CMOS OPERATIONAL AMPLIFIER Rev.1.0_02  Pin Configurations 1. SNT-8A Table 2 SNT-8A Top view 1 8 2 7 3 6 4 5 Pin No. 1 2 3 4 5 6 7 8 Symbol OUT1 IN1() IN1() VSS IN2() IN2() OUT2 VDD Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin Figure 2 2. TMSOP-8 Table 3 TMSOP-8 Top view 1 8 2 7 3 6 4 5 Figure 3 4 Pin No. 1 2 3 4 5 6 7 8 Symbol OUT1 IN1() IN1() VSS IN2() IN2() OUT2 VDD Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin MINI ANALOG SERIES Rev.1.0_02 CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series  Absolute Maximum Ratings Table 4 Parameter Power supply voltage Input voltage Output voltage Differential input voltage Symbol VDD VIN(+), VIN(-) VOUT VIND ISOURCE ISINK Output pin current SNT-8A TMSOP-8 Operating ambient temperature Junction temperature Storage temperature Power dissipation When mounted on board [Mounted board] (1) Board size : (2) Board name : Caution PD Topr Tj Tstg 114.3 mm  76.2 mm  t1.6 mm JEDEC STANDARD51-7 The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1000 Power Dissipation (PD) [mW] *1. (Ta 25C unless otherwise specified) Absolute Maximum Rating Unit VSS0.3 to VSS7.0 V VSS0.3 to VSS7.0 V VSS0.3 to VDD0.3 V 7.0 V 20.0 mA 20.0 mA 550*1 mW 800*1 mW 40 to 125 C 55 to 150 C 55 to 150 C 800 TMSOP-8 600 SNT-8A 400 200 0 0 50 100 150 Ambient Temperature (Ta) [C] Figure 4 Power Dissipation of Package (When Mounted on Board) 5 MINI ANALOG SERIES S-89130/89140 Series CMOS OPERATIONAL AMPLIFIER Rev.1.0_02  Electrical Characteristics 1. S-89130 Series Table 5 Parameter Symbol Conditions Range of operating power supply VDD voltage 1. 1  (Ta 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 2.7  5.5  V VDD 5.0 V Table 6 DC Electrical Characteristics (VDD  5.0 V) Parameter (Ta 25°C unless otherwise specified) Symbol Conditions Min. Typ. Max. Unit Test Circuit  1.00 1.25 mA 5 Current consumption (per circuit) IDD VCMR  VOUT  VDD / 2 Input offset voltage VCMR  VDD / 2 6.0 3.0 6.0 mV 1 VCMR  VDD / 2  3  V/C 1 Input offset voltage drift VIO VIO Ta Input offset current IIO   1  pA  Input bias current IBIAS   1  pA  Common-mode input voltage range VCMR  0.1  3.8 V 2 Voltage gain (open loop) AVOL VOUT  VSS0.5 V to VDD0.5 V VCMR  VDD / 2, RL  1.0 M 88 110  dB 8 VOH RL  1.0 M 4.9   V 3 VOL RL 1.0 M   0.1 V 4 CMRR VCMR  VSS0.1 V to VDD1.2 V 70 85  dB 2 PSRR VDD 2.7 V to 5.5 V 70 90  dB 1 Source current ISOURCE VOUT  VDD0.12 V 5.0   mA 6 Sink current ISINK VOUT  0.12 V 5.0   mA 7 Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Table 7 AC Electrical Characteristics (VDD  5.0 V) Parameter Conditions Min. Typ. Max. Unit Slew rate SR RL  1.0 M, CL  15 pF (Refer to Figure 13)  2.0  V/s Gain-bandwidth product GBP CL  0 pF  3.0  MHz 6 Symbol (Ta 25°C unless otherwise specified) MINI ANALOG SERIES Rev.1.0_02 1. 2 CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series VDD 2.7 V Table 8 DC Electrical Characteristics (VDD 2.7 V) Parameter (Ta 25°C unless otherwise specified) Symbol Conditions Min. Typ. Max. Unit Test Circuit  0.90 1.20 mA 5 Current consumption (per circuit) IDD VCMR VOUT  VDD / 2 Input offset voltage VCMR  VDD / 2 6.0 3.0 6.0 mV 1 VCMR  VDD / 2  3  V/C 1 VIO VIO Ta Input offset voltage drift Input offset current IIO   1  pA  Input bias current IBIAS   1  pA  VCMR  0.1  1.5 V 2 AVOL VOUT  VSS 0.5 V to VDD0.5 V VCMR  VDD / 2, RL  1.0 M 80 110  dB 8 VOH RL  1.0 M 2.6   V 3 VOL RL  1.0 M   0.1 V 4 CMRR VCMR  VSS0.1 V to VDD1.2 V 65 85  dB 2 PSRR VDD 2.7 V to 5.5 V 70 90  dB 1 Source current ISOURCE VOUT  VDD0.12 V 5.0   mA 6 Sink current ISINK VOUT  0.12 V 5.0   mA 7 Common-mode range input voltage Voltage gain (open loop) Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Table 9 AC Electrical Characteristics (VDD  2.7 V) Parameter Symbol (Ta 25°C unless otherwise specified) Conditions Min. Typ. Max. Unit Slew rate SR RL 1.0 M, CL  15 pF (Refer to Figure 13)  2.0  V/s Gain-bandwidth product GBP CL  0 pF  3.0  MHz 7 MINI ANALOG SERIES S-89130/89140 Series 2. CMOS OPERATIONAL AMPLIFIER Rev.1.0_02 S-89140 Series Table 10 Parameter Symbol Conditions Range of operating power supply VDD voltage 2. 1  (Ta 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 2.7  5.5  V VDD 5.0 V Table 11 DC Electrical Characteristics (VDD  5.0 V) Parameter (Ta 25°C unless otherwise specified) Symbol Conditions Min. Typ. Max. Unit Test Circuit  0.27 0.35 mA 5 Current consumption (per circuit) IDD VCMR  VOUT  VDD / 2 Input offset voltage VCMR  VDD / 2 7.0 3.0 7.0 mV 1 VCMR  VDD / 2  3  V/C 1 Input offset voltage drift VIO VIO Ta Input offset current IIO   1  pA  Input bias current IBIAS   1  pA  Common-mode input voltage range VCMR  0.1  3.8 V 2 Voltage gain (open loop) AVOL VOUT  VSS0.5 V to VDD0.5 V VCMR  VDD / 2, RL  1.0 M 88 110  dB 8 VOH RL  1.0 M 4.9   V 3 VOL RL 1.0 M   0.1 V 4 CMRR VCMR  VSS0.1 V to VDD1.2 V 70 85 dB 2 PSRR VDD2.7 V to 5.5 V 70 90  dB 1 Source current ISOURCE VOUT  VDD  0.12 V 5.0   mA 6 Sink current ISINK VOUT  0.12 V 5.0   mA 7 Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio  Table 12 AC Electrical Characteristics (VDD  5.0 V) Parameter Symbol (Ta 25°C unless otherwise specified) Conditions Min. Typ. Max. Unit 0.5  V/s 1.0  MHz Slew rate SR RL  1.0 M, CL  15 pF (Refer to Figure 13)  Gain-bandwidth product GBP CL  0 pF  8 MINI ANALOG SERIES Rev.1.0_02 2. 2 CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series VDD  2.7 V Table 13 DC Electrical Characteristics (VDD  2.7 V) Parameter (Ta 25°C unless otherwise specified) Symbol Conditions Min. Typ. Max. Unit Test Circuit  0.25 0.33 mA 5 Current consumption (per circuit) IDD VCMR  VOUT  VDD / 2 Input offset voltage VCMR  VDD / 2 7.0 3.0 7.0 mV 1 VCMR  VDD / 2  3  V/C 1 Input offset voltage drift VIO VIO Ta Input offset current IIO   1  pA  Input bias current IBIAS   1  pA  Common-mode input voltage range VCMR  0.1  1.5 V 2 Voltage gain (open loop) AVOL VOUT  VSS  0.5 V to VDD  0.5 V VCMR  VDD / 2, RL 1.0 M 80 110  dB 8 VOH RL  1.0 M 2.6   V 3 VOL RL  1.0 M   0.1 V 4 CMRR VCMR VSS  0.1 V to VDD  1.2 V 65 85 dB 2 PSRR VDD 2.7 V to 5.5 V 70 90  dB 1 Source current ISOURCE VOUT  VDD  0.12 V 5.0   mA 6 Sink current ISINK VOUT  0.12 V 5.0   mA 7 Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio  Table 14 AC Electrical Characteristics (VDD 2.7 V) Parameter Symbol (Ta 25°C unless otherwise specified) Conditions Min. Typ. Max. Unit 0.5  V/s 1.0  MHz Slew rate SR RL  1.0 M, CL  15 pF (Refer to Figure 13)  Gain-bandwidth product GBP CL  0 pF  9 MINI ANALOG SERIES S-89130/89140 Series CMOS OPERATIONAL AMPLIFIER Rev.1.0_02  Test Circuit (Per Circuit) 1. Power supply voltage rejection ratio, input offset voltage VDD  Power supply voltage rejection ratio (PSRR) The power supply voltage rejection ratio (PSRR) can be calculated by the following expression, with VOUT measured at each VDD. RF RS  VOUT  RS RF Test conditions: VDD  2.7 V: VDD  VDD1, VOUT  VOUT1, VDD  5.5 V: VDD  VDD2, VOUT  VOUT2 PSRR  20 log VCMR  VDD / 2 RFRS RS    Common-mode input signal rejection ratio, common-mode input voltage range VDD  Common-mode input signal rejection ratio (CMRR) The common-mode input signal rejection ratio (CMRR) can be calculated by the following expression, with VOUT measured at each VIN. RF RS   RS RF VIN VDD / 2 Figure 6 10   Input offset voltage (VIO) VDD   RS VIO  VOUT  2  RFRS  Figure 5 2. VDD1  VDD2   VDD1 VDD2  VOUT1  2   VOUT2  2   VOUT Test conditions: VIN  VCMR Max.: VIN  VIN1, VOUT  VOUT1, VIN  VCMR Min.: VIN  VIN2, VOUT  VOUT2 CMRR  20 log    RFRS VIN1  VIN2  RS  VOUT1  VOUT2   Common-mode input voltage range (VCMR) The common mode input voltage range (VCMR) is the range of VIN in which the common mode input signal rejection ratio (CMRR) is satisfied when VIN is varied. MINI ANALOG SERIES Rev.1.0_02 3. CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series Maximum output swing voltage (VOH) VDD  Maximum output swing voltage (VOH)  VOH  Test conditions VDD VIN1  2  0.1 V VDD VIN2  2  0.1 V RL  1 M RL VIN1 VDD / 2 VIN2 Figure 7 4. Maximum output swing voltage (VOL) VDD VDD / 2  Maximum output swing voltage (VOL) RL   VIN1 VOL Test conditions: VDD VIN1  2  0.1 V VDD VIN2  2  0.1 V RL  1 M  VIN2 Figure 8 5. Current consumption VDD  Current consumption (IDD) A   VCMR = VDD / 2 Figure 9 11 MINI ANALOG SERIES S-89130/89140 Series 6. CMOS OPERATIONAL AMPLIFIER Rev.1.0_02 Source current VDD  Source current (ISOURCE) Test conditions: VOUT  VDD  0.12 V VDD VIN1  2  0.1 V VDD VIN2  2  0.1 V   VIN1 A VOUT VIN2 Figure 10 7. Sink current VDD VOUT A   VIN1 VIN2 Figure 11 12  Sink current (ISINK) Test conditions: VOUT  VSS  0.12 V VDD VIN1  2  0.1 V VDD VIN2  2  0.1 V MINI ANALOG SERIES Rev.1.0_02 8. CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series Voltage gain (open loop) VDD RS RF VDDN  D.U.T  RS  NULL  VOUT RF 1 M VCMR  VDD / 2 VSSN VM VDD / 2 Figure 12  Voltage-gain (open loop) (AVOL) The voltage gain (AVOL) can be calculated by the following expression, with measured VOUT at each VM. Test conditions: VM  VDD  0.5 V: VM  VM1, VOUT  VOUT1, VM  0.5 V: VM  VM2, VOUT  VOUT2 AVOL  20 log 9.    RFRS VM1  VM2  RS  VOUT1  VOUT2  Slew rate (SR) Measured by the voltage follower circuit. tR  tF  20 ns (0 V to VCMR Max.) IN()  VCMR Max. IN()  0 V VOUT ( IN()) tTHL VCMR Max. VCMR Max.  0.9 VCMR Max.  0.1 VOUT ( IN()) tTLH VCMR Max.  0.8 tTLH VCMR Max.  0.8 SR tTHL SR  Figure 13 13 MINI ANALOG SERIES S-89130/89140 Series CMOS OPERATIONAL AMPLIFIER Rev.1.0_02  Precautions  Do not apply an electrostatic discharge to this IC that exceeds performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party.  Use this IC with the output current 20 mA or less.  This IC operates stably even directly connecting a load capacitance 100 pF or less to the output pin, as seen in Figure 14. When using a load capacitance 100 pF or larger, set a resistor 47  or more, as seen in Figure 15. In case of connecting a filter for noise prevention, and using a load capacitance 100 pF or more, also set a resistor 47  or more as seen in Figure 16. VDD VIN  VIN  VOUT Load capacitance 100 pF or less VSS Figure 14 VDD VIN  VIN  VOUT 47  or more Load capacitance VSS Figure 15 VDD Filter VIN  VIN  VOUT 47  or more Load capacitance VSS Figure 16 Caution 14 The above connection diagram and constant will not guarantee successful operation. Perform through evaluation using the actual application to set the constant. MINI ANALOG SERIES CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series Rev.1.0_02  Characteristics (Typical Data) 1. Current consumption (per circuit) vs. Power supply voltage 1. 1 S-89130 Series 1. 2 S-89140 Series IDDVDD, VSS  0 V, VCMR  VOUT  VDD / 2 IDDVDD, VSS  0 V, VCMR  VOUT  VDD / 2 1.2 0.4 0.3 0.8 +25°C Ta = −40°C 0.6 IDD [mA] IDD [mA] 1.0 +125°C 0.4 0.2 0.1 0.2 0 0 2 3 4 5 6 2 3 VDD [V] 4 VDD [V] 5 6 Voltage gain vs. Frequency 2. 1 S-89130 Series 140 120 100 80 60 40 20 0 Ta = −40°C +25°C +125°C 0.1 2. 2 AVOLf, VDD  5.0 V, VSS  0 V 1 AVOL [dB] AVOL [dB] AVOLf, VDD  2.7 V, VSS  0 V 140 120 100 80 60 40 20 0 10 100 1k 10k 100k 1M 10M f [Hz] Ta = −40°C +25°C +125°C 0.1 1 10 100 1k 10k 100k 1M 10M f [Hz] S-89140 Series AVOLf, VDD  2.7 V, VSS  0 V 140 120 100 80 60 40 20 0 AVOLf, VDD  5.0 V, VSS  0 V Ta = −40°C +25°C +125°C 0.1 1 10 100 1k 10k 100k 1M 10M f [Hz] AVOL [dB] AVOL [dB] 2. +125°C +25°C Ta = −40°C 140 120 100 80 60 40 20 0 Ta = −40°C +25°C +125°C 0.1 1 10 100 1k 10k 100k 1M 10M f [Hz] 15 MINI ANALOG SERIES S-89130/89140 Series Rev.1.0_02 Output current 3. 1 ISOURCE vs. Power supply voltage ISOURCE [mA] 3. 1. 1 S-89130 Series S-89140 Series ISOURCEVDD, VOUT  VDD  0.12 V, VSS  0 V ISOURCEVDD, VOUT  VDD  0.12 V, VSS  0 V 14 12 10 8 6 4 2 0 14 12 10 8 6 4 2 0 Ta = −40°C +25°C +125°C 2 3. 2 3. 1. 2 ISOURCE [mA] 3. CMOS OPERATIONAL AMPLIFIER 3 4 VDD [V] 5 6 Ta = −40°C +25°C +125°C 2 3 S-89130 Series 3. 2. 2 ISINKVDD, VOUT 0.12 V, VSS  0 V 10 8 Ta = −40°C 6 ISINK [mA] ISINK [mA] 8 +25°C 4 +125°C 2 Ta = −40°C 6 +25°C 4 +125°C 2 0 0 2 3 4 5 6 2 3 VDD [V] 4 5 6 VDD [V] Output voltage (VOUT) vs. ISOURCE 3. 3. 1 S-89130 Series VOUTISOURCE, VDD  2.7 V, VSS  0 V VOUTISOURCE, VDD  5.0 V, VSS  0 V 3.0 6 2.5 2.0 +25°C 1.5 1.0 Ta = −40°C 5 Ta = −40°C VOUT [V] VOUT [V] 6 S-89140 Series ISINKVDD, VOUT  0.12 V, VSS 0 V 10 +125°C 0.5 4 3 +125°C 2 +25°C 1 0 0 0 16 5 ISINK vs. Power supply voltage 3. 2. 1 3. 3 4 VDD [V] 20 40 60 ISOURCE [mA] 80 100 0 20 40 60 ISOURCE [mA] 80 100 MINI ANALOG SERIES Rev.1.0_02 3. 3. 2 CMOS OPERATIONAL AMPLIFIER S-89130/89140 Series S-89140 Series VOUTISOURCE, VDD 2.7 V, VSS  0 V VOUTISOURCE, VDD  5.0 V, VSS 0 V 3.0 6 5 Ta = −40°C 2.0 VOUT [V] VOUT [V] 2.5 1.5 1.0 +25°C +125°C 0.5 3 0 0 20 40 60 ISOURCE [mA] 80 100 0 40 60 ISOURCE [mA] 80 100 S-89130 Series VOUTISINK, VDD  2.7 V, VSS  0 V VOUTISINK, VDD  5.0 V, VSS  0 V 3.0 6 2.5 5 +25°C 2.0 VOUT [V] VOUT [V] 20 Output voltage (VOUT) vs. ISINK 3. 4. 1 +125°C 1.5 1.0 Ta = −40°C 0.5 +125°C 3 Ta = −40°C +25°C 2 0 0 3. 4. 2 4 1 0 20 40 60 ISINK [mA] 80 100 0 20 40 60 ISINK [mA] 80 100 S-89140 Series VOUTISINK, VDD  2.7 V, VSS  0 V VOUTISINK, VDD  5.0 V, VSS  0 V 3.0 6 +125°C 2.0 5 +25°C VOUT [V] 2.5 VOUT [V] +25°C +125°C 2 1 0 3. 4 Ta = −40°C 4 1.5 1.0 Ta = −40°C 0.5 4 +125°C 3 +25°C Ta = −40°C 2 1 0 0 0 20 40 60 ISINK [mA] 80 100 0 20 40 60 ISINK [mA] 80 100 17 MINI ANALOG SERIES S-89130/89140 Series 4. CMOS OPERATIONAL AMPLIFIER Rev.1.0_02 Input bias current vs. Temperature IBIASTa, VDD  5.0 V, VSS  0 V, VCMR  VDD / 2 60 IBIAS[nA] 50 40 30 20 10 0 40 25 18 0 25 50 Ta [°C] 75 100 125 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-89140BC-K8T2U 价格&库存
很抱歉,暂时无法提供与“S-89140BC-K8T2U”相匹配的价格&库存,您可以联系我们找货
