ESH2B R5G
ESH2B R5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE GEN PURP 100V 2A DO214AA
ESH2B R5G 数据手册
ESH2B – ESH2D Taiwan Semiconductor 2A, 100V - 200V Ultra Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Ultra Fast recovery time for high efficiency Moisture sensitivity level: level 1 per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 2 A VRRM 100 - 200 V IFSM 60 A TJ MAX 175 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ESH2B ESH2C ESH2D ESH2B ESH2C ESH2D UNIT Repetitive peak reverse voltage VRRM 100 150 200 V Reverse voltage, total rms value VR(RMS) 70 105 140 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 60 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: J2102 ESH2B – ESH2D Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 20 °C/W Junction-to-ambient thermal resistance RӨJA 75 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 2A,TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A SYMBOL TYP MAX UNIT VF - 0.9 V - 2 µA - 50 µA CJ 25 - pF trr - 20 ns IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING ESH2x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 100V(ESH2B) to 200V(ESH2D) 2 Version: J2102 ESH2B – ESH2D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 60 50 CAPACITANCE (pF) 2 1 40 30 20 10 0 f=1.0MHz Vsig=50mVp-p 0 0 25 50 75 100 125 LEAD TEMPERATURE 150 175 0.1 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) TJ=125°C 1 TJ=25°C 0.1 30 40 50 60 70 100 Fig.4 Typical Forward Characteristics 10 20 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 1 (oC) 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 1 10 UF1DLW TJ=125°C TJ=25°C 0.1 (A) AVERAGE FORWARD CURRENT (A) 3 1 0.01 0.001 0.1 0.3 0.4 0.4 0.6 0.5 0.8 0.6 0.7 1 Pulse width Pulse width=300μs 1% duty cycle 0.8 0.9 1 1.1 1.2 1.4 1.6 FORWARD VOLTAGE (V) 3 Version: J2102 1.8 1.2 ESH2B – ESH2D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 70 60 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: J2102 ESH2B – ESH2D Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: J2102 ESH2B – ESH2D Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2102
ESH2B R5G 价格&库存
很抱歉,暂时无法提供与“ESH2B R5G”相匹配的价格&库存,您可以联系我们找货
