SST24B-800BW
SST24B-800BW
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    SST24B-800BW
SST24B-800BW 数据手册
Insulated Non-Insulated SST24 Series Technical Data Data Sheet N2167, Rev.- 12 3 12 3 TO-220F SST24 Series 25A TRIACs TO-220C Insulated K(1) Diagram Circuit 2 G(3) 1 3 TO-220B (Non-Ins) TO-220A(Ins) TO-263 TO-263 A(2) Description With high ability to withstand the shock loading of large current, SST24 series triacs provide high dv/dt rate with strong resistance to electromagnetic interface. With high commutation performances, 3 quadrants products especially recommended focus on inductive load. Maximum Ratings: Characteristics Symbol Max. Units Tstg - -40-150 ℃ Tj - -40-125 ℃ Repetitive peak off-state voltage(Tj=25℃) VDRM - 800 V Repetitive peak reverse voltage(Tj=25℃) VRRM - 800 V Non repetitive surge peak Off-state voltage VDSM - VDRM +100 V Non repetitive peak reverse voltage VRSM - VRRM +100 V 25 A 250 A Storage junction temperature range Operating junction temperature range RMS on-state current I(TRMS) Non repetitive surge peak on-state current (full cycle, F=50Hz) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG=2×IGT) Peak gate current Average gate power dissipation Peak gate power ITSM Condition TO-220A(Ins)(TC=75℃) TO-220B(Non-Ins)(TC=90℃) TO-263 (TC=70℃) - I2t - 340 A2 s dI/dt - 50 A/μs IGM - 4 A PG(AV) 1 W PGM - 10 W  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST24 Series Technical Data Data Sheet N2167, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol IGT VGT VGD Test Condition VD =12V RL =33Ω VD =VDRM Tj =125℃ RL =3.3KΩ IG =1.2IGT IH IT =100mA VD=2/3VDRM Gate Open Tj =125℃ BW CW MAX Ⅰ-Ⅱ-Ⅲ MAX 1.3 V Ⅰ-Ⅱ-Ⅲ MIN 0.2 V Ⅱ 50 35 Unit Ⅰ-Ⅱ-Ⅲ Ⅰ-Ⅲ IL dV/dt Value Quadrant mA 80 70 100 80 MAX 75 50 mA MIN 1000 500 V/μs MAX mA Static Characteristics Symbol VTM IDRM IRRM Parameter ITM =35A tp=380μs VD =VDRM VR =VRRM Value(MAX) Unit Tj=25℃ 1.5 V Tj=25℃ 5 μA Tj=125℃ 3 mA Thermal Resistances Symbol Rth(j-c) Condition Junction to case(AC) Value Units TO-220A(Ins) 1.5 ℃/W TO-220B(Non-Ins) 1.1 ℃/W TO-263 2.1 ℃/W  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST24 Series Technical Data Data Sheet N2167, Rev.- Ordering Information S ST 24 A -800 BW SMC Diode Solutions BW: IGT1-3 ≤ 50mA CW: IGT1-3 ≤ 35mA Triacs IT(RMS):25A 800:VDRM/VRRM ≥ 800V A: TO-220A(Ins) B:TO-220B(Non-Ins) E:TO-263 Device SST24A-800CW, SST24A-800BW SST24B-800CW, SST24B-800BW SST24E-800CW, SST24E-800BW Package TO-220A(Ins) TO-220B(Non-Ins) TO-263 Shipping 50pcs/ Tube 50pcs/ Tube 800pcs/ Tape Marking Diagram Where XXXXX is YYWWL SST24A-800BW SST24B-800BW SST24E-800BW YY WW L = Part name = Part name = Part name = Year = Week = Lot Number Mechanical Dimensions TO-220A(Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.55 28.0 1.14 2.65 Typ. 2.54 3.75 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.95 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.258 29.8 1.102 1.70 2.95 0.045 0.104  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typ. 0.1 0.148 45° Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.274 1.173 0.067 0.116 SST24 Series Technical Data Data Sheet N2167, Rev.- Mechanical Dimensions TO-220B(Non-Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 Typ. 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.20 2.54 28.0 3.75 1.14 2.65 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.60 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.244 29.8 1.102 1.70 2.95 0.045 0.104 Typ. 0.1 0.148 45° Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.260 1.173 0.067 0.116 Mechanical Dimensions TO-263 SYMBOL Millimeters Min. Typ. Inches Max. Min. Typ. Max. A 9.90 10.20 0.390 0.402 A1 4.95 5.10 0.195 0.201 B 14.70 15.80 0.579 0.622 C 9.40 9.60 0.370 0.378 C1 4.70 4.80 0.185 D 2.54 D1 7.20 E 1.20 E1 7.60 F 0.75 G 0.189 0.100 1.40 0.047 0.055 0.85 0.029 0.033 1.75 0.069 H 4.40 4.70 0.173 0.185 J 2.30 2.70 0.091 0.106 K 0.38 0.55 0.015 L L1 ΦP 0 2.24 1.00 0.25 2.84 1.50 0 0.088 0.039 M 1.25 1.35 0.049 0.10  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  0.022 0.004 0.010 0.112 0.059 0.053 SST24 Series Technical Data Data Sheet N2167, Rev.- Foot Print TO-263 (dimensions in mm) Ratings and Characteristics Curves FIG.1: Maximum power dissipation versus RMS on-state current P(w) 36 FIG.2: RMS on-state current versus case temperature IT(RMS) (A) 30 α=180° TO-220B(Non-Ins) → 25 27 → 20 18 TO-220A(Ins) 15 10 9 5 0 0 5 IT(RMS) (A) 10 15 20 25 0 0 Tc (℃) 25 50 75  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  100 125 SST24 Series Technical Data Data Sheet N2167, Rev.- FIG.3: Surge peak on-state current versus number of cycles FIG.4: On-state characteristics (maximum values) ITM (A) 200 ITSM (A) 300 t=20ms One cycle 240 100 Tj=125℃ 180 10 120 Tj=25℃ 60 Number of cycles 10 100 0 1 1 0 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST24B-800BW 价格&库存
很抱歉,暂时无法提供与“SST24B-800BW”相匹配的价格&库存,您可以联系我们找货
SST24B-800BW
  • 1+19.577851+2.54566
  • 50+9.4882250+1.23373
  • 100+8.50858100+1.10635
  • 500+6.78848500+0.88269
库存:885
