SST41Z-600/800B
SST41Z-600/800BW
SST41Z-1200/1600BW
Technical Data
Data Sheet N2034, Rev.-
SST41 Series
40A TRIACs
Circuit Diagram
TO-3P Insulated
Description
With high ability to withstand the shock loading of large current, SST41 series triacs provide high dv/dt rate with strong
resistance to electromagnetic interface. With high commutation performances, 3 quadrants products especially
recommended for use on inductive load. From all three terminals to external heatsink, SST41Z provides a rated insulation
voltage of 2500 VRMS.
Maximum Ratings:
Characteristics
Symbol
Storage junction temperature range
TJ
Operating junction temperature range
Repetitive peak off-state voltage
Repetitive peak reverse voltage
Condition
Max.
Units
-40 to +125
Tstg
-40 to +150
C
VDRM
600/800/1200/1600
V
VRRM
600/800/1200/1600
V
Non repetitive peak off-state voltage
VDSM
VDRM +100
V
Non repetitive peak reverse voltage
VRSM
VRRM +100
V
RMS on-state current
I(TRMS)
40
A
400
A
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current
(IG =2×IGT)
Peak gate current
Average gate power dissipation
Peak gate power
ITSM
TO-3P(Ins)(TC=80℃)
C
2
It
880
A2 s
dI/dt
50
A/us
IGM
4
A
PGM
1
W
PG(AV)
10
W
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SST41Z-600/800B
SST41Z-600/800BW
SST41Z-1200/1600BW
Technical Data
Electrical Characteristics(Tj=25℃ unless otherwise specified)
3 Quadrants
Symbol
IGT
VGT
VGD
Test Condition
Quadrant
VD =12V RL =33Ω
VD =VDRM Tj =125℃ RL=3.3KΩ
Value
Unit
Ⅰ-Ⅱ-Ⅲ
MAX
50
mA
Ⅰ-Ⅱ-Ⅲ
MAX
1.3
V
Ⅰ-Ⅱ-Ⅲ
MIN
0.2
V
Ⅰ-Ⅲ
80
IL
IG =1.2IGT
IH
IT =100mA
MAX
60
mA
VD=2/3VDRM Gate Open Tj =125℃
MIN
1500
V/μs
Value
Unit
dV/dt
Ⅱ
MAX
100
mA
4 Quadrants
Symbol
IGT
Test Condition
Quadrant
Ⅰ-Ⅱ-Ⅲ
VD =12V RL=33Ω
Ⅳ
VGT
VGD
VD =VDRM Tj =125℃, RL =3.3KΩ
50
MAX
70
mA
ALL
MAX
1.3
V
ALL
MIN
0.2
V
Ⅰ-Ⅲ-Ⅳ
90
IL
IG =1.2IGT
IH
IT =100mA
MAX
80
mA
VD=2/3VDRM Gate Open Tj=125℃
MIN
1000
V/μs
dV/dt
Ⅱ
MAX
100
mA
Static Characteristics
Symbol
VTM
IDRM
IRRM
Condition
IT=60A tp=380μs,Tj=25℃
VD=VDRM VR=VRRM, Tj=25℃
VD=VDRM VR=VRRM, Tj=125℃
Max.
Units
1.5
10
5
V
uA
mA
Value
Units
1.1
℃/W
Thermal Resistances
Symbol
Rth(j-c)
Condition
Junction to case(AC)
TO-3P(Ins)
SST41Z-600/800B
SST41Z-600/800BW
SST41Z-1200/1600BW
Technical Data
Ordering Information
S ST 41 Z -600 BW
BW:IGT1-3 ≤ 50mA
B:IGT1-3 ≤ 50mA IGT4 ≤ 70mA
SMC Diode Solutions
Triacs
600:VDRM/VRRM ≥ 600V
800:VDRM/VRRM ≥ 800V
1200:VDRM/VRRM ≥ 1200V
1600:VDRM/VRRM ≥ 1600V
IT(RMS):40A
Z:TO-3P(Ins)
Device
SST41Z-600B/SST41Z-800B
SST41Z-600BW/SST41Z-800BW
SST41Z-1200BW/SST41Z-1600BW
Package
Shipping
TO-3P
30pcs/ Tube
Marking Diagram
Where XXXXX is YYWWL
SST41Z-600B = Part name
YY
= Year
WW
= Week
L
= Lot Number
Mechanical Dimensions TO-3P
SYMBOL
Millimeters
Min.
Typ.
Inches
Max.
Min.
Typ.
Max.
A
4.40
4.60
0.173
0.181
B
1.45
1.55
0.057
0.061
C
14.35
15.60
0.565
0.614
D
0.50
0.70
0.020
0.028
E
2.70
2.90
0.106
0.114
F
15.80
16.50
0.622
0.650
G
20.40
21.10
0.803
0.831
H
15.10
15.50
0.594
0.610
J
K
L
P
R
5.40
1.10
1.35
2.80
5.65
1.40
1.50
3.00
0.213
0.043
0.053
0.110
0.222
0.055
0.059
0.118
4.35
0.171
SST41Z-600/800B
SST41Z-600/800BW
SST41Z-1200/1600BW
Technical Data
Ratings and Characteristics Curves
FIG.1 Maximum power dissipation versus RMS
on-state current
FIG.2: RMS on-state current versus case
temperature
P(w)
60
IT(RMS) (A)
60
50
50
40
40
30
30
10
IT(RMS) (A)
10
40
50
FIG.3: Surge peak on-state current versus
number of cycles
500
α=180°
TO-3P(Ins)
Tc (℃)
50
75
100
125
FIG.4: On-state characteristics (maximum
values)
ITM (A)
400
ITSM (A)
t=20ms
One cycle
400
Tj=Tjmax
100
300
200
10
100
Tj=25℃
Number of cycles
10
100
1000
FIG.5: Non-repetitive surge peak on-state current
for a sinusoidal pulse with width tp
很抱歉,暂时无法提供与“SST41Z-600BW”相匹配的价格&库存,您可以联系我们找货
