UGA8120HC0G
UGA8120HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 8A TO220AC
UGA8120HC0G 数据手册
UGA8120 Taiwan Semiconductor 8A, 1200V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High junction temperature up to 175°C Negligible leakage sustain the high operation temperature Very low stored charge and its soft recovery minimize ringing and electrical noise to reduce power loss in associated MOSFET or IGBT High capability for high di/dt operation. High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 1200 V IFSM 80 A TJ MAX 175 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.85g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UGA8120 UNIT UGA8120 Repetitive peak reverse voltage VRRM 1200 V Reverse voltage, total rms value VR(RMS) 840 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 8 A IFSM 80 A TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: D2103 UGA8120 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2.3 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 8A, TJ = 25°C (2) Reverse recovery time Reverse recovery charges TJ = 25°C TJ = 125°C IF = 0.5A, IR = 1.0A Irr = 0.25A IF = 1A, dIF/dt = -100A/µs, VR = 30V, TJ = 25°C IF = 8A, dIF/dt = -200A/µs, VR = 400V, TJ = 25°C IF = 8A, dIF/dt = -200A/µs, VR = 400V, TJ = 125°C SYMBOL TYP MAX UNIT VF - 2.8 V 1 5 µA 5 100 µA trr 35 50 ns trr 50 70 ns Qrr 165 - nC IRM 11 16 A IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING UGA8120 TO-220AC 50 / Tube UGA8120H TO-220AC 50 / Tube Notes: 1. “H” means AEC-Q101 qualified 2 Version: D2103 UGA8120 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 8 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 10 6 4 10 2 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 1 175 0.1 1 CASE TEMPERATURE (°C) 0.1 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 1010 1 UF1DLW TJ=125°C TJ=125°C TJ=25°C 10.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=25°C 0.01 Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.5 1 0.6 0.7 1.6 0.8 0.20.30.4 0.4 0.6 0.8 1.2 1.4 1.8 0.9 2 2.2 12.4 1.1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 90 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 10 0.01 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 80 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2103 1.2 UGA8120 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: D2103 UGA8120 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2103
UGA8120HC0G 价格&库存
很抱歉,暂时无法提供与“UGA8120HC0G”相匹配的价格&库存,您可以联系我们找货
