FT24C02A-UTG-T
FT24C02A-UTG-T
    FMD(辉芒微)
    TSSOP-8
FT24C02A-UTG-T 数据手册
Fremont Micro Devices FT24C02A Two-Wire Serial EEPROM 2K (8-bit wide) FEATURES                Low voltage and low power operations:  FT24C02A: VCC = 1.8V to 5.5V, Industrial temperature range (-40℃ to 85℃). Two Versions of FT24C02A:  FT24C02A-5xx: Low cost with 5 valid pins. Suitable for most application except those with more than one EEPROM on the same IIC Bus. Details in the “Device Addressing” section.  FT24C02A-Uxx: 8 valid pins suitable for all application. Maximum Standby current < 1µA (typically 0.02µA and 0.06µA @ 1.8V and 5.5V respectively). 16 bytes page write mode. Partial page write operation allowed. Internally organized: 256 × 8 (2K). Standard 2-wire bi-directional serial interface. Schmitt trigger, filtered inputs for noise protection. Self-timed programming cycle (5ms maximum). 1 MHz (5V), 400 kHz (1.8V, 2.5V, 2.7V) Compatibility. Automatic erase before write operation. Write protect pin for hardware data protection. High reliability: typically 1, 000,000 cycles endurance. 100 years data retention. Standard 8-pin PDIP/SOIC/TSSOP/DFN and 5-pin SOT-23/TSOT-23 Pb-free packages. DESCRIPTION The FT24C02A is 2048 bits of serial Electrical Erasable and Programmable Read Only Memory, commonly known as EEPROM. They are organized as 256 words of 8 bits (1 byte) each. The devices are fabricated with proprietary advanced CMOS process for low power and low voltage applications. These devices are available in standard 8-lead PDIP, 8-lead JEDEC SOIC, 8-lead TSSOP, 8-lead DFN and 5-lead SOT-23/TSOT-23 packages. A standard 2-wire serial interface is used to address all read and write functions. Our extended VCC range (1.8V to 5.5V) devices enables wide spectrum of applications. © 2009 Fremont Micro Devices Inc. DS3011B-page1 FT24C02A PIN CONFIGURATION Pin Name A2, A1, A0 SDA SCL WP VCC GND NC Pin Function Device Address Inputs Serial Data Input / Open Drain Output Serial Clock Input Write Protect Power Supply Ground No-Connect Table 1 All these packaging types come in conventional or Pb-free certified. FT24C02A A0 A1 A2 GND 1 8 2 7 3 6 4 5 8L DIP 8L SOP 8L TSSOP 8L DFN 8L MSOP VCC WP SCL SDA FT24C02A SCL GND SDA 1 5 WP 4 VCC 2 3 SOT-23-5 TSOT-23-5 Figure 1: Package types DS3011B-page2 © 2009 Fremont Micro Devices Inc. FT24C02A ABSOLUTE MAXIMUM RATINGS Industrial operating temperature: -40℃ to 85℃ Storage temperature: -50℃ to 125℃ Input voltage on any pin relative to ground: -0.3V to VCC + 0.3V Maximum voltage: 8V ESD protection on all pins: >2000V * Stresses exceed those listed under “Absolute Maximum Rating” may cause permanent damage to the device. Functional operation of the device at conditions beyond those listed in the specification is not guaranteed. Prolonged exposure to extreme conditions may affect device reliability or functionality. Figure 2: Block Diagram © 2009 Fremont Micro Devices Inc. DS3011B-page3 FT24C02A PIN DESCRIPTIONS (A) SERIAL CLOCK (SCL) The rising edge of this SCL input is to latch data into the EEPROM device while the falling edge of this clock is to clock data out of the EEPROM device. (B) SERIAL DATA LINE (SDA) SDA data line is a bi-directional signal for the serial devices. It is an open drain output signal and can be wired-OR with other open-drain output devices. (C) WRITE PROTECT (WP) The FT24C02A devices have a WP pin to protect the whole EEPROM array from programming. Programming operations are allowed if WP pin is left un-connected or input to VIL. Conversely all programming functions are disabled if WP pin is connected to VIH or VCC. Read operations is not affected by the WP pin’s input level. MEMORY ORGANIZATION The FT24C02A devices have 16 pages. Since each page has 16 bytes, random word addressing to FT24C02A will require 8 bits data word addresses. DEVICE OPERATION (A) SERIAL CLOCK AND DATA TRANSITIONS The SDA pin is typically pulled to high by an external resistor. Data is allowed to change only when Serial clock SCL is at VIL. Any SDA signal transition may interpret as either a START or STOP condition as described below. (B) START CONDITION With SCL ≥ VIH, a SDA transition from high to low is interpreted as a START condition. All valid commands must begin with a START condition. (C) STOP CONDITION With SCL ≥ VIH, a SDA transition from low to high is interpreted as a STOP condition. All valid read or write commands end with a STOP condition. The device goes into the STANDBY mode if it is after a read command. A STOP condition after page or byte write command will trigger the chip into the STANDBY mode after the self-timed internal programming finish. (D) ACKNOWLEDGE The 2-wire protocol transmits address and data to and from the EEPROM in 8 bit words. The EEPROM acknowledges the data or address by outputting a "0" after receiving each word. The ACKNOWLEDGE signal occurs on the 9th serial clock after each word. DS3011B-page4 © 2009 Fremont Micro Devices Inc. FT24C02A (E) STANDBY MODE The EEPROM goes into low power STANDBY mode after a fresh power up, after receiving a STOP bit in read mode, or after completing a self-time internal programming operation. SCL SDA START Condition Data Valid Data Transition STOP Condition Figure 3: Timing diagram for START and STOP conditions START Condition SCL Data in ACK Data out Figure 4: Timing diagram for output ACKNOWLEDGE © 2009 Fremont Micro Devices Inc. DS3011B-page5 FT24C02A DEVICE ADDRESSING The 2-wire serial bus protocol mandates an 8 bits device address word after a START bit condition to invoke valid read or write command. The first four most significant bits of the device address must be 1010, which is common to all serial EEPROM devices. The next three bits are device address bits. These three device address bits (5th, 6th and 7th) are to match with the external chip select/address pin states. If a match is made, the EEPROM device outputs an ACKNOWLEDGE signal after the 8th read/write bit, otherwise the chip will go into STANDBY mode. However, matching are not be done for “-5xx” version chips. This three device address bits are not cared and could be coded from 000 (b) to 111 (b). Only one FT24C02A device can be used on the on 2-wire bus. If a match is made, the EEPROM device outputs an ACKNOWLEDGE signal after the 8th read/write bit, otherwise the chip will go into STANDBY mode. The last or 8th bit is a read/write command bit. If the 8th bit is at VIH then the chip goes into read mode. If a “0” is detected, the device enters programming mode. WRITE OPERATIONS (A) BYTE WRITE A byte write operation starts when a micro-controller sends a START bit condition, follows by a proper EEPROM device address and then a write command. If the device address bits match the chip select address, the EEPROM device will acknowledge at the 9th clock cycle. The micro-controller will then send the rest of the lower 8 bits word address. At the 18th cycle, the EEPROM will acknowledge the 8-bit address word. The micro-controller will then transmit the 8 bit data. Following an ACKNOWLDEGE signal from the EEPROM at the 27th clock cycle, the micro-controller will issue a STOP bit. After receiving the STOP bit, the EEPROM will go into a self-timed programming mode during which all external inputs will be disabled. After a programming time of TWC, the byte programming will finish and the EEPROM device will return to the STANDBY mode. (B) PAGE WRITE A page write is similar to a byte write with the exception that one to sixteen bytes can be programmed along the same page or memory row. All FT24C02A are organized to have 16 bytes per memory row or page. With the same write command as the byte write, the micro-controller does not issue a STOP bit after sending the 1st byte data and receiving the ACKNOWLEDGE signal from the EEPROM on the 27th clock cycle. Instead it sends out a second 8-bit data word, with the EEPROM acknowledging at the 36th cycle. This data sending and EEPROM acknowledging cycle repeats until the micro-controller sends a STOP bit after the n × 9th clock cycle. After which the EEPROM device will go into a selftimed partial or full page programming mode. After the page programming completes after a time of TWC, the devices will return to the STANDBY mode. The least significant 4 bits of the word address (column address) increments internally by one after receiving each data word. The rest of the word address bits (row address) do not change internally, but pointing to a specific memory row or page to be programmed. The first page write data word can be of any column address. Up to 16 data words can be loaded into a page. If more then 16 data DS3011B-page6 © 2009 Fremont Micro Devices Inc. FT24C02A words are loaded, the 17th data word will be loaded to the 1st data word column address. The 18th data word will be loaded to the 2nd data word column address and so on. In other word, data word address (column address) will “roll” over the previously loaded data. (C) ACKNOWLEDGE POLLING ACKNOWLEDGE polling may be used to poll the programming status during a self-timed internal programming. By issuing a valid read or write address command, the EEPROM will not acknowledge at the 9th clock cycle if the device is still in the self-timed programming mode. However, if the programming completes and the chip has returned to the STANDBY mode, the device will return a valid ACKNOWLEDGE signal at the 9th clock cycle. READ OPERATIONS The read command is similar to the write command except the 8th read/write bit in address word is set to “1”. The three read operation modes are described as follows: (A) CURRENT ADDRESS READ The EEPROM internal address word counter maintains the last read or write address plus one if the power supply to the device has not been cut off. To initiate a current address read operation, the micro-controller issues a START bit and a valid device address word with the read/write bit (8th) set to “1”. The EEPROM will response with an ACKNOWLEDGE signal on the 9th serial clock cycle. An 8bit data word will then be serially clocked out. The internal address word counter will then automatically increase by one. For current address read the micro-controller will not issue an ACKNOWLEDGE signal on the 18th clock cycle. The micro-controller issues a valid STOP bit after the 18th clock cycle to terminate the read operation. The device then returns to STANDBY mode. (B) SEQUENTIAL READ The sequential read is very similar to current address read. The micro-controller issues a START bit and a valid device address word with read/write bit (8th) set to “1”. The EEPROM will response with an ACKNOWLEDGE signal on the 9th serial clock cycle. An 8-bit data word will then be serially clocked out. Meanwhile the internally address word counter will then automatically increase by one. Unlike current address read, the micro-controller sends an ACKNOWLEDGE signal on the 18th clock cycle signaling the EEPROM device that it wants another byte of data. Upon receiving the ACKNOWLEDGE signal, the EEPROM will serially clocked out an 8-bit data word based on the incremented internal address counter. If the micro-controller needs another data, it sends out an ACKNOWLEDGE signal on the 27th clock cycle. Another 8-bit data word will then be serially clocked out. This sequential read continues as long as the micro-controller sends an ACKNOWLEDGE signal after receiving a new data word. When the internal address counter reaches its maximum valid address, it rolls over to the beginning of the memory array address. Similar to current address read, the micro-controller can terminate the sequential read by not acknowledging the last data word received, but sending a STOP bit afterwards instead. © 2009 Fremont Micro Devices Inc. DS3011B-page7 FT24C02A (C) RANDOM READ Random read is a two-steps process. The first step is to initialize the internal address counter with a target read address using a “dummy write” instruction. The second step is a current address read. To initialize the internal address counter with a target read address, the micro-controller issues a START bit first, follows by a valid device address with the read/write bit (8th) set to “0”. The EEPROM will then acknowledge. The micro-controller will then send the address word. Again the EEPROM will acknowledge. Instead of sending a valid written data to the EEPROM, the micro-controller performs a current address read instruction to read the data. Note that once a START bit is issued, the EEPROM will reset the internal programming process and continue to execute the new instruction - which is to read the current address. S T A R T W R I T E DEVICE ADDRESS WORD ADDRESS S T O P DATA *** SDA LINE LA SC BK LRAM S / CS B WK B M S B A C K Figure 5: Byte Write S T A R T W R I T E DEVICE ADDRESS WORD ADDRESS(N) DATA(N) ... *** SDA LINE M S B S T O P LRAM S / CS B WK B L A SC B K A C K DATA(N+X) A C K Figure 6: Page Write S T A R T R E A D DEVICE ADDRESS S T O P DATA *** SDA LINE M S B L RA S / C B WK N O A C K Figure 7: Current Address Read DS3011B-page8 © 2009 Fremont Micro Devices Inc. FT24C02A R E A D DEVICE ADDRESS DATA (N) DATA (N+1) DATA (N+2) S T O P DATA (N+3) *** SDA LINE RA / C WK N O A C K A C K A C K A C K Figure 8: Sequential Read S T A R T W R I T E DEVICE ADDRESS S T A R T WORD ADDRESS(N) DEVICE ADDRESS *** SDA LINE M S B R E A D S T O P DATA (N) *** L RA M S / C S B WK B LA SC BK M S B L RA S / C B WK N O A C K Figure 9: Random Read Notes: 1) * = Don’t Care bits Figure 10: SCL and SDA Bus Timing © 2009 Fremont Micro Devices Inc. DS3011B-page9 FT24C02A AC CHARACTERISTICS Symbol 1.8 V Parameter Min fSCL tLOW tHIGH tI tAA Clock frequency, SCL tHD.STA tSU.STA tHD.DAT tSU.DAT tR tF tSU.STO tDH 1.3 Clock pulse width high 0.6 0.3 START set-up time Endurance Unit Max 1000 kHz 0.4 µs 0.4 0.9 0.2 120 µs ns 0.55 µs 1.3 0.5 µs 0.6 0.25 µs 0.6 0.25 µs 0 0 µs 100 100 ns Input rise time(1) 0.3 0.3 µs Input fall time(1) 300 100 ns STOP set-up time 0.6 0.25 µs Date out hold time 50 50 ns Write cycle time (1) Min 180 Clock low to data out valid Time the bus must be free before a new transmission can start(1) START hold time Data in set-up time WR Notes: Clock pulse width low Data in hold time Max 400 Noise suppression time(1) tBUF 2.5-5.0 V o 25 C, Page Mode, 3.3V 5 5 1,000,000 ms Write Cycles 1. This Parameter is expected by characterization but is not fully screened by test. 2. AC Measurement conditions: RL (Connects to Vcc): 1.3KΩ Input Pulse Voltages: 0.3Vcc to 0.7Vcc Input and output timing reference Voltages: 0.5Vcc DS3011B-page10 © 2009 Fremont Micro Devices Inc. FT24C02A DC CHARACTERISTICS Symbol Parameter Test Conditions Min Typical Max Unit s 5.5 V VCC1 Power supply VCC ICC Supply read current VCC @ 5.0V SCL = 400 kHz 0.5 1.0 mA ICC Supply write current VCC @ 5.0V SCL = 400 kHz 2.0 3.0 mA ISB1 Supply current VCC @ 1.8V, VIN = VCC or VSS 1.0 µA ISB2 Supply current VCC @ 2.5V, VIN = VCC or VSS 1.0 µA ISB3 Supply current VCC @ 5.0V, VIN = VCC or VSS 1.0 µA IIL Input leakage current VIN = VCC or VSS 3.0 µA VIN = VCC or VSS 3.0 µA 1.8 0.07 VIL Output leakage current Input low level VIH Input high level VOL1 Output low level VCC @ 1.8V, IOL = 0.15 mA 0.2 V VOL2 Output low level VCC @ 3.0V, IOL = 2.1 mA 0.4 V ILO -0.6 VCC × 0.3 V VCC × 0.7 VCC + 0.5 V ORDER CODE: FT24C02A – XXX - X Packaging B: Tube T: Tape and Reel Temperature Range U / 5: -40 to 85? Package D: DIP S: SOP M: MSOP T: TSSOP L: SOT23-5 P: TSOT23-5 N: DFN © 2009 Fremont Micro Devices Inc. Option G: Green Package RoHS Compliant R: RoHS Compliant DS3011B-page11 FT24C02A ORDER INFORMATION Order code FT24C02A-5DG-B FT24C02A-5DR-B FT24C02A-UDG-B FT24C02A-UDR-B FT24C02A-5SG-B FT24C02A-5SG-T FT24C02A-5SR-B FT24C02A-5SR-T FT24C02A-USG-B FT24C02A-USG-T FT24C02A-USR-B FT24C02A-USR-T FT24C02A-UTG-B FT24C02A-UTG-T FT24C02A-UTR-B FT24C02A-UTR-T FT24C02A-5LG-T FT24C02A-5LR-T FT24C02A-5PG-T FT24C02A-5PR-T FT24C02A-UNG-T FT24C02A-UNR-T DS3011B-page12 Vcc Temperature Range Package Option DIP8 SOP8 1.8v-5.5v -40-850C TSSOP8 SOT23-5 TSOT23-5 DFN8 Green Package RoHS Green Package RoHS Green Package Green Package RoHS RoHS Green Package Green Package RoHS RoHS Green Package Green Package RoHS RoHS Green Package RoHS Green Package RoHS Green Package RoHS Packaging Tube Tube Tube Tube Tube T/R Tube T/R Tube T/R Tube T/R Tube T/R Tube T/R T/R T/R T/R T/R T/R T/R © 2009 Fremont Micro Devices Inc. FT24C02A DIP8 PACKAGE OUTLINE DIMENSIONS Symbol A A1 A2 B B1 C D E E1 e L E2 Dimensions In Millimeters Dimensions In Inches Min Max Min Max 3.710 0.510 3.200 0.380 4.310 0.146 0.020 0.126 0.015 0.170 3.600 0.570 1.524(BSC) 0.204 0.360 9.000 9.400 6.200 6.600 7.320 7.920 2.540 (BSC) 3.000 3.600 8.400 9.000 © 2009 Fremont Micro Devices Inc. 0.142 0.022 0.060(BSC) 0.008 0.014 0.354 0.370 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 DS3011B-page13 FT24C02A TSSOP8 PACKAGE OUTLINE DIMENSIONS Symbol D E b c E1 A A2 A1 e L H θ DS3011B-page14 Dimensions In Millimeters Dimensions In Inches Min Max Min Max 2.900 4.300 0.190 0.090 6.250 3.100 4.500 0.300 0.200 6.550 1.100 1.000 0.150 0.114 0.169 0.007 0.004 0.246 0.122 0.177 0.012 0.008 0.258 0.043 0.039 0.006 0.800 0.020 0.031 0.001 0.65 (BSC) 0.500 0.026 (BSC) 0.700 0.020 0.25 (TYP) 1° 0.028 0.01 (TYP) 7° 1° 7° © 2009 Fremont Micro Devices Inc. FT24C02A SOP8 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.006 0.010 D 4.700 5.100 0.185 0.200 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 1.270 (BSC) 0.050 (BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° © 2009 Fremont Micro Devices Inc. DS3011B-page15 FT24C02A MSOP8 PACKAGE OUTLINE DIMENSIONS Symbol A A1 A2 b c D e E E1 L θ DS3011B-page16 Dimensions In Millimeters Dimensions In Inches Min Max Min Max 0.820 0.020 0.750 0.250 0.090 2.900 1.100 0.150 0.950 0.380 0.230 3.100 0.320 0.001 0.030 0.010 0.004 0.114 0.043 0.006 0.037 0.015 0.009 0.122 0.65 (BSC) 2.900 4.750 0.400 0° 0.026 (BSC) 3.100 5.050 0.800 6° 0.114 0.187 0.016 0° 0.122 0.199 0.031 6° © 2009 Fremont Micro Devices Inc. FT24C02A DFN8 PACKAGE OUTLINE DIMENSIONS Symbol A A1 b c D D2 e Nd E E2 L h L/F Surface Electroplate Dimension(mil) © 2009 Fremont Micro Devices Inc. Min Dimensions In Millimeters Nom Max 0.70 0.18 0.18 1.90 0.75 0.02 0.25 0.20 2.00 0.80 0.05 0.03 0.25 2.10 2.90 1.50REF 0.50BSC 1.50BSC 3.00 1.60REF 0.40 0.25 3.10 0.30 0.20 0.50 0.30 NIPdAu (Nickel, Pd, Metal) 67*75 DS3011B-page17 FT24C02A SOT-23-5 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A A1 A2 b c D E E1 e e1 L 1.050 0.000 1.050 0.300 0.100 2.820 1.500 2.650 1.250 0.100 1.150 0.500 0.200 3.020 1.700 2.950 0.041 0.000 0.041 0.012 0.004 0.111 0.059 0.104 0.049 0.004 0.045 0.020 0.008 0.119 0.067 0.116 1.800 0.300 2.000 0.600 0.071 0.012 0.079 0.024  0° 8° 0° 6° DS3011B-page18 0.95 (BSC) 0.037 (BSC) © 2009 Fremont Micro Devices Inc. FT24C02A TSOT-23-5 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A A1 A2 b c D E E1 e e1 L 0.700 0.000 0.700 0.350 0.080 2.820 1.600 2.650 0.900 0.100 0.800 0.500 0.200 3.020 1.700 2.950 0.028 0.000 0.028 0.014 0.003 0.111 0.063 0.104 0.035 0.004 0.031 0.020 0.008 0.119 0.067 0.116 0.300 0.600 0.012 0.024  0° 8° 0° 8° 0.95 (BSC) 1.90 (BSC) © 2009 Fremont Micro Devices Inc. 0.037 (BSC) 0.075 (BSC) DS3011B-page19 FT24C02A APPENDIX A:REVISION HISTORY Version A: The original datasheet for FT24C02A. * Information furnished is believed to be accurate and reliable. However, Fremont Micro Devices, Incorporated (BVI) assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of Fremont Micro Devices, Incorporated (BVI). Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. Fremont Micro Devices, Incorporated (BVI) products are not authorized for use as critical components in life support devices or systems without express written approval of Fremont Micro Devices, Incorporated (BVI). The FMD logo is a registered trademark of Fremont Micro Devices, Incorporated (BVI). All other names are the property of their respective owners. DS3011B-page20 © 2009 Fremont Micro Devices Inc.
FT24C02A-UTG-T 价格&库存
很抱歉,暂时无法提供与“FT24C02A-UTG-T”相匹配的价格&库存,您可以联系我们找货
