TS2596S
Taiwan Semiconductor
2A, 24V, 150kHz Step-Down DC-DC Converter
DESCRIPTION
FEATURES
TS2596S Series are step-down switching regulators
Output Voltage: 5V & Adjustable version
with all required active functions. It is capable of driving
Adjustable Output Voltage 1.23V~19.5V ±4%
2A load with excellent line and load regulations. These
150kHz ±15% fixed switching frequency
devices are available in fixed output voltages of 5V,
Voltage Mode Non-synchronous PWM control
and an adjustable output version. TS2596S series
Thermal Shutdown and Current Limit Protection
ON/OFF Shutdown Control Input
Soft-Start (SS) Function
Short Circuit Protect (SCP)
Operating Voltage Can be up to 24V
Output Load Current 2A
Low Power Standby Mode
operates at a switching frequency of 150kHz thus
allowing smaller sized filter components than what
would be needed with lower frequency switching
regulators. It substantially not only reduces the area of
board size but also the size of heat sink, and in some
cases no heat sink is required. The ±4% tolerance on
output voltage within specified input voltages and
output load conditions is guaranteed. Also, the
APPLICATION
oscillator frequency accuracy is within ±10%. External
shutdown is included. Featuring 70μA (typical) standby
current. The output switch includes cycle-by-cycle
Simple High-efficiency Step down Regulator
On-Card Switching Regulators
current limiting, as well as thermal shutdown for full
protection under fault conditions.
SOP-8
Pin Definition:
1. Input
2. SW Output
3. Feedback
4. Enable
8. GND
7. GND
6. GND
5. GND
Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise specified) (Note 1)
PARAMETER
SYMBOL
LIMIT
UNIT
Supply Voltage
VCC
+28
V
Operating Voltage Range
VOP
+4.5 to +24
V
SW, EN Pin Input Voltage
VSW , VEN
-0.3 to VCC
V
Feedback Pin Voltage
VFB
-0.3 to VCC
V
Power Dissipation
PD
Internally Limited
W
VOUT
-1
Output Voltage to Ground
Storage Temperature Range
THERMAL PERFORMANCE
-65 to +150
TOP
-40 to +125
o
SYMBOL
RθJC
RθJA
LIMIT
15
70
TST
Operating Temperature Range
V
o
C
C
(Note 3)
PARAMETER
Thermal Resistance Junction to Case
Thermal Resistance Junction to Ambient
1
UNIT
°C/W
°C/W
Version: C1602
TS2596S
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise specified)
PARAMETER
SYMBOL
Output Feedback
ADJ
Efficiency
VFB
η
Output Feedback
5V
VFB
CONDITION
MIN
4.5V≤ VIN ≤24V
1.193
0.2A≤ ILOAD ≤2A
1.180
VIN =12V, ILOAD =2A
76
7V≤ VIN ≤24V
4..80
0.2A≤ ILOAD ≤2A
4.75
TYP
1.23
-5
MAX
1.267
1.280
-5.20
5.25
UNIT
V
V
Efficiency
η
VIN =12V, ILOAD =2A
84
Feedback Bias Current
IFB
VFB =1.3V (Adj version only)
-10
-100
nA
127
150
173
kHz
3
ms
2.4
A
60
kHz
1.15
1.50
V
Oscillator Frequency
FOSC
Soft-Start Time
TSS
Current Limit
ICL
Oscillator Frequency of Short
Circuit Protect
Saturation Voltage
FSCP
VSAT
Rising edge of EN on to ICL
Pear Current, no outside circuit
VFB =0V force driver on
When current limit occurred and
o
VFB
很抱歉,暂时无法提供与“TS2596SCS RLG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+24.21952
- 10+15.48755
- 25+13.95437
- 100+11.79833
- 250+10.36097
- 500+9.33086
- 1000+9.23504
- 国内价格 香港价格
- 1+23.662211+3.07360
- 10+15.1368510+1.96620
- 25+13.6579725+1.77410
- 100+11.48313100+1.49160
- 250+10.09124250+1.31080
- 500+9.13431500+1.18650
- 1000+9.047321000+1.17520
