FT93C56A-ISR-T
FT93C56A-ISR-T
    FMD(辉芒微)
    SOICN-8_4.9X3.9MM
    IC EEPROM 2KBIT SPI 2MHZ 8SOP
FT93C56A-ISR-T 数据手册
Fremont Micro Devices USA Inc. Product Change Notification Product Change Notification Number: PCN0401005 Title: FT93C46A/56A/66A Process Improved Product Identification: All Packages and Voltages of the chips, Industrial Temperature. □ Manufacturing Location Reason for Change: ■ Processing □ Quality/Reliability □ Logistics □ Material Change Description: FMD has optimized the layout of the devices. The new devices are compatible with the current FT93CxxA devices. New devices are available in 1.8 voltage and RoHS/Green compliance. Please refer to the Datasheet for the details. Identification Method to Distinguish Change: There will be a NEW ordering code created for this device. The ordering code will be “FT93CXX-UXX” for industrial temperature, SOP 8L and RoHS compliance, i.e. “U” will replace the “C” and “I” in the original ordering code. Qualification Data: Samples: ■ available ■ available □ will be available □ not applicable □will be available □ not applicable Quantifiable Impact on Quality & Reliability: Layout change has been performed to improve productivity. The new devices utilize the 0.25u process technology and are a form, fit and functional equivalent of the current devices, which meet all data-book specifications. Implementation Date: Last Time Buy Date: Last Ship Date: December 01, 2012 July 01, 2013 August 01, 2013 FMD will deem this change accepted unless specific conditions of acceptance are provided in writing within 30 days from the date of this notice. Information provided herein is in connection with FMD products. No license, express or implied, by estoppels or otherwise, to any intellectual property rights is granted by this document. Except as provided in FMD's Terms and Conditions of Sale for such products, FMD assumes no liability whatsoever, and FMD disclaims any express or implied warranty, including liability or warranties relating to fitness for a particular purpose, merchantability, or non-infringement of any patent, copyright or other intellectual property right. FMD products are not intended for use in a product or system intended to support or sustain life which, if it fails, can be reasonably expected to result in significant personal injury. FMD may make changes to specifications and product descriptions at any time, without notice. Flat 16, 16/F, Block B, 34-36 Au Pui Wan Street, Phone: 510-668-1321 Fax: 510-226-9918 www.fremontmicrousa.com Shatin, N.T., Hong Kong
FT93C56A-ISR-T 价格&库存
很抱歉,暂时无法提供与“FT93C56A-ISR-T”相匹配的价格&库存,您可以联系我们找货
