HS2A – HS2M
Taiwan Semiconductor
2A, 50V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Glass passivated chip junction
Fast switching for high efficiency
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1000
V
IFSM
50
A
TJ MAX
150
°C
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
Package
DO-214AA (SMB)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL HS2A HS2B HS2D HS2F HS2G HS2J HS2K HS2M UNIT
Marking code on the device
Repetitive peak reverse voltage
VRRM
50
100
200
300
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
210
280
420
560
700
V
Forward current
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: L2102
HS2A – HS2M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
80
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
5
µA
150
µA
50
pF
30
pF
50
ns
75
ns
HS2A
HS2B
HS2D
Forward voltage
HS2F
(1)
HS2G
IF = 2A, TJ = 25°C
VF
HS2J
HS2K
HS2M
Reverse current @ rated VR
TJ = 25°C
(2)
IR
TJ = 125°C
HS2A
HS2B
HS2D
Junction capacitance
HS2F
HS2G
1MHz, VR = 4.0V
CJ
HS2J
HS2K
HS2M
HS2A
HS2B
HS2D
Reverse recovery time
IF = 0.5A, IR = 1.0A,
HS2F
HS2G Irr = 0.25A
trr
HS2J
HS2K
HS2M
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS2x
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(HS2A) to 1000V(HS2M)
2
Version: L2102
HS2A – HS2M
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
175
f=1.0MHz
Vsig=50mVp-p
150
CAPACITANCE (pF)
2
1
125
100
HS2A-HS2G
75
50
25
HS2J-HS2M
50
75
100
125
150
0.1
1
10
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
1000
100
TJ=100°C
10
TJ=25°C
0.1
60
1000
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
100
80
100
10
10
TJ=125°C
1
0.1
TJ=25°C
HS2G
0.01
Pulse width
HS2J-HS2M
0.001
0.3
0.1
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
HS2A-HS2D
1
(A)
AVERAGE FORWARD CURRENT (A)
3
0.4
0.5
0.8
0.6
0.7
1
0.8
0.9
1.2
1
1.1
1.4
FORWARD VOLTAGE (V)
3
Version: L2102
1.2
HS2A – HS2M
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: L2102
HS2A – HS2M
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2102
HS2A – HS2M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2102
很抱歉,暂时无法提供与“HS2G M4G”相匹配的价格&库存,您可以联系我们找货
