ES2LD – ES2LJ
Taiwan Semiconductor
2A, 200V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Super fast recovery time for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
200 - 600
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
● High frequency rectification
● Freewheeling application
● Switching mode converters and inverters in computer
and telecommunication.
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.110g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ES2LD
ES2LG
ES2LJ
ES2LD
ES2LG
ES2LJ
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VRMS
140
280
420
V
Forward current
Surge peak forward current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: C2102
ES2LD – ES2LJ
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
35
°C/W
Junction-to-ambient thermal resistance
RӨJA
80
°C/W
Junction-to-case thermal resistance
RӨJC
25
°C/W
Thermal Performance Note: Units mounted on PCB (16mm x 16mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
ES2LD
Forward voltage
(1)
ES2LG
IF = 2A, TJ = 25°C
VF
ES2LJ
Reverse current @ rated VR
TJ = 25°C
(2)
IR
TJ = 125°C
ES2LD
Junction capacitance
ES2LG
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
trr
ES2LJ
Reverse recovery time
TYP
MAX
UNIT
0.94
V
1.30
V
1.70
V
10
µA
350
µA
25
pF
pF
35
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ES2Lx
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 200V(ES2LD) to 600V(ES2LJ)
2
Version: C2102
ES2LD – ES2LJ
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
60
50
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
3
2
1
40
ES2LD
30
ES2LG-2LJ
10
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
ES2LD
TJ=125°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
10
10
ES2LD
TJ=125°C
TJ=125°C
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
TJ=25°C
0.1
TJ=25°C
0.01
0.001
0.3
0.1
0.4
100
UF1DLW
1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
10
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
0.4
0.5
0.5
0.6
0.6
0.7
Pulse width
Pulse width 300μs
1% duty cycle
0.7
0.8
0.9
1
1.1
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
3
Version: C2102
1.2
ES2LD – ES2LJ
ES2LG
TJ=125°C
1
0.1
TJ=25°C
0.01
40
50
60
70
80
90
10
10
ES2LG
UF1DLW
1
TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
(A)
10
10
TJ=25°C
0.01
Pulse width
Pulse width 300μs
1% duty cycle
0.7
0.8
0.9
1
1.1
0.001
0.3
0.1
100
0.6
0.4
0.7
0.5
0.8
0.6
0.9
1
1.1
1.2
1.3
FORWARD VOLTAGE (V)
Fig.7 Typical Reverse Characteristics
Fig.8 Typical Forward Characteristics
10
10
ES2LJ
TJ=125°C
1
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
10
1.4
ES2LJ
UF1DLW
1
TJ=125°C
TJ=125°C
0.1
1
TJ=25°C
TJ=25°C
0.01
Pulse width
0.001
0.3
0.4
0.5
0.6
Pulse width 300μs
duty cycle
0.7 1%0.8
0.9
1
1.1
0.1
100
0.5
0.7
0.9
1.1
1.3
1.5
1.7
FORWARD VOLTAGE (V)
4
1.2
(A)
Fig.6 Typical Forward Characteristics
Fig.5 Typical Reverse Characteristics
Version: C2102
1.2
ES2LD – ES2LJ
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: C2102
ES2LD – ES2LJ
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2102
很抱歉,暂时无法提供与“ES2LDHM4G”相匹配的价格&库存,您可以联系我们找货
