MUR860HC0G
MUR860HC0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE GEN PURP 600V 8A TO220AC
MUR860HC0G 数据手册
MUR820 – MUR860 Taiwan Semiconductor 8A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 200 - 600 V IFSM 100 A TJ MAX 175 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MUR820 MUR840 MUR860 MUR820 MUR840 MUR860 UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 8 A IFSM 100 A TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: K2103 MUR820 – MUR860 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance Junction-to-case thermal resistance MUR820 MUR840 MUR860 SYMBOL TYP UNIT RӨJC 3 °C/W RӨJC 2 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MUR820 Forward voltage (1) MUR840 IF = 8A, TJ = 25°C VF MUR860 Reverse current @ rated VR TJ = 25°C (2) Reverse recovery time IR TJ = 100°C MUR820 MUR840 MUR860 IF = 0.5A, IR = 1.0A Irr = 0.25A trr TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 5 µA - 250 µA - 25 ns - 50 ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MUR8x TO-220AC 50 / Tube MUR8xH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 200V(MUR820) to 600V(MUR860) 2. “H” means AEC-Q101 qualified 2 Version: K2103 MUR820 – MUR860 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 8 CAPACITANCE (pF) 6 4 100 10 2 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 175 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=150°C 10 TJ=100°C 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW MUR840 1 TJ=125°C MUR820 TJ=25°C 0.1 1 MUR860 0.01 0.1 0.001 0.2 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.6 0.8 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.0 1.2 1.4 1.6 1.8 0.6 0.7 0.8 0.9 2.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 120 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 1000 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 10 (A) AVERAGE FORWARD CURRENT (A) 10 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 MUR820 – MUR860 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2103 MUR820 – MUR860 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 MUR820 – MUR860 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
MUR860HC0G 价格&库存
很抱歉,暂时无法提供与“MUR860HC0G”相匹配的价格&库存,您可以联系我们找货
