GB05MPS17-247
GB05MPS17-247
    GENESICSEMICONDUCTOR
    TO-247-2
    SIC DIODE 1700V 5A TO-247-2
GB05MPS17-247 数据手册
GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode TM Silicon Carbide Schottky Diode VRRM = IF (TC = 165°C) = QC = Features • • • • • • • • Package Low VF for High Temperature Operation Enhanced Surge and Avalanche Robustness Superior Figure of Merit QC/IF Low Thermal Resistance Low Reverse Leakage Current Temperature Independent Fast Switching Positive Temperature Coefficient of VF Low VF for High Temperature Operation Case RoHS TO-247-2 Advantages • • • • • • • • 1700 V 5A 54 nC K REACH A Applications Improved System Efficiency High System Reliability Optimal Price Performance Reduced Cooling Requirements Increased System Power Density Zero Reverse Recovery Current Easy to Parallel without Thermal Runaway Improved System Efficiency • • • • • • • • EV Fast Chargers Solar Inverters Anti-Parallel / Free-Wheeling Diode Motor Drives High Frequency Rectifiers Switched Mode Power Supply (SMPS) Induction Heating and Welding Medical Imaging Absolute Maximum Ratings (At TC = 25°C Unless Otherwise Stated) Parameter Repetitive Peak Reverse Voltage Continuous Forward Current Symbol VRRM IF Non-Repetitive Peak Forward Surge Current, Half Sine Wave IF,SM Repetitive Peak Forward Surge Current, Half Sine Wave IF,RM Non-Repetitive Peak Forward Surge Current i2t Value Non-Repetitive Avalanche Energy Diode Ruggedness Power Dissipation Operating and Storage Temperature Rev 21/Jun IF,MAX ∫i2dt EAS dV/dt PTOT T j , T stg Conditions TC = 100°C, D = 1 TC = 135°C, D = 1 TC = 165°C, D = 1 TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 µs TC = 25°C, tP = 10 ms L = 10.4 mH, IAS = 5 A VR = 0 ~ 1360 V TC = 25°C Values 1700 16 11 5 54 43 32 22 270 14 131 200 155 -55 to 175 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Unit V Note A Fig. 4 A A A A2s mJ V/ns W °C Fig. 3 Page 1 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode TM Electrical Characteristics Parameter Symbol Diode Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Switching Time tS Total Capacitance C Conditions Min. IF = 5 A, Tj = 25°C IF = 5 A, Tj = 175°C VR = 1700 V, Tj = 25°C VR = 1700 V, Tj = 175°C VR = 600 V VR = 1200 V IF ≤ IF,MAX dIF/dt = 200 A/µs VR = 600 V VR = 1200 V VR = 1 V, f = 1MHz VR = 1200 V, f = 1MHz Values Typ. 1.5 2.1 1 5 37 54 Max. 1.8 10 Unit Note V Fig. 1 µA Fig. 2 nC Fig. 7 < 10 ns 470 26 pF Fig. 6 Unit Note °C/W g Nm Fig. 9 Thermal/Package Characteristics Parameter Symbol Thermal Resistance, Junction - Case Weight Mounting Torque Rev 21/Jun RthJC WT TM Conditions Screws to Heatsink Min. Values Typ. 0.97 6.0 Max. 1.1 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Page 2 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode Figure 1: Typical Forward Characteristics I F = f(VF,Tj); tP = 250 µs Figure 3: Power Derating Curves PTOT = f(TC ); Tj = 175°C Rev 21/Jun TM Figure 2: Typical Reverse Characteristics I R = f(VR,Tj) Figure 4: Current Derating Curves (Typical VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Page 3 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode Figure 5: Current Derating Curves (Maximum VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Figure 7: Typical Capacitive Charge vs Reverse Voltage Characteristics QC = f(VR); f = 1MHz Rev 21/Jun TM Figure 6: Typical Junction Capacitance vs Reverse Voltage Characteristics C = f(VR); f = 1MHz Figure 8: Typical Capacitive Energy vs Reverse Voltage Characteristics EC = f(VR); f = 1MHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Page 4 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode TM Figure 9: Transient Thermal Impedance Zth,jc = f(tP,D); D = tP/T Figure 10: Forward Curve Model Forward Curve Model Equation: I F = (VF - VBI)/RDIFF (A) Built-In Voltage (VBI): VBI(Tj) = m × Tj + n (V) m = -0.00128 (V/°C) n = 0.99 (V) Differential Resistance (RDIFF): 1/RDIFF RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω) a = 2.03e-06 (Ω/°C2) b = 0.000711 (Ω/°C) c = 0.093 (Ω) VBI Forward Power Loss Equation: PLOSS = VBI(Tj) × I AVG + RDIFF(Tj) × I RMS2 I F = f(VF,Tj) Rev 21/Jun Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Page 5 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode TM Package Dimensions TO-247-2 Package Outline 0.190 (4.83) 0.205 (5.21) 0.620 (15.75) 0.635 (16.13) 0.170 (4.32) 0.216 (5.49) 0.530 (13.46) 0.557 (14.16) 0.059 (1.50) 0.098 (2.49) 0.085 (2.16) 0.108 (2.75) 0.212 (5.39) 0.244 (6.20) 0.047 (1.19) 0.238 (6.04) 0.248 (6.30.) 0.819 0.831 (20.80) (21.10) 0.640 (16.25) 0.695 (17.65) Ø 0.140 (3.56) Ø 0.144 (3.65) Ø 0.283 (7.19) REF 0.161 (4.10) 0.173 (4.40) 0.780 0.800 (19.81) (20.32) 0.075 (1.91) 0.094 (2.39) 0.044 (1.12) 0.052 (1.33) 0.214 (5.44) BSC. Recommended Solder Pad Layout 0.022 (0.55) 0.027 (0.69) 0.090 (2.29) 0.100 (2.55) Package View Case (K) 0.120 (3.05) 0.428 (10.88) 0.08 (2.03) K A NOTE 1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS. Rev 21/Jun Latest Version at: www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247.pdf Page 6 of 7 GB05MPS17-247 1700V 5A SiC Schottky MPS™ Diode TM Compliance RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive 2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative. REACH Compliance REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. Disclaimer GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal injury and/or property damage. Related Links • SPICE Models: https://www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247_SPICE.zip • PLECS Models: https://www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247_PLECS.zip • CAD Models: https://www.genesicsemi.com/sic-schottky-mps/GB05MPS17-247/GB05MPS17-247_3D.zip • Evaluation Boards: https://www.genesicsemi.com/technical-support • Reliability: https://www.genesicsemi.com/reliability • Compliance: https://www.genesicsemi.com/compliance • Quality Manual: https://www.genesicsemi.com/quality Revision History • Rev 21/Jun: Updated with most recent test data • Supersedes: Rev 19/Apr, Rev 20/Apr, Rev 20/Aug www.genesicsemi.com/sic-schottky-mps/ Rev 21/Jun Copyright© 2021 GeneSiC Semiconductor Inc. All Rights Reserved. Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155, Dulles, VA 20166; USA Page 7 of 7
GB05MPS17-247
物料型号:GB05MPS17-247
器件简介:这是一款1700V 5A的碳化硅肖特基二极管,具有低正向电压、增强的浪涌和雪崩鲁棒性、优越的品质因数、低热阻、低反向漏电流、温度无关的快速开关、正温度系数的正向电压、低高温操作正向电压等特性。
引脚分配:文档中未明确提供引脚分配信息,但根据封装信息,该器件使用TO-247-2封装。
参数特性: - 重复峰值反向电压(VRRM):1700V - 连续正向电流(IF):在不同结温下分别为16A、11A、5A - 非重复峰值正向浪涌电流(IESM):54A - 重复峰值正向浪涌电流(IFRM):在25°C时为32A,150°C时为22A - 非重复峰值正向浪涌电流(IEMAX):270A - i2t值(Ji2dt):14A²s - 非重复雪崩能量(EAS):131mJ - 反向恢复时间(ts):小于10纳秒 - 总电容(C):在1MHz频率下,分别为470pF和26pF
功能详解:该二极管具有低正向电压降,适合高温操作,具有增强的浪涌和雪崩鲁棒性,低热阻,低反向漏电流,温度无关的快速开关特性,正温度系数的正向电压,这些特性使其在多种应用中表现出色。
应用信息: - 电动汽车快速充电器 - 太阳能逆变器 - 防反并联/自由轮二极管 - 电机驱动 - 高频整流器 - 开关模式电源供应(SMPS) - 感应加热和焊接 - 医疗成像
封装信息:该器件采用TO-247-2封装,符合RoHS和REACH标准。
绝对最大额定值和电气特性表格提供了详细的操作条件和相应的参数值。热/封装特性表格提供了热阻、重量和安装扭矩等信息。还包括了正向特性曲线、反向特性曲线、功率降额曲线、电流降额曲线、结电容与反向电压特性、电容电荷与反向电压特性、电容能量与反向电压特性、瞬态热阻抗和正向曲线模型等图表。
合规性:文档提到了RoHS和REACH的合规性,指出产品符合相关标准,并且可以提供相关的声明。
免责声明:GeneSiC Semiconductor, Inc. 保留了在不通知的情况下更改产品规格和数据的权利,并声明对使用或应用任何产品所产生的所有和任何保证和责任不承担责任。
相关链接:文档末尾提供了SPICE模型、PLECS模型、CAD模型、评估板、可靠性、合规性和质量手册的链接。
GB05MPS17-247 价格&库存
很抱歉,暂时无法提供与“GB05MPS17-247”相匹配的价格&库存,您可以联系我们找货
