SST139C-600E
SST139C-600E
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    SST139C-600E
SST139C-600E 数据手册
SST139C-600E SST139C-800E Technical Data Data Sheet N2043, Rev.- SST139 Series 16A TRIACs Circuit Diagram TO-220C Description With SST139 series triacs with low holding and latching current are especially recommended for use on middle and small resistance type power load. Maximum Ratings: Characteristics Symbol Max. Units Tstg - -40-150 ℃ Tj - -40-125 ℃ Repetitive peak off-state voltage(Tj=25℃) VDRM - 600/800 V Repetitive peak reverse voltage(Tj=25℃) VRRM - 600/800 V Non repetitive surge peak Off-state voltage VDSM - VDRM + 100 V Non repetitive peak reverse voltage VRSM - VRRM + 100 V 16 A 140 A A2 s A/μs PGM Ⅰ-Ⅱ-Ⅲ Ⅳ - 98 50 10 2 0.5 W PG(AV) - 5 W Storage junction temperature range Operating junction temperature range RMS on-state current Non repetitive surge peak on-state current (tp=20ms) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG =2×IGT) Peak gate current ITSM I2t dI/dt IGM Average gate power dissipation Peak gate power I(TRMS) Condition TO-220C(TC=100℃) -  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  A SST139C-600E SST139C-800E Technical Data Data Sheet N2043, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol Test Condition Ⅰ-Ⅱ-Ⅲ IGT VD=12V RL=33Ω VD=VDRM Tj=125℃ RL=3.3KΩ IG=1.2IGT IH IT=100mA VD=2/3VDRM Gate Open Tj=125℃ D E F B 5 10 25 50 10 25 70 70 Unit mA ALL MAX 1.3 V ALL MIN 0.2 V Ⅰ- Ⅲ IL dV/dt MAX Ⅳ VGT VGD Value Quadrant 15 30 50 80 20 40 100 120 MAX 10 25 40 60 mA MIN 20 50 100 500 V/μs MAX Ⅱ- Ⅳ mA Static Characteristics Symbol VTM IDRM IRRM Condition Max. Units Value Units 1.6 5 1 ITM=20A tp=380μs,Tj=25℃ VD=VDRM VR=VRRM, Tj=25℃ VD=VDRM VR=VRRM, Tj=125℃ V μA mA Thermal Resistances Rth(j-c) Symbol Condition Junction to case(AC) TO-220AC 1.2 ℃/W Ordering Information S ST 139 C -600 E SMC Diode Solutions Triacs E:IGT1-3 ≤ 10mA IGT4 ≤ 25mA IT(RMS):16A 600:VDRM/VRRM ≥ 600V 800:VDRM/VRRM ≥ 800V C:TO-220C Device Package Shipping SST139C-600E/SST139C-800E TO-220C 50pcs/ Tube  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST139C-600E SST139C-800E Technical Data Data Sheet N2043, Rev.- Marking Diagram Where XXXXX is YYWWL SST139C-600E YY WW L = Part name = Year = Week = Lot Number Mechanical Dimensions TO-220C SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 ϕ 4.40 0.70 0.45 1.23 2.20 8.90 9.90 6.30 28.0 1.14 2.65 Typ. 2.54 3.39 3.6 Inches Max. Min. 4.60 0.90 0.60 1.32 2.60 9.90 10.3 6.90 0.173 0.028 0.018 0.048 0.087 0.350 0.39 0.248 29.8 1.102 1.70 2.95 0.045 0.104 Typ. Max. 0.181 0.035 0.024 0.052 0.102 0.390 0.406 0.272 0.1 1.173 0.133 0.067 0.116 0.142 Ratings and Characteristics Curves FIG.1 Maximum power dissipation versus RMS on-state current FIG.2: RMS on-state current versus case temperature P(w) 24 IT(RMS) (A) 24 20 20 16 16 12 12 8 8 4 4 0 0 4 IT(RMS) (A) 8 12 16 20 0 α=180° TO-220C Tc (℃) 0 25 50 75  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  100 125 SST139C-600E SST139C-800E Technical Data Data Sheet N2043, Rev.- FIG.3: Surge peak on-state current versus number of cycles 140 FIG.4: On-state characteristics (maximum values) ITSM (A) 100 ITM (A) t=20ms One cycle 120 Tj=Tjmax 100 80 10 60 40 Tj=25℃ 20 0 1 10 Number of cycles 100 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST139C-600E 价格&库存
很抱歉,暂时无法提供与“SST139C-600E”相匹配的价格&库存,您可以联系我们找货
